This post was updated on April 5, 2026
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood cleaning. My Restore-A-Deck Kit review is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
Restore-A-Deck Cleaner Kit Update 2026
The Restore-A-Deck Cleaner Kit remains our top performer for the 2026 deck season. It is easy to work with, very cost-effective, and produces great results! Please read this article and post any questions you have in the comment area below. Our newly enhanced website now allows you to upload and post pictures of your exterior wood or deck. This will help us determine the proper prep for your deck using the Restore-A-Deck Cleaner and Wood Brightener Kits.
Below is a YouTube Video Review of the Restore A Deck Prepping kit. This is from an actual consumer and is very informative and helpful.
9.0 Overall Rating Restore-A-Deck Stain Cleaner & Brightener
The Restore-A-Deck Cleaner System is a two-step wood cleaning and brightening kit designed to properly prepare exterior wood before staining. It uses a powdered concentrate formula that is mixed with water, making it both cost-effective and easy to store.
From my experience restoring decks since 1993, proper prep is the most important step in any deck staining project. A system like Restore-A-Deck is designed to remove dirt, grime, and old stain residue while restoring the wood’s natural color and pH balance.
Overall, Restore-A-Deck is one of the better-performing cleaning systems available and is a key step in achieving long-lasting stain results.
Restore-A-Deck is the only product on the market that offers both a Step 1 Deck Cleaner and a Step 2 Deck Brightener in the same kit. Restore-A-Deck comes in a powdered concentrated formula. Each 2 lb container makes 5 liquid gallons. Pour each into a five-gallon container and add water to dissolve the powder concentrate.
🔹 Quick Verdict – Restore-A-Deck Cleaner System
Restore-A-Deck Cleaner System – Quick Review
- Best For: Proper deck prep before staining
- Not Ideal For: Skipping steps or light maintenance cleaning only
- Type: Powdered cleaner and brightener system
- My Overall Rating: 9/10
Restore-A-Deck is one of the most effective and consistent deck cleaning systems I have used. It does an excellent job of preparing wood for staining when used correctly.
How I Rated Restore-A-Deck Cleaner Kit
My Restore-A-Deck Cleaner Kit review contains a 5-step process and the final average score. Each step is on a scale of 1-10.
- Removal of Graying and Dirt
- Removal of Old Stain (if applicable)
- Ease of Application
- Restore-A-Deck Cleaner Kit Final Score
5-Step Review of Restore-A-Deck Cleaner Kit
The Restore-A-Deck Step 1 Deck Cleaner did very well at removing general dirt and grime. The deep cleaning formula made breaking down the gray wood cells easy. All mold was also removed. The Step 1 Deck Cleaner did not remove some rust stains from the furniture, but the Step 2 Brightener did.
2. Cost Per Square Foot: 10
The best on the market today. The cost to clean and brighten an average 600-square-foot deck is less than $.07 a foot. Since Restore-A-Deck comes in a powder we like, you only need to mix as much as you need. Very little waste.
3. Removal of Old Stain: N/A
RAD products are designed to clean, not remove, old deck stains. We would presume that they would remove a deck stain if it has deteriorated drastically.
4. Ease of Application: 8
RAD does not come in a liquid. You need to measure 6 oz per gallon of water and mix the entire 2 lb. container into 5 gallons. This product can be applied easily to a garden pump sprayer. We needed to make sure to mix at the correct dosage; otherwise, the powder would not completely dissolve. Testing was done with both scrubbing and pressure washing. Both worked well. Step 2 brightener does not need to be scrubbed, just rinsed with water after 10 minutes.
5. Final Appearance of Cleaning: 9
The IPE wood deck looked brand new after cleaning and drying for 2 days. We would have given this a score of 10 if it was not for a couple of minor water spots that did not come out. These spots looked to be from planter boxes.
Overall Score for Restore-A-Deck Cleaner: 9
Restore-A-Deck is a great and economical product for restoring your deck to like-new condition. We really like that the kits contained both the cleaner and brightener. This was easier than buying the products separately.
Manufacturer: Restore A Deck
Product Type: Powdered Concentrate. Kit contains Step 1 Deck Cleaner and Step 2 Deck Brightener.
