Best Clear Deck Sealer for Wood Decks in 2026: Expert Reviewed
Here at DeckStainHelp.com, we are proud of the fact that we are the Internet’s number one reference for your deck stain opinions and reviews. We thank you for your continued support. Clear deck sealers continue to be a great option for protecting your wood deck from water damage, but unfortunately, do not provide any protection against UV rays and graying/wood darkening. If you have used clear deck sealers, we would like to hear what you think, so feel free to leave a comment below and pictures of your completed projects if you have them.
Ready to find the best deck sealer for your patio? Take a closer look at our top picks for clear wood deck sealers, and leave any questions you might have in the comments below.
- Defy Extreme Clear: This clear deck stain is a favorite of ours. It’s also one of the best wood deck sealers on the market because its penetrating formula soaks deeply into wooden boards and leverages zinc oxide to protect against moisture, mold, mildew, pests, and UV damage.
- Armstrong-Clark Transparent Wood Stain: Armstrong-Clark’s clear deck stain defends against moisture and sunlight to keep your deck in tip-top shape all year. The penetrating sealant offers enhanced longevity and is well-suited to areas that receive heavy rain or snowfall.
- TWP 100 Series Clear Stain: TWP’s 100 Series Clear Stain goes on easily, requires minimal maintenance, and helps protect and preserve your wooden deck boards from moisture damage. The penetrating product absorbs deeply into your deck, sealing the wood pores and protecting the boards in even the coldest climates.
- TWP 1500 Series Clear Stain and Preservative: Another excellent TWP product, the 1500 Series Clear Stain and Preservative is an EPA-registered wood preservative that works hard to protect your deck from UV damage, mold, mildew, and moisture. At the same time, it slows drawing and minimizes the risk of cracking or warping, even in colder areas.
Clear Deck Sealers and Stains for Exterior Wood
It is no secret that protecting a wood deck with a water-repellent sealer is vital to its integrity and lifespan. Clear deck sealers leave the wood looking natural which may appeal to the deck owner. Without a doubt, a natural-looking wood deck is a thing of beauty.
Deck sealers do give adequate water protection by locking out moisture. This is important to the wood’s lifespan. When water is absorbed into the wood it swells and when it dries up it shrinks. This continuous swelling and shrinking eventually begins to crack, split, and warp the wood. A clear wood sealer will stop this water damage from happening.
Another enemy to a wood deck is the sun. Harsh UV rays turn the wood fibers gray and also cause warping and splitting of the wood. The problem with clear deck sealers is that they lack the pigment to protect against sun damage. So although a clear deck sealer will give a deck great water protection it will not protect against sun damage.
This is without a doubt a huge disadvantage when using clear deck sealers. The best way to keep a natural look and give the wood deck both water and sun protection is to use a semi-transparent deck stain in a natural color. The wood grain is still allowed to show through and with only a little bit of tone or color a wood deck can still look very natural, yet the deck stain has enough pigment to give adequate sun protection.
Clear deck sealers can be very appealing to deck owners looking for water protection and to keep that “natural look” they are wanting. This comes at a risk to the wood deck because of the lack of sun protection. If you are looking for a natural-looking deck with both water and sun protection consider using a semi-transparent deck stain as opposed to a clear deck sealer.
How to Choose the Right Clear Deck Sealer
Finding the best sealer for a deck isn’t always easy, especially if you want a clear product that will still protect your wooden boards. Consider the following questions when choosing your clear deck stain:
- What type of deck do you have, and where is it located? The best clear deck sealer for you may depend on whether your deck sits poolside, near the ocean, or high in the mountains with lots of snow and rain.
- What kind of weather is your deck exposed to? The best product for your needs may vary depending on the weather your area experiences most frequently.
- What’s your budget? Prices can vary, but it’s critical to do your research and find the best deck seal for your needs rather than picking the least expensive option. You may spend slightly more upfront, but you could save on maintenance costs over time.
