Best Wood Stains for a Log Cabin 4/5 (30)
Best Wood Stains for a Log Cabin in 2026
We at Deckstainhelp.com offer tips for more than staining decks. In this article, we offer our insight on which stains are the best for log cabins. We always appreciate your input, so feel free to leave a comment below with pictures of your log cabin stain projects. For 2026, TWP 1500 Series and the Restore-A-Deck Wood Stain are two excellent examples of log cabin stains.
Log Cabin Stain
Log Cabin Stain
Best Exterior Wood Stains for a Log Cabin and Wood Framed Homes
There is no doubt that a log cabin is a thing of beauty in almost any type of landscape. To keep a log cabin looking good and lasting for many years, maintenance is key. Log cabins can be very high maintenance and homeowners know all to well the tedious task of keeping it in good condition.
Like any other wood structure, a log cabin needs to have a protective finish. This keeps water and UV damage from rotting the logs and causing damage to the structure. Determining the best wood stain for a log cabin takes many factors into account. The texture of the wood, age, log moisture content, and climate are just a few. So while there may be many wood stains best for a log cabin there are a few that stand out.
Considering that most log cabins are constructed with rough-textured porous wood that eliminates using any type of stain made for dense smooth woods. A wood stain that is uniquely designed for rough sawn and porous wood is ideal.
Wood stains such as TWP 1500 Series and the Restore-A-Deck Wood Stain are two good examples of log cabin stains. These penetrating stains help prevent the damage caused by water, fungi, and UV radiation. They will allow the natural beauty of the wood to show through while providing maximum protection.
For extra dry logs, a stain like Armstrong Oil Based Stain can be a great choice. In addition to enhanced beauty and weather protection, Armstrong utilizes nondrying conditioning oils to replace the wood’s natural oils that have since evaporated. The nondrying oils separate from the drying side of the formula that remains at the surface to lock in the conditioning oils providing a dry to the touch barrier.
Try to stay away from wood stains designed for smooth hardwoods and also film forming or acrylic based stains. These types of stains are not best used on the rough sawn cut texture of log cabins and can cause a whole host of problems.
If you Have Questions on Staining Your Home, Please Ask Below
The Best Wood Stains Log Cabin Photos
269 Comments
Tony Barnett
Tony Barnett
Could you tell me what kind of stain to use and can I just pressure wash it thin stain
Jeffrey Curtis
Jeffrey Curtis
I just got a log cabin from Little log cabins.com two years ago it’s Sun faded out yellow notty pine what stain you recommend the enteior I what’s clear varnish what is best
ABW
ABW
I just bought a cabin that has unstained rough cut cedar on front and back and hardie board on sides that the prior owner painted brown. Trying to figure out how to stain the cedar and somehow make the sides match or at least blend. Can hardie board be stained?
Olivia
Olivia
We don’t know what kind of stain was used on our log cabin but it is time to stain, is there a stain we can use without sanding?
Gerard Riquier
Gerard Riquier
How to protect from ULV ray in South Georgia ?
Arlene Wakeling
Arlene Wakeling
We live in an original pioneer cedar log home from the 1800’s and like to re-stain the logs next year. I used about 6 years ago Premier quality exterior wood semi transparent stain on the logs, they still look great but I would like to change the color by staining over it.
Which type of stain is best to paint over old color without sanding out stain off? We live in Ontario , Canada a four season country.
Arlene
Arlene
What if I used the same brand?
frank andrews
frank andrews
I have a cedar sided home built in 1986.The exterior has been preserved / stained with only one product that has been used over the years. I need to reapply and cannot find and old can. The store I purchased it is out of business. Crazy but all I can remember that it was labeled as a stain wood preservative for cedar buildings and log homes. I believe the product began with the letter P. the color is a dark brown.Hope possibly someone maybe able to help.
Thanks in advance
Thomas Rauls
Thomas Rauls
Reply to  frank andrews
Could be Penofin wood preservative
New product is Penofin Verde a greener product
Reney
Reney
What kind of stain do you recommend for new Western red cedar 4×4 posts?
Is arbor coat or structure wood stain okay.
I’ve seen good ratings for Armstrong but can’t find where to buy it
Thomas Rauls
Thomas Rauls
I agree with not using Arbor Coat.
New options would be AgriStain by Green Planet Paints. Penetration of a 4×4 cedar post in thee months in the sun. 100% renewable resources,
No mildew, mold or in can preservatives. All natural preservation of wood.
Reney
Reney
Devin
Devin
Can I use a solid color of Olympic Elite stain on my log home? Do solid color stain breath enough for log?
