Deck Stain to Prevent Mildew? 5/5 (1)
Best deck stain to prevent mildew?
The best type of deck stain to prevent mildew is a water-based deck stain. The best water-based deck stain to prevent mildew is Restore-A-Deck. Some oil-based deck stains have added mildewcide, but not all. Check the label of the brand and color you want to make sure it is appropriate for a wetter climate. The best oil-based deck stains with mildewcide are TWP and Armstrong Clark semi-transparent penetrating deck stains. A deck with existing mildew must be thoroughly cleaned before applying new deck stain in a moist environment.
  • Water-based deck stains are the best option for preventing mildew, with Restore-A-Deck being the top recommended product.
  • Not all oil-based deck stains contain mildewcide, so always check the label before buying, especially in wetter climates.
  • The best oil-based options with mildewcide are TWP and Armstrong Clark semi-transparent penetrating deck stains.
  • Always thoroughly clean existing mildew from your deck before applying any new stain in a moist environment.
  • RAD Guard Mildew and Algae Cleaner and Preventer removes black mildew and green algae stains and keeps them away for 1 to 2 years.
  • Homeowners in wet climates should pay close attention to product labels to confirm mildew resistance before purchasing any deck stain.
How to Prevent Mildew on Deck Stains
More information on coping with mildew on decks in a wet climateMildew on deck
0 Comments
