How to Strip a Deck Stain: Pro Steps for Removing Old Stain 4.8/5 (100)
Hi, I am Scott Paul, an exterior wood restoration contractor and business owner with over 30 years of experience in stripping and removing exterior wood and deck stains. My Deck Stripping tips are based on my history as a wood restoration contractor and actual hands-on testing. See here for more info about me.
Quick Answer: How to Strip a Deck Stain
  • Apply a deck-specific stripper (not a general cleaner) and let it dwell 5 to 45 minutes depending on stain type
  • Oil-based semi-transparent stains usually loosen in 10 to 15 minutes; water-based acrylic stains can take up to 45 minutes or multiple passes
  • Agitate with a scrub brush, then rinse with a pressure washer at 1200 to 2000 PSI from 8 to 12 inches away, or a stiff brush and garden hose if you don't have a pressure washer
  • Apply a wood brightener afterward to neutralize the stripper and restore pH balance
  • Solid color stains and paints often need sanding in addition to chemical stripping
  1. Deck Stripping Materials
  2. Choosing the Right Deck Stain Stripper
  3. Stripper Dwell Time and Difficulty by Stain Type
  4. Step-by-Step: How to Strip a Deck
  5. Pressure Washing Tips for Deck Stripping
  6. Stripping a Deck Without a Pressure Washer
  7. Best Temperature and Safety Tips
  8. Brightening the Wood
  9. Cost to Strip a Deck
  10. Ask Me Deck Stripping Questions
  11. Frequently Asked Questions
  • Proper Deck Stain Stripper
  • Gas-powered pressure washer
  • Pump sprayer for applying
  • Scrub brush to agitate
  • Protective Equipment: Gloves and eyewear
  • Plastic sheeting to protect plants and home
  • Wood Brightener to neutralize when done
Scott’s Pro Tip: See here if you need to remove a Difficult to Remove Deck or Wood Stain.
Solid Color Stain Stripping
Deck Stain Stripping: Deck Stain Stripper Reviews
*Ships Free.
Makes 5-Liquid Gallons.
*Ships Free.
Removes Solid Stains.
Deck Stripper Dwell Time by Stain Type
Existing Stain Type Dwell Time Difficulty
Oil-based semi-transparent 5 to 15 minutes Easy
Water-based acrylic semi-transparent 20 to 45 minutes, may need multiple passes Moderate to Hard
Solid color stain or paint Often requires sanding, stripper alone may not work Hard
Failing Deck Stain
Failing Wood Deck Stain
Below are the exact steps I follow when stripping a customer’s deck, from setup through final rinse.
  1. Protect the work area. Cover the house siding and any surrounding plants or grass with plastic or poly tarps before opening any stripper. Most strippers will damage plants and discolor siding on contact.
  2. Clear the deck. Remove all patio furniture, planters, and grills from the deck and the surrounding area so you have full access to every board.
  3. Prewet the deck with water. A damp surface helps the stripper spread evenly and reduces the chance of it drying out too fast in sun or wind.
  4. Mix the stripper if needed. Follow the label directions in a bucket, then transfer it to a pump sprayer for even, controlled application. Test a small, inconspicuous section first since stripper strength varies by brand and stain type.
  5. Apply the stripper to all flooring first. On a large deck, break the job into 100 to 300 square foot sections so the stripper doesn’t dry out before you can rinse it.
  6. Let the stripper dwell. Wait 5 to 45 minutes depending on the stain type. Agitate with a scrub brush periodically; you’ll know it’s working when the surface feels slippery and the old stain starts lifting. Keep the area wet during this time so the stripper doesn’t dry on the wood.
  7. Pressure wash all deck flooring. Use a steady pendulum motion, holding the wand about 8 to 12 inches from the wood. Rinse thoroughly until no more stain residue washes off.
  8. Repeat on vertical surfaces. Apply stripper, dwell, agitate, and rinse the railings, fascia, and any vertical wood the same way you treated the flooring.
  9. Spot strip any leftover areas. Check the whole deck for spots where the original stain didn’t fully release, and repeat the stripping process on just those sections.
  10. Apply wood brightener once stripping is complete. Let it sit per the label instructions, then rinse thoroughly with water about 20 minutes after application.
  • Always use a deck stain stripper. These products do 90% of the cleaning work. The power washer should only be used to rinse off the loosened grime, not as the main cleaning method.
  • Treat the power washer like a rinse tool, not a scrub brush. Use it to gently wash away the cleaner or stripper, not to grind dirt off the surface.
  • Use a sweeping, pendulum-style motion. Work with the grain of the wood and never pause or reverse direction without lifting the wand. Failing to maintain a smooth motion can leave permanent “stop marks” in the wood.
  • Keep pressure between 1200 and 2000 PSI. Even if you’re using a 3000 PSI machine, distance matters. Washing from 8 to 12 inches away will reduce the effective pressure to a safer level for wood surfaces.
  • Exercise caution. If you’re unsure about your technique or have never used a power washer on wood before, it’s best to hire a professional. Incorrect use can permanently damage your deck.
Pressure washing technique diagram for deck stain stripping showing proper wand angle and distance
Can You Strip a Deck Without a Pressure Washer?
You can strip a deck without a pressure washer by using a stiff bristle brush and a garden hose, though it takes more time and effort. Apply the stripper as directed, scrub the loosened stain by hand once it activates, then rinse thoroughly with a hose on a high setting. A pressure washer speeds up the process and gets into the wood grain better, so for decks larger than a few hundred square feet, renting one is worth the cost.
Best Temperature and Safety Tips for Stripping a Deck
The ideal temperature for stripping a deck stain is between 50 and 85 degrees Fahrenheit. Stripper works too slowly in cold temperatures and can dry out too fast in direct sun or high heat, which reduces how well it lifts the old stain. Avoid stripping a deck in direct sunlight or when rain is expected within 24 hours.
Most deck strippers are not safe for plants and grass if they come into direct contact with the runoff. Cover nearby plants and grass with plastic sheeting before applying stripper, and rinse any accidental overspray off vegetation immediately with plain water.
How Much Does It Cost to Strip a Deck?
Stripping a deck yourself typically costs between 50 and 150 dollars for a 300 to 400 square foot deck, covering stripper, brightener, and pressure washer rental if needed. Hiring a professional to strip a deck usually runs 1.50 to 3.50 dollars per square foot depending on the condition of the existing stain and how many coats need to be removed. Decks with multiple layers of solid stain or paint cost more because they often require sanding in addition to chemical stripping.