Nancy Krause
Nancy Krause
We currently have a rough cedar sided home stained with behr premium log home glossy cedar stain. It is turning dark in areas, also not a fan of the glossy finish. What can i use to switch to a more flat finish.
glyfada kinser
glyfada kinser
What is the best clear log cabin sealer?The cabin is made from logs cut straight from our woods & is 40 years old.
Lillian Poff
Lillian Poff
What color stain is on this cabin in the picture above?
Lillian Poff
Lillian Poff
Could you send pics and names of the stain that would go good with black trim?
Greg Alan Flem8ng
Greg Alan Flem8ng
Just purchased 26 to stacked logcabin. Home inspector said I need to pressure wash and stain logs deck and deck railings. I’m awarded monies to buy pressure washer and all products for the job and want to bring this home back to life. Help!what can brighten it up. Do i need to pressure wash/strip/brighten/stain?or is there more or less. And particular products
Richard
Richard
My log home is 25 years old and needs to be recounted. Which product is best with the most longevity
Dave Powell
Dave Powell
Is CWF-UV5 a good choice for re-staining a log home. We have eastern white pine logs.
Eugene Campbell
Eugene Campbell
I have a pine log home approx. 20 years old. Getting ready to power wash and restain for the third time. I would like to have a semi transparent or clear look showing the beauty of the wood, but would also like to have a glossy or satin look. What product do I use?
Gene
Miranda Dean
Miranda Dean
I have a large, pine, log home and live in Mississippi. We have issues with sun and rain. Im thankful that we do not have to worry about a lot of snow. Can you recommend the best stain for us? Our house is 3280 sq. ft., so how many gallons would we need?
Cecil Pugmire
Cecil Pugmire
I have a 3 sided log home that was last stained about 6 years ago, live in SE Idaho with semi dry climate at 6000 feet altitude. what is best oil based stain recommendation?
Stefanie
Stefanie
Are any of your recommended stains compatible with Permachink chinking compound?
Cory
Cory
Hi. I’m a first-time cabin owner… and looks like I need to restain it before winter. Previous owner used Superdeck 1910 Natural. I really like the color, but it’s fading after a few years. Can I reapply the same stuff over the top (after pressure washing) or do I need additional prep work? If I need to do additional prep, should I just go with another brand of stain? Looks like Superdeck doesn’t get very good reviews. Thank you!
Norma Counts
Norma Counts
We used capture and cascade on our log home, it is water based. Is it okay to switch to an oil base
Karen Freeman
Karen Freeman
I have a 27 year old log home that we moved into 3 years ago. It needs to be stained. I believe it was previously stained with Cabot semi transparent stain about 8 to -0 years ago. Any recommendations.
Cindy and Don Adams
Cindy and Don Adams
We have a 38 year old log home we built ourselves. We need your help choosing the right kind of stain/preservative. The last thing that was used on it was cuprinol 38 years ago.other than that bug spaying and power washing is all that has been done to it. We have some carpenter bee problems west side and post beetles on the east side. The house is actually in good shape. We know we need to power wash it 1st. Not sure what to use. If anything. Please help. cell phone is 603-860-2891
We live in Massachusetts , but we live inland near the New Hampshire boarder.
Marcy Slaughter
Marcy Slaughter
We bought a log cabin in southern Colorado 4 years ago. We think the cabin was built 25 years ago. The logs are green treated and do not look like they have been stained. We are planning on pressure washing with a cleaner, then brighter to make sure everything is off the logs. Next, stain them because they are looking dry and in need of some chinking too. What stain would you advise me use on these green treated logs?
Also, it has a porch with log railing around the house. Would you put the same stain on the log railing that you would the log house or do I need to use a deck wood stain on the log railing?
Thanks for you help.
Betty Viersen
Betty Viersen
We need to know what will go over Behr Super Rawhide? We had excellent results with it but time it’s redone. Help
I used Olympic Clear coat stain on my exterior white cedar logs. The water-based stain has not lasted 3 years. I am ready to put a solid pigment stain on my cabin even if I have to go to a darker color; right now it is sort of a neutral blonde color. Please advise me on what is the best brand to use. I live in western Indiana where the weather constantly changes. Some of my logs have started to turn dark where the stain has worn away. Please advise. I just remembered that my wife and I accidentally put water based solid stain on the logs as well. I know it was a mistake but we did not know what to do. Can I put a solid oil base stain over all? All of the logs have a knife and peel look to them…
Terry
Terry
I have a log home made out of larch pine,very dry and hard wood . The sun has dried the logs out. What stain should I use?
Ken
Ken
Have a cedar rough cut cabin in British columbia.it was first stained in about 1972 with a stain that I believe was called rawhide. This stain never dries and stays tacky to the touch when it is humid. Is there a stain that can be applied over it?
Some people have sandblasted it off of their cabins but it’s an unbelievable mess.is there a way to avoid sandblasting
Ken
Ken
Is there an alternative such as chemical or pressure wash that might work to remove it?
