🏆 Top Picks Summary
- Best Overall: TWP 100 or 1500 Series
- Best for Old Decks: Armstrong Clark
- Best Budget Option: Restore-A-Deck
- Best Penetrating Oil: CUTEK Extreme
| Product | Type | Durability | Ease of Maintenance | Key Strength | Best For |
| TWP 100 | Semi-Transparent (Oil) | 2–3 Years | Easy | Proven performance, deep penetration | Most decks |
| TWP 1500 | Semi-Transparent (Oil, Low VOC) | 2–3 Years | Easy | Better VOC compliance, similar performance to TWP 100 | VOC-restricted states |
| Armstrong Clark Wood Stain | Semi-Transparent (Oil) | 2–3 Years | Easy | Excellent oil penetration + conditioning oils | Dry, aging wood |
| Restore-A-Deck Wood Stain | Semi-Transparent (Water-Based) | 2–3 Years | Very Easy | Simple prep system + easy recoat | DIY homeowners |
| CUTEK Extreme | Penetrating Oil | 2 Years | Very Easy | Deepest penetration, no film buildup | All Wood types |
| Defy Extreme | Semi-Transparent (Water-Based) | 1–3 Years | Moderate | Strong UV resistance with zinc nano-particles | Sunny/high UV areas |
- Best Overall Deck Stain: TWP 100 Pro Series — A deep-penetrating, oil-based semi-transparent stain that offers excellent durability, easy maintenance, and consistent performance for up to 3 years.
- Best Semi-Transparent (Water-Based): Restore-A-Deck Semi-Transparent Wood Stain — A user-friendly, UV-resistant stain that can be applied to damp wood, allowing prep and staining in one day.
- Best Oil-Based Alternative: Armstrong Clark Wood Stain — A penetrating oil formula that conditions aging wood while providing long-lasting protection and easy reapplication.
- Best for VOC-Restricted States: TWP 1500 Series — An EPA-registered preservative with strong UV and mildew resistance, ideal where traditional oil-based stains are limited.
- Best for UV & Mildew Resistance: Defy Extreme Wood Stain — A water-based formula enhanced with zinc nano-particles for superior UV protection and mildew resistance.
- Best Semi-Solid Stain: TWP Pro Series Semi-Solid — Offers richer color, excellent UV blocking, and better coverage while still allowing some wood grain visibility.
- Best Solid Color Stain: Restore-A-Deck Solid Color Stain — A durable, breathable coating that resists peeling and works well for older or heavily weathered decks.
- Best Deck Resurfacer: Gulf Synthetics Deck Revive — A thick resurfacing coating designed to restore heavily worn or damaged wood surfaces.
*Free Shipping Included
✅ How I Rate Deck Stains
- Durability in real-world conditions
- Ease of application and maintenance
- Resistance to peeling and wear
- Overall long-term performance
- Wear and tear after 2 years
- Oil-Based:
- Deep penetration
- Easier maintenance
- Water-Based:
- Better UV color retention
- Faster drying
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
3. Defy Extreme Stain
Type: Oil-Based Semi-Transparent- Durability: 2–3 Years
- Maintenance: Easy recoat, no stripping needed
- Best For: Most decks (pressure-treated, cedar)
- Why It Stands Out: Deep penetration and consistent long-term performance without peeling
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Type: Water-Based Semi-Transparent
- Maintenance: Very easy, simple prep system
- Best For: DIY homeowners and quick projects
- Why It Stands Out: Can be applied to damp wood, allowing prep and stain in one day
My Test Deck Stats
UV Exposure: 50% Full Sun
- Type: Oil-Based Semi-Transparent
- Maintenance: Easy reapplication
- Best For: Older, dry, or weathered wood
- Why It Stands Out: Contains conditioning oils that help restore dried-out wood
My Test Deck Stats
Deck Square Footage: 600
- Type: Semi-Solid (Oil-Based)
- Durability: 3 Years
- Maintenance: Moderate
- Best For: More color coverage with strong UV protection
- Why It Stands Out: Rich color options while still allowing some wood grain to show
My Test Deck Stats
When Tested: August 2023
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Type: Oil-Based Semi-Transparent (Low VOC)
- Maintenance: Easy
- Best For: VOC-restricted states
- Why It Stands Out: EPA-registered preservative with strong UV and mildew resistance
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Type: Water-Based Transparent
- Durability: 1.5–2.5 Years
- Maintenance: Easy
- Best For: Maintaining a natural, “bare wood” appearance
- Why It Stands Out: Unique formula designed to preserve the natural color of new wood while still offering UV protection
My Test Deck Stats
Stain Color Used: Chesnut
- Durability: 2 Years
- Best For: High UV and mildew-prone areas
- Why It Stands Out: Zinc nano-particles provide superior UV protection and mold resistance
My Test Deck Stats
Stain Color Used: Cedartone
- Durability: 1-2 Years
- Best For: DIY users and quick, forgiving applications
- Why It Stands Out: Extremely easy to apply with no back-brushing needed, but shorter lifespan than higher-end penetrating stains
My Test Deck Stats
- Type: Penetrating Oil
- Maintenance: Very easy (clean and reapply)
- Best For: Exotic hardwoods (Ipe, teak) all wood types
- Why It Stands Out: Extreme penetration with no film buildup, making long-term maintenance simple
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Best Deck Stain for Old Wood
- For new pressure-treated wood, wait until the wood has weathered and is able to absorb stain (typically a few months), then prep and stain.
