Defy Extreme Stain Review for 2026 4.1/5 (57)
Defy Extreme Wood and Deck Stain Review
✅ Defy Extreme Stain Review (Quick Verdict)
Defy Extreme is a high-quality water-based deck stain that offers excellent UV resistance and color retention. While it requires proper prep and careful application, it performs well for those wanting a durable, eco-friendly alternative to oil-based stains.
✅ Defy Extreme Stain – Key Takeaways
  • Type: Water-based / acrylic penetrating stain
  • Durability: Above average with proper prep
  • UV Protection: Excellent (zinc nano technology)
  • Ease of Application: Moderate (less forgiving than oil)
  • Maintenance: Moderate—requires proper prep for recoats
7.5 Rating Defy Extreme Wood Stain
Defy Extreme Stain was introduced in 2008 as the newest member of the Defy Stain family. Defy Extreme Deck Stain is a penetrating water-based stain that does not film on the wood. Defy Extreme contains synthetic epoxy resins that “harden” the wood pores below the surface.
Utilizing nano-technology, Defy Extreme is one of the best stains on the market when it comes to preventing UV graying.
✅ What Type of Stain Is Defy Extreme?
Defy Extreme is a water-based semi-transparent wood stain that uses synthetic resins combined with zinc nano-particles for enhanced UV protection. Unlike traditional oil-based stains, it relies more on surface bonding while still offering some penetration into the wood.
Defy Extreme Deck Stain Ratings (1-10)
– Defy Extreme Stain had a rich look to the wood. Natural grain was highlighted evenly throughout. The Defy Extreme did not mask the grain like other water-based wood stains. The penetration of the stain into the wood was excellent. The Cedartone color was slightly on the “orange” side but acceptable for a cedar deck stain color.
– One of the best in the industry. Testing over a 2 year period showed little to no color fade. The zinc oxide nanoparticles seemed to help drastically with the UltraViolet radiation that turns the wood gray.
Wear/Tear and Peeling: 8
– Better than average wear and tear. High traffic areas show some wearing but overall tested
extremely well. No noticeable peeling.
Cost Per Square Foot: 7
– Defy Extreme costs about $55 per gallon. For two coats we got about 100 square feet per gallon. We used 8 gallons for the 750 square foot deck translating to a per square foot price of $.55 a foot.
– Defy Extreme Stain is a water-based stain that does not promote mold growth in the stain. A very small amount of algae was noticeable but was only in a shaded area and was on top of the stain. More of an issue with the decks’ location, not the stain itself.
Ease of Application: 7.5
– Fairly easy to apply. One issue we noticed was that it can dry very fast when in direct sunlight and on a hot day. Easy cleanup with water.
Color Shifting (darkening) after 2 Years: 9
– Stain changed very little in color after the 2 year period. No noticeable darkening.
– No noticeable darkening, deep penetration, and little wearing make the Defy Extreme Stain an easy product to reapply when needed. Mild wood cleaning with the Defy Wood Cleaner and Defy Wood Brightener is what you would need to use to prep.
– Defy Extreme is an excellent product and easily outperforms the majority of stains on the market. When it comes to water-based “Eco-Friendly” stains, Defy Extreme is our top choice. Defy Extreme performed in the top three of all stains tested when it comes to preventing UV graying on a horizontal surface. On vertical surfaces such as railings, the Extreme had no color change.
✅ Real-World Performance
In real-world use, Defy Extreme performs well in terms of color retention and UV resistance. However, like most water-based stains, it can be less forgiving during application and may require more thorough prep to ensure even absorption and long-term performance.
