This post was updated on March 17, 2026
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Best Deck Stain reviews and help tips are based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
Elevate Your Deck with the Best Wood Stains & Sealers
Whether preparing for a DIY deck-staining project or looking for the perfect stain to share with your contractor, I’ve got you covered. I have rounded up the eight best deck stains available in 2026, including oil-based stains, water-based stains, and semi-transparent and solid options.
Scott’s Expert Guide to Choosing the Best Deck Stains
Questions About Which Deck Stain or Sealer to Use?
Want personalized help? Post your questions below in the comments, and I’ll gladly guide you toward the best deck stain and sealer. Please include any pictures you may have and a brief history of the deck.
Over 30,000 Q&A Comments Below on this article. Ask Below, I Love to Help!
My Recommended Best Deck Stains and Sealers at a Glance
Click on the link and jump straight to the review:
- Top-Rated Deck Stain: TWP 100 Pro Series Stain Review — This deep-penetrating, long-lasting, semi-transparent stain is oil-based, easy to apply, and withstands the elements for up to 3 years.
- Recommended Semi-Transparent: Restore-A-Deck Semi-Transparent Wood Stain Review — Restore-A-Deck’s UV-resistant, semi-transparent stain can be applied to damp wood, which means we can prep your deck and apply the stain in one day.
- Leading Semi-Solid: TWP® Semi-Solid Pro-Series
- Oil-Based: TWP 100 Pro Series Semi-Transparent
- Best Water-Based: Restore-A-Deck semi-transparent deck stain
- Recommended Solid Color: Restore-A-Deck Solid Color Wood & Deck Stain
- Best-Applying: Armstrong-Clark Wood Stain — This long-time favorite is a hard-working, deep-penetrating option that goes on easily and allows for simple maintenance.
- Excellent Semi-Solid Wood: TWP Pro Series Semi-Solid Stain — TWP’s semi-solid stain goes on quickly, holds color well, and offers maximum UV protection and a variety of color palettes to choose from.
- Outstanding Wood Preservative Deck Stain: TWP 1500 Series Semi-Transparent Stain — TWP’s 1500 Series consistently ranks as one of my top options for deck stains, thanks to its deep-penetrating formula, UV- and mold-resistant properties, and long-lasting color.
- Recommended for Mildew: Defy Extreme Semi-Transparent Wood Stain — Defy’s water-based Extreme Wood Stain offers rich, penetrating color and an infusion of zinc oxide Nano-particles that prevent damage from UV rays, mold, and mildew.
- Best Deck-Resurface Coating: Gulf Synthetics Deck Revive
Steps to Picking the Perfect Deck Stain for Your Needs
Is There a #1 Rated Best Deck Stain or Sealer?
Transparent Stains
As the name suggests, transparent stains are clear or very lightly tinted stains that help seal and protect wooden decks while still allowing the wood grain to show through.
Semi-Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
Common Deck Staining Mistakes and How to Avoid Them
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly.
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time.
From: $41.99 | From: $47.99* | From: $65.99* | From: $69.95* |
*Free Shipping Included
- Ease of application
- Wear and tear after 2 years
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
5. Ready Seal Wood Stain
3. Defy Extreme Stain
- Scott’s Pro Tip: My most used deck stain in the past 30 years! We have used the TWP 100 Series on many 1000s of decks.
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Scott’s Pro Tip: My favorite deck stain to save time and money. We prep and stain on the same day.
My Test Deck Stats
UV Exposure: 50% Full Sun
- Scott’s Pro Tip: Regarding ease of application and performance, the Armstrong Clark stain is one of my top stains. We love their semi-solid colors and performance.
My Test Deck Stats
Deck Square Footage: 600
- Scott’s Pro Tip: My favorite penetrating semi-solid wood and deck stain soaks into the wood and provides excellent UV protection.
My Test Deck Stats
When Tested: August 2020
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Scott’s Pro Tip: My favorite current penetrating semi-transparent oil-based stain is the TWP 1500 Series. Michigan switched to low-VOC, so I now use it on the majority of decks that I restore.
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Scott’s Pro Tip: My new favorite IPE and Hardwood Deck stain is the first stain I have ever seen last more than one year on exotic hardwoods.
My Test Deck Stats
Stain Color Used: Chesnut
- Scott’s Pro Tip: The Defy Extremes is one of my top choices when using a water-based semi-transparent wood stain.
My Test Deck Stats
Stain Color Used: Cedartone
- Scott’s Pro Tip: Ready Seal Stain is not my favorite since it requires annual recoating, but I do like that it applies easily. Ready Seal does not cure fully and can rub off the wood on clothing.
My Test Deck Stats
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Deck Stain Facts: Frequently Sought Answers
When helping people choose the best deck stain and sealer, I often hear many of the same questions. Here are some facts and words of advice about exterior wood stain that can help answer these questions:
What is a deck stain?
