This post was updated on March 17, 2026
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Best Deck Stain reviews and help tips are based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
Elevate Your Deck with the Best Wood Stains & Sealers
Whether preparing for a DIY deck-staining project or looking for the perfect stain to share with your contractor, I’ve got you covered. I have rounded up the eight best deck stains available in 2026, including oil-based stains, water-based stains, and semi-transparent and solid options.
Scott’s Expert Guide to Choosing the Best Deck Stains
Questions About Which Deck Stain or Sealer to Use?
Want personalized help? Post your questions below in the comments, and I’ll gladly guide you toward the best deck stain and sealer. Please include any pictures you may have and a brief history of the deck.
Over 30,000 Q&A Comments Below on this article. Ask Below, I Love to Help!
My Recommended Best Deck Stains and Sealers at a Glance
Click on the link and jump straight to the review:
- Top-Rated Deck Stain: TWP 100 Pro Series Stain Review — This deep-penetrating, long-lasting, semi-transparent stain is oil-based, easy to apply, and withstands the elements for up to 3 years.
- Recommended Semi-Transparent: Restore-A-Deck Semi-Transparent Wood Stain Review — Restore-A-Deck’s UV-resistant, semi-transparent stain can be applied to damp wood, which means we can prep your deck and apply the stain in one day.
- Leading Semi-Solid: TWP® Semi-Solid Pro-Series
- Oil-Based: TWP 100 Pro Series Semi-Transparent
- Best Water-Based: Restore-A-Deck semi-transparent deck stain
- Recommended Solid Color: Restore-A-Deck Solid Color Wood & Deck Stain
- Best-Applying: Armstrong-Clark Wood Stain — This long-time favorite is a hard-working, deep-penetrating option that goes on easily and allows for simple maintenance.
- Excellent Semi-Solid Wood: TWP Pro Series Semi-Solid Stain — TWP’s semi-solid stain goes on quickly, holds color well, and offers maximum UV protection and a variety of color palettes to choose from.
- Outstanding Wood Preservative Deck Stain: TWP 1500 Series Semi-Transparent Stain — TWP’s 1500 Series consistently ranks as one of my top options for deck stains, thanks to its deep-penetrating formula, UV- and mold-resistant properties, and long-lasting color.
- Recommended for Mildew: Defy Extreme Semi-Transparent Wood Stain — Defy’s water-based Extreme Wood Stain offers rich, penetrating color and an infusion of zinc oxide Nano-particles that prevent damage from UV rays, mold, and mildew.
- Best Deck-Resurface Coating: Gulf Synthetics Deck Revive
Steps to Picking the Perfect Deck Stain for Your Needs
Is There a #1 Rated Best Deck Stain or Sealer?
Transparent Stains
As the name suggests, transparent stains are clear or very lightly tinted stains that help seal and protect wooden decks while still allowing the wood grain to show through.
Semi-Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
Common Deck Staining Mistakes and How to Avoid Them
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly.
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time.
From: $41.99 | From: $47.99* | From: $65.99* | From: $69.95* |
*Free Shipping Included
- Ease of application
- Wear and tear after 2 years
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
5. Ready Seal Wood Stain
3. Defy Extreme Stain
- Scott’s Pro Tip: My most used deck stain in the past 30 years! We have used the TWP 100 Series on many 1000s of decks.
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Scott’s Pro Tip: My favorite deck stain to save time and money. We prep and stain on the same day.
My Test Deck Stats
UV Exposure: 50% Full Sun
- Scott’s Pro Tip: Regarding ease of application and performance, the Armstrong Clark stain is one of my top stains. We love their semi-solid colors and performance.
My Test Deck Stats
Deck Square Footage: 600
- Scott’s Pro Tip: My favorite penetrating semi-solid wood and deck stain soaks into the wood and provides excellent UV protection.
My Test Deck Stats
When Tested: August 2020
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Scott’s Pro Tip: My favorite current penetrating semi-transparent oil-based stain is the TWP 1500 Series. Michigan switched to low-VOC, so I now use it on the majority of decks that I restore.
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Scott’s Pro Tip: My new favorite IPE and Hardwood Deck stain is the first stain I have ever seen last more than one year on exotic hardwoods.