Deck Wood Type: IPE Exotic Hardwood
Deck Square Footage: 500
The condition of the Deck: Heavily grayed with mold/mildew. No previous stain
How Much Product Used:Â RAD 300 Kit. Retails for $64.99
🔹 Pros and Cons – Restore-A-Deck Cleaner & Brightener
Restore-A-Deck Cleaner System – Pros
- Highly effective at removing dirt, grime, and old stain residue
- Brightens wood and restores natural color
- Powdered concentrate makes it cost-effective
- Easy to mix and apply
- Works well on most exterior wood types
Restore-A-Deck Cleaner System – Cons
- Requires proper mixing and application steps
- Must follow with brightener for best results
- Not a one-step process
- Can damage surrounding areas if not properly rinsed
🔹 Best Uses for Restore-A-Deck Cleaner & Brightener
- Prepping wood before staining: Essential step for best results
- Removing graying and weathering: Restores wood appearance
- Cleaning older decks: Prepares surface for new stain
- Stripping light residue from previous coatings: Helps improve absorption
Not Ideal For:
- Skipping prep before staining – this is not optional for best results
- Heavy paint or solid stain removal – may require a stronger stripper
🔹 Application Tips – Restore-A-Deck Cleaner & Brightener
- Always mix according to instructions
- Apply evenly to damp wood
- Allow proper dwell time for cleaning
- Rinse thoroughly and follow with brightener
Proper prep is the foundation of any successful deck staining project.
- Always clean and brighten before staining
- Do not skip the brightening step
- Allow wood to dry completely before applying stain
- Proper prep will improve stain penetration and longevity
From my experience, most stain failures are due to poor prep—not the stain itself.
🔹 Who Should Use Restore-A-Deck Cleaner?
- You are preparing a deck for staining
- Your wood is dirty, grayed, or weathered
- You want consistent and reliable prep results
- You are using a penetrating stain system
- You need to remove heavy paint or solid coatings
- You are looking for a quick, one-step cleaning solution
🔹 FAQs – Restore-A-Deck Cleaner & Brightener
Do you need both cleaner and brightener?
Yes, both steps are required for proper wood prep and best staining results.
How long should you wait before staining after cleaning?
Typically 24–48 hours, depending on weather and drying conditions.
Can this remove old stain?
It can remove light residue but is not designed for heavy stripping.
Is it safe for all wood types?
Yes, when used properly according to instructions.
Can you skip the brightener step?
No, skipping this step can lead to poor stain absorption and uneven results.
How often should you clean a deck before staining?
Every time before applying a new coat of stain.
🔹 Final Thoughts – Restore-A-Deck Cleaner & Brightener
The Restore-A-Deck Cleaner System is one of the better deck prep systems available and plays a critical role in achieving long-lasting stain results. It is effective, cost-efficient, and works well across most wood types.
From my hands-on experience, proper cleaning and brightening is the most important step in any deck staining project. Using a system like this will greatly improve stain performance and longevity.
If you want your stain to perform the way it should, proper prep is not optional—it is required.
An Independent YouTube Customer Review
Restore-A-Deck Cleaner Only
I just installed some new cedar siding consisting of lumber that has been sitting around for several years. It has all been sanded with 80 grit. Can I apply a solid stain such as Flood at this time or must I allow the wood to weather??
Wait and month and clean and brighten the wood before using the solid stain.
I live in Chicago. In one month it will be too cold to stain
Do it in Spring.
I used an oil based clear sealer about 4 years ago. I bought your complete kit, pressure washed the deck which removed the majority of the old finish and left a light residual coating. I used your stripper twice on one board to test and all it did was trun the old sealer to a gummy mess that even the pressure washer won’t budge. I applied stripper again, let it sit for 30 minutes, scrubbed with a fairly stiff nylon brush. again it turned to a gummy mess that the brush would move around but it can’t be washed off.
Please post a picture of the board you are having an issue with.
I plan toter this board over and not use stripper in the rest of the deck.
That is raised wood fibers, not old stain. Just sand this board at 60-80 grit to remove the fibers and you will be okay.
Actually it is old sealer. Still gummy from yesterday
Sorry but no it is not. You are seeing wood fibers, not sealer or stain. When the wood is over stripped it will do this to the wood. Sand it and it will be fine.
