Behr (Advanced) Deckover Review 2026 2.3/5 (683)
Behr Advanced Deckover Review
  2. Preventing UV Graying
  3. Peeling or Wearing
  4. Cost Per Square Foot
  5. Preventing Mold and Mildew
  7. Color Shifting
  8. Ease of Reapplication
3. Wear/Tear and Peeling: 4
4. Cost Per Square Foot: 1
6. Ease of Application: 2
Where To Buy: Home Depot
Cost: $45 per Gallon
Coats Required: 2 Coats.
Dry Time: 8-24 Hours
Cleanup: Water
Manufacturer: Behr
UV Exposure: Full sun
Behr DeckOver Video Review
5 47
4 60
3 140
2 160
1 276
5 163
4 155
3 131
2 93
1 141
5 85
4 77
3 94
2 122
1 305
5 38
4 14
3 35
2 46
1 550
5 123
4 101
3 109
2 93
1 257
5 111
4 66
3 83
2 89
1 334
822 Comments
Russ
Russ
Cathy
Cathy
Reply to  Cathy
Conestler Green
Conestler Green
Leslie E
Leslie E
Lisa Fryar
Lisa Fryar
Reply to  Leslie E
Mick
Mick
JOHN
JOHN
Reply to  Mick
Alice Jones
Alice Jones
Reply to  JOHN
JOHN
JOHN
Reply to  Alice Jones
Eric
Eric
Alice Jones
Alice Jones
Reply to  Eric
Brian
Brian
I used this product and it sucks. After 1 year it chipped and peeled… followed all directions to prep deck and apply product.. Now I have to strip all the product off and apply new stain. I would never refer this product to anyone who has a wood deck.
Sandra Higgins
Sandra Higgins
Reply to  Brian
Is there a product to strip the deck over. We have to do ours and one we are elderly, it’s costly and the time we have vested. I’m so disappointed 😞
carole cotton
carole cotton
why footprints???????????????? terrible with all behr deck paints help
Mike in NC
Mike in NC
Adding to the negative reviews of Behr Deck Over. I purchased this product a few years ago. I was convinced by the sales person that it would be good to use on older decks (ours was 15+ years old at the time). Looked pretty decent at first, but took less than a season for it to start peeling, even in low traffic areas. Re-applying does not help. At first I thought I had done something wrong when applying this product but sounds like this peeling is a pretty common problem. Wish I had seen these reviews before spending all that money on this inferior product.
Adriana Green
Adriana Green
Would expect some refund.
Adriana Green
Adriana Green
We had a professional apply Deck Over so it was done well per instructions. Although it looked great the next spring it came up in sheets. I was blowing it off to put down a rug and it just came off. We spent a lot of money on this because it was Behr and we only use Behr products. We are so very disappointed!!! Really should give a refund. It also molded on an area.
Summrbrz in Michigan
Two years ago, we replaced worn slats in our 15 year old, 115’ wood stockade fence.
We then painted the fence, front and back with Deckover. The fence still looks great!
Ricky Kendall
Ricky Kendall
Purchased 3 gallons in April but didn’t get around to painting until October. All 3 gallons hardened and were unusable. They should yell you to use immediately. Terrible waste of money.
This stuff is garbage..did it perfect to the instructions. It lasted not even two years and looks horrible. Most has peeled off. Never use this product.
Kathy
Kathy
Behr advanced deck over is the WORST paint I have ever used. It’s the consistency of concrete, it has sand in it, it’s flat and dull and the color shipped was not the color of the online swab. It was terrible to use, like trying to roll putty on a roller. It has bad reviews as well.
Melissa
Melissa
This stuff is horrible! I wish I read these reviews before using. It is extremely difficult to use. The product does not stick to the roller forcing you to kind of scoop it, then it is very difficult to spread the paint on the deck. We followed all directions to a T and 2 weeks in it is already peeling and there are a lot of scuff marks. Furthermore, it did not provide great coverage.
Heidi melone
Heidi melone
Dear DeckOver victims……I am one as well. Recently purchased our home which has 3 lovely decks which the previous owners painted with DeckOver. I must have 2000 square feet of deck to fix as it is now peeling up in sheets!! This products SUCKS!!!! We all know that or we wouldn’t be here. But that’s not the point of my post. I’m posting to tell you how I am removing it and hope it helps others.