- For older pressure-treated decks, proper cleaning and brightening will restore the wood and allow for better stain penetration.
- If you want to maintain cedar’s natural look, use a lighter or natural-tone stain.
- If you want longer UV protection, choose a slightly darker tint, as it will hold color longer.
- Wood Condition: New, weathered, or heavily worn
- Desired Look: Natural grain showing vs solid color
- Maintenance Preference: Easy recoat vs long coverage
- Climate: Sun exposure, moisture, temperature swings
✅ Deck Stain Types Explained
- Transparent/Clear Sealers: Natural look, less protection
- Semi-Transparent Stains: Best balance (most recommended)
- Semi-Solid Stains: More color, moderate maintenance
- Solid Color Stains: Maximum coverage, higher maintenance
Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
- Film-forming coatings on older decks
- Over-applying stain
- Choosing based on color alone
- Skipping prep
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly. See my Deck Cleaning Guide for best results!
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time. See my How to Stain a Deck tips for the best results.
✅ Best Deck Stain FAQs
Quick Tip:
What is a deck stain?
⏳ Durability & Maintenance
🎨 Appearance & Color
🛠 Application & Usage
🆕 New Deck Questions
- Smooth wood: Wait ~3 months
- Rough wood: Can stain once clean and dry
- Kiln-dried wood: Wait 1–2 months
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
I have a mahogany large deck that gets a lot of wear and tear fro the weather what is the best coating to use without changing the color.
See here and you must have tint for UV protection so your color will be enhanced.
New wood tips: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
Thank you in advance for your help!
I finished building a deck in Austin, TX about a month ago. I used pressure treated lumber from Home Depot– I’m guessing pine. The deck gets full sun in the morning and early afternoon, with shade in the late afternoon/early evening. I haven’t had any mold/mildew issues on the deck or older things like the porch. I don’t want it to look terrible, but I’m much more interested in extending the life of the deck than I am in bringing out the beauty of the cheapest pressure treated lumber I could find. Thanks!
See here about new wood.
Great site and helpful info! I’m about to tear out an old cedar deck install a new cedar deck in Seattle. If I plan on doing a deep clean and brighten each summer, is it possible to apply only one coat of TWP clear oil each year and have it be protective? Or, are two coats necessary on a yearly basis? On my previous deck, I think two coats of the bad water based stain I used was too much.
You can do one coating yearly but you must use a tinted color for UV protection. Their Honeytone is the lightest tint.
Thanks. I’m hoping a yearly approach will keep it looking better and in the long run easier to maintain.
TWP is very easy to maintain. Just clean and brighten prior to reapplying.
ANSWERS TO YOUR SIX QUESTIONS: 1. In which state is your deck located? INDIANA 2. How much sun/shade does your deck get? Almost completely shaded, filtered sun almost all day 3. What type of wood is your deck made of? Part of it is treated lumber that was down about eight to ten years before the first application of semi-transparent stain (PPG Paramount) and the rest is cedar that was down about 22 months before the first application of semi-transparent stain (PPG Paramount) 4. Do you have mold or mildew issues? No 5. Why/how did the previous stain fail? Massive peeling on the horizontal surfaces after about 10 to 14 months after application (it’s been about 19 months since it was applied right now, as of 07/2022). 6. What type and brand (if known) of stain did you use last time? PPG Paramount Semi-Transparent stain. Trying to figure out how to proceed. I’ve been in communication with PPG and they are willing to send me $335 for stain and the stripper to try and re-do, but also must sign a waiver and release form, since they seem to know there’s a “PPG issue”. I’ve described in great detail and sent photos to them and they still cannot provide any rationale or reasoning as to why it has failed so badly and so quickly. I initially powerwashed with a cleaner and let it all dry for several days before application of the stain. The different sections of the deck, stairs, and “bridge” had been in place and weathered/leached out for two to ten years, as noted above. Based on your guide, I’d like to use the TWP-100 Pro but since I’m in Indiana, I apparently cannot. The second choice looks to be the Restore-A-Deck semi-transparent product, but not sure what to use and how to prep the deck, given all of the peeling that has happened. Also, given that we used “Rustic Cedar” color – would like to be able to at least come close to matching, since the balusters and posts (the vertical surfaces) are still holding up OK and don’t intend to re-do those at this point. I compiled the following steps, based on several back-and-forth emails with PPG and sent them back via email to the PPG rep, but still waiting to hear back from her to confirm or tweak these steps: 1) Clean/power wash the wood using a wood cleaner; 2) Strip the wood, using the stripper that PPG recommended; 3) Sand the wood in the direction of the grain with a belt sander and 60-80 grit sandpaper; 4) Wash it down again to get rid of the sawdust/etc.; 5) Let it dry for a couple of days(????); 6) Apply the new product/finish and back-brush the rolled areas to work the stain in; 7) Put a second thin coat on the high traffic areas within 4 to 72 hours of the first coat??? Obviously, these would entail a LOT of work, but I also don’t want to… Read more »
Steps in response to yours:
