TWP 100 Wood and Deck Stain Review 2026 4.5/5 (42)
2026 TWP 100 Series Review
Important Note: The TWP 100 Series has undergone a label change and is now called TWP 100 Pro Series. Rest assured, it’s the same trusted product with identical performance and colors.
At DeckStainHelp.com, we’re proud to be your go-to resource for everything related to exterior wood and deck restoration. Customers who have used the TWP 100 Series consistently report that their decks have weathered the harsh winter remarkably well, standing the test of time and the elements.
We value your feedback! If you’ve used the TWP 100 Pro Series, feel free to share your experience in the comments below. Don’t forget to include pictures of your completed projects—we’d love to see them!
TWP 100 Series Deck Stain Review
TWP 100 Series Stain RatingImportant Note:  This is our 2nd Review of the TWP 100 Series.
See our other reviews of the TWP 100 Series here: TWP 100 Wood Stain Reviews
TWP 100 Total Wood Preservative Deck Stain protects and maintains all exterior wooden surfaces. TWP Wood Stain is a special blend of chemicals in a contractor-grade formula that safeguards and protects exterior wooden surfaces.
TWP 100 Wood Deck Sealers lock out water and moisture that causes wood to crack, split, and warp. Freeze damage is also prevented in cold climates.
TWP Stains – 100 Stain Review
– The TWP 100 Stain was applied to a very large deck surrounding a pool. The wood was about 1 year old at the time and was prepped with the Restore-A-Deck Cleaner and Brightener kit. The wood was a knotty cedar and the Cedartone 101 color gave a rich look that is typical of a cedar stain. Knots and grain were enhanced and the stain dried evenly for the 2 coats that were applied to the floor.
– Same as the first time tested, The TWP Cedartone 101 retained about 80% of the original color after 2 years of weathering.
Wear/Tear and Peeling: 8
– We found that the TWP did wear slightly in about 20% of the floor area. It was mostly in the high-traffic areas that surrounded the pool. The upper-level deck in the back had little to no wearing.
TWP 101 Cedartone Color
Cost Per Square Foot: 8.5
– The price paid was $170 for the 5-gallon pail of TWP 101 Stain. We used all 15 gallons for the 2100 foot pool deck. We applied two coats to the floor and 1 coat to the railing.  The cost to stain with TWP 100 Series was $.23 per sq. foot.
– No mold, mildew or algae spores were present.
Ease of Application: 8
– As you can see from the photo, this deck was surrounded by a pool. We needed to be extremely careful of getting any stain into the pool. We did all flooring with a stain pad that allowed the stain to apply evenly and absorb well. We tarped the railings to prevent overspray and used a pump sprayer to apply to the spindles, back wiping the drips.
– The TWP did not darken from mold or UV discoloration. Slight water spots were noticeable around the edge of the pool.
The difficulty of Reapplication: 9
– Reapplication will be easy without the need for stripping off the two-year-old stain. The use of a wood cleaner and wood brightener should be sufficient prep. On this particular deck, we cleaned and prepped the flooring and reapplied it to the floor and top of the railings. We did not do the verticals as they still looked good from the original application.
Overall Score TWP 100 Series Stain at 2 Year Period: 8.69
– As contractors, we enjoy using TWP Stains. It penetrates well into the wood, fades lightly in color, and holds up to wear and tear. We like that when it is time to redo the wood in 2-3 years, the TWP can be cleaned and re-coated or even removed with ease. This makes the reapplication process much easier.
Note: We do not use TWP on brand new wood. If applied to wood that is less than 4 months old, it seems to have a difficult time with penetration. We find this with many of the stains we have used on new wood. The manufacturer suggests waiting 4-12 months to let the wood weather. We strongly suggest that you wait.
