How to Apply Deck Stain to Damp Wood
We appreciate your input here at Deckstainhelp.com as we continue to be your go-to source for the latest in deck restoration news and trending topics through 2026. See below for an article about Applying a Deck Stain to Damp Wood.
- Properly prep your wood surface first. Prepping is always the key to the stain's longevity and long-term performance.
- Wait 2 to 4 hours after prep before applying stain. Wood should be damp, not visibly soaking wet.
- Currently, Restore-A-Deck Wood Stain is the only tested stain confirmed to work on damp wood surfaces.
- Start with vertical surfaces like railings first, applying a light second coat within 20 minutes to 2 hours.
- Apply one coat only to new decks less than a year old when staining horizontal or flooring surfaces.
Applying a Deck Stain to Damp Wood on the same day as prep? We here at deckstainhelp.com have been receiving inquiries asking how best to apply a deck stain to damp wood. This is a newer concept, as before, stains could only be applied to dry wood that has been prepped with a waiting period of 2-3 days after prep. So far, the only stain that we have tested that can be applied to damp wood is Restore-A-Deck Wood Stain.
Tips for applying stain to damp wood
- Properly prep your wood surface with correct prep products. Prepping is always the key to the stain’s longevity. Any questions on how to prep, please see our extensive articles in the main menu.
- Wait 2-4 hours after the prep to let the wood dry somewhat. The RAD stain can be applied to damp wood but not to visibly soaking wet wood.
- Start with vertical surfaces first, such as railings. Make sure horizontal and other surfaces are
protected from excess paint. After the first coat is complete, apply a light second coat to the top
of the railing only between 20 minutes to 2 hours after the first coat has been applied. - Repeat this process for all benches or vertical structures.
- Once all vertical surfaces are stained, apply one coat of Restore-A-Deck wood stain to the flooring
and horizontal surfaces, ensuring the entire floor is covered. - Reapply a second light coat 20 minutes to an hour after the first coat has been applied. For new decks, less than a year old, only apply one coat of stain.
Deck after prep showing damp wood but not soaking wet.
Our deck immediately after damp wood application
Have you applied stain to damp wood? We want to hear your thoughts and suggestions. Leave us a
comment below.
We live in Hawaii (Big Island), so it rains just about every day. Our deck was primed (Kilns) and painted on top, but the underside was left bare. The paint peeled after a year, so we sanded and repainted. It is peeling again, and we are getting patches of rot too. I was told I need to seal the underside or it will keep peeling. What do you think, and what products should I use?
No, that’s incorrect. The coating is peeling because you are using the wrong products. You do not use primer on a deck and never use paint on a deck. You need a stain. To fix you will have sand it 100% off and then use a proper deck stain that is breathable.
I bought an older home with a wood deck that appears to have never been taken care of. The wood seems to be solid and I had it power washed and let it dry for several days. I coated it with 2 coats of Super Deck solid stain. Looked really good the first year, but now I think I am in real trouble. It started to peel this spring as the weather turned warm. I had a couple of contractors look at it and they said that it could be power washed strong enough to remove most of the stain that was coming off. Not so good results there at all. They tried to use a paint remover, that worked somewhat but left a lot of areas untouched. The latest thing was to sand it down, but that did not work out so good either as the stain kept clogging up the sandpaper. I noticed that the wood appeared dry where the stain had been removed, but when I peeled the stain from a different spot the wood was damp under the stain. The deck gets a southern exposure and is in direct sunlight most of the time. Not sure why the wood is damp under the stain, but I am thinking that is part of the problem. I do not want to be negative to the Super Deck, as a similar deck that has a UV canopy above it looks as good as the day I finished it 5 years ago. That area needs a little touch up but traffic being what it is a little touch up annually is normal. I do not think that Super Deck is the answer for problem area at all. Not so sure what to do there, it is a real mess now. My game plan is to scrape and sand it until all of the stain has been removed and we are back to the wood again. That will probably take me the better part of the summer, but then, what do I put on it? Thanks for any suggestions you might have to offer.
Get it all off then use a breathable penetrating stain like TWP or Armstrong Clark.
Hi
I’ve recent laid flooring using red cedar, what stain do you recommend to use to bring out the true colour?
Look at using the Armstrong Clark after the wait and prep.
One of my house’s decks has damp wood, and the stain is starting to leach. Thanks for suggesting that I should prep the wood surface with the right prep products to make sure that it adheres correctly. I think I’ll hire someone to restore the look of my deck as well so I can make sure that it’s going to be good.
RAD= Restore-A-Deck brand?
Sherwin Williams has a semi trans stain that states it can be applied to damp wood. Any experience with this product? I am fighting the weather, every day I think I am ready and it’s starts a rain again. I need to sand and stain soon.
Nope, but all their products for deck staining are not very good and have poor results and reviews from consumers: https://www.deckstainhelp.com/?s=sherwin+williams
Is Thompson and ready seal good staining brands?
Thompson is garbage and RS has major issues with drying and fading fast. You can find reviews on this site for both.
I built a farmhouse dining table. Made of Douglas Fir. The wood is damp not kiln dried. Can I stain and which is the best stain, oil base or water base
This is an inside or outdoor table?
It’s an inside table
Sorry, but we do not have any experience on what to use for an inside table. Our experience is strictly outdoors and you would not use an outside coating for an interior table.
Very strange….you would think that if it’s good for exterior it would be even better for interior since there is no UV or moisture. But thank you anyway.
Completely different coatings are used inside compared to outside.
For surfaces that food is in contact with, shouldn’t it be a food grade stain or oil?
No. A fully curing stain means it does not matter once it is cured. The stain will not leech out.
Materials contain chemicals for outdoor use that are not good to use indoors…I have read…
What stain is used in the above picture?
Restore a Deck Wood Stain in Light Walnut: https://www.deckstainhelp.com/restore-a-deck-wood-stain-review/