Method Typical Cost (300-400 sq ft deck) What’s Included
DIY stripping $50 to $150 Stripper, brightener, pressure washer rental
Professional stripping $1.50 to $3.50 per sq ft Labor, materials, equipment, disposal
Solid stain/paint removal (DIY or pro) Higher than above Additional sanding labor or equipment for multi-coat removal
Frequently Asked Questions About Stripping a Deck Stain
How long does deck stripper take to work?
Deck stripper typically takes 5 to 45 minutes to activate, depending on the type of stain and the stripper used. Oil-based semi-transparent stains usually loosen within 10 to 15 minutes, while water-based acrylic stains can take the full 45 minutes or multiple applications. Keep the stripper wet during this time, since it will not finish breaking down the old finish if it dries on the wood.
Can I strip a deck without a pressure washer?
Yes, you can strip a deck without a pressure washer by using a stiff bristle brush and a garden hose, though it takes more time and effort. Apply the stripper as directed, scrub the loosened stain by hand, then rinse thoroughly with a hose on a high setting. A pressure washer speeds up the process significantly and gets into the wood grain better, so for larger decks it is worth renting one.
How much does it cost to strip a deck?
What temperature should it be to strip a deck stain?
The ideal temperature for stripping a deck stain is between 50 and 85 degrees Fahrenheit. Stripper works too slowly in cold temperatures and can dry out too fast in direct sun or high heat, reducing its effectiveness. Avoid stripping a deck in direct sunlight or when rain is expected within 24 hours.
Do I need to strip my deck or can I just clean it?
You need to strip your deck if there is any old stain remaining on the wood, even if it looks mostly worn away. A simple deck cleaner only removes dirt, mildew, and surface graying, but it will not remove old stain film. The water bead test is the fastest way to tell the difference: if water beads up instead of soaking in, stripping is required, not just cleaning.
Is deck stripper safe for plants and grass?
Most deck strippers are not safe for plants and grass if they come into direct contact with the runoff. Cover nearby plants and grass with plastic sheeting before applying stripper, and rinse any accidental overspray off vegetation immediately with plain water. Some strippers, like Restore A Deck’s formulas, are more plant-friendly than caustic strippers, but precaution is still recommended.
How many coats of stripper does it take to remove an old deck stain?
Most oil-based stains come off with one application of stripper. Water-based acrylic stains and stains with multiple old layers often need two or three applications, with a full dwell and rinse cycle between each one. If the wood still beads water after stripping and brightening, that’s a sign stain residue remains and another pass is needed.
741 Comments
Earl
Earl
2 months ago
Hi Scott, I forgot a couple questions from an earlier post.
My porch looks almost exactly like the attached image from one of your articles.
  1. Can you tell if that is a solid or semi-transparent reddish stain? I think semi-trans.
  2. It is mentioned in your writing to let the decking dry a couple days before staining.
If I use the RAD Brightener and Semi-Transparent stain, they both say
it is OK to stain on a wet (damp) deck.
Do you agree with that procedure or is waiting a couple days for deck to totally
dry after brightening a better approach for the RAD Semi-Trans stain?
Thanks again!!
My-Porch_20260912_091656
Earl
Earl
2 months ago
Hello Scott and thank you for sharing your knowledge, it is a BIG help having this guidance.
I am working on a very small front porch…9′ x 5′.
I have removed and orbital sanded every one of the 26 balusters using 60-grit discs.
I also used the orbital to sand the railing area, then found all your info!!.
There is some remaining solid stain on the railings which, from what I have read, does not need to be sanded off. Is that correct?
I am buying the RAD Paint and Solid Stain Remover to use on the deck boards which currently has a reddish semi-transparent stain on it.
We will be using RAD Semi-Transparent stain.
Questions:
  1. Can/Should I use the stripper on the remaining solid stain of the railings (only one coat there) or just clean/brighten the railings before solid staining?
  2. Will the RAD solid stain cover any remaining solid stain on railing area?
  3. After using the RAD Paint and Solid Stain Remover on the decking, do I need to clean and brighten or just brighten before staining?
I appreciate your time and expertise with this!
Trying to wrap this up prior to temps too low here in Rochester NY.😃
2 months ago
I am going to strip my old stain off using a Cabot wood stripper then pressure wash it and then use diluted oxolic acid as the brighter to neutralize the stripper. I have read if you use OA you then have to use baking soda to neutralize it so the new oil based (Penofin) stain will penetrate the wood is this true? I’m applying the Penofin with a Cabot stain pad. Or is there a better product to use besides OA?
2 months ago
Thanks you. This is so frustrating all over the internet it said to use baking soda after brightener. I even spoke with my local paint store they also recommended it. I had already purchased Penofin so I have to use it as the return date had passed. If you know of a better stain that I can use over Penofin next time great. I live in CA not sure if that makes a difference.
5 months ago
I do have another question if that’s okay, I’ve bought the Redwood 1500 TWP for my top deck (because I have to match it to a behr semi solid redwood water base stain on the verticals) but for my pool deck, which is Redwood about five years old, we might want to go a bit lighter but it’s mostly in the Sun all day in California so what’s the lightest TWP stain you think we’d get away with good UV protection. (As it looks so good stripped and damp with dew) thanks
IMG_5832
5 months ago
But would these offer enough uv protection as opposed to redwood color?
5 months ago
I messed up a little with the Redwood as bought the 5 gallon can but it’ll be fine for my front and back deck but not my Pool Deck as it’s too red. I think shipping will take too long to order TWP online and they don’t seem to sell it anywhere locally but somebody does have Armstrong Clark. Do you write this in the same calibre as TWP or should I bite the bullet and just wait for delivery.? I have friends coming over next Friday and would like it to be done and dry by then
4 months ago
With them both being not film forming would I eventually be able to layer them if I buy a 5 gallon can of Armstrong Clark when I need to touch up the TWP (after cleaning)?
5 months ago
Used rad stripper like you suggested, applied with brush and started scrubbing once I’d finished a section so maybe 30 mins and the deck is all patchy with dark areas from the stripper. This is old redwood that I freshly sanded last year and put two coats of ready seal down which was wearing. I wouldn’t mind if it all turned dark but it’s really patchy and you can see where I occasional splashed the stripper from the bucket- not happy Anna very worried I’ll have to let it dry and sand AGAIN! I daren’t try the brightener in case it just brightens but leaves it as patchy as it is now as ship water in so don’t want to waste time if I’ll have to sand it anyway!
5 months ago
So I just scrubbed it as sanded last year and hosed it with the hose on jet but you are right the brightener helped immensely. Phew was scary for a while as looked almost burnt black where the bucket had sat or where is splashed it.