Purchase a product called “Diamabrush”. There are great videos on YouTube of people using it. It fits onto an angle grinder and LITERALLY eats through the Deckover without hurting the wood. I am not being paid to say this. I spent 8 hours sanding one portion of my deck with a deck sander I rented and got nowhere. 10 minutes with the diamabrush and I cleared probably 30 square feet with no residual product left over. Pros: fast…..thorough…..won’t chop into wood like a sander does….gets the Deckover OFF!! Cons: a little dusty but you can attach it to a shop vac…..angle grinder gets a little hot so I had to take breaks to let it cool.
Really guys this method might be the saving grace when it comes to getting this horrible product off and I felt like I had to reach out and let other folks know about it. Oh also, I am not a deck pro or anything. I am a Nurse Anesthesiologist. Good luck and sorry you all are going through this.
Terry
Terry
Reply to  Heidi melone
Heidi, Thanks for the tip I’m going to give this method a try before just replacing all the boards.
David Matos
David Matos
Less than 3 years old.
Wood completely rotted under the DeckOver. foot went through my front porch steps (see the blue tape one. Sad thing, was it still looked good, just structurally it was destroyed underneath. Like lipstick on a pig.
The work that was done on this house’s decking was done by professionals, the wood was cleaned, dried (replaced if necessary) and the DeckOver produce was properly applied and allowed to dry. The nails and screws are all under a solid layer of DeckOver. There are areas of my front steps that looked completely solid, however the wood under it was completely rotted.
Behr has graciously offered to supply me with more DeckOver – warrantied for a whole year. I am currently tearing out my steps and replacing them with composite.
Tracey J Wilson
Tracey J Wilson
Reply to  David Matos
Really, their solution was to offer you more crappy product so you rot more boards???? What a joke, who in their right mind would use this stuff again??????
Carla Monnier
Carla Monnier
OK, let’s look at this realistically. If the product was applied to a deck that was beyond repair…or in need of great repair, no product will effectively replace the need for wood repair. If the deck has been managed adequately and is aging, in need of a cover then this product fairs well. Like all paint/stain jobs, ease of application and time involved depends on the brushes used and the experience of the painter. Just having finished a deck, the product covered as indicated for the first coating. I painted lattice and a full deck with one can. I am going to apply a second coat which will require another can to finish the job. My inexperience with the product made it difficult to predict coverage so I went in ‘trying’ it out. The coverage was also good for the wood condition on my deck. I wanted something that will last for awhile and having used other stains on decks, I suspect this will be fine for up to five years. If not replacing the deck is most likely the next step for this deck anyway. It is a 25 year old covered deck with little wear, no barbecuing, etc. so it has held up well for the age. I don’t think this product is a cure all for an uncovered deck. Covered, uncovered big consideration!
Sherry H
Sherry H
I’m like everyone else on this post, this product is crap!!! Peels and then let’s wood mold and mildew! Very time consuming to prep for and very expensive too! What a waste!
Is rotten it holds the most moisture so now it’s
My deck is rotting it holds moisture so now my deck is rotten I would not Recommend anyone to put this on their deck they should have to fix our decks
Mary Mayka
Mary Mayka
This has got to be the worst product EVER. I’ve had such amazing luck with Behr indoor paints that I won’t use anything else–I’ve been a Behr loyalist for years–until now. I spent days and days stripping down my deck and prepping it. I stripped it with a chemical stripper, and then sanded it down till it was smooth as a baby’s butt (80 grit smooth, anyways). Cleaned it and then let it dry out for days. I know I’m not a professional, but I really don’t think and then painted on a gorgeous overcast day in the mid-70s. No rain for days. It looked amazing immediately afterwards.
Problems started pretty fast. First, the deck got very “dirty” very fast. We have kids and dogs, nothing abnormal. Mind you, we used a reddish brown color–its not really light so it shouldn’t look like I need to wash it 1-2 weeks later, and it didn’t wash off with rain or sweeping. It’s like the dirt was attracted to the paint. Am I being picky? Maybe, but it was noticeable.
