SuperDeck Stain Review for 2026
Share Your Experience with SuperDeck Stain
Have you used the SuperDeck Stain from Sherwin-Williams on your wood or deck? We’d love to hear from you! Please share your thoughts by posting a rating in the Consumer Star Ratings below.
Consumer Feedback:
Reviews in the comment section have shown lower-than-average results when using SuperDeck Stain, with concerns about performance and durability being common themes.
If you have any pictures of your experience with SuperDeck Stain, feel free to share them in the comments along with a detailed description of your project. Your feedback helps others make informed decisions about their deck restoration projects!
The DuckBack company is the original manufacturer of Super Deck and was purchased by Sherwin Wiliams a few years ago. The Super Deck brand has gone through numerous changes since. Sherwin Williams has kept the SuperDeck brand but has added their old Deckscapes formula into the Super Deck lineup. They now have an oil-based and water-based version. This review of the Super Deck would be comparable to the current oil-based formula of the new label of the SuperDeck, under the Sherwin Williams paint brand. The current Sherwin Labels Super Deck, which is water-based, would be comparable to our review of the Sherwin Williams Deckscapes.
Super Deck Review Sherwin Williams
SUPERDECK® Semi-Transparent Stain is a 70% solid, pro-grade, wood deck finish developed to give superior protection and enhanced color to exterior wood. Superdeck Semi-Transparent Stains uses iron oxide pigments to prevent UV damage. Containing tung and linseed oils that provide superior protection with mildewcides that inhibit the growth of mildew. Superdeck Semi-Transparent Stains contain Carnauba for a durable finish that is scuff resistant.
SUPERDECK® Semi-Transparent Stain Rating (1-10)
– We used the Superdeck Stain in the redwood color on a newly built redwood porch in Northern California. The final appearance after drying was a sticky uneven finish on our porch. The stain did not penetrate very well into the wood even though the Superdeck cleaner and brightener were used to prep prior to application. Only one light coat was applied.
– 80% of the initial color was left after 2 years of exposure to full sun. The Superdeck did score fairly well here.
Wear/Tear and Peeling: 8
– The was no peeling of the Superdeck Semi-transparent stain but there was wearing in the high traffic areas. This porch is the entrance to the home and the Superdeck was completely worn from the stairs to the door.
Cost Per Square Foot: 7
– Superdeck Semi-transparent stain costs $40 a gallon. The 800-foot porch needed 5 gallons to cover. This included the deck and the railings.
Preventing Mold/Mildew/Algae: 6
– After 2 years of weathering, the Superdeck Semi-transparent stain had a significant amount of mildew spots growing in the finish. Containing linseed oil (known feeder for mold), the Superdeck seemed ineffective at preventing the mold even though it contains mildewcide.
Ease of Application: 8
– We applied the Superdeck Semi-transparent stain with a staining brush to the entire surface of the porch. The stain had issues with penetration into the wood and did not dry evenly. It took nearly 8 hours to apply the stain with two people.
Color Shifting (darkening) after 2 Years: 4
-Very disappointed with the Superdeck Semi-transparent stain turning a dark blackish color after two years. It seems that dirt sticks to the stain. There was a tree above the porch that may have contributed to this issue.
Difficulty of Reapplication: 6.5
– Unfortunately, the Superdeck Semi-transparent stain will need to be stripped and brightened prior to reapplication since the stain had turned a very dark color after the two years.
Overall Score SUPERDECK® Semi-Transparent Stain at 2 Year Period: 6.69
SuperDeck Stain Review: A Disappointing Experience
We were not impressed with the performance of SuperDeck Stain. The most significant issues we encountered were related to its application and overall appearance over time.
Key Concerns
- Unsightly Discoloration: After just 2 years of exposure, the stain turned a dark black color, which is both unattractive and problematic. Wood stains should enhance the wood’s natural beauty—not degrade into an unsightly finish.
- Reapplication Challenges: The discoloration makes reapplication difficult, requiring more prep work to achieve acceptable results.
