Hi, I’m Scott Paul, an exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My review of Armstrong Clark Wood Stain is based on my extensive background as a wood restoration contractor and hands-on testing. I’m here to share my honest insights to help you make the best choice for your decking needs.See here for more info about me.
Armstrong Clark Wood Stain Reviews
Armstrong-Clark Wood Deck Stain is a semi-transparent, oil-based penetrating stain designed to condition the wood while providing UV protection and long-term durability. It uses a blend of drying and non-drying oils, which helps it both penetrate into the wood and replenish the wood fibers over time.
From my experience restoring decks since 1993, Armstrong-Clark is one of the better-performing oil-based stains when it comes to balancing penetration with color retention. It penetrates well into most wood types while still maintaining a richer, longer-lasting color compared to many traditional penetrating oils.
Overall, Armstrong-Clark is a great option for homeowners who want the benefits of an oil-based stain but with improved color longevity and durability.
8.50 Overall Rating for Armstrong Clark Stain
🔹 Quick Verdict
Armstrong-Clark Wood Deck Stain – Quick Review
- Best For: Homeowners wanting oil penetration with better color retention
- Ideal For: Extremely dry wood needing maximum penetration or very low-maintenance expectations
- Type: Oil-based penetrating stain
- My Overall Rating: 8.5/10
Armstrong-Clark is one of the most balanced oil-based stains I have used. It offers excellent penetration while holding color better than most traditional oils.
Armstrong Clark Stain Description
Armstrong Clark Wood Deck Stain is a well-respected oil-based stain, crafted with over five generations of experience in the stain industry. It comes in several formulas: transparent, semi-transparent, and semi-solid colors, offering options for a variety of wood types and aesthetic preferences.
What sets Armstrong Clark apart is its unique formulation, blending drying and non-drying oils that are applied separately. The non-drying oils penetrate the wood fibers, helping to rejuvenate and restore the wood’s natural oils. Meanwhile, the drying oils cure on the surface, locking in the conditioning oils and creating a protective barrier against the elements, ensuring long-lasting weather protection for your deck.
Armstrong Clark Stain Review
How I Rated Armstrong Clark Deck Stains
My Armstrong Clark Deck Stains review contains an 8-step process and the final average score. Each step is on a scale of 1-10.
- The appearance of Armstrong Clark Deck Stains after the Application
- Preventing UV Graying
- Peeling or Wearing
- Preventing Mold and Mildew
- Color Shifting for Armstrong Clark Deck Stains
- Ease of Reapplication
- Armstrong Clark Deck Stains Final Score
8-Step Review of Armstrong Clark Stain
Armstrong Clark’s initial appearance was a rich, deep finish with naturally enhanced wood grain showing through the stain formula. Our choice of the Cedar Semi-Transparent color had a rich cedar tone.
Upon our 2-year inspection, Armstrong Clark Wood Deck Stain in the Cedar Semi-Transparent color produced above-average UV resistance. With the Armstrong Clark, the transparent colors would deliver slightly less UV shielding due to less pigment in the formula, while the semi-solid colors would have slightly better UV protection when in full sun.
3. Wear/Tear and Peeling: 9
No peeling was detected at the 2-year point. There was slight wear on the high traffic areas, around the furniture, and on the stairs.
4. Cost Per Square Foot: 9
Armstrong Clark Deck Stain can be purchased for $49.99-$69.99, depending on the opacity of the formula. In our test experience, Armstrong Clark had one of the best spread rates of any stain. We used 3.5 gallons on our 600 square foot deck applied in one coat.
5. Preventing Mold/Mildew/Algae: 8
At 2 years we noticed some slight mold growth on top of the Armstrong Clark stain in some shaded areas. We did not detect any mildew spores within the stain as the mildew spores could be wiped away using a wet towel.
6. Ease of Application: 9
The Armstrong Clark Deck Stain was super easy to apply and extremely user-friendly. Upon the manufacturer’s claims of being able to apply in direct sunlight, we tested our application on a 90-degree day in full sun. We were surprised the stain did not dry too quickly and applied evenly in those conditions, avoiding potential issues with Applying a Deck Stain in Full Sun. There were no excess dripping issues on the railings even though we applied using a pump sprayer and back wiped with a stain brush. The semi-transparent stain applied well using this method.
