Ready Seal Wood and Deck Stain Review 2026 — Is It Worth It? 3.8/5 (58)
Hi, I’m Scott Paul, a licensed exterior restoration contractor with over 30 years of experience and 10,000+ deck restorations. This review of Ready Seal Wood and Deck Stain is based on my own hands-on field testing, not manufacturer claims. See my full credentials and testing stats here.
Ready Seal stain is one of the most searched independent deck stain brands in the US. After testing it for two years on a 600 square foot pressure treated pine deck, my verdict is clear: it is one of the easiest stains on the market to apply, but its UV protection is poor, and you will be reapplying it every 12 to 18 months. If easy application and simple recoats matter more to you than long term color, Ready Seal is worth considering. If you want a stain that holds its color for two to three years, look at TWP or Armstrong Clark instead.
Quick Answer: Is Ready Seal Worth It?
  • Ready Seal is a paraffin oil-based transparent stain best suited for homeowners who want easy application and easy recoating
  • It penetrates deep, does not peel, and goes on evenly with a sprayer, brush, or roller
  • UV protection is poor — expect significant color fade within 12 to 14 months in full sun
  • Plan to reapply every 9 to 18 months to maintain color
  • Best for: pressure treated pine, cedar, and fences where ease of use matters more than longevity
  • Not recommended if you want a stain that holds color for 2 or more years
Ready Seal Stain Ratings (1 to 10)
All ratings below come from my two year test on a 600 square foot pressure treated pine deck in full sun, using the Gold color.
Appearance After Initial Application
Score: 7 / 10
Ready Seal applied evenly and gave the older pine decking a warm tone similar to wet wood. The Gold color looked good on day one, but it faded noticeably within the first few days as the paraffin oil soaked deeper into the wood.
UV Protection at 2 Years
Score: 3 / 10
UV protection is Ready Seal’s biggest weakness. No visible color remained after two years on my full sun test deck. Paraffin oil offers little UV protection on its own, and the trans oxide pigments fade faster than those in competing oil based stains. If your deck gets direct afternoon sun, expect color loss well before the two year mark.
Ready Seal stain showing significant color loss at 14 months on pressure treated pine
Ready Seal Gold on pressure treated pine at 14 months. Color loss is significant. Photo via DeckStainPro.com.
Wear, Tear, and Peeling
Score: 8 / 10
Ready Seal does not peel because it penetrates into the wood fiber instead of forming a surface film. That is a genuine advantage over solid stains and film forming sealers. Even under heavy foot traffic, the finish wears away gradually instead of chipping or flaking.
Cost Per Square Foot
Score: 5 / 10
Ready Seal’s real world coverage is lower than advertised. I got about 75 square feet per gallon on weathered pressure treated pine and needed two coats, which used 10 gallons on my 600 square foot test deck. At $50 per gallon, that is $500 in product for one application, before prep. With a 9 to 18 month recoat cycle, the yearly cost of ownership is higher than most competing stains.
Mold, Mildew, and Algae Resistance
Score: 7 / 10
Ready Seal contains an algaecide, and its paraffin oil base does not feed mold the way linseed oil stains can. Even so, green algae covered about 30 percent of the deck floor at the two year mark. It performs adequately, but not as well as TWP 1500 Series in damp, shaded conditions.
Ease of Application
Score: 9 / 10
Ease of application is Ready Seal’s strongest attribute. The manufacturer calls it goof proof, and that is largely accurate. It will not lap, streak, or show brush marks, and sprayer application is especially clean. When I checked the deck 24 hours after application, the finish was perfectly even. For a first time DIYer, Ready Seal is one of the most forgiving stains available.
Color Shift After 2 Years
Score: 9 / 10
Ready Seal does not darken over time, a common problem with linseed oil stains. It fades evenly instead, which makes recoating easier. You can apply a fresh coat of Ready Seal over a faded Ready Seal deck without stripping. Switching to a different brand does require stripping, as covered in the FAQ below.
Ease of Reapplication
Score: 8 / 10
Recoating Ready Seal is straightforward. Clean and brighten the wood, let it dry 48 hours, and apply a fresh coat. No stripper is needed as long as you stay with Ready Seal. That is a real advantage for homeowners who want to maintain a deck without a full stripping project every few years.
Overall Score at 2 Years
Score: 7.0 / 10
Ready Seal is a legitimate product with real strengths in ease of application and non peeling penetration. Its weakness is UV protection. If you go in knowing you will recoat every 9 to 18 months, it is a reasonable choice, especially for fences and other structures where full sun color life matters less than on a deck floor.
Ready Seal Second Test: Natural Cedar on a Cedar Deck
Ready Seal got a second full test from me after readers argued that the Gold color carries too little pigment to judge the brand fairly. I applied Natural Cedar, a more pigmented shade, in two coats to a 600 square foot cedar deck in full sun, then scored it after 2 years in the same 8 categories.
