This post was updated on August 20, 2025
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Best Deck Stain reviews and help tips are based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
Elevate Your Deck with the Best Wood Stains & Sealers
Whether preparing for a DIY deck-staining project or looking for the perfect stain to share with your contractor, I’ve got you covered. I have rounded up the eight best deck stains available in 2026, including oil-based stains, water-based stains, and semi-transparent and solid options.
Scott’s Expert Guide to Choosing the Best Deck Stains
Questions About Which Deck Stain or Sealer to Use?
Want personalized help? Post your questions below in the comments, and I’ll gladly guide you toward the best deck stain and sealer. Please include any pictures you may have and a brief history of the deck.
Over 30,000 Q&A Comments Below on this article. Ask Below, I Love to Help!
My Recommended Best Deck Stains and Sealers at a Glance
Click on the link and jump straight to the review:
- Top-Rated Deck Stain: TWP 100 Pro Series Stain Review — This deep-penetrating, long-lasting, semi-transparent stain is oil-based, easy to apply, and withstands the elements for up to 3 years.
- Recommended Semi-Transparent: Restore-A-Deck Semi-Transparent Wood Stain Review — Restore-A-Deck’s UV-resistant, semi-transparent stain can be applied to damp wood, which means we can prep your deck and apply the stain in one day.
- Leading Semi-Solid: TWP® Semi-Solid Pro-Series
- Oil-Based: TWP 100 Pro Series Semi-Transparent
- Best Water-Based: Restore-A-Deck semi-transparent deck stain
- Recommended Solid Color: Restore-A-Deck Solid Color Wood & Deck Stain
- Best-Applying: Armstrong-Clark Wood Stain — This long-time favorite is a hard-working, deep-penetrating option that goes on easily and allows for simple maintenance.
- Excellent Semi-Solid Wood: TWP Pro Series Semi-Solid Stain — TWP’s semi-solid stain goes on quickly, holds color well, and offers maximum UV protection and a variety of color palettes to choose from.
- Outstanding Wood Preservative Deck Stain: TWP 1500 Series Semi-Transparent Stain — TWP’s 1500 Series consistently ranks as one of my top options for deck stains, thanks to its deep-penetrating formula, UV- and mold-resistant properties, and long-lasting color.
- Recommended for Mildew: Defy Extreme Semi-Transparent Wood Stain — Defy’s water-based Extreme Wood Stain offers rich, penetrating color and an infusion of zinc oxide Nano-particles that prevent damage from UV rays, mold, and mildew.
- Best Deck-Resurface Coating: Gulf Synthetics Deck Revive
Steps to Picking the Perfect Deck Stain for Your Needs
Is There a #1 Rated Best Deck Stain or Sealer?
Transparent Stains
As the name suggests, transparent stains are clear or very lightly tinted stains that help seal and protect wooden decks while still allowing the wood grain to show through.
Semi-Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
Common Deck Staining Mistakes and How to Avoid Them
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly.
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time.
From: $41.99 | From: $47.99* | From: $65.99* | From: $69.95* |
*Free Shipping Included
- Ease of application
- Wear and tear after 2 years
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
5. Ready Seal Wood Stain
3. Defy Extreme Stain
- Scott’s Pro Tip: My most used deck stain in the past 30 years! We have used the TWP 100 Series on many 1000s of decks.
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Scott’s Pro Tip: My favorite deck stain to save time and money. We prep and stain on the same day.
My Test Deck Stats
UV Exposure: 50% Full Sun
- Scott’s Pro Tip: Regarding ease of application and performance, the Armstrong Clark stain is one of my top stains. We love their semi-solid colors and performance.
My Test Deck Stats
Deck Square Footage: 600
- Scott’s Pro Tip: My favorite penetrating semi-solid wood and deck stain soaks into the wood and provides excellent UV protection.
My Test Deck Stats
When Tested: August 2020
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Scott’s Pro Tip: My favorite current penetrating semi-transparent oil-based stain is the TWP 1500 Series. Michigan switched to low-VOC, so I now use it on the majority of decks that I restore.
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Scott’s Pro Tip: My new favorite IPE and Hardwood Deck stain is the first stain I have ever seen last more than one year on exotic hardwoods.
My Test Deck Stats
Stain Color Used: Chesnut
- Scott’s Pro Tip: The Defy Extremes is one of my top choices when using a water-based semi-transparent wood stain.
My Test Deck Stats
Stain Color Used: Cedartone
- Scott’s Pro Tip: Ready Seal Stain is not my favorite since it requires annual recoating, but I do like that it applies easily. Ready Seal does not cure fully and can rub off the wood on clothing.
My Test Deck Stats
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Deck Stain Facts: Frequently Sought Answers
When helping people choose the best deck stain and sealer, I often hear many of the same questions. Here are some facts and words of advice about exterior wood stain that can help answer these questions:
What is a deck stain?
Deck stain is a type of finish applied to the wooden boards of your deck. Generally speaking, deck stains come in three types —transparent, semi-transparent, and opaque —and are available in a wide range of colors to suit your taste.
Answer: The deck stain must be tinted to protect it from UV graying. I prefer semi-transparent stains, as they do not mask or cover the wood but highlight the grain while providing UV protection.
Answer: My favorite deck stains have been penetrating semi-transparent and semi-solid stains. These stain types allow the wood grain to show, and if they truly soak into the wood grain, reapplying is easier down the road.