7. Color Shifting (darkening) after 2 Years: 8.5
Our 2-year test of Armstrong Clark Stain in Semi-Trans Cedar color did show signs of slight darkening from its original color. We figured this was likely due to the formula’s higher solid content. The AC is over 70% solids containing linseed and paraffin oils.
Because Armstrong Clark Wood Deck Stain penetrates well and does not overly darken, it would be easy to recoat. A simple cleaning with a wood deck cleaner to remove dirt, grime, and mold spores would be sufficient prior to reapplying.
Overall Score Armstrong Clark Stain at 2 Year Period: 8.5
Armstrong Clark Wood Stain performed exceptionally well during our 2-year test. Its easy application and impressive coverage rates elevate it to the top tier of wood stains. We noticed no peeling, and the slight darkening color shift that occurred was more than acceptable. The stain is also easy to maintain and prep before recoating, which is a significant plus for long-term care.
Overall, Armstrong Clark remains one of our top choices for a professional, durable finish. It not only lasts but is also straightforward to work with, making it an ideal option for both initial applications and future maintenance.
More Info: Armstrong Clark Stains
Cost: $59.99 per Gallon, $299.99 per 5 Gallon Pail
Stain Type: Transparent, Semi-Transparent, Semi-Solid – Oil-Based
Available Colors: Transparent Natural, Transparent Cedar, Transparent Redwood, Semi-Trans Cedar, Semi-Trans Rustic Brown, Semi-Trans Sierra Redwood, Semi-Trans Amber, Semi-Trans Mahogany, Semi-Solid Mountain Cedar, Semi-Solid Woodland Brown, Semi-Solid Oxford Brown, Semi-Solid Sequoia, Semi-Transparent Chestnut, Semi-Trans Natural Oak, Semi-Trans Black Walnut for Hardwoods
Application Temperature: 50-110 F
Coats Required: 1 Coat
Coverage Per Gallon: 200-250 sq. ft
Dry Time: 8-72 Hours, Depending on UV exposure and air temps
VOC Compliant: Under 50 VOCs. Compliant in All 50 States and Los Angeles Counties
Manufacturer: Armstrong Clark
Deck Square Footage: 600
🔹 Pros and Cons
Armstrong-Clark Wood Deck Stain – Pros
- Excellent balance of penetration and color retention
- Conditions wood with both drying and non-drying oils
- Better UV resistance than most penetrating oil stains
- Rich, natural-looking color tones
- Can be reapplied with proper prep without heavy stripping
- VOC allowed in all States and Canada
Armstrong-Clark Wood Deck Stain – Cons
- Slightly less forgiving to apply compared to simpler penetrating oils
- Can over-apply if not careful, leading to uneven drying
🔹 Best Wood Types for Armstrong-Clark
Best Wood Types for Armstrong-Clark Wood Stain
- Cedar: Excellent color enhancement and protection
- Pressure Treated Pine: Very good penetration and durability
- Redwood: Rich color tones with good longevity
- Hardwoods (IPE, Cumaru, etc.) – requires hardwood colors: Amber, Mahogany, Black Walnut
- Do not over-apply—this is critical with Armstrong-Clark
- Back-brush or wipe excess stain to ensure even penetration
- Apply in thin, even coats for best results
Armstrong-Clark offers solid durability but still benefits from regular maintenance.
- Recoat every 18–24 months depending on exposure
- Light maintenance coats will extend performance
- Avoid letting the stain fully wear off to prevent heavier prep
From my experience, maintaining Armstrong-Clark before full fade will keep the deck looking consistent and reduce long-term work.
🔹 Who Should Use Armstrong-Clark?
