Best Stain for Composite Decks – What to use? 4.6/5 (53)
Staining Composite Decks in 2026
At DeckStainHelp.com, we appreciate your continued support as we maintain our position as the internet’s leading resource for wood and deck restoration. Composite decks have surged in popularity in recent years, and while many homeowners believe they are maintenance-free, that is not the case. Like any outdoor surface, composite decking is susceptible to fading, graying, warping, and mold growth. To protect and enhance your composite deck, applying a quality composite deck stain is essential.
Why Stain a Composite Deck?
Composite decking consists of a blend of wood and plastic, making it prone to UV fading, moisture damage, and mildew growth over time. A composite deck stain helps:
  • Block UV rays to prevent fading and discoloration.
  • Repel moisture to reduce warping and swelling.
  • Prevent mold and mildew buildup for a cleaner, healthier deck surface.
How to Stain a Composite Deck
Step 1: Clean the Deck Thoroughly
Before staining, the surface must be completely cleaned to ensure proper adhesion. Follow these steps: ✔ Use a composite deck cleaner and a scrub brush or pressure washer to remove dirt, mold, mildew, and graying. ✔ Focus on mildew removal – composite decks are prone to mildew due to their wood content. ✔ Allow the deck to dry completely before applying the stain to avoid trapping moisture.
Step 2: Choose the Right Composite Deck Stain
Opt for a high-quality, penetrating composite deck stain that resists UV fading and discoloration. ✔ Look for stains with mildewcides or inhibitors to prevent future mold and mildew growth. ✔ Stains with zinc particles offer added protection against mildew and fungi.
Step 3: Apply the Stain Correctly
✔ Use a brush, roller, or stain pad for even application. ✔ Avoid over-applying to prevent pooling or an uneven finish. ✔ Stay away from film-forming or solid stains, as these can trap moisture, peel, and encourage mildew growth.
Our Test Composite Deck Stain
We recently prepped and stained a very old and dirty Trex deck in Spring of 2021. We applied the penetrating TWP Semi-Solid Pro-Series to the Trex, and it turned out outstanding! Looks brand new and the TWP soaked deep into the composite decking with no issues. We highly suggest the TWP Semi-Solid if you are looking to add some color or stain to your old composite decking.
TWP Semi-Solid Pro Series
Prep Materials: Restore A Deck Cleaner Kits
Color Used: TWP Semi-Solid Mount Rushmore
Coverage: 1 coat was applied. 4.5 gallons were used. Coverage was about 200 Sq Feet per gallon.
TWP Semi-Solid Pro-Series Review: TWP Pro-Series Semi-Solid
$73.99
5.00out of 5
$294.95
$87.99
$374.95
Composite Deck Stain Photos
67 Comments
William Strugger
William Strugger
7 months ago
I have a composite deck (EverGrain) installed 21 years ago. It has held up well, seems structurally sound, some cracks in the material (for which I received money back from the manufacturer). I power wash every year.
What products should I purchase to: clean, seal, and (hopefully) freshen up the color of the deck with a solid stain? Thanks.
William Strugger
William Strugger
7 months ago
Excellent. Thanks for the quick response. I guess there are no recommended solid stains, just the TWP semi-solid?
also, for a deck that is 425 sq. ft., what is the recommended quantities for both items?
Kenny
Kenny
I’m trying to purchase a composite deck stain (gray) for my deck..
I haven’t been able to get information about what to purchase or the colors..
My composite deck (unsure of brand or color) is needing some TLC. I was looking at the Rust-Oleum® RockSolid® Composite Deck Refresh to hopefully bring some color/life back. I searched the website, but could not find reviews on that exact product. Have you used that before? We are looking to replace deck in the next 5 years so holding up long-term, I am not too concerned about.
I would appreciate any input or suggestions! Here are some pictures of my deck for reference. ***there is dirt from muddy boots which I haven’t cleaned yet.
Thank you so much for your honest feedback!
If I choose a semi-solid stain, would staying in the same color family be best? I am definitely lost in the area of choosing a stain color. The choices are overwhelming.
Dawn
Dawn
I have a ChoiceDek that is 15 years old. It looks bad, dark mildew throughout. Composite deck cleaners have not helped. Is there anything that I can do? I saw that it can be stained but considering that I cannot get the mold off, is it even worth doing or should I just bite the expensive bullet and replace the boards?
James
James
Paint was spilled on our composite deck. What is the best remover? I am sure that it will leave splotches of a lighter color. What type of deck stain should I use to get a more complete color?