What deck stain types can be cleaned and recoated as needed?
Answer: Penetrating deck stains are not prone to peeling, and we can clean and reapply them as needed. Deck stains that dry or film on top of the wood are much harder to maintain and prep when reapplying.
Answer: Absolutely! Deck stains are wood stains and work very well for wood fences, vertical wood siding, and log cabins. They last even 2-3 times longer on vertical wood.
The waiting period before staining a new deck can depend on the material used to build it. Take a closer look at our recommended time frames based on deck material:
- New, smooth wood decks: Wait at least 3 months before applying stain.
- Rough-hewn wood decks: No wait time is needed; you can apply stain as soon as the wood is clean and dry.
- Kiln-dried or KDAT wood decks: Wait 1-2 months before applying stain.
For more information, check out this guide on how long to wait before applying stain to your deck.
The most popular deck stain colors of 2026 include:
- Cedar tones
- Brown tones
- Honey tones
- Redwood tones
The best way to apply a deck stain can vary based on the product used, but my personal favorite applicators include flooring brushes and stain pads. Learn more in this guide to the best deck stain applicators.
What’s the difference between a deck stain and deck paint?
Deck stain and deck paint are similar in that they add color to a wooden deck. However, deck stain typically penetrates into the fibers of wooden deck boards and often results in a more natural final product. On the other hand, deck paint is typically thicker and creates an opaque layer of color over the wood.
What’s the difference between water- and oil-based deck stain?
Both water- and oil-based deck stains can provide rich color and long-lasting protection against moisture and UV damage. However, there are some differences between the two stains.
For instance, oil-based stains may offer advanced protection against warping or cracking and last longer than water-based stains. However, water-based stains are generally more environmentally friendly and easier to apply and clean up. Many water-based stains also feature additives to prevent fungal damage or wood rot. Learn more in this guide to the differences between water—and oil-based stains.
The 3 best deck stain brands for decks in full sun are TWP, Restore-A-Deck, and Armstrong Clark. The TWP 100 Pro Series semi-transparent penetrating deck stains in darker tints are best for most decks. TWP also has a semi-solid penetrating deck stain that works well in full sun. Restore-A-Deck has semi-transparent and solid deck stains for full sun. Armstrong Clark is a high-quality oil based deck stain.
Additional Deck Stain Rating Questions
If you have questions on this review of deck stains, please ask me below in the comments.
Want My Help Finding a Deck Stain?
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
- TWP 1500 Series
- Armstrong-Clark Deck and Wood Stain
- Restore-A-Deck Wood Stain
- Defy Extreme Wood Stain
I am here to help you find the best wood deck stain for your situation! Just post a comment below with answers to these questions.
TWP Natural Effect Top Coat 1 Gallon - Step 2
Hi, I have a new (6 months old) pressure-treated pine deck which I need to seal with a transparent or semi-transparent seal. The deck is completely exposed to the South Florida sun, and it’s near the ocean. What sealer do you recommend that will give me a natural matte look but seal well for a few years?
TWP 100 Stains or Restore A Deck Semi-Transparent Stains.
In which state is your deck located?
Georgia
How much sun/shade does your deck get?
Completely exposed to sun. No shade
What type of wood is your deck made of?
Yellawood pressure treated. Completely new install 4/19/2025. Brand new never been stained.
Which stain would be best for my deck?
I’m most interested in the natural high shine oil based look. TWP 1500 sounded pretty good from your review but not sure which color.
Lastly, how long should I wait to stain my new pressure treated wood deck? My plan is to sand with 120 grip and pressure wash before staining.
See here about new wood:
Do not sand for prep as that reduces stain penetration. You cannot have a “high shine” as that leads to peeling. The TWP 1500 is an excellent penetrating wood stain.
I have a newly constructed cedar deck that is about 200 yards from the Oregon coast and is in direct sunlight 50% of the day, when it’s not overcast. If untreated, based on our experience mildew, rot, and sun damage will be problems. Am I correct in thinking that “Restore a deck woodstain” would be an easy-to-apply choice? Are there better choices? Can I treat it now or must I wait the 3 months mentioned on this site? Why does the wait help?
The Restore A Deck Stain is excellent. You do need to wait for three or more months and then prep before staining. You cannot skip this.
I have three areas, with lots of plants around them, where the color needs to match:
1 – Deck and walkway that is 8-years old. Let them sit for a year after installation then prep following best practices. Have tried many different primers and deck paints from a paint store and none work well. Scrapped and sanded 2- years ago and started over with the same poor results using different products. Always touch up in the spring and fall. Both have cracks with the walkway being much worse.
2 – Cement that is in very good shape. Many coats of paint over the years. No peeling or flaking.
3 – Deck floor in a gazebo that is 25-years old and in very good shape. I keep top coating when I paint the other areas. Surface is very hard making it impossible to strip. Some cracks in a small area the sun hits.
What needs to be done to each of the four areas and what products should I use on each area?
To fix, you should remove it all down to the bare wood and start over. It will need to be power sanded:
Once it is fully removed, you can use a proper deck stain. Never use paint or primer for decks.
Thanks for the reply. Which stain do you recommend? I live in Ohio. Front of deck gets afternoon sun. Back of deck gets little sun so there is some algae and mildew each year. Wood is pressure treated. I used paint most recently because stain has failed in the past. The stain I used was Flood Pro Series Solid Stain. My wife likes a solid looking finish. I look forward to finally fixing the deck. Thanks again!