My Test Deck Stats
Stain Color Used: Chesnut
- Scott’s Pro Tip: The Defy Extremes is one of my top choices when using a water-based semi-transparent wood stain.
My Test Deck Stats
Stain Color Used: Cedartone
- Scott’s Pro Tip: Ready Seal Stain is not my favorite since it requires annual recoating, but I do like that it applies easily. Ready Seal does not cure fully and can rub off the wood on clothing.
My Test Deck Stats
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Deck Stain Facts: Frequently Sought Answers
When helping people choose the best deck stain and sealer, I often hear many of the same questions. Here are some facts and words of advice about exterior wood stain that can help answer these questions:
What is a deck stain?
Deck stain is a type of finish applied to the wooden boards of your deck. Generally speaking, deck stains come in three types —transparent, semi-transparent, and opaque —and are available in a wide range of colors to suit your taste.
Answer: The deck stain must be tinted to protect it from UV graying. I prefer semi-transparent stains, as they do not mask or cover the wood but highlight the grain while providing UV protection.
Answer: My favorite deck stains have been penetrating semi-transparent and semi-solid stains. These stain types allow the wood grain to show, and if they truly soak into the wood grain, reapplying is easier down the road.
What deck stain types can be cleaned and recoated as needed?
Answer: Penetrating deck stains are not prone to peeling, and we can clean and reapply them as needed. Deck stains that dry or film on top of the wood are much harder to maintain and prep when reapplying.
Answer: Absolutely! Deck stains are wood stains and work very well for wood fences, vertical wood siding, and log cabins. They last even 2-3 times longer on vertical wood.
The waiting period before staining a new deck can depend on the material used to build it. Take a closer look at our recommended time frames based on deck material:
- New, smooth wood decks: Wait at least 3 months before applying stain.
- Rough-hewn wood decks: No wait time is needed; you can apply stain as soon as the wood is clean and dry.
- Kiln-dried or KDAT wood decks: Wait 1-2 months before applying stain.
For more information, check out this guide on how long to wait before applying stain to your deck.
The most popular deck stain colors of 2026 include:
- Cedar tones
- Brown tones
- Honey tones
- Redwood tones
The best way to apply a deck stain can vary based on the product used, but my personal favorite applicators include flooring brushes and stain pads. Learn more in this guide to the best deck stain applicators.
What’s the difference between a deck stain and deck paint?
Deck stain and deck paint are similar in that they add color to a wooden deck. However, deck stain typically penetrates into the fibers of wooden deck boards and often results in a more natural final product. On the other hand, deck paint is typically thicker and creates an opaque layer of color over the wood.
What’s the difference between water- and oil-based deck stain?
Both water- and oil-based deck stains can provide rich color and long-lasting protection against moisture and UV damage. However, there are some differences between the two stains.
For instance, oil-based stains may offer advanced protection against warping or cracking and last longer than water-based stains. However, water-based stains are generally more environmentally friendly and easier to apply and clean up. Many water-based stains also feature additives to prevent fungal damage or wood rot. Learn more in this guide to the differences between water—and oil-based stains.
The 3 best deck stain brands for decks in full sun are TWP, Restore-A-Deck, and Armstrong Clark. The TWP 100 Pro Series semi-transparent penetrating deck stains in darker tints are best for most decks. TWP also has a semi-solid penetrating deck stain that works well in full sun. Restore-A-Deck has semi-transparent and solid deck stains for full sun. Armstrong Clark is a high-quality oil based deck stain.
Additional Deck Stain Rating Questions
If you have questions on this review of deck stains, please ask me below in the comments.
Want My Help Finding a Deck Stain?
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
- TWP 1500 Series
- Armstrong-Clark Deck and Wood Stain
- Restore-A-Deck Wood Stain
- Defy Extreme Wood Stain
I am here to help you find the best wood deck stain for your situation! Just post a comment below with answers to these questions.
Im going a small side deck (new wood). I want to get a white washed look with lots of woodgrain showing through. I don’t want a solid white look. What would you suggest? Thanks.
It is not possible to white wash a deck or get the look you want.
I live in WY. we have harsh winters. we have a porch cedar deck. Only 2 yrs old. the product I first used started to peel in 1.5 yrs. the TWP, as well as some other brands sound good. Most of the railing is in fair condition. The deck is stain is nearly gone. I would like to maintain the natural color of the cedar if possible. What would u recommend?