Who Should Use Armstrong-Clark Wood Deck Stain
You should consider Armstrong-Clark if:
- You want an oil-based stain with better color retention
- You prefer a richer, more vibrant finish
- You want a balance between penetration and durability
- Your deck is in good to moderately weathered condition
- Your deck is extremely dry and needs maximum penetration
- You prefer a water-based or low-VOC product
🔹 FAQs
Armstrong-Clark Wood Deck Stain – FAQs
How long does Armstrong-Clark last?
Typically 18–24 months depending on sun exposure and maintenance.
Does Armstrong-Clark peel or flake?
No, it penetrates into the wood and does not form a surface film.
Is Armstrong-Clark oil or water-based?
Can Armstrong-Clark be used on new wood?
Yes, but proper prep is required to ensure even absorption.
It performs very well, with better color retention than most oil-based stains.
Yes, if the previous stain is compatible and the wood is properly prepped.
🔹 Final Thoughts
Armstrong-Clark Wood Deck Stain is one of the better oil-based stains available when it comes to balancing penetration, color retention, and durability. It stands out from traditional oils by offering richer color and improved UV resistance.
From my hands-on experience working with deck stains for over 30 years, Armstrong-Clark is a great choice for homeowners who want a high-quality oil-based stain that provides both performance and appearance.
If applied correctly and maintained over time, it can deliver excellent long-term results without the issues commonly associated with film-forming coatings.
I just stripped and stained my old redwood deck with Armstrong Clark Natural Oak semi trans and I’m happy with it. The directions on the can are great, but I’m surprised they don’t recommend pad application. Nonetheless, I used a pad and it worked really well,
Looks great!
Deck Stain Help,
We just wanted to give you a big thank you for all the prepping and staining advice. In the end we decided to go with Armstrong-Clark on account of some advantages it offers. We have a large south facing deck. The fact that we could put it on in the sun is a big plus as it is too hard to time a dry deck with an overcast day and no foreseeable ran here in the NW. The other big advantage of this product is that you let it sit and soak in for 24 hours instead of having to towel it off 30 to 60 minutes after application. This is a huge labor saver that keeps you from trying to towel up stain while you are still trying to get it on other areas. Within 24 hours it was all soaked in and looking nice. We used the Armstong-Clark Cedar Semi-Transparent on cedar deck boards. Thanks again for all the help!
Lee
Looks great!
Hi Scott. Should I put a second coat on now or latter? New con heart about two weeks old. Lightly sanded 150grit. Brushed on Anderson-Clark Amber. 2 1/2 gallons covered 800 sq.ft. I was surprised. Pics about an 1/2 hour after the 3 hrs it took to stain, once sanded and swept. How can I send pics?
Hi Perry,
Unfortunately, you stained your new deck prematurely and didn’t prepare it correctly. New wood neds to weather for three or more months and the prep should be the cleaner and brighentener to remove mill glaze and oxidation, not sanding. There is a reason it spread so thin, because the new wood directions were not followed, and your wood was unable to accept the stain properly.
New wood tips:
Just leave it alone for a year. It may wear unevenly since you stained it too soon. If it does, you will need to strip and brighen for prep.
FYI, never sand finer than 60-80 grit as it will reduce stain penetration.
I wanted to wait several years before posting this to be certain my recommendation was well founded and accurate.
It has now been seven years and I can confidently recommend the Armstrong Clark stain product for exterior, element exposed cedar. I am in Portland, OR and have cedar carriage garage doors.
The house was built in 6/2008. I had wanted a smooth furniture finish on the doors and so the painter applied numerous thin coats of lacquer to all exposed wood; mahogany front doors, cedar soffits, the cedar ceiling over the enclosed deck, and the garage carriage doors.
By 10/2013 the lacquer had peeled off the garage doors due to the direct southern exposure to sunlight, rain and snow but I will say all other exterior wood was and is still fine.
After researching and finding this site I removed the garage doors, stripped, brightened, properly sanded (going through each grit until 1200) and then applied the Armstrong product as four thin coats.
One gallon was sufficient for two doors (3 Car)
Throughout the years there have been no problems with the product or with any type of greying or fading of the wood.
Despite my best effort at sanding this is still not a smooth, glossy finish which what I desired but I see that that is not practical nor does the product purport to deliver that.