$59.99
$269.99
Help or Questions? Defy Extreme Stain
Cost: $55 per Gallon, $269 per 5 Gallon Pail
Available Colors: Cedartone, Natural Pine, Light Walnut, Clear, Redwood, Butternut, Driftwood Gray
Coats  Required: 2 Coats. “Wet on Wet”
Dry Time: 2-4 Hours
Cleanup: Water
Manufacturer: Saver Systems
Cedartone
Defy Wood Stain Photos
✅ Defy Extreme vs Oil-Based Deck Stains
  • Defy Extreme (Water-Based):
    • Better UV color retention
    • Faster drying
    • Lower VOC
  • Oil-Based Stains:
    • Deeper penetration
    • More forgiving application
✅ When Defy Extreme Works Best
  • Decks in full sun exposure
  • Users wanting long-lasting color retention
  • Environmentally conscious homeowners
❌ When to Avoid Defy Extreme
  • Poorly prepped wood surfaces
  • Users wanting the easiest maintenance option
  • Older decks with heavy wear
FAQs – Defy Extreme Wood Stain
How long does Defy Extreme last?
Typically 2–3 years depending on exposure and prep.
Is Defy Extreme better than oil-based stains?
It offers better UV resistance but may require more careful application and prep.
Does Defy Extreme peel?
It is less likely to peel than solid stains, but improper prep can lead to adhesion issues.
Is Defy Extreme easy to apply?
Moderate—requires attention to avoid lap marks.
799 Comments
Bill Ellis
Bill Ellis
Texas Gulf Coast Dock Application Review.
I have a 2 1/2 year old pressure treated pine dock on the Texas gulf coast that needed a sealer preservative application. I had applied Thompson’s after initially allowing the wood to dry for a few months, but the sealer had lost its effectiveness after only 9 months or so. I researched diligently and chose Defy.
I followed the instructions strictly, using first their wood cleaner, then Brightener, then a week later applying the stain. (I had already pressure washed the deck boards before beginning.)
I am highly impressed by the products thus far. The cleaner was very effective and easy to use. The Brightener was a really easy step that I was curious about, but I did it and I’m glad I did. The Brightener makes a huge difference in opening up the wood pores to receive the stain/sealer.
I then applied the Extreme stain/sealer in Natural Pine color. I sprayed it on with a deck pressure tank sprayer followed immediately by brushing in with a car wash type brush (Unger) and followed with a second wet on wet coat, same steps, within 15 minutes or so, again following the instructions as strictly as I could. I was careful not to over-apply. (The deck is about 500 square feet, but I only used about 3 1/2 gallons.)
I am super happy with the whole process and appearance on completion. It looks fantastic. Really first rate. Let’s see how the next two years of wear and tear go.
Bill in Rockport.
Tania Stockless
Tania Stockless
Reply to  Bill Ellis
Hey Bill, how did this hold up for you? I’m in Florida and looking to do the same on large deck – blazing sun, humidity and subsequent mildew here is probably similar to Texas conditions. I love the natural pine color but have been wondering if I should consider going darker for the additional UV protection. Thanks! 🙂
Jay
Jay
12 years ago
I live in western ny. No matter how hard I tried (and tried, trust me) I was only able to get off 80-85 of my old cabot stain off of my pressure treated deck. Would Defy Extreme still be a good choice for me?
Walter
Walter
12 years ago
The sun facing side of my cedar shingled sided So. Cal house near the ocean gets hammered by the elements. I've used both Cuprinol and Deckscapes water based stains, can I switch to an oil base, or stay with a water based Defy Extreme?
Walter with Shingles
12 years ago
The sun facing side of my cedar shingled So. Cal house near the ocean gets hammered by the elements. I've used both Cuprinol and Deckscapes water based stains, both only lasting 18 months before drying and fading. Would you recommend the Defy Epoxy Extreme for better results?
Donna
Donna
12 years ago
We have 6 yr old PTW deck that had water based semi transparent stain (brand or color unknown). Vertical surfaces have held up fairly well. Deck surface is very worn and there is quite a bit of green algae on all surfaces. How do we re-stain and get uniform color? Do we have to strip all the vertical surfaces? Would prefer to use water based stain. Can we just apply Defy stain over entire surface without stripping the railings? We can live with some uneven color, but will that be too much?