1. No need to clean if stripping.
2. Correct.
3. After stripping, let dry and sand what cannot be stripped.
4. You must use a wood brighener after stripping. Use this and pressure wash rinse after.
5. If using TWP, then yes.
6. Sort of. TWP and RAD are applied wet on wet if doing two coats so your second coat will back brush it evenly.
7. No, needs to be applied wet on wet: https://www.deckstainhelp.com/deck-stain-instructions-for-wet-on-wet/
Try the TWP 1500 Series if you want TWP. it is just as good as the 100 Series but allowed in IN.
Thanks, for the quick reply and point-by-point responses, Scott!
So given the description/background and what you see in those photos, do you think stripping & sanding + brightner has the best chance to salvage this mess (vs. power washing/cleaning or any other combination/process)??
And following those above steps and using the oil-based TWP 1500 Series product would give the best chance of success?
And lastly – I suppose I should go ahead and sign the release and take the money that PPG is offering, assuming I’m not going to get any further relief, beyond the product replacement cost that they’re offering and nothing for our time & effort and all of the work of re-doing this?
Yes, strip, sand, and then brighten. TWP 1500 is a great penetrating stain and will make future reapplications much easier.
Take what you can get from PPG but we would not use their stains.
Thanks!! Appreciate the advice.
Upstate NY
Full Sun
Pressure treated Pine not previously stained only a year old
Hello, we are looking for a semi transparent stain and sealer that has a mahogany tone, that can stand up to our extreme winter weather.
Look at Restore A Deck Stain in Light Walnut or Armstrong Clark Stains in Chesnut or Natural Oak.
Oregon
Filtered sun/mostly shade, light traffic
Cedar
Applied SW Superdeck Oil semi-trans over well-prepared deck with new and old boards. The crew did a lousy job, left bubbles and dribbles all over, and the contractor has agreed to strip and redo the deck (the rails are fine). I’m not impressed with Superdeck and need a good oil-based transparent (or a more transparent semi-transparent if that makes sense).
TWP 100 Series or Armstrong Clark Wood stains are much better oil-based stains.
I live in Colorado and I’m planning to stain a deck, but with a solid colour i.e blue. Do you have any recommendations for an oil based product. Water based stains don’t appear to weather well. Thanks in advance
You will not be able to find a solid color oil-based anymore in CO, only water-based.
Do I need to use the same stain stripper and wood brightener
California
Morning sun
Redwood
Minor mold, mildew
previous stain peeled off, possibly due to applying too soon after installation
arborcoat, non penetrating was used previously
deck has been stripped and brightened with Cabot brand products
I want a transparent, penetrating/oil based stain that shows the beautiful redwood
Restore A Deck Semi-transparent Stains or Armstrong Clark Stains.
Five year old deck, Seattle area. Part gets fair amount of sun, part near the house is always in shade. Cedar decking and rails. Adjacent Douglas fir leaves pitch and black spots that I assume are mildew. In shady areas, finish is solid, but has turned too yellow for our taste. In sunny areas, finish has become patchy, especially after pressure washing and there are some underlying darker areas. Deck has been twice sealed using Olympic Maximum clear.
Because we want to change products, I am in the process of sanding the deck using 60 grit to remove the current finish.
Photo 1 is shady area, photo 2 is sunny area, photo 3 is after sanding. Photos 2 and 3 are not that gray. To my naked eye, they seem natural colored with a bit of graying.
Currently thinking a semi-transparent stain, either natural or cedar color would be better than clear.
Recommendations would be much appreciated. Want to make a good choice to allow simply using another coat in the future. Thanks in advance.
Stripping and brightening would be easier and you still have some old stain embedded in your wood after sanding that needs to come out. After the prep is done, try TWP 1500 Series or Restore A Deck Stains.
Thanks for that.
Stripper/brightener would be easier. I suspect there will be some sanding to be done here and there.
Would you recommend the RAD stripper additives, or might I get by without?
I hear oil-based tends to last longer, so I’m leaning toward the TWP 1500.
I’ve seen recommendations for one coat and a wipe, or two coats wet on wet. Is two coat necessary, or might one be sufficient?
By the way, what does “wet on wet” mean?
Using the additives would make it easier to strip. See this about wet on wet and TWP: https://twpstainhelp.com/twp-stain-wet-on-wet-application/
We’d like to get your feedback regarding our 15-year-old deck in Bellingham Washington. Here are the answers to your questions:
1 – 15-years-old
2 – Three years ago our house painter applied Benjamin Moore Arborcoat Solid Stain – he said it was best to use the solid because the wood was cracking, but that stain has peeled – badly – see photo #1.
