How to Blend New and Old Deck Boards 4.7/5 (60)
This post was updated on April 12, 2025
Hello. I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior decking. My blending of new and old wood help tips are based on my history as a wood restoration contractor and actual hands-on testing. See here for more info about me.
Blending New and Old Deck Boards
At DeckStainHelp.com, I strive to remain the Internet’s number-one reference for deck stain questions, opinions, and reviews. This updated article suggests blending new and old deck boards for a beautiful, even surface. We would like to hear your thoughts, so feel free to comment below.
You would have a mix of new and old deck boards for many reasons, but it can be a common situation. The most frequent reason is that some boards needed to be replaced due to decay or wood rot while others were still in good condition. It is also common for a deck owner to protect the deck from a stain once all the repairs have been made. The dilemma is that new and old boards look very different when stained.
Understanding why this happens may help you minimize the problem. Once old deck boards weather, the top layer of wood fibers begins to gray and become soft. Newer deck boards are denser and very hard. The older boards will absorb more deck stain and appear much darker than the new, denser deck boards, which appear lighter.
Prepping New and Old Boards
To better blend new and old deck boards, it is necessary to wash the entire deck. Use a good wood cleaner and a pressure washer to remove dirt, mold, mildew, and graying from the older deck boards. The newer deck boards will normally have mill glaze on them, which can prevent good stain penetration. Use the same method to clean all the new boards and remove any mill glaze.
New and Old Decking
New and Old Decking
Cleaning the deck this way will also help the new coat of deck stain perform better. A clean wood surface prepped correctly will ensure better performance, coverage, and lasting protection.
After cleaning the wood, apply a wood brightener to the deck. A wood brightener will lighten all the older, darker boards and open the wood pores of the newer deck boards for better stain penetration. This step can help a lot when blending new and old deck boards.
It can also help to sand the boards once the deck is clean and dry. Sanding the old wood boards will remove additional softwood fibers to create a harder surface. Sanding newer, already dense boards will have the opposite effect, softening the wood fibers and removing any mill glaze that cleaning did not remove.
In addition to these steps for blending new and old deck boards, a quality semi-transparent deck stain will help. Follow these prepping and staining tips, and your newly repaired deck will be safer and look better.
My Pro Tip: A penetrating semi-solid stain will provide maximum UV protection and help blend the new and old wood better!
Need Help Blending Deck Boards? Ask Below
286 Comments
Annie
Annie
I have a mahogany deck that has a few replacement boards and the whole deck is ready to be stained. Will adding a 2nd coat to new boards help blend the color or will it just lead to over application?
Jeremy
Jeremy
Hi, the guy who helped me refurbish my deck has already cleaned and stained and the new boards he replaced look way different Than the old ones. I’m not sure if he cleaned and prepared the new boards the same as the old ones. At this point, is there anything I can do to blend? Add Another coat?
Ron
Ron
Hi, I am in Toronto Canada. I have a slight dilemma that I hope you could advise on regarding staining my new pressure treated deck, which was built having the cut ends of each board sealed, which I expect is normally a good thing except some of the clear sealer was unfortunately lapped onto some surface areas. So I had some concerns when it comes to staining to ensure the stain absorbs and the lap marks are the least noticeable as possible. My questions essentially are:
1) How long would be too long for weathering? is there a suitable amount of time I can wait before staining (not so long that the non sealed wood starts to deteriorate, but long enough that the sealed portions will absorb new stain) ?
2) Or instead, should I sand the problem areas instead of waiting too long?
3) Which stain might be able to cover over the sealed sections most unnoticeably? Preferably water based.
The deck was finished 10 days ago (Aug 2nd)
Wood: MicroPro Sienna pressure treated wood.
The deck is in full sun.
The sealer used on the cut portions was “Wolman Clear Wood Preservative with water repellent” (an older oil based product).
The MicroPro Sienna website says 2 – 8 week wait is sufficient as long as wood is dry to the touch, unless the stain manufacturer says otherwise.