Application Tips for Clear Deck Sealers
Ready to start sealing your deck? Check out these tips before getting started for the best results.
- Don’t stain a new deck right away. If your deck is brand new, wait at least 30 days before applying a stain or sealant. Otherwise, the boards won’t absorb the stain.
- Make sure you know what type of product you’re using. Deck sealant, stain, and paint may all sound the same, but they’re actually three different products offering varying degrees of UV production, preservation, and pigmentation.
- Take the time to prep your deck before staining it. Sweep your deck, repair any loose or damaged boards, and give the wooden surface a good scrub before applying stain to ensure the wood absorbs the product properly.
- Check the weather before applying stain. Finally, make sure you apply your stain on a dry, sunny day when the temperature is between 50 and 90 degrees Fahrenheit. Damp weather, high temperatures, or lots of wind can negatively impact the application and may result in the need for recoating.
Longevity and Durability of Clear Sealers
Even the best deck sealer will need reapplication at some point. However, clear deck stains and sealant may require more frequent maintenance and recoating to keep your wooden boards safe and protected from UV, moisture, and pests.
As a general rule of thumb, plan to reapply a clear stain once a year.
Eco-Friendly and Non-Toxic Options
Looking for an eco-friendly, non-toxic clear deck stain? You’re in luck! There are several products available from trustworthy brands like ECOS. You may also consider natural oils, such as teak, linseed, or walnut oil, though these may require more frequent reapplication.
Clear Deck Sealer Performance in Various Climates
As mentioned above, the type of weather your area experiences can be a determining factor when selecting the best deck seal for your project.
For instance, if you typically receive heavy rain and snowfall or live in an area with high humidity, the TWP 100 Series or TWP 1500 Series clear sealants may be the best bet for your deck. On the other hand, if you live in an arid, sunny region, the Defy Extreme Clear sealant may better protect your wooden deck boards.
Comparing Clear Deck Sealer Brands and Prices
The cost of clear deck sealant can vary widely. However, most of the products in this list cost between $50 and $60 for a 1-gallon container.
Ultimately, quality is the most important factor to consider. Plus, spending a bit more upfront on a quality product may save you more money and headaches down the road.
Common Issues with Clear Deck Sealers and How to Solve Them
Some of the most common issues with clear deck sealers include UV damage and wear and tear over time. Other problems may include moisture damage, discoloration, or even brush or roller streaks in the stain.
If you’re dealing with brush or roller streaks, you’ll likely see them fade over time. However, wear and tear, UV damage, and rot may require touch-ups or reapplication to prevent further damage.
FAQs About Clear Deck Sealers
Read on for more about clear deck sealers.
How often should I reapply a clear deck sealer?
As a general rule of thumb, plan to reapply a clear deck sealer once yearly to protect your deck boards.
Can clear sealers be used on all types of wood?
Yes, you can typically use a clear sealer on all types of wood. Keep in mind you will need to remove any existing stain or sealer before applying a new coat.
What are the best conditions for applying a clear sealer?
For best results when applying a clear sealer, keep an eye out for two to three days of clear weather, dry with temperatures between 50 and 90 degrees Fahrenheit.
How do clear sealers impact the wood’s natural color and grain?
As their name suggests, clear sealers are transparent and allow the wood’s natural color and grain to show through without altering it. Instead, they simply help protect the deck boards from UV, moisture, and pest damage.
What is the difference between water-based and oil-based clear sealers?
Oil-based sealers generally penetrate more deeply into wooden deck boards, resulting in enhanced protection and preservation. That said, water- or silicon-based sealers can also defend your deck against the elements, though they may require additional care and regular reapplication.
How should I prepare my deck before applying a clear sealer?
For best results, make sure your deck is clean, dry, and clear of any furniture or decor before applying a clear sealer. If needed, you may also use a scrub brush or pressure washer and deck cleaner to remove dirt, grime, and old stain or sealers.
Are there clear sealers that also provide UV protection?