However due to the slight roughness on the surface I do find that pollen and dust stick to the doors so I just wipe them down monthly.
In considering all attributes that this site uses to rate stain products, the Armstrong is superior to the other products I have dealt with.
I helped a family member with his deck and he insisted on a using different product because of the price. What a foolish choice he made!
The cost of the stain is so minimal when compared to labor and time costs.
In 2020 I did give the garage doors a very light sanding and added a single coat before I sold my house.
It looked beautiful and I believe the doors were a contributing factor in selling the house, even during the slower housing market.
I highly recommend the product and I will use it again.
Extremely impressed with this stain. After a backbreaking job of sanding and brightening the cupped pressure treated 7’x28’ front porch and four 5’ wide steps, I was praying the finished product would be worth it. I wasn’t disappointed. A complete transformation. Very easy to apply, and huge bonus not having to time application to avoid the sun. Used two coats applied only about 20 mins apart but dries enough in that time to not have worries about leaving shoe imprints on previously coated surfaces. Finish was rich and smooth. After almost a year signs of wear are minimal, and only on steps used to drag bicycles and scooters up and down in addition to very heavy foot traffic.
Will recoat steps this summer and that’s it. Highly recommend,
Do you have any pictures to post?
I’m out of town for a couple of weeks but can get take some pictures when I return and post them at that time. I never think to do a before and after. If you had seen the before, you’d be amazed by the after.
Afters would be great. Thanks!
I was wondering about a comment you made about Armstrong Clark
Not Ideal For: Extremely dry wood needing maximum penetration or very low-maintenance expectations
What constitutes “extremely dry” wood. My cedar deck is about 8 years old. Has full sun exposure all day. Has places where wood has split with the grain. Is this “extremely dry” and I should go another route? Also your comment about mainenance expectations needs a bit of clarification for me if you would. What do you mean by that. I like TWP color but I was hedging toward A C because you mentioned could be applied in full sun. Is AC superior to TWP due to the sun issue. I REALLY appreciate your input
Not sure what comment you are referring to, as you can use it on old and dried-out wood. It helps replenish the lost oils.
Hi Scott–It’s stated in your “quick verdict” section
🔹 Quick VerdictArmstrong-Clark Wood Deck Stain – Quick Review
From your response I believe that you no longer have that opinion? Also is there a significant performance difference between TWP and AC if the application has to be in full sun as my deck gets sun from sunrise to sunset. You had mentioned AC performed well. Does TWP not do as well? Thanks
That’s a typo should be “Ideal”.
We fixed it.
Wow. That makes a huge difference. Thanks
My poolside cumaru is 10 years old and regularly maintained. This January I stripped,sanded and applied 3 coats of deckwise ipe oil. It drank it in and now looks blond. The second photo is the same cumaru in our linai. What other oil would I use to bring back the rich warm colors of the wood.? I miss the richness. FYI, we’re in southwest Florida.
Strip and brighen for prep. Do not sand. Look at the Armstrong Clark in Mahogany color if you would like it richer. Do not apply 3 coats to cumaru. Just one coat every year after cleaning.
Yes this is my PT deck pictured in late April here, but the deck is 3/4 open to the sun all day in summer? what would you recommend? I like seeing the grain.transparent? Armstrong…. nano seal what…..looking for something easy to refinish also. previous used defy crystal clean only lasted 2 years. Ty Dan
Strip and brighten for prep to remove the old coating, and then use the Armstrong Clark in one of the semi-transparent colors.
I’m looking for a product that won’t track oily shoe prints on my indoor wood floors! Does the Armstrong dry without oily residue remaining?
AC stains are fully curing and drying stains.