For an opaque solid stain, look at one of these three on this article:
Should I strip the paint before sanding or just sanding?
You could try to strip it first to remove as much as you can, but you will most likely need to power sand to get it all off.
Wood deck extends off of a cement patio around a pool. I worry about kids slipping and falling. Can I add sand or another anti-slip material to My Restore-A-Deck Solid Wood Stain? Thank you!
No, anti-slip additivess only work in very thick coatings like deck resurface type coatings for exterior wood. We have never had anyone complain about slipping with solid color deck stains.
I saw your post that you get 2x coverage for the second coat of RAD solid stain. The product description indicates coverage of 200 – 350 sq. ft. per gallon. I will be sanding the pressure treated deck boards to remove the old paint, washing and brightening them. What coverage have you found on the first coat and second coat?
You will average about 100-150 sq. feet per gallon for the two coats of solid stain.
I sanded the deck with a drum sander. Picture attached. What is the best way to get the rest of the paint off. Thanks again!
If you are going with the RAD Solid stain, you do not have to remove 100% of the old solid stain. Just what is loose and peeling. You should be good.
Will I have trouble with the RAD solid stain penetrating the wood where paint remains? I thought from a previous post, I needed to get all of the paint off. Sorry to reconfirm. I don’t want to go through this process again next year.
Also reconfirming your response regarding coverage before I order product. For coverage, you indicated 100 – 150 sq ft average for the two coats which is far below what RAD indicates. How many gallons do you think I need for a 750 sq ft deck? Thanks again!
PS. I look forward to posting pictures next Spring of the deck, after going through a Winter.
“For coverage, you indicated 100 – 150 sq ft average for the two coats, which is far below what RAD indicates.”
-The coverage they state is per gallon for 1 coat. What I stated is the average for 2 coats. You will need about 6-7 gallons for two coats on 750 sq feet.
“Will I have trouble with the RAD solid stain penetrating the wood where paint remains?”
-Solid stains are not penetrating, but filming. You need to remove what is loose or peeling for recoating:
recommend best cleaner and stain for an ipe deck
See here for both: https://www.deckstainhelp.com/ipe-staining-instructions/
Scott,
Live in Ohio, have a cedar deck about 5 years old. Historically have used ready seal with last application 2 coats last year. Unfortunately used bleach for prep to rid of mildew a few weeks ago, ruined part of the deck. (Won’t do that again) Not super happy with color-lasting of ready seal, and planning to strip/brighten and re-stain. Looking into your recommended TWP, assuming I’d need to go with 1500 series for semi-transparent. Wondering if I should go with TWP semi solid for less maintenance, but worried it may block too much of the beautiful wood grain. Thoughts or recommendations?
Yes, strip and brighten for prep. TWP 1500 would be the correct product for Ohio and will show the wood grain fully. The wood color will be enhanced based on the stain color you choose. If you want longer UV protection, the low-VOC TWP semi-solid colors would be the choice, but you will see less of the wood grain.
Which one: TWP 100 ST stain vs Defy Extreme ST for redwood Colorado ( southern sun exposure) deck&rails 15 years old sanded down now from previous Sikkens ( peeling issue) ST stain.
Both are very good, but go with the TWP 1500 Series. The 100 Series is not allowed in CO due to VOC laws.
My deck is 1 year old. I live in michigan and Im looking to get the best stain/sealant
Clean and brighten for prep and then use TWP 1500 Series or Armstrong Clark Stains. Where in MI? You can pick up locally if in Metro Detroit.
Hi. I’m confused. Yesterday, I swear I read your top rated oil based semi transparent stain was TWP 1500. Later, I ran into several articles and reviews elsewhere, stating the formulation has changed and isn’t as good (something about water, I believe). I get back on your site today and read where you stated that TWP 1500 has changed and wasn’t your best recommendation; it now seems to be the TWP 100 series?
Is TWP 100 your top recommended semi transparent, oil based stain to date? Also, did you do some updating on your site sometime yesterday, did I read 2 different articles or am I just crazy? 😂
TWP 1500 Series is an excellent stain and is oil-based, not water-based. It is one of the top products out there and performs the same as the 100 Series.
I hit post before attaching the photos. I am attaching them here. Thank you.
