This post was updated on March 17, 2026
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Best Deck Stain reviews and help tips are based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
Elevate Your Deck with the Best Wood Stains & Sealers
Whether preparing for a DIY deck-staining project or looking for the perfect stain to share with your contractor, I’ve got you covered. I have rounded up the eight best deck stains available in 2026, including oil-based stains, water-based stains, and semi-transparent and solid options.
Scott’s Expert Guide to Choosing the Best Deck Stains
Questions About Which Deck Stain or Sealer to Use?
Want personalized help? Post your questions below in the comments, and I’ll gladly guide you toward the best deck stain and sealer. Please include any pictures you may have and a brief history of the deck.
Over 30,000 Q&A Comments Below on this article. Ask Below, I Love to Help!
My Recommended Best Deck Stains and Sealers at a Glance
Click on the link and jump straight to the review:
- Top-Rated Deck Stain: TWP 100 Pro Series Stain Review — This deep-penetrating, long-lasting, semi-transparent stain is oil-based, easy to apply, and withstands the elements for up to 3 years.
- Recommended Semi-Transparent: Restore-A-Deck Semi-Transparent Wood Stain Review — Restore-A-Deck’s UV-resistant, semi-transparent stain can be applied to damp wood, which means we can prep your deck and apply the stain in one day.
- Leading Semi-Solid: TWP® Semi-Solid Pro-Series
- Oil-Based: TWP 100 Pro Series Semi-Transparent
- Best Water-Based: Restore-A-Deck semi-transparent deck stain
- Recommended Solid Color: Restore-A-Deck Solid Color Wood & Deck Stain
- Best-Applying: Armstrong-Clark Wood Stain — This long-time favorite is a hard-working, deep-penetrating option that goes on easily and allows for simple maintenance.
- Excellent Semi-Solid Wood: TWP Pro Series Semi-Solid Stain — TWP’s semi-solid stain goes on quickly, holds color well, and offers maximum UV protection and a variety of color palettes to choose from.
- Outstanding Wood Preservative Deck Stain: TWP 1500 Series Semi-Transparent Stain — TWP’s 1500 Series consistently ranks as one of my top options for deck stains, thanks to its deep-penetrating formula, UV- and mold-resistant properties, and long-lasting color.
- Recommended for Mildew: Defy Extreme Semi-Transparent Wood Stain — Defy’s water-based Extreme Wood Stain offers rich, penetrating color and an infusion of zinc oxide Nano-particles that prevent damage from UV rays, mold, and mildew.
- Best Deck-Resurface Coating: Gulf Synthetics Deck Revive
Steps to Picking the Perfect Deck Stain for Your Needs
Is There a #1 Rated Best Deck Stain or Sealer?
Transparent Stains
As the name suggests, transparent stains are clear or very lightly tinted stains that help seal and protect wooden decks while still allowing the wood grain to show through.
Semi-Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
Common Deck Staining Mistakes and How to Avoid Them
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly.
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time.
From: $41.99 | From: $47.99* | From: $65.99* | From: $69.95* |
*Free Shipping Included
- Ease of application
- Wear and tear after 2 years
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
5. Ready Seal Wood Stain
3. Defy Extreme Stain
- Scott’s Pro Tip: My most used deck stain in the past 30 years! We have used the TWP 100 Series on many 1000s of decks.
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Scott’s Pro Tip: My favorite deck stain to save time and money. We prep and stain on the same day.
My Test Deck Stats
UV Exposure: 50% Full Sun
- Scott’s Pro Tip: Regarding ease of application and performance, the Armstrong Clark stain is one of my top stains. We love their semi-solid colors and performance.
My Test Deck Stats
Deck Square Footage: 600
- Scott’s Pro Tip: My favorite penetrating semi-solid wood and deck stain soaks into the wood and provides excellent UV protection.
My Test Deck Stats
When Tested: August 2020
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Scott’s Pro Tip: My favorite current penetrating semi-transparent oil-based stain is the TWP 1500 Series. Michigan switched to low-VOC, so I now use it on the majority of decks that I restore.
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Scott’s Pro Tip: My new favorite IPE and Hardwood Deck stain is the first stain I have ever seen last more than one year on exotic hardwoods.
My Test Deck Stats
Stain Color Used: Chesnut
- Scott’s Pro Tip: The Defy Extremes is one of my top choices when using a water-based semi-transparent wood stain.
