Powerfully Restores Wood
Removes Stubborn Stains
Prepares New Wood for Coating
Typical Uses
Important Note
STEP 1: PREPARE
Safety & Precautions
How to Apply
Coverage
- Wood density and smoothness
Application Steps
- Pre-wet the wood surface
- Apply generously using:
- Brush
- Roller
- Broom
- Low-pressure garden sprayer
Removal (Very Important)
Best practice:
After Cleaning
- Light sanding or
Clean-Up
