TWP 100 Wood Stain Review 4.7/5 (12)
TWP 100 Pro Series Stain Review
TWP Stain Reviews
TWP Stain Reviews
This is Our 1st Review of TWP 100 Series Stain. Our second review was completed in 2018. Please see here: TWP 100 Stain Review
TWP 100 Deck Stain RatingImportant Note for TWP 100 Series: There has been a label change for the TWP 100 Series. New labels now say TWP 100 Pro Series. Same product, performance, and colors.
TWP 100 Series Wood and Deck Preservatives have been manufactured for over 25 years while proving to be one of the best products on the market.  TWP 100 Series is a 550 VOC compliant wood stain that is available currently in 36 states. Composed of natural and synthetic oils, TWP 100 Series will provide ample protection from snow, rain, and UV radiation.
TWP 100 Series has been rated #1 by Consumer magazine.
TWP Stain – 100 Series Rating
– We tested the 101 Cedartone color for the pool deck. The semi-transparent color was a traditional cedar color, slightly orange/yellow. The stain had no issues penetrating into the wood completely and did not mask the wood grain.
– The TWP 100 Stain retained 80% of the original color after 2 years of weathering.
Wear/Tear and Peeling: 8.5
– TWP 100 exhibited zero peeling of the stain after 2 years. Slight wearing around the stairs where the wood butted up to the pool. This area was slightly more faded as well. Possibly from the chlorine in the pool.
TWP 100 Series
TWP 100 Series
Cost Per Square Foot: 9
– We paid $139.99 for the 5-gallon pail of TWP 101 Stain. We used all 5 gallons for the 800-foot pool deck. We applied two coats to the wood. The cost to stain with TWP 100 Series was $.18 per foot for 2 coats of stain.
– TWP offers the best resistance to mold and mildew for an oil-based wood preservative. No mold, mildew or algae spores were present on the wood decking.
Ease of Application: 9.5
– TWP is easily applied. We applied two coats to the flooring using an 18″ wide stain applicator. The first coat took us about 30 minutes to cover 800 feet. The second coat took only 20 minutes as the TWP 100 applied at a better spread rate. Overall the 800 square feet were covered in under an hour and applied evenly with no puddling.
– TWP 100 lightens in color after 2 years. No darkening from UV or mold.
The Difficulty of Reapplication: 9
– TWP 100 Pro Series offers deep penetration with no darkening of the stain. Reapplication will be easy without the need for stripping off the two-year-old stain. Cleaning to remove some dirt and grime would be enough to prep for another coat.
Overall Score TWP 100 Series at 2 Year Period: 8.81
– TWP for good reason gets one of our top overall scores. It is too bad that this product is not available in all 50 states but the TWP 1500 Series performed nearly the same in our test results and can be obtained in all states. If you are looking for a great stain that is economical as well, then the TWP 100 Series should be considered.
Price range: $58.99 through $68.99
Price range: $219.95 through $245.95
Price range: $270.00 through $296.00
5.00out of 5
Price range: $285.00 through $311.00
5.00out of 5
More Info: TWP 100 Stain
TWP Stain Facebook Page: TWP Deck and Wood Stains
Cost: $41.99 per Gallon, $209.99 per 5 Gallon Pail
Stain Type: Semi-Transparent – Oil-Based Wood preservative
Available Colors: 100 Clear, 101 Cedartone, 102 Redwood, 115 Honeytone, 116 Rustic, 120 Pecan, 105 Cape Cod Gray, 106 Prarie Gray
Dry Time: 2-8 Hours
Deck Wood Type: Pine
Deck Square Footage: 800
UV Exposure: Full Sun Pool Deck
101 Cedartone
TWP 100 Series Stain Photos
TWP 100 Pro-Series Review Video
347 Comments
mike Natoli
mike Natoli
Hi there. A few questions… I had my new deck and screen screen porch stained 2 weeks ago with TWP series 100 cedartone. The new wood was left to dry about 8 months prior to staining.