My Test Deck Stats
Stain Color Used: Cedartone
- Scott’s Pro Tip: Ready Seal Stain is not my favorite since it requires annual recoating, but I do like that it applies easily. Ready Seal does not cure fully and can rub off the wood on clothing.
My Test Deck Stats
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Deck Stain Facts: Frequently Sought Answers
When helping people choose the best deck stain and sealer, I often hear many of the same questions. Here are some facts and words of advice about exterior wood stain that can help answer these questions:
What is a deck stain?
Deck stain is a type of finish applied to the wooden boards of your deck. Generally speaking, deck stains come in three types —transparent, semi-transparent, and opaque —and are available in a wide range of colors to suit your taste.
Answer: The deck stain must be tinted to protect it from UV graying. I prefer semi-transparent stains, as they do not mask or cover the wood but highlight the grain while providing UV protection.
Answer: My favorite deck stains have been penetrating semi-transparent and semi-solid stains. These stain types allow the wood grain to show, and if they truly soak into the wood grain, reapplying is easier down the road.
What deck stain types can be cleaned and recoated as needed?
Answer: Penetrating deck stains are not prone to peeling, and we can clean and reapply them as needed. Deck stains that dry or film on top of the wood are much harder to maintain and prep when reapplying.
Answer: Absolutely! Deck stains are wood stains and work very well for wood fences, vertical wood siding, and log cabins. They last even 2-3 times longer on vertical wood.
The waiting period before staining a new deck can depend on the material used to build it. Take a closer look at our recommended time frames based on deck material:
- New, smooth wood decks: Wait at least 3 months before applying stain.
- Rough-hewn wood decks: No wait time is needed; you can apply stain as soon as the wood is clean and dry.
- Kiln-dried or KDAT wood decks: Wait 1-2 months before applying stain.
For more information, check out this guide on how long to wait before applying stain to your deck.
The most popular deck stain colors of 2026 include:
- Cedar tones
- Brown tones
- Honey tones
- Redwood tones
The best way to apply a deck stain can vary based on the product used, but my personal favorite applicators include flooring brushes and stain pads. Learn more in this guide to the best deck stain applicators.
What’s the difference between a deck stain and deck paint?
Deck stain and deck paint are similar in that they add color to a wooden deck. However, deck stain typically penetrates into the fibers of wooden deck boards and often results in a more natural final product. On the other hand, deck paint is typically thicker and creates an opaque layer of color over the wood.
What’s the difference between water- and oil-based deck stain?
Both water- and oil-based deck stains can provide rich color and long-lasting protection against moisture and UV damage. However, there are some differences between the two stains.
For instance, oil-based stains may offer advanced protection against warping or cracking and last longer than water-based stains. However, water-based stains are generally more environmentally friendly and easier to apply and clean up. Many water-based stains also feature additives to prevent fungal damage or wood rot. Learn more in this guide to the differences between water—and oil-based stains.
The 3 best deck stain brands for decks in full sun are TWP, Restore-A-Deck, and Armstrong Clark. The TWP 100 Pro Series semi-transparent penetrating deck stains in darker tints are best for most decks. TWP also has a semi-solid penetrating deck stain that works well in full sun. Restore-A-Deck has semi-transparent and solid deck stains for full sun. Armstrong Clark is a high-quality oil based deck stain.
Additional Deck Stain Rating Questions
If you have questions on this review of deck stains, please ask me below in the comments.
Want My Help Finding a Deck Stain?
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
- TWP 1500 Series
- Armstrong-Clark Deck and Wood Stain
- Restore-A-Deck Wood Stain
- Defy Extreme Wood Stain
I am here to help you find the best wood deck stain for your situation! Just post a comment below with answers to these questions.
Full sun in morning
Wood type: Cedar & Treated Pine
Deck is approximately 4 years old (gray)
Never been treated
We would like to stain it a darker color but still have the woodgrain show through.
Jamie, clean and brighten to prep. I would look at Armstrong Clark in Rustic Brown or TWP in Dark Oak colors.
Minnesota
Full Sun
Cedar
No
Peeled/wood turned grey
Kristine55104, clean and brighten the wood to remove the gray form the cedar deck. I would look at TWP 1500.