Category Test 1: Gold on Pressure Treated Pine Test 2: Natural Cedar on Cedar
Appearance After Application 7 8
UV Protection at 2 Years 3 4
Wear, Tear, and Peeling 8 9
Cost Per Square Foot 5 6
Mold, Mildew, and Algae 7 8
Ease of Application 9 8
Color Shift After 2 Years 9 10
Ease of Reapplication 8 8
Overall Average 7.0 7.63
The darker pigment helped. Natural Cedar kept about 50% of its color at the 2 year mark, where Gold had almost none left, and it faded evenly with no darkening. Ready Seal’s weaknesses did not change. It still needed two coats, covered only about 80 square feet per gallon (7 to 8 gallons for a 600 square foot deck), stayed oily on the surface for several days, and grew black mildew spots on about 20% of the deck floor.
My conclusion after both tests: darker Ready Seal colors do last longer than Gold, but even with more pigment, Ready Seal holds its color for roughly half as long as TWP or Armstrong Clark. Plan on recoating every 12 to 18 months.
Ready Seal vs Competing Oil Based Stains
Ready Seal competes directly with TWP 1500 Series and Armstrong Clark among oil based deck stains. Here is how they compare based on my testing.
Feature Ready Seal TWP 1500 Series Armstrong Clark
Stain Type Paraffin oil, transparent Modified oil, semi transparent Modified oil, semi transparent
Price Per Gallon About $50 $69.99 From $72.95
Coverage Per Gallon 75 to 100 sq ft 150 to 200 sq ft 150 to 250 sq ft
UV Protection Poor (3/10) Excellent (9/10) Excellent (9/10)
Durability on a Deck Floor 9 to 18 months 2 to 3 years 2 to 3 years
Ease of Application Excellent (9/10) Good (8/10) Good (8/10)
Peeling Risk None None None
Recoat Prep (Same Brand) Clean and brighten only Clean and brighten only Clean and brighten only
Best For Fences, easy access decks Decks, all softwoods Decks, all softwoods
Hardwood Version None TWP Natural Effect Armstrong Clark Hardwood
If UV protection and longevity are your priorities, TWP 1500 or Armstrong Clark is the better investment. Ready Seal’s advantage is foolproof application and a simple recoat, so it is the right choice when ease of use matters more than how long the color lasts.
Ready Seal Product Information
Where to Buy ReadySeal.com
Cost $50.00 per gallon, $225.00 per 5 gallon pail
Stain Type Paraffin oil based, transparent
Available Colors Gold, Natural Cedar, Light Brown, Medium Brown, Dark Brown, Medium Red, Dark Red
Application Temperature 45°F to 95°F
Coats Required 1 to 2 coats
Coverage Per Gallon 75 to 100 sq ft as tested on weathered pressure treated pine
Application Tools Sprayer, pad, brush, or roller
Dry Time 48 to 72 hours before foot traffic; never fully cures
Cleanup Mineral spirits
VOC Compliance 250 g/L, compliant in all 50 states
Manufacturer Ready Seal Inc.
Ready Seal Test Deck Stats
  • Wood Type: 8 year old pressure treated pine
  • Square Footage: 600 sq ft
  • UV Exposure: Full sun
  • Test Duration: 2 years
  • Color Used: Gold
  • Second Test: 600 sq ft cedar deck, full sun, 2 years, Natural Cedar
All results are from my own testing. Results may vary based on wood type, UV exposure, and weathering conditions.
What Wood Types Is Ready Seal Best For?
Ready Seal performs differently depending on wood species and porosity. Here is what I have seen across multiple projects.
Pressure treated pine is the most common use for Ready Seal and the wood I ran my first test on. It penetrates well, but the UV fade is most visible with light colors in full sun. Expect to recoat every 12 to 15 months on a south facing deck.
Cedar
Cedar takes in paraffin oil stains more slowly than weathered pine. Ready Seal’s even application works well on it, and cedar’s natural oils can stretch the life of the stain slightly. Natural Cedar, the color from my second test, looks best on raw or lightly weathered cedar.
Fences and Vertical Surfaces
Ready Seal’s no drip, no run formula makes it especially well suited for fences. The paraffin oil wicks into fence boards quickly and dries without lap marks. For fences, Ready Seal is one of the better options in its price range.
Hardwood and Exotic Wood Decks
Ready Seal is not recommended for IPE, teak, or other dense exotic hardwoods. These woods have very low porosity, and a paraffin oil stain will not penetrate them adequately. For hardwood decks, use a stain made for dense wood, such as Armstrong Clark Hardwood or TWP Natural Effect. TWP Natural Effect is a two step system that requires a separate top coat.
New Wood
New wood needs time before any stain will soak in. Smooth, milled boards, including most pressure treated lumber sold at home centers, need 3 to 4 months of weathering before staining. Rough sawn wood can be stained right away. To check, sprinkle water on the boards. If it beads up, wait longer. If it soaks in within about 30 seconds, the wood is ready.
How to Apply Ready Seal Stain Step by Step
Applying Ready Seal correctly is straightforward, but prep determines how long the finish lasts. Here is the process I follow on professional deck projects.
  1. Clean and Brighten the Wood
    Start with a deck cleaner to remove dirt, mildew, and gray oxidation, then follow with a wood brightener to open the grain and neutralize the wood’s pH. Do not skip this step. Stain applied to dirty or unprepped wood will not penetrate evenly and will fail early. Let the wood dry at least 48 hours after brightening before staining.
