The question comes up a lot about if there is a way to make your deck stain last longer. The simple answer is that you can’t make it last longer, and sometimes you may do more harm than good. Trying to apply extra coats of deck stain or a sealer may prove to be problematic. It may not affix to the wood, and may ultimately damage the appearance and lead to peeling.
- Start with a high quality deck stain from the beginning rather than adding extra coats or products later.
- Applying extra coats of deck stain will not extend longevity and may cause peeling and damage.
- Proper application is essential; even a trusted deck stain product will fail if not applied correctly.
- Avoid using a top coat over existing deck stain, as it can alter the look and feel of your deck.
- Adding a sealer over deck stain may not bond to the wood and can cause long term problems.
- Choosing a proven, reliable deck stain upfront is the best strategy for getting maximum longevity from your finish.
Longer Life for Deck Stain?
Rather than trying to apply an extra coat or product, you want to instead use a high quality deck stain to begin with. It should provide long term protection, and you want to be sure that you apply it properly. If you go with a trusted product then you can feel confident that you will get longevity out of your deck stain. Avoid the temptation of going with a top coat or other such product, as this will cause long term effects that you don’t want that may alter the look and feel of your deck overall.
More Info on Longer Last Deck Stain
Have a Deck Stain question? Ask in the comments below.