Also, We've tried Wolman DeckBrite to clean it, but still have some green algae that didn't come off. Thanks.
Romeo
Romeo
13 years ago
I installed cedar shingles on my cabin last fall. It is now ready to be stained. I was thinking to use Defy, but I am hesitating due to the dripping and difficulty to apply on vertical surfaces.
Would you recommend Defy in my situation?
Fritz
Fritz
13 years ago
I have a PTW deck that had silkens on for 4 years with good results. Deck gets 20% sun. This year after a bad winter The deck needs resealing. I will strip all the old finish off and want to apply Defy extreme but I want a darker color like walnut. Can I mix a watco walnut stain in the Defy extreme to make it darker? I did that with previous stains and got good results.
Eddie
Eddie
13 years ago
What about Spar on top of Timber Oil?
Eddie
Eddie
13 years ago
What do you think about using this on a picnic table? Location: Baton Rouge, Louisiana. (HIGH HUMIDITY!) And what do you think about topping with a Spar Varnish?
spc
spc
13 years ago
We applied this product as recommended in sept 2012. Looked great for the first month, but then had ~30% of the deck peel over winter (by Feb 2013). Not sure what has gone wrong as we followed all instructions re preparation.
SPC
SPC
13 years ago
I purchased the cedar (5/4X6) in June, it sat in the drive for a month before I installed it. After installation it sat for another month un-prepped (it was dry during this period) before I used the defy wood cleaner to clean the wood. I then waited 2 d to ensure the wood had dried from the cleaning and applied the stain. I was originally going to go with a behr stain but after reading the reviews on this site opted for the defy. I used the behr product as trim on the margins of the deck and on the edges of planters and seating-it came through the winter unscathed which makes me think there isn't a problem with the wood.
SPC
SPC
13 years ago
Hmmm, interesting: this is from their product sheet: "New cedar should be cleaned and stained as
quickly as possible to avoid damage from the sun and rain." https://www.defyextremestain.com/pdf/extreme-wood-
did I miss something here?
SPC
SPC
13 years ago
Not sure if it helps, but some sections happened to be covered through the winter and they look great, it was only where the defy stained sections were open to the elements that I had a problem.
Sean
Sean
13 years ago
This is an awesome website with a ton of info on the different stains available. I am still torn between going with a water based stain vs. an oil base. I am nearly finished sanding a 10+ (who knows) year old PT deck down to the fresh looking wood. There is also a cedar arbor I am power washing that sits above a pressed concrete patio. I am concerned about using an oil based product on the arbor because of the possibility that it might get onto the concrete (even with a tarp in place). I am also concerned that a water based stain will be difficult to reapply in the future. The other factor is the age of the deck. It is has been neglected for a few years and required deep sanding. The wood seems dry and leads me to think that an oil based product will rejuvenate the wood. Based on these things do you recommend oil or water based? Thanks for your help!
Sean
Sean
13 years ago
Ok will do. I have one more question. I used 120 grit sandpaper to finish off an area of the deck to reduce (hopefully eliminate) the splintering of the wood. I read somewhere that using 120 will make the wood so smooth that it will reduce the ability of the wood to absorb a stain. Do I need to go over this area with a courser grit to open up the wood? After putting so much time into the prep I want to make sure the staining goes smoothly. I need a two year break after this! Thanks!
Sean
Sean
13 years ago
I took your advice on the Armstrong Clark stain and I could not be happier. The deck looks awesome! Thanks a million for the website you provided and the feedback.
Bruce Epstein
Bruce Epstein
13 years ago
I live in Green Mts. Vermont. Deck has Northern exposure made from western red cedar. Grass in this area turns to moss. First product I tried 10 years ago was Wood Iron. Mold started growing after 2 weeks. Since then I save sanded everything off twice. Permacheck product I now use looks awful, but no mold. I am considering TWP 100 possibly w/ Defy extreme. I also considering Cabot Australian Timber Oil w/ Defy Extreme Clear over the top. Comments/ recommendations appreciated.