Kurt Wiesbauer
Kurt Wiesbauer
Western red cedar what do you recommend for an exterior and interior stain
Maria Mejia
Maria Mejia
Hi! I’m purchased a cabin in twin peaks, California. I have a big deck that needs re paining. I would like to stain it. Recommendations of what to use or what brands to use? Please help!
Dawn
Dawn
Is there an advantage over corn cob blasting and/or walnut media blasting?
sharon walker
sharon walker
we have a home with log cabin siding..right now we have sickens on it and it is not holding up. what is the best product to use on the siding? we live in Missouri and have sun, heat . we plan on power washing the sickens off but need a great product to replace it with.
What about Outlast Q8 Log Oil for log cabin stain It says it is EPA registered. Any experience or comments?
Shirley
Shirley
I have a spa room. We installed a tongue & groove ceiling. Can I use Thompson Water sealer on it?
dean
dean
can you use cabot austrailin oil on a pine log house
jim munroe
jim munroe
I have a Lincoln log house I built in 1985 always have used cwf cedar stain would like try something different as far as color its held up ok after about 6 applications over years
Alan
Alan
How would you remove the cwf ?
Willy
Willy
Reply to  jim munroe
Don’t build layers (multiple coats) with semi or solid stains, it’s not like a paint that builds durability and life by applying multiple coats. Multiple coats of solid or semi stains will peel, one coat with a thin second coat is the max or it WILL peel.
Willy
Willy
I used Behr Deck Plus Solid stain 12 years ago on our cabin and it still looks like we just stained it yesterday.. Solid stains don’t typically peel like paint, just slowly fade away. But the Behr still looks like new. So good we used it on our main home in New England and it is holding up unbelievably. I do see it rated #1 in Consumer Reports all the time so it has an excellent rating from them also. I would never use semi or clear oil stains, they attract mold since it is a natural food for mold spores. They look nice and natural but the constant maintenance is not worth it for me. I’m hoping for 20 years out of my solid stain, so far so good. If you pick the right color the solid looks beautiful.
Willy
Willy
Is TWP a linseed based product??? If it is, linseed is a natural food for mold.
Wayne
Wayne
We had a sunroom completed last November. It is Douglas fir post and bean construction. The weather was too cold to apply a finish so we are waiting for Spring.
What one step product do you recommend (exterior finish on new wood)?
We would like to keep the natural wood look (stain and seal)
Wayne
Horseshoe, Ontario Canada
Can this stain & protectant be used on pressure treated wood decks
Kevin
Kevin
We have a 30 year old log home currently stained with Cabot solid stain acrylic. Would it be advisable to remove by corn blasting and starting over with product specifically made for logs? (ours are pine)
Greg
Greg
We have a log cabin that is 30 years old. The south side of the cabin really get beat up by the sun. I looked at it and many of the logs have the normal cracks from the sun and heat but the wood is really dry and needs a finish. I am looking for a clear type of finish that preserves and protects from the UV rays of the sun. Currently it has had oil based stains on it in the past, (Clear wood Finish UV and Cabot australian timber oil and others over the years).
Brandon
Brandon
Would Olympic stains be ok for a log cabin. Is there any way to figure out what kind of stain that’s already on it because it seems to be a very good product and I like the color.
Patti A Ashbolt
Patti A Ashbolt
We are in the process of picking a stain for our log cabin. It is old and the old stain is not coming ff completely. Can I use a sold stain such as Solid Matte – Rubbol® Solid Wood Finish?
Scott Welch
Scott Welch
Hello, I am in the process of stripping the old stain and putting on new, my question is I bought 5 gallons of TWP 200, but everywhere I look I see that people are using TWP 100, can you tell me your opinion on this? My house is red oak, and the stain is old and failing bad, thank you Scott.
Gregg Juster
Gregg Juster
Finally about to stain my log cabin with TWP 100. First step your stripper, wait 45 minutes then wash off. Apply brightner. How long before the stain is applied?
Gregg Juster
Gregg Juster
Do I wash off the stripper then apply the brightner. Do I have to wash off the brightner then allow the 48 hours of drying.
Gregg Juster
Gregg Juster
What if the TWP stain is applied and it rains in 12 hours (or 24)
Mark Littlejohn
Mark Littlejohn
Can the Flood semitransparent stains be used on logs, and if so, which type? Will be used in Montana.
Paul
Paul
Hello!
Can you recommend a stain product for rough cut pine siding? The cabin is one year old.
Thank you for the help.
I have log railings for our deck that I need to re-stain. They are presently a golden oak looking stain and we want to keep that same look. Any recommendations? My wife wants to see a stain chart to do a comparison before we buy. Thanks!
rick
rick
Here is a picture.
X
269
