TWP Semi-Solid Pro Series Oil-Based Wood Stain – 1 Gallon
Available in 30 Custom Colors, the TWP® Semi-Solid Pro-Series is formulated to preserve and enhance the beauty of your exterior wood. With superior UV protection and long-lasting performance, this stain ensures your wood looks fresh, vibrant, and protected for years.
- TWP Semi-Solid Pro-Series provides deep penetration and strong water repellency to reduce warping, cracking, and splitting.
- TWP Semi-Solid Pro-Series performs in harsh climates, resisting freeze damage and extreme weather on decks, fences, and log homes.
- TWP Semi-Solid Pro-Series covers about 100-200 sq ft per gallon; apply 1 to 2 coats wet-on-wet with brush, roller, pad, or sprayer.
- TWP Semi-Solid Pro-Series is low VOC and compliant in all 50 states and Canada; custom colors are nonreturnable, allow 1-3 day processing.
🔹 Why Choose TWP® Semi-Solid Pro-Series?
✔ Unmatched UV Protection – Prevents fading and extends stain life.
✔ Superior Penetration & Water Repellency – Protects against warping, cracking, and splitting.
✔ Ideal for Harsh Climates – Resists freeze damage and withstands extreme weather conditions.
✔ Easy Application & Maintenance – Applies with brush, roller, or sprayer for even coverage.
✔ Mildew-Resistant Finish – Keeps wood cleaner for longer.
✔ Customizable Appearance – Semi-solid formula offers more coverage while still showcasing the wood grain.
🔹 Where to Use TWP® Semi-Solid Pro-Series
TWP Semi-Solid is perfect for all types of exterior wood, including:
✔ Decks
✔ Siding & Shingles
✔ Rough Sawn Cedar
✔ Log Homes
✔ Fences
✔ Shakes & Fascia
🔹 Color Selection
✔ Available in 30 Custom Colors
✔ View Full Sun vs. Shade Effects on Each Color
🔹 Important Notes
❗ Custom Colors – All TWP Pro-Series Semi-Solid stains are custom made and cannot be returned or exchanged.
❗ Color Variations – Stain colors vary based on wood type, prep, and application. Small samples available for testing.
❗ Shipping Time – Custom orders may take 1-3 days to process before shipping.
🛒 Order TWP® Semi-Solid Pro-Series Stain Today!
✔ Premium Oil-Based Formula
✔ Superior Color Retention & Durability
✔ Low VOC, Compliant in All 50 States & Canada
Protect and enhance your deck, siding, fences, and more with TWP Semi-Solid Pro-Series Stain. Order now for long-lasting, beautiful results!
Technical Specifications – TWP Semi-Solid Wood Stain
Stain Type: Semi-Solid, Oil-Based
Coverage: 100–200 sq. ft. per gallon
Recommended Coats: 1-2 Coats (Wet-on-Wet Application)
Dry Time: 4 to 24 Hours
My virtually bare wood soaked this stain up! 10 x 16 w/steps and one gallon was not quite enough. Recommend buying extra if your wood is older. The part I was able to do looks great! Got the semi solid boulder color and really like it. Awaiting the second gallon to complete😊🖌️. Good coverage, just thirsty wood.
Send some finished pics.
Finished deck. Looks great and feel like it’s well protected from the elements! Color is semi solid Boulder
What color in the pro series semi solid stain matches closest to the color of the WP1500 series in cedar tone I want to switch to the pro series for my decking but don’t want to have to do the balusters again so I want to try and match the tone
There is no “matching” between a semi-solid or a semi-transparent, as the colors will vary drastically for each based on the wood type and the age of the wood. Maybe:
Earth, Appalachian Trail, or Musket.
Would this work to change grey composite to a darker brown color?
It should, but it’s not 100% opaque, so you may see a little gray coming through.
The #1 rated oil-based semi-solid exterior wood and deck stain! 👆