And then another couple of weeks later the problems really started in. Less than a month after I applied the product and the crap is bubbling up all over the deck. Relatively new boards in perfect condition, old boards, there’s no difference–it’s bubbling everywhere. After it rains, the boards on the underside is SOAKED. My deck is raised ~5 ft so it’s not like it’s trapping in moisture from being too close to the ground. There is no beading on the surface of the paint at all, you can almost watch the water soaking in.
I called Behr’s helpline and and they walked me through their list of questions to see what I screwed up in my prep. Maybe I applied it too thin or too thick. Their suggestion was to to sand down the spots and reapply–they seemed nice enough and wanted to send me some more paint and cleaner. OK, whatever! Forget that noise! I can’t believe I didn’t find these reviews until after I did all that work!
So, my question now is… what to do? My current plan is to strip the porch down AGAIN (this time I’ll be renting a drum sander) and then use the DeckRevive products. But… what about the railings/spindles? Those were SUCH a pain in the butt to do and I don’t think I could possibly get a sander in between them. The DeckOver appears to be well adhered to those (for now)… would I be able to prep and just repaint with the DeckRevive? Or will that be OK and do I just leave it?
I’d really appreciate some feedback.
John O.
John O.
One of the worst deck products on the market. Avoid at all costs. It took days to remove pealing paint.
kathie lansdale
kathie lansdale
What happened?? I followed the directions to a tee.. put the first coat on with the recommended brush. Second with the recommended roller.. done after following prep directions.. footprints l
eave a mark.. my dog laid down and his nails left marks.. his nails are trimmed regularly.. when it dried, it looked like flat paint.. blah.. I’m disappointed.. can’t believe I paid so much money and put so much effort into this project..so disappointed.. wish I would have read the reviews first..
Sandy Carney
Sandy Carney
We loved how it filled cracks and no more splinters BUT it peeled off within the year. We did everything manufacturers told us to do and did it a second time. It peeled off again. Wish I could find something that would work.
Elizabeth Fortner
Elizabeth Fortner
It’s horrible! Now what? I did what it said in applying. It’s peeling. Bubbling. It’s a mess. Is there a guarantee? Money back?
Nina
Nina
Worst product ever – I agree
Ruined my deck and now cost to restore is astronomical
Becky C
Becky C
Reply to  Nina
Looks like our deck.
Jenny
Jenny
Worst product ever. All 4 of our decks are rotting and need replaced. Your talking $60,000 worth of decks that we’ve always maintained. There was a lawsuit that we found out about after it was over. DO NOT USE THIS PRODUCT!!!
Cliff
Cliff
So far good results here in Rhode Island/New England. Caveat is prepare the heck out of your deck or porch. Power wash the deck clean, clean, clean but be careful not to rip apart the wood fibers with too much power. If need be use some elbow grease and bristle brush. Let the deck dry, this make take a few days. Sand down any rough or splintered areas after the deck has dried and blow off all debris, dust, small wood pieces, dirt that may have settled after the cleaning. Once this is done you will need to apply an Alkyd Oil based primer and really work the primer into all cracks and crevices. Don’t be cheap with the primer. Let the primer adhere to the deck for 2-3 days. Lastly, apply the Deck Over and don’t be cheap and apply at least 2 coats and in some areas 3 coats.
My deck previously had many small and somewhat large cracks and I had never stained or painted it before. It sat for about 8 years and was completely weathered before I tried the above. It is all about cleaning and preparing the deck, applying a good oil based primer and then painting. Don’t be cheap on the primer and paint and let it dry thoroughly before adding coats, which you should do.
Judy
Judy
My deck looks terrible. I will have to have someone come to completely sand the deck and go back to stain. Shows footprints and hard to get marks removed. Bubbles terrible. Should refund money to customers. Shouldn’t Be on the market.
Terrible product peeling traps moisture ruined my wood deck shouldn’t be on market the damage it’s done replacing rotted wood now
Chip Johnson
Chip Johnson
I am very disappointed with Deck over. I followed all the directions when applying it. If you don’t fill every deck screw hole or fill even the smallest imperfection in the wood, the Deck over will bubble up. It looks terrible. I have scraped those portions of my deck that are bubbling or wrinkling 3 times now, and the problem keeps returning. Next spring, I will sand it all off and use stain. Don’t use it.
