Armstrong-Clark Wood Stains – Premium Oil-Based Protection for Decks & Siding
Deep-Penetrating, Conditioning Oils for Maximum Wood Rejuvenation
Backed by five generations of oil-based coating expertise, Armstrong-Clark Wood Stains provide long-lasting protection and superior performance for decks, siding, fences, and outdoor wood surfaces. Using a unique blend of nondrying conditioning oils and drying oils, this stain restores, protects, and enhances wood by replacing natural oils lost over time while locking in water repellents and UV-blocking pigments.
- Armstrong Clark Stain 1 Gallon covers about 150 to 200 sq ft on softwoods and 300+ sq ft on hardwoods; varies by porosity.
- Armstrong Clark Stain 1 Gallon applies with brush, roller, pad, or airless sprayer; always back brush after spraying for an even streak free finish.
- Armstrong Clark Stain 1 Gallon performs from 50 to 110+ F, dries in 8 to 24 hours, and cleans up with mineral spirits.
- Armstrong Clark Stain 1 Gallon delivers advanced UV and water protection, low odor, and meets 50 VOC limits for broad regulatory compliance.
- Armstrong Clark Stain 1 Gallon works with one to two coats; prep with Restore-A-Deck Cleaner & Brightener for best adhesion and longevity.
🔹 Why Choose Armstrong-Clark Wood Stains?
✅ Deep-Penetrating Oils Restore & Rejuvenate Wood – Nondrying oils revive older wood, while drying oils lock in moisture protection.
✅ Advanced UV & Water Protection – Transparent oxide pigments shield wood from fading, graying, and moisture damage.
✅ Easy Application in Direct Sunlight – Can be applied in the heat of the day without performance issues.
✅ Multiple Application Methods – Apply with brush, roller, garden sprayer, or airless sprayer.
✅ Flexible 2-Coat Application – If the first coat penetrates within 30 minutes, a second coat can be applied for extra durability.
✅ Low-Odor & VOC-Compliant – Meets all environmental regulations and contains no offensive odors.
✅ Self-Leveling Formula – Spraying? Back-rolling or brushing ensures an even, streak-free finish.
📌 Note: If puddles or glossy spots remain after 24 hours, remove with a dry rag.
🔹 Coverage & Application
✔ Coverage Rate: 150-200 sq. ft. per gallon (varies based on wood porosity).
✔ Works on New & Aged Wood – Suitable for softwoods and hardwoods, including pressure-treated pine, cedar, redwood, Ipe, and Mahogany.
✔ Can Be Applied in Direct Sunlight – No waiting for shade or cooler temperatures.
✔ Best Applied with a Brush, Roller, or Sprayer – For optimal results, back-brushing is recommended after spraying.
📌 Pro Tip: Prep your wood properly before staining by using Restore-A-Deck Cleaner & Brightener for the best results and longevity.
Technical Info Armstrong Clark Stains
Gallon Sizes:
1’s & 5’s
Coverage Per Gallon:
150-200 sq feet (Softwoods) 300+ (Hardwoods)
Coats Required:
1-2 Coats
Temperature:
50-110+ F
Application Tools:
Pad, Airless Sprayer, Brush
Dry Time:
8-24 Hours
Cleanup:
Mineral Spirits
VOC Limits:
50 VOCs. Compliant in all States and Canada
Product Data Sheets
Semi-Trans Hardwood Product Data
Safety Data Sheets
✔ Get Unmatched Performance with Armstrong-Clark Wood Stains!
✔ Restore, protect, and enhance your deck, siding, and fences!
✔ Enjoy long-lasting, deep-penetrating stain technology!
✔ Easy to apply with superior UV and water resistance!
🔹 Order Armstrong-Clark Wood Stain today and give your wood the professional-grade protection it deserves!
Great stain and easy to apply!