Make sure to remove the old coating fully first. Try the TWP 100 Series. You need one of the tinted coors if you want UV protection from graying.
Is there any chance you are going to review (without bias) other National brands of deck stain? There are lot of other ones out there that aren’t just the ones you sell on the online store you operate. I feel as though it would be a great benefit to the consumers. Specifically Olympic, Cabot, Thompson, Benjamin mohr.
All of those brands you mentioned have been reviewed on this site numerous times by us and have 100s of consumer reviews as well below each. You can use the search icon (to the right of main menu) to find them or just scroll through all the wood and deck stain reviews. https://www.deckstainhelp.com/category/deck-product-reviews/deck-stain-reviews/
I’ve built a new redwood deck and it has aged about 3 months now. I’ve sanded with 60 grit to remove the sap, tannin bleed, and even out the surface. I plan to clean the wood next using Behr wood cleaner to make sure any mill glaze and sanding dust is removed and then stain with Cabot ATO mahogany flame. Do I need to do anything after using the wood cleaner prior to staining other than letting it dry a couple days?
No, but you might want to consider better prep and stain products. There are much better brands.
We have an old but freshly pressure washed/planed redwood deck and are looking for a clear sealer. We are fine with washing and re-applying yearly but do not want to have to scrape/sand etc. We’re on the coast in Sonoma county, California and get lots of shade in the winter and blazing sun in the summer. We don’t have mildew issues on the deck but do on some of the more protected vertical posts supporting our awning. The previous stain was Cabot Water Based Semi—Transparent 1306 Neutral Base Cordovan Brown. It didn’t so much fail as simply wore out over the years. Actually it’s still fine in protected areas. We didn’t do anything for at least ten years and as a result the surface was dry, splintered and cracked with some rot where wood met. We don’t want to use that product again as we don’t want to change the color of the redwood. We’re looking at the Cabot 3,000 translucent in natural, Defy (if we can find a recommended formula approved for California). Any suggestions would be most welcome!
Clear means no UV protection from graying. It must be tinted. Do you want it to gray in months?
We were hoping that reapplying yearly would do the trick to keep it looking like redwood rather than “redwood color”. I suppose our tolerance for gray has to do with how lazy we are feeling when we notice it. What product do you recommend that would give us the most natural look with the most protection, ideally 1 yr for uv, but longer for water resistance?
I have recently installed new red cedar 6″ T&G siding rough side out on a covered deck. What is the best process to preserve the way it looks new. We do not want to change the color in this area.
No tint or color means no UV protection from graying. Are you okay with this?
Hi Scott, I do not want gray. I want the new cedar look to remain. See picts I attached. Is there any product that will preserve the new look?
That is impossible. It must have a tint to prevent UV graying:
Have you tried Expert Stain and Seal, boasted as the best stain on facebook groups??
We have. It is not bad but not as good as other brands. It has not warranted a review as of yet due.
I should add that durability and longevity of the finish are especially important to me. It’s also easier to work with water based so that’s preferred, but if the oil based alternative is more durable or generally better I’d use that.
I installed a lot of fencing and stair railings around my yard using 4×4, 2×4 and 2x 8 pressure treated lumber last fall . Now it’s time to finish it and my wife wants it stained a hunter green. What’s the best product to use either solid or semi solid that comes in colors or specifically green? I’m located in Putnam County NY so we get hot summers with a lot of sun, a lot of rain and cold winters.
You will need a custom tint to achieve this color. Only a solid stain would work:
Thanks for the response! Are there custom tints for semi transparent stains that can tint the wood green? I don’t need the finish to be of solid color. Also I read your take about solid color stains being a last resort approach, so I want to see what other options there are, if any.
No custom tints for semi-transparent stains. If they (example Behr stains) say they can do that, then it will end up looking fully opaque.
I am looking for a recommendation for a semi transparent deck stain for a mahogany deck that has been stained in the past with PPG timeless. I can not use TWP because of VOC laws in MA. What would be the next best option? Thank you.
Use one of these brands for hardwood decking: https://www.deckstainhelp.com/hardwood-deck-stains/
Hi! I though I submitted this question a month or so ago, but do not find it in the queue. So, apologies if this is a repeat….
