Restore-A-Deck Wood Stain Stripper – The Best Deck Stain Stripper
Powerful, Eco-Friendly Formula for Removing Old Stains & Coatings
Restore-A-Deck Wood Stain Stripper is a biodegradable, powdered concentrate that effectively removes old wood stains, clear sealers, and semi-transparent finishes while eliminating dirt, mold, mildew, and mill glaze. This Step 1 product in the Restore-A-Deck system ensures proper surface preparation before re-staining.
🌱 Eco-Safe Formula – Biodegradable & plant-safe when properly rinsed
💰 Cost-Effective – 1 container makes 5 gallons, costing less than $7 per gallon
🏆 #1 Rated Deck Stain Stripper – Removes most clear, transparent, and semi-transparent stains
🔹 Why Choose Restore-A-Deck Wood Stain Stripper?
✅ Removes Most Oil & Latex-Based Finishes – Strips clear sealers, transparent, semi-transparent, and semi-solid stains.
✅ Powerful Formula for Deep Penetration – Lifts dirt, mildew, and stubborn coatings.
✅ Easy to Mix & Apply – Powdered formula mixes with water to create 5 gallons of solution.
✅ Cost-Effective & Efficient – Covers 500-1,000 sq. ft. per container.
✅ Safe for All Exterior Wood Surfaces – Use on decks, fences, siding, outdoor furniture, pergolas, and more.
✅ Adjustable Strength for Tough Finishes – Mix at maximum strength (3 gallons water per container) for difficult coatings.
📌 Note: Restore-A-Deck Wood Stain Stripper must be followed with Step 2 – Restore-A-Deck Wood Brightener to neutralize the surface and restore wood pH before staining.
🔹 Where to Use Restore-A-Deck Wood Stain Stripper?
✔ Wood Decks & Railings
✔ Fences & Outdoor Furniture
✔ Siding & Log Homes
✔ Pergolas & Playsets
✔ All Exterior Wood Surfaces
📌 Not required for completely new, unstained wood. Use Restore-A-Deck Wood Cleaner instead.
🔹 Surface Preparation & Application
1️⃣ Ensure Proper Temperature: Wood surface should be above 50°F.
2️⃣ Protect Surrounding Areas: Cover plants, shrubs, and nearby surfaces to avoid exposure.
3️⃣ Mix the Solution: 1 container mixed with 5 gallons of water (or 3 gallons for tougher stains).
4️⃣ Apply Using a Pump Sprayer or Pressure Washer Injector: Fully saturate the surface.
5️⃣ Let Sit for 10-20 Minutes: Keep the surface wet to allow penetration.
6️⃣ Scrub or Pressure Wash Off: Rinse thoroughly to remove all residue.
7️⃣ Neutralize with Restore-A-Deck Wood Brightener: Apply Step 2 Brightener immediately after stripping.
📌 Pro Tip: Use a stiff-bristle brush or pressure washer for best results.
✔ Restore & Prepare Your Deck for Staining with Restore-A-Deck Stain Stripper!
✔ Removes old stains, dirt, and mildew from decks & wood surfaces!
✔ Cost-effective & eco-safe – makes 5 gallons for less than $7 per gallon!
✔ Easy to apply – mix, spray, and strip with minimal effort!
🔹 Order Restore-A-Deck Wood Stain Stripper today and get your deck ready for a fresh new stain!
Stain Types Removed
Restore-A-Deck Cleaner Only
i’m about to restore my deck and realize i bought the cleaner instead of the stripper. can i possibly make an exchange?
Hi Paul,
You would have to cover shipping costs both ways (that could cost you $25-35), and we would not be able to ship the Stripper until the Cleaner is returned. It may be easier to order the Stripper and keep the Cleaner for future maintenance, but that is up to you.
BTW, have we given you advice already on your stripping project? If not, you may want to upload some pictures in the comments to ensure you have the correct products for the stripping.
Thanks for getting back.
I don’t see any beading up on the deck so from what I’ve read, the cleaner should probably be fine. I’ll hold on to the added stripper boost and thickening gel I purchased for the next time.
I’ve watched a lot of your videos and why I bought all the products to strip (along with the additives) the brightener and semi-transparent stain. Unfortunately I made the mistake of getting the cleaner and not the stripper.
-Paul
Is your wood previously coated? If so, you need to remove the current stain before switching to a different semi-transparent stain brand or color.