I am considering whether to wait until the end of May 2020 to stain it (about 10 or so months), or sand the problem areas now before staining this September (past mid Sept will be too cold). I was planning to use a semi-transparent water based stain if I can find the most appropriate brand … the sealer was however oil based.
Any advice would be greatly appreciated.
Ron
Ron
Thanks very much for the advice!
Steven W.
Steven W.
I have some deck areas that have pressure treated boards and others with cedar boards. Is there a way to reduce the redness of the PT boards so they stain more closely to the cedar boards?
Marv Boggs
Marv Boggs
Does it make any difference whether you add new wood boards before stripping, cleaning and brightening an old cedar deck, or should you add them after?
Marv Boggs
Marv Boggs
Thanks. I’ve got to say, you have been the best help of any source I’ve turned to for advice on my deck work. Really appreciate it! Forgot to mention in my last question, I’ll be using a solid stain so I believe the new board/old boards difference will not be as apparent, other than checking in some of the old. Am I right?
Our front porch had planters on the ends and the treated deck boards were never treated. We removed the planters and the wood under them looks newer. We would like to stain the wood now, using a Cabot product that is semi transparent. We plan on prepping the entire surface. Should I do anything different to the newer looking areas? Thanks
Nick
Nick
I am in much need of advice. We purchased a house with a 2nd story deck that seems to be pretty old and has a solid red paint. Last October I added a set up stairs with pretreated wood but was waiting to seal it, then this summer I replaced all of the boards with pretreated wood on the deck because of splintering and rot but I kept the support structure and railings because all of that was in good shape but it is still all red. I know I need to wait a couple of months to stain or paint the new boards. What is my best course of actions for the next steps to get everything to match(ish)? My plan was to try and power wash the existing red off but from there I am lost as to what to do because of the big difference in the age of wood between the boards/stairs and the structure. I am assuming the older wood is too old to stain but is it wrong to paint the new wood?
Nick
Nick
Reply to  Nick
This is a picture
Scott L Strite
Scott L Strite
I have a deck that I built and stained 3 years ago with a (supposedly) 6 year semi-transparent stain. Since then I’ve had a deckboard or two split and crack so I replaced those boards today with new wood. I stained a sample piece of the new wood (see the orange-ish 2 ft. section lying in the one picture) with the same stain that I used 3 years ago but it doesn’t match my existing deck boards closely at all. The current deck boards aren’t in terrible shape so I’m thinking that stripping them probably isn’t necessary, but what steps would you recommend I do to get these new boards matching the old as best as possible? Thanks in advance.
Scott L Strite
Scott L Strite
Reply to  Scott L Strite
Here are the pictures.
Francisco
Francisco
What is the best brightener? I have a super clean deck but very dark, i need something that really brightens the wood.
Katie
Katie
Pictures for my comment below. The boards at the top and bottom of the picture are the new boards that I stained, the board at top of pic I sanded with 150 grit to see if that would help…it didn’t. The other picture is the “before.” Thanks!
Katie
Katie
Thank you so sand off or leave it alone?
Katie
Katie
Hi, novice here. I have a pressure treated deck and hired someone to stain. They replaced 2 boards and I am trying to get a stain that somewhat matches because the mismatch is driving me crazy. I have a semi transparent cedar stain down, they also put on new boards which turned yellow. I tried different stains to get to match, and it seemed I needed to go really dark, so I applied Moorish teak opaque oil based. Looked okay until it dried. I sanded one of the boards with 150 grit, only made it worse. Some dried a bit shiny which makes me think it didn’t absorb. Glad I found your site!
Questions:
1) should I try to brush paint thinner on these boards to decrease the darkness?
2) should I try to sand off with belt sander and apply another stain?
3) Should I sand some off and put another stain down?
Thanks in advance for your help. I will post pictures in another post because I don’t think my previous post worked with pictures. Thanks!!
Pat
Pat
When blending new and old deck boards together do you still have to wait months to stain the new boards? It seems kind of crazy to stain all the older boards and railings and not the new boards? Please help! Our handyman who is going to be doing the job is not quite sure himself which way to proceed?
