Deck Stain Calculator: How Many Gallons Do You Need? 5/5 (10)
Hi! I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood staining and restoration. My simple deck stain facts and tips are based on my history as a wood restoration contractor. See here for more info about me.
Deck Stain Calculator: How Much Stain Do You Need?
Before staining a deck, you need to figure out the deck’s total square footage. Once this calculation is considered, you can figure out how many gallons of deck stain you need by reading the coverage rate of the stain you are buying. On average, most deck stains cover 150 to 300 sq ft per gallon per coat, depending on the age, condition, and porosity of the wood.
Quick Answer: Deck Stain Calculator
  • Calculate your deck's total square footage by adding flooring, railing, and steps measurements together.
  • Most deck stains cover 150 to 300 sq. ft. per gallon, varying by wood age, condition, and porosity.
  • A deck stain calculator helps estimate both stain amount and prepping supplies needed for refinishing.
  • Always follow the manufacturer's directions for application, as coverage rates vary by brand and stain type.
  • For fence staining, multiply length x height, then multiply by 2 to account for both sides.
  • New wood under one year old gets one coat only. For transparent, semi-transparent, and semi-solid stains on wood less than one year old, apply only one coat. New wood is denser and less porous than weathered wood and will not absorb a second coat properly. See our full guide on staining new decks.
Contents
  1. Deck Stain Calculator
  2. Fence Stain Calculator
  3. How to Calculate Deck Square Footage
  4. Coverage Rate by Stain Type
  5. How Much Prep Product Do You Need?
  6. Pro Tips on Buying the Right Amount
  7. Recommended Deck Stains
  8. Frequently Asked Questions
Interactive Deck Stain Calculator
Use the calculator below to estimate how many gallons of stain you need. Enter your measurements and select your stain type and wood condition for the most accurate estimate.
Deck Stain Estimator
New wood less than one year old should receive only 1 coat of transparent, semi-transparent, or semi-solid stain. Learn more about staining new wood.
My Pro Advice: Using most deck stain brands and types, this deck stain calculator will help you determine the proper amount of stain and prepping supplies needed to refinish your deck. This calculator is intended to provide you with an approximate estimate, and the amount varies by brand and type of stain. It is best to always follow the manufacturer’s directions when it comes to applying.
For more info, see this article: How Much Deck Stain Should I Buy
Use the calculator below to estimate how many gallons of stain you need for a fence. Click the button to expand the calculator.
Wood Deck Stain Estimator Formula
Deck Sq. Footage
Flooring Length x width =?
Railing Length x height =?
Steps Width x Depth x #of Steps =?
Add up all 3 for the Total Sq. footage.
Fence Sq. Footage
Length x height =?
Multiply x 2 for both sides = Total Sq. Footage
Tips for Measuring Your Deck
When measuring your deck it is best to use a tape measure or measuring wheel. If you do not have access to a measuring device you can come up with a close approximation by stepping the deck off. A long stride is close to a yard, which equals 3 feet. Multiply the number of steps you took by 3 and that is the approximate total in feet. Do this for all sections mentioned above to calculate your deck’s total square footage.
Be sure to add in any extra areas that are less common — lattice, skirting, benches, pergolas, or other wood structures you plan to stain.
Coverage rates vary significantly by stain type and wood condition. Use this table as a starting point, then adjust based on the specific product label.
Stain Type Coverage Per Gallon* Notes
Semi-Transparent Oil-Based 150 to 250 sq ft Penetrating; weathered wood absorbs more
Semi-Transparent Water-Based 150 to 200 sq ft Film-forming; coverage more consistent
Semi-Solid Stain 150 to 250 sq ft Heavier pigment load; coverage varies by brand
Solid Color Stain 150 to 300 sq ft Two coats required; second coat covers more
* Coverage rates shown are per coat on the first application. Second coats typically cover up to 50% farther than the first coat, as the wood has already absorbed its initial saturation.