While clear sealers don’t offer as much UV protection as semi-transparent or solid stains, there are several products on the market that can help protect your wooden deck from UV damage.
Can I apply a clear sealer over an old stain or paint?
In most cases, you’ll need to remove old stain or paint before applying a clear sealer. If not, the old stain may show through the clear sealer and may even impact the sealant’s ability to penetrate into the wood.
What are the safety precautions to take when applying a sealer?
When applying any type of stain or sealant, make sure you wear long pants and sleeves to avoid skin irritation from splatters, along with proper protective gear, including gloves, goggles, and a mask. Make sure you’re in a well-ventilated area to avoid inhaling fumes, too.
How to handle sealer runoff and spills during application
In most cases, you can handle small spills by blotting up the sealer and using soap and water to rinse off excess. If you’re facing a larger spill, you may need to use a deck stain cleaner to remove the unwanted sealant.
Have A Question on the Best Clear Deck Sealer? Ask Below in Comment Area!
We bought a 10 year old home last year in the PNW. The home has a lovely covered by roofline wrap around deck. The person we hired stripped and then made an error and used two coats of a one coat product. It became sticky. He rest ripped the deck with mixed results. We had an expert come out and recommend sanding the deck. He has agreed to do this. After it’s sanded we want to put a transparent sealer on it but really from Thompson’s to Defy there are poor reviews on all of them The deck is 600 square feet and we don’t want to repeat the problem. Thanks for your advice.
TWP 1500 Series or Armstrong Clark.
I could not locate TWP transparent. Do you have a link?
They have semi-transparent colors. You must have a tint for UV protection from graying.
Is there a water repellent I can use over a newly cleaned and stained deck?
You cannot add a clear sealer on top of a deck stain.
Is there a sealer that protects against the moss or lichens growing on a completely shaded deck. I need something that will keep the deck from getting slick when it rains.
Try Defy Extreme Clear but if you already have a stain on the deck now, you cannot add a sealer on top of it.
I’ve cleaned the deck and removed all the old sealer. My concern is the slick deck from the scum that grows from the shade. I wondered if there was a sealer or stain I could use to alleviate this problem.
No, a sealer will not stop this from growing on top. May minimize but not stop.
I have stained a deck , what can I put on it to protect against water and sun?
You cannot top coat or seal over a deck stain.
Best clear deck water sealer
Defy Extreme Clear.
Can I use a colored stain over a a clear deck sealer?
No, not without removing the sealer first which is fairly easy with a stain stripper.
What do you recommend to protect a tobacco stick wood outdoor gate? I would like to keep the original appearance while protecting from water damage. Note: kept in shade
Try Defy Extreme Clear.
Does the clear wood protected peel?
Depends on the brand. Not all soak in.
Ok your article makes sense. Suggest a couple of quality semi-transparent sealers,
See here:
I just built a deck using pressure treated wood. What is the best clear water sealer to use? How long should I wait before sealing? Do I seal the entire deck or do I leave some untreated?
As the article mentions, clear means little to no UV protection. Are you okay with it turning gray in a matter of months?
What about using “Liquid Rubber” for IPE? I love the look of my IPE after it is cleaned but it turns grey in a couple of months.
It will have no UV protection from graying and it will most likley ruin your IPE.
In your opinion who makes the best Natural looking deck preservative
Natural Color in Restore A Deck Wood Stains or Armstrong Clark Stains.
Hi, can you put a clear sealer on the decking without staining first? My client likes the colour of the wood already. Thanks
Hi Dan, two things. You cannot apply a clear sealer over a deck stain. As the article states, a clear sealer will not provide UV protection so your clients wood will gray naturally in a few months.
I have seen you not suggesting clear over a previously stained deck. I am assuming it would repel and not accept the top coat. Can you restain with the same semi-transparent stain later for maintenance and if so, why would this take and not the clear? Thanks!
You cannot seal over a deck stain right after install. The sealer will not adhere or soak in. When recoating with the same color and brand of stain, you can clean and brighten the wood for the prep. This will ensure proper adhesion.
