This post was updated on May 8, 2025
How Dry Should a Deck Be Before Staining?
The first step in deck restoration and maintenance is to properly clean and prep the wood. A well-prepped surface ensures the deck stain penetrates and performs to its full potential. But how dry does the deck need to be after cleaning or rain before applying the stain?
Since our original publication, Restore-A-Deck Wood Stain has been introduced, allowing application on a damp surface. However, for all other deck stains, the wood must be completely dry before staining.
Measuring Deck Dryness Before Staining
There are two primary ways to determine if your deck is dry enough to stain:
1. Use a Moisture Meter
A moisture meter is the most accurate tool for checking wood dryness. These meters have probes that insert into the wood and provide a moisture reading.
- Check multiple areas, as some parts (e.g., decking boards exposed to direct sun) may dry faster than shaded sections (e.g., railings or spindles).
- A moisture level of 12-15% or lower is ideal for staining.
- If readings are higher, allow the deck to dry further.
2. Allow for Drying Time
If you don’t have a moisture meter, follow these general drying time guidelines:
- After cleaning: Typically, 24-48 hours of drying time is sufficient.
- After rain: If it rains before staining, wait at least 24-48 hours after the last rainfall.
- Consider climate and wood type: Humid conditions, cooler temperatures, or dense wood types may require additional drying time.
The Risks of Staining a Wet Deck
Staining before the deck is fully dry can trap moisture beneath the stain, leading to:
- Mold and mildew growth
- Premature stain failure
- Wood rot and decay over time
While waiting for the deck to dry can be frustrating—especially if unexpected rain delays your project—it’s crucial for achieving long-lasting results.
Tips for Staining Your Deck Like a Pro
In this section, I’ll expand with some staining advice beyond the topic of how long to wait after rain to stain a deck.
Choosing Proper Application Tools
Stain brushes are excellent for use on edges and in tight spaces. I recommend using Choose China bristle brushes if working with oil-based stains. Stain applicator pads, such as the 6 to 10” options from Padco, hold plenty of stain, making them effective in larger areas and railings.
Brushes attached to threaded poles are good for staining deck floors, particularly if using transparent or semi-transparent stains. Paint-style rollers are a good alternative to brushes for coating large areas if using semi-solid or solid stains. Pump-up stain sprayers work well with most transparent or semi-transparent stains, while airless sprayers work well with all stain types.
Picking the Most Suitable Stain
Deck stains are primarily grouped according to opacity and whether they have water or oil bases. Transparent stains allow the wood’s natural grains to show but offer limited UV protection, do not hide imperfections, and need to be reapplied yearly. With a paint-like consistency and durability, the texture of solid stains hides flaws but also conceals the natural appearance of the wood.
Semi-transparent and semi-solid stains offer some balance between the aforementioned extremes. I prefer deeply penetrating, semi-transparent stains because they enhance the natural wood grain while offering some UV protection. Semi-solid stains offer very good UV protection and help to hide imperfections. I suggest choosing oil-based semi-solids, as many water-based options fail to deeply penetrate and begin to prematurely peel or flake.
Cleaning and Preparation
First, always remove all items from the deck. You should use a deck cleaner on surfaces with dirt, mold, mildew, or algae, or a deck striper to eliminate existing coatings.
Lightly dampen the wood before applying a deck cleaner. Agitate the surface with a brush and then wash off and rinse with a pressure washer set between 1500 to 2400 psi. If necessary, lightly sand with 60 to 80-grit sandpaper. Visit my site for detailed instructions on properly cleaning a deck.
To remove any existing stain or coating, apply a deck stain stripper, allow roughly 20 minutes of dwell time, and rinse. After stripping or cleaning, apply a wood neutralizer or brightener. A brightener will lower pH levels and open the pores of the wood to allow for better stain penetration.
Stain Application Tips
Use the appropriate application tools outlined above for staining. Begin with vertical or hard-to-reach areas including railings, corners, and spindles before staining the larger areas. Always allow the stain time to soak in and remove any excess. Follow the manufacturer’s instructions if two coats are recommended.
Final Thoughts on Deck Staining After Rain
So, how long do you wait before staining a deck after a rain? After a rainfall, allow 48 hours for the deck to dry completely. Keep in mind that more drying time might be needed if the humidity is high or if the temperatures are cool. Allowing the wood to dry thoroughly is critical to having sustained results.
Most stain manufacturers do address how long to let a deck dry before staining. When in doubt, always review these instructions.
