Restore A Deck Solid Stain and Prep on the Same Day!
Restore-A-Deck Solid Color Wood Stain – Durable, Opaque Protection
High-Performance Solid Stain & Sealer in One!
Restore-A-Deck Solid Color Wood Stain is an extremely durable, synthetic-resin, opaque wood finish that provides maximum protection against water, fungi, and UV damage. This VOC-compliant, water-based stain is designed for all exterior wood surfaces, delivering a beautiful matte finish that resists peeling, cracking, and fading.
✔ Applies to Dry or Damp Wood – Stain the same day as prep!
✔ Provides Full UV Protection – Prevents graying & wood damage
✔ Seals & Protects Wood in One Step – Waterproofs while adding color
🏆 #1 Rated Solid Deck Stain for Long-Lasting Protection
🔹 Why Choose Restore-A-Deck Solid Color Stain?
✅ Apply the Same Day as Cleaning – No waiting for wood to dry!
✅ 100% Opaque Coverage – Hides imperfections & provides a uniform color.
✅ Advanced Water-Based Technology – Durable protection without peeling.
✅ Eco-Safe & Low VOC – Compliant in all 50 states & Canada.
✅ Ideal for All Wood Surfaces – Decks, fences, siding, outdoor furniture, & log homes.
✅ Flat, Matte Finish for a Modern Look – Seals & enhances wood grain while providing solid color protection.
📌 New Wood Note: New wood must weather & be prepped before staining to ensure proper adhesion and performance.
🔹 Where to Use Restore-A-Deck Solid Color Stain?
✔ Decks, Railings & Stairs
✔ Fences & Pergolas
✔ Wood Siding & Log Homes
✔ Gazebos, Outdoor Furniture & Playsets
📌 Perfect for older or weathered wood that needs full coverage.
🔹 Coverage & Application Instructions
📏 Coverage: 200-350 sq. ft. per gallon per coat. (varies by wood porosity). 2 coats are needed for proper coverage.
🕒 Dry Time: 2-4 hours at 70º F, <50% humidity.
🌞 Can Be Applied in Sun or Shade
How to Apply Restore-A-Deck Solid Color Stain
1️⃣ Prep the Wood: Use Restore-A-Deck Cleaner or Stain Stripper followed by Restore-A-Deck Brightener.
2️⃣ Ensure Surface is Ready: All standing water should be dried off (typically 2-4 hours after prep).
3️⃣ Apply Stain Using Brush, Roller, or Pump Sprayer: Work wet-on-wet for even absorption.
4️⃣ Back-Brush or Use a Stain Pad: Ensures even penetration & smooth finish.
5️⃣ Let Dry Completely: Allow 24-48 hours before heavy foot traffic.
📌 For detailed guides:
- How to Apply RAD Stain to Damp Wood
- Restore-A-Deck Stain & New Wood Prep
- Two-Tone Deck Application Tips
🔹 Available Colors
🎨 Choose from Pre-Mixed Solid Color Finishes for Full Coverage:
✔ White
✔ Desert Taupe
✔ Cypress
✔ Brown Oak
✔ Coastal Gray
✔ Get Full-Coverage, Long-Lasting Protection with Restore-A-Deck Solid Stain!
✔ Stain & protect your wood the same day as prep!
✔ 100% opaque coverage for maximum UV & moisture protection!
✔ Eco-friendly, water-based stain for easy cleanup & maintenance!
🔹 Order Restore-A-Deck Solid Stain today and give your deck or exterior wood surfaces a durable, beautiful finish!
Order Solid Stain Samples: RAD Solid Stain Samples
Download RAD Solid Stain Color Chart
Note: We would suggest downloading and printing the color chart by clicking the picture to the left. There is also a full version of the color chart picture below and in the product pictures above.
*Colors will vary based on full sun or shade.
Color Chart Below is the RAD Solid Stain on Wood Samples
Available Solid Stain Colors: Espresso, Brown Oak, Classic White, Cypress, Desert Taupe, Coastal Gray
I’m kinda stuck at this point with Acrylic which really is not good. Just looking for something acrylic that is better then cabot. Maybe restore a deck. The deck is pretty big and wish i never used the acrylic.
Did you have a question(s)?
My deck is currently stained with brown cabot acrylic and it only lasts a couple of years before peeling. I’m wondering if this is a better solution and if I can get sample colors?
The RAD Solid stain is much better than any other solid stain brand, but the key is prep. Any failing coatings should be removed first.
Samples: https://www.deckstainhelp.com/product/restore-a-deck-solid-stain-sample/
What if the current condition of the deck is pealing in some places. What prep do you recommend
Add some pics in the comments of your deck for prep advice.
Used the restore-a-deck solid stain on my fence and couldn’t be more pleased. Smooth application, great coverage, and a great life span.