Pat
Pat
Thank You
Robin Rose
Robin Rose
I have a deck that was improperly painted with an opaque stain (probably Behr) by the previous homeowner the year I got my house. It started flaking off within a few months. Fast forward several years and it’s time to do it right!! I’ve taken off all the flaking stain that I could so it would dry and will sand off the rest with a drum sander and edger. There will be some wood that will need to be replaced. I’m interested in using Restore-A-Deck Wood Stain. Do I need to use a cleaner and brightener before I stain or is the complete sanding sufficient? Thank you for this website; as a first timer, the information here and the accessibility of its presentation has been very helpful.
Robin Rose
Robin Rose
Thank you. Time to put the order in! Having spent an hour or two reading Q&As on your website, I’m still not clear on a few things:
1) Do I need to let the sanded wood weather before I do the clean, brighten, and stain? Or can I do it as soon as weather permits? It seems I read both options as viable. And that said, do I need to time it so all 3 tasks get done within a few days of each other? (I don’t know the waiting time or the effort involved in the clean and brighten steps).
2) Same for the new wood: one commentary said to let it weather, then do the clean, brighten, and stain. Another said to sand it along with the rest of the deck and go ahead and prep and stain it along with everything else.
3) once all is done, would it be wisest to NOT put down an outside rug? I read about rug outlines. I never had that with the opaque stain, but am wondering if it would interfere with the natural weathering that I’m guessing will take place, especially the first year after applying the Restore-A-Deck Wood Stain.
Thank you again for your help. It is a life-saver and great anxiety reducer!!!
Robin Rose
Robin Rose
‘weathering after fine grit sanding is suggested.’ I thought one did not use fine grit when sanding because it made the wood pores less penetratable, but did all the sanding with the 60 to 80 coarse grit sandpaper.
Robin Rose
Robin Rose
Can you hear me yell “Arghhh!”? It became clear after 3 hours of sanding with a drum sander that it would take several days to get the crappy (Behr) solid stain removed, if I was lucky. Plus after reading other comments about using pressure washing, stain removing products, and sanding and still not getting it all off, I realized the time and money would be better spent on new pressure treated wood. An improvement since the current deck was rotting on a number of boards and likely not PT. I even briefly contemplated composite decking (there is some the same price as PT wood) until I read the really bad reviews. I suppose I could have painted over all the blotches with a better solid stain, but I feel really untrusting of opaque stains and am wanting just wood and a semi-transparent stain. So soon I will have a new deck of PT fir/hemlock in WA state with some hot afternoon sun for our brief summer, and lots of wet for the rest of the year. Current deck gets some algal growth. Not too much traffic, but lots of pots (on wheeled plant caddies). I was aiming for RAD. I like everything you say about it and am drawn to the eco formula. But I’m wondering if an oil based stain would be better? Or if it doesn’t really matter which I use. Thanks. And yes, I will let it weather for the appropriate period of time before prepping and staining.
Robin Rose
Robin Rose
I’m still here! Just purchased the PT douglas fir decking at my local lumber store and they were adamant that it did not need to be stained; that the pressure treatment chemicals are filling any available pore space already. And yet on your website I’ve read repeatedly about staining PT wood. Mostly pine–don’t know if that makes a difference. I am also thinking that if I don’t stain now, in a few years of weathering, staining might be needed, as well as possible. What are your thoughts on this?
Kevin Richer
Kevin Richer
When restaining a fence with old panels and new panels…how do you make the stain be the same color
Micah
Micah
Great read. Thanks for putting this post together.
Question in redwood decking. I am in a new build home (Colorado, so sun and snow through the winter) withmall redwood deck. Been here 6 months, haven’t stained or treated the deck. I’d like to extend the deck but am trying to set my expectations for how that will look.
With no staining or seal on the original deck it’s now greyish after 6 months. If I add new redwood decking to extend it, should I let it get a similar weathered look through the winter and then in the Spring power wash and seal or stain? Should I do something to the current deck to stop the weathering so that the new addition can catch up? What’s my best bet for matching those colors and then protecting a redwood deck (I like the natural color so I wasn’t planning on any colored stain)?
Nicki
Nicki
Hi there!