Northeast Ohio
Partial/Full Sun/shade (depending on different sections of the deck
25 years old, power washed and sealed every 3 years or so, so it's in pretty good shape
Graying, some light green molding in the real shady areas
Not sure I'm happy with the semitransparent stain from Sherwin Williams deckscape series we've used the last few times
Want something that brings out the natural wood grain, but adds just a touch of warmth/deepening of the color
JEH-BV, you are probably using the SW waterborne product that masks the wood a little. If you switch you will need to remove it then use a deep penetrating stain like Armstrong Clark or TWP.
minneapolis ,mn shade-some full sun , cedar no mold sun damage on part
Dennis, TWP or Armstrong Clark would be my choice.
Ohio
Full sun
Pressure treated pine
No
New deck
Julie, look at TimberOil brand for this brand new wood.
Indiana
Partial Shade
Pressure Treated Pine
No, new Deck
New Deck, 1st treatment
Jim, I would look at TimberOil Brand for this new deck.
I need a suggestion for stain type for my front porch deck. Not too much foot traffic, but does get "ice melt" thrown on it in the winter.
State….NE Wisconsin
Faces west…direct sun for about 4 hours then spotty sunlight thru a tree.
Wood is pressure treated pine
No mold or mildew issues that I know of
The deck is new.
Diane, I would look at the Defy Extreme Stain.
Indiana
Full sun
Peeling and gray
Been using Behr Premium solid color weatherproofing stain
Vertical surfaces look great but horizontal surface show major wear in sun and traffic areas pretty quickly. What should I use to strip off stain from vertical and what stain should I start using?
Brock, Behr is difficult to remove from the verticals. I would use one of the powdered deck stain stripper such as HD80 or Rad Stain Stripper. This way you can mix them stronger if needed. You will need to strip a few times and maybe even sand a little to get this off. Once off I would look at TWP 1500 or Armstrong Clark.
Fence Location State: Texas
Full Sun, Partial Shade, Full Shade: Full Sun
Wood Type: Cedar Board on Board
Mold or Mildew Issues: Yes
Reason for Previous Stain Failure: None (brand new fence)
RT67, For a fence that has mold issues I would strongly look at the Defy Extreme. It will perform extremely well and hold color for many years.
Georgia
Southern yellow pine
Partial shade
Yes, mold (or mildew–black sludge came up from cleaning) and some algae
Don't know the history of the deck. We've been here less than a year, and I just cleaned it to discover wood grain that had been covered in black in the shady spots. I'd like something lasting and protective. The deck gets lots of sun in part and is mostly shaded in other places; tough combo on the look of the wood.
Deborah, I would use TWP 100 Series or Defy Extreme.
Thank you. I have a couple of other questions from delving into this project further.
Is the TWP 1500 series significantly better then the 100? Since you don't mention it much, I thought you may be impressed with the 100's performance and price advantage enough to not be concerned with the 1500.
After reading this site a bit, I am thinking about going with a darker color for the railing than for the floor of my deck. What color looks good for the pine floor and gives good uv protection? How do I figure the amount of stain I will need for the railing?
Deborah, I thing the 100 Series and 1500 Series are pretty equal. We do not mention the 100 Series as much since it is not VOC compliant in many states. You want to do two colors? Darker for railing and lighter for floor?
yes
I would consider the 1515 Honeytone for the flooring.
Dear Deck Pros': Please advsie 1-2 top choices for staining :
1. So CA- Oceanside Ave temp 67F relatively high humidity, small amt of rain annualy.
2. East to West from the south
3.Redwood
4.Mold very slight issue
5. Deck replacement of old doug fir 20 years old.
Would prefer clear or semi transparent appearance.
Thnak you much !!
Missouri
Full sun in am. Shade in afternoon.
New deck. Cedar smooth finish on horizontals.
Mercross, I would look at the TimberOil Brand for this new deck.
If we go this route with new deck, does this limit in any way what product to use in 2-3 years to maintain? It is a large deck-2,000 sq. ft- so we need something that is as low maintenance as possible. We are wanting a natural cedar stain look.
Whenever you switch brands in the future you will need to remove the previous coating for best results. This can easily be done with a deck stain stripper.
Northern Virginia
Morning sun, afternoon shade
Newly replaced deck
Minor mold in shaded area
Not yet treated
Fred, I would look at the TWP 1500 Series for Northern VA.