I have new red cedar deck boards to install, and would like a recommendation for the best clear sealant. It is uncovered, and might eventually have a chlorinated hot tub on it. I live in Iowa.
Also: I’ve been letting the boards sit out on the deck frame for weathering, as some sites suggest. Should I turn them over to weather on both sides? How long from the last rainfall should I wait, before sealing them? And is it best to seal all 6 sides?
See this about new wodo and what to prep and stain with:
No need weather both sides. No need to stain all sides.
Hello there. We recently stained our deck that was a year old. We prepped before by power washing and sanding. We used Valspar Semi Transparent All in One Stain and Sealer in a darker brown color.
Since staining we have notice a lot of dirt from foot traffic that doesn’t come clean with water and a soft brush or even a mild deck cleaner. Is this something we will keep having to battle with this specific stain?
Any suggestions to help keep the deck clean? Can we put another sealer on top?
If we need to remove and restain with something better will we have to strip/sand before hand?
Appreciate any insight and advice.
Eric
You cannot top coat over a deck stain with a sealer. There is not anything you can do to prevent this, sorry. You would have to fully strip and sand to swith to a better stain brand.
Hi! I’d like to stain 2 and possibly 2 other different surfaces to be about the same color.
1) new chicken coop 2) old greenhouse 3) old fencing 4) old deck
The chicken coop will be new construction, we will stain some sort of wood siding. Everything else was here and like this when we moved in. The greenhouse and fence appear to be very weathered, never treated wood. The thing with the fence and greenhouse is it’s in the garden, so I’m concerned about the chemicals used during wood cleaning and prep.
The old deck was Trex decking which was old and peeling. We did a solid stain that was supposed to work for that kind of material but it didn’t last. Even in the areas that weren’t already peeling.
Would like to do something like a natural semi-transparent Cedar. Some trim will either be solid stained or painted black.
– What would be the process for each surface?
– Do any of the stains you recommend work on Trex decks?
– Is there a way to prep the greenhouse/fence without chemicals getting into the garden?
– Or what would happen if we skipped clean and prep on the weathered greenhouse?
Got a lot we’d like to do here so really appreciate the help!
You always have to prep when staining. For older wood needs a good deck cleaner and pressure washing. Brighten after. Stain with one of these brands:
No idea how to fix the painted Trex. It cannot be sanded off and not sure of strippers will work.
Hi, we are in Houston, TX area. We built our deck new in November 2022 with pressure treated wood. We are currently waiting for the treatment to “dry out” and want to stain it for the first time. I’m looking for a two toned grey deck. It receives pretty hot mid day sun. Thanks I’m advance for your help.
See tips here for two toned decks: https://www.deckstainhelp.com/why-have-a-two-toned-deck/
We want to re-stain a 20 year old composite deck that was stained 7 years ago. There is no peeling, but the first stain job was tacky for 2 weeks, What prep and coating products do you recommend?
Pictures?
Hello! I have a 3 year old cedar deck that was varnished. It peeled horribly. We have since sanded off that finish. I don’t know the best product to use on it now. We are in middle Tennessee. HOT summers with plenty of sun and lots of rainAnd high humidity. Mildew can be a problem. I want to see the beauty of this cedar. What is your recommendation? Thank you
Clean and brighten the wood after sanding. Stain with TWP 100 Series or Restore A Deck Wood stains.
In which state is your deck located? Toronto, Ontario Canada
How much sun/shade does your deck get? West facing. Afternoon sun from 11 am to 5 pm (summer). Lots of snow from Jan – April (removed promptly after each snowfall but piled in one corner of the deck)
What type of wood is your deck made of? Pressure treated wood
Do you have mold or mildew issues? almost none
Why/how did the previous stain fail? Started wearing off after about 3 years in high traffic areas only. Completely intact in very low traffic areas after 8 years (also there WAS shade from a large tree but the tree was cut down this year, so much more exposure to sun now)
What type and brand (if known) of stain did you use last time? Dulux solid stain. It was cleaned with a power washer before staining over previously stained wood in 2015. Not washed with deck cleaner or brightener, just light pole sanding of deck prior to staining.