Deck stain is a type of finish applied to the wooden boards of your deck. Generally speaking, deck stains come in three types —transparent, semi-transparent, and opaque —and are available in a wide range of colors to suit your taste.
Answer: The deck stain must be tinted to protect it from UV graying. I prefer semi-transparent stains, as they do not mask or cover the wood but highlight the grain while providing UV protection.
Answer: My favorite deck stains have been penetrating semi-transparent and semi-solid stains. These stain types allow the wood grain to show, and if they truly soak into the wood grain, reapplying is easier down the road.
What deck stain types can be cleaned and recoated as needed?
Answer: Penetrating deck stains are not prone to peeling, and we can clean and reapply them as needed. Deck stains that dry or film on top of the wood are much harder to maintain and prep when reapplying.
Answer: Absolutely! Deck stains are wood stains and work very well for wood fences, vertical wood siding, and log cabins. They last even 2-3 times longer on vertical wood.
The waiting period before staining a new deck can depend on the material used to build it. Take a closer look at our recommended time frames based on deck material:
- New, smooth wood decks: Wait at least 3 months before applying stain.
- Rough-hewn wood decks: No wait time is needed; you can apply stain as soon as the wood is clean and dry.
- Kiln-dried or KDAT wood decks: Wait 1-2 months before applying stain.
For more information, check out this guide on how long to wait before applying stain to your deck.
The most popular deck stain colors of 2026 include:
- Cedar tones
- Brown tones
- Honey tones
- Redwood tones
The best way to apply a deck stain can vary based on the product used, but my personal favorite applicators include flooring brushes and stain pads. Learn more in this guide to the best deck stain applicators.
What’s the difference between a deck stain and deck paint?
Deck stain and deck paint are similar in that they add color to a wooden deck. However, deck stain typically penetrates into the fibers of wooden deck boards and often results in a more natural final product. On the other hand, deck paint is typically thicker and creates an opaque layer of color over the wood.
What’s the difference between water- and oil-based deck stain?
Both water- and oil-based deck stains can provide rich color and long-lasting protection against moisture and UV damage. However, there are some differences between the two stains.
For instance, oil-based stains may offer advanced protection against warping or cracking and last longer than water-based stains. However, water-based stains are generally more environmentally friendly and easier to apply and clean up. Many water-based stains also feature additives to prevent fungal damage or wood rot. Learn more in this guide to the differences between water—and oil-based stains.
The 3 best deck stain brands for decks in full sun are TWP, Restore-A-Deck, and Armstrong Clark. The TWP 100 Pro Series semi-transparent penetrating deck stains in darker tints are best for most decks. TWP also has a semi-solid penetrating deck stain that works well in full sun. Restore-A-Deck has semi-transparent and solid deck stains for full sun. Armstrong Clark is a high-quality oil based deck stain.
Additional Deck Stain Rating Questions
If you have questions on this review of deck stains, please ask me below in the comments.
Want My Help Finding a Deck Stain?
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
- TWP 1500 Series
- Armstrong-Clark Deck and Wood Stain
- Restore-A-Deck Wood Stain
- Defy Extreme Wood Stain
I am here to help you find the best wood deck stain for your situation! Just post a comment below with answers to these questions.
Moved in our house 4 years ago, it was built in 2001 and pretty sure the deck was original, so 21 years old. We’ve done nothing to it since moving in. Not sure what the stain on it is. I want to bring it back to life and extend its life. What would you recommend in terms of stain? I’ll repost if need pictures without it raining. Thanks!
Need some pics to help with prep and what stain type and brand would be best.
Scott,
Here are pictures. It rained a bit ago so the wood is darker than typical. The stain on it appears to be oil based as there is no peeling at all, it is totally soaked within the wood, but i’m not sure. A contractor looked at our deck yesterday and recommended SW SuperDeck product, but your reviews indicate it is a poor product. For the $$ it costs, I want it done right and with a good product (do it once do it right!). We are located in Northern Illinois if that impacts what product to use. The deck is on the south side of the house and 2/3 of it gets baked in the sun, and 1/3 is shaded. Thank you for your time and recommendations.
Jason
It’s a penetrating semi-transparent stain but could be oil or water-based. It does need to come off first. Use the Restore-a-Deck Stripper and Brightener kits for this. Once prepped, use TWP 1500 Series or Restore A Deck Stains in IL.
Thank you? Just to clarify:
Thanks again, super helpful!
1. Yes, you always have to remove when switching brands of semi-transparent stains.
2. Try their calculator: https://www.twpstain.com/twp-deck-stain-calculator
Live in sw colorao. Redwood that has constant sun. Penofin has been used in the past but it darkens. We have sanded the deck and ready for a finish.