  1. It rained about 9/10 hours after application (not forecasted). Applied in 60ish degree weather. Color still looks ok, i don’t see spots or streaks and the water was beading/puddling on the exposed deck when i woke (I swept the standing water off as soon as I could). Color may be a bit lighter than in the screened porch but may just be lighting. Question is, did this light rain overnight impact the integrity of the product on the exposed porch and if so what should I do?
  2. The cedar tone application on the new wood is a bit more yellow/orange then I anticipated. More so several weeks after application. Can I apply Pecan color over this to tone down the yellow/orange? If so how and when?
  3. My painter only applied one heavy coat of stain. IS that ok?
Susan Long
Susan Long
Which is better for a brand new pool deck? The TWP pro series 1500 or 100 series?
Chuck Magaha
Chuck Magaha
Live in Kansas, Just did a re-work of my deck using treated pine how long should I wait before I apply the stain.
Richard Baker
Richard Baker
I did a reapply of twp on cedar siding exposed to severe weather conditions in Florida after the cleaning process 2 coats on problem areas and one coat on less exposed areas it has some shinny spot where it didn’t penetrate the wood as much wouldn’t it be better to leave those areas instead of wiping it of with the mineral spirits to keep the product on to protect the wood better in this environment?
Roper
Roper
I’m in the process of having a Patio cover and pool cabana built. The post for the cover and outside of the cabana will be rough cedar. Is the TWP 100 stain a good option for this aplication or should I look into something else?
KAREN DARRIN
KAREN DARRIN
Can wpt stain be applied to epay wood decking as a post 10 years application in Seattle wa. I used twp 101 for the the original application and will use the same. What preparation do i need to do before i apply the next application?
prem
prem
I stained my deck with TWP 100 last fall and now i kind of feel its not as vibrant as it was during last fall.. is that expected? and also i missed to sand before the stain and now every time i run my hand over the deck top i get a splinter or two in to my hand.. can any thing be done without having to restain?
Prem
Prem
THANKS. What about the splinters.. is ther any way to fix wothout restaining them
Lisa
Lisa
Hi. We live in Georgia and trying to decide what to do about a new porch which faces South with a lot of sun (picture included).
We originally thought we would paint railings white and stain the cedar ceiling, corbels and gable. Now that we see the cedar railing, I think I’ve changed my mind as the wood itself is beautiful.
TWP 200 has been recommended by the contractor; however, he did not mention that the wood might need to age. Some of the wood seems rough and some smooth.
Couple of questions:
Would you recommend TWP 200 Butternut (as the door is stained a dark walnut) or prefer a TWP 100 or even an Armstrong product?
Would you still recommend to allow it all to age 4 – 12 months before staining?
Is there anything else I might be missing while considering staining everything as it pertains to direct sunlight?
Thank you in advance!
Brian
Brian
I want to slightly lighten the two 100 dark oak. Can I add clear and mix the two to achieved a lighter stain without adding any concern?
JIm Mueller
JIm Mueller
Is there any advantage in using 1500 TWP over 100 series for new Cedar Fence 6 mos. old?
Ray
Ray
Any thoughts on how twp 100 or 1500 will work on redwood? Testing was performed on pine.
john
john
I just re-coated after 3 years in MN using TWP100; almost 2000 ft2 of redwood decking. I used Wolman Deck & Fence Brightener Wood Cleaner and Coating Prep and power washed off before the re-coat (3 days drying) using a 40 degree nozzle (white). The reason using the Wolman product was to deeply clean/brighten the areas under roof cover, which were in great shape and I wanted the whole deck surface consistent in stain appearance. I just needed to clean some areas with mineral spirits after staining to remove the shinning stain where it didn’t soak in under the areas of roof cover where the original coat was still good.
The decking looks like the original coat after the re-coat. I love TWP100 and the Wolman (no sodium hypochlorite) made the cleaned decking look new. 2022 will be my next re-coat.
My re-coat was one applied coat using a deck staining pad and long pole to back brush where the stain wouldn’t completely soak in.