  2. Check Weather Conditions
    Apply Ready Seal only when air and surface temperatures are between 45°F and 95°F, with no rain forecast for 48 hours. Avoid hot afternoon sun, which makes the stain flash off before it penetrates. Early mornings and overcast days are ideal.
  3. Stir, Do Not Shake
    Ready Seal’s pigments settle in the can. Stir thoroughly before you start and again every 30 minutes during the job. Do not shake the can, which adds air bubbles.
  4. Apply the First Coat
    Apply Ready Seal with a sprayer, brush, pad, or roller. A pump sprayer or airless sprayer works well on large decks. Put on a generous, even coat with the grain. Ready Seal levels itself, so back brushing is not required. On very thirsty wood, a quick pass with a brush or pad helps work the stain into the grain.
  5. Apply the Second Coat While the First Is Still Wet
    On thirsty or weathered wood, apply the second coat within 45 to 60 minutes, while the first is still wet, so both coats penetrate together. If the first coat has already soaked in and dried, do not add a second coat. It will sit on the surface and stay oily. Watch the first coat: if it soaks in within about 20 minutes, the wood will take a second. On newer or less porous wood, one coat may be enough.
  6. Allow 48 to 72 Hours Before Foot Traffic
    Keep foot traffic and furniture off the deck for 48 to 72 hours. Ready Seal never fully cures, so any excess left on the surface will stay oily and can be tracked indoors. Avoid power washing or heavy cleaning for 30 days after application.
Ready Seal Stain Frequently Asked Questions
How long does Ready Seal stain last on a deck?
Ready Seal typically lasts 9 to 18 months on a deck floor before significant color loss. On my full sun Gold test deck, no visible color remained at 2 years, and the 14 month photo above shows how much fades in the first season. Shaded decks and vertical surfaces like fences can last closer to 18 to 24 months. Paraffin oil offers little UV protection, which is the main reason Ready Seal fades faster than TWP or Armstrong Clark.
How many coats of Ready Seal do you need?
Ready Seal recommends one to two coats depending on how porous the wood is. On weathered or thirsty wood like older pressure treated pine, two coats are almost always needed. Apply the second coat while the first is still wet so both penetrate together. On newer or less porous wood, one heavy coat may be enough. My 8 year old pressure treated pine test deck needed two coats and about 10 gallons for 600 square feet.
Can you apply Ready Seal with a sprayer?
Yes, Ready Seal sprays well. A pump sprayer works for smaller projects, and an airless sprayer is faster on large decks. Back brushing is not required, but on very porous wood a quick pass with a brush or pad helps even out penetration. Ready Seal’s no drip formula makes it forgiving on vertical surfaces. The most common sprayer mistake is applying too thin, so put on a generous coat and make sure the wood is absorbing it.
Does Ready Seal work on pressure treated wood?
Yes, Ready Seal works on pressure treated wood once the wood is ready to absorb stain. Smooth, milled lumber, which includes most pressure treated boards from home centers, needs 3 to 4 months of weathering first. Rough sawn wood can be stained right away. Sprinkle water on the surface. If it beads up, wait longer. If it soaks in within about 30 seconds, the wood is ready.
How does Ready Seal compare to TWP 1500 Series?
Ready Seal and TWP 1500 Series are both oil based, but they perform very differently. TWP 1500 uses a modified oil base with strong UV inhibitors and holds its color 2 to 3 years on a deck floor. Ready Seal’s paraffin oil base fades in 9 to 18 months. TWP 1500 also covers 150 to 200 square feet per gallon versus Ready Seal’s 75 to 100. Ready Seal is easier to apply and more forgiving for DIYers, but TWP 1500 is the stronger performer for color life and coverage.
What colors does Ready Seal come in?
Ready Seal comes in seven colors: Gold, Natural Cedar, Light Brown, Medium Brown, Dark Brown, Medium Red, and Dark Red. All are transparent and show the wood grain. Gold is the lightest and best suited to newer or light colored wood. Darker shades carry more pigment and hold color longer, as my two tests showed, but every Ready Seal color fades faster than semi transparent stains from TWP or Armstrong Clark.
Does Ready Seal ever dry? Why is my Ready Seal deck still oily?
Ready Seal is a paraffin oil stain, and paraffin oil does not cure. Any stain the wood cannot absorb stays on the surface, where it rubs off on shoes and clothing and gets tracked indoors. The most common causes are over application and adding a second coat after the first has already soaked in, which leaves the second coat sitting on top. If the deck is still oily after several days, the fix is to strip the stain and brighten the wood, then restain.
Do I need to strip Ready Seal before switching to a different stain?
Yes. Whenever you switch brands of semi transparent stain, the old stain has to come off so the new one can penetrate. The good news is that Ready Seal strips easily because it never forms a film. Apply a deck stain stripper, pressure wash it off, then use a wood brightener to restore the wood’s pH before applying the new stain. My picks are in my best deck stain strippers guide.
Do darker Ready Seal colors last longer?
Yes. In my two tests, Natural Cedar kept about 50% of its color at 2 years, while Gold had almost no color left. More pigment blocks more UV, and that holds true for every stain brand. Even in darker shades, though, Ready Seal fades faster than TWP or Armstrong Clark, so expect to recoat every 12 to 18 months on a deck floor in full sun.