There would be no advantage to you using a clear sealer over a stain even if you could o this. The clear will offer zero UV protection and stain colors will have the same water repellency anyhow.
what is best sealer for a exterior cedar table. want to keep look of cedar.
You will need a tinted stain if you want to protect from UV graying. See one of these brands:
Can a clear deck sealer (or any other wax or product) be applied over a toner to give the toner added life. It seems crazy no one can make a product capable of lasting more than a year or two.
No you cannot add anything on top.
I had a PT pine fence installed this week. (130ft x6ft)… the company said to apply a sealer within a few weeks. What products do you recommend?
Use one of these stains: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
I just pressure washed my deck it has not been sealed or stain.it is about 9 months old i want to keep the natural look what should i use i do not want to stain it
You are okay with it graying naturally in a matter of months? Clear sealers will not provide UV protection. You must have “stain” in your coating for UV protection. Best to use one of these:
I am having a deck built currently. The wood is cedar and it is prestained. Do you think that just a water sealer will be enough since it came prestained? I love the color of it currently, I know it will fade some but want to try and keep it as close to the color it is as possible.
Andrea
You cannot add a clear sealer over a deck that has a deck stain on it nor will a clear sealer help to prevent the fading. Leave it and redo in 1-2 years with a stain.
thanks for the feedback. The prestain that they used does not bead up when water gets on it though. I am not sure what kind of stain they use. I purchased them stained. Should I just put a coat of Behr stain and water sealant on it?
Andrea
No, you cannot do that. The pre-stain has to be stripped off first and then brighten the wood. After, use a tinted deck stain like one of these: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
Sorry I am just not understanding why…I took a piece of scrap wood that they had cut off and put a semi transparent stain/water protector made by Behr on there last night and, put a little water on there. It was still pooled on there this morning, and since it was semi transparent ceder it looked even prettier than just the prestain they put on there. Why can I not do that? Will it mess up the deck?
You cannot apply a stain over a different brand of stain and assume it will soak in correctly and penetrate properly. You are setting yourself for product failure by not following the correct prepping steps. BTW, Behr has horrible reviews. Might want to read the consumer comments here: https://www.deckstainhelp.com/behr-deck-stain-review/
I have an older deck that was just pressure washed, and algecided. Gets full then partial sun depending on time of day. Location is NW NJ. Was very mildewed prior to cleaning. I live in townhouse. What would be best low maintenance stain to use? Would like if natural would could be seen. Thanks.
Try the Defy Extreme Stains.
We have a deck that is 20 months old. We stained the deck with Sherwin Williams Super Deck Semi Transparent Water Borne formula (latex). I put 2 coats on the floor after the wood had cured for 10 months. Now 10 months later it is already spot peeling. What should I do now? I want to make sure the wood is protected and is waterproof.
Strip and sand to remove. Brighten all the wood after. Use a penetrating stain going forward so it does not peel and is easier to reapply. See this for brands: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
I used Thompson’s WaterSeal Wood protect in clear (green & white can) on my PT pine deck because we were in a time crunch and I could grab it easily from HD. I did clean it & pressure wash beforehand. However, I’m not very happy with how it turned out and I want a bit more color. (Also I’ve been reading about how awful Thompson’s is).
Questions:
1) The label says I can apply oil based paint over TWS in about 1 month, is this true?
2) I’m considering putting TWP semi-transparent over top of it after it cures. Will this work, or do I need to actually paint over it instead of stain?
3) If I can put oil based semi transparent stain over top in 1 month, will I need to powerwash again before staining?
Any advice is great appreciated, thanks a million!
1. No
2. You cannot apply a semi-transparent stain over this.
3. You should remove the Thompsons by stripping and brightening the wood while pressure washing. This will work: https://www.deckstainhelp.com/restore-a-deck-injectable-deck-stain-stripper-review/
What are some top products to clear coat outdoor wood railings
Defy Extreme Clear.