Ron
Ron
Comment. Deck over isn’t Good in high humidity on wood decks. If there is a crack in the paint it holds moisture. Rots the wood. It’s like paper in a water balloon with heat. Don’t use in high humid areas on wood
Ron
Ron
Reply to  Ron
My deck over doesn’t flake away like most I used a think base roll. Now the deck is bloated and rotting.
Ron
Ron
Reply to  Ron
And now I had the deck for 13 years and it’s trashed with the deck over. Leave it dry and untreated is better
Ron
Ron
Reply to  Ron
2 years or so deck over. Thanks
Ron
Ron
Reply to  Ron
I want. Damn new top on my deck. And not a deck over. Wood or carb . 18ft x32 foot deck. Pay up
Ron
Ron
Reply to  Ron
Fix it
Jay
Jay
Behr deckover lasted a year before it started peeling off. I seen there was a class action investigation and settlement against Behr and Home Depot and the consumers won. So, how is it that they can continue to sell this defective product?
Steve Ostrom
Steve Ostrom
Product looked great the first year in MN, but started pealing horribly after that. I’m going to need to scrape it all off, sand everything down, then reapply a different Behr stain/sealer. This product had very high reviews, which is why I chose it. Terrible decision. Very odd since Behr has such high quality products.
Brian McDonnell
Brian McDonnell
Wish we never used this product. Pure crap. Peeling faster than I can pull off. Someone should sue this company It ruined our deck
Darcy
Darcy
I followed the instructions for surface preparation and application. After 2 years the pInt started peeling, bubbling and lifting. I am in the process of having to redo the entire 2 level deck.
Very disappointed.
constance m stoddard
I used your deck over product on my deck. I purchased the produce at Home depot. At the time of purchase you were offering a rebate as part of your promotion. I should have know when I never received my rebate , after all the documentation was returned to you. I had to redo several areas on the boards because of the product started peeling after one year of the original application. This spring entire sections had peeled away. I hired a contractor to help repair the damage. He tired your product to strip the paint off which did not help the problem. It only made it worst. My deck is 18×24 and I now have to replace several boards because of the damage done by deck over. After several days of scraping and sanding the deck looks terrible. I truly was excited when I first use your product, but what a disappointment.
My husband and are retired and it is hard to keep paying for the repairs being done year after year.
margaret bell
margaret bell
worststuffever
JC Cap
JC Cap
Extremely disappointed. Did not last a year. Prepped and primed as recommended. Less than a year later, I get a call that it’s peeling. I thought it was just going to be a touch up, I ended up stripping 400 sqft of deck. hours power washing. I’m 700 cad out of pocket just to fix the issue, and I can even file a complaint through homedepot. Behr makes it extremely difficult to contact them directly. I’ve had better service with WISH, when it came to faulty products. I thought products produced in North America would be better. I was so wrong.
It may work well for covered porches, but so does latex paint. Stay away from this product.
drb2020
drb2020
Reply to  JC Cap
Completely agree – I’m in the process of stripping a huge deck. I regret buying this product – pure garbage and hard to remove. Rots the wood faster than the elements.
Muddbone
Muddbone
This is the absolute worst product I have ever used. This crap is hyped to make old decks look good again by filling cracks and bad places in boards. Hell it might work if it would stay on the deck boards. A gnat can fart and this crap blows off in big sheets down to the wood it is hyped to protect. The deck was prepped utilizing all the fancy expensive prep cleaners for wood that the expert behind the paint counter and the label on the paint cans stated and it made it all of 3 months before the gnat darts blew it off in sheets. Do not waste your hard earned money or time with this garbage!
Tom D
Tom D
Reply to  Muddbone
You are correct it’s a horrible product. It started peeling after a year. We installed it just like instructions stated.i tried numerous times to get refund. But they always said I didn’t send in receipt but sent copy in.
I would not recommend this to anyone. My neighbor use it too & it peeled off too.