TWP 100 Pro Series Review
$58.99$68.99
$219.95$245.95
$270.00$296.00
5.00out of 5
$285.00$311.00
5.00out of 5
TWP Help? Search Google: TWP Stain Help
More Info: TWP 100
Cost: $41.99 per Gallon, $210 per 5 Gallon per Pail is the average
Available Colors: 100 Clear, 101 Cedartone, 102 Redwood, 115 Honeytone, 116 Rustic, 120 Pecan, 1o5 Cape Cod Gray, 106 Prarie Gray
Dry Time: 2-8 Hours
Deck Square Footage: 2100
TWP Cedartone Natural 101
TWP 100 Series Stain Photos
TWP 100 Pro-Series Review Video
Subscribe
Notify of
684 Comments
Robert
Robert
12 years ago
I was just about to move forward with a deck staining (5-10 year old pressure treated pine) and glad i found this site for the best products. I was about to go with SW oil-based on contractor recomm (as they get discounts), but looks like i may be changing to TWP100 series (101 natural) given the info reviews and comments on this site.
John S
John S
12 years ago
I live in Atlanta GA and just had a new PT Pine deck built, approximately 300 sf. It receives direct sunlight most of the day. I was told I would only need to wait about 6 weeks to stain….is this correct for the hot summers of Atlanta? Also, would you recommend TWP or Defy Epoxy? What type of prep should be done? Any other recommendations? Thank you,
Justin Sorem
Justin Sorem
12 years ago
I applied Sikkens SRD one coat Natuaral Oak color to my deck about two years ago. The color and water repellent on the deck flooring and top of the railings has faded, but the side railings are still repelling water and holding color. I'd like to stain the deck and railings again. What product would you recommend and how should I prepare the deck properly. Thanks!
Dave H
Dave H
12 years ago
I just put on a new 320 sq ft deck of pressure treated pine. I plan to use twp 100 series and maybe cedar tone. I plan to wait 4 months to coat. Do I need to wash first? Is one one coat enough or should I do two? If I buy 5 gallons, will the leftover keep for a couple of years?
Julie
Julie
12 years ago
I have two decks one 21×28 and the other 21×15 with a hot tub submerged part way. I had it done 3 years ago where he talked me into staining the deck. He used Dura-Stain semi stain. The deck is about 22 years old with a few boards new 3 years ago. Needless to say the deck starting peeling after year one, he came back and re-did areas that summer.. After the 3 years the deck was peeling in a lot of areas. I powered wash with 3 tubs of stripper from Home Depot. I cannot get all of the stain out. The side boards are mostly intact with the stain.
I have received a lot of different opinions as to what product to move forward with from Deck Over from Home Depot to using a solid stain from other companies like Benjamin Moore. I also asked about sanding, and everyone suggests I just solid stain the deck.
Any suggestions??
Julie
Julie
12 years ago
I tried power washing again yesterday and removed some more of the stain, but I feel I am ruining the wood. Do you have any suggestions for using anything on the deck to help get the stain off? It's not moving off the ends of the boards. I do live in Chicago area where the weather can be extreme in both directions. I am not crazy about putting down a solid stain, I do not love the colors.
What product should I use?
Diane
Diane
12 years ago
Reply to  Julie
I've spent hours researching what stain to use on m cedar deck in Washington since the Behr stain I originally used failed in the first year. TWP is highly rated by this site. I recommend you go to their website. Decks are a pain.
Jill
Jill
12 years ago
I am putting up a large brand new redwood deck with full sun exposure and need to know my best product. My biggest concern is not the sun but my pollution build-up. I live in Los Angeles very near several freeways and near Dodger Stadium, so I have an unusual amount of air grim that settles on my wood – it looks more dirty than grey. Is there a product that won't hold on to that grim during the year between yearly applications. I will hose it down but I need something that drys COMPLETELY, so that it cleans easily. So many people post about extreme weather – but I feel like I have a unique situation and need some help. Thanks!
kevin
kevin
12 years ago
I am planning on stain my deck soon. Just purchased home and the deck is around 4 years old and looks like it has never been treated. I plan on using restore-a-deck cleaner and brightner and twp 100 dark oak. The deck is pt pine, and is around 480 sq.ft. including railings and stairs. My question is would 5 gallons be enough for two coats ? or would I need 2-5gallon? Also my deck is up off the ground with concrete patio underneath so should i worry about treating underneath deck boards ? I live in N.kentucky and my deck is on south-west side of house . Thank you.
Maddy
Maddy
12 years ago
Just had a huge two level deck pressure washed without any cleaner (about 1000 sq. ft) and had to replace several rotten boards. It looks great and now it is time to stain/seal it but now I realize the new wood is going to not take the stain properly.