Kathleen
Kathleen
13 years ago
Thanks for providing such a helpful web site. I live in hot and humid Baton Rouge, Louisiana and have a 10+year-old deck in full-sun. It hasn't been maintained for about 4 years, and has turned completely gray with a few patches of black mold and water stains, and a few places where the wood is separating. I'm looking to clean and seal it with non-toxic products (it's next to an herb garden). Once I've got it cleaned, I'd like to keep the look of the natural wood, as opposed to an opaque stain.
In reviewing potential products, my inclination is to go with the Restore-A-Deck Cleaner & Brightener and Defy Extreme Stain in Natural Pine. Two questions: (1) Are these products the best to use, and if not, what are? (2) What is the best way to address the separating/ splintering areas, and if replacing the wood/sanding is involved, how would that affect applying the products? Thanks!
Jules
Jules
13 years ago
I am so confused with deck stains. Hopefully you can help me. I am located in southeastern Pennsylvania. I have a north west facing cedar deck that is about two years old. We originally treated the deck with the water based cwf semi-transparent. I have been very unsatisfied with the durability of this product. All the high traffic areas are almost completely worn away. There is a ton of algae growing on the steps. Part of the deck including the steps gets virtually no sun as it is shaded by the house. The rest of the deck gets a good amount of full sun in the summer. To complicate matters further a tree fell on the deck during hurricane sandy and half of it was destroyed. So now I have a deck that is half new and half old. What recommendations do you have for me? I have been considering the TWP 1500 but would really like to stay away from oil based. I am also considering the defy extreme. Help!
13 years ago
I just finished building a pergola and railing with tigerwood and rough sawn cedar. I live in the San Francisco area and am trying to decide on the best stain to use. I was originally thinking of using Defy Hardwood on both, but the product sheet recommends Defy Epoxy Fortified for rough sawn lumber. Since Defy Extreme is an upgraded version of this should I use Defy Extreme on the cedar and Defy Hardwood on the tigerwood? How should the new wood be prepped for staining? Should I stain now or wait? If waiting is recommended, how long? Also, which shade of stain will yield the closest end result to the original wood color?
Barb Westermann
Barb Westermann
13 years ago
We live in Chicago and are just finishing new construction with cedar trim and siding. If the weather stays above 50 should we stain now or wait til spring. I am concerned that the winter will weather the wood more than we would like. I could stain most of it inside before it goes up. However, I read that with new wood one should wait several months. Can you clarify what is best. What would you suggest Defy or TWP1500? Thanks
Jay Kaye
Jay Kaye
13 years ago
Your website is a great resource. One week ago I just had put up 150 linear feet of 6-foot tall new cedar fence with PT posts. We live in Massachusetts so we get humid summers and snowy winters. Fence is in shaded area, under trees, so gets filtered light and may get some mildew. I want to protect wood from water damage , but let color gray naturally. I don't mind superficial mildew that can be sprayed off. 80 feet of fence sits next to property line and, even though we are friendly with neighbor, don't want to be trampling through their yard several times a year to reapply sealer. So I am looking for a clear coat sealer that will last a year or so and is easy to reapply (hopefully just recoat), without stripping down or bleaching the previous coat. I read good things about Defy Extreme Clear here, but product sounds finicky to apply and tough to remove necessary. I also what I read about Armstrong Clark product, but, again, how hard is it to maintain. Also, how urgent is it to seal the fence at this time: We are entering wetter season and expect a week of rain from hurricane Sandy, so fence may be exposed to weather for three weeks.
John Macdonald
John Macdonald
13 years ago
I'll be using Defy Extreme on table tops made of African Padauk. Would it be possible or advisable to then put on a topcoat of lacquer?