New Hampshire (central)
Full sun
6 years old
African red mangeris mahogany, no Mold issues
I have used australian timber oil 2x ,looks great for 3mo, dissapointed with lasting performance,I didnt know there were other options, bad recomendations fron local paint store, dont want to make same mistake
deck is fully stripped and pressure washed, looking for new product
Warren, I would highly suggest the Armstrong Clark stain in the Mahogany color for this deck.
Iowa
Mostly shade (north side)
Red cedar (18 years old)
Mold, sun damage,green moss
No stain or sealant -just clean it every year (deck brightner and power wash)
We want to stain it this year, but first we will be replacing a few damaged boards with new cedar. Since we will have both new and old boards, which stain should we use?
Kathy, I would use the TWP or Defy stains for this deck.
Grand Rapids, MIchigan
Half shade, half sun (plus significant snow accumulation over winter)
7 month old deck – installed in fall, no treatment to date
pressure treated pine decking with cedar fascia and seating
mildew on cedar, some on pine in the shadiest area (separate landing) – came off with cleaning except for a few speck here and there
just cleaned deck with Behr all-in-one cleaner (only now saw you don't recommend that)
am ready to stain but in one post you recommended a brightener first for a new deck of similar age (is this necessary? It doesn't appear grey – at least to me)
what prep and stain do you recommend? I want a light color that will show the wood grain.
Tanya, the wood brightener will help remove the mill glaze from your newer wood. I would use it. I would look at TWP 100 Series for a Michigan deck.
I tried to find a location near me that sells TWP 100 and can't find any. I need to stain the deck this week so I don't have time to order a product online. Do you have a alternative recommendation?
Would the Defy Extreme Stain be a good alternative? I think I can get that locally.
Does the brand of brightener matter?
Thanks again.
Defy Extreme is a very good product as well. The brand of brightener does not matter that much.
One more question regarding sanding during this whole prep process. We were thinking we should sand the cedar and any other rougher areas with 150 grit or higher paper just to smooth out imperfections. Do you think this is good and if so, when should this be done? Before or after the brightener?
Tanya, do not sand. Spot sand will hinder the stain\’s ability to penetrate properly and evenly. If you sand, you would need to sand the entire deck with 60 grit paper then clean and brighten after.
East Central Iowa (20 miles from Mississippi)
New Cedar Covered wrap around Porch (800 SQ-FT) North and east facing.
Main entrance to the house so portion of it will be high traffic
We would like a transparent stain, Cedar Natural Tone Color
Behr was recommended (Consumer Reports). I do not trust them
Dave & Annette, for new wood we like the TimberOil Brand or Armstrong Clark. Make sure to clean and brighten the new cedar first.
1.Deck Location State: Northern VA
2.Full Sun, Partial Shade, Full Shade: partial sun and partial shade
4.Mold or Mildew Issues: N/A
5.Reason for Previous Stain Failure: N/A
Kovit, I would look at the Defy Extreme for your deck unless it is cedar wood.
It's PT pine, can defy extreme use it? Thanks
Yes Defy Extreme is a great stain for PT Pine!
1.Deck Location State: Nancy Lake (Willow, Alaska)
2.Full Sun, Partial Shade, Full Shade: Full Sun in parts, Partial shade in parts
3.Wood Type: Pressure Treated wood
4.Mold or Mildew Issues: Assume yes
5.Reason for Previous Stain Failure: flaked off, some of color faded
6. Staining what? Dock in full sun is pressure treated wood. Stairs and handrailings from cabin to dock in partial shade may not be pressure treated??
Nicole, what brands can you get in Alaska? Not all are sold there so maybe a breakdown of what is available would help us suggest one.
Any suggestions of best Semi Transparent Stain? Longer wearing
Deck Location State: St Paul MN
Wrap around House Deck. South Facing Full Sun All day no shade, East Side Partial Shade AM and full shade PM, West Partial Sun Early AM and Full Sun Midday, Shade Mid Afternoon.
Wood Type: Cedar Select Grade
No Mold or Mildew Issue.
The Deck is 10 yrs old. Used TWP first year and third year. Super Deck yr.5 and 8.
Reason for Previous Stain Failure: I assumed all just weathered away. Super Deck properly applied but result in year 8 seemed to look too "shiney". Area's in Sun weathered quickly turning grey, and those in Shade looked dirty with traffic areas looking worse.
Contractor stopped using Super Deck, but didn't state any problems.
Never would use a power washer. Used hose with water wand. Day One, Cleaned and prep per Mfg instruction. Day Two, Fully dried, Temp 80, and no wind. Applied with spray, second person brushing in, and third person wiping each board. So smooth timing at each step.
