2.9K
Can you use deck stain on concrete?
No, you cannot use deck stain on concrete. Deck stain is engineered to penetrate into wood, not concrete. It can be tempting to use deck stain on concrete if some stain was accidentally applied and you planned on sealing the concrete. However, concrete stains designed specifically for penetration and sealing of concrete should be used.
- Deck stain cannot be used on concrete because it is engineered to penetrate wood, not concrete surfaces.
- Use a concrete stain specifically designed for penetration and sealing when working with concrete surfaces.
- Deck stain can be applied to railings, spindles, fences, and outdoor wood furniture beyond just decks.
- Always choose the best deck stain based on wood type, whether hardwood, IPE, pressure treated pine, or composite.
What can deck stain be used for?
Deck stain can be used in places other than your deck. Deck stain can be used on railings and spindles, as well as fences. You can also apply deck stain to outdoor wood furniture. It is still important to get the best stain for the job based on the type of wood and application. Deck stain should only be applied to wood, hardwood, IPE, pressure treated pine, or composite decks.