I have the same issue on my cedar siding. When you say that it is ‘over stripped’ does that mean I used too strong a solution when I stripped it? Left it on too long? What can I do to prevent this in the future? I’m only halfway through my project, so I’d like to avoid doing it again.
Post a picture and what stain are you removing. There is not always a way to stop this from happening but maybe you can minimize it.
Here’s a closeup of the cleaned section. The white door picture has been cleaned, the green door picture has not yet been cleaned. I believe the stain was Sherwin Williams SuperDeck. I’ve done a few passes on them. First with straight sodium percarbonate. That left some stain residue, so then I purchased Ben Moore Remove and Restore. They have both been through a full cycle of Sodium Percarbonate, BM Remove, and BM Restore. Thanks for the help!
Actually it looks pretty good. Try using half strength of the stripper and see if that still remove but furs up the wood less.
Is there a deck cleaner and Brightener that is recommended that can be purchased at a common retail store. We need to clean and then stain just our rough grain rafter boards before it rains on Saturday and next week. We want to get our roof up next week. I didn’t realize that restore a deck can only be purchased online and not in WA.
Try Defy Wood Cleaner and Wood Brightener.
Can this product be used safely on a pier thats in the water?
It is eco-safe.
Is it safe if the product ( cleaner & brightener ) is rinsed off the wood pier into the lake water?
Yes, it is eco-safe for water.
How important is it to use the cleaner and brightener on my new deck banister spindles (2×2 rough pt pine? Creates a lot more work for me – (2nd story and older man- ha). Thanks, Lyle..
Very. You need to remove the oxidation and mill glaze.
Thanks, will do..
What product for stripping solid stain is safe for animals and the environment
Deck stain strippers will not remove solid stains fully.
I replaced the deck boards on my 600+ sq/ft deck earlier this year using pressure treated pine. I am now ready to apply a water sealer but want to clean it first. I live in Florida and we are in the hot season now. Is there any issue applying this product in the heat, or should it be applied in cooler temperatures? Also, how long should I wait before applying a sealer – like Thompsons Water seal or something comparable?
Best to do in temps that are around 85 or less. Works better and easier for you as well. As for a clear sealer, try Defy extreme clear. You can do this after the prep.
Thank you for your quick response. After reading the reviews, I was leaning towards the Defy Extreme stain, and using the Restore-A-Deck cleaner/brightener to prep. A couple of other questions – I assume I should cover the lower 2-3 feet of my siding (painted hardi lap) with plastic to protect against over-spray. Do you also recommend using a paint brush for the stretch that butts up to the house? Also, I had a stainless steel rail system installed using 4×4 pine posts with pine board top rail. I think I should also just use a paint brush to apply the stain on the railing instead of spraying – do you have any other suggestions? And, does the type of brush matter? Also, will the cleaner/brightener harm the stainless steel?
Lastly, my house is on stilts and the deck extends out over the garage. I am thinking I should go ahead and clean and stain the underside as well even thought it gets less exposure to the weather. Do you recommend doing this?
Thanks for your help and for creating this web site – very informative and helpful.
Use a deck stain pad for applying. The prep products should not harm the railings. No need to stain the undersides unless you want for appearance reasons only.
Thank you again for your quick reply. You have been very helpful.
i have cedar deck previously stained with a Behr transparent stain. It is flaking and would appreciate recommendations for how to proceed with prepping and restaining. Thanks.
Anyone used this on a redwood deck? Mine looks like the before photo above, it’s about six years old.
Yes. No issue with redwood. Make sure to use the Step 2 brightener after the cleaner.
After washing the cedar deck, next day I noticed water stains . The stains don’t seem to go away but remain on the stained wood . Wood wa stained week ago and it was 90 plus for a week . What can I use to remove the water stains on the deck
Picture, please.
Used the stripper and brightener today. Deck isn’t even dry yet but very happy with how fresh it came out, however now we have a lot of ‘hairs’. Especially on the railing. Do we stain as is or need to sand? Not all of the decking boards have it, or seems concentrated to a few boards… but the top railings are bad.
Found few stain droplets fall on the deck while staining. Found out after it dried. What grit sand paper do I sand it off? Do I do it manually or use rotor sander? Some areas applied thicker than others, what do I do. Wait till next year and top up even ?
What stain brand? Post a picture.