Pro Tip: Restore-A-Deck Wood Stain can now be applied to damp wood, which makes prepping and staining possible in one day. This RAD stain is a water-based product available in five different semi-transparent finishes. The manufacturer recommends using a single coat on new wood decks and two coats applied “wet on wet” on older wood.
FAQs: Answering Common Deck Staining Questions
How can I tell if my deck is dry enough to stain without a moisture meter?
Without a moisture meter, allow between 24 and 48 hours of dry time after cleaning or rainfall. The stain should not feel tacky to the touch. Allow extra dry time if there is extreme humidity or temperatures near 50 degrees. I’ve found that water-based stains dry quicker than oil-based stains.
Can I stain my deck right after it stops raining?
No. Decks require between 24 to 48 hours of drying time after being cleaned or exposed to rain before staining. Stain manufacturers usually recommend the wood’s moisture content be in the 12 to 17% range or less.
The most accurate way to measure the moisture content of the wood is with a moisture meter. Moisture meters are compact, personal devices that express the water content as a percentage. Most meters have probes that are inserted into the wood. Basic moisture meters commonly range from $25 to $99 but more advanced models will exceed $100.
How do weather conditions affect deck staining?
Various outdoor elements can affect the results of deck staining efforts. The “ideal” conditions for staining a deck are dry days with temperatures between 50 and 90 degrees, with low to moderate humidity.
Stains may dry too quickly at temperatures above 90 degrees or when exposed to direct sunlight, which impedes stain penetration and causes an uneven finish. Consider staining in the morning before the sun rises overhead, or use tarps to create areas of shade. Stains often dry very slowly in high humidity and dry too quickly in very low humidity.
I’ve found that oil-based stains will protect better in regions with extreme weather conditions. For example, the desert regions of the Southwest and areas with harsh winter conditions, such as Michigan and Minnesota.
Can I stain my deck if it’s been lightly misted or fogged?
Many wonder how long it takes for decks to dry after rain, but what about in foggy or misty conditions? In general, you should avoid staining your deck amid misty or foggy conditions for many of the same reasons as rain.
Both fog and mist are types of moisture that form as water droplets, which remain suspended in the air. Heavy fog will often cause condensation, which causes surface moisture and will negatively impact the stain’s adherence. Mist and fog may transition to drizzle, which contains water droplets smaller than that of rain.
This version enhances clarity, improves flow, and maintains a professional yet approachable tone. Let me know if you’d like any further refinements!
How To Apply Deck Stain to Damp Wood – DeckStainHelp.com
[youtube PWJ2_C5qmYY]
Waiting for the weather to cooperate…I not able to schedule 24hrs before and after staining. Using cabot deck correct. I now have today, last rained 6:30 am, day 2 no rain, day 3 rain possible in the afternoon. Maybe apply late today…12hrs after rain. Second coat on day 2, day 3 rain possible in the afternoon. Unfortunately the deck is in the shade.
Better to have a stained deck get rained on vs stain deck that’s not as dry as it should be?
A deck stain can typically take a rain much sooner than 24 hours.
It rains every day around six been trying to paint stain, sun in ninth degrees can I do it?
Depends on the stain but probably not.
What if you’re just rinsing of a new deck with the hose? Not pressure washing.
It may not remove the gray. See here for new wood tips: https://www.deckstainhelp.com/staining-a-new-deck/
What if u stain a new pressure treated deck and it wasn’t cured long enough? Is it fixable? after a rain , I noticed the water is laying on top for a long time. Dies that mean I sealed it too soon?
Leave it alone for now. The worst-case scenario is you will have to redo next year.
So we have a spot in our deck that has high moisture readings, it has been more than several days of no rain! I want to get it sealed before it decides to rain again but it will not dry! Is there anything I can do to speed up the process?
No, but it is probably okay to stain. What does it read and what stain brand are you suing?
I have 4 boards that are reading between 16-20. Using behr
You might want to stay away from Behr. See customer comments: https://www.deckstainhelp.com/behr-deck-stain-review/
15% or less is ideal.
If we pressure wash our deck with salt water (fresh water not available), can we proceed with sealing after it is well dry or does the remaining salt cause a problem? Thanks.
I honetsly do not know. Never heard of anyone pressure washing with salt water and if there are any issues.
If it rains 48-72 hours after cleaning the deck, will I have to clean it again or just let the deck dry for several days?
Just let it dry for a few days after a rain.