For my second deck I got the jet wash out! Problem now is we are having this Mountain Dew every morning since but twp needs 48 hours dry 🤦‍♀️
James Raska
James Raska
6 months ago
Here are the pictures I forgot to attached to post
20260519_121144
20260519_121107
20260519_121226
20260519_121121
James Raska
James Raska
6 months ago
We rebuilt our pool deck in the summer of 2023, with new treated lumber decking, posts, spindles. The deck boards were installed in June 2023 and were left until fall of 2024 to stain using Cabot Solid Color Acrylic Deck Stain. We noticed a little bit of cracking/flaking on the deck boards in 2025 but now the deck boards are in bad shape with peeling and flaking of the stain. The railing and spindles are fine as we did stain them indoors before installing them. We have to do something and don’t know where to start. Very disappointed in that we thought we had used a quality stain and waited enough time for lumber to weather.
Not sure if we want to tackle it ourselves or hire it out. Your suggestions would be much appreciated.
LEE
LEE
Apologies for piece-meal query. Here are a few pictures of the remnants of stain. I’m betting, though, that the whole thing should be stripped? Also, when I had the old stain pressure washed off, it was then treated by a company called ‘Elite Seal’ with a silicate based concrete and wood sealer he marketed as creating a ‘liquid glass’ barrier to moisture about 1/8″ below surface of wood that would prevent deterioration. I can find nothing on the company now, and what I can find about using concrete sealers on wood is not advisable, so I’m not happy. It was great at first but then the wood began to mildew and I’ve been washing it since.
IMG_1635
IMG_1636
IMG_1637
Sally B DeVore
Sally B DeVore
I have ordered the products. The young contractor I hope to help me isn’t available until end of October. I live near Cincinnati, OH. Is this too late in the fall to start this project?
LEE
LEE
Note: I tried just today sanding off bits of the old stain. It is too big a job for me (74, female) and occurred to me stripper would be required.
LEE
LEE
in 2017 we stained my deck and railings with Defy water based stain. The new lumber had been aged over 9 months. But it started flaking off in 3. In 2018 I had it pressure washed which removed 90% of the stain, but little bits remain between boards and rails, and in corners and on porch headers. Now we want to stain it with TWP 1500. What is the right stripper to use, and how long will this take? Total of 280 sq ft which includes all verticals.
Carl
Carl
Scott, I have a large deck (1,700+ sq. ft.) about ten years old that I will re-stain in about 10-12 days (weather permitting). I will be using TWP’s 1500 Series semi-transparent stain (Cedar color).
For context, here is the prep I have completed:
  • 2 weeks ago, using top quality PW pine, I replaced a number of deck boards, as well as some balusters, a bottom railing, and 2 stair treads.
  • Next, I pressure-washed all surfaces, including the steps, posts, balusters and railings, to remove layers of dirt, grime, algae, mold and any layers of stain that I could remove
  • Then I treated the same with Restore-a-Deck (RAD) Cleaner, to give the deck an additional cleaning treatment
  • Finally, I applied Restore-a-Deck Brightener and thoroughly rinsed off of this product per instructions
At this point, I still noticed a few small areas needing cleaning and that have retained a considerable amount of the previous stain (which I believe was a semi-transparent water-based Cabot product in a “Cedar” tone).
Here are my 2 questions: (1) Should I use the RAD Stain Stripper I have on these areas (note I have not used it anywhere else on the deck) and then Brighten, or would you recommend an alternative effort (i.e., sanding/cleaning) to get a result of “uniformity” so there will be a consistent color across my deck after I apply the new stain? (2) I’m certain the new wood I installed is too moist to accept the new stain. That said, would you NOT apply the stain on these pieces until they have sufficiently dried? My thinking is, in a few months time, I could individually apply the stain to these pieces. Thoughts?
Many thanks! – Carl
(Note: Photos attached)
IMG_1284
IMG_1287
IMG_1288
IMG_1289
Jeff
Jeff
I want to remove my Cabot gold stain off my deck. Is there an easier way besides sanding it all off? What stripper would you use? Also what kind of stain would you recommend for matching my old deck with my addition I put on? Thanks
Jeff
Jeff
Reply to  Jeff
It’s the stain that advertises the look of hardwood floors outside
20250407_164049
20250407_164028
20250407_164012
Jeff
Jeff
That’s what I thought. Thanks for your help.
Becke Hudecek
Becke Hudecek
We have raw cedar beams and railings that we stained with Behr last year that seem to be turning yellow/orange to me. I would like to start over and use a high quality stain. Is this possible without ruining my raw cedar beams and railing?
House
Stain
Eleanore Higgins
Eleanore Higgins
We have a brand new cedar deck. We put Behr Waterproof cedar naturaltone on it and it turned orange. Need to get it off but dont want to damage new wood. Stripper or industrial sander?
Advise please
Eleanore Higgins
Eleanore Higgins
Pics attached
17286691748204060704226399012300
20241010_194510
Eleanore Higgins
Eleanore Higgins
Perhaps we should just sand it then? Forget the stripping and cleaning steps?
Eleanore Higgins
Eleanore Higgins
After we get all the stain off, could you recommend a clear coat waterproofing product for use in Canada? We would like the white cedar to remain as natual looking as possible. Thompson water sealant any good?
Jane
Jane
Hi
I have a 19 y.o tigerwood deck. In the early years I cleaned and stained yearly. Life got busy and now it has been at least 5 years since last treatment. My questions for you are
1. I am planning on sanding rather than chemical stripping. What order of activity do you recommend. Sand/clean/brighten/ rinse/ dry/ stain or clean/ brighten/ sand/stain?
2. Grit recommendation and sander type for tigerwood
3. What is the best stain product and color to return the wood back to its original beautiful state. Thank you!
20240918_163212
Beckie
Beckie
I had my entire deck replaced in Aug. 2023, used yella wood. It was stained with gray color stain in April 2024. I live in NW Florida where it gets very hot in the summer. Pitch began showing up as soon as summer hit. In all the years I’ve had a deck and have had boards replaced, etc., I have never had this happen. What is the best way to remove the pitch and is there any way to do it without harming the stain. Also, should I wait until cooler weather. Thanks!
IMG_6240
Beckie Campbell
Beckie Campbell
Fun, fun, lol Thanks Scott!
Pat
Pat
I plan on applying the deck stripper with a brush to better control the application. I recall reading that certain types of brushes are not recommended for the application of caustic strippers. I have ordered RAD stripper, booster and brightener.