Will a oil based semi transparent be best for resist fading or darkening or do you have another recommendation? We currently have a short window = the next 5 days to to this due to temperate and no rain
See our prior reply to your other post.
Hi Scott, Thank you for your answer, but I can’t the prior reply.
How do I find it? Thank you
I live in Alabama. My porch is covered but about 2/3 full sun each day. Last May we prepped and applied one coat of Thompson Semi Transparent deck stain.Now the 3/4 exposed to sun has faded and looks worn and splotchy. The other 1/4 still looks ok. Do I need to strip and restain or can I put another coat directly over the whole porch?
Post some pics for prep advice.
Here are my pictures.
Strip and brighten all using the Restore A Deck Stripper/Brightener Kits with both additives: https://www.deckstainhelp.com/restore-a-deck-stain-stripper-booster-thickening-gel-review/
Hi. We’re looking for a semi-transparent stain for our deck. Info as follows: built Dec 2019, has never been stained/painted, located in far western KY (McCracken Cty) which is humid, built on east side of house, constructed of treated decking boards (possibly yellow pine but I am not certain), no current mold or mildew issues, has been recently washed and sanded. We have two boards that weep sap during hot weather and are wondering if they need to be replaced (photo included). Thank you for your assistance.
Prep well with the Restore A Deck Prep kits and stain with the Restore A Deck Stains or Armstrong Clark Stains.
Hello, new deck with treated wood, has been sitting for about 6 months in Atlanta, so we sanded and this is how it turned out. We used Cabot Timber Oil Natural and it has some areas that are matte looking and others that are sheen looking. Please see attached and ideas on how to correct?
You will need to remove all and start over to fix this. Strip and or sand. Brightener after. Also, use a better stain brand when done.
I live in Nevada and would like to see what you recommend. I want a semi-transparent stain that can withstand some sprinkler overspray and a good amount of sun. Tried repositioning the sprinklers but it’s hard to get them off the top of the deck entirely. Previous Cabot stain has come off on much of the deck and would like to redo it with something better. Deck was built earlier this year but is now lightly weathered Douglas fir. No mildew or mold.
Remove all the Cabot first and then try TWP stains or Restore A Deck Stains.
Massachusetts. East facing, but tucked in a corner so shaded from the south and covered in one area by the door. Ipe. Installed 9 years ago – not treated at all. Has weathered variably due to sun/weather exposure I expect – some more protected areas still retain some original color, others are fully grey. Some cracking in a couple of the grey areas. A few very small spots of pale green algae (or mold?). I have read so many different things!!: wash (with/without bleach products); maybe sand the surface (more than 80/less than 80 grit)? And then the stain/oil, but which one?! Help! 🙂 Thank you!
Clean and brighen the wood while pressure washing for prep. Choose one of these stains after: https://www.deckstainhelp.com/ipe-exotic-hardwood-stain-review/
Thanks! That’s what we are going to try, with the AC I think. But given the weather here I think we won’t be able to do it until the spring. Thanks again though! Your site really helped me weed through it all and come up with a plan!
Welcome!
do you also rate best stains for wood [cedar] siding? im needed to re-stain my house currently. thank you
The ratings and reviews also work for cedar siding as well. Stains in general will last 2-3 times longer on vertical siding compared to a deck flooring.
Hello!
I live in Maine and have Meranti Posts and Railings installed in 2016. They were sanded (poorly) and stained once since. This area has a few hours of sun a day and the portions that have highest UV exposure have done the worst. The wood has split and does have some mold/mildew issues. See two pictures (first post has not been sanded, the second one has.) Unfortunately I don’t know what that contractor used previously for stain.
After the prep, use one of the stains: https://www.deckstainhelp.com/ipe-exotic-hardwood-stain-review/
Tennessee south facing deck that was installed two years ago with no previous treatment. Vacation cabin so looking for a quality stain with durability and ease of reapplication. House color is gray so would like to compliment this aspect.
Try the TWP 100 Series or the Armstrong Clark Stains.
Looking for best stain – solid. Mostly covered deck but stairs (2) and short stretch (12×5?) are uncovered and had mold/mildew.
In which state is your deck located? Massachusetts
How much sun/shade does your deck get? Limited sun in AM.
What type of wood is your deck made of? Not sure but I think PTP.
Do you have mold or mildew issues? Yes
Why/how did the previous stain fail? Worn or mold/mildew.
What type and brand (if known) of stain did you use last time? No idea.
Deck is 5-6 years old (original).
See here for solid stain reviews: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
just finished staining my deck (pressure treated wood) with a clear (honey) stain. is it ok to now use a clear sealer over the top of the stain? or is there a better protection option?
No, never apply a sealer over a deck stain. It will peel.
