Restore-A-Deck Semi-Transparent Stain & Prep Combo Kit – Stain & Prep in One Day!
Everything You Need for a Beautiful, Long-Lasting Finish
The Restore-A-Deck Semi-Transparent Stain & Prep Combo Kit is a complete deck restoration system that allows you to clean, brighten, and stain your wood all in the same day. This kit includes:
✔ (2) 2.5-Gallon Containers (Total 5 Gallons) of Restore-A-Deck Semi-Transparent Wood Stain
✔ (1) Restore-A-Deck Step 1 Wood Cleaner
✔ (1) Restore-A-Deck Step 2 Wood Brightener
With this all-in-one system, you can quickly prep and protect your deck, fence, or wood surfaces without waiting days between steps.
🌿 Eco-Safe, Low VOC, and Water-Based – Safe for wood, pets, grass, and plants when properly rinsed
🌞 Stain & Protect in Just One Day – No waiting between prep & staining
🏆 #1 Rated Deck Restoration System – Trusted by homeowners & professionals
🔹 Why Choose the Restore-A-Deck Stain & Prep Combo Kit?
✅ Clean, Brighten, & Stain in One Day – Saves time with a fast and easy application process.
✅ Advanced Semi-Transparent Stain – Provides deep wood penetration & long-lasting protection.
✅ Prevents UV & Moisture Damage – Blocks harmful sun rays, water absorption, & mold growth.
✅ Perfect for All Exterior Wood Surfaces – Works on decks, fences, log homes, siding, outdoor furniture, and more.
✅ Cost-Effective Solution – Professional-quality results at a fraction of the cost.
✅ Water-Based & Easy Cleanup – No harsh odors or difficult cleanup.
📌 New Wood Note: New wood must weather & be prepped before staining to ensure proper adhesion.
🔹 What’s Included in the Restore-A-Deck Stain & Prep Combo Kit?
(5 Gallons) Restore-A-Deck Semi-Transparent Wood Stain
✔ Deep penetrating, water-based stain for superior protection
✔ Prevents graying, cracking, and water damage
✔ Applies to dry or damp wood – Stain the same day as prep
✔ Eco-friendly, low VOC, and safe for all exterior wood
✔ Dries to a flat, natural-looking finish
Available in 4 Beautiful Semi-Transparent Colors:
🎨 Natural – Enhances wood’s natural tones
🎨 Cedar – Rich, warm wood finish
🎨 Light Walnut – Medium, warm brown
🎨 Dark Walnut – Deep, rich brown
📏 Coverage: 100-200 sq. ft. per gallon (varies by wood porosity).
Step 1: Restore-A-Deck Wood Cleaner
✔ Removes dirt, mold, mildew, and grayed wood fibers
✔ Prepares wood for staining by opening wood pores
✔ Works on all wood types, including composite decking
✔ Safe for pets, plants, and grass when properly rinsed
📏 Coverage: 750-1,000 sq. ft. per container.
Step 2: Restore-A-Deck Wood Brightener
✔ Neutralizes the wood cleaner & restores natural color
✔ Removes rust stains & tannin stains from fallen leaves
✔ Helps stains absorb more evenly & last longer
✔ Eco-safe & easy to use
🔹 Where to Use the Restore-A-Deck Stain & Prep Combo Kit?
✔ Wood Decks & Railings
✔ Fences & Pergolas
✔ Siding & Log Homes
✔ Outdoor Furniture & Playsets
📌 Perfect for preparing wood before staining for long-lasting protection.
🔹 How to Use the Restore-A-Deck Stain & Prep Combo Kit
Step 1: Clean Your Wood with Restore-A-Deck Cleaner
1️⃣ Mix the Cleaner: Each container makes 5 gallons.
2️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the wood surface.
3️⃣ Let Sit for 10-15 Minutes: The cleaner foams and lifts dirt & grayed wood fibers.
4️⃣ Scrub or Pressure Wash Off: Rinse thoroughly with a garden hose or pressure washer.
Step 2: Brighten the Wood with Restore-A-Deck Brightener
5️⃣ Mix the Brightener: Each container makes 5 gallons.
6️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the surface.
7️⃣ Let Sit for 10-15 Minutes: Neutralizes the cleaner and restores wood pH balance.
Step 3: Apply Restore-A-Deck Semi-Transparent Stain
9️⃣ Ensure Surface is Ready: All standing water should be dried off (typically 2-4 hours after prep).
🔟 Apply Stain Using Brush, Roller, or Pump Sprayer: Work wet-on-wet for even absorption.
1️⃣1️⃣ Back-Brush or Use a Stain Pad: Ensures even penetration & smooth finish.
1️⃣2️⃣ Let Dry Completely: Allow 24-48 hours before heavy foot traffic.
📌 For detailed guides:
- Aplying RAD Stain Wet-on-Wet
- How to Apply RAD Stain to Damp Wood
- RAD Stain & New Wood Prep
- Two-Tone Deck Application Tips
✔ Get a Complete Deck Restoration in Just One Day!
✔ Clean, brighten, & stain your wood in a single day!
✔ Prevents graying, water damage, & mold growth for years!
✔ Eco-friendly, easy to use, and works on multiple wood surfaces!
🔹 Order the Restore-A-Deck Stain & Prep Combo Kit today and give your deck or exterior wood surfaces a long-lasting, beautiful finish!
AVAILABLE SEMI-TRANSPARENT COLORS:
NATURAL, CEDAR, LIGHT WALNUT, DARK WALNUT, COTTAGE GRAY
