Restore-A-Deck Wood Cleaner – The #1 Rated Deck Cleaner
Powerful & Eco-Friendly Cleaning for Wood & Composite Decks
Restore-A-Deck Wood Cleaner is a highly effective, professional-grade powdered concentrate that safely cleans, restores, and preps wood and composite surfaces. This Step 1 cleaner in the Restore-A-Deck system removes dirt, grime, mildew, and UV-induced graying, bringing back the natural beauty of wood decks, fences, stairs, and siding.
🌱 Eco-Safe Formula – Will not harm pets, grass, or plants
💰 Cost-Effective – Makes 5 gallons of cleaner for less than $6 per gallon
🏆 #1 Rated Deck Cleaner – Used by homeowners & professionals alike
🔹 Why Choose Restore-A-Deck Wood Cleaner?
✅ Removes Dirt, Mold, Mildew & Weathered Graying – Restores wood to its original natural color.
✅ Designed for Exterior Wood & Composite Decking – Works on all horizontal & vertical surfaces.
✅ Prepares Wood for Staining – Ensures proper adhesion for best stain performance.
✅ Easy-to-Use Powdered Formula – Mixes with water to make 5 gallons, covering 750-1,000 sq. ft.
✅ Safe & Biodegradable – Won’t harm wood fibers, landscaping, or pets.
✅ Cost-Effective – Far cheaper than pre-mixed cleaners, saving you money on deck maintenance.
📌 Note: Restore-A-Deck Wood Cleaner slightly darkens wood. Use Restore-A-Deck Wood Brightener afterward to neutralize & brighten the wood back to its original color.
🔹 Where to Use Restore-A-Deck Wood Cleaner?
✔ Wood & Composite Decks
✔ Wood Fences & Railings
✔ Outdoor Stairs & Walkways
✔ Siding & Log Homes
✔ Patios & Pergolas
📌 Not a Stain Stripper: This is a cleaner, not a stain remover. If you need to remove a semi-transparent stain, use Restore-A-Deck Stain Stripper instead.
🔹 How to Use Restore-A-Deck Wood Cleaner
1️⃣ Mix Solution: Add one container to 5 gallons of water.
2️⃣ Apply to Surface: Use a pump sprayer, brush, or mop to saturate the wood.
3️⃣ Let it Sit for 10-15 Minutes: The cleaner will foam and lift dirt, mildew, and graying.
4️⃣ Scrub if Needed: Use a stiff-bristle brush for deep stains.
5️⃣ Rinse Thoroughly: Use a garden hose or pressure washer to remove all residue.
6️⃣ Follow Up with Restore-A-Deck Wood Brightener – This neutralizes the cleaner and restores natural color.
✔ Restore & Prep Your Deck for Staining with Restore-A-Deck Wood Cleaner!
✔ Removes mold, mildew, and graying from wood & composite decks!
✔ Prepares wood for staining by improving stain adhesion!
✔ Eco-friendly, cost-effective, and easy to use!
🔹 Order Restore-A-Deck Wood Cleaner today and give your deck a fresh, clean start!
Defy Wood Cleaner 2 Pounds
Hello, I have a newer deck and after speaking with you last fall we agreed it was best to wait until spring to clean and brighten the new pine boards. I bought the complete restore a deck cleaner and brightner kit. Today I started the cleaning process on my 300 SQ ft deck. I followed the instructions. I have then been rinsing the cleaner for about an hour as I’m seeing and feeling a slimy substance left on the boards pictures attached. Could you please advise? Thanks Mike in Ohio.
Yes, that is the oxidation residue that was removed during cleaning. It is normal. Rinse that off before it dries.
Hi Scott
I tried rinsing this off before drying but it would not budge. Very jell like. Hose water had no effect. I’m attaching new photos of this morning. I’m at a loss on what to do. I don’t have any of the cleaner left, just brightner.
That is not oxidation removal (as in the other picture) in this picture, but furring. This can happen during prep for a variety of reasons. See tips:
Hi Scott
I guess I’m not done asking for your expertise. I do apologize and appreciate what you do. Anyway, I started late afternoon cleaning my deck and couldn’t go right to brightner. I ended up with fuzzies.
With your advice and then spent the next 2 afternoons sanding them off. (At least what I understood them to be).
The next day (today) I have spent the afternoon applying the brightner in sections. I have put hundreds of gallons of hose water in rinsing to the best of my knowledge.
I’m attaching pictures. When wet the deck looks great. When dry it turns white. I’m exhausted. Can I stain or not?
Thank you again
Yes, stain. It will look great!
I used green 3m pads. Also we are now expecting 4 days of rain. Will I still be good after this system has moved through? Thanks again for everything!
Yes, just remove any debris prior to staining. AC stains need 48 hours after prep or rain to dry. Post some pics when done.
Another picture
How fine of a grit did you sand?
Another picture
Here’s another picture from yesterday showing the oxidation laying on the boards as a jell like substance that would not rinse off.
