✔ Wood & Composite Decks
✔ Brick & Paver Patios
✔ Asphalt & Tile Roofs
✔ Outdoor Furniture & Fences
🔹 Coverage & Maintenance
✔ Covers Over 1,000 Sq. Ft.
DEFY Composite Deck Cleaner
No, it should not.