Bryan
Bryan
13 years ago
I'm planning to install western red cedar T&G siding on an addition in Toronto, Canada. I'm planning to stain both sides of the siding indoors before installation next spring. Should I buy the siding now and let it rest in the house over the winter before staining with Defy Extreme or should I buy the siding in the spring and stain with Cabot Timber Oil and then stain it again before the winter with Defy Extreme for durability?
Michael
Michael
13 years ago
I really appreciate this site! I am in the foothills of the Sierra Nevada in California. We get very hot dry summers. Almost no rain for half the year, lots of full sun. Then the rest of the year it rains a lot, and for about two months it can rain half the days or more. Occasionally it might rain almost every day for weeks. We had a cedar deck, but at this point we are thinking of putting down outdoor carpeting, so the issue is the railing–also cedar. There are 4 X 4 vertical posts, with 2 X 4 supports and a 2 X 6 rail. We are thinking about refurbishing the posts and replacing all the rails, which have a lot of splitting, deterioration and rough wood, as we have not put anything on the wood in 10 years. Also, the posts are MUCH harder to replace, but they are mostly in good shape, if cleaned. With all this mix of old and new wood, and extreme climate differences, I am wondering what to do after reading ALL the comments on this page, and some on other pages. Here are the choices I see:
*Sanding down the 4 X 4 posts, vs. cleaning, bleaching and/or pressure washing them (maybe followed by very light sanding?) before staining.
*Despite the posts being cedar, we have considered switching to redwood for the new rails, for what might be a nicer look and hold up better — so, cedar vs. redwood rail mixed with cedar posts?
*Use Armstrong Clark, TWP 1500 or Defy Extreme, or ?? and when to apply? Actually, it looks to me like TWP 1500 might be the best choice, but I guess I could not apply that right away on new wood. If so, would I wait till spring, and then clean the wood first before applying?
*I have not even considered using anything but transparent, but maybe I would be better off using a color stain to get a nicer look, particularly with the combination of woods. The top board of the railing takes a beating with the sun. We thought that redwood would hold up better than cedar there.
Sorry for so much complexity–can you help?
Thanks, Michael
Michael
Michael
13 years ago
Hi, and thanks so much for your response to my questions. I've been pondering your #3 answer, that Armstrong Clark is made in my area. I'm not sure what you meant by that. On their web site, it says they are in Michigan, and I could not locate any dealers in California on their web site. Is there any way I can find a dealer here in CA? I probably only need one gallon, so better if I could get in somewhere in the Sacramento area.
Michael
Michael
Michael
13 years ago
Sorry about that. I did locate the manufacturer just this morning, and phoned them. They have a dealer within 1/2 hour from me in Auburn, CA. By the way, we sanded all the posts considerably, and took them down to new-looking wood. All the verticals members of the railing will be cedar, and the horizontals, top and bottom and cap, will be beautiful "B" grade redwood with a mix of red and white wood. I will probably use Armstrong Clark semi-transparent Sequoia Redwood stain.
Michael
Kelly
Kelly
13 years ago
Which Defy would you recommend for an ten year old PTW deck that faces north. Half gets sun and half never sees the sun. It was black with mold but I've got it pretty well restored with Restore-a-Deck and brightener. Okay to stain in October?
Jeff B
Jeff B
13 years ago
Am in Columbia, SC. Just replaced all deck boards with Pressure Treated Premium Pine about a month ago. About 350 sq ft. Am about to prep by cleaning with bleaching using a pressure sprayer. We want a water-based semi-transparent light colored stain. What stain do you recommend? Thanks.
Reid
Reid
13 years ago
Live in Southeastern Michigan and have not found that TWP lasts much more than 1-1.5 yrs in terms of fading and maintaining water beading. Have used a Sikkens product in Northwestern Michigan on Lake Michigan waterfront deck and it still is working out well at 3 yrs. Would you recommend Defy Extreme over TWP in SE Michigan, or should I consider a Sikkens product?