Jeff
Jeff
Hi, I have a ~12 year old 600 sq ft Mahogany deck. It has probably had 5~7 coats of Sikkens deck stain on it over the years. The last coat is now peeling off at a rapid rate and I am about to have it sanded. I am thinking about using the TWP 100 (redwood) stain. Is there any additional prep work I need to do besides the sanding?
Also, there is a large built in bench around 2 sides of the deck. Stripping the vertical pieces will be tricky. Do they need to be completely stripped down to the bare wood for the TWP to stick and look reasonably similar to what is there?
How to I figure out if I will need one or two coats?
Thanks, Jeff
Jeff
Jeff
Hi, what do you mean “wet on wet”?
Lee
Lee
I purchased TWP 1500 oil stain based on your ratings and recommendations for removal of prior transparent stain, (Behr), which peeled in many areas after 1 year. I used Restore A Deck cleaner and brighter. Our 600 sq.ft cedar deck was 20 years old and some boards needed replacement. Since new wood doesn’t absorb stain the same as the older wood. and review of many of others with similar experience in your Q&A area, I applied only one coat, not wanting to over apply the oil on adjacent new and old cedar wood. Based in TWP recommendations and the TWP calculator, I purchased 6 gallons of the TWP 1500., but used only 3 gallons since I did not apply the second coat. The deck came out beautifully. It looks great but now I have an excess of stain .I am very pleased with the results and would recommend TWP 1500 oil to anyone.
Can the excess TWP 1500 be used for my next treatment, probably in two years ? If so,, should I store it in the original 5 gallon shipping container ( with 2 gallons remaining) or should I transfer it to smaller gallon metal or plastic containers? I have 1 gallon remaining in the TWP original container.
Thank you for your helpful recommendations on preparation and stain. I look forward to your response.
Lee
Lee
Thank for the information regarding shelf life and storage. Can either plastic or metal cans be used for storage?
Since my 600sf cedar deck had a mix of 20 year old and about 10 % new boards I applied one coat of TWP1500, since the mix of cedar boards would absorb stain at different rates.
Should I apply a second coat after 1 year ( after cleaning )
Is brightner also required ?
Is it preferable to wait to until the first coat begins to wear or fade before cleaning and reapplying TWP 1500 with the recommended wet on wet 2 coat process?
Big Ben
Big Ben
I have an 11 month old cedar deck. Our house is set in the woods and surrounded by 40′ + trees. We get no direct sun in the morning, but a fair amount of afternoon sun. All of the railing you see is replaned western redwood(?) from the original deck which was built in 1970.
Our contractor hand sealed all of our decking and railing with Olympic clear 3 year. As you can see it is coming off quickly.
Note: The single board that is darker I brush coated with Olympic 6 year semi transparent in the redwood tone. I am liking the darker look and think it matches better with the railing.
Any suggestion on a redwood tone stain that I can put on the decking that will compliment the railing?
Thanks for your help,
Ben
Frank Simpson
Frank Simpson
Hi, I am building western red cedar outdoor furniture. What steps and products should I use?
Gina Steis
Gina Steis
Does anyone know if tint can be added to the series 100 clear? I would like to have cedartone.
Jessie Goldsmith
Jessie Goldsmith
Hi, I am a new customer. Have a deck that was stain with a oil base stain. Want to try your product, how to I prep before I apply your product. This also has been added to so I understand the color will be darker, looking at going with a dark oak stain. Currently a dark brown on the old part. Next what is the difference between the 100 and 1500 series. Also, I have a 200 ft fence installed last fall and want to apply a natural clear coat, want to leave the greyish look, do I have to prep it before spray the fence. and how much would I need to order for 200 feet on the outside 6 foot high. I would need to double the stain to do both inside and out?
Craig Wilson
Craig Wilson
Please get back too me. Because sikkins.faded way to fast
Andre
Andre
3 year old deck is ready for a new coat of stain. Should I use the same brand, or would it be ok to use the TWP brand?? If so, what kind of prep work should I do??
new yellow cedar decking…how long should it sit before cleaning & staining with TWP 100 ?
