TWPĀ® 1500 Series Stain ā 5 Gallon
Premium Oil-Based, Semi-Transparent Wood Stain & Preservative
TWPĀ® 1500 Series is a high-performance, EPA-registered wood preservative that enhances and protects exterior wood surfaces while allowing the natural beauty of the wood grain to show through. This low-VOC, oil-based stain is compliant in all 50 states and outperforms the previous TWPĀ® 500 series formula by offering improved penetration, faster drying time, and increased durability.
š¹ Key Benefits of TWPĀ® 1500 Series Stain
ā Preserves Natural Wood Color ā Protects against graying and fading
ā Deep Penetration for Long-Lasting Protection ā Conditions and strengthens wood fibers
ā Water-Repellent ā Reduces warping, cracking, and splitting
ā EPA-Registered Wood Preservative ā Prevents structural damage and wood decay
ā Mildew & Mold Resistant ā Keeps wood fresh and clean
ā Superior UV Absorption ā Prevents sun damage and discoloration
ā Easy Application & Maintenance ā Clean and recoat as needed
ā Low 250 VOC Formula ā Safe for use in all 50 states
š¹ Where to Use TWPĀ® 1500 Series Stain?
ā Wood Decking & Railings
ā Fences & Gates
ā Log Homes & Wood Siding
ā Hardwoods & Softwoods
ā Outdoor Furniture & Gazebos
ā Roofing & Shingles
š Ideal for all above-ground exterior wood applications!
š¹ Why Choose TWPĀ® 1500 Series?
ā
Penetrating Semi-Transparent Formula ā Enhances woodās natural beauty while providing unmatched protection.
ā
Resistant to Water & Freeze Damage ā Prevents water absorption that leads to warping and cracking.
ā
Prevents Mold & Mildew Growth ā Keeps surfaces clean and free from organic staining.
ā
Complies with All VOC Regulations ā Low 250 VOC formula for safe use in all 50 states.
ā
No Peeling or Flaking ā Allows wood to breathe naturally, reducing surface film buildup.
š¹ Application & Coverage
ā Prep the Surface ā Clean and brighten wood before staining for best absorption.
ā Apply with Brush, Roller, or Sprayer ā Work stain into the wood grain.
ā Back-Brush for Even Penetration ā Avoid puddling for a smooth, even finish.
ā Allow Proper Dry Time ā Typically 24-48 hours before foot traffic.
š Coverage: 100-300 sq. ft. per gallon, depending on wood porosity and surface texture.
Technical Specifications ā TWP 1500 Wood Stain
Coverage: 100ā300 sq. ft. per gallon, per coat.
Recommended Coats: 2 Coats (Wet-on-Wet Application). *1 coat for new wood less than 12 months.
Application Temperature: 45°F ā 95°F
Application Methods: Stain Pad, Sprayer, Brush
Dry Time: 4 to 24 Hours
ā Protect & Beautify Your Exterior Wood with TWPĀ® 1500 Series!
š¹ Available in 1-Gallon & 5-Gallon Sizes
š¹ Professional-Grade Stain for Homeowners & Contractors
š¹ Enhance & Preserve Your Investment for Years to Come!
ā Order TWPĀ® 1500 Series Today and Keep Your Wood Looking Its Best!
What is recommended size tip for a graco magnum 257025 sprayer ?
A .013″ or .015″ tip is generally recommended.