Appreciate your recommendation for Canadian winters between Benjamin Moore Arbercoat solid stain, Dulux solid stain and Behr solid stain or any others you suggest if not these ones.
Many thanks….trevor
None of those solid stains. See here:
As for prep, see this:
Hello! I am a new home owner in Northern Oregon and I need help knowing where to start to take care of my deck. I dont know the wood type or what was done previously, but I am guessing stained at one point. There is no peeling, mold, or mildew. It on the east side under a covered porch so the end of the deck can get 6hrs of sun. It has some rough spots in need of sanding at the very least. Where do i start and what stain would work best?
Strip and brighten for prep. Look at Restore A Deck Products. Stain with TWP 1500 Series or Restore A Deck Stains.
Hi there – I have a 2 year old redwood deck that has weathered to a natural gray. I don’t mind the gray – I just want to maintain it for longevity. Its a large deck around a swimming pool and it gets full sun. My understanding is that a semi transparent stain is best for UV protection but I don’t want to change the color dramatically too dramatically. What would be the most natural looking product to maintain the deck? I’m so confused by all the options!
You cannot stain or seal over the gray oxidation. You have to remove it first before applying a deck stain or sealer. You can then apply a clear (not Natural) coating that will protect the wood and then allow the wood to gray again naturally. Try TWP 1500 in Clear.
The company that I hired to stain my deck has applied Behr Arborcoat on my deck. They had fist applied a coat of Sherwin Williams semi transparent stain but it turned out that it did not cover equally due to work that was not done properly. The Arborcoat is covering well but I happened to check the comments that it was not the best product and that it would peel easily.
I have not yet payed them and I really not know what to do. What it says on the can is that it is a sem transparent stain and that it is oil based. What should I do? I hired them because I wanted the work to be done professionally.
You have to pay them for doing the work.
I am attempting to stain a redwood deck. It is 40 plus years old. It has been stained maybe 3 times with oil based. Has been more than 10 years since last staining. I think the last stain was solid SuperDeck but it has pretty much dissapeared down to bare wood.
I pressure washed some of the deck and I have been sanding the wood. Old stain comes off like dust.
Wondering if I should go with something like TWP 100 oil based or Messmer’s?
State: Northern Utah (Snow and Hot Summer Sun)
30% Sun 70 % Shade
Redwood
No mold. A little lichen growth on verticals. Sands off.
Old stain has weathered away due to UV
I think it was Sherwin Williams Ducksback Superdeck oil based. Looks like it may have been solid because some remains.
Ben
Strip the remaining stain off and then brighten all wood so it is even. Use TWP stains after.
Hi! Need advice on a stain to use on my fence. It is new. One part is a year old, the other is 2 months. It is board on board, pressure treated pine. The fence is huge!!! I want to be able to roll it on. It is going to take me a long time to get it coated!
In which state is your deck located? Florida, near the coast
How much sun/shade does your deck get? parts of it are full sun, parts of it get shade and sun throughout the day.
What type of wood is your deck made of? Pressure treated pine
Do you have mold or mildew issues? Maybe green stuff
Why/how did the previous stain fail? it has never been stained
Thanks for your help! I attached a couple pictures of part of the fence.
Jen
Clean and brighen the wood for prep. For application, easiest is to spray and then back brush any drips with a stain pad. Roling does not work well for penetrating stains. For the stain, look at Restore A Deck Semi-Transparent stain or Armstrong Clark Stains.
Could I get your opinion? We are building an outdoor pavilion. The ceiling 1 1/4″ tongue and groove pine. My husband likes to see a little of the wood grain. I’m leaning more towards water based since I will be doing it myself. I’m wanting something that will not yellow. The boards are already on the yellower side. What do you think I should use? The ceiling starts at 9′ and goes up to about 15′, I think. Thank you so much! LaDonna
Try something brown. Maybe Armstrong Clark Stains in Rustic Brown or Natural Oak.
https://www.armstrongclarkstain.com/armstrong-clark-photo-album
Deck is 5-6 years old treated lumber-1st application was Cabot Semi-Transparent and looked great. 2nd application 2-3 years ago used same product and seemed to not soak in as well. Getting ready to coat again but had peeling last time so have areas of bare wood and some areas of covered stain. Have cleaned/washed and am doing a light sanding. what product would be best. It is a brown stain used in the past.