Our Verdict
While SuperDeck Stain may work for some, our experience suggests it falls short in terms of durability and appearance. A stain should protect and beautify your deck over time, and this product simply didn’t meet those expectations.
Have you experienced similar issues with SuperDeck Stain? Share your thoughts and photos in the comments below—we’d love to hear about your project.
Where To Buy: Lumber Yards and Sherwin Willaims Paint Stores
Cost: $45.99 per Gallon, $229.99 per 5 Gallon Pail
Stain Type: Semi-Transparent as tested
Available Colors: Cedar, Redwood, Weathered Gray – Tintable to 60+ Colors
Application Temperature: 40-95 F
Coats Required: 1 Coat
Coverage Per Gallon: 250-350 sq. ft. Actual coverage was 175 sq. feet as tested
Dry Time: 8-24 Hours
VOC Compliant: 250 Compliant in All 50 States. 100 VOC for LA Area
Manufacturer: Duckback
Deck Wood Type: Redwood Porch
Deck Square Footage: 800
Stain Color Used: Redwood
Used Sherwin Williams SuperDeck Semi Transparent Water Based Stain. Initial application failed. A second application the following year after sanding and refresher failed even worse. The product goes on like paint and has no penetration. I used this product many years ago before the initial manufacturer was bought by Sherwin Williams.
We have used SuperDeck for many years & been loyal to the product…until now. I was informed the formula was thinner than previous years but that it still was just as efficient with filling in small cracks & going on smooth. I found anything but! The dries uneven & is thinner than regular paint. It did fill in any cracks whatsoever. I will not be buying this product again, in any form. SuperDeck went from being best to worst In one season.
What a huge disappointment. Paid over $3000 to have our 500 sq. foot deck and railings stained with super deck. Stained in the fall and was peeling by spring. Darkening and mildew accumulated as well. Huge disappointment. Do not recommend.
I will never use this product or S.W again! Was stained one year ago and peeling off😫! They said wood needed to be primed. Thought this product took care of that. Bad stuff all around. I used my savings to get my exterior painted and decking finished.
Sherwin Williams Superdeck Waterbourne stain is a huge disappointment! Does not penetrate the wood, and because of no penetration, the brush marks will drive you crazy. It cannot tolerate much foot traffic. Wear areas, with exposed bare wood, will result after a few months; not only on the floor but on the edges of your steps. Since it is really just a surface treatment, it will peel off it you are not careful. How can this be called a stain when there is no wood penetration? Complete waste of time and money. It will also darken within the first year.
The only positive point is that you can clean your brush with water. Stay away !!
Disappointed with this product. After having used deckscapes by Sherwin Williams on my deck and porch since 2007 ( redo every 2.5-3 years) Sherwin Williams discontinued it and sells Superdeck . It was supposed to be improved but I prepped and applied as directed and am greatly disappointed. It took days to dry, looks really dark and has not held up, turning black in big areas after about two months. I gave the remainder of product away and am now planning to sand and paint to be done with the cycle of stain and repeat
After only one year, the stain is peeling and overall my deck looks filthy. My house is only three years old; I waited until the wood had cured, as directed, and had it professionally cleaned before staining. I get morning sun only where the deck is located. This was disappointing for as much as I paid; after reading the other reviews, I’ll probably wait until next year and have someone come out to strip this and use a different brand of stain to replace.
I have the same problem as many others. My deck has an oily film that attracts dirt so it looks filthy all the time. We spent the whole day today stripping it off. A very expensive lesson. The worst thing, when I called SW regarding my frustration, they acted surprised.
Anyhow I’ve used this product for about 10 years…I have had some pressure treated lumber “go dark” after applying this product, on other pressure treated lumber It has looked great for years.
The stain is intended to be applied with “thin” coats, then another “thin” coat within a few hours, over applying (one thick coat) will cause an incomplete drying and will attract dirt, dust, and pollution to stick to it.