3 – We are trying to decide what to do next. We have tried to remove the old stain with Benjamin Moore REMOVE, but it took three coats and there is still some stain that will not “remove.” see photo #2. We’ve also used Behr Stripper, and it did better, but still left paint that will not come off – see photo #3.
4 – The stain before the BM Solid was Sherwin Williams transparent
5 – There are no mold or mildew problems
6 – From what we can determine, the cracks in the decking allowed water to get under the solid stain and make it blister and then peel.
Our Questions:
Should we switch to the stripper you recommend?
What is the best product going forward after we strip and brighten? Do we have to use a solid stain since it is unlikely that we will be able to remove every speck of the old stain even with sanding. Do you recommend a “re-surfacer” for older wood?
THANK YOU SO MUCH for your input!!
You cannot fully strip a solid stain. Best to strip off as much as possible, let dry, and then sand off any more peeling stain. You can cover the intact stain after: https://www.deckstainhelp.com/how-to-reapply-a-solid-color-deck-stain/
Recoat with a quality solid stain after. See here: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
My railings are in Seattle, Washington, a short walk to Puget Sound. Huge evergreen trees to the south. Moderate summer sun. Lots of shade and rain half the year. Lots of pollen from big trees.
Railings posts and tops are clear cedar. Most sections are 15 years old. The horizontal surfaces tend to become dirty looking and hard to clean.
Last used Armstrong Clark 2 years ago and have now pressure washed everything with 30 second cleaner and have sanded off most top horizontal surfaces. Just bought Penofin pro-tech stripped to try.
Considering using Penofin or TWP stain this time. I even considered applying a marine spar finish to top railings, but I don’t know how that would work with rest of railings using a different finish. Also considering stripping/sanding balusters and applying new finish to entire railings… and hope to stick with that brand for continued maintenance.
TWP is much better than Penofin as Penofin has issues with darkening in color or turning black. Never apply a spar varnish to a deck, it will peel.
Thank you. And to be clear… We are staining the railings, not the deck (the deck is Ipe and we have let it go gray). The railings are cedar and the top surfaces tend to get dirty and darkened over the year.
If we go with TWP, what sort of cleaner should we periodically use to remove pollen/mildew and not compromise the stain?
Warm water and dish soap.
I have a wraparound deck that get sun different part of the day see picture attached. I live Hampton VA; right on, the Chesapeake Bay the deck is about 5 year old that is ground contact pressure treaded wood (not the yellow wood) and does not have any stain or sealer. The only spot that has green staining are the steps. I would like to have a very light-colored stain
Try Restore A Deck Wood Stain in Natural tone or Armstrong Clark Stains in Amber color. Make sure to clean and brighten the wood first for prep.
would I need pressure wash the deck first
Pressure wash while using the cleaner and the brightener.
Have have some knot what can I use to fill them in
You can’t. Wood fillers do not work on decking and will not stain to blend.
Great
I was looking to make a deck from wood pallets (in Virginia). I wanted something that would protect the pallets for as long as possible. I don’t care about the look or ease of application. The pallets will be on cinder blocks so they are not directly on the ground. I am planning to use pressure treated fence boards to be the floor of the deck. What would your recommend for the longest protection possible because once I put the fence boards down I will not be able to re apply protectant on the pallets. Thanks for all that you do!
TWP 1500 Series or Armstrong Clark Wood Stains.
What is the best product to stain and seal a deck that is in full sun. How often should this be done to keep boards from rotting. We have gone through this before. Built a large deck (the width of out house). We were constantly every year replacing many rotted boards. This last time the joints under the deck had to be replaced in many places because the boards could not be nailed down, so we decided to replace the entire flooring and many rotted joists. Now we have the task of sealing/staining again. Please help with suggestions on product to use.
We used treated wood. I think that the sun in our problem here.
You are rotting from the undersides so a deck stain on top will not prevent this. As far as the best stains to use, try TWP 1500 Series or Armstrong Clark Wood Stains.
Lobe this site !! My new deck (Jan.22) in Kentucky , all day sun minus about 4 hrs in the am. Not covered. I want to stain floor and top rails and support posts. And paint ther barestera I think like the first pic the second is my deck.
See here about two-toned decks: https://www.deckstainhelp.com/why-have-a-two-toned-deck/
Hello, we live in Denver Colorado area and have a mahogony plank deck that is half covered and half exposed. The deck is 18 years old. We had always been using a Sikkens SRD Cetol Transparent stain on it hat always gave it a very glossy finish that we really loved even though the can said Matte on it. We always just powerwashed it and applied the stain every year or 2. Well, this exact stain has changed, been reformulated/rebranded or whatever and even though it is still described as Kikkens SRD Cetol Transparent Matte the new stuff goes on VERY dull and sheen doesn’t look anything like we had. Any recommendations on a good quality product that will give us a glossy look?
No. Having a glossy coating on a deck leads to many issues with peeling and dry rot so deck stains are not designed to be glossy. On another note, you cannot apply a different brand of any coating over what you have. Your current coating will have to be fully sanded down to the bare wood.