Post some pics for prep advice. For the stain, try Armstrong Clark stains or Restore A Deck Stains.
Can I apply epoxy resin to oil base stain so it could last longer
No and it would would actually make it worse.
In which state is your fence located? Northern Virginia
How much sun/shade does your fence get? Full sun. Southern exposure. Backside faces north.
What type of wood is your fence made of? Cedar. Aged under roof for two years before building it.
Do you have mold or mildew issues? Not yet.
Why/how did the previous stain fail? No stain yet.
What type and brand (if known) of stain did you use last time? None.
I’m looking for a stain to help preserve the natural color and delay the grey that my neighbor experienced with the same wood. Please see photo attached.
Use Restore a Deck Semi-transparent stain or TWP 1500 series.
Thank you! 😎
Home and deck built in 2022 in southern South Dakota. The cedar deck faces west and is partially covered-about half of deck gets full sun in the afternoon. There are a few boards with fuzzies. Deck is 16.5′ x 12′ with 3′ wide stairs with 4 steps. The area is new construction in a new development so it is very dusty. My questions:
Does it need both a deck cleaner and a brightener?
Should I lightly sand out some rough areas on the wood-most of it is smooth.
After reading your site, I’m thinking oil-based semi-transparent cedartone TWP as I want to see the grain pattern, does that make sense?
It’s too windy to use a sprayer, should I use a brush or pad?
The mornings are about 65 degrees, gets to 90 in the afternoon. Should I wait until fall when it’s cooler? The boards are showing a difference in color between the covered and uncovered portions so I’m not sure I should wait much longer.
1. Yes.
2. Not needed.
3. Sure, that would work for you. http://www.twpstain.com
4. Stain pad or brush will work.
5. You can stain now but maybe early am or later afternon. Avoid the hottest part of the day.
East Central Alabama, full sun all day, not sure what kind of wood, no mildew,been years since original stain- sun and weather has caused boards to rot, not sure about original brand. Hiring someone to replace rotted boards ans sand and stain. I know the whole thing prob needs replacing but can’t do that right now
You have a solid stain. See here for prep tips: https://www.deckstainhelp.com/how-to-reapply-a-solid-color-deck-stain/
See here for the best solid stains: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
What exterior transparent stain is best for T111 siding at 9000′ elevation in Colorado? I was considering Messmers UV MC500 Natural.
Try TWP 1500 Series for this.
Greetings Scott! I’ve enjoyed your website — lots of useful info. This question is not about decks–but rather wood. (First time homeowner here with little knowledge about exterior stains). Two very large exterior barn doors are about to be built (7.5 x 15 feet each) out of eastern white pine for our barn. I’m on the hunt for a high quality exterior stain and am wondering if there is a reason why I couldn’t use deck stain?
I live in New Hampshire (so think rain, sun, humidity, snow, sleet, wind–all the elements). There will be an overhang so the doors will be protected to a degree and they won’t get full sun all day (they are mostly north -east facing). I’m also thinking it would probably be best to not seal them with a sealant for ease of stain reapplication. Wondering if you have any thoughts on all of this and wondering if you have any recommendations. Many thanks!
“Deck: stains are basically exterior wood stains so yes, you can use them on vertical wood like doors. Look at Armstrong Clark Stains or Restore A Deck Stains in semi-transparent color.
I have a deck with 2 yo 5/4 treated lumber that I have never sealed or stained. Ideally, I’d like to put textured solid surface protection on it. What would you recommend, and how long would this last? I’m in GA, just north of Atlanta.
Alternatively, I’d consider a solid color stain, again, how long would this last and what would you recommend?
I believe you want a deck resurface stain. See these articles on what to use and not use:
https://www.deckstainhelp.com/category/deck-product-reviews/deck-resurface-stain-reviews/
Gulf Synthetics Deck Revive is the only that actually works well.
Hi, Thanks for offering to help with a finish. I’m in western NC. My issue is with solid wood columns on my front and back porches. I believe they are pine or some other blonde softwood. They get direct sun for about 4 hours a day. The finish is 4 years old. The lower portions of the columns get wet on occasion. Not much mildew is evident. There is a graying out of the wood at the bottoms of the columns. When I scratch the finish with my fingernail, it feels like all the finish is mostly gone. I believe the finish used was Olympic Elite.