Ready Seal Customer Photo Gallery
Best Deck Stains Video
This video covers my top rated deck stains, including the TWP and Armstrong Clark stains I recommend over Ready Seal for longer color life.
Have You Used Ready Seal?
If you have used Ready Seal, leave a comment below with your wood type, the color you used, and how long it held up. Photos help other readers most. I answer questions in the comments as well.
110 Comments
joe brown
joe brown
I used ready seal on my cedar tone cca after letting it set for over a year. This product went on great and covered fine. A few months later I tried to power wash a few spots and the stain all came off. That was fine just recovered and went on,but my biggest problem is you cant walk on the deck without the stain rubbing of on your shoes and tracking in the house. I sat on the deck once and ruined a pair of pants. I thought I had found a great product not so sure now.
Trish
Trish
The Ready Seal did not last and will not use it again. New larch dock, waiting one year before applying.
Dan
Dan
All of this was my experience as well. Older deck absorbed so much stain I had to acquire more – twice. When wet, the color was beautiful. After a few days of curing, it was much lighter and had a flat finish. Many of my boards stained different shades even though they all received two coats. Ultimately, the job looks like “meh” rather than “wow”. I don’t know if people will even know I refinished the deck.
I chose the mahogany for its deep red color. It doesn’t look like the pictures at all. Its dark brown. This is on older pine pressure washed to a light gray.
I tried the product becomes the Thompson’s wouldn’t last one season. Every spring the deck looked like camouflage. That stain sits “on” the wood rather than soaking into it.
I wish there was a win-all for deck stain. I guess its called composite
Toni
Toni
Just posting a review, and I agree 100% with your review. Ready seal is very easy to apply and is very forgiving. It looks great after application, but in full sun, it only lasted about 6 months before needing to be reapplied. It completely fades.
Sharon
Sharon
Reply to  Toni
What color is this?
Liz
Liz
Do I have to strip this Ready Seal product from my deck or just go with cleaning and whitening before staining with something else? Color faded quicky and I HATED the off gassing of the product – it smelled of oil/chemical odor for the first year.
Also, please make a suggestion of a stain/sealer that would be ok to use after cleaning.
Marion
Marion
Used Thompsons weather shield two years ago. It left a crystalline residue which caused having to wear shoes on deck because everyone ended up with dirty feet or clothes if sitting on the deck. I’ve power washed it twice and allows about four months since the last wash. Will Ready Seal leave a residue? I really don’t want to end up with the same problem…
Gary
Gary
I stained my PT pine wheel chair ramp with Ready Seal semi transparent 2 weeks after it was installed. I know now that was too soon. But it looked great. Still looked great 6 months later, but I went ahead and applied a second coat. Now, 1 year after the second coat, the stain is showing wear on the high traffic area. The rails and posts still look good tho. I’m getting ready to apply another coat to the floor boards in the next couple of weeks.
Dave seals
Dave seals
I put one coat of Ready Seal Pecan on my 2yr old treated pine deck a week and a half ago.
Wanted to put a second coat on but it has unexpectedly rained every other day and finally has been dry for 48 hrs.
Should I do a second thin coat now or has to much time passed?
terry
terry
My contractor uses it, so he said use Ready Seal…tho I have only used Ace deck stains before. I was excited to think it may be worth the 2 x price of ‘Preserve a wood’, redwood color.
It was a 95 degree today, so he figured last nights pressure washing and bleach clean would be dry. I did NOT completely strip the old oil deck stain.
Usually I would only use less than 1/3 gallon of Ace oil on my 300 sq feet of redwood deck.
I sprayed the Ready Seal and my contractor used a high quality painters roller type looking thick plush pad to back brush each piece.
Normally…since the Ace oil says on the can, “AFTER APPLICATION, REMOVE ALL OIL THAT HAS NOT PENETRATED (SHINES), WITHIN 15 MINUTES”, ..I figured the very wet looking deck would be tacky, if left like he had suggested, so I re-read the Ready Seal can and it did not say to use rags nor did it even mention removing any wet (shiny) surface oil.
Contractor said it will be dry by tmrw. but after 5-6 hours, it looks exactly the same…’wet’.
I am so fearful that even it will may eventually dry, it will be sticky…like the Ace oil, if left standing on the surface.
Hopeful to get someones feedback before the heat of the day tmrw.
ANYONE HAVE ANY FEEDBACK / EXPERIENCE IN THIS AREA?
Thanks much.
terry
terry
terry
The next day warmed up, and it started to dry in many places…so I wiped what had not yet dried, and it looks pretty good…but not as good as the 1/2 ythe price, Ace brand Preserva Wood
Kristen
Kristen
Sorry. Adding more to my question! I live in South Carolina near the coast and TWC and RestoreADeck are not sold here. What other suggestions do you have? This is a photo after I used deck restore and sanded.
Kristen
Kristen
Hi. I am getting ready to re-stain our back screened in porch wood floor that was previously stained with Cabot Timber oil. I went to Sherwin Williams and got their restore and applied that to the deck, scrubbed and rinsed it. I then went over it with a sander. I was going to restrain with Ready Seal because I am definitely not a professional and looking for ease of application with good results. Do I need to apply a brightener first? Would love your thoughts and suggestions.