My Pro Tip: New or smooth wood absorbs less stain than weathered, porous wood. If your deck boards are gray, rough, or deeply weathered, plan on using 20 to 40 percent more product than the label suggests. Always buy a little extra — you can return unopened cans or save them for the next maintenance cycle.
Stain quantity is only half the equation. Before you stain, you need to prep the wood. Coverage estimates below are based on Restore-A-Deck Prep Products, our recommended prep system. Here is how to estimate coverage for a typical deck.
Prep Product Typical Coverage When You Need It
Deck Cleaner 500 to 1,000 sq ft per kit New or lightly weathered wood with no old stain
Deck Stain Stripper 500 to 1,000 sq ft per kit Any deck with old or failing stain that needs removal
Wood Brightener 500 to 1,000 sq ft per kit Always — used after cleaning or stripping to neutralize pH
[woo_product_slider id=”30714″]
  • Always buy extra. It is better to have a partial gallon left over than to run short mid-project. You can return unopened cans to most retailers or save them for future maintenance coats.
  • Factor in two coats on bare wood. Most penetrating stains on bare or stripped wood require two coats. The first coat absorbs deeply; the second coat absorbs up to 50 percent less product because the wood is already partially saturated.
  • Adjust for wood porosity. Older, weathered, or heavily weathered wood can use 20 to 40 percent more stain than the label coverage rate suggests. New or smooth wood will use less.
  • Fence coverage doubles. When calculating a fence, measure one side (length x height) and multiply by two for both sides.
  • Don’t forget railings and steps. Most homeowners underestimate how much stain goes on railings and stair stringers. Always add these into your total before buying.
Now that you know how much stain you need, find the right product for your deck below.
[woo_product_slider id=”30670″]
Frequently Asked Questions About the Deck Stain Calculator
How many gallons of stain do I need for a 300 square foot deck?
For a 300 square foot deck floor with one coat of a semi-transparent stain at 150 to 250 square feet per gallon, you need 1 to 2 gallons. For two coats on bare or stripped wood, plan on 2 to 3 gallons total, since the second coat absorbs up to 50 percent less than the first. Add additional product if you are staining railings and steps, which can easily add another 100 to 150 square feet or more depending on the deck layout.
How do I measure my deck square footage for staining?
Measure the floor by multiplying length times width. Then add railing square footage by multiplying the total linear length of all railings by their height, typically 3 feet. Add step square footage by multiplying the step width by the tread depth by the number of steps. Add all three totals together for your full deck square footage. For a fence, multiply length by height and then multiply by two to account for both sides.
How much stain does a gallon cover on a deck?
Most deck stains cover 150 to 300 square feet per gallon for the first coat, depending on the stain type and the condition of the wood. Semi-transparent oil-based stains typically cover 150 to 250 square feet per gallon. Solid color stains cover 150 to 300 square feet. Weathered or porous wood absorbs more stain and will reduce coverage toward the lower end of the range. Second coats cover up to 50 percent more ground than the first coat since the wood is already partially saturated.
Do I need one coat or two coats of deck stain?
Most deck staining projects on bare or stripped wood require two coats for full protection and an even finish. The exception is new wood less than one year old — for transparent, semi-transparent, and semi-solid stains, apply only one coat, as the dense wood fibers will not absorb a second coat effectively. See our guide on staining new decks for full details.
How much extra stain should I buy as a buffer?
I recommend buying at least 10 to 15 percent more than your calculated estimate. Wood porosity varies board to board, and it is common to use more stain than expected on rough or weathered sections. Unopened cans can be returned to most retailers. If you have leftover stain in an opened can, seal it tightly and store it in a climate-controlled space for future maintenance coats — most oil-based stains stay usable for 1 to 2 years after opening.
Does the deck stain calculator account for railings and steps?
Yes — the calculator above includes separate inputs for your deck floor, railings, and steps so you get an accurate total square footage rather than just the floor measurement. Many homeowners forget to include railings and steps when estimating, which is one of the most common reasons people run short on stain mid-project. If your deck has additional features like built-in benches, lattice skirting, or a pergola, add those measurements manually to the total.
0 Comments