What is the minimum time I have to wait before I have it stained? I assume the stain also seals it as well?
Jess
Jess
12 years ago
Please explain the merits/differences between TWP 100and the 1500. Is one better than the other for cold snowy Eastern Washington state winters? T
12 years ago
Excellent site. I have a Big Green Egg table made of cypress which has weathered for several years and is getting dry. I am moving it from a shaded, protected area to an open deck. What products would you recommend to seal and protect the cypress wood?
rob & kim
rob & kim
12 years ago
We have a 10 year old cedar deck in northern lower Michigan. It was covered in urethane and then painted. We have stripped and powerwashed it. Waited two weeks, sanded, looks good. Is brightener/cleaner step necessary before twp 100 series is applied? How much drying time after cleaner step before staining? How much drying time after staining before it can be exposed to rain? Please be aware this is our weekend cottage. Great site, very informative!
MEW
MEW
12 years ago
My project isn't a large deck, but I want to keep my new untreated cedar porch swing with a stunning appearance for many years to come. After reading the comments about the nightmare's of removing an old finish, I want to do it right the first time. I would also like the upkeep in the years to come, to be female and senior friendly. I live in Twin Falls, Idaho. Should I let it age before applying the finish? I want to maintaine the natural cedar color, how should I proceed? Thank you for your help.
MEW
MEW
12 years ago
So which stain and color do you recommend to keep the cedar color?
dave
dave
12 years ago
can i put this right over readyseal?
Mar
Mar
12 years ago
I live just south of Nashville and have a 350 sq foot deck about 6 years old, it is yellow pine. Although it is on the north side of the house, there are no trees and it bakes in the afternoon sun. Five years ago I had it power washed and sealed it with a Cabot product. I am having it power washed in another week or so. What do you recommend for sealer and how long do I wait after the power wash? Although my previous sealer was semi-transparent, I am thinking more of a solid stain or very dark transparent.
Ben B
Ben B
12 years ago
Please help. Behr semi transparent peeled on deck again after one year in Wisconsin. Thinking of removing finish by stripping or sanding and using TWP 100 series or 1500 series. Deck is 30 year old cedar, well maintained with new boards over the years (cedar only). Which would be better for us, TWP 100 series or more expensive 1500 series. Want dark red color and semi transparent. What is best for stripping, Gemini Restore Kit or other? Power washing seemed to make the peeling Behr even worse. Help……….
Ben B
Lee K
Lee K
12 years ago
I have a cedar deck surrounded by trees that gets beaten by elements: sun, wind, snow, rain, falling leaves and heavey tree dirt. When my deck is cleaned and stained, it looks great for 1 month, and then it looks like we hadn't taken care of our deck in years. Is there a recommendation of correct product(s) that would handle the beating of the heavy elements and continue to look fresh.
Lee K
Lee K
12 years ago
It is truly just nature, a few thunderstorms, leaves, and dirt are flying. The deck will look great if it is wet, and then when it dries it just looks dirty again
Charlie C
Charlie C
12 years ago
So happy I found this site. It is fantastic. I have a Cedar Deck in CT, it gets direct sun. I recently stripped with power washer and sanded with a belt sander. I was going to stain next. I like to look of the decking when it is wet. Would like to achieve that. What stain and next steps (if any) do you recommend?
Brian
Brian
12 years ago
Hello
I have a redwood deck in san francisco area about 20 yrs old that I have been staining with Olympic Max (acrylic) every two years. The last time it seemed very watery like so I'd like to switch to defy or twp. Which do u recommend ? And do I need to strip or just clean
Thank a lot
Brian
Robert
Robert
12 years ago
Hello, I have just built a brand new covered porch with a Douglas Fir floor and ceder steps. I live in Chicago IL and the porch faces east. I plan on letting the wood age for 4 months or so. What stain/sealer would you recommend please?
Julia
Julia
12 years ago
We live in NC and I would like to stain our screened in porch. It has never been treated and is in great condition, it is 13 years old. I know it needs some prep cleaning, or something. Would this product be good for it? It is about 12X12. I know it will need 2 coats, just from reading here. We are dunces about this but are good at following directions. How much stain? We live in the Raleigh area so I am sure we can find a place that sells this brand. Thanks for all the expert advice.