Patrick
Patrick
13 years ago
Could not get TWP here in Canada so I went with this product instead… ease of application 3/10. Just like painting with water: drippy, runny, ultra fast drying. Did a poor job on my cedar deck I just spent countless hours sanding. Blotchy look, I hate it.
Justin
Justin
13 years ago
Thank you for taking the time to make this site. I have a brand new rooftop deck made from Western Red Cedar on top of a 4 story building – it's going to see sun basically all the time. It's very hot during the summer and will get cold in the winter. It also has railings which need to be treated. We love the look of the cedar by itself, but are thinking it will fade very quickly if we do any type of clear stain. I'm wondering if you would go with the TWP 1500 for protection vs. the Defy Extreme because of the ease of application or if you have other suggestions? It's very sunny and we are worried that the wet on wet application would be near impossible w/a fast drying stain.
Bill Woodley
Bill Woodley
12 years ago
Reply to  Justin
How did the stain hold up? After what time span
Ken
Ken
13 years ago
I have a brand new cedar deck. South facing in Minnesota (Hot and cold!). It will have a hot tub on it so the surface will be wet. What's the best product for my situation?
Don Marlo
Don Marlo
13 years ago
We had a cedar deck built about 6 months ago and would like to use the Defy Extreme buit you seem to recommend the Armstrong Clark or Timer Oil instead for new wood.
Would you consider our deck new wood? What would we use in 1 or 2 yrs to treat the wood? Would we have to stripe to apply something else?
george
george
13 years ago
i have new deck of PTW and live in chicago area. the deck is on west.i was wondering should i apply stain now or wait a year? also i was convinced oil based was better. was leaning towards TWP1500 or flood . now im thinking about defy. what would you recommend?
Jason
Jason
13 years ago
Which stain would you recommend for vertical surfaces. I have a board and batten Larch shed that needs to be sealed. This wold be the first application for the building. The location is western NY, and the building see full to partial sunny throughout the year. Thanks!
Jason
Scooby
Scooby
13 years ago
i have a covered deck i need to restain again. the covered part looks good, but the parts that received sun need a another coating. what prep work is needed to restain it. i used a defy deck stain and put on a wet on wet application or second coat. was very pleased with the product 8 years ago. Thanks!
Kenny
Kenny
13 years ago
Just sanded a redwood deck and have been trying to decide on a product. Sunny southern calif, not much rain. The deck gets sun most of the day. Would love a suggestion. Also other then sanding is there anything else I should do? Thanks for any help you can give me. Kenny
Art
Art
13 years ago
Tinted stain ? stain thats not clear? How long after cleaning and brightening should I apply stain? Thank you
Art
Art
13 years ago
My deck is in direct sun and is now gray. Will this product bring natural color back to the wood or will it stay gray after applying product?
Vanessa
Vanessa
13 years ago
We have a redwood deck that was treated with OneTimeWood 2 years ago, and we'd like to switch to a different product. We're not happy with how the OneTimeWood finish has lasted, it's mostly worn off already. We live in a cool, rainy coastal climate in northern California. Would Defy be a good option for this deck? Do we have to remove the OneTimeWood before switching to another brand? I so, how do we remove it?
George Moore
George Moore
13 years ago
Can you provide comments on Wolmans deck stain? How does it compare/rate to Defy? I found Wolmans to be very easy to apply, great color consistency, very easy clean up and looks beautiful. I have a 2×6 redwood deck. problem is that it fades very quickly. It last 2years at best. I live in Colorado and maybe that is the best I can hope foe? Furthermore, it is very cost effective. Thanks!
Eric
Eric
13 years ago
I was planning to use Defy natural pine or clear on my one year old PTW deck with full sun exposure in Indiana. It appears that you recommend Armstrong Clark for newer, previously untreated applications. Could you please provide some insight as to why one is a better choice for this application. Thanks in advance.