I have a new treated pine deck (about 275 sq ft) which was completed on May 2nd this year. I would like to have the railings and risers white, and the deck floor and treads, grey. Can you stain both the floor and the railings or should the railings be painted and deck stained? Is there a product that has a white stain for the railings? Also, is it best to use a semi-transparent or semi-solid stain? Finally, is Restore-a-Deck a good product for a new deck?
See this article and it will answer your questions: https://www.deckstainhelp.com/why-have-a-two-toned-deck/
I have a small bump out section of my siding that is cedar tongue and grove cedar. It had cheap water based semi transparent stain applied when new, three years ago. It was peeling and faded. I have sanded it off, am going to clean and brighten and reapply a semi transparent stain. Do you have a preference between the Restore A Deck semi transparent and the Armstrong Clark Semi transparent stain for such an application. The bump out faces west and gets strong sun from about mid day until sunset. I was leaning towards the oil based Armstrong Clark stain but y’all rate the Restore A Deck even higher.
Both are excellent stains. Do you have mildew or mold issues at your house?
No mold or mildew issues
Than either would work very well.
Is there an advantage to having the oil in the Armstrong Clark soak into and perhaps rejuvenate the natural oils of the wood lost to weathering of will the restore a deck water based stain accomplish the same thing without oil?
Oils can help internally but I doubt it will make much difference on your vertical wood.
Northern WI. 2 yr old bare treated pine. A dock over water facing west with lots of sun exposure. Slight graying, but in good condition. Algae/mildew where dock meets shore and in small areas in boathouse shadows. Looking for recommendations for stain.
For prep, use the Restore A Deck Cleaner and Brightener Kits. Stain with Restore A Deck Stains or Armstrong Clark Stains.
Armstrong oil or water based for either Semi T or semi S stain?
Armstrong Clark is only oil based.
CAN we even buy TWP or Armstrong Clark anywhere in Oregon? I can’t find it.
Check with their site or buy online at http://www.twpstain.com
Is there a good semi transparent stain that comes in black or dark charcoal? Looking to stain a pergola that I am building. Its new douglas fir. I’ve gone back and forth between paint or stain. Looking for lowest maintenance and longest lasting without frequent re application. Thank!
No dark black but you can get a very dark brown. Try TWP 1504 Black Walnut or Armstrong Clark in Black Walnut.
The stain was not fully removed by the treatment described below.
Additionally, the 2-yr-old, oil based stain was not fully removed from the boards of the deck.
We live in middle Tennessee. SealSmart treated our pressure-treated pine deck last Friday, September 23,2022. Once the treatment dried, our deck looks worse, nothing like the result advertised. We were told the treatment is water based.
How can moisture content be measured?
How long should the deck dry before it can be stained and sealed with another product?
Can another product be safely used on it?
If so, should the product be water or oil based?
What stain and sealant product do you recommend?
You will need to remove it fully to fix it. Post pics for prep help.
Hi Scott – thank you so much for this website. I live in Maryland and had a pressure treated pine fence installed about six months ago. It doesn’t get full sun but the summers here are very humid. I’d like to put either a transparent or semi-transparent stain and sealer on it that won’t hide the look of the wood. I’m also not sure if a water based or oil based stain would be best. Do you have a couple of stains that you can recommend? There are a lot of Benjamin Moore and Sherwin Williams stores in my area but I don’t see any of their stains on your ‘go-to’ list. Thanks for your help.
Try TWP 1500 Series if wanting oil-based or Restore A Deck Stains if water-based. Both are excellent.
Thank you Scott. It looks like TWP is not available in Maryland. Do you have a second best oils based stain that you prefer?
Use the TWP 1500 Series. It is allowed in MD.
I finally found it. Thank you.
Pressure treated lumber. Washington State. Transparent Stain showing wear on steps as well as around outer edges. Close to Puget Sound.
Pics for prep help?
Most of the pressure treated pine deck is 2 years old , and has never been treated. The covered walkway is 30 years old and is stained dark brown. It is in good shape. A few sixteen foot boards were replaced about a year ago, and are are not in direct sunlight. I think that a need a solid stain in order to achieve a uniform color.
For solid stains, see here: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
Hi, I would like your suggestion for a stain on my deck. Some of the deck is very good, other parts are rotted where weather contacted it regularly. Thinking about painting the railings and staining the deck. We live in Oregon. Deck receives full sun most of the day. It has a clear cover or roof. The wood is old, pressure-treated wood, don’t know what it is. Fir, maybe. No obvious mold or mildew, except for the rotten boards. It previously had a Behr deck-over type paint on it which had started peeling and bubbling where the deck was getting continually wet all winter long. Please advise. I have already striped, sanded and cleaned the wood, just need to stain/seal it and fix bad boards.