Contractor for many years…built and power washed and stained over a thousand decks…MANY products do not hold up well…never use a solid color…only semi-transparent…always use an “oil based” product…if you can clean it up with water…leave it at the store!
Super unimpressed with this deck stain.
I treated the wood exactly as instructed and it peeled a year after application.
After it peeled, I painted it again and decided not to use the deck at all throughout the winter.
Sure enough, it peeled in a bunch of places again.
This has been an absolute nightmare.
I’d recomment burning down your deck and building a new one before getting involved with this deck stain.
I have two decks, almost same situation. “This stuff sucks” May I ask what if anything have you done to try to correct the problem.
I am a little disappointed in the Superdeck stain. At first I thought my deck was just dirty but to find it getting dirty relatively fast was just crazy. Last season I had to scrub the deck down at least 4 times just to remove the dark grime that was accumulating on the surface. Like the review above, this stain attracts dirt and stuff like crazy giving it a consistently dirty appeal on the top. I’ve attached a photo of my deck, this is after all the snow has melted and you clearly see the difference between the top of the deck and the sides where the sides don’t seem to be affected as much as the top surface. Keep in mind that last season, this is how my deck looked mostly with the dark dirty grime on the top. I highly do not recommend Superdeck, I’ll now have to spend extra expenses to strip, clean and use another stain in hopes it better than this crap I used.
I had a new deck stained 2 years ago with the same stain and have the exact same issue – terrible, however this tells me that any other stain I put on top of this will likely adhere very well and plan on restaining with another solid stain (without stripping) from a different manufacturer. Any thoughts about doing this?
You should strip it for the best results. Super Deck is very easy to strip. Use the Restore A Deck Stripper. Brighten after.
I have exactly the same problem. My deck attracts dirt and won’t let it go. It looks like I never clean the deck. Very disappointing and the fix will be expensive to get this crap off.
I used Superdeck natural transparent stain on rough cedar cladding about 4 years ago. It looked fantastic for the first year but gradually it got darker until now it is a near a black brown. The cedar was dry and the cladding was out of the weather. I am now looking at having to paint or replace the cladding. Very disappointed with this product.
What semi transparent oil stain is best full sun Northern California
Doug fir post and beams
New
Hi Mike,
See this for new wood:
After the wait and prep, try Armstrong Clark Stains or Restore-A-Deck Stains.
Superdeck solid. Looked great after application but dog made muddy footprints all over that are still there after vigorous scrubbing. Hard to see in pictures I’ve taken so i wont post them. Also has the oily blotches others have mentioned. Not too impressed over all and it’s only been a little over a month.
I used super deck semi solid over super deck, semi transparent which I did last year. Now the deck is all blotchy. Can I use a solid same color to even it out
You may make it worse. Best to remove all and start over.
I applied superdeck to a new deck and steps. The wood was allowed to dry for 9 month and then washed thoroughly with a deck wash. The surface started to peal within less than a year and continues to peal every time I wash the deck. I am now trying to figure out how remove the superdeck so that I can start over.
Use this kit to remove it: https://www.twpstain.com/restore-a-deck-stripper-brightener-kit
Look at one of these stains after:
Just applied semi transparent oil based, 5 gallons to an off the grid log cabin previously stained with a dark latex. Sanded all loose latex. Went on well. Will post again in the spring and in a couple of years. It seemed to me like it adhered very well to the old late. Solid stain, and the dark color blended in very well where I sanded down to bare wood.
Time will tell. Using Wolmans f&f oil on my cedar lap house. They all will get darker, better than gray.
Elected to not use the Wolmans because I was going over a previous latex application
Had a new deck installed with pressure treated wood. Waited a year as instructed and hired a painting company. They stained it with Super Deck transparent modified oil formula exterior wood stain cedar tone. The deck turned out dark in some spots (was not an issue prior to staining) and grey in others. I complained and withheld payment. They came back TWO years later and sanded and “blew” the deck clean. I asked if they’d be washing the deck to prep it and they said sanding and blowing was the same if not better. The deck looks horrible. It’s a mixture of areas of blackish dirty, random grey spots, unstained look in others, cracking, and sanding marks yet some parts look a beautiful honey color. They tell me that this is the normal wood grain coming through. They brought a Sherwin Williams rep to inspect it (in the rain) and said because it was beading it was doing its work. For your reference images 3, 4 and 5 in the comments section match the look of my deck. I don’t know what to do and feel bullied.