Ray M-Pittsburgh, PA
13 years ago
I have a new PTW deck and I have been reviewing your site. Very interesting reading BTW. I am considering using the Defy Extreme over the TWP 1500 primarily because it is water based. Unfortunately, Defy only has 3 colors, but of primary concern to me is resistance to splitting. Deck will get morning sun -East facing. Either of these better in that regard? Also, on the Defy website it says that the hardwood product should be used over the Extreme. Any thoughts on that?
Ray M
Ray M
13 years ago
Thanks for the reply, but as I reread my post I noticed that I didn't write it very clearly. Regarding the information on the Defy website it says that for new pressure treated wood the Defy Hardwood should be use instead of the Extreme. Their reasoning is that new PTW has a tighter grain from manufacturing and the Hardwood stain has a smaller molecular size (than the Extreme product)which allows it to penetrate deeper into hardwoods and new PTW. It also states that one coat should be applied to new PTW. Most of this is in the FAQ. Just wanted to know what you thought about this considering you experience.
Mrs Trudy Broek
Mrs Trudy Broek
13 years ago
We have had a very negative experience with your Defy Deck stain. We prepared our deck as directed ( had no previous stain) and applied your stain. Over winter and into spring the stain peeled and washed away in spots. It is ugly and we are unhappy. We feel we should get our money back.
Researcher
Researcher
Did you let the new deck boards "cure" (left the raw, new boards totally alone with absolutly nothing on it paint or stain wise for 12 months before preparing and staining the deck boards, very minimum to wait is 4 month, no, not 2 or 3 1/2 months, 4 months MINIMUM!. Very, very, very important to do. Sometimes by a miracle, pressure treated wood is stained sooner and looks great…this is because 1. It sat in a dry, heated warehouse for minimum of 4 months and not in the lumber outside yard for ANY time. 2. It's like burning wood in a fireplace, it needs to sit for a year and THEN used. I know, it looks dry BUT IT'S NOT. If you're desperate to stain before 4 months, get a Water Moisture Meter minimum $80 for one that works well. The site below or Google info on "proper moisture content in deck boards before staining".
"Many problems associated with deck staining or deterioration can be traced to the original moisture content of the lumber.
Look for the mark to be sure what you’re getting. Grade marks, such as the ones on these two pieces of pressure-treated lumber, indicate the maximum moisture content of the wood, which is information that’s good to know if you’re going to use the wood to build a deck. Some pressure-treated wood will carry two marks, one from the mill and one from the pressure treated."
Donna
Donna
Reply to  Researcher
You declare the new deck boards should cure for 12 months, but this does not hold true. We were very proud of the deck after Defy was applied. We followed all directions from the company to prepare the wood. Some of the boards were recently replaced, some had been there for a year and some for a year and a half. The product failed in less than 6 months on all three types of boards. It was perfect weather when we applied the product, but we have had a very wet winter. The product has washed off of all the exposed areas of the deck. It no longer beads up. We are going to contact the manufacturer for advise, but since we followed directions exactly we cannot advise anyone in the Pacific Northwest to use this product!!!
Adrian
Adrian
13 years ago
Any thoughts on applying one coat of the Defy Hardwood Stain followed by a coat of the Defy Extreme Clear? I'm interested in the protective properties of the Extreme, but somewhat concerned about the difficult application. This will be for a new redwood deck in central coast California (fog, light rain, lots of sunshine).
Laurie
Laurie
13 years ago
I have a new pressure treated deck. I have a small dog that urinates on the deck. What is the best stain to use so the urine does not penetrate? Thanks!
jim
jim
Training the dog will be the only real solution.
Kay
Kay
13 years ago
I treated my deck three years with Duck-something.
It is now gray and ugly. Would this product offer more longevity?
The deck is mostly covered but I live in heavy snow conditions.