What would you recommend on a deck that was built 30 years ago. Really never taken care of. No stain no clear nothing..just cleaned it up looks ok but. It could look better. She don’t want stain or anything on it but it would won’t withstand much longer without something on it. Any recommendations?
For a clear coating, try the Defy Extreme Clear.
how log does ittake clear sealer on a deck to dry
That varies based on the brand and the weather. 2-6 hours, maybe longer.
I’ve used Thompson’s for years but they have changed the formula to a thicker texture which doesn’t work well with a sprayer; it comes out in little blobs and puddles and I had to smooth it out with a paint brush or roller.. Have you heard anything from others about this? Any suggestions for something thinner which will go on smoothly with a sprayer?
I don’t know why Thompson’s changed their deck sealer so that one can not use a pump up garden sprayer, but I would like to know a product that can be sprayed on with a garden sprayer.
everything I read hear indicates clear sealer does not provide UV protection, but when I look around on line it seems many brands say there product does protect against UV. What are your comments about this. Also if you use a clear sealer will the western red cedar that I have gray, if so in how much time?
They are not a true clear finish then and are slightly pigmented. Many companies will have a clear that is lightly pigmented and will enhance the grain of the wood. Also “natural” colors are not clear, but pigmented.
A true clear sealer like TWP Clear or Defy Extreme Clear will gray naturally in a matter of months.
Which wood deck sealer has the best longterm rating?
Clears will only last a few months to maybe a year. Defy Extreme Clear seems to do the best. If you want it to last longer, you will need color in your stain.
If you reply every year with clear sealer do you think it will prevent greying?
No, not possible.
when do I stai a new deck
I live in Missouri and have a 3yr old untreated deck that is 1/2 totally covered, and 1/2 that is full sun. I know the full sun part will need to be treated probably twice as often as the full shade part, but I don't want there to be a obvious "line" or color difference. I thought if I went with a clear sealant hopefully it wouldn't be as obvious. Is there a brand or something you can recommend?
It will show a difference when using clear. Exposed wood will gray will covered will not.
If clear will show a difference, is there something that wouldn't show the difference as much? I just read on your site it's better to use a tinted sealer in direct sun? Is there one you can recommend that would maybe blend with the shaded deck older sealer better since I will be re-doing the sunny part more often? I have a very large 1 level deck, so re-doing the entire deck each time to avoid the color difference is something I would like to avoid.
Are these two different decks? You cannot just do half a deck, it will show.
No, it is 1 very large continuous deck with 1/2 getting absolutely no sun, and the other 1/2 receiving constant sun. So you're saying I will have to re-do the entire deck even though only the sun part needs re-sealed and the shade part looks like I just sealed it? I realize it will show using a tinted sealer, that's why I had asked about using a clear.
Yes you will need to do all the flooring. You cannot stop and start in the middle of a continuous deck when prepping and staining. It will never blend and look bad.
My cedar deck is fully stripped and cleaned and looks very light when dry, but the color really pops when wet. What will it look like after the Defy Extreme clear is applied (and dried)? Will it have a wet look, or will it revert back to the dry looks once the Defy cures? Thanks.
The Defy Clear does not enhance the color. You need tint/colored stain to do that.
Do you have a Rating for Deck sealers that are Crystal clear?
Clear with no pigment will give little to zero UV protection. Are you looking for the wood to gray naturally?
I'm using reclaimed boards that have been previously stained by tar. The staining is fairly inconsistent creating a large variance in color. We really like the way the wood looks as it is. So after some wire brushing & light sanding we want to seal it with something truly clear. I don't want any sort of toner or color that may change it. What would you suggest to seal & protect it as well as seal in the odor of the tar?
You cannot seal over top of a deck stain. Will not work. Also using a wire brush could have negative impacts. If any part of the wire metal is left in the wood, it will rust and turn black when it rains on it. A wood brightener will remove the rust issue, but will also change the color of the wood some.
What about Sikkens one coat for an entry floor that is mostly covered? Will it protect the wood from water and foot traffic?