No pics and both the contractor and the rep were incorrect.
SuperDeck is my Go To Stain. I stained my decked in 2020 and only had to touch up 3 years later. It’s the best stain on thr mkt in my opinion. You have to properly prep: powerwash, treat surface for mold, and sand. If you don’t prep properly it will fail. However, this product rewards folks who properly prep. So easy to apply and reapply 3 years later. The cheap deck stains peel and flake. Superdeck does not. My Go to stain.
Sherwin Williams after they bought Super Deck changed the formula and it is not the same anymore. It does not perform nearly the same as the regional formula.
It’s time to re-stain my deck. (spring 2023)
unfortunately, Super Deck has been taken over by SW.
I’m switching to TWP as the next highest rated brand.
it is so unfortunate that excellent products and good companies are bought out by larger companies that want to instantly change the formula.
I loved Supedeck semi transparent oil stain……….but SW has decided without the input from their consumer base to change it to the same as their current product.
What ever happened to quality American products sticking to their guns?
Corporate greed and the belief they have to cheapen the product quality to be competitive in big box stores. Many great stain brands have fallen victim to this. SuperDeck, Cabot, Flood, Sikkens North America, etc.
Thank you for your thoughts……….I tend to agree. It just seems so un-American……….we used to be innovators………now we are just followers. No one ever wins a race by running with the pack. What do you think of TWP
We have been using it for 20+ years. Excellent stain and is better than the old Super Deck.
Thank you! you provide a great service…I wish more people where like you (us)
Have used super deck for over 10 years ..quite happy overall…always oil based…under Nevada sun stain holds up a minimum of 2 years ..Was quite sad when local hardware stores quit carrying it because of the high voc but found the Sherwin Williams stores still make and carry it. Proper prep is the solution.
SW changed the formula so it is not the same as what you used prior.
What is the cost of super deck cedar stain per gallon
Sorry but no idea.
Anyone uses Zar deck stain?
Not fans.
Last year I had to replace the back of my fence, and have used superdeck 1905 heart redwood color of stain for years on my fences. Last year I bought a case of this stain when I replaced my fence. I recently had to replace the side fence of my yard and had a gallon left over, but not enough to stain the whole fence. I go today to purchase some more and you can no longer get it in California, (Figures). So my question is, I stained half of my new fence and need a brand/color to match it the best I can. Any suggestions.
Strip off the Super Deck and then brighten and start over with a new and better brand of stain like Armstrong Clark or TWP 1500 Series.
Heart redwood transparent stain is no where near the same colour as previous. Previous this stain has a dark red. New stain or orange. Doesn’t take on wood grain as previous. Looking for different product to carry on last years staining. Not happy with this new product
Reviews of rodda rural manor stains? Trying to find a stain that will color match body of house.
Sorry but never used this stain.
Was so excited to put that stain ( natural semi transparent super deck ) on the new weathered and sensed cedar wood decking , the application and appearance went really good ,we stained it in the month of August 2020 in the spring of 2021 was shocked to see the decking it looks like old none stained deck , was hoping to get at least 3 years on it!!! So disappointed 😞!!!
Can I put super Deck oil base stain over the modified oil base stain? The modified oil stain SUCKS ?& looks like crap. Was a wast of time & money. The old one is MUCH better!
No, you will have to remove it first. Strip and or sand.
The new, reformulated SuperDeck Transparent Stain is a huge disappointment. The stuff looks like orange yogurt, and goes on with a plastic sheen. It doesn’t seem to penetrate the wood at all, and doesn’t show off the wood grain like the old formula did. This is “name brand engineering” at its most tawdry.