Your posting and responses are very helpful! We have an old deck (~20 yrs old). We prepped it by power washing and sanding and deck cleaner. We are now staining with a semitransparent oil stain, using a pad. My question is, do we need to stain between the boards? Of course, a little bit has dripped down, but not sure if this is something we need to stain directly, I assume by taking a pad a running it along each edge.
Nicki
Nicki
Nicki
Thank you so much for your response! I think we will end up doing so, only because the gaps are wide enough that you can otherwise see the drips. But based on your input, we will keep it to a very light coat!
Connie Laswell
Connie Laswell
I have replaced rotten boards on Deck. I have stripped and cleaned old stain. I want to put a water sealer on next. Can I do it now or do I need to wait 30 days and let the new boards dry out so they’ll be the same color. I’m afraid to let the old boards set too long without a water sealer.
Pam
Pam
Everything has been power washed and restained. New replacement boards stick out like a sore thumb. Is there anything we can do besides just adding extra stain to new boards? Too late to start from scratch.
Just had my deck restrained and the outline from the outdoor rug is still visible.
Is there a way to correct this?
Ingeborg macci
Ingeborg macci
AskHahahaha….that was actually funny! a Question or Post a Review…
LINDA Chase
LINDA Chase
We removed outdoor carpet from a pool deck that is 17 years old…Replaced a few boards and put up new railing.. Was surprised how good the deck looked under the carpet…it has always been carpeted. Now we are contemplating a sealer such as Rust-Oleum Restore. I’ve read nothing but bad reviews on this product. Suggestions for a good sealer? Any suggestion would be appreciated…My son is determined to use Restore…
We have a 5 year old pt pine deck, partially covered. Stained for first time 1 year after construction with semi solid oil based. 2 years later, sanded bare and restained with solid water based. Built pt pine privacy fence 6 months ago. Still unstained. Beginning to grey. Built addition to deck, onto uncovered portion 2 weeks ago. Still unstained. Would like advice on getting most uniform look to all surfaces. Planning on using oil based semi solid in a darker cedar or maybe walnut (something that will hide paw prints). Thanks
Carolyn
Carolyn
Can I successfully apply semi transparent or semi solid stain on this newly cleaned two year old deck? I prefer textured luck. My goal is to preserve wood from Midwest temperatures (uv rays and cold temps).
Leslie
Leslie
We have old cedar deck. Stained every two years. We have totally sanded and ready to stain. Our boards are many different colors due to replacement. Plan to use semi-transparent stain. Do we need to use brightner 9brand?) and how long after using it do we stain? Thank you.
Scott Herny
Scott Herny
Can I use Yenkin Majestic Paint Stain on my deck over Cabots after pressure washing? Both are cedar in color.
Thank You, Scott
kenneth c hodges
kenneth c hodges
what are the chances that the Armstrong semi solid deck stain will peel if the deck is properly cleaned.thanks
Robert
Robert
Spent the time and effort to properly prep deck for oil stain. Finished applying stain and wouldn’t you know it, rain, about 12 hours after I finished. That was a week ago. Can I simply reapply stain to the entire deck now that the weather is clear for several days? Please tell me I don’t have to prep all over again.
Robert
Robert
As in whether or not the brand is the same? Can you elaborate what it depends on? Thanks
Jeff
Jeff
I have a front and back deck made with PT pine, just replaced several old, damaged boards on both. Would it be wise to let the deck age and weather for around 10-12 months to get a more uniform blend between the boards before staining, or is that unnecessary? (Was thinking of a semi transparent for the front, possibly solid for back.)
If waiting is preferable, should I also wait to strip, clean and brighten until closer to staining time or go ahead and do that now?
Jeff
Jeff
Thank you. My other question I forgot to mention was the back deck has some semi transparent that needs to come up. Does stripping take the place of cleaning, or will I need to strip, clean, then brighten?
Sorry if this has already been addressed elsewhere.
Pegmorlen43
Pegmorlen43
We have spent weeks and lots of money getting solid stain off the deck. Finally done. We added an addition 5 years ago to a 10 year old deck after solid stain removed the newer side is still very much lighter. We have stained it thinking we could just add mote stain to newer side to make it darker. This has only made it redder than the other side we used dark walnut transparent stain. I don’t want to go through the stripping process again! Are there anyway to blend this with out solid stain or redoing?