If I have vapor barrier-on ground and decking is 16" above, is it necessary to stain underneath board? (2X6" decking.)
Where can I get twp 100 stain in Tacoma/ Seattle area, western Washington.?
Where can I get twp stain in Seattle/ Tacoma area, western Washington.?
Michael Bridges
Michael Bridges
Reply to  Mike
ACE hardware can order it for you. I have used the TWP116 with great results. It is special ordered and comes 4 gallons to a box.
GMT
GMT
I am installing a new cedar (kiln dried) pergola in Maryland. All rough cut boards. I want to prevent graying. In years to come, removal of stain from a 3 layer, 12 ft high 14×20 pergola will be very difficult (topmost layer is 2x4s on 10 inch centers). Is there a product I can apply with a sprayer after applying a cleaning product such that I don't have to go in and hand stain every board? I am not even sure it would be possible to do that.
Franco
Franco
Where can I buy TWP in. Houston, Texas?
Sharon
Sharon
Has any one had trouble with the T.W.P. treated deck being slippery when wet?
S G
S G
followed the directions to a "T" on a brand new C60 ft. Cedar deck. It did not make it thru the winter. The stain pealed off. My friend used it also and the same thing happened. Everywhere we walked the stain came off :'(
Greg
Greg
Greetings, I just re-stained my pine deck after stripping all the old finish off, treating with brightener etc. I read that I needed to be careful to not over apply the stain, so I ended up just doing one coat. I hit a few other places with a bit more, but as far as I can tell the color is good and I am happy with the outcome. It did not look like it needed more. However, since I did not do a second coat, did I under apply the stain? I used a bit over 3 gallons on a mainly horizontal ground deck (not elevated) that had two sections, 15×23 and 16×22 respectively. I bought 8 gallons thinking I would need that much plus some for maintenance. I applied with the small 6" pad you sell. If I did under apply, is it too late to do a second coat (it has been 3 days, and it would not been done until at least 2 more, and there has been some very light drizzle one morning), or should I just wait to see how it is next summer? Thanks!
Monique
Monique
I'm a single mom in the Dallas-Ft. Worth area so my apologies in advance for the many questions. I bought a new home about 10 months ago in a new subdivision so am dealing with new construction/healthy wood. I'm considering staining my side of the yard wood fence since I believe the wood is now “old enough” but am unsure as to the benefit since the subdivision lots are small and I share the fence with a neighbor on the east side and a different neighbor on the west side….and these neighbors probably won't stain their sides of the fence.
Question 1) Is there a benefit to me years later in terms of seeing a beautiful fence on my side should I choose to stain the yard fence visible on my property while my neighbor(s) neglect staining their sides?
Question 2) My fence looks great now but I'm honestly unsure as to what if anything the builder has already treated the wood with. Assuming I do treat the fence on my side, should I just clean the wood first and then stain because my gut leads me to believe the builder hasn’t treated the wood?
Question 3) I'm uncertain as to what to clean my fence with before beginning this project. Any suggestions?
Questions 4) Its seems that TWP 100 is an option for purchase today in TX but I'm confused as to if I should go with TWP 100 (seems to be better per the discussion/reviews below so I'm leaning on going this route) or TWP 1500 and what later challenges I'll have wrt future staining assuming TX later outlaws the sale of TWP 100… Would I be able to stain my fence in the future with any retail brand oil-based stain or would TWP 1500 be an option if my initial stain today is TWP 100?
Questions 5) Would stripping be later required to go from TWP 100 in 2015 to TWP 1500 or to a retail oil-based brand 3 or 4 years later?
Questions 6) Am I correct to assume a 2-coat stain with TWP 100 will last 3 or 4 years on average in the state of TX considering our hot summers?
Questions 7) What recommendations do you have to protect home siding paint?
Thank you in advance for your assistance!