What is a good deck Brightener to use after cleaning?
Restore A Deck Brand for both cleaning and brightener.
I used Superdeck in Cedar Bark color on pine Siding with great results last year! First I washed and scrubbed all of the clear boards with water, let dry for 24 hrs and then applied the Superdeck with a rolller and after a few minutes, wiped it with a cloth. I applied two coats on the exterior side of the board and one coat on the interior. I am disappointed to hear that the formula has changed as, I have two more sides of my house to do. As it has only been up a year, I have not noticed any darkening issues and hope that doesn’t happen!
Worst stain ever started rubbing off after 6 months garbage even paid a professional to do it.
Can you apply a second coat? My deck does not look best with just one…
It may not dry or cure corectly if too much is applied Try a test board first.
First coat was applied two days ago… I have tried to apply a second coat in one area, but it doesn’t seem to adhere properly. Hence my question if a second coat application is OK to add to make the deck look better – now there is a lot of unevenness in colour.
No, it will not work.
Why every year?
Because it is not a very good brand. Try something better:
https://www.deckstainhelp.com/best-semi-transparent-deck-stain-reviews-2020/
Super deck looks good for 60 days only if used frequently, marks easily, wear through easily, we have to recoat every year and they can’t ever get color close enough to spot in areas, Getting tired of sanding covered porch every year,I’m disabled.
My painter applied Woodscape to my deck almost 2 years ago. I called him after a year, and told him that it faded.
Question: Can you put Super Deck over Woodscape? I have 1500 sq feet of deck space.
I asked one employee at the Sherwin Williams store and he did not know.
I asked at another store he said sand it all down. (Sure 1500 sq feet)
One part of the deck now has been replaced with new boards, but it connects to an existing deck with Woodscape. Dark brown.
Please Help
Paul
No, you will have to remove the old coating first.
I bought Super Deck Waterborne Exterior Deck Stain and Stain & Sealer Remover. When reading the instructions I see that Revive Cleaner is required after the remover. Is this cleaner really necessary? No one at the Sherwin Williams store mentioned it and, of course, I do not want any unnecessary work. It is pressure treated wood that I previously covered with Deckscapes.
You must use a brightener after stripping a deck to neutralize the stripper. The SW Revive is a brightener.
So, since I have already scraped and sanded the deck then I should be able to just apply the Deck Stain, right?
No, clean and brighten for final prep to open up the wood pores.
Ok, then it’s back to the paint store. Thanks for your help.
I used super deck solid stain on my deck on june 16th 2020 and it is now july 6th 2020. I have mildew forming on top of my deck and dirt will not come off. I called SW and the guy said he jas been there 3 years and never had problems with it. Well after some research I see he is full of it. They arr gonna make a decision and call me back about what to do. I’m not holding my breath. I will attach pics. Do you have any advice? The pics are after scrubbing it with Dawn and a hard brissle push broom
Try watered down bleach to kill it. 1 part Bleach to 4 parts water. Do a test spot first to see how it works.
Ive also used a commercial grade mold and milder cleaner it was just as effective lol. Sorry didnt note that in the comment
I have a 2000 ft IPE deck that is 3 years old. I live in N. CA so we get a lot of weather changes from 80 to aprox. 50. The deck gives out tiny splinters. I’m going to clean / scrub the deck using the sherwin William’s super deck wash. Can I/ should I also use the super deck exterior water borne clear sealer. Will this help prevent those little splinters?
No, it will not prevent splinters. You would need a solid stain for that.
Thanks. Recommend a stain that is close to the natural IPE color? Or at least a brand that I can use for IPE. I know you need a stain specifically for hard woods. What do you think of penefin? Or is Penefin the same as the sherman William’s water borne clear sealer I mention above. P.S. I know the minimum on this topic.
Penofin turns black, do not use it. See here for the top IPE stains: https://www.deckstainhelp.com/ipe-exotic-hardwood-stain-review/
I did my deck in a oil based semi-transparent oak color. I don’t care for it. Too yellowish. Can I restain it in a different color
You will have to strip it off and then brighten the wood. Then you can apply your new stain.