Greetings, I have a 20+ year deck on the front of my house in Lake Tahoe, Nevada. It is fairly high altitude (6300′) very low humidity environment. It is east facing and gets lots of morning sun and afternoon shade. Definitely some UV as Lake Tahoe is sunny 270 days per year. Most of the deck is covered by a roof however part of it is not and in the winter the part of the deck that is not gets icy from snow melt from my roof running onto the deck and reforming ice. It stays that way for a few months out of the year.
The floor of the deck is redwood. The railings are pine. My wife and I have fully stripped and rough sanded it (50 grit) to remove the 20+ years of prior staining. There are no mold issues. The prior stains have failed due to peeling. The last product we used was Sherwyn Williams Solid Color Alkyd Stain. It lasted less than a year in the area where the ice forms.
Would you be able to recommend a product that will last a couple of years and is easy to prep and restain when the time comes. I am trying to get my maintenance time down to less than two days every couple of years and to not have to remove everything like I did this time. The stain on my house is the solid Sherwyn Williams on cedar shake siding-milk chocolate brown. We would like to roughly match the deck color with the siding and have a neutral tone like a grey on the railings.
I have attached some pictures however part of the deck was shaded. if you need more let me know.
Regards,
AR
Try Armstrong Clark Stains or TWP 1500 Series. Both are penetrating stains that can be cleaned and reapplied as needed.
Thank You
What are the downsides to using TWP 100 instead of TWP 1500 given my objective as described above? It has a color variation we are interested in as we wish to use two tones. one for the deck and one for the rails.
No downside.
Thank You
New 12’ x 36’ PT deck in Maine. What stain would you recommend? We shovel snow off the deck in winter.
See this article about new wood: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
Thanks for earlier advice re stain treatment of new deck boards (treated). A related question: the boards (#2/Home Depot) have a fair number of knot holes. Some are superficial, others deeper. Should they be filed? If so, what kind of product is most
reliable, and is stainable? My suspicion is that any product may crack in the short
term. Thanks!
No, we never suggest wood filler on decks: https://www.deckstainhelp.com/wood-filler-for-decks/
Hello, after viewing your video on the best deck stains, I would like to know which one would be best for my deck. It’s only been stained once 8 yrs ago in 2014. It was built
summer of 2008. It’s Pressure treated wood. We waited 6 yrs to stain it after it was built. I just pressure washed it 2 weeks ago and now I am looking for the best stain that lasts the longest and preserves the wood. Its still in great shape but with all the rain we’ve been having it had a lot of mold and mildew. Can you please let me know which stain would be the best – I would like something to fill the cracks in as well. And a semi transparent look with a natural to medium color. I live in upstate NY about an hour from NYC…and also how many coats and is water based or oil based better… also would I need a seal coating? Thanks hope to hear from you soon!
You cannot fill cracks with a stain or sealer and we strongly suggest never trying to use a crack filler. It looks bad on decks. Cracks are normal in decking so just leave them as is. As for the stain, look at Armstrong Clark Stains or Restore A Deck Stains.
Never seal over a deck stain, it would peel if you did.
what about TWP
That would work as well. You need the 1500 Series for NY.
Happy to find your website. Lots of great information! Can you suggest a stain/sealant for me.
Located in Southern Ontario Canada, deck is Sierra Brown Pressure treated wood, shade in morning, full sun exposure in afternoon and evening, surrounding a pool. Installed for 2 years. Looking to protect wood and provide a darker ‘wet’ appearance. Some tendency for mildew as I live in a high moisture valley. Full snow covered in winter.
TWP 200 Series or Restore A Deck Stains would work the best.
I have used Australian Timber oil on my ceder deck for 2 years on a new cedar step.
The first year was great .
I gave it another coat last summer and this spring it is all peeling off. I would like to know why and how to proceed from here.
The stringer and side of the stop have weathered ok.
Strip and brighen of prep to remove all. Use Restore A Deck Stripper/Brightener Kits. Stain with TWP 1500 Series after or Armstrong Clark Stains. Both are much better than the Cabot.
Florida new redwood pressure treated 2×6 deck with a messy canopy of crepe myrtle trees mostly shaded with some sun 20×28 deck. Being replaced from cabots Australian timber oil failure. Mold and algae can build up from tree droppings any suggestions on semi transparent stain and sealer thanks
I’ve got a 25 year old deck in Northern Michigan that I’ve used Australian Timber oil on. I agree it’s not what it used to be-didn’t penetrate as well and had peeling on wood I replaced (after waiting 1 year after to seal).
it’s been 3 years since last application and ready for reseal with something else.
Can I do RAD full strip and change to water soluble? Would it be better to keep with oil base and if so do can I skip the stripping step?
You have to strip no matter whan switching brands, it does not matter if oil or water-based. Use both RAD Stripper additives for this.
Suggestion for best stain? It’s PTPine. Water soluble or oil?
Either. Restore A DEck Stains if you prefer water-based. TWP stains if oil-based.
