Cedar Deck: Stain or Not? 5/5 (1)
Best Stain for a Cedar Deck
  • Use a penetrating semi-transparent stain — never a film-forming sealer or solid stain
  • Top picks: TWP 1500 Series, Armstrong Clark, Restore-A-Deck
  • Wait 3+ months before staining new smooth cedar
  • Clean and brighten the wood before every application
  • Choose a cedar or natural tone to preserve the wood's natural color
Cedar deck: stain or not?
Cedar deck stain should always be a penetrating semi-transparent formula — not a film-forming sealer, solid stain, or paint. Cedar is a dense softwood that naturally resists decay, but it is highly susceptible to UV graying and color fading without protection. A penetrating semi-transparent stain soaks into the wood fibers rather than sitting on top, which prevents peeling and allows easy reapplication without stripping. The tint in the stain blocks UV rays while keeping cedar’s natural grain visible. Top-performing products on cedar include TWP 1500 Series, Armstrong Clark Wood Stain, and Restore-A-Deck — all available in cedar and natural tones.
New Cedar Deck vs. Weathered Cedar — What Changes
New smooth cedar should weather for at least 3 months before you apply any stain. Fresh-milled cedar often has mill glaze on the surface that blocks stain absorption. After weathering, clean the wood with a sodium percarbonate deck cleaner, apply a wood brightener while the wood is still wet, then stain once dry. Skipping prep on new cedar is the most common reason stain fails early.
Weathered cedar that has already gone gray can be restored before staining. A deck cleaner followed by a wood brightener will open the wood pores and bring the surface back to a state where stain can penetrate evenly. Do not stain over gray, uncleaned cedar — the stain will not absorb properly and the result will be blotchy.
Oil-Based vs. Water-Based Stain for Cedar
Oil-based semi-transparent stains are generally the better choice for new cedar decks. Cedar is denser than most decking lumber and oil-based formulas are thinner in viscosity, which allows them to penetrate deeper into tight wood fibers. Water-based stains can perform well on older, more porous cedar that has been properly cleaned and brightened. Either way, the stain must penetrate the wood — any product that sits on the surface will eventually peel. For a detailed comparison, see our full guide on oil vs. water-based deck stain.
Best Colors for Cedar Deck Stain
Cedar deck stain colors work best when they complement the wood’s natural warm tones rather than cover them. The most popular choices on cedar are cedar tone, natural, and redwood. A lighter cedar or natural tone preserves more of the wood’s original color and grain. A darker cedar or redwood tone provides stronger UV protection because more pigment means more UV-blocking capacity — which extends the time between reapplications. Avoid gray tones on cedar unless you are going for a specific aesthetic, as gray stains tend to look unnatural against cedar’s warm undertones.
Cedar Deck Stain — Frequently Asked Questions
What is the best stain for a cedar deck?
The best stain for a cedar deck is a penetrating semi-transparent stain with UV protection. Top-performing options on cedar include TWP 1500 Series, Armstrong Clark Wood Stain, and Restore-A-Deck Wood Stain. All three penetrate cedar’s wood fibers rather than forming a surface film, which prevents peeling and allows easy reapplication. Choose a cedar or natural tone to complement the wood’s color rather than masking it.
Should I use oil-based or water-based stain on my cedar deck?
Oil-based semi-transparent stains generally work better on new cedar because cedar is a dense softwood and oil-based formulas are thinner in viscosity, allowing deeper penetration. Water-based stains can perform well on older, more porous cedar that has been properly cleaned and brightened. Either way, the stain must penetrate the wood rather than sit on top of it.
How long should I wait before staining a new cedar deck?
New smooth cedar should weather for at least 3 months before staining. Fresh cedar often has mill glaze on the surface that prevents stain absorption. After weathering, clean the wood with a sodium percarbonate deck cleaner and apply a wood brightener before staining. Rough-sawn cedar is the exception — it can typically be stained sooner because it has no mill glaze.
How often does a cedar deck need to be restained?
A cedar deck stained with a quality penetrating semi-transparent stain typically needs reapplication every 2 to 3 years on horizontal surfaces. Vertical surfaces such as railings can go 3 to 4 years between coats. Cedar’s natural oils can slow stain absorption over time, so cleaning and brightening before each reapplication is essential for even penetration.
Will cedar turn gray if I don’t stain it?
Yes. Unprotected cedar will gray within one season of sun exposure. UV rays break down the wood’s surface fibers and natural oils, causing the characteristic silver-gray color. A semi-transparent stain with UV inhibitors stops this process and preserves cedar’s natural warm tone. Once cedar has gone gray, it can be restored with a deck cleaner and brightener before staining, but prevention is far easier than correction.
Can I use a clear sealer instead of a stain on cedar?
A clear sealer alone is not recommended for cedar decks. Clear sealers provide moisture protection but offer little to no UV protection, meaning the cedar will still gray from sun exposure. A semi-transparent stain includes both UV inhibitors and pigment that block the sun while allowing the grain to show through. If you want a near-natural look, choose a lightly tinted natural or cedar-tone semi-transparent stain rather than a clear product.
More information about staining cedar decks
0 Comments