Will mixing this product(SuperDeck oil based exterior Natural stain) in an “automatic mixer” for a few minutes destroy water repelling quality? Instructions on can say to Stir contents not mix. Was this product ruined by this mixing? After apply to wooden gazebo does NOT repell water.
Mixing does not ruin a product and deck stains are not designed to bead water but shed water.
I have used Superdeck transparent stain in Redwood and Heart redwood, in Nevada for over 23 years, no problems. Re-stain every 2-3 years. Having to replace some boards now from rot.The deck is around 30 years old. I can live with that. At our new house I used PPG timeless advanced transparent stain and sealer which is the same as Olympic Elite Advanced stain and sealer, according to this web site, and like it real well.Cant find either one of those on the web.. Used Sikkens, did not hold up as well as Superdeck. I am making my own deck stain now. Diesel, boiled linseed oil and tung oil and paint as color.The test pieces looks good. I will see how this does. Would go back to Superdeck any time.
Looking forward to any comments.
I have used the Superdeck Sealer (clear) on my two decks for the last 5 years. It works well, is easy to apply and keeps the wood(redwood) dry. I reapply yearly – cleaning, sand, clean again and apply. It takes me about 90 minutes per deck. Based on this experience and cost, when on sale, I will continue to use.
What stain can you use on a raised garden bed?
Any of these: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
I would not recommend unless you what the chemicals from the stain in the food your grow. Use Cedar or redwood for the bed and let it grey.
We have used Superdeck stain cedar 2001 for several years in our large board fence around our farm. Our supplier said they can’t get it anymore & substituted with a product we don’t necessarily like. Where can we order what we want? Thank You
Check with their website directly.
Hi Ann, your review could have been written by us! Have you ever found a suitable replacement? We too used Superdeck 2001 Cedar on several thousand feet of our wooden fence and loved it. We noticed over the years as we added fence or re-stained that the formula had obviously changed and didn’t perform as well. 20 years ago you had to keep stirring because the pigment settled. About 10 years ago (still called 2001) you didn’t really even have to stir any more and just didn’t look as good and didn’t last as long. We went around and bought up all of the 2001 we could find. The new formulas are terrible. The areas we stained 20 years ago look better than those we did just a couple of years ago. We recently tried the so-called “modified oil based” semi-transparent. Didn’t really like the way it looked so we tried mixing a few ounces of it with the same amount of the original transparent (same formula as 2001, but clear) as a test. Found it odd that the oil based floated on the new “modified oli based” stuff. We have given up on Superdeck and are trying to find something like the original Superdeck 2001.
TWP or Armstrong Clark would be options.
This stain peels after 3 months. Do not use
Yes this stuff is horrible ….. it is coming up on the stairs and walk way after 6 months. I want it gone
What about the hold up on a place in the ocean? Salt …
Try Armstrong-Clark in one of their semi solid colors.
I’ve read a few times where you’ve stated that you must strip in order to use another stain over Superdeck. However, I have two very large carved trees that have this deck coating and yes, like everyone else, they turned completely black. It took 6 hrs just to pressure wash them to remove the black dirt/mildew and there are many intricate patterns so stripping the old stain off to start over is out of the question. I have to believe there is another compatible stain I can apply over Superdeck–like another linseed oil based stain. If not, I will add a mildewcide (M-1 Advanced) to the Superdeck this time. Can you recommend a compatible stain to apply now after the wood has been thoroughly sprayed and cleaned with a pressure washer? If not, what are your thoughts of adding a mildewcide to a stain like Superdeck?
Stripping Super Deck is super easy. Just apply the stripper and pressure wash off. It would have saved you hours of pressure washing as well as it makes it very easy. You should still do it as applying something over it will not fix the issues and could result in more problems with adhesion or drying of the new stain.