Pegmorlen43
Pegmorlen43
Are you seeing this pic
Leigh
Leigh
I have this situation (different aged wood) is semi transparent the best option?
jim
jim
what if i mix new boards and old boards , wash it, then solid color stain it? would that work better? Thanks.
I wish I had found this great site LAST weekend! I have a redwood deck of unknown age previously stained with a very dark purplish opaque stain. I pressure washed. The stain stayed in the few shady areas and in knots of the wood. I took out my belt sander to fix those areas (35 grit). The deck looks gorgeous. But after reading this site – oops! – What should I do now before staining? Or just PW, Brighten, stain?
Second, when do you know to replace the boards? I have 6 with minor surface cracks that go down about 1/4″. All are still as solid as their neighbors. And if I should replace, should I age the whole deck? THANKS for the help!
Michael
Michael
Just installed this new step and it’s raining for about a week before I installed. Should I wait until everything dries up to try to match the older boards or does it not matter? Also should I pressure wash everything then try to stain the older boards too? Thanks!
S stohl
S stohl
Have a treated deck, already stripped and used brightener… But looks like I should have replaced the rotted boards first oops…I was thinking of sanding the old boards to see if they would lighten up more(I prefer transparent stain and the color dif between new and old is still significant) so would I have to re brighten the deck?
Rich
Rich
I have an older deck that will need about 20% replacement of the deck boards. Is there a way to tell if they were PT or Cedar 2 X 6 boards? If PT, how to prep and stain to match old wood?
Brad
Brad
I have a deck that is all messed up, the whole thing needs to be sanded, stain stripped, and some boards definitely need to be replaced. Is this the correct order of operations:
1. Replace Boards
2. Stain strip
3. Sand (What grit? I have a power sander and brush, and was thinking for the more damaged poles and railings, to use the power sander, and for the furred deck boards, to use the brush.)
4. Brighten
5. Refinish/stain/everything else (I'll worry about this at a later date)
ctmeda
ctmeda
Three new boards added to replace rotten ones. Deck has already had every thing done to it before new boards were added. Now a problem. What to do to the three boards to blend them in to old deck that will be acceptable. No thought was put into this issue when the decision to replace the boards due to safety issues.
Juanita
Juanita
Since I just found this article today, I was wondering if I need to go back and do the deck cleaner when I used a pressure washer and sanding the old boards.I did nothing to the new boards yet. Can I just sand them like the rest of the deck and then do the brightener or go back and follow your suggestions? It's been a lot of work sanding if I can get the same effect as the cleaner and then move on to the brightener–would be great news! Thanks!
Juanita
Juanita
Reply to  Juanita
Could you reckoned a deck brightener brand for me? Thanks for all the help too.
Jean Williams
Jean Williams
I have a cypress ceiing in my den that we put up 31 years ago. The ceiling also had box built cypress beams, which we recently removed. We whitewashed the ceiling and it is beautiful except for where the beams were. That area won't blend with the rest of the ceiling no matter what we do. Also, there is a dark line that seems to outline where the beams were. It is a slight line but we can't get rid of it. We have tried sanding, that made the differences show up more. We tried stripper, denatured alcohol, etc and nothing we do blends the two. Any help would be greatly appreciated. We are trying to find a solution other than having to spend a fortune to put new beams back up to cover the discolored wood.
loretta
loretta
I am staining my deck with 1501 cedartone. Some boards are a nice golden color and some are dull greyish after the application. The deck was powerwashed three weeks ago. Why do you think there is such a noticeable difference.
Norrie
Norrie
I am doing the final sanding on a cedar deck. Some of the boards have been replaced. The total deck has been sanded with a 60 grit. I have three questions:
1. what grit should I use for the final sanding?
2. do I still need to use the restore a deck products since I have removed the previous stain on the old boards?
3. my preference is to use a brush, do you have any other suggestions?