TWP 101 cedar stain where i have stain drips
Curious, did you let this new wood weather and did you prep before staining? https://www.deckstainhelp.com/staining-a-new-deck/
For the drips, You cannot spot fix this. Best to redo that entire step. Sand it off and recoat.
Yes it was weathered for about 3 months . Moisture meter showed less than 12 pct . I think the wood was sitting in storage for a while for moisture content to be that low. The wood was cleaned and brightened using Restore Deck cleaner and brighter . What grit sand paper do you recommend ?
80 grit.
Thanks. Based on the picture you don’t think it weathered enough?
Not really. TWP wants 4-12 months. Looks like it may not have soaked in very well since it was only 3months. Not the end of the world though, just clean and reapply a light coat next year if needed.
Was planning on doing another stain next year . Thanks for all your help .
I do not know if my deck was previously stained. Moved in last year and had a new baby – finally getting to the deck! I cleaned it thoroughly with a power washer, here’s what I’m working with. Should I use cleaner or stripper before the brightener?
Use a stain stripper and then a wood brightener.
Didn’t use the system. Used the RAD stripper on a cedar deck and then the RAD brightener.
After spraying on the brightener the change in deck appearance was almost instantaneous. This product made the labor of stripping a deck worth the work. Definitely satisfied with th he results.
Easy application and clean up.
Pics of the deck about 2 hrs after brightener was rinsed.
Looks great!
Used the RAD Cleaner and Brightener. The cleaner has left few white spots which can only be seen on wet wood. Even after applying the brightener the white spots don’t seem to go away. Planning to stain this weekend. Should I sand those areas or it wont show up when staining?
Picture, please.
The deck is 10 year old in Nova Scotia, Canada. Within 15 yards from a ocean bay.
The deck was made using pre treated wood. The deck is in
good shape with heavily grayed. My guy will pressure wash the deck. Is pressure washed required?
Yes, you have to prep and use a deck cleaner. Pressure washing will make it easier.
Hi
I have an old deck that has minimal stain left and the railings do still have some left on it. The deck has not been done for probably 10 years. There are some boards that I think need a sanding and it is dull and needs help. What order do I do the process when I want to sand. I just received today the stripper and brightener. What is the best say to proceed.
Strip and brighten for the prep is a good start and hopefully will work for the prep. Any issues with that, send us a picture.
Hi folks-
I stripped the stain off our 5 year old deck and then brightened (both with RAD). Decided to sand it afterwards to remove feathering. OK to just use brightener again before staining with TWP 1500 or should I lightly strip first then brighten?
Thanks in advance. This is a great website!
Just brighten and rinse well with water.
What is best way to use cleaner/brightener on railing. Using a sprayer seems like it will waste a lot. Will brush application work also. Since I would not be able to finish all the raining in 20 minutes, or perhaps even an hour, should i do the raining in sections.
You will have to spray and then pressure wash off.
We built our deck with pressure treated cedar about 10 months ago and it has weathered as seen in the photos. We plan to use the RAD cleaner and brightened at this point. I am now shopping for stain. My question is: should we use an oil based or a water based stain for our pool deck. We live near St Louis MO.
Either would work. Try one of these brands: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
I have a mix of new pressure treat lumber and old stained wood (pressure treated as well) in the same repaired deck. I want to use semi transparent stain. Do I need to use a stain stripper in prep since some of the old wood was stained? Thanks!
Hi Allen,
-You cannot stain new wood right away: https://www.deckstainhelp.com/staining-a-new-deck/
-All previous coatings will need to be removed inf switching brands.
If I clean a deck today, do I need to brighten the same day? Next day? A few days later?
Same day.
Hello, I am restoring my never stained deck and staircase. I used a power washer on it because of the extreme mold and mildew on much of the wood. I have been reading your site and will be using the Brightener you suggested. My question is because of the firing due to the power washer in of the boards I want to do a complete sanding with a floor sander, and I would like to know if I should brighten the boards before or after I sand. I have read on some blogs not to get the boards wet at all after sanding and some it doesn’t matter. Your help will be greatly appreciated.
If you sand, do the brightener and a light pressure rinse after. Water doesn’t harm sanding and in fact helps by swelling the wood pores. The more absorbent the wood, the better for wearing.