These tree sculptures are 15′ tall each (there are two) and have all vertical surfaces with lots of detail. All washing/prep requires an extension ladder that has to constantly be raised, lowered and repositioned. Just applying the stripper (like applying the stain) would be a full day job and probably would not get into or come out of all of the crevices. At this point, since I didn’t strip (but did get all the black off), I don’t plan to go back to spend another day to do it. If there’s no compatible stain that’s better than SD, I will just try to add mildewcide this time and hope for the best.
I still would like to hear your thoughts on adding mildewcide to a stain. The packaging says it can be used in stains. Seems like it should prevent black mildew , however, there has been some talk about SD attracting dirt, so I don’t know how much of the black is from mildew and how much is from dirt. I’m sure people have added mildewcide to stain before…what do you know about the results when used with a deck stain? Thanks!
Adding a mildewcide will not fix the issue with SuperDeck turning black. It already has mildewcide in it. The issue is the product darkens no matter what.
Don’t use this product. It is really poor when it comes to mold resistance. I even added mold and mildew inhibitors and it still turned black
Which holds up better Rymar Deck or SuperDeck as a preservative to our deck?
Rymar Deck is touted to hold up for 3 years which is wonderfully amazing …
Please advise
Neither are very good and neither will last 3 years on a deck. Rymar is probably better than SD.
Ask a Question or Post a Review…
Thank you for your response. Which brand then would you suggest, where can you buy it, and about how much $ per gallon?
Check with their websites as to where to buy.
Stained cleaned cedar deck a week ago and it’s still not dry!!! It’s been very humid and hot. What can I do? I’ve used superdeck before & never experienced this. What a mess.
If it does not dry you will probably need to strip it off down to the bare wood and start over. Give it another week to see if it dries.
Thank you. I am going to wait. 🤞
Exactly the same problem. Very tacky after one week. SW told me to wipe it down with paint thinner. I did. No change! Totally disgusted
I have used Superdeck for 4-5 years now and every spring my deck is black with dirt and stains. I have washed, sanded, done everything and same results every spring. I am going to try something different. It looks good when done but doesn’t last
Based on the suggestion of another website I used superdeck on my Cumaru deck last year, even though it wasn’t marketed for tropical hardwoods. I have used a different finish every year (including many of the higher rated ones here) and the Superdeck was by far the best. It was so good I considered letting it go for a second year as there was no graying at all. Application was easy as I felt I didn’t have to worry as much about soaking up any oil.
The color was blotchy but I think that was more of an issue with using their stripper & brightener which had poor instructions and no product knowledge at all from their store or help line – avoid those. AFter a year the color was pretty good and it didn’t collect dirt and darken like the other oils I have used.
This seems to contradict many of the other reviews here but I’m putting it on again after cleaning and power washing.
Forgot to note that this is a review for the semi-transparent stain. This may perform differently than the more opaque versions. Mine really doesn’t have any problems with trapping dirt / mildew and is actually much better than the other Ipe oils I have used in this regard. I just re-applied 2 days ago and application was easy once again. Highly recommended for Ipe or other tropical hardwoods.
I have found that if shoes have dirt on them and it sits for a day it is extremely difficult to clean. This has happened on more that one occasion. I like the look and coverage but think it needs some sort of sealing additive to prevent these dirt marks from penetrating and making it so hard to clean?
It is an issue with Super Deck. It embeds dirt and turns black.
I had a new deck stained 2 years ago with the same stain and have the exact same issue – terrible, however this tells me that any other stain I put on top of this will likely adhere very well and plan on restaining over it with another solid stain (without stripping) from a different manufacturer. Any thoughts about doing this?
In 2016 Sherwin William’s sold us Super deck as replacement for Deckscapes since they no longer had Deckscapes. Super deck was tacky and took forever to dry. Had a rubbery appearance. It is lifting and peeling off. The original Deckscapes underneath is still adhering. Horrible product.
Don’t use this product. Cleaned my deck according to their instructions. Applied stain last summer, looked good.
The stain peeled off from the winter snow. Very dissatisfied with product.