Nate
Nate
Hey what chemical or brand of stripper did you use? I can’t find a stripper that removes it. The oil is too deep.
I doubt blasting will draw out the deep oil either.
Reply to  Nate
I have the same problem. Did you find something to completly remove it ?
Nate
Nate
Reply to  David
No I have not. I’ve tested several strippers. So far I’m just having to wait for the oil to burn off. It’s been 5 years….
Reply to  Nate
I used Restore-a-deck stripper with the additive and it removed the color completely but the wood is still slightly oily.
Marvin Linton
Marvin Linton
I installed a new cedar deck in June of 2020 and applied a product called Ready Seal. This was recommended by my local lumber company and was an oil penetrating product but not strictly petroleum based as it could be cleaned up with warm water if not allowed to dry in brushes. The product has now grayed with a hazy film on my deck which ruins its appearance. I have a hot water commercial pressure washer that I cleaned a portion of the deck with and the color and beauty of the wood is still there under that nasty film. I want to clean the entire deck and and reseal it with your best oil/stain penetrating UV protection product. I live on the Missouri/ Illinois border near St. Louis so summers are very humid here. What would you recommend in my situation? Is that TWP sold in Missouri? It got your best rating overall. Please advise. Thank you.
Erik Beauchamp
Erik Beauchamp
Hi, very useful article, thanks. I was just about to purchase Ready Seal – Pecan because there are many great pictures showing the results when applied on cedar. However, seeing on this review that the color fades so quickly, it’s not so interesting finally.
Which other product performs best in your reviews, when applied on a white cedar deck, with a similar Pecan color and available in Canada? The deck is 6 months-old, almost through its first winter. Thanks in advance!
LeeAnn Dunch
LeeAnn Dunch
Reply to  Erik Beauchamp
After applying Pecan ready seal this spring 2 coats it simply looks beautiful, I don’t live in an area that gets excessive wind and dirt flying all over.but in Ohio so far its been crazy with rain and thunderstorms! I would recommend you reconsider your decision..Just because someone may not have used enough stain or stained when the moisture level was too high…does not mean it will happen to you.. read the product info and follow their directions you should be just fine! There is a utube video on how to apply with a garden sprayer..and not a paint sprayer that might work better and reduce over spray mist..that’s what I’m going to try painting my fence when it drys out some.But my Pavillion looks awesome..
Anita
Anita
Oil Stain for deck – seems whatever we use, continues to peel after the winter, and so annoying. This past spring, we washed the deck with a hose (did not spray hard at all) and the stain that was peeling came off easily. Live in Canada and the deck sits in full sun. We are going to re sand the deck and reapply stain again. We have tried diff stains over the year. The deck was built in 2012. I have read the reviews and only 1 person mentioned peeling but everyone else, says easy to apply or it fades after a year. We want natural oil stain, I would rather it fades than to peel as it is very annoying to have to do this annually. I want to enjoy our deck. Has anyone experienced peeling using this Ready Seal Oil Stain for deck? We use the same oil stain for fence and experience zero peeling so what the heck! Look fwd to replies back re peeling from those living in Canada as apparently because of environmentalist, our oil stains have changed. Very frustrated.
Anita
Anita
thanks for the answer…so you never use RS….what do you recommend then for Canada? that doesn’t peel and last long? cause I am so tired of doing this every year.
Mel
Mel
I stain a cedar table base with Ready Stain & Sealer in “Dark Walnut”. However the color was a more golden brown color. Can I use a darker Ready Stain & Sealer “Mahogany” over the existing stain? Im looking to darken the Wood and give it a red tint.
deb
deb
Reply to  Mel
Spoke to manufacturer about just this issue. They suggest a quick clean of 25% bleach and 75% water. Rinse well, Let dry completely like you would a deck and apply a coat of next color darker. The cleaning reopens pores and kills any mildew etc that might be hiding in the grain.
S Thomas
S Thomas
I’ve got 3 gallons left of a 5 gallon pail. Can the stain/sealer be saved? If so, what is the best way to store and at what temperatures?
TOM CASEY
TOM CASEY
Should I apply a second coat with this product on the first application?
TOM CASEY
TOM CASEY
Just as I thought. The 2 different people at the paint store recommended a light second light coat on outdoor furniture I made and some of it took 48 hrs to dry. Lesson learned but I will use it again. Thanks.
Andrew
Andrew
I have previously used transparent Behr products on our deck, but cannot completely remove the Behr product from all the crevices of some redwood shingles that we have as a part of the railing. What can I do if I want to make the switch to using Ready Seal, because I am worried that the new coats may not be absorbed through the Behr product that lingers.
Thanks for any tips.
Andrew
Andrew
Doing both, hope it turns out OK!
Andrew
Andrew
My deck (mahogany/redwood color) is weathered, and has many small cracks and splits. Unfortunately, before i know this site, i have applied wood filler (dap plastic wood) to fill those cracks. Now my deck has a beige colored filler scattered on tje mahogany/redwood colored deck. It seems that the ready seal is semi transparent? Would 2 coats of ready seal still make the beige area noticeable? Would you rather suggest using solid stain?