Longer process than anticipated-to remove old ATO I stripped twice (long story), powerwashed closer than expected to remove old film, sanded to get remnants/knock down wood fibers.
I’m now ready to brighten! Did a test patch of brightened spray then rinse with hose for 20 minutes. There was no visible bubbling reaction during that time of rinsing. Thinking it’s been so long from stripping and a couple good rains there might not be any residual stripper to react?
Do I need the full 20 minutes of rinse? I don’t want to ever do the stripping step again so I don’t want to do anything incorrectly at this point
Thanks for the advice!
Yes, you want to rinse the brightener well so there is no reaction with the stain.
Excellent article. Restored deck surface with treated pine (Home Depot) that has cured now for 6 months. Please recommend best stain for such a surface. Missouri: hot summers and relatively mild winters. I have assumed that stain would be followed by a sealer. Is this accurate? I am skeptical of the combined stain-sealer on the market. Please advise and thanks again for a most helpful article. I would hope to preserve some of the grain effect, so probably the semi-transparent products would be appropriate?
All deck stains act as sealers as well and you cannot apply a sealer over a deck stain. Try Retore A Deck Stains or TWP 100 Series.
Thanks for the clarification re stain/sealer. Will visit the TWP 100 Series.
Springfield, Missouri. East side of house in sun all morning with gradual shade progressing in the afternoon. We have periods of very wet weather and periods of very dry weather. Newer deck of untreated Yellawood, installed about 18 months ago. Cleaned it in May with Wolman’s cleaner/brightener (now by Rustoleum). Mildew had grown on rails and spindles. I know I will need to prep again before I stain it. My priority is something that will protect as long as possible. Prefer water-based but not sure whether semi-transparent or solid would be better.
Used Sherwin-Williams semi-transparent water-based on former pressure-treated wood deck. Looked great initially but poor performance over 1-2 years.
Try Restore a Deck Stains. They have both solid colors and semi-transparent colors.
We have a newer (2years) cedar deck at lake kachess in Wa state. Hot morning sun and lots of snow nov-April, used Thompson’s water seal and it all peeled off. Obviously it’s not meant for extreme weather shift! Looks like you recommended RAD or TWP which holds up better to 90plus in summer and single digit winters?
Sanding whole deck after only one summers use!
TWP or RAD would both work better for you.
Best article on decks I have ever read. Thank you. I am widow who because of my husband’s illness let out porch go. I stained it in the summer of 2018. I used an Olympic maximum stain & sealant cedar clear tone. I live in Michigan. Deck gets hot west side sun & is main entrance. Porch rails still look good but floor is awful. Help!
Post some pics so we can help with your project.
I live in Ohio. had a new deck built….want to apply a top rated water sealer not stain as I want to preserve the natural wood grain….so many choices here so much reading….whats the best suggestion for my need?
You cannot preserve the natural color of the wood with a clear sealer. It will gray naturally in a matter of months. It must be a tinted stain for UV protection from graying.
I have a year old deck never stained, what’s the best product to use and process?
Try the TWP Stains or Restore A Deck stains. Make sure to prep first with a deck cleaner and then a wood brightener.
I live in Ohio, deck in sun, yes to mildew. Previously used Behr deckover which chipped, one board rotten ( pine). Stripped all deckover off with diamabrush, which was a lifesaver. Advice would be greatly appreciated. Don’t ever want another mess like this again.. Thinking semi transparent
Yes, use a penetrating semi-transparent stain. Try TWP 1500 Series or Armstrong Clark stains.
I have a wooden deck that is over 30 years old. The wood is slightly rough and is splitting some. I cannot replace it now. I used One Time Wood about 10 years ago and it held up surprisingly well. My deck is under massive maple trees and gets very little direct sunlight. I live just southeast of Cleveland Ohio. There is no mold or mildew. I will be pressure washing the deck this summer. What would be a good product for my deck? Thanks
You will need to strip the deck when pressure washing to remove the OneTime and then brighten it after. You have to remove this coating before using anything else. Try TWP 1500 Series or Armstrong Clark stains.
I purchased a home in the Midwest in Southern Indiana. The previous owner put a deck paint on the treated lumbar deck boards. Since the purchase the high traffic areas have flaked and so I decided to pressure wash and repaint. Well, most of the paint came off. There are still spots that stayed adhered pretty well and of course the deck sides and posts are still painted (not pressure washed). I am curious if there is an application I can put over the bare lumbar as well as the small paint spots that are still remaining? I was thinking I could burnwith a weed burner, removing the stick on paint and giving the wood a cool looking finish then applying a sealant. Possibly using a black or dark stain/sealer over the deck as is? Even going to the extreme of stripping the top boards of the deck with a diamond tipped angle grinder head that I’ve seen advertised. I know I can repaint but would rather try and find something that would last more than a season before flaking from foot traffic. Thanks for any advice.
No, that will not work. You cannot apply any stain or sealer over what you have unless you remove 100% of the old coating.
If you remove all of the old paint, then yes, you can use a dark color stain.