Joel
Joel
As a general contractor, I’ve used the DeckOver Textured product many times, and am very happy with it. The peeling problems so many report is almost always due to ill-prepared surfaces or application at the wrong temperature. I’ve painted my own large front wrap-around porch, as well as the back stairs, both about 8 years ago. The paint has not cracked, peeled or faded. I primed all bare wood with a quality oil-base exterior primer. It’s a little tricky applying the DeckOver, but I’m very happy with the results. The only issue I had was when a step dried out, shrank and split. I cleaned out the split, painted the crack with Varathane Wood Hardener, filled the crack, primed and then painted the step. You’d never know the step cracked at all.
Frank
Frank
Reply to  Joel
Joel, I’m thinking of using this, which is a huge risk given all the negative feedback. Could you offer more details about the prepping and application that got you the success? Thanks.
Joel
Joel
Reply to  Frank
Frank,all I did was in my last post. I really think the trick is in the prep. I’ve seen the prep work many DIY’rs, as well as many contractors, and it doesn’t leave a properly prepared surface for most any type of finish. Then they wonder why it’s not lasting. The substrate must be solid, clean, free of all loose, peeling or flaking finish. All cracks need to be filled with a high-quality exterior filler. On areas of questionable bonding capability, I like to paint the area first with the wood hardener I mentioned. It not only hardens the wood, locking down loose fibers, but also acts as a great primer. Then the high-quality exterior primer, then usually a minimum of 2 coats, sometime 3, of the final finish. I never apply the primer of finish in direct sunlight. It dries the solvents in the oil primer too quickly, preventing a good bond, and it evaporates the moisture out of the water-based finish too quickly, causing it to shrink and delaminate. With exterior paint, I’ve found that a nice, slow drying process can actually increase the bond. It really is all common sense. The wood must be sound, clean, and, very important for the oil primer, it must be dry. Although it is possible some of the negative replies were due to a bad product batch, no matter the final choice of finish, the results are all in the prep work. Regardless of your choice of finish, good luck.I might add that I live in the SF Bay Area, where the weather is milder than many areas, so my results may be vastly different than someone living in an area of 4 true seasons.
One last thing – if power washing, turn the pressure down!! Too many people use high pressure and end up shredding the surface and leaving a multitude of damaged wood fibers.
Joel
Joel
Reply to  Joel
One thing I should have mentioned: all my experience with this product is on covered porches and or exterior steps that are weather protected on the underside. If your steps are open to weather, rain, extreme humidity, freeze/thaw cycles, etc., then my remarks may not be accurate for your conditions. If this is the case, and it were me, I would clean & prime/seal the underside also. If the top is sealed, but the underside is open to adsorb moisture, then that moisture is trapped and may start causing de-lamination of the finish.
marlene devlin
marlene devlin
Reply to  Joel
Not meant for most climates.
Frank
Frank
Reply to  Joel
Very helpful, Joel! While I still don’t think I’ll risk this product, as I’m in the midwest, your suggestions about prepping make a lot of sense.
Debbie
Debbie
Reply to  Joel
My deck was new when I applied this stuff and I cleaned it and let it dry for 2 days. I am quite particular about how I do things. My deck peeled quite badly and I tried to rent a sander and it still has not come off. This stuff is just plain shit and terrible so I do not appreciate you saying that it is all wonderful when it is not. Are you paid by Behr to say this ? I wonder
marlene devlin
marlene devlin
Reply to  Joel
wow…You were lucky. We have to replace our deck after using this horrible product.started peeling in 6mow. IT also held in moisture and rotted some boards. Most disappointing. Feel more should be done to help with redoing it.
April Gardner
April Gardner
Reply to  marlene devlin
Yep same thing happened to us and we have a huge 1,000 square foot deck that has to totally be replaced after 1year! 😡
Renie
Renie
Reply to  Joel
Hi Joel, Thank you for all your detailed answers to all those who ask. I DO NOT have a wooden deck. I have a concrete dock. It’s in fairly good shape but not great. For me, is it to use The Behr Advanced Deck or go looking for some off brand? Once applied, I certainly do not want or have to repaint yearly. HomeDepot sells 2 types. Smooth or the Textured/Extra textured. Dont know which one to purchase? I read feedback as to just how thick all these products can be, Hence Im now leaning toward the Smooth finish instead.