Simon
Simon
Reply to  Monique
No, it (the color) will not last more than a year when exposed to rain and sun! I have used 1500 series to stain a new, 1 year aged (without stain), pressure treated wood, prewashed, let dry, applied 2 coats within 30 min, the color all faded next summer. You have been warned! Not worth the extra cost. Many reviews are bogus or not from folks whom have had actually experience longer than after applying. I bought and used TWP based on reviews, the actually product is anything but like the reviews. Use at your own risk if price and labor is of no concern. You'd have to re-stain yearly, major PITA!
Steven O
Steven O
The key for best results is proper prep-work. When we purchased our home it came with a beautiful yard but the 400 ft (2400 sq ft) of cedar fence was dark grey almost black that looked very bad in such a beautiful yard. I had never power washed wood before and as recommended I power washed w/3200 psi 25 deg tip and the results looked like new when completed. I did not feel the need to strip or brighten. Used pump sprayer & 15 gal of twp 101 and the appearance is better then new and is just as beautiful as the yard landscaping. What a huge difference. Always being asked what I used to achieve such great results. Looks very close to day of staining after 2 yrs. highly recommend TWP 100, by far the most bang for your buck.
Dknight
Dknight
I am sanding some tongue and groove clear western red cedar that we installed a couple years ago under a porch. As this is the ceiling, it is not exposed to the sun or water. I had to sand it to get some old CWF clear searler off after a major leak. I live in the Texas hill country west of Austin. I used to use CWF over the years but it doesn't seem to be the same product.
I thought about putting a marine polyurethane on the cedar but I like the more natural look of a clear sealer. The wood is multi-tone so I don't want a stain. What would you recommend?
C.Mckinney
C.Mckinney
Just finished sanding a solid color stain off a 2 yr. old salt treated deck in full sun, in East TN. Do I still need to use RAD cleaner/brightener? As well, I have narrowed my next stain down to the TWP 100 or Armstrong Semi-trans Grey. Which will do the best job protecting against UV degradation and preserving the wood which is already cracked severely.
Calvin Crump
Calvin Crump
Stain three different colors. Bought five gallons of rustic TWP 100. Didn't even cover with one coat my 375 sq ft deck. Applied with a 3 inch brush. Three different colors even after following all instructions. The restore cleaner and brightener worked great but the rustic TWP 100 gave dark brown, reddish, and fire engine red in color. Looks horrible. Called customer service and the representative said "what's my question and do I want to order more to finish?" I said what about the three different colors? He responded with "that is irrelevant and would you like to place a order or not?"
Scott Retterbush
Scott Retterbush
I have a nine month old pressure treated pine deck that has never been painted, stained, etc…. What do I need to do to prep it or can I just stained. It has greyed only slightly.
Allan
Allan
Does TWP 100 come in a Gray color and is there a retail outlet in the Niagara NY area?
KEVIN
KEVIN
WHO SELLS THIS PRODUCT IN COLORADO. THANKS
CAROL BARSIN
CAROL BARSIN
Is TWP 100 series available in Charlotte, NC. If so, where?
Also, how does a water -based stain/sealant compare to oil for a new pine treated-wood deck?
Carol
Carol
Where can I get twp stain in Seattle area, western Washington.?
EYG
EYG
If I were to refinish a deck in Texas with TWP 100, would I be able to restain with TWP 1000 (or something else) in future years without stripping it in the event Texas decides to outlaw TWP 100?
karensueof82
karensueof82
We had peeling, mildewy solid color stain on our 5 year old deck so we have sanded the entire deck and are planning to restain with TWP 100 Cedartone. Do I need to wait any time to apply the stain or can I proceed when we get a few dry days?
Brooke
Brooke
I've purchased and assembled a Western Red Cedar Adirondack Chair set from Tofino Cedar Furniture Co. in Canada. They recommend [for people wishing to treat ("unnecessary")] a Sikkens product not available in California. When searching on line I found the TWP-1500 was very highly rated and the TWP-100 even higher. My questions are 1) Is it necessary to "age" the product 1st? (According to Tofino web-site they "only use Wood from naturally fallen trees (storms) and branches and logs left and recovered from others Lumber operations….." does this count as aged? 2) Which TWP product 1500 or 100 is best suited to the intense UV environment of Southern California?