I will be using the Armstrong Clark Amber Stain
MarcB
MarcB
I am trying to restore a 20 year old cedar deck (2×4). I have used a stripper and a power washer (turned down to about 1500 PSI) to remove the layers of old staing, mildew and crud. I'm having to also replace some of the boards due to rot. I have found some weathered old cedar boards at a used building supply store. The boards look very porous and grainy so I'm thinking of renting a drum floor sander to smooth out the deck. Should I still use a cleaner before I stain after I sand? BTW, I'm going to apply TWP 100 natural cedar semi transparent.
MarcB
MarcB
Reply to  MarcB
Thanks, I thought so. Someone told me the cleaner would prepare the wood to receive the stain better. I going to use Behr Premium Wood Cleaner. Is that okay?
what is the best way to get semi-transparent stain off the vertical spindles (my are 1 inch square by 3 feet)?
Monique
Monique
i have an old redwood fence that I'm attaching a new redwood trellis/posts. I was advised to use a semi transparent stain and I am planning on using the Arborwood brand but don't know what stain is going to match them both. I want something along the cedar or natural color. Do I need to buy two different colors of stain or will one work? I am getting it pressure washed and could put a brightener to it if necessary. any suggestions?
Erika R
Erika R
What grade of sandpaper would you use to sand old and new wood?
trench
trench
Question – Blending old and new deckboards. Undecided on final product. Completed cleaning of deck floor and stripping of old, oil-based stain that was mostly on the spindles. Next up: first sanding, then a brightening product. Haven't used a power sander before, but can rent one pretty cheap. Can an amateur power sander handle a heavy-duty sander without making a grievous, irreversible mistake? My deck nails/screws are countersunk fairly well, so I think I can go across them with no issues — at least, lightly. But how skilled to do you have to be to sand the entire floor evenly with no bad cuts?
Mixing new red cedar with old redwood. Should I sand before/after brightening and what grit sandpaper do you recommend for the new cedar and old redwood?
Would it make sense to sand the New wood with a rougher grit (e.g. 60) to soften the fibers and the Old wood with a smoother grit (80) to harden the fibers? I was thinking this would help equalize the absorption since the old wood absorbs like a sponge and it lays on top of the new wood after sanding both samples with 100 grit.
Also, the new wood was laid 2 weeks ago and I cleaned/brightened 1 week ago. Should I wait and let the wood age before I sand and re-brighten or should I just sand and stain it now?
JL Mitchell
JL Mitchell
I have a 6 year old deck, this will be my 3rd time staining, there are sections of the deck that the stain has peeled off. In the past I used a transparent stain, this time I believe the better road is to use solid stain. My question is after I power wash the deck what prep work do I need to complete to get one solid smooth colour on the whole deck. Also can you recommend a solid stain brand that will last more then one year.
LindaB
LindaB
Our deck has new and old wood so we used an solid stain. It started peeling so we have scraped, cleaned, and it has dried but we can't decide what product to use next. Any suggestions. We've ready many reviews of products but don't feel there are many good options. Has anyone used Duckback Superdeck Elastomeric Paint? Did it work? Can't find any reviews on it.
Ari
Ari
Reply to  LindaB
I'm in the same exact predicament. What did you decide? I was thinking about duckback also.
laren
laren
no offense, but this article doesn't address the issue suggested by the title, namely how to blend new and old deck boards. Doing what was put forth in the article will not blend them, generally speaking. If you really want a blend, then after doing what was suggested in the article, you are going to have to experiment with stains on the new boards primarily and then a protective coating over all of it.
Megan
Megan
12 years ago
We have a deck that we stained a couple years ago and an addition to the deck from earlier this year. We want to restain the older part and stain the new part to match. Should we strip the old stain first, then use an oxygen cleaner and brighten everything? We started by using a bleach-based deck cleaner on the old part, which I see now was a big mistake. It left splotchy areas of bleached wood/old stain and made the wood fuzzy. How do we get back on the right track? Thanks!
Nell Best
Nell Best
12 years ago
did not do any of the above. some slats and tops on posts are new. already stained. big mess is there hope?
1 2 3
X
286