I would like help choosing the best stain for my deck. Some background insight…..I don’t not know how old the deck is/was, other than OLD. There were issues in 2016 when I purchased the home. In 2019 the deck was restrained. I pressure washed the old stain off the deck and had someone apply new stain. Until fall 2024, nothing else was done to the deck. There were a couple of spots where the deck was structurally unsound. A friend was supposed to help me (I am a woman who has never done anything like this before.) My “friend” did not do as promised after having me remove ⅓-½ of the deck boards (deck is 25’x15’). After removing the boards I did, I realized they were not going back on the deck (many had curled and looked like skids on Santa’s sleigh). I also realized that while there were only the 2 spots structurally unsound, the substructure of the deck was not in great shape. Since I knew I needed to replace the old deck boards with new ones, I decided the substructure needed “shoring up” to prevent the new surface from being a waste of money in a year or 2 when the substructure failed. So, beginning August 2024, I undertook repairing/rebuilding my deck—by myself, with absolutely no experience in anything wood related, from choosing boards and nails (I quickly learned screws are used now, not nails and screws have torq heads, not flat or Phillip), to using a circular saw (and now a miter saw, a sawzaw (reciprocating saw), and a jigsaw), to not knowing there was something called an impact (which I now understand is like a drill with a hammer built in and a battery that lasts for days), to building stairs, and the list continues. For the substructure, I added a 4×4 to each 4×4 on the original substructure (from ground level to deck level), new 2×6 joists opposite the originals the width of the deck on each row of 4×4’s, and multiple diagonal 2×6 joists between the rows of 4×4’s. Then I put new 5/4x6x16 deck boards for the deck surface. I then had to learn how to build box frame stairs to replace the 2 sets of stairs on the deck-one had rotted and was unsound, the other was some random, jerry-rigged concoction that had worked, but I couldn’t duplicate. Finally, I added “electricity” to the middle of the deck to power the lights in my umbrella. I ran an extension cord under the deck with flush mounted “covered outlets” at the electrical outlet and the center of the deck, so the extension cord would be out of sight when not in use. Then I thought the easy part was all that was left—staining the deck. Apparently, I was very misinformed!!! I believe at this point that the process I need to use to stain my new deck is let the wood dry, clean it using deck cleaner being very careful IF I… Read more »
See this about new wood:
You are okay with preparing and staining this spring. Look at the Restore A Deck Cleaner and Brightener Kits for prep. For the stain, try the Restore A Deck in Dark Walnut or TWP 1503 Dark Oak.
Forget to mention we want a natural look.
Thanks again
Duncan C
I am installing a new tongue and grove (12 x 50) ceiling on a screen porch on a lake house in central al Mississippi.The wood is clear no knots or pressure treated pine. I plan on staining both sides in case the roof might develop a leak it might help prevent it from seeping through to the underside. What stain/sealer would you recommend for both the hidden and exposed sides.
I really appreciate all the info you have provided on your site. It really helps!
Duncan
Hi Duncan, you cannot pre-stain new wood, and there is no advantage to staining both sides. It would have zero effect on preventing water from leaking through from the backside.
As for the stain to apply, look at Restore A Deck in Natural or Armstrong Clark Stain in Natural after the weathering and prep.
We installed a pressure treated wooden deck around a pool last October. It is now February. The deck has a railing that goes all the around as well as two sets of wooden steps. Is it too soon to stain the deck? It gets full sun most of the day. It is shaded by Oak trees towards the evening hours. I am in Oklahoma and am looking for something that will protect the wood as well as keeping the wood grain look. Nothing to dark. There are so many brands and choices out there. What would be your stain of choice in my situation?
Hey Scott, Richi Tannerhill here again. I didn’t really feel a way to edit my last question so that’s what this is is an added to the last question. It was supposed to say the homeowner wants me to use a semi solid cabinets all based stain and then thin it ratio two to one two parts stain one part thinner Again. I begin a long time and can assure you that the deck will be prepared and prepped, right I can’t really see it on this day on phone anyway, and I am convinced that Siri hates me so the voice text don’t always work out. Forgive me for the typos in the errors. I’m a bit of a perfectionist on a job and with the work that I do however I had to learn to manage stress to look something’s going like being grammar and spelling and typing stuff lol hope it makes sense. Thanks for your help
Why would you thin the semi-solid stain? Sounds like a bad idea as you are “thinning” the protection from the UV. There would be no point to this and you would be better off just choosing a semi-transparent stain.
Hey Scott, I really appreciate what you’re doing here and definitely respect your opinion. I would concur on TWP being the best how do you feel about using cabbotts stain? The homeowner wants me to get a semi solid because you can get semi solid in oil based and then send it to the one with a good paint thinner. How do you feel about the longevity of this idea obviously preparation being most important.?
We have not been fans of Cabot since they sold out to Zinser many years ago. They changed all the formulas. If you want oil-based semi-solid, the TWP version would be much better.
Hey Scott, we have a large deck wrapping around our house we bought 2 years ago. The Front part (north facing, gets morning and some late evening sun) must have been redone not too long before we bought it but not sure it was ever sealed. We have to redo the back part (south facing, lots of afternoon soon). We are in the SF Bay Area – medium fog, lots of sun. We are using redwood con heart smooth wood to redo the back. Any stain recommendations for both the new and old section to ideally get them closer to color match?
As for blending new and old wood, it is not possible to get them to match when using semi-transparent stains. The older wood always stains darker since it is more porous. You would have to go with more opacity to acheive this. Semi-solid colors or solid stains.
Hello Looking for recommendations on deck stain – mainly semi transparent vs solid stain. I purchased this home last spring and the deck needs attention so I can’t answer some of your questions. – The first picture shows the area that has a covered roof, the 2nd/3rd picture show the deck in the uncovered area. I’ve replaced a few boards this summer.
The vertical parts of the deck look in need of protection also but not as bad as the floor boards.
I appreciate your assistance.
See this article for Solid vs Semi-Transparent:
https://www.deckstainhelp.com/solid-vs-semi-transparent-deck-stain/
The key here is the prep. Strip and brighten for prep. Look at the Restore A Deck kits.
Thank you in advance for your help and support!! Great website.
Getting ready to prep and stain a redwood fence that is 1 year and 9 months after install. Never yet treated with any type of stain. I live in San Jose, CA. Full sun in parts for at least half of the day. Other areas shaded by plants.