Why is a water based acrylic sealer harder to remove and re-apply vs an oil based semi transparent or transparent? I thought a water based would be easier to simply pressure wash off every year and then re apply. I’m looking for the least maintenance possible. My deck wraps around my pool, so the least amount of stripping and sanding possible is what I’m looking for to reduce contaminants. And getting on my hands and knees to strip every thing every year is not my cup of tea.
When you say “filming”, what do you mean? And in my case, with all these spots and blotches, do you think I can just take it up with my pressure washer before applying a new sealer, or do I really need to strip? If so, what stripper for a water based clear sealer?
Martha
Martha
We just stained our deck with TWP 1500 series and it is blotchy. Some areas look dry and some not. We applied with a large deck brush and followuped with back brushing. The first coat seemed to look dry before we began a second coat. It was longer than the recommended 10 to 60 minutes when we applied the second coat as we wanted to get a first coat on. It has been 24 hrs and it is tacky. Will it eventually dry? I tried wiping with a rag of mineral spirits but it made it a mess, pulling the stain off like a peeling sunburn.
This is a new deck. We waited a year and it was cleaned twice and had minimal 80 grit sanding 2 months prior to staining. I thought I carefully read your instructions when applying. I think one coat would have been sufficient as it seemed to quickly dry. It is very hard to judge from the instructions what the stain should look like when applying to judge what it should look like. I saw that one is supposed to wipe off any pooled areas but perhaps after 10 minutes the whole board should be wiped off? Personally I am not sure I would recommend this product as I don’t think the results are acceptable for ease of use. One coat would have yielded an acceptable outcome.
Now what? Will it dry or will it continue to be sticky and what do I do so we can use our deck?
Kathy
Kathy
How can I remove peeling RESTORE Deck stain ? The type that had law suits because it peeled. Thank you.
Jodi
Jodi
I have a large deck that is painted with a solid color stain (previous owners didn’t take care of this house). You can see there are two colors going on here. What do you recommend for removing absolutely all color? There are also a lot of areas with wood rot that need to be replaced. I want to get our deck back to a beautiful brown wood stained color.
Konni Barich
Konni Barich
I have a large deck built with treated wood. It is partially stained with a stain that was too red. I want to remove this stain and apply a different stain, one with more brown tones. How can I prep the whole deck (stained and pressure treated) so it takes the stain equally?
Konni
Konni
Hopefully you can see this picture
MARJORIE C WOOTEN
MARJORIE C WOOTEN
Age of porch with bloody dog footprints in recent comment – 25 years
MARJORIE C WOOTEN
MARJORIE C WOOTEN
Removal of dog blood from porch,several bloody dog footprints from an injury; porch never been stained or painted, advise removal of the blood,
Yvonne
Yvonne
Good Evening, I have a 20-year-old Cedar deck that I need to re-stain as so as possible. I believe after reading so many posts I should try the Restore A Deck. I’ve been trying to see if it kills grass and flowers. Any advice will be greatly appreciated.
Rich J.
Rich J.
it’s great you’re providing this resource! The deck I am working on is a hardwood deck that has been stained with an oil semi transparent stain every year for the last 15 years. Some of the decking was black before I started this project. So far, I have used a stain remover, followed by a wood brightener. I have not achieved my desired appearance yet. Can you please provide advice on how to proceed? I have attached photos.
Rich J.
Rich J.
Just following up to say that it’s looking much better. I used the floor buffer with 60-grit mesh sandpaper and a scrubbing pad as backer on the entire deck which really helped to bring back the wood grain appearance I’m looking for. Is it ready for stain, or should I do something else before that? The look is a little inconsistent, but the stain will probably blend everything and make the inconsistency disappear.
Kathy R
Kathy R
I had a new deck installed 3 years ago. I treated all the wood with Penofin (clear) blue label at that time. It, of course (now reading your reviews), turned to a dark gray. I used a product called Sun Frog Deck Cleaner to prep the deck for re-treatment. I was unhappy with the Penofin because water seemed to just soak into my deck and I live in Oregon and we have a lot of rain. I then saw that Penofin made a product that was a Stain and Sealer so decided I would try that. They didn’t make it in clear, so I chose the Cedar finish (it is a cedar deck). I should have stopped immediately, but with the rainy season fast approaching, I figured I just needed to get something on the wood. Now, however, I just can’t stand how dark it has made my deck. I need your advice – I have thought about just completing the deck in this Penofin so that when I attempt to strip it next year at least it will have a similar look everywhere. That is, unless there is a product that can completely remove all this freshly applied Penofin. The staining is about 1/3 completed. So, is there a product that will completely remove this fresh stain? Please tell me all the products I should use (it sounds like a brightener is another important step, that I have never used). The TWP 100 series is rated the best on your site so I will use that next time (should I get clear or cedar to get the look that you have on your banner above?). Thank you so much for your help!!
C T
C T
Hi Scott. We stripped and brightened our cedar deck yesterday, and today found we missed removing some of the stain in part of the deck. The stain is TWP 100 rustic and looked almost new in that area since it was in a covered area. It was very difficult to remove compared to the rest of the deck but we missed it last night when the deck was wet. Since we plan to use the same stain again will it be a problem? I was thinking of spot stripping that area but spot stripping does not seem recommended due to leaving uneven results after staining. Would spot sanding be better? Attached are pictures of the uncovered area and the problem area.
BTW the RAD stripper worked awesome. We had sanded the deck before and this works so much easier, We also love the TWP stain and this forum.
Sandra Kelly
Sandra Kelly
I had a contractor re-stain my deck and it is very sticky three weeks later and every bit of Lindt and dust is just stuck to it there is also footprints on it
Max
Max
Excuse me…I used the same, albeit poor, stripper – Valspar
Max
Max
Stripped stain off IPE deck. Decking to the right was done 2 weeks before the decking to the left. Used the same, albeit poor, stain – Valspar. Do I need to sand the decking on the left? Will exposure allow it to eventually blend?
Lisa
Lisa
I spilled pool chlorine on my pressure treated deck. How can I remove the stain?
TomL
TomL
Hello. I am getting ready to tackle our 16′ x 14′ pool deck. My plan was to strip, brighten, sand, and stain the top railing and deck boards and leave the sides and balusters alone since they are in good shape. Can this be stripped off with stripper and a power washer or do I need to sand it off?
TomL
TomL
I was planning on using the Defy stain stripper as I can get it locally. Is there anything special I should do with it to make getting this stain off easier?
TomL
TomL
Would the RAD kit remove more stain or make the process easier or are they both the same in your experience?
TomL
TomL
If I was to stain with a semi-solid, is all the prep work (strip, brighten, sand) still required? What if I was to stain with a solid stain? This is a pool deck, and I definitely don’t want to be re-doing the deck every couple of years because of the extra care needed to keep everything away from the pool itself.