Maybe a different product for St Paul.
You need to strip off all these old coatings. That is why you were getting shiny spots and dirt trapping in the SuperDeck. I would look at the Armstrong Clark stain this time once it is properly prepped
Deck Location State: Northern Virginia / 30 miles west of Washington DC
Full Sun, Partial Shade, Full Shade: Full sun
Wood Type: New 2 month old Pressure Treated Pine
Mold or Mildew Issues: none yet
I am trying to figure out the best start for taking care of my deck. I am uncertain how long I should wait for any aging, although I would prefer to proactively seal before any mold or aging issues and continue to re-apply in the coming years as needed to keep it in good shape. Should I use one product now, and another later? Should I wait an optimal amount of time and use one product, reapplying the same every couple years, etc? Any help is appreciated.
Steve, I would wait 1-2 months then lightly clean the wood to prep. I would look at only one coat this year of either Defy Extreme or TWP 1500. You can reapply the same when needed in the future.
1. Alabama
2. Full Sun
3. Pressure treat pine (Yellawood)
4..New Pier on lake
5. Want to maintain the Yellawood "Natural" look. Also, want to stain or paint a Logo on the deck after sealing it.
6. I cleaned it last week with Behr All Purpose Wood Cleaner. Will I need to reclean it if I wait too long to apply a sealer?
Behr is not a very good cleaner but since it was new it is probably sufficient. I would look at Armstrong Clark in Amber or Defy Extreme in Natural Pine.
Thank you! Is there a better cleaner? How long after I cleaned it is too long to wait to seal it? Should I clean and seal the 2X10 Bands around the outside of the pier?
I would stain within a couple of weeks at the most after cleaning. It would not hurt to do the outside boards of the pier.
Thanks! If I reclean what do you suggest I use? Also, I'm being told by a consultant to my employer to use a 20% Siloxine solution. What are your thoughts?
I good powdered deck cleaner and wood brightener. Defy Wood Cleaner and Restore-A-Deck are a couple. \”Siloxane\” is used in sealers for concrete.
Illinois
Full Sun
Western Red Cedar, 6 years old
No Mold/Mildew
Behr Premium Semi-Trans applied with Wagner pad peeled off in less than one year. Deck is currently stripped, cleaned, pressure washed, and brightened. Hoping to stain tomorrow!
Want to use transparent this time by the way.
Chad, Not sure what you can pick up locally for today but if you can find it, I would use TWP 1500 or Defy.
State: New York (Long Island)
Full sun
Not much mildew
Major Oxidization/graying
-Was stained 2 yrs ago with Cabot 9200 Natural after pressure washing
Matt, I would clean/strip and brighten the wood to remove the graying. For pressure treated wood in NY, I would use the Defy Extreme Stain in Natural Pine
ARVADA COLORADO
FULL SUN
10 YEAR OLD DECK
NO MOLD
STAINED SEVERAL YEARS AGO
USED PENOFIN (BRAND NAME) AFTER A YEAR OR SO STAIN BECOMES DARK WE HAVE SANDED THE DECK 4 TIMES SINCE PUTTING IT IN BECAUSE OF THE DISCOLORATION
Cindy, I would look at TWP 1500 or 100 series. It does not darken in color but fades lightly through the years.
KANSAS CITY MO
MORNING SUN
4 YEAR OLD DECK
STAINED 2 YEARS AGO HAD HAIL DAMAGE LAST YEAR
PRESSURE WASHED ALREADY AND DECIDING ON KIND OF STAIN
PRETREATED PINE
NO MOLD OR ALGAE YET BUT SHADED IN THE PM AND THE GRASS GETS MOSSY IN SPOTS AROUND IT
Sherry, Defy Extreme if you are worried about mold or algae. Second choice would be TWP.
Deck Location State: Maryland
Full Sun, Partial Shade, Full Shade: Full Sun in afternoon
Wood Type: Ipe wood
Mold or Mildew Issues: very little, but old stain needs to be removed
Reason for Previous Failure: when first applied it bubbled up and was sticky for several weeks. Now the deck is very dark.
Lew B, I would strip off the old dark stain and brighten the IPE wood. As for re staining, I would look at the Armstrong Clark Stain in the Mahogany color or the Defy Stain for Hardwoods in Light Walnut.