As far as prep, today I used some pool chlorine 1 to 3 mix with water along with a bit of dishwashing liquid. Two or 3 day prior to painting I plan to do a light pressure wash as the dock is now fairly clean and this product should adhere well.
What do you think? Purchase the Smooth finish or the the Textured finish? or perhaps just plain steer clear and find a different brand as it sounds like you really know your stuff?
Joel
Joel
Reply to  Renie
Renie, I hate to disappoint you, but I can’t make a recommendation for use on concrete on a dock. The underside of the concrete must be constantly barraged with the moisture near the water. This could lead to moisture absorption, which could lead to delamination of the paint product. What I have done in the past is to use a concrete stain, but I applied it while the freshly poured concrete was still ‘green’ That way it actually etches into the fresh surface and won’t come off. Just like using a cementitious dye in the raw material. I have also used what is basically a cyanoacrylate (super-glue) as a primer-bonder, then coat with a two-component epoxy paint, with a bit of silica sand mixed into it for a non-slip surface. This is obviously not a cheap endeavor. Sorry I can’t give you the go-ahead you’re hoping for. Good luck.
Rene Triay
Rene Triay
Reply to  Joel
Thank you Joel for your very detailed reply. Sorry it’s taken so long to respond but we have been dealing down here with hurricane ETA and her aftermath.
This dock was built in 1978 and was professionally painted around 10 years ago. It held up fairly well for years. I repainted a couple of years ago but has not held up as well. I used the stuff sherwin Williams recommended but not happy with the results. Since the Behr product is thick, I was guessing it would hold up better. Also remember it’s really hot down here and trapped moisture has never seemed to be an issue. And yes, the procedure you have suggested sound very laborious and expensive.
I guess I’m back to square one. I think I have to do more homework.
Thank you my friend,
Renie
April Gardner
April Gardner
Reply to  Joel
Yeah that board that dried out cracked and split was from the deck over product! My whole deck , brand new deck did the same thing with this product! My sister works for Behr so we did exactly what they said to do! This product is Crap!! There is No right or wrong way to apply it even if you do everything that they say you Will Not get the results that they say you will! Our deck is beyond repair now totally destroyed practically every board 😡
Barbara
Barbara
We used Deck Over 9 years ago and it lasted. We’ve had to replace about 30% of the deck boards so now we have raw wood and painted wood. There is some peeling but nothing like what the others reported. Do we need to prime the raw wood? We planned to do a good powerwashing and then paint once it dries. That’s it. We are just trying to extend the deck another 3-4 years.
Barbara
Barbara
Thanks for the quick reply! So that’s yes to the question of whether we need to prime the raw wood? Should we use something like Kiltz or just more Deck over?
Ginny Fischer
Ginny Fischer
I painted my decks at my lake house two years ago with Deck Over. I followed the directions on the can before starting to paint. Last year the paint started peeling off. It was so bad that I could peel off very long strips at a time. I am still trying to get the paint off. I spent a lot of money and time working on my deck. I am very disappointed with the product and wished I had know about the poor quality of the paint before I purchased it from Home Depot. Now the task to remove the paint has started and getting the paint off has been a nightmare! Any suggestions on how to get it off? I will not even try Behr Stripper and would like other suggestions to remove the paint.
marlene devlin
marlene devlin
HUGE job to fix. WE are just going to replace whole deck with trex. NO, We are not well off.
Jim golden
Jim golden
Finish my deck with deck over. Very expensive. Needs 2 coats. Fast forward one year sealer started to peel. Snow and rain made more peel. Surface becomes very hot in sun, blistered young grandsons feet. Many boards now replaced due to rot. Class action law suite 1 1/2 year ago still have heard nothing. Home Depot still sells this product. Negative Remarks have been removed from Home Depot web site. Our deck is 20 x 20. All material purchased at Home Depot. Lesson learned to late. Photos available on request.
HOLLY DIEDERICH
HOLLY DIEDERICH
I finished my deck summer of 18, NOw the peeling and wear are horrible. I have a large deck, with minimum usage, and the idea of having to scrape and redo is overwhelming. And I can not download photos.