Kris
Kris
New Georgia deck. Cedar and cypress. Applied TWP 100 Pecan to both after they aged about three weeks. Looks great on the cedar, not so good on the cypress. The builders rushed me because they wanted it stained before the screens are installed. I wish I could lighten the cypress… Is there an easy way to do this? More impotently, I'm afraid that they messed up my ceiling (which has sky lights) – I asked for clear TWP, but they applied Cabot 1400 clear instead. Please tell me that I can apply TWP cedertone or honey over the Cabot clear?? They just applied it and now I realize that it will probably turn gray within the year. What should I do?
Kris
Kris
Thank you for the quick reply. Very much appreciated. The pecan color has evened out nicely so all that's left to do now is the floor, which is pine. We're waiting until Spring, when the temperatures are warmer but I wanted to know if you can apply TWP 1500 or 200 over an older coat of TWP 100-series without stripping first? If not, can you apply TWP 100 over an older coat of TWP 100 without a problem? Thank you again!
Kris
Kris
Thanks – last question.. Which type of deck cleaner would you recommend in this scenario?
JIm Turner
JIm Turner
Located in Georgia
Brand new refurbished deck (less than 2 weeks old)
Boards are Cypress, hand rails are Cedar
Should I let the wood cure before staining, if so how long? Getting conflicting advice from contractors.
What stain do you recommend for Cypress?
What is the difference between TWP 100 & 200?
Ron San
Ron San
Hello:
I have a small 8 by 10 deck here in NJ which is about 14 years old, stained by acrylic bm yellow about 11 year ago and since then it was stained with a clear Thompson sealer twice which covered only the areas where acrylic gave in…
Overall it looked pathetic…and needed much help ground up.
I used wolman stripper for acrylic and stripped the deck down 90% prior to that washed it with a oxyclean n bleach mixture lastly power washed it using turbo nozzle. I finally sanded it down so that 99.5% of the acrylic is removed.
I have not used a brighter – deck has not seen rain in 4 days and is ready be stained..for which I need advice, I am confused between defy, twp and Armstrong clark…
It southeast facing and gets lots of sun..is also exposed to snow during dec thru march
Please advice what will serve my needs best.
Thx in advance for your time and reply…sincerely Ron
Alan
Alan
Hello, first of all, this is a great site!
I live in Toronto, Canada where they have also applied the low VOC law. I have a 5 year old cedar deck. I did not seal it right away after construction (big mistake). It greyed and got dirty over a period of 3-4 years. Last year, I tried to sand all of the fibers that have built up over the years. I then used a deck cleaner/brightener. Following that, I used the Benjamin Moore Arborcoat waterborne translucent deck stain. After the winter, I found that 2/3 of my deck has peeled off. What a massive waste of time and money. I was extremely disappointed and frustrated.
I need some help from the experts! What should I do? I want something that will last and that I can trust.
Question 1: From your past experience with other Canadians, do you know any products available in Canada that are good?
Question 2: If answer is No to question 1, then I'll need to order a product in the U.S and ship it to buffalo for pickup. What do you recommend that I do to strip, clean and re-stain? Any help and advice is greatly appreciated!
Question 3: Sanding was a huge job, can I avoid sanding?
Alan
Alan
Alan
Thank you for your reply! Much appreciated. Here are a few follow up questions if you don't mind 🙂
1. Can I get away with a Canadian sold product for the cleaner and brightener? or does this play a very big factor into the staining process as well?
2. I used a hand sander last time and it took a very long time. Do you recommend renting a bigger unit from a big box store (if that exists) and what coarseness do you recommend for a cedar deck?
3. Why do you recommend Armstrong Clark over TWP? Just to confirm, I am looking at a non low VOC product, if I'm able to get it shipped and pick it up
4. Can you explain why you would recommend a semi solid color? I've used translucent on the railings and I love how it brings out and enhances the natural color of the cedar.
Amelie
Amelie
I have a 20 year old mahogany deck that we have sanded clean and beautiful. I want to apply a clear sealer that will haelp to maintain the natural color of the wood and can be reapplied WITHOUT stripping. What would you recommend?