Did you remove 100% of the old coatings?
there are small spots here and there with paint, still scraping/sanding it off. Also, between the boards, there is some paint still there. Still scraping. Did the photos show up that I attached?
I did attach photos are you seeing them? Also, can I use bondo to patch the holes? I’ve used mixmax wood filler, but boy, this is getting expensive.
Yes, the pics are there. 100% must come off to switch to a transparent. Wood fillers will not work on exterior wood. They will not stain to blend with transparent or semi-transparent deck stain.
Please recommend a deck cleaner, brightner and sealer/stain for my deck.
We are in southern middle TN. The deck is on the south side of the house. In the winter it gets sun all morning. In the summer it is almost full shade nearly all day. The deck is 2 years old, pressure treated Pine and has never been sealed. Approximately 10′ X 30′ w/40″ safety rail on 6″ X 6″ posts at 10′ height above a concrete patio. It currently has alge growing on it in places as does the concrete patio under it. Photos attached.
Prep with Restore A Deck prep products and stain with their stains or Armstrong Clark Stains.
Thank you Sir!
Cetol translucent wood finish: redwood sequoia
There are white fuzzies on the rail tops and some whitish areas on the deck floor. I don’t know if that is residue from the bleach based cleaner I used or white fuzzies. Can you tell from the photo?
Thanks in advance for your help.
Try TWP stains or Restore A Deck Stains.
I need your recommendation. We are in No .Carolina. New construction about 12 mo. old. Pressure treated yellow pine. No current mildew problems. With stairs, deck and railings I figure it is close to 1000 sq. ft
I have to get my old fence restained and realized that the products have all gone to water based. It was originally done with a BEHR solid stain that required mineral spirits to clean up. The stuff would wear off gradually and never peel.
I sure don’t trust the current water based versions.
It is rough surface type clear cedar that has been pressure washed. Can’t wait to have product shipped as I need to pick something up today. (Seattle ,WA)
The best products on your website aren’t available for pickup in local stores…..help?!!
What advice can you offer since I have to settle for local availabilty?
There are not any solid oil-based stains anymore that we know of.
Looking for a good product to preserve the natural color of my new red cedar fence. I don’t want it to silver. Fence gets about 10 hrs of full sun, then shaded by a near by oak tree. Located in south Louisiana. Any suggestions would be great. TIA
Try the TWP 100 Series or the Restore A Deck Stains. See new wood tips: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
This is M Reinert. I forgot to add your questions.
State- Missouri
Sun/ morning shade only
Wood type- Cedar
Mildew- was on pergola but the rough cut seems to be holding much better than the smooth deck.
Failure- deck fading and lifting after only one year
Type- Valspar Semi Transparent
The pictures are on prior email.
Thank you for your much appreciated answers.
Strip and brighten all wood to remove the Valspar. Then use a fully penetrating stain so this does not happen again: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
I applied Valspar semi transparent last year after stripping and cleaning. Now after only one year, it is faded and coming off the flat surface with no water shedding.
What is my alternative to this disappointing experience?
Apologies. Here are the photos referenced in my post below this one.
Thanks for your expertise! I have an unusual deck, containing quite a bit of variation.
* In which state is your deck located?
Virginia
* How much sun/shade does your deck get?
It is a 4- level deck. Some parts get very little sun, and a couple of sections get a fair amount (varies depending on angle of sun/time of year)
* What type of wood is your deck made of?
Not sure. Treated lumber. I know 2 of the levels are made of a different wood than are the other two.
* Do you have mold or mildew issues?
Yes. Especially in the sections that get little to no sun.
* Why/how did the previous stain fail?
No idea. What I do know is that the deck hasn’t been treated with any stain since some time prior to 2005(!).
To prep this woefully neglected deck, I’ve:
– sanded two of the levels (the ones that get more sun needed it; their wood might be older in addition to different from the other two)
– Meticulously power washed, using Krud Kutter
– I’m about to apply/treat with Valspar All-in-one deck prep
* What type and brand (if known) of stain did you use last time?
No idea. See above.
The deck area total is 842 sq. ft, exclusive of stairs and railings. So I imagine price could be a factor, especially if more than one coat is required.
I look forward to your guidance, and thank you!
Photo guide:
1. Closeup of high sun area. Sanded and cleaned.
2. Stairs. Sanded. Cleaned. One step treated with Valspar All-in-one.
3. Another high sun area, sanded and cleaned. Small test patch treated with Valspar All in one.
4. Deck that gets little sun (part gets none). Cleaned.
Clean and brighten all wood for prep and then stain with TWP Stains or Armstrong Clark Stains.
hopefully you can help. we wrapped our beams in cedar and tore down the old railing system and replaced it with cedar rails. we waterproofed everything in thompsons – it was a clear waterproofing product purchased at lowes. the cedar wrapped beams have been fine, some flaking but the railing system began to collect black blotches and the arm rails going down the porch turned nearly black. why would it do this after water proofing? some folks said the railing was not cedar but pine. we sanded it down to remove the blotches. do you have any suggestions? thanks
Thompsons is useless and does more damage than good. You will have to strip it all off and start over with a better stain brand.