TomL
TomL
If the existing stain is water-based, can I cover the intact stain that is not peeling with an oil-based solid stain?
TomL
TomL
For power sanding any remaining stain off, what is best to use? A 5″ random orbital sander, a 1/4 sheet sander, belt sander, etc?
TomL
TomL
Thanks. And if that is not enough?
TomL
TomL
After stripping, does it matter whether I brighten first and then sand with 60-80 grit or is it best to sand and then brighten?
TomL
TomL
Thanks. I finished stripping the stain with stripper and pressure washer. I do have some lap marks from the pressure washer as some of the stain was more difficult to get off than in other areas. I do plan to sand the entire deck with 60-80 grit. Will the sanding remove the lap marks? If not, what would you recommend?
TomL
TomL
Thanks. I will try 60 grit first and if that does not work will go to 40 grit.
TomL
TomL
Reply to  TomL
I finished the sanding and brightening on Saturday. It rained today, so I need to wait a couple days for the wood to dry. I was hoping to get the deck finished before the trees around it started dropping little flowers, but they have started to do so. I can wait a few days to see if that will end, but then I think that the pollen will start up.
So, what to do? If I do not stain in the next 1-2 weeks, will the deck be ok with no stain on it over the summer? If I wait until the fall, will I need to clean with a deck cleaner, sand, and brighten all over again?
Ted Marsters
Ted Marsters
I am about to address a significant stain application problem on my western red cedar siding and need advice. Can the info you provide on decking be applied to siding? Can I ask questions about siding on your website? If not, can you suggest an alternative source for help on siding? Thank you. Ted
Anthony654
Anthony654
Could use some advice on a 25-year-old deck. Treated twice w/ SW stain remover & revive but it didn’t get all the old stain off. Plan was to sand deck to remove remaining stain & smooth surface since it’s in rough shape. But I’ve since learned that sanding pressure-treated wood is hazardous, so now I’m stuck. Just trying to get a couple more years out of the deck before i replace w/ a composite. Per HOA rules, will use semi-transparent stain.
Thinking there are 3 options: 1) sand it (which i think would do the job but is dangerous healthwise); 2) buy a more hardcore stripper (not sure what that would be); 3) spot strip w/ leftover SW stripper, stain, and live with the spotty result. Any insight would be appreciated.
Anthony654
Anthony654
Thanks. Which would look worse: staining over the remaining stain or staining over spot sanding? Leaning toward not sanding the whole deck due to the PT wood, so aiming for “good enough.”
Anthony654
Anthony654
Deck assistance
BRENDA PADDOCK
BRENDA PADDOCK
DECKING HAS BEEN STAINED AND OILED ABOUT 6 ONTHS AGO …BUT WE DONT LIKE IT AND WOULD PREFER TO PAINT …ANT ADVICE ON WHAT WE SHOUÑD DO?
K. Merritt
K. Merritt
I applied 2 gallons of Maximum 1 Gal. Honey Gold Exterior Stain and Sealant in One Low VOC to the interior of my screened in porch. I need more and can’t get any unless I drive 2 hours to get it. Since it has recently been applied, will using deck stripper work? Or will it have to be sanded?
K. Merritt
K. Merritt
Here’s my porch with the Olympic Max Honey Gold exterior stain and sealant.
Rachelle Couture
Rachelle Couture
Kitchen cupboards were painted and then a layer of stain was added to gloss it. how to remove it all so I can repaint.
Karen Brown
Karen Brown
How long after stripping the deck can we stain it
Brad Motteler
Brad Motteler
I’m using TWP 1500 semi transparent pecan on the deck in the attached pics. I’ve power washed it, should I use a stripper and brightener or just sand before staining?
Brad Motteler
Brad Motteler
After I sand do I need to power wash again and use a Brightener or can I just clean the dust off and stain ?
Brad Motteler
Brad Motteler
Jenny
Jenny
Will this product remove Behr oil-latex redwood stain?
Linda Kay Whitehead
Linda Kay Whitehead
I purchased a stain from Lowes and was told it was water base, transparent, it was Warm Puddy. the color was a light color with a brown tone. Told that the natural wood grain would show. It was Valspar produce. They mixed the stain, handed it off to my workers and they off to stain the deck. When I saw what was done I was in shock. It looks like white paint. Not at all transparent just looks like white paint. The house is built all green so now I have no idea what to do to get it back to the natural wood. It changed the whole look of the house. It looks like plasic white paint. I cried for two days. Please give me advise.
Greg Pierce
Greg Pierce
I prepared my deck and decided on a light red clear stain.My deck has a step down and buts up to my pool deck. I used a brush to trim out by the pool edge and step up. When I used a roller on the deck itself, I got the color I wanted, but the trim area is much darker. What can I use on the trim area to achieve the lighter shade on the deck?
Frank
Frank
We had a deck installed…waited a year..sealed it clear…now it is slippery and shoes or feet carry slipperiness into house…how do I fix that
Rob
Rob
Been sanding off old behr deck stain which is junk Front is done but there are traces here and there that couldn’t get with sander because of grain grooves such. It’s dulled out nice. Will defy deck cleaner help it out before I apply their stain. Just impossible to remove every speck of old stain. Thanks!!
Hattie Brown
Hattie Brown
Someone attempted to stain my new deck he made an awful mess and would not fit. How an I get this off?
Mary C
Mary C
how do I get the hard to scrape stain off the wood, so many layers remain after 30 years?
Mary C
Mary C
there are so many layers of stain that i can actually peal the parts that are lifting, i want the partio to look natural, this is at leasr 30 years of staining,,,,,, the rails were never stained and are looking great.. I’ve gotten some boards down to the bare wood, im having some problems with some others
Stacy
Stacy
photo 4 of 4
Stacy
Stacy
photos 1-3 of 4
Stacy
Stacy
“One of the biggest mistakes DIY homeowners make in cleaning and preparing a wood deck for stain is not removing all remnants of old deck stain.”
Boy, did I find out how true this is! I spent two weekends doing the following prep work: 1) applied Defy Stain Stripper, 2) scrubbed entire deck with stiff bristled brushes, 3) pressure washed, 4) sanded the deck with 80 grit paper and 5) applied brightener.
Even after all these steps, some old stain remained and since I was staining with a darker color, I didn’t think it would be a problem. Just stained it yesterday and you can see EVERY SINGLE spot where the old stain wasn’t removed. I’m just sick about it. When you say “ALL” remnants you aren’t kidding!
So, two questions:
1) Do I have to re-strip and start all over to fix this? Can I do that right away, when I just stained it 24 hours ago?