Austin, Texas
50% Full Sun, 50% Shaded by overhanging roof
Cedar, New Deck
Has not been finished yet
Want semi-transparent cedar color
Bill, I would look at the TimberOil Brand or the Armstrong Clark stain for this new cedar deck.
Second attempt to post this – user error on my part probably!
Kansas City
5-7 year old Cedar deck
Mostly shaded (by trees and house), partial sun
Some mold/mildew
Have cleaned with Deck Bright last two years but didn't get sealed/stained, hence need to reclean each year. Just cleaned again with Behr cleaner (couldn't find Deck Bright), and now REALLY want to seal!
Seeking transparent or semi-transparent sealer (love look of natural cedar when clean/wet!) that doesn't get too slippery when wet. Thank you!!!
Jam, I would look at the TWP 1500 Series in the Honeytone color or the Defy Extreme in the Natural Pine.
Northern Virginia
Full sun/sometimes townhouse shades the deck
5yr old PTP
No mold or mildew
stained with behr premium 2-3 years ago. flaking but hasn't greyed much. what stain should I use and what is the best method to remove the remaining stain?
Fred, you need a pretty aggressive stain stripper to remove the Behr. I would look at HD80 or RAD Stain Stripper. Both need to be neutralized with a wood brightener. For the deck, I would look at the Defy Extreme for northern VA.
Help! We're so confused…water based or oil based? And, which specific product? From what we've read, pros re: water based are better protection, less mold/mildew issues; but cons include subject to peeling and cracking (and more maintenance later due to stripping, etc?). As for oil based, pros seem to be better penetration, easier application, not subject cracking and peeling; but cons include higher mold/mildew issues. And if oil, read should avoid linseed or soy based products to minimize mold/mildew issues; instead look for products that are alkyds, contain additives prevent mold/mildew, and include transoxide pigments (whatever those are). All this reading and we're stymied! Help!
1. Location: northern IL (northwest of Chicago).
2. Sun or shade: deck is on the north side of the house and has semi-circle cutout to accommodate 100+ year old oak tree. Deck gets partial sun/partial shade depending time of day & season. Also gets droppings from tree leaves (and resins?) and acorns and occasional gutter overflow.
3.Wood: pressure treated pine, installed 2-3 seasons ago; never treated (and in process of cleaning now before staining).
4. Mold or mildew: Yes, some in past with our old cedar deck. Anticipate potential future due to north facing and the oak tree.
5. Reason previous failure: N/A as new deck never treated. (As to old deck, some problems due to lack of maintenance.
We're in limbo…..any help you can give is greatly appreciated. Thank-you.
The2Zees, you are correct with all of your comments. I would look at the two products:
TWP 1500 Series- Oil Based, does better than almost all oil based stains when it comes to mold prevention. this is because it contains a different mildewcide that makes it a registered EPA wood preservative. The only stain that achieves this.
Defy Extreme stain – Water Based, Defy makes the best penetrating water based stains on the market. They use a completely different resin then the other manufactures. This resin penetrates better, resulting in less chance of the peeling that many water based stains are prone to.
Hopefully this helps!
Deck Location State: Illinois
Full Sun, Partial Shade, Full Shade: Northern exposure, goes from full shade in morning to full sun in late afternoon.
Wood Type: Cedar
Mold or Mildew Issues: None, less than a year old, never been stained, slightly greyed.
Reason for Previous Stain Failure: n/a, less than a year old, never been stained, slightly greyed.
Mike D, make sure to clean and brighten the wood to prep. IL is a low VOC state so I would go with the TWP 1500 or Armstrong Clark. Defy Hardwood Stain for cedar would be another good choice if you would want an water based stain.
South Carolina
full sun
Mold problem
A new dock and 15 year old deck previously covered with semi-transparent stain
Terry, Make sure to prep both the new and old decks. The new deck needs a wood cleaner and a wood brightener. The olde deck needs to be stripped and brightened. I would look at the Defy Extreme Stain. It has excellent mold resistance.
Minnesota
Full sun/snow
15 year old cedar deck
No mold or mildew
Just stripped and neutralized previous application of Sikkens (transparent cedar)- peeling and breaking down after 2-3 yrs.
Tim, TWP would be an excellent choice.
Florida – on the beach
Full sun
10 year old mahogany shutters
No mold
The shutters we neglected and the varnish peeled
Greg N, I would look at the Armstrong Clark stain in the Mahogany color for these shutters.