Mary
Mary
12 years ago
We live in the Upper Peninsula of Michigan and need to find a tough deck stain or treatment that can handle shoveling. Is there such a thing?
Jeff
Jeff
12 years ago
I know this site is mainly for decks, I am applying stain to T&G Cedar siding (Texas) I assume that all the test and reviews would apply to siding as well. I am nearly sure (from what I've read) that a waterproof penetrating oil is where I am leaning.
Is there something I am missing as far as your stain reviews for decks as opposed to siding applications?
steve
steve
12 years ago
we have a 20×30 white cedar deck which is 2 yr old, we treated it with Olympic (ppg) oil acryd stain (green can), not happy it has a lot of wear tracks. the deck buts to vynl siding and shrubs. what should I strip it with and what should I now put on it? I would like to use a cleaner and or a brightner to maintain it and not have blotches when I restain it every 2 yr with out having to strip it. we live in mpls and it has full sun any ideas of what to use and is available in mn. ?
12 years ago
Help! I live in the Chicagoland area and have a 450 Sq ft cedar deck with about 4-5 coats of Wolman semi transparent stain on the horizontal surfaces & 2-3 coats of the vertical spindals ect…the deck faces the south and we do get extreme weather in this area, it seems every year I have to recoat the horizonal and every 2 years vertical areas..
verticals are still in pretty good shape but with 2 dogs and the weather the horizontal area's will need to be sanded or striper due to (scratches) from dogs and people traffic… is there a product that I could use that would get me 2 or more years? this is a huge yearly hassle…. did notice most strippers won't work with the Wolman product…TWP & Defy aren't sold in our area, also on the market they are now selling the restore products like used in truck bedliners but have heard application is very difficult but is supposed to last 10 years???
advise please.
Diane
Diane
12 years ago
Reply to  Mike
Hopefully, you didn't use REST"ORE. My niece carefully preped, watched the video and applied Restore. It has only been a year and it is already cracking/peeling especially on the stairs.
Randy
Randy
12 years ago
I used One Time deck stain 2 years ago on my new 500sq foot cedar deck. Looks terrible…..I used the Honey color, what color would you recommend for a color match? Also, should I strip, brighten, then apply stain for the best results, or should I sand?
Cathy
Cathy
12 years ago
I had a deck build Sept 2012 with pressure treated pine. I need to stain it for the first time. What do you recommened?
hehe
hehe
12 years ago
Had a large deck constructed last year with treated pine lumber in North Carolina. The deck gets morning/early afternoon sun then shade. What would you suggest to treat this deck?
Paula
Paula
12 years ago
I live in Minneapolis and have a 600 ft deck, two years old, pressure treated pine, never stained. The deck gets some morning sun but mostly shaded under a maple tree (or covered with snow). I want a slightly darker color to offset the railings which will be solid stained white. I have pine chairs clear coat stained that I don't want to match the deck. The house is light grey with a dark red brick chiminy chase against the center of the deck. What brand and color of stain would you recommend? Thanks much!
Shane
Shane
12 years ago
I just bought a house in Ohio. The house has a large deck on the back of the house, that hash't been treated in a while. The wood has turned grey and has green spots in it from the trees. There doesn't seem to be any rotting. This is my first deck, what all do you suggest?
I've been told to power spray wash it, then seal it. Do you agree? What color will look the best on a deck that has already greyed?
Micah
Micah
12 years ago
Is there anywhere you know of where I can purchase TWP deck stain in Toronto, Ontario CANADA? Help!!!!
Jerry
Jerry
12 years ago
Reply to  Micah
I would consider going over a bridge. This VOC thing is over-kill. Out forests and even our breath has VOCs.
Lee Muth
Lee Muth
12 years ago
Have put in a new redwood deck around a swim spa in San Diego, any advice on "finish" for this? It's now "heart redwood" (grade A) but grade B (common being grade C). So many products and I'm not happy with any of the "common one" sold at Lowe's or Home Depot such as Sherwin Williams, Behr, Valspar, etc. THanks Lee
12 years ago
I have western red cedar adirondack chairs and small (beer) tables that I completely disassembled, stripped and sanded. Once I broke through the surface, I found the colors and grain of this cedar are stunning. The chairs will be stored indoors during winter, but out on our patio all summer. We live in upstate New York. What stain would you recommend for appearance and durability? I want something to accentuate and richen the red cedar colors and grain. And something that can be reapplied periodically without stripping all over again. I bought Flood CWF-UV locally, but now I am reading that's probably not the best. Now is the time to back out if I made the wrong choice. Thanks.