I have an old deck 40 years + I would like a Semi-Solid Stain I live in Salt lake city
Post some pics for prep help as you will need to remove prior coatings. See here for semi-solid reviews: https://www.deckstainhelp.com/best-semi-solid-wood-and-deck-stain-reviews/
Eugene Oregon. So lots of rain except in summer. Yes to mold and mildew.
Cedar, 5 years old.
Never stained or sealed. Just washed annually with oxiclean or pressure washed.
Deck gets more shade than sun.
Try Restore A Deck stain or TWP 100 Series.
Central New York, South facing covered porch, pressure treated lumber on log home. Exposed to afternoon sun, halfway toward house. After a couple years the stain, opaque, is peeling and looks awful. Would love a penetrating stain that doesn’t peel. Also, our dog makes grand entrances and it shows!
You cannot fully strip off a solid stain so you will have to power sand this all off to remove it. Do you want to do this to use a semi-transparent penetrating stain?
Hello Scott – I live in Connecticut and have a 30 year old pressure treated deck which appears to have been treated several times, most currently (I’ve learned) with a Cabot Semi Transparent Oil stain about a year ago. That stain appears to have failed (faded), resulting in my pressure washing the deck, followed by use of the Thompson 3 in 1 brightener. The results of that effort were good, though certain boards appear slightly darker than others (due to shade I assume) with some displaying green patches which I believe to be algae. I assume sanding to be required at this point followed by an application of stain. Would you agree with this approach and if so, which type of stain (oil or water based) and brand would you suggest? Thank you, Scott!
Post some pics in the comments of your prep so far.
Thanks Scott for your prompt reply. The leftmost image reflects the sunnyside of the deck, the middle image the shady side (with algae) and the final image reflects the current state of the railings. Any suggestions would be appreciated. Thank you!
Hi Brian,
Strip and brighten for prep. Use the Restore A Deck Stripper/Brightener kit with both additives: https://www.deckstainhelp.com/restore-a-deck-stain-stripper-booster-thickening-gel-review/
Once prepped, try Restore A Deck Semi-transparent stain if you want water-based or Armstrong Clark Stains if you prefer oil-based.
Thank you Scott for your help! Will pursue your direction….
You are welcome. Post some pics when you are done!
Hi Scott – Just completed the Stripping and Brightening process on my 30 year old pressure treated deck as you recommended – what an amazing difference – the wood looks brand new! One question however .. there a couple of stubborn spots on the deck where the old stain simply won’t come off. Should I sand those off, then apply the RAD Semi Transparent Cedar stain (I see in prior posts that this stain may appear darker on older wood and could possibly cover the trouble spots I mentioned). What would you suggest? Thanks, Scott for your ongoing assistance!
Post a picture or two.
Scott – Have posted pictures of a couple of trouble spots I encountered when cleaning my deck as you had requested (most are on vertical surfaces or in shaded areas (as you can see, the horizontal surfaces look excellent – any suggestions? Thank you!
The darker color will show through so we would sand all the top railings, posts, and side rails. Use 60- 80 grit. It will look better this way when done.
Thanks very much Scott – will pursue your direction!
Thanks Scott for your direction regarding sanding my top railings, posts and side rails to remove what is left of the old deck stain – that process has largely been completed, though some stubborn spots do remain. At this point however, I am unclear as to how to proceed. In reviewing some of your recent posts, you mention the need to reclean and brighten the deck a second time following sanding. I had completed this step initially using the recommended RAD products and am unclear as to the need for an additional round of cleaning – could you clarify? Thanks, Scott!
It depends on how porous the wood is after sanding if you should clean and brighten it again. You want the stain to be able to penetrate and over-sanding too fine can lead to issues with the stain soaking into the wood fully. If water soaks in right away then you should be okay to stain. If it beads on the wood, then clean and brighten to make the wood more porous.
Thank you Scott – will follow the direction provided…
We live in Mpls MN. Our cedar deck is 15-20 years old and the traffic area is in partial sun and shade, rest of the deck is shade. We have had some moss grow between or on edges of parts of deck, live with lots of tree coverage. Do lighter or medium grays show more than a dark solid stain? Our home is a taupe so would like to go a little lighter gray that leans toward a greige to lighten up backyard space. Will a medium gray show dog foot prints etc. more than a darker? wanting to lighten up the space a bit since back is so shady. Thanks!
The color will not matter much when it comes to showing muddy dog prints. It will show no matter what. If you want a lighter solid stain in a gray, than look at Restore A Deck Brand: https://www.deckstainhelp.com/restore-a-deck-solid-color-stain-review/
we are in Minneapolis MN. Our cedar deck is 15-20 years old. The highest traffic area is partial sun the rest of the deck is mostly in shade.We get moss growing between some boards but haven’t really noticed mold or mildew? Previous stains only lasted a year or so and were transparent I can’t remember which brand. We have 2 golden retrievers who come and go from house to yard via the deck daily.
I live in Weirton, WV near Pittsburgh. New deck, 2×6 deck boards, all treated Lumber from 84 Lumber. Wood is dry, what kind of prep do you recommend before semi-transparent stain is applied? Is TWP 100 your choice for me? Thank you
See this about new wood as you cannot stain it yet: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
The TWP 100 Series would work well after.