2) If the answer to #1 is yes, how in the world do I get all of that stubborn old stain off? (especially between the boards)
I’ve included some photos.The old stain is a TWP 101, color Cedartone Natural (the orange you see) and the new stain is C2 Guard, color Cordova.
Stacy
Stacy
Thank you for your quick reply! I added the pics in separate posts.
Iman
Iman
Bought some decking which already had a colour to it. Added some clear varnish to protect it, but made ended up making it a lot darker than I liked. So I bought some to seal decking stripper to remove the stain so I can start anew and paint it an even colour. However the stripper hasn’t done a good job of removing all the varnish and it’s gone patchy. What do you advise I do? Really struggling here 🙁
Look forward to your reply!
Many thanks!
Charlie
Charlie
I recently I applied Thompson Waterseal penetrating timber oil to my deck. The first can was fine. The second can had a yellow tinted to it. When I contacted the store it appears the can was missed labeled. How do I remove the wrong oil from the deck before putting on the correct oil or can I just go over it with the color I originally picked.
about 3 weeks ago I applied Storm Wood Stripper to my garage door and hanger done a thing with it since. My question is, is the stain stripper still dangerous? My neighbor showed me how to remove paint on my front door using a heat gun and that was super easy. Wishing I didn’t put the chemicals on the garage door. Any advice appreciated have a good day.
Reva Dawdy-Goodall
Reva Dawdy-Goodall
What can I use to remove deck stain splatters from vinyl siding ?! Thx
steve
steve
I live in MN and I have a sixteen-year-old deck that needs refinishing. I’ve never done this type of work before so I need to get educated.
1. What do I use to remove the existing finish?
2. What do I need to do to prep the wood to accept new stain?
3. What type of new stain should I apply?
Rachel
Rachel
Hi, we had new decking 2 years ago and I love the colour of what it is when first laid. It faded and we put a natural oak stain, hoping this was as close to new as possible, I didn’t like it, so this year it needs to be done again, and I want to get it back to as close to new decking as possible then cost with maybe an oil or something to keep it like that. Please can you help, thank you
Rachel
Rachel
Ok, sorry is the strip and brighten a complete product or figure of speech ? Lol sorry, if a product which is best ? Thank you very much
James
James
I have an old deck from the 80’s with redwood and green treat mix due to old rotten replaced boards, is there a semi transparent stain someone might be familiar with that can blend green treated pine and redwood together in a close match?
Ive done solids in the past, and after renting a sander, would like to stay transparent if I could, or semi transparent. Thanks for any help.
Dawn
Dawn
I have a brand new cedar deck that we have ruined because applied Cabot semi gloss stain with pad/roller and didn’t use brush after. It applied the stain way too thick and looks horrible. I used a brush on the stairs and they turned out beautiful. Is there anyway to strip off and start all over?
Dawn
Dawn
Hope this helps
Eric
Eric
Good morning,
When we purchased our home last year the previous owner used a solid latex stain on the deck floor boards and a semi transparent on the hand rails and spindles.
I would like to have the solid removed off the deck floor boards but wasn’t sure if this was even an option. Would you try and chemically strip it first with the Restore A Deck stripper and then mechanically sand?
I have attached pictures of the deck as well as a photo of the solid deck stain that was used on the floor boards. Thanks
Maria Beasley
Maria Beasley
what stripper will remove semi solid stain from deck?
Bob in Bend
Bob in Bend
Hi. I had two coats of a semi transparent gray water based stain on deck. It’s about 3 years old, deck is about 3.75 years old. Power washed, cleaned and brightened. Realized too much stain remained. Applied stripper per directions, yet still a fair amount remains bears edges and on rails. See pic. I have restore a deck gray semi stain I plan to use, which by test seems about the same color. What else should I do, beyond drying, before applying? Thank you
Frank Dudinyak
Frank Dudinyak
Hey I just had a couple questions and concerns about stripping and re staining a deck. My girlfriend and I want to stain our deck a different stain, probably a much lighter stain and not nearly as dark as this stain. I have been reading up on this for a week or two now and have a game plan of what i am going to do but just not sure what i am going to do if the wood does not look like it did before she originally stained it . I was first going to pressure wash it to get a lot of surface dirt off of it. After this, get a stripper like the restore-a-deck brand that you talk about in other threads. Do that 1 or 2 times to remove as much of the old stain as possible and pressure wash it after i let it soak in for 15-30 minutes, or whatever the directions are. After this i was going to sand it to ensure all of the old stain is off and then use the restore-a-deck brightener product after sanding. My concern is, what if the wood is still dark after going through all of these steps? We don’t really want to put a darker stain on it again but I’m guessing this would be are only option. I’m not sure what type of wood it is but it is pressure treated wood and my girlfriend believes she originally put a semi-transparent teak stain on it when the deck was built 5 years ago. The first picture i posted is what the deck looked like before the original stain was put down and the other 2 photos are what it currently looks like. The little drops in the 2 photos of the stained deck are just a couple of rain drops if you are wondering. Wanted to get a couple of photos to post on here before it started to rain today lol.
PaulyP_in_NC
PaulyP_in_NC
Our deck is less than a year old…made with Southern Yellow Pine #1 KDAT, pressure treated…good stuff, ready to stain immediately. We stained it using top of the line semi transparent stain…it looks horrible, not because of the stain/color or the wood…it was the way it was applied…blotchy, uneven, total amateurish…its been stained now thru a very mild winter for about 6 months…should I just restain over the applied or power sand it off and start clean? Its big, about 750 sq/ft
Pat
Pat
Can the old deck boards be removed, turned upside down, reinstalled and stained again on top.
Sue
Sue
Hi, I have just applied 2 coats of Feast Watson Jarrah traditional decking oil to my treated pine deck and hate the colour…far too orange when the sun hits it. Any tips to remove it? Would rather not sand as it is a large deck. I am hoping to stain the deck once the oil’s removed.
Brenda
Brenda
I bought a house a year ago with a deck that is partially covered, with an uncovered catwalk that was moldy and in need of replacement. The new boards and new railing have been put in and the deck is now ready to be stripped/cleaned/stained. But I can’t tell if the old stain can be removed with a stain stripper, or if its more like a paint and needs to be sanded off. I plan on using a transparent sealer over the entire deck to keep a natural look, so I want the old wood to look good natural instead of needing to cover it up with another dark stain. Any advice? I’m new to all this and I’m hoping to be able to do it myself.
Brenda
Brenda
Thanks! Should I rent a drum sander? The paint is also on posts. What type of sander would you recommend for those small spaces?