I have conflicting top priorities. I want the best result and ease of maintenance. I am also chemically sensitive and want to use the most non-toxic products now and in the future when maintaining. Trying to find a balance in priorities and would prefer not to have to use a stripper in the future for maintenance.
I posted my questions on cleaning elsewhere. Here are my questions on staining.
Can you stain over your water-base options for maintenance without stripping? Do all of your water base options penetrate rather than topcoat?
Which oil product is most non-toxic and environmentally friendly? Same question for which water based product?
Recommendations for my situation?
How do I prevent bleed though to my neighbor’s side when trying to stain fence and lattice on my side? Tips?
Thanks you.
-All of the penetrating semi-transparent stains we suggest can be cleaned and reapplied as needed. Water-based versions as well.
-There is no such thing as a completely non-toxic oil or water-based stain. They are chemicals.
-There is no way to prevent stop bleeding through on a fence to the other side. We always suggest doing both sides to prevent this.
Try Armstrong Clark for oil-based or Restore A Deck Stains for water based.
Hi, we have a wood deck around our pool in arid New Mexico. We are considering a polyurethane coating for long lasting protection. Our dry climate ages wood rapidly when it gets wet, then dries out in the sun, so we thought a polyurethane would provide longer protection than a stain. What do you recommend? Thank you!
You cannot use a poly coating on exterior wood. It will blister, peel, attract mildew and become a huge nightmare to fix when it does fail:
https://www.deckstainhelp.com/can-you-apply-a-clear-sealer-or-polyurethane-over-a-deck-stain/
Dear Scott, my mahogany Front porch has not been done for several years. The wood actually looks gray and weathered except for under the mat, which is still a beautiful red. Not sure what we used, but it Could’ve been penofin. My neighbor says it needs Light sanding But I have done that and the color is still grayish. There is maybe a little red showing through here and there. The porch has a roof over it But even so, most of it is the grayish color. Should I use semi transparent and what brand would be best? I live in New Jersey. thank you Louise Lambros
Use a deck cleaner and then a wood brightener for prep. Stain with Restore A Deck Stain in Light Walnut color.
Thank you very much, but is that a semi transparent oil?
It’s a penetrating water based stain. It does not have to be oil based but if you want oil, look at Armstrong Clark. See the top hardwood stains here:
I used Defy Extreme wood semi transparent stain on floor deck (pressure treated) and am happy with the results so far. However I am not completely done and yesterday I made a mistake when wrapping up the day, I allowed the last 5 boards to dry completely with only one coat on, forgetting about the wet on wet process. I plan to put second coat on today but was wondering how that will affect the final process?
It may not penetrate into the wood correctly now. If you apply a second coat after the first coat has dried and cured, it sits on top and creates a film. This can lead to premature failure.
I have a new yellawood presure treated deck that is now ready to be stained..Deck is located in Southeast TN. It is a covered deck and gets full sun on 2 sides for about 3 hours each day. I would like to keep the wood grains showing. Could you please recommend 3 brands and types that would be best suited for this application
Read this about new wood and it does apply to your wood type.
I’m sorry, I meant to say my deck is 5 years, not five hours old!!!
Hi. My small deck is only five hours old and I’ve already sanded it down to bare wood and refinished it twice. The first time, I used I used ultra premium penofin Transparent oil finish. It lasted only 6 months. The serving time, I went with behr transparent water based finish, it last only a couple of months longer. I think I liked the penofin oil look and feel better but 6 months is just too short a time. I would like to be able to see the wood in all its natural glory and I want to protect it from the elements. I am willing to put in work and am ok with reapplying something once a year. But I don’t want to have to sand or strip it again. Well, if I have to, I’ll do it just one more time. It’s a small platform deck which is not hard to sand but it was really hard work for me. I’ma small middle aged woman. Stripping sounds very bad for my garden’s plants and I don’t like the idea of using harsh chemicals. Please help me with to figure out a successful process for removing the failed stain, choosing a new stain and maintaining my deck. Answers to your questions are below. Thank you!
Deck Location: San Francisco, CA (inner sunset, where we get quite a lot of fog year round. I think our deck is wet more nights than not)
Sun/Shade: Full sun with shade part of both the morning and afternoon due to neighbors’s trees. Our deck is next to the south facing back side of our house.
Wood Type: Redwood
Mold/Mildew? Yes, there is some black mildew but it’s not too bad yet.
How Did the Last Stain Fail? I sanded it down to bare wood and applied two coats of finish September 2023 but by May 2024, water mostly stopped beading on it and now there are spots that have no finish and it looks terrible, especially when it is wet.
Which Stain Was It? Behr Premium Transparent waterproofing wood finish.
All the pictures attached show how it looks within the last month or so.
Strip it all off. If needed sand the rest off. Brightener when done. Never sand finer than 60-80 grit and when you sand, only 1 coat of stain is suggested. Stain with a penetrating stain. Look at the TWP 1500 Series or Armstrong Clark in a semi-transparent color.
Thanks! I was afraid you’d say that. What does maintenance entail? Is spot cleaning and applying more whenever any area starts looking bad what people do? How often should I expect to do this?
Clean and reapply as needed when you use a penetrating stain like the TWP or AC.
Can you explain why in my situation you would only use an oil based stain. I’m not opposed to it, but the last one I used lasted a very short amount of time. So I’d like to understand the reasoning and avoid having to start all over again.