Strip and or sand to remove the old coating. Brighten all wood when done. Use the Restore A Deck semi-transparent stain when done.
Can you roll Cabot stain on a deck
Depends on the type of stain.
If we have a 7 month old pressure treated deck and rail that we are going to use TWP semi on floor and RAD solid in white on railing, do we need to clean and prep with their brand cleaner and brightener, or is any cleaner with light washing ok?
Best to use brand prep producst for best results.
Hi-
Our deck is about 5 years old. I’m not sure what was on it before but we have now y cleaned and sanded it. It’s on the north side of our house in Iowa and gets quite a bit of sun. I’m hoping to find a stain with a darker color to match the rest of the house better. What would you suggest?
Did you fully remove the old coating? What grit paper did you sand with? Post some pics for prep advice.
As for matching the house, pics would help as well.
7 year old cedar deck. Not sure what was originally on it. Put on Thompson’s water seal after it started to fail a few summers in. Last year sanded and then put on Timber oil (I think). Currently in the process of sanding and wondering what to do next. Also realizing that maybe sanding isn’t the best option since it didn’t work last time.
Always started to fail where the water runs off the house. The part that is protected from the weather is in better shape. Hoping to put gutters in at some point to help prevent the water run off damage.
Hoping that I don’t need to put stripper on the stairs before applying a semi-transparent stain. Wondering how to treat the wood on the stairs before applying stain, and what makes TWP better than Cabot (which I already bought).
Yes, you need to strip it all down. Use the RAD Deck Stain Stripper with both additives:
No stain will prevent water damage from lack of a gutter. Cabot stains used to be great, until they sold the company to Zinser and they changed all the formulas.
Just power washed and old pressure treated deck on east side of home that has clearly had nothing done to it that I could tell. Applied Sherwin Williams Superdeck Oil base exterior translucent natural and got about 1/2 inch of rain 10 -11 hours later. Now what? SW told me to wait 3 days to recoat. Is this correct? I don’t love the fact that it has a bit or amber to it and wonder how it will ware.
I also have a small deck on west side on home with a covered porch which doesn’t get near the weather what would you recommend for it? I am not a fan of color I would refer just a clear OIL to penetrate and not have to deal with redoing every year from stain peeling off. What are your thoughts on Thompsons Ultra Advanced Water proof Sealant in clear? It looks like its oil and acrylic. Why acrylic? Will it turn yellow or orange over time? What happened to good old petroleum oil?
Would love your thoughts and were to buy what you might recommend.
See thsi about the deck that is rained on:
https://www.deckstainhelp.com/it-rained-shortly-after-staining-what-to-do/
You must have a tint in your deck stain for UV protection:
Thomposos is agrbage. You can read the poor reviews here:
https://www.deckstainhelp.com/?s=thompson&post_type=post
You want a penetrating semi-transparent stain:
Zebrawood deck about 10 years old on the Northwest Oregon Coast. It’s in the open and faces West. It was probably never treated. It was recently pressure washed and looks very thirsty.
Restore a Deck Wood stains or Armstrong Clark hardwood stain colors.
Deck is 3.5 yo Redwood, treated professionally at 18months old. Not sure of product. Now it needs re-protected. We are at 8500 ft in CO so UV is very high and humidity pretty low. Leaves provide partial shade only 4 months of the year. Which steps and products do you recommend for the refinishing process and maintenance in the future?
Need pics added for proper advice.
We have a 450 sqf redwood deck built 6 years ago that has been stained annually with penofin clear. Now we added another 250 sqf redwood deck 1 month ago. We want to switch to TWP 1500 (for Colorado) or Armstrong Clark.How do we prepare our old deck for the new stain? How long should we wait to stain the new addition? Do you recommend to use TWP 1500 clear or 1502 redwood or Which one from Armstrong Clark? Should we use the same stain for old and new deck? We live at 5300′ altitude in Colorado. We like the transparent look in general. Your advice will be appreciated
For the older wood, you will need to strip and brighten for prep. You must have tint for UV protection so do not use the Clear.
Best deck stain for North Dakota?