12 years ago
12 years ago
Great, thanks. One more question…would you recommend staining each board individually then assembling the chairs, or assemble the chairs then stain them complete?
12 years ago
Ok I have decided on TWP1515 as you suggested. One more question…would you recommend staining each board individually first then assemble the chairs, or assemble then stain complete? Thanks, Chris
Update…I disassembled, sanded each board and stained the chairs while reassembling to ensure complete coverage and avoiding fit issues from swelling during stain absorption. They were absolutely stunning for the first few weeks then they started to fade and dull, developed a few dark spots that cleaner/brightener wouldn't touch. I am now in the process of steel wooling the areas with spots and completely restaining all furniture after only about 5 months of summer patio exposure. Will second and subsequent coats over the years penetrate deeper and provide better protection? Or do just need to accept that the elements are relentless and keep restaining every year? Any other maintenance suggestions? Thanks.
Thanks for all the help. After I applied the first maintenance recoat, the furniture looks incredible and beads water better than an oil slick. I applied stain, let it sit overnight to absorb as much as possible then wiped off excess with clean cotton rag in the morning…and I mean all excess stain. I do not recommend applying stain to assembled furniture. It is impossible to get any excess stain out of the joints and the pooled stain hiding in the cracks will drool and cause dark spots or cake and peel if you don't immediate wipe it. If you need to stain assembled furniture, I recommend removing each board one by one and mop up excess stain with a rag, reassemble. This was extra motivation for me to upgrade to high quality exterior torx screws (way better than square drive). The project took longer than I wanted (and longer than wife expected), but the results were worth it. Night and day difference from the crap film forming fence stain that they came with originally. Now we have nine pieces of beautiful Western Red Cedar furniture on our patio that along with Travis Industries Tempest gas torches (Really Cool) make our yard look like a resort. Can't be happier!
Alan
Alan
12 years ago
I live in Omaha, NE and built a 325 SF cedar deck in September, so it's had 7 months to weather with most of that being over the winter months. Do you feel I've given it enough time to fully weather and am ok to apply a product like TWP 100? Also, I really liked the look of the deck on rainy days when the new cedar was wet, is that going to be a similar finish to the TWP 101 Cedartone? Thanks for the help.
Tim
Tim
12 years ago
That's pretty much what I thought. I may wait a year and let the new section darken up a bit and then try to get them to match.
Tim
Tim
12 years ago
I have a 12 X 40 deck with half old and half new treated pine in NC. The older half is about 3 years old and the new section is just under a year. Neither have any stain or sealer. The older section is grey while the new section is still yellow pine. I am going to start with cleaning the old section (still researching the best product for that) and will then plan to use TWP 100 (PECAN) to stain the entire deck. My concern is how are these 2 sides going to match in color? Anyone have any comments or suggestions?
Larry
Larry
12 years ago
My deck is 12 years old. I removed all the floor boards and railing. I planed all the wood with a portable planer. The deck looks new again and I want to keep it that way. I want a clear/neutral oil based waterproof treatment. Any thoughts?
Larry
Larry
12 years ago
Okay. Since the wood is dry and planed to a new surface, will it take the stain better than new wood? Is there a stain that will re-moisten the wood cells?
Dick
Dick
12 years ago
How would I do the two coats on my deck, if I do the whole deck with one coat and then want to apply second coat? Or do I just do several boards, then second coat them and move on to next few boards? Is coverage based on just a single coat or on the premise that you would do two coats. I have a 12' by 12' deck—would I plan to buy just for the 144 sq. ft. or would I need enough for 288 sq. ft.? (plus rails etc.)
Brian
Brian
12 years ago
Would this be a safe product to apply to a child's redwood swing set? As an alternative, Anderson Clark?
Ron
Ron
12 years ago
What would you recommend for a bamboo fence? It is new and natural color. I was told by one company to use TWP 300. How is it different from the TWP 100? Is it a good choice for retaining the natural appearance? Can it be applied to the new bamboo? I want to put a finish on before I install it. Is it a better choice than a marine varnish or urethane?