Hi Scott. Question on AC Cedar semi-transparent. Will be doing a full strip/brighten of Cabot ATO with RAD on a three year-old cedar deck. Deck surface, fascia, top rail (all cedar) is almost 400 square feet. Debating on purchasing four 1 gallon cans vs. one 5 gallon can. If I go with individual gallons, I would need to box them prior to staining (combine in a 5 gallon bucket) to ensure color uniformity, correct? Not needed with a 5 gallon can purchase, however, I don’t want to end up with a lot of extra stain I won’t use. I know I may need to put a maintenance coat on 12+ months or so, but don’t want it going bad (I could purchase some empty paint cans and transfer for that period of time). Also, what supplier does the stain come from if ordered here on your site? I’ve seen reviews on Amazon where a supplier (The Sealer Store in MI) had sent out old batch dates with hardening, leaking, and unusable product in the 5 gallon cans. Looks like the resources to get product to Illinois are limited to two (both MI), including that one. I certainly don’t want to spend $300 to get an old batch, whether that be 1 gallon or 5 gallon. If the 1 gallon cans turn faster (batches are current), it’s worth the extra cost. That’s one advantage to a stain like Cabot, where I can purchase off the shelf at a big box store and check the batches and dates. But I’ve done Cabot twice, and it’s not durable…hence moving to AC. Also, what is the expected lead-time to receive AC Cedar ordered here online? I’d like to get this done sometime next week. Thanks, and feel free to email me directly as well if that works better for your answer.
-Yes, mix well first and then box the gallons together.
-The Sealer Store has never sent out old stain with old batch dates; it is always new, based on their extremely high volume and turn rate. Anyone saying that is straight-up lying or making an incorrect assumption. As for leaks, UPS has been known to mishandle packages in some rare cases. If that ever happens, they will replace it at no charge. All stain products, whether in gallons or pails, are not expired or old.
Shipping to IL takes 1-2 business days.
Appreciate the response. For my size deck and age, 4 or 5 gallons? If five, five gallon can? Thanks again!
It is hard to say, but I would think 4 gallons should be enough for two coats applied wet on wet.
Hi Scott. Need some direction.
I used RAD stripper per the directions today on my cedar deck. I do not have a power washer, but did use a pressure wand attached to a garden hose. The stripper did not remove all of the stain…some larger patches, and some very small areas on many boards, a lot of which are around knots. Also, I did one half the deck that had a lot of intact stain and the boards are now neutral color. The other half of the deck has much more exposure and most of the Cabot ATO was already gone. The wood darkened quite a bit when the RAD was applied, so I gently scrubbed with a medium bristle brush. That created a lot of residue, which looked like balls of mud. The wood on that side was much more reddish after brushing, and I’m not sure all of the residue was removed. In both cases, the wood now has fuzzies (I read your instructions on that). I did not brighten because I could tell there was still stain post-stripper. What do you recommend for next steps? I do have a random orbit sander and plenty of 60 and 80 grit, if I should be lightly sanding at this point. Thanks!
FYI: Just purchased Armstrong Clark semi-transparent cedar from you, and it arrives tomorrow. Want to be sure I’m giving it the best prep possible so it doesn’t fail on me in the near future.
To strip best (and easiest), you need a pressure washer. Can you rent or borrow one? Add some pics of the project so far in the comments.
My neighbor has a power washer I believe I can borrow. Pics attached. Do I need to let it dry out before attempting again, and use the stripper again?
Additional photos
Most of the old stain is removed. No need to let it dry out; reapply the stripper and pressure-wash it off. Shoot for 95% removal or more. The brightener will restore the pH level and lighten the wood when done.
Hi Scott
So my newer pt pine deck is ready to be stained after following all prep guidelines. However our spring weather is making this a challenge. After a day of rain we will have 3 good days of sun. Although temps have dropped from the 80’s into the 50’s. On the 3rd day we will have temps in the 70’s which I would like to stain.
However the next day there is a chance of rain all day with chances starting around 4am.
Can I take the chance to stain? It will have around 12-14 hours of dry time with temps in the 70’s.
You should be fine but it does vary based on the stain brand’s drying time.
It’s AC semi transparent cedar.
Thanks for the quick reply
Hi Scott
Well I finally got the deck stained! All the credit goes to your expertise and this great website. Also you can’t put a price on your willingness to answer questions quickly! I’m very pleased with the results and thank you again. Due to constant rain chances I still need to finish the steps. However the stressful part is done!
Another picture
Nice job! Looks great!