You can use any penetrating stain, regardless of the base. Behr Premium is not penetrating but film-forming, which is one reason it failed. Behr Review:
https://www.deckstainhelp.com/behr-deck-stain-review/
Best Penetrating stains:
You wrote “when you sand, only 1 coat of stain is suggested” – does that mean, if sanding is not needed, I should use more than 1 coat? Do you mind explaining why sanding=1 coat?
That would vary based on the age of the wood, the directions for the stain brand you choose, and the type of stain you are using.
I’m on the RAD website but I can’t figure out what combination of stripper / booster / additive to use to strip my deck. Please see the posting and pics that I sent 5 days ago for more details of my situation. Also, it sounds like a cleaner is not needed if one is using a stripper – is that correct? Also, if I want to avoid sanding, would using a stripper meant for removing solid stains be helpful even though the stain I’m using is Behr transparent finish? Thanks!
Use the RAD PaintStrip here, as the Behr looks opaque in some areas, like a solid stain. There is no need for a Cleaner if you are stripping.
When I use Defy or TWP as a sealant, can I use the Restore-A-Deck cleaner/brightener kit or should I stick with the same product line to clean and brighten?
You can use the RAD prep prducts for other stain brands.
Thanks! Is it OK to use the Restore-A-Deck cleaner/brightener kit before applying Defy or TWP sealers, or should I stick with the same brand for every step?
I am an older widow; you and your website have really helped me gain confidence in hiring someone to work on my deck. Thank you so much!
I want my new pressure treated pine deck to gray naturally. You have said different things about ‘clear’ penetrating sealers in this regard. But, you have also mentioned using a “semi-transparent gray for floors.” More specifically you have mentioned Armstrong Clark “Driftwood,” and I have noticed that Restore-A-Deck Wood Stain has a new color “Cottage Gray.”
Question: Which would be better for the wood itself? Clear, or a penetrating semi- transparent GRAY STAIN?
In your response to ‘Suzie,’ who wants her deck to turn gray naturally, you have recommended that she look at Defy Extreme Clear, or TWP 1500 Series in Clear. Defy Extreme carries a Proposition 65 warning, and although TWP is low VOC and an EPA registered wood preservative, it carries the same warning. I have had cancer myself and would like to avoid asking someone to expose himself to this risk.
Question: Can you guide me to a GOOD product that does not contain this warning? Or do all of them carry the same warning? And, if they do, what kind of protection should I provide for the person who seals my deck?
All products will carry the Prop 65 warning. This is due to a California regulation and is not a concern.
If you want the wood to gray nautrally then use a clear. Try the Defy Extreme Clear or the TWP 1500 Clear.
Hi Scott. I used a stripper and power washed a Behr solid deck stain that had started to peel. Do I really need to use a wood cleaner or “brightener” before I apply a new stain?
Yes, you need a brightener.
I’m in California close to the ocean. Deck gets light sun and is mostly shaded. The deck is redwood. Deck was never stained or sealed. Approximately 7 years old. I’m using a power washer and deck cleaner and will use a deck brightner before staining. I would like the grain of the wood to stand out and would like it to have a dark redwood look. What color and brand stain should I use?
I’m not sure what you mean by “dark redwood” look. Look at Armstrong Clark stains. Maybe Sierra Redwood or Sequoia colors. Another option could be TWP 1516 Rustic color.
Thank you. I want this look.
The final color will vary based on the wood’s age, prep, and grain. I suggest the colors mentioned prior and include Pecan from TWP. Both websites have samples for testing after your prep is done.
One year ago, my contractor spray painted one coat of semi transparent Flood stain and did not back brush. I did not allow him to apply a second coat since it was well past the 24 hour window to do so per instructions on the can. The stain is very uneven. How do I prep to apply a new coat with the same stain? If sanding is required, how do i know if i have done enough. See picture attached. Thanks!!
You should remove all of the Flood stain and start over. Strip and brighten to do this. When done, use a better semi-transparent stain. One that is fully penetrating as the Flood films on top and is main the reason for the uneven application.
I am ready to apply Defy Extreme Stain to my cedar deck. Asking for clarification on the process of applying this stain to a damp (?) deck. Does that mean wait 24 hrs. after rinsing off the brightener and then apply the stain. Or wait 48 hrs. when the deck has dried, then re-dampen the deck by misting water (no puddles), and when the wetness has been absorbed into the wood (the deck is sort of dry to the touch) then apply this stain?
Do not apply the Defy Extreme to damp wood. Wait 48 hours after prep or rain to apply it to a fully dry deck.
I finished staining with Sherwin Williams waterborne Superdeck on Monday. I had cleaned, belt sanded and applied two coats with a brush. It was dry weather – and it turned out great. But Saturday my partner put the deck furniture back on it and used the hose to rinse off the chairs. The water beaded but when it dried it left white marks everywhere. I just rinsed again and broomed off the standing water but we will see what it looks like in the morning. Did I do something wrong? Will that happen after every rain or was it just the standing hose water? What tips do you have for me? Thanks!
It may have not cured fully yet. The white marks should go away when it dries and cures fully.
My deck currently has RAD semi transparent light walnut around 3 years old is it ok to use TWP 100 on my next staining and what would be to process for best results ?
If you want to switch, you would need to strip and brighten for prep.
Hi:
My name is Frankie.