Stebe
Stebe
Stay away from this product. It’s pure garbage. My experience with the textured application was it bubbled up and peeled off easily in certain sections. I stained the wood in my garage before it was installed. So my preparation process was above and beyond what would typically be done. I’m a week of my time and hundreds of dollars into trying to completely remove it and still have many hours of work left to get this junk off my deck. So if you are considering using this, save yourself a huge headache and don’t use it. Go to a store that only sells paint and get good advice from people who deal with professional painters daily. Behr preys on Do it yourselfer’s. Any professional painter I’ve talked too lately said they would never offer this junk to their customers. Plus it’s not cheap. I just bought 4 gallons of Benjamin Moore and it was the same price and behr…so, don’t think You’ll pay a premium for paint by going to a paint store.
marlene devlin
marlene devlin
Reply to  Stebe
A painter told me that nothing you apply will stay for long without peeling. Deck over is the absolute WORST of them all.
margaret bell
margaret bell
worstproductever
Trawitz
Trawitz
😡 Won’t let me show picture…. but like the majority…. it’s just bubbling and peeling off. Held moisture…some boards with rotten spots. Now what?? Replace the deck?!?!
Tamie Miller
Tamie Miller
Definitely do not recommend Deckover. Started bubbling in spots just weeks after I applied it. Sanded and did touch ups. More bubbling elsewhere. This is year two. I’ve been sitting on the deck, literally just peeling large chunks off. I’ve peeled close to 3/4 of the stain off with no effort. It is a complete waste of time and money. It looks good for about 5 minutes.
Rob Brown
Rob Brown
Reply to  Tamie Miller
Agreed this product is crap! Get your money back!
Teri Madden
Teri Madden
We just finished using the DeckOver, would not recommend it. Its like working w/cement! We ended up using a brush as the roller used to much paint. Very diffucult to cover over the previous textured paint from previous homeowners. Powerwashed to removing flaking/peeling areas..used 7 gallons costing $260 dollars!
H in Ohio
H in Ohio
We used Advanced Deck Over summer 2019. We followed all the application instructions. Spring rolls around and the Ohio snow melted and we were left with bubbling and peeling finish everywhere. It was clear that water had penetrated the finish as the boards were wet.
We contacted Behr customer service and they sent us replacement product and said they would cover the rental of a sander. All well and good, I still had to purchase stripper and power wash the deck. Still the finish isn’t removing everywhere. It also appears that the Advanced Deck Over has ruined boards on the deck. I’m guessing because it held water all winter between the finish and the board.
If we can’t get the product off completely, we may have to replace the entire deck which is over 500sq ft.
Joshua Baptiste
Joshua Baptiste
Does anyone know if there is difference between DeckOver and the new “Advanced DeckOver” product that HD is selling now?
Anonymous
Anonymous
We used product on decking and step landings going down to lake. Product looked good first year. This year is totally pealing off vertical surface of deck wall. Now we have to figure out what to put on it to match horizontal surfaces. Disaster. Didn’t seal moisture either. Instructions do not say you cannot use on vertical surface..at least not that I can see on the instructions. We put a lot of work into this and are very disappointed.
PJ
PJ
Deck looked beautiful after application. Followed instructions to the letter. After first year it began to peel. Now we are in year 3 trying to figure out how to get it all off and find something that works!
Heidi Melone
Heidi Melone
Reply to  PJ
I am in the same boat as you. This happened to the deck on the home we just bought. We have 3 huge decks…..I think the previous owners just kept painting additional coats as it started to peel. Sanding doesn’t work. Tried that. I purchased a product called “diamabrush”. Basically grinds the deckover off without hurting the wood. Taking all the coating off down to the bare wood and then plan to paint. Deckover is the worst!!
Jake
Jake
Worst product ever,did not come close to doing what it said,peeled and cracked within 6 months,most of the rest like a thick layerof that peeled wright off,but it did manage to seal moisture in which wasn’t too good for the wood,have 4 gallons in basement if anybody wants them.If I could give minus stars there are not enough in the sky!
822