It is an okay stain.
I had a new deck installed last year. We sealed it with Olympic Maximum clear waterproof sealant
( it does have a toner – it doesn't mention on can but it gave the wood a slight color) says 3 yr warranty. The deck does not repel water any more 1 year- what can I use to seal deck. I plan on power washing deck as is starting to show signs of water darkening. What can we use?
Go with a semi-transparent stain if you want UV protection. Prep well and try TWP or Armstrong Clark.
My deck was cleaned and stained last summer. I am looking for a clear sealer, used Thompson sealer and wasn't impressed. Any recommendation for a better quality dealer ?
Defy Extreme Clear. Clears will not give UV protection.
I have stained the railing on our new patio with a light colored water-based stain. I have puttied to holes where the screws were used and then sanded them down. I would like to seal it now with a clear stain. What type of stain would you recommend?
You cannot seal over after you have already applied a stain. It will not work.
My new deck is almost complete. When done can I put a semi-transparent desk stain on it then or do you have to wait? Where can I get this kind of stain?
See this about new wood here: https://www.deckstainhelp.com/staining-a-new-deck/
I just power washed and sanded my deck. The prior owners didn't stain it for 5 years. It's getting cold in NY so I'm afraid to stain it. Can I use a clear water seal now with the cooler weather (45-60 degrees) just to protect it for the winter then stain it in the spring? If so recommendations.
No you cannot sealer then stain over it. Either stain now or stain in the Spring.
I would like to know the best clear deck sealer I can purchase I am going to be putting it on for the 1st time we just built deck last year. Also what is the best cleaner to bring it back to the natural wood not the gray color? I also need to know where to purchase it in my area.
Try the Defy Extreme Clear. Prep with their cleaner and brightener.
What is the best sealer for an épée deck at the Jersy Shore that was just treated with Teak Oil
You cannot seal over Teak Oil. Best to leave alone then redo next Spring with a tinted stain like Armstrong Clark or Defy Hardwood stain.
We live in Florida and just used Olympic semitransparent stain on our new pressure treated wood deck. I want to add an additional sealant to give it a sheen and extra protection from the elements. What would you suggest? I am looking to do it this weekend so preferably something I can purchase at Lowes or Ace Hardware.
You cannot add a sealer on top of a deck stain and you definitely cannot add a shine to an outside deck. It will peel and blister.
What is the best clear stain for pressure treated wood deck 15 years old ,just power washes. Dont' really want color last time it tuned deck too too dark.
Use the Defy Extreme Clear or TWP in Clear.
What is the best water sealant for pressure treated wood deck
Solid stains always peel on my deck….would a semi transparent stain solve this?
Only of you remove all of the solid stains 100% first then use a penetrating semi-transparent. You will need to sand off the solid stains.
What is the best clear deck sealer at a reasonable price?
Defy Extreme Clear.
I am putting up a red cedar fence 100 feet long and I have a huge maple and a huge oak tree in my back yard.
I want to keep the natural color of the wood what would you recommend we also have cold winters in inside of fence faces
north
Ron Hough
dv.pavvilion@gmail.com
Clear will not last that long. Best to go with a tinted stain. If you want a clear then use Defy Extreme Clear.
Please list the top rated sealers and their ingredients.
Ingredients? That is trade secrets of the manufacturers and we do not have any knowledge on that. We have already rated all the best stains for you to see the top ones. Click reviews above.
I need a product recommendation for use on a new redwood deck, at 8500 feet (lots of UV), with snow, ice, in a very dry climate. Help!
Please read this article: https://www.deckstainhelp.com/staining-a-new-deck/
Can you use a sealer under or over a solid stain to protect against water damage and if so, do you have any recommendations for solid stains and sealers?
When we sue solid stain we tend to use Flood\’s SWF.
Do I have to wait to apply a stain or sealer or can this be before assembling the deck?
You need to wait according to the stain brands suggestions for new wood.