So you have a particular brand in mind? I’m starting to think the 2x4s we were sold weren’t cedar
See the top brands here: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
I AM IN SOUTH CAROLINA AND MY DECK IS 1YR OLD. IT’S FULL SUN. I STAINED DECK WITH OIL BASE STAIN AND IT DIDNT LAST; SO I CLEANED THE DECK AND PUT ANOTHER COAT OF STAIN ON IT BUT IT IS TURNING BLACK. I WAS TOLD THAT THE WOOD IS YELLOW WOOD THAT IS TREATED. WHAT SHOULD I DO TO RESTORE DECK. THANK YOU FOR YOUR HELP.
Post some pics in the comments so we can properly help.
Hello, Thank you so much for your website. I have a new pressure treated lumber deck that is located in North East, Md. It is 600 sq ft and is an L shaped deck. It was built in the spring and we have done the moisture test to make sure it is ready to stain and it says it is. It gets constant sun exposure on part of it and the other is more shaded with only morning sun. I am a senior and am looking for a stain that lasts longer with lower maintenance and prefer one coat. I have tried the solids and semi solids in the past and we had issues so we have decided to try an oil based transparent stain. We also share our deck with our dog. Lower voc is something I would like to use but am not dead set on it. I have been recommended to get Preserva wood, Ready seal, Armstrong & Clark,, PPG Proluxe/ , Sikkens, Penofin, or TWP. In your opinion which stain do you feel would best suit my needs? I am also open to other suggestions on brand and type. Thank you so much for your time. Sorry for the duplicate postings. I originally forgot to post photos and was having trouble. I would like to stain this week if possible before the weather changes so any info would deeply be appreciated.
Clean and brighten for prep and use the TWP or Armstrong Clark Stains.
Thank you for your quick response. Do you think this is ready for stain? It was built in late may. We were advised by someone else to wait until next spring but are afraid due to snow over the winter. How long do you recommend to wait before staining? Our moisture is between 9-12% when using a moisture meter. Also how long after cleaning do you advise to wait before staining?
You can stain now or Spring. Wait 48 hours after prep to stain.
Hello … Thank you for maintaining such an informational website! We are looking for a prep and stain recommendation, please.
Last year we cleaned and brightened the deck with Penofin products – intending to use Penofin Verde (Mission Brown). But we hesitated based on some of the reviews, although felt if we encountered problems, we could follow with Penofin Verde (black) the following year, as black would match the house, too. We are not opposed to this option.
We definitely would like an absorbing product as our previous experience with a peeling deck was a nightmare.
The deck boards are close together, so it holds snow for quite a while. Additionally, sand seems to get moved around the surface without freely falling between the boards, which may add to the wear? If you have any experiencing on widening the gaps, we are also open to that advice.
Clean and brighten for prep again and try TWP stains or Armstong Clark stain.
Why do you have sand on your deck?
We have a gravel driveway and operate our business from home, so work boots bring sand onto the deck, along with our two boys and dog 🙂 It just seems that the dirt/sand doesn’t fall through the board spacing very well, I wasn’t sure if this would increase the wear and tear on stain or not.
Also, I forgot to add that the deck is on the north side of our house – the areas that don’t have sun exposure are prone to a bit of mildew each spring.
Many Thanks
There is no way we know that widens the gaps.
Are you able to advise on what color in the TWP 200 series gives just a natural “wet” look similar to the TWP 115 ? It’s $100 USD to get a few samples shipped to Canada and photo galleries of the 200 series seem to be lacking across the internet. Thanks!
TWP 203 Cedar Gold.
We just installed a new tiger wood deck. At first we cleaned the deck with a pressure washer. Then, the next day, we put stain on it (I know, we didn’t wait the 48 hours to let it dry…totally our fault). The stain never dried. We put it on with a 3/8 nap roller, like the can says, IPE oil. It never dried, just stayed sticky.
So, we bought the Restore-A-Deck stain remover and balancer and put it on just like the bag says, it didn’t seem to take the stain off, looked like it still had residue on it.
So, we repeated the process with the Restore-A-Deck stain remover and balancer. We tried a few spots with the stain, and it turned yellow. So, we just did the stain remover and balancer again (now it is 3 times), and the deck just looks VERY dark.
Can you help us? This is how it looks now
Brighten the wood to neutralize and restore the color. Leave alone for a few months then prep and stain. You cannot stain new wood right away: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
Thank you……NO one had told us that before! Thank you for your help!