RJMitt
RJMitt
13 years ago
I have the Defy Epoxy fortified stain on deck now…..retreat every two years should I switch to the Defy Extreme the next time I recoat my deck? I hear alot of good things about onetimewood also was thinking of switching to this the next time I recoat.
Donna A.
Donna A.
13 years ago
deck was treated in 2007 w/Behr premium weatherproofing stain, began to fail immediately, now really needs help. Is high bank waterfront on river in WA state where it rain a LOT! Is vacation rental home so can't use product that will make the deck slippery when wet, what do you suggest?
John Taylor
John Taylor
13 years ago
I was reading that wood should not have a hard coating thus allowing it to expand and contract. Does the Defy create a hard coating? Does it allow the wood to breathe?
M.H.
M.H.
13 years ago
Recently, I applied Defy Extreme Stain to a new deck in Michigan built with treated red pine 2 x 4s. On the plus side, it seems to have superior protective properties, and the "natural oak" version I used produced a rich-looking, almost honey-colored finish. On the minus side, Defy Extreme is tricky to apply evenly because it is very drippy on vertical boards (has a water-like consistency), which can make it necessary to re-brush each board as it dries. Also, because it dries fast and resists a second coat when dry (beads up), lap marks, bead spots, and drip spots are hard to avoid. Overall, though, I'd be inclined to use it again. Two tips for making the application easier: Use a good quality natural bristle brush because synthetic bristles are two or three times as drippy; also, use a mini roller to stain the sides of closely spaced vertical boards used to make benches, if you have them.
Sleepless in Seattle
13 years ago
Reply to  M.H.
I agree with M.H.'s comments on the difficulty of applying Defy Extreme stain. My 2 decks are 8 years old made of 2×4 cedar boards. After a laborous/thorough prep: sanded off old semi-transparent oil stain, cleaned w/ oxygenated cleaners, stripped the missed spots w/ stain remover, brightened, and finish sanded with 80 grit. I initially tried a pad applicator but found the cedar toned Defy extrememly drippy. Once it dripped on, it's almost impossible to blend in w/ a later coat. I quickly switched to a synthetic bristle brush, but still found difficult to avoid lap/brush marks. The color difference between the 1st and 2nd coat was significant even if the 2nd coat was applied when visibly wet. Compared w/ the oil based stain I used before, the water based Defy seemed to be less absorbant and more difficult to blend to achieve a uniform appearance. About 2 gallons were enough for me to cover about 400 sf, probably because cedar is less absorbant than treated wood and of the use of a brush. On the positive side, I liked the low VOC and ease of cleaning with just water. I'm looking forward to observing the durability and ease of maintenance/reapplication in the coming years.
Marsha NC
Marsha NC
13 years ago
What about Charlotte north carolina which stain would you recommend for my area
I have a 10 year old deck treated 5 years ago
Marsha
Emily
Emily
Marsha,
If you are still following this thread, can you let me know what you used and how it has withstood the past few years?
Curious from Charlotte
sunburned in CO
sunburned in CO
13 years ago
I appreciate your great reviews, but need a little more direction for climate conditions, with the understanding that it is your personal opinion. With all options open, which would you consider best suited for sunny, dry conditions year-round: the water-based defy extreme, oil-based TWP 100 series or TWP 1500 series. The reviews on the Defy are outstanding, and I love the easy clean-up, but would prefer longevity.
SoCalSac
SoCalSac
I'm in Southern California desert. Real dry and direct sun. What product would be best for my area. Note: railing only.
Peterson
Peterson
13 years ago
what does "wet on wet" application mean?
Miko
Miko
14 years ago
Could you give us a 3-yr update on Defy Extreme Stain? Sounded pretty good at 2 yrs …
We're in Coastal British Columbia, lots of summer sun and winter rain. Thanks
trackback
[…] Defy Extreme Clear Wood Stain is an “untinted” version of the Defy Extreme Stain. Clear wood deck stains traditionally will not last as long as a stain that has a tint when it […]
1 2 3 7
799