Ok, thank you
Hello! I live in Colorado at about 7600 feet. I have a south-facing deck that had been stained and then painted but the paint is peeling after only a year. The wood a beautiful redwood and now it looks terrible! It was never meant to be painted but it was done without my approval. In addition, some of the boards had rotted because they were covered by some bricks. The boards have been replaced and I now want to remove the peeling paint and stain it properly. I really need some direction on what is best to use and that will be easier to maintain. HELP! Thank you in advance.
You cannot strip off paint so you will have to power sand and scrape to remove or just replace the wood if it is starting to rot.
Update. Thank you. I should have been more clear. We do plan to scape and sand it off. The 4 boards that were rotted have been replaced. The rest of the boards are fine. Once that is complete I would like a suggestion on which or what kind of stain to use. It’s very dry here in the mountains and the sun is pretty strong on the deck in the afternoon. It’s not a covered deck.
TWP Stains or Restore A Deck Stains will work after all prior coating is removed.
Update: I’m in the PNW, greater Seattle area. Deck gets full morning and mid-day sun and lots of rain.
I have an old deck made with pressure treated wood (with incisions) that has never been finished. The boards are in decent condition, very few cracks etc. which stain do you recommend? I’m trying to blend in with new deck made with Trex Enhanced Basics in Clamshell. Pictures so before and after pressure washing deck.
Prep with the Restore A Deck prep products and stain with Restore A Deck Stain or Armstrong Clark Stains.
North Central PA. Our deck is pressure-treated pine. Full sun. no mold or mildew. The last stain was Olympic put on in the spring but after winter it was peeling off. Now, its all pressured washed and ready for a better product. What do you recommend? Thank You.
You will have to remove teh old stain first. Reply back with pics for help with this. As for the stain, try TWP 1500 Series or Restore A Deck stains.
Oakland County, MI / Deck went from 50/50 sun/shade to 100% sun. / Cedar / No mold or mildew / Live in a wooded area with a lot of trees.
Cleaned deck built in 2019, just lightly power washed. Deck was originally sealed with Penofin Blue Label. Just lightly power washed the dirt off and the wood looks pretty good – but I’m not an expert! What is the best recommendation for sealing now to keep the deck in good shape?
Try TWP 100 Series or Restore A Deck Stains. You can pick it up in Bloomfield Hills at 2388 Franklin Rd.
Will do. Many thanks!
Hi, we are in upstate NY next to the Canadian border along the St.Lawrence River/Seaway. Our deck is made of pressure treated pine. We used Deckover and followed every instruction to the letter when applying it. There is a roof over the deck but still plenty of sun along the front edge. You can tell the spots where the deck over failed are due to sun, higher traffic, and snow/rain exposure. It seems obvious that the deckover didn’t penetrate the wood at all. It peels off easily. We have no problems with mold or mildew.
You will have to power sand this to fix this. It has major issues with peeling.
https://www.deckstainhelp.com/behr-deckover-review-updated/
Once we’ve power sanded all the old deck over away, what product recommendations do you have for our location? Also, thank you for hosting this site. I have a hard time with using customer reviews to choose products. You never know if the person leaving a review really understood what and how to do whatever they needed to do to get the optimal result. I’ve read through a bunch of your responses here and am ready to do whatever you suggest. You’re clearly the guru! Thank you so much again!
You want a penetrating stain. These are the best for appearance and reapplication as they can be cleaned and reapplied as needed. See tips here: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
Hi Scott, thank you for all the expertise. Can you guide us as to what to power sand with?
See for tips: https://www.deckstainhelp.com/how-to-sand-your-wood-deck/
Prep first and try TWP 1500 Series or Armstrong Clark Stains.
SW WA State, deck gets direct sun in summer months and outer boards get lots of rain the rest of the year as deck is only partially covered. We made the mistake of sanding new Tigerwood before building, which may also explain why annual maintenance is needed. We’ve used Gemini Cleaner, Neutralizer then Messmers Hardwood UV Plus each Spring so it’s time again. Have been researching online…
1) How does TWP 1500 series compare to Messmers?
2) Restore-A-Deck kit is three times the price of Gemini (same manufacturer, I understand) Is it worth the difference?
Many thanks!
Tigerwood requires annual reapplication. See this for hardwood tips and what stains work the best. https://www.deckstainhelp.com/ipe-exotic-hardwood-stain-review/
The Gemini Restore Kit and the Restore A Deck Kit Cleaner/Brightener Kit are the same price. Not sure what you are seeing that makes it 3 times as expensive?
Sorry, my mistake…I was deducing the RAD packages 300/600/1000 etc. as the square footage they completed.
I was surprised to read your comment about the Tigerwood, as I’ve read other reviews that at least imply “no maintenance for years”.
I didn’t find reference to Messmers anywhere in your reviews, but hubby will most likely stick with that, since we’ve used for several years.
Thanks for your time and expertise…very comprehensive website!