Hello –
I have a deck in North Carolina, pressure treated wood, lots of sun all day. Last two times I’ve used Sherwin Williams solid stain, and prefer to keep a darker solid color going forward so I don’t have to completely strip down to bare wood. I’ve found coverage to be ok in past, but it’s failed immediately after application in that it’s always showing dog paw prints (muddy back yard often) and they don’t wash off without leaving major marks. Any suggestion to help rid of constant paw prints? No real mildew problems either.
Nothing we know of will stop muddy paw prints. As for the best solid stains, see here: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
Southeast Virginia – Virginia Beach
Morning sun. Starting slightly before noon, shade starts to move across deck. Fully shaded by 5:00pm during the summer.
Half of the deck flooring was replaced 6 months ago with ‘premium’ pressure treated boards. The other half and the railings were installed before we purchased house over ten years ago.
Slightly in the more shaded area where the table is.
Wouldn’t say it failed, it’s just time to re-do and apply for first time to new boards.
Thompson water sealer.
Prep well first and try Restore A Deck Stains or Armstrong Clark stains.
Hello, I have a deck railing that is several years old and was stained with a light transparent color. I now wish to stain it a solid black. From your list of preferred products, I didn’t find one that offered a black stain. Can you recommend one? Thank you
We do not know of any brands that have a solid black deck stain. Sorry.
Thank you for your quick response. By chance can you suggest who might have the darkest/blackest tint and if you would have any performance concerns with its use?
Much thanks!
Top solid stains: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
You would have to find the top brands and see their color charts for a black color. We do not ever apply black so no experience.
Scott – thank you for your help. Using your link to Defy, I wasn’t able to see all of their color options. They now have a Dark Cocoa color. Please consider updating your website to allow the product to be purchased with proper credit to yourself.
Unless you think it is helpful to your business, no need to update your comment feed with this note.
All the best,
That is only in the solid stain and it is a custom mix.
I meant to send you this link to their product.
As I wrote in my last update, no need to add this to your blog.
I have a 15 year old deck that is the sun most of the day. I have replaced any rotted boards about six months ago. I would like to know a good solid paint for this deck. I have used Olympic deck paint on my other deck about 7 years ago and it has held up just fine. Olympic does not make this paint any more. I was wondering if the Olympic elite is as good as their discountinued paints? thanks, GDB
Use a solid stain for a deck, not paint: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
Olympic has gone down hill since they sold out to PPG. Formulas are not the same.
We built a gable end roof over our deck 2 years ago that needs to be sealed so these questions apply to the ceiling/posts of that structure and not our deck. We live in a very wet climate, but all of the wood is under cover except for the posts. We like the color of the wood and are not very interested in changing the color with pigment. I pressure washed the wood recently and am wondering if further prep is recommended. The wood appears to be “clean.” Thank you for offering your help in determining which product would be best to use!
Heather
It has to be tinted/colored for UV protection. A clear will not offer protection from graying. The ceiling will not likely not gray but the posts will. Try a light-tinted color like Restore a Deck in Natural or TWP in Honeytone.
Thank you for your recommendations, Scott. They are very much appreciated.
Also, I read that TWP is a “wet on wet” application. Is this a requirement, and if so, what exactly does it mean? I was hoping to apply the stain to the dry wood, as it will be the wood’s first application of a product. I pressure washed the wood approximately 2 weeks ago.
Yes, two coast: https://twpstainhelp.com/twp-stain-wet-on-wet-application/
In which state is your deck located? Northern California. Six months rain, six months sun and warm to hot weather. Occasionally do get snow. 2200′ elev.
How much sun/shade does your deck get? Three decks from full sun to full shade. The same with siding on house.
What type of wood is your deck made of? One deck redwood, two decks cedar. House siding is cedar.
Do you have mold or mildew issues? Yes, on decks and house.
Why/how did the previous stain fail? Mold and mildew a big concern on decks and siding.
What type and brand (if known) of stain did you use last time? Penofin blue and red label.
Some history: in thirty years, the decks and house siding were only pressure washed with bleach, but not stripped, wood cleaned or brightened. Currently, as you can see in the back deck photo, the deck with rail siding, were pressure washed, stripped (twice), cleaned and brightened. Products used were Behr #64 stripper and Behr #63 wood cleaner. The Behr products appear to do a good job of stripping and cleaning but required a lot of elbow grease. Would you advocate different products? The small portion of the wall cedar siding (east side house photo’s) was pressure washed and cleaned with Behr #63 wood cleaner and then pressure washed again. The east deck photo has not been redone. I’ve been bouncing around from using solid stain to a semi-transparent stain. As a forester, I really like the look of the semi-transparent stain vs. solid stain. I know once you use solid stain you have to stay with it. I would appreciate your advice regarding a longer lasting, penetrating semi-transparent stain or solid stain that can be obtained in California. Thank you.
