Armstrong Clark Hardwood Stain – Long-Lasting Protection for Exotic Hardwoods
Premium Oil-Based Stain Designed for Ipe, Mahogany, Cumaru & Other Exotic Woods
Armstrong Clark Hardwood Stain is specially formulated to provide deep-penetrating, long-lasting protection for dense, exotic hardwoods such as Ipe, Mahogany, Cumaru, Tigerwood, and other Brazilian hardwoods. Unlike standard deck stains, this formula uses conditioning oils that penetrate deep into the wood grain to restore moisture balance, enhance color retention, and provide superior weather resistance.
🔹 Why Choose Armstrong Clark Hardwood Stain?
✅ Designed for Dense Hardwoods – Penetrates deep into tight wood grain for maximum protection.
✅ Applies Easily in Direct Sunlight & Heat – Can be applied on hot days without performance issues.
✅ Flexible Application Methods – Works with a roller, brush, or airless sprayer (back-brushing recommended for even coverage).
✅ Reconditions Older Wood – Nondrying oils restore moisture while drying oils lock in UV & moisture protection.
✅ Eco-Friendly & Low-Odor – Compliant with all environmental standards and contains no offensive odors.
✅ Longer-Lasting Color Retention – Formulated with high-performance pigments & water repellents to resist UV fading & moisture damage.
🔹 Armstrong Clark Stain for Exotic Hardwoods Outperforms All Other Brands On:
✔ Ipe
✔ Mahogany
✔ Cumaru
✔ Tigerwood
✔ All Brazilian Exotic Woods
📌 Note: Amber, Mahogany, and Semi-Transparent Black Walnut are the same formula across all wood types, but they are specifically optimized for exotic hardwoods.
🔹 Available Hardwood Stain Colors
🌲 Amber
🌲 Mahogany
🌲 Semi-Transparent Black Walnut
🔹 Coverage & Application
✔ Coverage Rate: 300-400 sq. ft. per gallon (varies based on wood porosity).
✔ Apply in Thin Coats – Exotic hardwoods absorb stain differently; a thin, even application is recommended.
✔ Remove Excess Stain After 24 Hours – Any puddles or glossy spots should be wiped off with a dry rag.
📌 Pro Tip: For best results, clean & brighten your hardwood deck with Restore-A-Deck Cleaner & Brightener before staining.
✔ Get Superior Protection & Beauty for Exotic Hardwoods with Armstrong Clark!
✔ Preserve the rich, natural beauty of Ipe, Mahogany, and Cumaru!
✔ Protect against harsh UV rays, water damage, and fading!
✔ Enjoy easy application and long-lasting results!
🔹 Order Armstrong Clark Hardwood Stain today and experience the best in exotic wood protection!
Technical Info Armstrong Clark Hardwood Colors
Gallon Sizes:
1’s & 5’s
Coverage Per Gallon:
300+ sq feet Exotic Hardwoods
Coats Required:
1 Coat
Temperature:
50-110+ F
Application Tools:
Pad, Airless Sprayer, Brush
Dry Time:
8-24 Hours
Cleanup:
Mineral Spirits
VOC Limits:
50 VOCs. Compliant in all States and Canada
Product Data Sheets
Semi-Trans Hardwood Product Data
Safety Data Sheets