Andrew
Andrew
Thank you…… It seems that i am stuck……. well, would thin paimt spray on the filler area followed by applying ready seal eventually result in peeling in a while? Thank you.
Andrew
Andrew
I now own a 25 year old home with 25 year old magogany/redwood colored deck, which now has so many small cracks and splits. Unfortunately , before i recognize ready seal, i applied beige colored wood filler (dap plastic wood) in sealing the cracks and splits. Now, would two coats of ready seal on the deck hide, at least more or less, bright colored filler marks? Or would you recommend using other solid stains?
Dayle
Dayle
Reply to  Andrew
no
James
James
Our builder delivered new green (wet) cedar to our home, but it also rained on the wood for two hours that day, and then he built our fence with the very wet pickets. He returned just 36 hours later and stained with Ready Seal dark walnut. Of course the stain job is completely uneven and four different colors, but the worst part is that all of the defects in the wood turned very dark brown – black and the fence looks horrible; I suspect this is because the tannins never had a chance to dry and cure before being soaked with oil stain, but do you have a reference that I can read to understand this better, and at this point what can / should we do?
James
James
I will post three images. One of the new “wet” stained fence, one of a 17 year old gate that was power-washed and stained, and one of a two month old fence that was never stained until now; all three were stained the same day with Ready Seal.
Russ Newberry
Russ Newberry
Reply to  James
It looks, to me, like the left side of your fence (in the picture on the left) was sprayed with dark walnut and the lower right portion was sprayed with the pecan stain. The door and the non rail side of the fence both look like walnut. I’ve used Ready seal for years and have never seen that kind of color difference. This is purely speculation, on my part, but it sure looks like two different colors of stain were used…
tim
tim
Reply to  James
it appears as if the product wasnt mixed well the lower was the mostly solvent “top of the pail” and the upper was the “bottom of the pail” where all the colorant settled. as for the photo on the right soft woods need conditioner directly before staining to take stain evenly
James
James
Reply to  tim
Thanks for your insight Sherlock. The fence builder stirred the stain, he’s not very bright but he’s not that stupid!
Ready Seal is just a really crappy product designed for ease of use by DIY’ers and fence builders with little professional continuing education; read the reviews by the professionals here at Deck Stain Help.
I had the crappy Ready Seal chemically stripped off and then restrained with Bakkers, no more black knots and defects, just an even single tone and single color of high quality stain that will last for 5 years.
Do your research, Ready Seal fades 50% within 18 months and has no UV protection, just garbage.
Nate
Nate
Reply to  James
Francisco
Francisco
Reply to  James
Can you please tell me what is the name of the color of the first picture on the lift
James
James
Hi, I replied this morning and included three images, but for some reason I don’t see that reply as posted. Did you get it? Thank you.
Tariq Suseyi
Tariq Suseyi
Reply to  James
Cedar has to dry for a whole year pressure-treated 90 days before you apply any paint or stain
Hugh Coatwood
Hugh Coatwood
Ready sesl gets loads of love from verified purchasers. This fact influenced my purchase decision.
steve fung
steve fung
Does Ready Seal works well for walking deck that already had an old coating that was from more than 10 years ago? Any recommendation? Thanks.
Jason M.
Jason M.
I've used 20 + gallons of this stain on decks over the past 5+ years and have found the Ready to hold up very well. I have also used Defy (older mix) and Ready Seal applied easier and lasted longer on a full sun deck in Maryland area. I do think the overall review score on this site seems low and believe the UV rating should be higher. The ease of reapplication is also a major plus. Stains seem to only last 2-3 years on most full sun decks, but this stain has outperformed others in my experience. Overall I would rank this as the best possible stain for the money, and given other aspects of a good quality stain. As others noted, you can also 5 gal. at Home Depot right to your house with free shipping.
Michael
Michael
I am very familiar with the Ready Seal products and wouldn't use anything else. The Texas heat/sun can be relentless, but Ready Seal has held up beautifully on the fences around here for years. I agree with those who say that the darker colors will have a longer "staying power" than the lighter shades, so your review of the Gold color is a little misleading about the brand as a whole. Pecan is the most popular color choice in our area. Some other key points that some are not mentioning– the age of the wood, the type of wood, and the condition of the wood can all affect how any stain works. Experienced contractors will know this, but DIY homeowners may not. If you are applying stain on a brand new fence or deck, it won't last as long as an older fence because of the porosity of the wood. Older wood is more porous and will absorb more stain. That is just the nature of wood– it can take months or years for it to open up completely. So after that first application on a new fence, you may have to re-stain after a couple years, but beyond that, you should be getting years longer life. Also, if an older fence or deck is grey and oxidized, or if it has been previously stained or sealed with another product, there are some easy but necessary steps to prep the wood. Power washing is not always sufficient. Sanding not always recommended. And if there is any moisture left in the wood at all after cleaning or rain, the stain won't absorb properly. You absolutely have to let it dry sufficiently before applying any product (should be less than 15% – you can get a moisture meter cheap at HD to be sure). I've found very helpful information just by calling the company (Ready Seal) to describe the condition of a particular project and to get their advice on the best way to prep. I personally recommend Ready Seal to all our customers. I think it's an excellent product and was pumped to find it available at my Home Depot last year.
brian
brian
Is the information on this site applicable to staining wood on Log homes?