Guest
Guest
12 years ago
Reply to  Ron
Hi Ron, I installed bamboo fence and used TWP 300 and it is amazing! It is actually more like a varnish which really makes the bamboo look great. I am in N.Central Ohio and it has held up very well. I used 315 light cedar.
Rich
Rich
12 years ago
Is TWP 100 redwood stain a semitransparent?
emile vitella
emile vitella
12 years ago
TWP 100 is not compliant in Delaware, would TWP1500 be the next best product to use or is there a better choice for a new deck.
alex beard
alex beard
12 years ago
I have a large Mahogany wood deck that is 13 years old. I bought the house four years ago. The deck appeared to have had no treatment since installation 9 years prior. I had it sanded and applied Sikkens to it but was dissappointed with the results. The deck has significant exposure to direct (and strong) Colorado sun. I am trying to decide what best to do now. I am leaning toward using a wood cleaner and then Cabots Australian Timber Oil ATO series 19400 in Mahogany Flame.
Would you recommend this or some other alternative? Thanks for any help you can provide.
Wayne Kivi
Wayne Kivi
12 years ago
I put on a new mahagony deck that was pretreated with Cabots ATO. I live on Cape Cod and the deck is south facing and gets additional sun with reflection off my bleached cedar shingles. I see that my deck has faded quite a bit and that the finish seems to have disappeared leaving almost bare wood in many areas. I've also discovered that Cabots ATO is now water based, My question is can I use TWP stains over what is left of the ATO or do I need to strip off whats left. The deck is two level and is 425 sq ft. Thanks for any help that you can offer.
wpkivi
wpkivi
12 years ago
I'm not sure about the best way to remove the Cabots ATO. Do I use a stripper, which one, or rent a sander and do it the old fashion way?
Donald Blount
Donald Blount
what stain would you recommend for Atlanta ga 15 year old treated pine deck?
Jeff
Jeff
12 years ago
Reply to  Wayne Kivi
Given that it is Cabots you are removing, I would recommend using the Cabots Cleaner. I have used it and when applied and scrubbed with a good deal of pressure and with a very stiff brush, it will strip the wood… I haven't used "brighteners" yet and probably won't, so I don't know if you would want to followup with one… Lastly, to get best penetration and a uniform look, you should definitely clean off the old Cabots before applying anything else… Last note, stay away from pressure washing… For my Ipe deck, I am considering using either Armstrong Clark Stain or possibly TWP based on some reviews I have read, but still find that the Cabots ATO gave me the results I expected… I think if you got lucky and picked one of the top 3 products for your wood type, the best you can expect is to have to re-apply it after 2 years at the outside…just the way it is with oils… hope this helps someone…
Joe Palmer
Joe Palmer
12 years ago
My fence is about 5 years old. It needs to be cleaned and stained. What products would you recommend for this process
TomnFl
TomnFl
12 years ago
Hello I only applied one coat about 3 weeks ago and my question is can I apply a second coat now? Thank you
aloha
aloha
12 years ago
By the way, I meant Cabot Australian Timber Oil, not the Woodrich product. Same answer? Thanks for this excellent website!
aloha
aloha
12 years ago
You say that you can put TWP over Timber Oil. How about the other way around? Can you put timber oil over an oil based stain?
trackback
[…] Important Note:  This is Our 1st Review of TWP 100 Series Stain. Our second review was completed in 2012. Please see here: TWP 100 Stain Review 2013 […]
Travis L
Travis L
12 years ago
Great, thanks! I used "Brown Sugar". The color is beautiful on pine, it is just the right amount of color, and looks very natural. It goes on looking quite orange, but then dulls down after a couple days. Any idea what color would be similar to this in TWP-100?
Travis L
Travis L
12 years ago
Great review, thanks for the info! Very helpful as always. I took your advice last year and applied Woodrich timber oil to my new treated pine deck, (in NC – partial shade/sun) for the penetrating qualities for new wood, and have been pleased! I want to make sure the next stain application protects more from UV graying. You've always had great things to say about this product so I'd like to apply this product next. What will I need to do to prep before applying TWP 100 knowing that timber oil was previously applied? Thanks!!
1 2 3 6
684