Dean
Dean
We live in Lawton, OK, temperatures can get extreme here but we applied TWP 100 Cedartone to our 20×20 deck in the middle of April. temperatures from then until July have been well below normal. The deck was 18 months old at the time and was pressure treated, according manufactures specs this was a seasoned deck, nonetheless we sanded the entire surface, was smooth and clean before application of two "wet" coats. drying time was very fast, next day patio was ready for furniture. It came out beautiful, very nice shine to it, deep color, absolutely outstanding. for about 3 weeks.After that the shine is complete gone, very dull looking. We are extremely disappointed with this product, after looking online there is no warranty associated with the stain. In my opinion this stain is a complete failure, to have less than a month of newness is ridiculous, would NOT recommend using this stain at all.
Jennifer B.
Jennifer B.
Hi!
I purchased a 12 year old home 4 years ago (western NC) with a 2nd story back covered deck (8X40). This year, the center part of the deck still looked nice but the parts which received the most sun had very little color and the water didn't bead up. I used SW Deckscape stripper & revive products then a final power washing because I wasn't sure what was previously used on the deck (wood grain showing but a 'honey' color – the wood is probably pressure treated pine from Lowes). I am a DIY newbe. There are places where the wood looks 'furry' – maybe too much pressure washing / scrubbing with the nylon brush? I noticed you don't recommend sanding but should I sand under these circumstances? If I do have to sand, would it be enough to use a leaf blower to remove dust?
I am 60 so In the future I would like to complete regular maintenance that would let me treat one half of the deck and then the other half of the deck so I wouldn't have to move everything into the yard for a week or more and I wouldn't have to cover everything below deck and in the yard because of harsh chemicals. Can you recommend a semi-transparent stain and a proper maintenance schedule?
Thank you for your help!
Jennifer B.
Jennifer B.
Thank you for the response!
Since coatings on my deck deteriorate at different rates, will it be a problem to re-coat areas that are still beading up? I don't mind washing and re-coating, it is just having to clean/wash/brighten/wash/dry/re-coat that seems overwhelming.
Jennifer B.
Jennifer B.
Can I wipe up product that doesn't soak in? possibly with a cloth soaked in turpentine?
Jennifer B.
Jennifer B.
Thank you so much for the help!
Kyle
Kyle
Hi there,
We just installed a new Western Cedar deck and were wondering what prep. is required prior to staining and what type of stain you could recommend out of the ones we have available here in Edmonton, Alberta (Canada). We get cold winters with lots of snow and warm summers with low humidity. The deck is east facing so it gets a lot of sun during the day but is in full shade in the evenings.
I hear TWP and Armstrong are really good brands for deck stains, unfortunately neither is available here. I have seen the following sold here: Wood Pride by Dulux, Behr, Sikkens, Cabot, Benajmin Moore, C-I-L, and Olympic.
We would prefer a stain that allows more of the wood grain to show through to one that also doesn't require too much maintenance (if possible).
Thanks for any help you can give us.
Jetta
Jetta
We live in Illinois and have a cedar deck that is about 12 years old. We previously used Sikkens on it and have never been happy with how it holds up (peeling & fading) causing us to have to redo every few years. My husband used a cleaner on it and pressure washed but there are some areas on floor where Sikkens did not come off and the railings still have Sikkens on them. What would we have to do to remove the rest of the Sikkens from the floor and railings before applying the TWP product? Thanks for your help!
Clyde
Clyde
Very little solid stain remains hopefully will remove residue with cleaner/brightner application and pressure wash. Any thoughts? Also why TWP 100 over TWP 1500 product?
Clyde
Clyde
OKC area 1200 sqft deck of which 900 is new smooth pt pine & remaining 300 is 15 yr old previously solid stain pt pine.
Allowing new decking to weather possibly until spring and will clean/brighten all areas prior to stain application.
Wanting to use TWP stain products which is based on all available product reviews. Which TWP product will best suit my situation?
X
347