I used One Time Wood treatment for a terrace roof and columns eight years ago.
I’m completely satisfied with the product in every aspect. (Consider we had Hurricane María back in 2017)
But I cannot find the product again.
It’s still looking good, but I’m overdue for a touchup
Any suggestion for any other product?
I will appreciate the point of view.
You will need to remove the One Time if switching. Strip and then brighten to do this. Try TWP Stains or Armstrong Clark Stains.
Thank you for your quick response
and suggestion.
God bless your family and work
Thanks and you too!
Hi Dave…..my deck currently has Sikkens Rubbol Solid Stain on it.what products can I use over the top of it?
You can apply another solid stain over it after prep. See this for tips: https://www.deckstainhelp.com/how-to-reapply-a-solid-color-deck-stain/
water based or oil?thank you
Solid stains only come in water based these days.
I have an older deck. It had a lot of mold and dirt. Should I use a solid stain to fill in cracks better? Or the semitransparent? I want a taupe color because it would blend in well with my brick and siding
If you want a taupe color then you need a solid stain. Clean and brighten for prep. Look at Restore A Deck Solid stains.
FYI, solid stains will not fill in cracks. No need to fill the cracks as this is normal for exterior decking and not a concern.
Hi, I purchased samples of the RAD Semi-transparent Deck Stain in both Light Walnut and Cedar colors. I took a single rough-sawn groove half of Cedar Tongue & Groove siding that had been cleaned and brightened, and on the top half of the board, I put a coat of the Light Walnut, and on the bottom half, I put a coat of Cedar color. The Light Walnut turned out to be a lighter color than the Cedar color — on the same board! Were the samples I received mis-marked? If not, what could cause this? I have attached a photo to show the 2 colors on the same board. The narrower board on the right has the RAD Semi-transparent stains on it. The wider board on the left has samples of the Defy Extreme Semi-transparent wood stain on it. The same thing happened. The Light Walnut color is on top, and the Cedar Tone is on the bottom of that narrow board. Why is the cedar tone coming out darker? I checked that I properly marked the boards with the correct colors and stain type. I even did a second board of each to verify that the Light Walnut comes out a lighter color than the Cedar Tone in both stains.
No, it is correct. Cedar leans to be a little more brown while Light Walnut has a reddish brown color. In general, they are very close in color.
Also, make sure to shake both stains/samples vigoursly for a minute before applying
Scott I’m doing a post & beam porch of rough cut hemlock lightly sanded, is Defy extreme STWS a good choice? do I need to pre condition the pine to stop bleeding out? if so what to use . also under the porch ceiling I will do tug & grove knotty pine I have same questions as above – stain type, pre condition?? I’m not a fan on using a polyurethane
enjoy reading your reviews on different stains
Thank You
Defy Extreme would work well here. Also, consider the Restore A Deck Semi-transparent stain. Look at the Natural color. You cannot pre-condition before using a penetrating exterior wood stain.
Hello Scott, I have been looking at the TWP 200 series for a vertical surface that needs UV protection, but I am wondering if there are any better options I don’t know about. I am in Maine, and i am looking at a stain for a vertical fence and an inset porch and posts that will be vary from full sun to full shade depending on the position. I am more concerned with UV than rot, because I will be using atlantic white cedar and will be well above ground. What is your best bet if UV protection is the #1 concern, and the hope is for more years between applications?
Thank you in advance. 🙂
The TWP 200 would work very well. Also, TWP 1500 Series or the Restore A Deck Stains. When it comes to UV protection, darker or richer colors will hold up longer.
Hi Scott. I need to restain my 5yo fence in the DFW area. What stain would be best for this project?
Need more info as prep is key. What was it stained with prior? Brand and type? Pics would help as well. You can add them in the comments.
Thank you! It was stained by the builder before we moved in. Probably wasn’t sealed.
It was builder grade stain 5yo.
Clean and brighten for prep with Restore A Deck Kits. For the stain, try Armstrong Clark or Restore A Deck Stains.
thank you
What is your recommendation for Tongue and Groove Douglas fir porch boards. The wood had been treated with an oil based sealant approx. 3 years ago.
My Boathouse is located in north Alabama. It basically has three paint areas with each about 500 square feet; the pier, the deck with about half of it covered and the inside of the boathouse. Each of which were Solid Stained using a Home Depot product.
The Pier – Replaced about 90% of the decking with pressure treated limber as it rotted and peeled. I want to stain this ASAP.
The Deck – In the 2025 spring, I plan on replacing boards as require and stain with the same product as the Pier. The covered area is in good shape
The Boathouse – For the most part I plan on leaving as it -it’s in good shape
I am 76 and plan on doing this myself in phases. I am looking for a Solid Stain Recommendation. Your advice would be greatly appreciated.
Pier/Deck – See this about new wood first: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
For the best solid stains, see here: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
We prefer the Restore A Deck Solid stains.
What products and deck stain/color do you suggest for this deck in Michigan? I am considering Restore- a- Deck Stripper/Brightener followed by Light Walnut stain. Is that what you suggest?
Yes, that would work well for this. Are you in Metro Detroit? You can pick up in Bloomfield Hills.
Thank you! No we are in Grand Rapids.