After reading through some posts, it sounds like you don’t recommend a transparent sealer. I was thinking it was more low maintenance. Sounds like it needs to be reapplied every year- is that true? Can it just be re-applied over the previous sealer? If that is the case, it might be easier than having to sand the entire deck every couple of years. I’m not sure yet what I’ll do.
Brenda
Brenda
Sorry if this is posted twice but I think my reply didn’t go through.
Do you recommend a drum sander? And what would you recommend for the posts that need to be sanded too?
Harley
Harley
I am using a deck paint (not stain) matched with the same color paint on an old deck that I am redoing. What I need to know is how much old paint must I remove before I put the new paint down? I think the other paint on there was latex and I have an oil base paint. I know that I have sanded down to where it is smooth but there is still old paint showing, will that matter if I just paint over it?
Harley
Harley
Thank you very much for the info 👍
Pete Co
Pete Co
Title: Trying to Fix Mistake of Changing to Water Based Stain
Stained my deck 4 years ago with TWP 1500 Dark Oak. It was beautiful. It needed a recoat. The local pressure washer and deck supply guy recommended I go with a water based stain because all stains with VOC, like TWP, were going to be banned soon. So I got the closest color stain and stripped a small landing deck as a trial. Stripping the TWP was a major job on the 80 sf landing deck and I was not looking forward to that on the big deck (1000 sf).
When I started staining it applied and looked terrible compared to the TWP. After staining 3 boards I stopped to figure out what to do. I decided then to stay with the TWP 1500. That was a couple weeks ago. I still have the 3 boards I stained with the water based stain. I tried a sodium hydroxide stripper but it didn’t work to get the water based stain off. What do I need to use to strip the water based stain before applying the TWP 1500.
Pete Co
Pete Co
The stain is a house brand. I do not know who makes it. This is the only description on the bucket that might give a sense of the type of stain it is: “With other Deck and Fence Sealing products, you have to wait for the surface to dry and worry about rain showers. Our stain can be applied to a damp wood surface so you can complete the job the same day. This fast drying wood deck and fence sealer can be brushed, rolled, or sprayed with an airless sprayer.”
Attached are pictures.
peteco
It may be easier to just replace the boards.
peteco
It is a house brands. This is the only info that might tell what it is. They told me it is water based. This is on the bucket: “With other Deck and Fence Sealing products, you have to wait for the surface to dry and worry about rain showers. Our stain can be applied to a damp wood surface so you can complete the job the same day. This fast drying wood deck and fence sealer can be brushed, rolled, or sprayed with an airless sprayer. “
nhernandez
nhernandez
My deck was built exactly 14 months ago and I did not apply sealer or anything else. The pressure treated wood is still solid and it still looks good . I did pressure wash it with a cleaner about 2wks ago. Now I want to use a semi-transparent stain. Do I need to seal it separately? Or will a sealer/stain combo be enough?? Thanks.
We have a cedar deck that is one year old. Clear sealer was applied when installed, and then another coat of sealer was applied but not immediately after first coat of sealer. Apparently the deck was not cleaned between coats of sealer. Now the deck has mold and large gray areas with obvious peeling sealer. We will need to strip the deck before applying new stain. What are the recommendations for stripper and stain for a cedar deck? Will we need to use a brighter before applying stain, even tho deck is only one year old. Thanks
Dan
Dan
dark stripes have appeared where stripping overlapped. How are these removed?
Trish
Trish
I bought my house two years ago and the deck is at a point where it needs to be restained. I found a partially used can of Flood CWF-UV Penetrating Wood Finish Cedar in the garage which is what I assume the prior owner used. Will this need to be sanded or will I be able to use a stripper to remove the existing stain?
RJH
RJH
I’ve read through some of the questions in this article and understand that you recommend sanding to remove a solid stain (Behr solid wood stain applied 2007). There are areas on my deck that won’t be accessible to a belt or orbital sander. Is it possible to sand blast these areas to remove the old stain?
can u power sand at 80 grit paper a Cedar deck?
We used Pittsburgh Wood concentrate resurfacer approximately 5 years ago on wooden deck and it is now in horrendous shape. Peeling terribly and looks awful. What is best to use to make the deck able to re-stain?
Allen
Allen
I power washed my deck and then sanded with 80 grit, but in the photo it looks like I haven’t gotten it all. The previous owner used Olympic stain, I plan on using the same stuff. At this point, does it look bare enough to just put down the new stain? Or do I keep sanding? It’s pain to get up, and it sounds like stripper won’t work.
Allen
Allen
Thank you. I am considering using Restore a deck stain stripper, would you recommend this to remove the remaining Olympic stain? I also plan to follow it up with a brightener.
Kari Collins
Kari Collins
We have a deck that was painted and part of it has some residual paint stuck on (many years old) and we have not been able to scrape it off or get it off with a power washer. We bought the house this way. I don’t know if the other portion of the deck was stained or not, but it does not bead up, as a matter of fact it gets mildew and slick. So, do I need to use the stripper or the cleaner followed by the brightener? And, what sort of sander will work to get the leftover bits of paint up?
Can I power sand my decking even though it is ridged?
I have recently moved into a house and want to strip and redo the decking. I have no idea what they have used to treat the wood, any ideas from these photos?
I have bought some Ronseal Paint Stripper – will that do the job?
Many thanks
Reply to  Tom
Photo 1
Reply to  Tom
Photo 2
Please let me know if you require any more
Thanks, can you still power sand when the wood is grooved?
Thanks, will power sand be effective even though the wood has lots of grooves?
Thanks for the advice – at least I know not to waste my time trying to remove!
Apologies for all the posts, they were not showing before.
Jesse
Jesse
Just bought our house. Some of the deck is being entirely resurfaced with new wood. Some areas are decent for a few more years. One area had a solid stain on it that looks to be very old. Most of it came off with pressure washing and scrubbing using a deck cleaner. Some areas still need scrubbed some more. See attached photo. I have two issues:
1. We bought a stain/sealer (Olympic Maximum Pearl Gray) and tested it on one support post. We do not like the outcome. I will be using Cabot Australian Timber Oil instead. How can I get this post back to clean again? It was just applied last night and I plan to TRY to strip this tonight. Since this is freshly applied, would a deck stripper get this off pretty easily still?
2. Some areas that did not completely clean from the old solid stain will be scrubbed and pressure washed again. I’m still not sure it will all ever come clean since it’s so old and deeply set in the wood. Since a lot of the stuff that did not come off is up high in the air, I’d love to find a chemical that will remove this so that I don’t have to scrub high stuff dangerously. Any ideas how I could possibly avoid significant sanding efforts?