Thank you so much for your quick reply. :)
I tried Sherwin-Williams Revive to clean our 1-yr old cedar deck— sprayed the product on, waited 15 min, then power washed off. There’s still gray material left on the deck, and I can see the marks where the power washer was closer than another place. I’m abandoning the SW product and ordering RAD. Does it help to power wash first to get the bulk of the gray stuff off and then apply RAD and rinse? Do I need to keep cleaning until all the gray material is gone 100%? Also, when spraying, some boards get fuzzy— do I sand those after cleaning but before brightening?
No need to pressure wash first. Try and remove 90-95%. A little bit of gray will not matte. Fuzzies are from oxidation. Sand those off if needed.
Where do you purchase this RAD product. I have called various suppliers. Thank you.
Check with them directly.
We have Sherwin Williams Deckscapes (paint). What us best to remove it or am I stuck with paint. It has mold and has faded a lot.
You will need to sand off a paint. Strippers will not remove it.
Installed a new greenwood treated deck around our Wisconsin log home (wooded) 8 months ago and now are preparing to stain. As the wood is new, is it necessary to power wash before using the RAD cleaner? If so, is it just a light once-over?
You pressure wash while using the RAD Step 1 cleaner, not before.
I have an IPE deck on an island in New England. Have replaced most boards on deck(appx 2000 soft) Older boards now showing mold and mildew. Would like to give deck uniform look. Do I need to powerwash?….inconvenient….scrubbing sounds like an option I would prefer. Do you recommend a scrubber I can buy, with a handle? How long should I leave cleaner on before scrubbing? Will 2 packages of cleaner do the job?
Use a deck cleaner and a pressure washer for the best result. Brightener after. Apply cleaner, wait 5-10 minutes and lightly pressure wash off. You will need 3 Kits for 2000 sq feet.
Our deck is a typical candidate for restore-a-deck. However it is bordered by several mature cedars and three fruit trees and a number of flowering plants. What effect, if any, do such chemicals as restore-a-deck have on these plants?
Proabbly no effect but tarp anything that you can so there are no issues from overspray while working.
HELP: Deck constructed 3 1/2 months ago was cleaned with RAD cleaner/brightener. Didn’t remove graying so pressure washed. Still gray so used a second RAD kit. Again graying remained and have pressure washed two more times. Cleaning wasn’t performed in direct sunlight. Mixed cleaner in five gallon bucket and applied with pump sprayer. Very little foaming which I attributed to new deck not being very dirty. Only noticed small amount of crystals not dissolved but never clogged sprayer. Based on pictures do you think deck is ready for stain? Plan on sanding some and using Armstrong Clark semi transparent. Thanks for any help you can provide.
Yes it is ready to be stained.
My cedar deck is only 6 months old – do I need to use a cleaner / brighter on it before staining (with twp 1500)?
Yes, that is correct.
One Time Wood Follow Up
Thanks for the response.
How do I know when stripped completely?
Color change?
Yes, on color change. Also OneTime typically turns dark brown in color after being outside for a years. This should come off.
Will Resore A Deck stripper remove One Time Wood? This was the natural version.
Hello, we have used it on Onetime. Works decently but we had to go over it twice.
I have been cleaning and oiling Ipe and other Brazilian hardwood decks for over 10 years and I’m still disappointed in the products out there for prepping these decks. Seems to me they are getting less effective rather than better. I have tried countless products, Flood, Messemers, Behr, Zep, Rustoleum, Woodrich, and others but still am not satisfied with the outcome. Searching yet again I discovered your product this morning and placed my order for the Restore A Deck kit. I’m very optimistic that this product will do what it states. I will do a follow-up once I have tried it on a couple of different decks. Hopeful…
You may be using the wrong product for prep. Might need to be stripped and brightened instead of cleaned and brightened.
Can I use Defy Extreme Stain after cleaning my cedar deck with Restore-A-Deck? I want the Redwood color and the water-based Restore-A-Deck does not come in that color.
Yes, you can use the Restore A Deck prep products as prep for any stain brand.
Where can I buy RAD? Do I need to order on-line only?
Check with their website for local dealers or purchase: http://www.restore-a-deck.com
Why is it that all your “top rated” cleaners,strippers, brightners and stains are ALL listed for sale on Restore A Deck website. Does this sites owner own a stake in RAD? Literally all 4 different products brands they sell are listed here in top 5 in each category. How can I trust this sites reviews with that being said?