I am located in Vancouver Island, Canada (West Coast). The exposure is SW so it gets significant sun and it is on the ocean so it has that exposure as well. The deck cedar. We can get mold or mildew, but usually not on the deck as it is hot with the SW exposure; however, the side door staircase and platform made with cedar does get mold/mildew as it gets less sun. We bought the house 2 years ago, so I am not when it was stained last. Unfortunately, the previous owners applied Cloverdale Sunfast on the deck which Cloverdale tells me is not a product for horizontal surfaces. It looks like they reapplied it over the years as it was quite patchy. We have done a significant amount of sanding as Cloverdale said we would need to remove that the Sunfast before applying a new product – they recommend Cloverdale Sharkskin Deck which is water-based. Based on reading the information on your website – water based may not be the best choice. First two photos are of the deck when we purchased 2 years ago. The last is after sanding, which we started in June. It has began to weather so we may need to do further prep. Any help with product selection etc would be appreciated.
What a nice deck and view! It looks like your nails/screws are rusting (black marks around each). You may have removed the protective coating when you sanded or the builder used the wrong type. If it bothers you, you would have to replace all of them to fix. Make sure to clean and brighten all wood before using a stain. For Canada, look at TWP 200 Series or Armstrong Clark Stains. They are oil-based and allowed for Canada.
I CANNOT GET THE TWP 100 IN COLORADO. IS THE 200 A GOOD OPTION? THANK YOU FOR YOUR HELP.
BILL
Use the TWP 1500 Series for CO:
https://www.twpstain.com/twp-1500-series
We just installed a weather treated, sanded, new cedar railing to long outdoor stairs 2 weeks ago and want to stain it. Seattle, limited sun exposure. Does it need sealant before a semi transparent stain? Water or oil base? Should be steer away from Clear? Do we really need to wait the winter before staining? Thank you!
You cannot add a sealer before a exterior wood stain. Clear has no UV protections. Use a semi-transparent stain. It does need to wait until spring:
I have an 8 X 20 cedar deck, built in 2016, in the Seattle area. It has wood – presumably cedar or possibly hemlock – railings too. The contractor used an eco-friendly, plant-based stain called TimberPro Coatings (Portland, OR). He also used it on a privacy fence. It looks good and has held up well in general, with the exception of decking exposed to sun and rain, which cracks and flakes. Covered decking has held up, as has the railings and fence, but the exposed decking is driving me mad. I repair it every summer but it starts to fail again in about six months. I finally decided to take another route. Stripped the Timber Pro stain with their stripper last fall, but couldn’t get it all off. Now I am back at it. I got Defy stripper to try this time. I was going to use Ready Seal, thinking it wouldn’t crack or flake, but there are other negatives. Also considering Defy. But thinking an oil-based product would be less prone to cracking again? Can I strip with Defy stripper and stain with TWP? Or would it be best to follow Defy stripper with Defy stain?
You can strip with Defy and brighten after. You have to brighten. Then use TWP or any brand that you choose.
I pressure washed and used a cleaner on an old, moss covered deck. It came cleaner than I had expected but 1/3 of the deck never sees sun. It just won’t dry out. What are my options? I have fans on it right now but I’m not so sure this is going to be enough. Should I just wait and stain next year? I could stain the 2/3 of it that is dry and wait and hope it dries out enough before the snow flies. Not many product available for wet wood. It was previously coated with a restore a deck/ deck revive type stain that has grit in it. Of course not all of that will come off in the area under the eves. The wood is in rough shape and I thought I would use a similar product but I know if I apply to a wet deck it will peel. My original thought was cabot deck correct but not so sure now. Help.
You must fully remvoe the Rust-Oleum Deck Restore before using any other brand. Once this is done, use a penetrating semi-transparent stain. Spring time will be okay.
Hi All –
Thanks for the helpful and inspiring info on TWP 100… I have some beautiful Black Walnut rails that I just built for the new deck – what color will best feature the natural beauty of this wood? I’d rather ot ‘color’ it too much? I see the “Clear” offers no UV protection… Many thanks again!
Drew
New wood cannot be stained right away. Needs to weather and be prepped. When was it built?
I cut and milled the walnut 5 years ago, and it’s been stick-drying ever since… ripped and planed the rails two weeks ago, installed, and sanded right away…
thanks for the speedy reply!
Drew
You need the wood porous. Deck stains do not work like interior wood stains. You should let this weather outside until Spring. Clean and brighten for prep, not sand. See this about new wood: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
It applies to hardwood like your Black Walnut wood. You would then want an exterior hardwood stain. See here for options:
Copy on all counts Scott – on top of all this, the deck itself is 24 year old pressure treated pine (I hear that’s the old treatment), from my parents old house next door. The new owners pulled it off the house, and asked if I wanted it – YES! I towed it to my house w my tractor, and removed each board (painful galvanized screw-shank nails). Ran the previous bottom side of each deck board through the planer for a fresh new surface, and routed new softer edges (see photo). Joist tape on the original joists, and redecked it all w scews. Posts and steps are new, Should I go w TWP100 for that part?
You rock – Drew
Where do you live?
Asheville, NC – deck has 3- 6 hours of direct sunlight daily, depending on time of year… I’ll likely use the ‘Restore-a-deck for the old pressure treated white pine…
Yes, the TWP 100 Series can be used in NC and would be a great option.
Hi Scott – Many thanks again – I appreciate feeeling informed and being instructed on the restoration steps available to acheive long lasting beautiful decks! You are doing good work, and I trust it comes back to you in many ways!
Drew