Deck Location State: Northern Wisconsin
Partial Shade
Wood Type: Cedar
Reason for Previous Stain Failure: Peeled and turned dark in color
Denny, I would look at the TWP or the Armstrong Clark for your deck in a cold weather state.
Kansas City
Partial (mostly) shade
5 years old cedar
Have cleaned annually (with intent to seal) because turns very gray/mildewy but haven't gotten to sealer before intense heat. Just cleaned days ago with deck cleaner and REALLY want to seal this year so I don't have to clean EVERY year.
Want semi-transparent or transparent (not a lot of color), do not want to sand or apply by hand and concerned about being slippery after treatment.
I would look at the TWP 100 Series. It is not a slippery stain as it penetrates into the wood.
Deck built July 2011. Around pool – so lots of foot traffic & it gets wet. 56" off ground. Never stained.
Cleveland Ohio area
full sun (plus snow/ice in winter)
10 months old (been thru 1 winter)
current issues: some popped knot holes, some splitting & slight warping, small dark specs almost everywhere which I assume is mold or mildew.
Been doing lots of research on this as its our first deck & I want to approach the staining/sealing right the first time – we built it ourselves & it was an enormous back-breaking job and we want it to last. We do want a product that we can buy locally – within 50 miles of us (rather than an internet buy) in case we run short.
I'm thinking based on your suggestions, the Armstrong or timberoil. Please advise. thanks for a great site – appreciate all the helpful info!
I would look at the Armstrong Clark or the TWP 1500 Series for this 1 year old deck. I am not sure though if they can be found locally.
Deck Location State: Louisville ky
Full Sun, Partial Shade, Full Shade: full sun
Reason for Previous Stain Failure: purchased the house 2 years ago. Previous owner had just applied fresh stain. The stain is not transparent. Two different colors. Darker on the rails and lighter on the deck. I have no idea what product was previously used. We have dogs so traffic is an issue. It's a large trilevel deck. One level is exposed to full sun. The other two are under cover. The exposed area looks really bad now with peeling issues. I just cleaned over the weekend to see how bad it really is. The traffic is the issue with the steps and the covered areas. I was looking into the deck restore product for the durability. The wood is in really in very good condition just a stain issue. The previous owner seemed to stain the deck regularly. Also we have a cedar picket fence with the dark finish that also needs refinishing.
Thanks in advance for the advise.
JR
Sounds like you have a solid color deck stain. Solid color stains will peel and they cannot be removed effectively so that you can go with a semi-transparent. The Synta Restore is an alternative but it is not a end all solution. It will also peel eventually. I believe it cannot be applied over an old stain either. Might be best to just reapply a solid color stain again.
Portland, Oregon
Full sun during middle of day; partial shade in am and late afternoon. Deck on north side of home.
5 years old Ipe deck
some mold and mildew
Applied Messmers a month or two after installation and 2 years ago, but wonder if something else will last longer.
Have washed deck and want to apply best product. Do all recommended products need to be applied to dry decks? Is there a recommended product that can be applied to a deck that is not very dry?
With IPE, nothing will last that long. Messmers is a very good choice. You could also look at the IPE Oil and Defy Stain for Hardwoods. None of the stains can be applied to a damp deck.
Deck Location State: Portland, Oregon
Full Sun, Partial Shade, Full Shade: Full Sun through the morning until about 1pm, it is on the east side of a 2 story house and hence is shaded during the latter half of the afternoon
Wood Type: Mahogany
Reason for Previous Stain Failure: previous stain was Behr (POS), failed in 3 months, you could see some sections lift the stain into the puddles from the rain.
Additionally, I've got a very energetic black lab whose paws (nails) can be very hard on the surface, he loves to run and leap on and off the deck. the deck is 45X15
John, for this hardwood deck I would look at the Messmers UV Plus for Hardwoods or the Defy Stains for Hardwoods.
Full sun/partial shade
Mold/mildew… Not yet
This deck was built last summer and has never been stained. We have noticed some of it has grayed. We are planning on sanding it before staining. Would we still need a cleaner? And we're assuming we need a brightener.
Michelle, I would not sand but rather use a wood cleaner and a wood brightener to prep. For staining I would look at TWP 1500 or Armstrong Stain.
Deck Location State: Central Virginia
Reason for Previous Stain Failure: Peeled and wood turned dark and dried up.