Glen
Glen
Readyseal Is the best stain I've ever used will always use it. itlasts The longest and goes on the easiest it is uniform with great color
Kendall
Kendall
Ready Seal is easy to apply but does not last very long. We do many decks in PA and tried the Ready Seal a few years ago. Color fading was significant after one year, but that was not the biggest complaint we received. Our customers really did not like the oily residue that would rub off on clothes after the first week or two of applying. I guess this would be the nature of having the paraffin oil as it does not dry at all. We stopped using it because of this.
Jeff
Jeff
So basically, you've got a 3-4 year old review about a product that isn't even made anymore (Ready Seal Gold), and you're basing your evaluation off that? I have no connection with the company nor do I care which stains are rated highly, but the point is your review is too old to be valid any more, yet it doesn't mention anywhere the date of the review, nor what has changed with the product. It certainly doesn't cost $27.99, and it definitely doesn't come in the colors this review claims it does. I believe, like another poster said, that the Gold finish, specifically, didn't contain UV protection. So while you claim you were trying to compare apples to apples, you definitely weren't. Time for an update, or even a retest?
MaryBeth
MaryBeth
Very disappointed in this stain. Very expensive & does not cover with one coat. Fades quickly if fence is in the sun.
Color varies significantly from can to can. Will never use again.
john
john
"Ready Seal Stain and Sealer for Wood is an oil based semitransparent stain and sealer in one. It is a unique blend of oils, quality resins, and finely ground transoxide pigments that penetrate deeply into wood to protect and preserve it from the elements."
all brands say this, and the "oils" are subject to change and also unlisted. i personally would not rely on rumor and assume the product contains no natural oils that mold likes to eat. you'd have to keep it clean, like (%99 to %100 of products i can find that are not synthetic; like urethan)
Raysa
Raysa
I have 125 feet of new cedar wood fence to stain front and back, how many gallons of Ready Seal do I need to buy. I will be using a sprayer. Thanks
Randy Oberg
Randy Oberg
I have used Ready Seal for the past 3 years and I believe I have finally found the stain I will be using forever. I have a 500 square foot cedar deck built in 2008 which I first used Cabot and I was not pleased with the results. In 2011 I stripped the deck and applied Behr solid stain. The be Behr stain is junk do not use this stain ever! In 2013 I tried 3 gallons of Ready Seal for the floor just to try it out. It worked wonderful. I will never use another stain. Buy it you will love it.
Jim Scandle
Jim Scandle
I have used this product four times at our beach home and it in the past 13 years and it has held up well and provided the protection I expected. Will use again and would recommend it.
This Product is the best on the market Goof Proof no laps runs or streaks and it shows the wood grain looks beautiful. I have used it several times on different jobs decks, fences, cedar homes, and logs homes. The light colors don't last as long because they don't provide as much UV blocking. Light colors 2-3 year, Dark colors 7-8 years. I prefer a medium to dark color. I have use it on my own personal things like a 20 year old Redwood deck that I stain ever four years with Ready Seal, I use the Redwood color it looks like new. I also have a 20 year old fence that I stain ever seven years it too looks like new. How many fences have you hear of lasting 20 years I think that says it all.
H Rushing
H Rushing
My deck was 10 feet from the water's edge on North Padre Island, Corpus Christi TX. About every 5yrs I would power wash and refinish with Ready Seal using their dark transparent stain. Many compliments by those living on the Island. With stood the hot South TX sun and salt air/ salt moisture. Found no other seal to compare. Worked well on long privacy fences,sprayed banisters/rails, fences and used roller/brush on deck, applying 3 coats each, using much less with each coat. I gave 5 star on all questions as the deck mellowed over a 5yr period. Much better than other products.
Tom Howard
Tom Howard
The stain does apply easily, civerage is good but be aware it does dry darker than you might anticipate. I have a shaded deck so I can't really judge how well the stain holds up in direct sunlight. I do vey much like the surface of the wood on bare feet, very smooth. If asked to rcommend it I would but i would be cautious about using it in areas that receive a great deal of direct sunlight.
Jonathan
Jonathan
READY SEAL is actually a really good product but you have to know some things about it, choose the correct color and use ample amounts where the sun is going to hit.
Basically, we've found (after using it on hundreds of decks) that the darker the color, the more UV protection. This may not be much of a surprise! However, using "Redwood" color on pressure treated pine or other similarly dense woods, we can easily get 2 full years of UV protection and still have a beautiful looking wood color.
Tim
Tim
12 years ago
Used readyseal on cedar pool deck. Horrible for this application. Figured since it penetrated it would have some durability. Currently looking for an oil penetrating stain for cedar that will not peel and last longer than the swimming season in NY.
Charles
Charles
12 years ago
I used ready seal 3 years ago on a new deck after 6 months of aging, I used the dark walnut, it has held up very well, I have found that it needs to be applied heavily on the. First coating, then reapplied after 48 hrs. It is easily applied , I think some people apply like a paint. It all about your application, have been very satisfied, am about to reapply again.