Armstrong Clark stains or TWP 100 Series would be excellent.
Hi, trying to find a solid stain to best cover the imperfections on my deck. Previously stained with a semi solid Cabot canyon color that had an orange base that is now very orange in places. Want a nice neutral color that is not too bright or dark. Located in Northern California about 2 hours from the coast. Summer 90-110, winter 20-40F, rain 20-40inches. No snow except 1 -2 times a year but not every year. So far everything we’ve tried has been too bright or not a good color. The color chips are very hard to use. Thx
Solid stains come in any color you want as they can be custom tinted.
After powerwashing 2 x how to remove remaining latex stain ?
I need advice for what oil based stain to use on a 6 month old pressure treated deck and porch.We live in northwest ga. We have a lot of Sun in the morning on the front porch and then a lot of sun in the afternoon on the back deck. The screened porch will be not be in much sun at all. I’ve been researching brands and now I’m more confused than ever. I have samples from Woodrich oil penetrating stain. We will have to mix stains to get our color. That makes me nervous. Reviews are great, but I don’t know.
I just paid for 2 TWP samples to be delivered. My painter said he used it years ago and it didn’t hold up well…..confused again after reading this website.
Any advice greatly appreciated.
Look at the TWP or the Restore A Deck Wood Stains. Both are excellent. See new wood tips here: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
how Do you rate Flood (PPG) semi-transparent wood stains? For use on new pressure treated pine.
There are much better stains out there than Flood. Flood used to be excellent but then they sold out to Sikkens and the PPG. This resulted in numerous formula changes and not for the better:
https://www.deckstainhelp.com/?s=flood&post_type=post
After reading your reviews, and a few others, for best deck stains I decided on Defy Extreme for a set of wood steps leading down into my yard from the shaded patio. Most of the steps get shade with the bottom one getting a bit of sun. After leaving to overwinter, I cleaned and brightened the day before staining and already saw an improvement. The light walnut shade of stain looked more like cedar… very orange…but my biggest problem was that I overapplied. I used the defy hand held brush and applied wet on wet but I could see it leaving behind small patches of puddling after the second coat. I repeatedly tried to empty the brush and brush over the patches but they just kept puddling. Is this what you meant by “difficult to apply” in the review? Can overapplication happen by applying second coat while first coat is still too wet? I’m going to be building a replacement kiln-dried deck in part sun, part shade and I would like a new product suggestion and/or application tips please. The sun shines through the trees for about two to three hours per day on small patches of the deck. I liked that defy would provide UV and anti-mildew protection and I liked that it was water based, low VOC. And I would probably go with a walnut color to prevent the orange look. Yikes this turned into an essay.
Just apply one coat and you should be okay. Applying too much stain can lead to issues.
I have an exterior deck with pressure treated wood from that I stripped by sanding. The old stain was Cabot acrylic deck stain. However, I can’t completely remove some of the old stain in hard to reach spots. Do you think I should go ahead and try TWP 100 series or do I need to use the same product as before? If I use Cabot again, do I still need to clean the surface since their stain sits onto of the wood? I reside in Michigan Thank you in advance!
Post some pics of the prep.
Thanks for getting back to me! The deck is in the shade now, which gives a darker appearance in the photo.But here you go:
We would go ahead and use the TWP for this. It should be okay to stain.
To add, parts of the deck are wet due to rain this morning.
Would you recommend Cabot Gold? It leaves a nice satin sheen finish to the wood. I would be applying it to a pressure treated deck.
No, it will peel. You cannot have a shine on a deck.
https://www.deckstainhelp.com/deck-stain-with-sheen/
You want a fully penetrating stain so you will not have any peeling and more importantly, future maintenance is much easier with cleaning and recoating.
We .I’ve in Northern New York, approximately 30 miles from the Canadian border. We replaced the deck boards about 2 years ago. We are replacing the uprights this year. What is your recommendation for staining our deck?
Try the Restore A Deck Stains or the TWP 1500 Series. Make sure to prep well first.
What is the best way to restore the true color of my red trex composite deck?
You can’t. There is no coating or sealer that will enhance or restore the color of composite decking. You can stain it if the old school Trex:
https://www.deckstainhelp.com/deck-stain-for-composite-decking/