Any help is appreciated and thanks for all the previous help this site has given me over time. It has been extremely helpful for us!
Jesse
Jesse
UGH….I had a feeling. Thanks for the help!
Theresa kelly
Theresa kelly
Just had my deck stained on Monday. The guy had taped something to a post and when he pulled it off, yes, it peeled. I can see the post underneath still has the previous stain…actually a little shiny. He was supposed to prep and stain. I could literally peel the whole post. He used Sherwin Williams superdeck. semi solid. What should I do?
Justin
Justin
When you say power sand what grit do you recommend? I’ve been trying to sand mine with an orbital. 60 grit is taking forever. Belt sander isnt very efficient either.
G.Davis
G.Davis
What is the best solution to use to remove Olympic Rescue It from a deck?
Laurie Allen
Laurie Allen
My deck is about 8 years old pressure treated wood quite large last summer, my contractor cleaned it with Pittsburgh ultra deck cleaner and restained it with Cabot semi-solid redwood stain. now everything is peeling what do we have to do to fix this? I live in Central ohio.Thanks so much for advice.
Laurie Allen
Laurie Allen
Following up had to wait for rain to stop. Two photos today.
Laurie Allen
Laurie Allen
Ok do after power sanding do we have to do anything else to prep?
Bruno
Bruno
I have just stained my deck with decking oil, and I hate the colour!! Can I remove it
It was thompson timber oil
Bruno
Bruno
Thompson timber oil
Bruno
Bruno
Reply to  Bruno
See pic
Paul
Paul
I am planning on stripping a horrible application of solid arborcoat in the spring as well as replacing some rotting boards. For the boards that are still in good shape – can I strip the arborcoat off and then apply a semi transparent stain (Flood Series) or is it hard to apply stain after a solid coat has been stripped?
Thanks for the advice!
Lee Cumming
Lee Cumming
I have just stained my deck with decking oil, and I hate the colour!! Can I remove it??
Brian Bishop
Brian Bishop
Bought our house a year ago and the deck stain is wearing out. I assume I have to strip, brighten and then stain, but wanted to double-check. You can see in the pictures that parts of the wood are grayed, while some still appear to have stain on them. In fact, the first picture shows where I had some tape on the deck, and when I pulled it up the stain came off and gray was underneath. I found a couple of Behr products in the shed (Semi-transparent weather proofing all-in-one wood stain and sealer, and transparent weather proofing all-in-one wood finisher), so I assume these are what the previous owner used on the deck. Do I need to strip, brighten and stain, or can I use wood cleaner, brightener and stain? Or, just pressure wash and stain?
Also, how many days of dry weather should there be between prepping the deck and then staining? Is 2 enough?
Thanks in advance!
Brian Bishop
Brian Bishop
One more question: The deck goes right up against the house. If I use Defy’s stripper do I need to put a barrier up to protect the house paint? The directions say to protect surrounding areas, but I assume that means other stained items you don’t want stripped. I just want to be sure. The house was just painted a few months ago with Sherwin Williams SuperPaint.
Thanks again, in advance!
Shanna
Shanna
I am so frustrated.
We worked on our porch floor for weeks stripping it with paint stippers, scraping off layers of paint and sanding to get rid of all the stain.
I put the Pittsburgh clear ultra deck sealer on and
It turned it orange, I am livid, the endless hours and money we have spent and this is the result we get.
Sanding will not take the orange color off.
Any suggestions other than freaking out on the company
Rick Smith
Rick Smith
I had a product called Deck Restore applied about 3 years ago. It is supposed to be put down in two coats .,but was not .Needless to say it is a peeling mess. I started stripping it using a power washer ,but there are sections that don’t want to come up . Is there anything I can treat it with to strip it easier.
Bob Parry
Bob Parry
I have a deck that was sealed two years ago…Pittsburgh acrylic oil Clear….but it had an orange tint to it. I wanted to remove and first used Wolman DeckBrite. This did not do a good job so we bought a deck stripper. The question is, do we need to apply another Wood Cleaner and Coating after the stripper or are we good? Right now most of the wood looks brand new though it is over 15 years old.
Heather Schmidt
Heather Schmidt
We purchased our home a year ago. It has a 25 year old deck that had a solid stain on it. We replaced several old boards. We sanded it all which took days and then used a deck cleaner. When we were washing off the deck cleaner we noticed the old stain was still peeling in some areas. Do we need to strip it as well or can we just use a brightener and then apply a solid stain? It was a reddish/brown and we are hoping to make it grey. We have invested 40+ hours (1,000 sq. ft. deck) so want to do it right the first time. Thanks for any advice!
Heather Schmidt
Heather Schmidt
what do you think is easier, sand or strip? If I strip do I need to sand again? I used a large floor sander on the floor and hand held sander on the rails. Most of it is down to the bare wood but some areas still have small streaks of stain on the floor.
cathys
cathys
I have had an accident with this product and want to remove it. Any advice on a stripping product please?
Adrian
Adrian
While sanding my deck I discovered 3 boards with damage. Right now the deck is solid 20′ boards. Should I replace the whole length or just sections of the 3 boards? Also once sanded, what is the best oil based stain that has the least amount of color in it? Thanks!
Sarah
Sarah
Help! We have a pressure treated deck that’s a few years old and my dear husband took it upon himself to stain it. I ABSOLUTELY HATE the orange looking stain. I just wanted it to remain the same colour and be weather guarded. Can this be stripped off right away? What do you suggest….aside from divorce?? Please help😡
Daniel
Daniel
Hello, I have a deck with an unknown prior coating. Not sure when prior homeowner last stained.
My plan is too strip, brighten and stain with Flood Pro Series Solid Cedar.
Do you think it will require sanding as well?
Here are some photos that may help.
Dan
Adrian
Adrian
Two years ago I put “Behr Premium semi transparent weatherproofing” on my deck. It looked terribly right from the beginning. Two years later it looks really bad. This is an acrylic stain. What can I use to strip my deck? I would prefer to use a product that can be put on, then hosed off with a pressure washer. Is there such a product? Thanks.
Adrian
Adrian
Thanks for your help. I accept that it will have to be hand sanded. What can I put on it afterwards so that I never have to deal with this again? I want to protect the deck, but I don’t need any additional color (ie stain) or anything – just protection from sun and rain. What would you recommend? Is Thompson’s water seal a good choice?
Jen
Jen
Reply to  Adrian
Crazy I have the SAME exact issue. How to get it off?! I have a painter who says he can use a Diamabrush to get it off.
Good luck! UGH 🙁
M. J.
M. J.
Should deck be dry before applying deck stripper?
741