Diane
Diane
12 years ago
Reply to  Charles
How did you apply your ready seal? Did you spray or paint with a brush? If sprayed, did you use hand pump type sprayer or electric sprayer?
Charles Porter III
Charles Porter III
12 years ago
Reply to  Diane
Personally, I have had the best results with a two inch paint brush. It allows you to thoroughly apply the product, and coat cracks and crevices, etc.
Charles Porter III
Charles Porter III
12 years ago
Reply to  Charles
Another detail, is to thoroughly stir the product before use. The color pigmment tends to settle at the bottom of the can, so it really should be stirred with a stir stick once every hour, to maintain a uniform color while using the product.
Charles
Charles
12 years ago
Preventing UV graying at two year mark, a score of 1? I built a cedar fence in 2008, stained it with Ready Seal, Redwood, using a pump up sprayer and a thin nap roller, and I attest to you that it still looks beautiful, over five and a half years later. I have noticed, with the product, that it really should be applied pretty heavy, so that the wood can thoroughly soak it in, otherwise it will in fact appear too light in color, whichever color being used.
Charles
Charles
12 years ago
Okay, DeckStainHelp, first of all, the issue here involves; {Preventing UV graying at two year mark, a score of 1} Nowhere, does this issue involve whether or not the product has washed out after one year, regardless of any surface it has been applied to (hopefully properly applied). The fence that I built for my friends, is only my first experience with Ready Seal. My second experience (in 2010), was when my mother asked me to pressure wash her deck and apply Ready Seal, 'Natural Cedar'. I did not use a roller on her deck, I only used a pump up sprayer, and I used 15 gallons to cover 2,000 square feet of everything (deck, banisters and handrails). Now, I HAVE NEVER SEEN ANY GRAYING WHATSOEVER, and it has been well over two years on both. The next issue here, 'Looks completely washed out after a year on a deck floor'. All I can say to that one, is, in my experience, the person who used Ready Seal on a wooden deck, or a wooden floor, should not use the product sparingly, however, should use a generous amount, if they actually care about what they are doing. I had to re-apply the product on a deck, because it rained shortly after the product was initially applied; that was completely understandable. If you want to give a stain/seal a poor rating, it should not be Ready Seal. I don't know how Ready Seal invented their product, but I can tell you, I am happy with the quality of the product, and I have no reason to doubt its integrity, whatsoever.
Charles Porter III
Charles Porter III
12 years ago
Ready Seal in itself is a high grade oil that has been tinted. It must be stirred thoroughly before use, and for best results, it must be applied generously on the first coat for best results. Other brands out there look fabulous the first year, but tend to peel, and reveal graying; and need to be fully stripped off in order to properly reapply. Ready Seal does not require much work in order to reapply.
Dorothy Guderian
Dorothy Guderian
12 years ago
Where can I purchase TWC stain in Austin, TX?
Diane
Diane
12 years ago
You can order it on-line at Home depot. I live close to Austin, in Lago Visa TX area. UPS delivered it. It was cheaper than their website. No charge for delivery for me.
Tyoung
Tyoung
Kelly Moore Paints, 3 locations and Jeremy is knowledgeable about the product.
Lucille Ettore
Lucille Ettore
13 years ago
I just started putting Ready Seal on my 21 year old cedar deck. Second time (first in 2008 a contractor did it) It should get a "20" for ease of application! I am a 65 year old grandmom and I love this stuff enough to order it from Texas and get it in New Jersey. I did not want to switch to TWP because I LOVE the natural cedar color.
13 years ago
I have a cedar fence in TX that I coated with Ready Seal, 3 years ago when it was new and it needs to be recoated. Should I stick with Ready Seal since it lasted 3 years or do you recommend TWC or AC as an alternative since they are more highly rated for UV protection? Also, how does the prep differ based on the product I choose? THX
markinaustin
markinaustin
13 years ago
I plan to use red pigment to deepen the color of the Ready Seal dark red. I have tried this on test pieces of pressure treated and I have achieved the color my wife wants – a truly reddish stain. I found the pigment at a woodworking store. A very small quantity of pigment will recolor 5 gal.
I have 500 sq. ft. of relatively new pressurized pine – it will have been under TX sun for two months when I clean it and then stain it.
I will let you know how this works out over the next year and I will have photos available.
The pigment is called "Mixol"..
Jean
Jean
13 years ago
Well I can attest that Ready Seal in Medium Red does not hold its color for very long in Utah sun. I've been very disappointed with the product for this reason. It's frustrating when you go through the whole process and within a couple of week it's all faded again. I'd like to give TWP a try instead. Can I clean and brighten, then apply TWP over a deck that has been previously stained with Ready Seal?
Michael
Michael
14 years ago
The Ready Seal Gold **specifically** states that it has no UV protection.
It is no surprise at all that the UV resistance was low. Only the Gold and Clear have no anti-UV properties. The 3 browns and the Cedar do have anti-UV compounds.
Ready Seal is one of the highest rated stains. You might want to try another shade of stain in fairness to your customers.
14 years ago
Ready Seal's Gold, Cedar and "light" red and brown are not the best for UV resistance. Stay with the Medium or Dark and you won't have much of an issue with fading.
110