Penofin has known issues with turning black or dark in color. Try TWP 1500 Series or Restore A Deck stains. Both are much better and will not turn black like this.
As for prep, use the Restore A Deck Stripper and Brightener Kits with both additives: https://www.deckstainhelp.com/restore-a-deck-stain-stripper-booster-thickening-gel-review/
Thanks Scott. Sounds like the new additives would be good on tough stain removal areas and use regular product for less tough areas. Can Big Stretch (wood tone) caulking be used to fill knot voids and large cracks without problems re: applying TWP 1500 series stain? Also, I live in a high fire hazard area. There is a product called FlameCheck that can be added to stain. Can this be added to TWP 1500 series stains? Not sure of the efficacy of this product. I realize that you buy into more risk regarding wood sided houses, but I believe good maintenance helps. Thanks for your help.
Sorry but not sure on the caulk or Flame Check but probably okay.
Thanks anyways. Just curious, wouldn’t an oil based stain like TMP 1500 be a better choice for wood health than a water based stain like Restore A Deck?
No, both would work very well.
I am not sure the original question posted. Those 2 pics are my redwood railing – new construction. South facing, 2000’ elevation central coast CA mountains. High UV and high water performance needed, no mildew or mold issues with old deck. Composite floor, heart redwood railing. Would prefer to preserve the tones in the natural wood but know that silvering is a reality. I note you don’t suggest TWP on new wood – can you make a suggestion and should is go with a slight color or use clear? Seeking lowest maintenance, hence the composite floor install.
See here abut new wood and tips: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
Photo of railing for reference
You will have to weather and prep this before staininig.
Looking for suggestions for a high performing penetrating stain or deck oil for railings only on new construction deck. Composite floor and heart redwood railings. 2000’ costal CA mountains means high UV exposure and heat in summer, perched on a ridge we get good air flow so mild and mildew weren’t the issue with the deck we replaced. When it storms and rains it’s windy and we get average 50+” of rain yearly. UV and Water performance are key. My goal would be to lock in the natural colors and tones of this gorgeous wood but know silvering will take hold. Wood is about 4 weeks old now and I’d like to stain/seal before rains come in about 6 weeks. You don’t seem to recommend TWP for new wood so can you guide me on what you would use in my case? Do you suggest I use a semi-transparent color over clear?
Yes, it has to be tinted for UV protection.
Thank you. So I assume you want me to leave the wood unprotected through the winter then clean and brighten in Spring prior to stain. Do.you have a recommendation on brand?
Yes, try TWP Stains or Restore A Deck Stains.
My deck is in central MS that is lake front. The 16×20 deck gets full sun and the remainder of my wood is covering 1/2 a boat slip and covered with boathouse roof that will get a few hours of morning sun. The deck is treated “yellow wood” from Home Depot. I let it dry for 100 days before applying the Sherwin Williams Super Deck stain/paint. Don’t really have mold or mildew problems that I can see. The product is peeling off the deck and covered area and only lasted about 20 months.( oh, and put down 3 coats) Thanks so much for your advice as I prepare to correct the problem with a far superior product. Will post my pics here ?
You have a solid stain so you will need a solid stain again. See here for prep: https://www.deckstainhelp.com/how-to-reapply-a-solid-color-deck-stain/
and here for solid stain advice: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
so Scott, just to clarify , the stains that you have recommended will cover my Sherwin Williiams Super Deck solid latex stain ?(if i prepare as you suggested)
Thanks for your help, David
Yes, correct.
Hi Scott after doing some homework i found this statement from “restore-a-deck : “ will not remove solid color stains, paints, polyurethanes, or excessively over-applied acrylic based coatings”. That said,I used Sherwin Williams superdeck solid stain and wondering if i should spend the $60 for the product ? Should i expect some removal of the paint that is already peeling? I’ll also prep with a belt sander but not remove all the original solid stain. Certainly appreciate your input.
No deck stripper will remove a solid stain fully but the RAD Stripper will remove what is loose so you can cover the intact stain that is not peeling. You can also accomplish this by sanding the peeling stain.
Sounds good . Thanks for your time and input 🙋🏼♂️
In which state is your deck located? – Arizona
How much sun/shade does your deck get? 50% in shade, 50% faces south into intense AZ sun
What type of wood is your deck made of? redwood
Do you have mold or mildew issues? no
Why/how did the previous stain fail? substantial fading in less than 2 years, esp. where sun exposed
What type and brand (if known) of stain did you use last time? SuperDeck Transparent (1906 Valley)
Strip and brighten for prep using Restore A Deck kits. Stain with Restore A Deck Stains or TWP Stains.