We give full disclosure of who we are and where our experience comes from on the front page and very first article. Our reviews/articles come from our experience as contractors for 25+ years. Consumer reviews and star ratings come from the 37,000 people how have contributed in the last 7-8 years. Best to read both our experiences and consumer experiences so you can make an educated decision on what to purchase.
FYI, the video above is from a consumer who tried and tested the RAD products and he has no relation to this site or RAD products in any way.
I have a covered outside deck that HAS been stained two years ago. I just want to clean it not restain it. Lots of dirt and mildew on it. Please recommend the best cleaner.
It is virtually impossible to just clean it after two years and not have to reapply another coat of stain. This would depend though on the brand and type of stain you used last time?
ok. I will restain. What is the best cleaning product???
The RAD products are what we use.
We have an untreated ipe deck that has silvered which we love but it dirty and starting to show some mildew. What can we use to just clean and not change the silver
No that is not possible. When you clean, it will remove the silver (oxidation) and any dirt, mildew etc. It will gray again though in 6-12 months if you do not stain the wood.
Thank you. What do you suggest we clean with?
The Restore A Deck products.
Like to try the restore a deck on my white cedar on my house, have some black discoloration n is somewhat dried out from the sun.. will it help on the discoloration?
It should help this. Apply the Step 1 and pressure wash off. Apply the Step 2 after.
will splatter from deck cleaner and conditioner on aluminum and vinyl leave stains? I know I have to be careful with the stain. new deck installed last year and will be ready for stain when weather permits.
Possibly on the aluminum (no issues on vinyl) but hard to say for certain as it depends on the condition of your aluminum, color, etc. Always test first to confirm no reaction will occur.
Can I use this to prep a log home for stain?
Yes you can.
We have a 850 sqft dock build over water in southwest Florida. The pressure treated 2 x 6 deck board are 3 years old and never been sealed. What cleaner / brightener would you recommend ? What clear or lightly tinted sealer would you recommend ?
Prep with the Restore A Deck Cleaner/Brightener Kits. Clear coatings will not provide UV protection. Need a tinted stain for this. Look at light colors in the TWP 100 Series, Armstrong Clark, or Restore- A Deck Stains.
I have an untreated wood walkway, and want to stain it. Do I need to use both the cleaner and the brightener? Also, I’m going to use the cleaner on some wood poles on my front porch which are on top of Saltillo tile. Will these products harm the finish on my tile? Is it safe around plants, or do I need to cover them?
Yes you should clean and brighten for the prep. It should not harm the tile. Cover the plants or rinse well before and after applying.
Brand new deck, 2×6 Master Grade pine. It’s about 2 months old now, and has been in Southern sun/weather.
1. Has it aged enough to prep and stain or should I wait longer?
2. Should I use a pressure washer on this wood, or will manual cleaning be enough? No dark spots that I’ve seen. I’m a little concerned with damaging the wood with pressure, and overlaps.
thanks, Great site.
See this for tips about new wood: https://www.deckstainhelp.com/staining-a-new-deck/
You can use a pressure washer as a high rinse tool after using the cleaners.
Will this product work well on exposed timbers on a post and beam porch? The wood is untreated white pine and has been exposed to the elements for 10 years. There are significant black mildew stains and some worrisome brown staining on the ends of the horizontal beams, even with substantial roof overhang.
It should remove the mildew but the other stains are most likely water stains and a deck cleaner will not remove this.
Great job on the video. Thank you for taking the time to put this together and sharing.
Can you use this on cedar
Yes you can.
How much Restore a Deck Cleaner is needed for a Mahogany Deck that is 1350 Square Ft. + a one-story stair case? *Oil Stained w/ Cabot product.
You should use their Stripper Kit if swtiching brands of stain. You will need two kits.
I have a cedar deck that had some rotten boards. I removed all the rotten boards and stripped and brightened the remaining good wood before applying TWP100. I am installing new cedar where there was rot. So I have a deck with a nice TWP100 finish on the old wood plus boards that are new cedar. How long should I wait to apply TWP100 to the new wood? What prep should I use for the entire deck when it is time to reapply TWP100? I don’t want to strip again.
TWP states 4-12 months for neww wood to season. Use their Gemini Restore Kit when reapplying down the road.