James Bush
James Bush
Thanks. We’ll work something out.
Scott
Scott
I have the original Trex Composite Decking which is about 20 years old. Can I use the TWP Pro-Series-Semi-Solid Stain/Sealer? Or would you recommend Defy Composite Sealer? When I power wash the deck the color is still fairly good.
Laura
Laura
I’m confused now. I have a five year old composite deck. I hate the saddle brown color and am now also going to add on to it at a different height. So can I stain it? Can I use a semi solid stain? Something else? Thanks very much.
James
James
What made you guys stop staining composite decks over 10 years ago? Was the process just difficult?
Patty borst
Patty borst
Why is in not possible to fix the chalky white caused by goof off.
We had our house painted and contracted taped paper on deck during prep. The glue from tape would not come off our trex deck contractor used goof off ruining the deck. He has offered to stain Deck.
So would like to know why goof off damage can not be fixed?
Patty borst
Patty borst
How would goof off know how to re stain a Trex deck or why its not possible.
I am not asking why the product had this impact I am asking about re staining to my deck to cover the problem
Bill Kay
Bill Kay
I have one of the older(not encapsulated) Trex Decks with soaked in grease stains that cleaning with vinegar and baking soda did not remove. Is there any hope of removing the stains or will one if the composite deck stains hide the grease stains?
Jonathan Groves
Jonathan Groves
I just installed pricey AZEK ARBOR, PVC decking… Brazillian Walnut colot… ($100 per board!) – I need to revitalize the finish in some spots. Surface is damaged. Here’s what happened… I tried to remove some latex paint drops using popular “Goof-Off” spray… BIG MISTAKE! Every place I wiped with Goof-off is now chalky white. Help!!
Daryl
Daryl
My trek decking is 20 yrs old and needs to be stained it’s very grey any recommendations on the type of stain?
Jim Brose
Jim Brose
We have a 16 year old Timber Trac decking and wondered if staining was an option and if so what to use? The product is no longer made and the decking has faded considerably..
Joe Katz
Joe Katz
Can you recommend which stain to use for a 15 year old brown Trex deck
George Gardner
George Gardner
What is the best deck stain I can use on a composite deck
Richard
Richard
What is the best deck stain for a ten year old composite deck?
Brucene Hill
Brucene Hill
The info was helpful, but I need to know what brand of stain would be best for a composite deck(Trex). When I go to a paint store they don’t know of any product to put on Trex. Please Help
Michele
Michele
Messmer still lists the composite stain on their website. Do you have any experience with this stain?
Michele
Michele
Peter
Peter
I have a 2002 Timbertech deck that is very weathered. What is the current best stain brand for this type of deck and should you use oil or water based stain?
Bill Ferry
Bill Ferry
I recent purchased a home with light gray Trex decking. It’s at least 10 years old and looks weathered (even a bit rough) with small black mold spots. A painter told me to clean it and to use a translucent stain. However most companies stains for composite decking are solid stains. Which is best? Water or Oil base?
Multi coats?
Mark Cullen
Mark Cullen
Is there a particular deck stain that you would recommend for staining (want to do a complete color change) a composite deck?
Bruce
Bruce
Did Messmers work well 10 years ago?
Elizabeth King
Elizabeth King
My dog has made a scratchy mess of my Timbertech deck. Will staining help cover the scratches and will the new stain scratch easily? I am trying to figure out if it is worth the time and effort. Thanks!
Elizabeth King
Elizabeth King
I was afraid of that 🙁 Thanks so much for your response!
Betsey Day
Betsey Day
Need help! Roof washer products left bleachy splotches on my Eon deck!!! Since i am planning to sell my house this year i need to stain/paint it as it is a huge asset to my house. Plesse recommend a specific quality paint to use & if it should be sealed afterward. Here is a picture of damage: fortunately i had not yet paid contractor!!!
Mike Orlando
Mike Orlando
Not true!!!!! Use Benjamin Moore Arborcoat Solid Stain. Any good paint or stain suitable for PVC will do the job. Light sand first than paint or stain. It works!
Reply to  Mike Orlando
Do you need to remove all the clear sealer prior to staining? Have you actually stained a Eon Product?
Gary
Gary
I stained my composite deck because it was turning pink. Now it is moldy with many black spots. What stripper can I use on it. I will restain with TWP 100.
Gary
Gary
It is one of the stains in the picture, sorry I don’t remember which one.
Mold Mildew on Deck Stain
Gary
Gary
It is oil based.
Mary Lou
Mary Lou
What is the best rated stain for composite decks?
67