We replaced the deck last spring so it has been 1 year now and we want to stain it. The deck is in the sun from 9am to 5pm, we are wanting to have a tinted stain as well. What should we do to prep the deck for the stain as well.
Heather, To prep I would use the Restore-A-Deck kits. Vert easy and cost effective. For the stain, I would look at Defy Extreme or TWP 1500.
Minneapolis, MN
Full sun
3 yr old deck
Cedar decking with graying (before sanding)
No mold
Previously used semi-transperant waterproofing stain to retain natural color (fail)
Prepared it by sanding down the wood to get the cedar color back. Just needs a fresh coat of stain.
ERick, TWP 1500 would be a good choice or you could try the Armstrong stain.
Indianapolis, IN
Full Sun late morning to late afternoon
Pressure treated pine & rough cedar on privacy screen
Deck installed 4 years ago
Currently trying to remove Sikkens Cetol SRD in Mahogany–it's been a nightmare. Finish never functioned properly, it barely protected horizontal decking so the boards are cupped and cracked in places and then had issues with finish in other areas being more of a varnish. It's peeling on some of the pressure treated wood on privacy screen. Sticking great to cedar, and pine spindles-the rest not so much. We have sanded some of the wood but not all of the color/finish came off. So we tried using Defy deck stripper and it is not removing this stuff! Don't know what to use to remove and have not tried powerwasher yet. Not sure if I will get all of the dark mahogany off so I will need a stain that will be a close match. Before finding this website, picked up Cabot Australian Timber oil in Jarrah Brown. Tried at test spot on railing and it was very spotty over the sanded and some of the finish left…HELP on Stripping, getting finish off of spindles and little nooks and crannies, power wash?, drum sand, Stain—you name it we need help!! Also was recommended to use regular oil based stain to achieve desired color then go over it with marine spar varnish.
JFS1010, DEfnintely do not use a spar varnish! This is what I would suggest.
1. Get the Restore-A-Deck Stripper. This is a powder so you can mix it stronger if needed. It probably will not remove all but it will get more off. I would use a pressure washer with the stripper as a high rinsing tool.
2. Sand where needed.
3. Look at the Armstrong Clark Stain in the Mahogany or Sequoia color to blend in what you cannot remove of the Sikkens SRD.
Good luck!
Thanks!! Was anxious to get going on the stripping and since I was not sure about the Restore A Deck and would have to order online I went ahead and picked up Duckback Superdeck stripper and brightener. I used it on a small area and worked on it off and on for an hour and it really did a good job removing. Now I have a belt sander and DA Orbital Sander to work it over. Going to try to get as much off that route then strip and then sand where needed. One bonus, got a woodworker that is going to take my railing down and take it apart in his wood shop and sand it all down to the bare wood. Yeah for that!! Thanks for the reply. I am very much interested in the Armstrong Clark stain–that is the conclusion I came to too!
Great site!
Flagstaff AZ
Full sun
16 years old, Redwood
No mold on deck – redwood pickets have black mold from snow drifting
Last coated with Behr Premium solid acrylic – sanded to bare wood, nearly 80% peeled inside 2 years
Thanks for any guidance stripping, cleaning, staining.
Mark, Thanks for the kudos! I would get the Armstrong Clark stain for this AZ deck with high UV index.
Where can you buy Armstong Clark in Northern California?
I am not sure. You could try their website at http://www.armclark.com
San Antonio, Texas
Partial Sun
3yr old Cedar Deck
Light mold cleaned with pressure washer
Some greying but no major failure, just ware
Don, For Texas I would look at the Defy Extreme Stain or TWP 1500.
Toronto, Ontario, Canada
Full Sun
New Deck of Western Red Cedar
Les, not sure what you can get locally. If buying online, I would look at the Armstrong Clark stain.
Would recommend the Armstrong Clark over the TWP 100, even though the TWP is your top rated stain? If so, why?
Thanks again.
Les, TWP cannot be shipped to Canada.
1.Deck Location State: Illinois (Chicago)
2.Full Sun, Partial Shade, Full Shade: Partial Shade (winter the deck gets little sun, summer it gets full sun)
3.Wood Type: Pressure Treated Pine
4.Mold or Mildew Issues: Yes (only in one corner that gets no sun)
5. Never stained, just cleaned every other year.
Paul, I would look at the Defy Extreme Stain for this PTP deck with some mold issues.
