This post was updated on April 7, 2026
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood cleaning. My Restore-A-Deck Stain Stripper with Additives review is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
9.8 Rating Restore-A-Deck Stain Stripper Booster & Thickening Gel
I would love to hear if you have used the Restore-A-Deck Stain Stripper with the Booster and/or Thickening Gel additives on your wood or deck. Please post a rating in the Consumer Star Ratings below.
If you have any questions as to the effectiveness of your deck or wood stripping project, please ask below with the name of the stain brand and type being removed. Please add a couple of pictures as well.
Note: These are 2 additives for the RAD Stain Stripper. They only work as additives for the Restore-A-Deck Stain stripper and will not work by themselves. This article reviews both additives when used together in the RAD Stripper. We tested this on two extremely hard-to-remove finishes: Behr Acrylic-Based Semi-Transparent Wood Stain and a White Solid Color Deck Stain. Both of these coatings were applied 3 weeks before removal. Pictures of the test boards are below.
Restore-A-Deck Stain Stripper Booster – Up to 300% More Effective
Restore-A-Deck Stain Stripper Booster Additive is a special blend of solvents added to premixed 5-gallon containers of the Restore-A-Deck Stain Stripper. The Restore-A-Deck Stripper Booster will increase the effectiveness of stain stripping by up to 300% by helping to break down the surface tension of difficult-to-remove wood stain finishes.
Restore-A-Deck Booster should be used to increase the effectiveness of stripping difficult-to-remove wood and deck stain coatings. Stripper Booster improves effectiveness on removal for most exterior wood and deck finishes, including:
- Acrylic-based (water-based) wood and deck coatings such as Behr, Olympic, Sherwin Williams, etc
- Oil-based wood and deck coatings
- Clear wood and deck sealer
- Transparent wood and deck stains
- Semi-transparent wood and deck stains
- Most semi-solid exterior wood and deck stains
Behr Stain Before Stripping with Booster and Bare Wood After Stripping with RAD Stripper + Booster
Restore-A-Deck Stripper Thickening Gel Additive – Clings up to 1 Hour
Restore-A-Deck Stain Stripper Thickening Gel is a special blend added to premixed 5-Gallons of the Restore-A-Deck Stain Stripper. With a longer dwell time, Restore-A-Deck Stripper Thickening Gel will increase the effectiveness of stain stripping by adding the ability to cling to vertical and horizontal surfaces for up to 1 hour. Works especially well on improving the stripping performance on vertical wood, such as wood railings, wood fences, and wood-sided homes.
Restore-A-Deck Thickening Gel should be used to increase the effectiveness in stripping difficult-to-remove wood and deck stain coatings. RAD Stripper Thickening Gel improves effectiveness on removal for most exterior wood and deck finishes, including:
- Increased effectiveness for vertical surfaces such as railings, wood siding, log homes, and wood fences
- A longer dwell time for horizontal and decking surfaces
- Clings to wood for up to 1 hour
The pictures below show the RAD Stain Stripper with Thickening Gel combined with the Booster Additive. The before picture is Behr Acrylic Stain. The middle is after 30 minutes leaning against a wall. Notice how the stripper did not run off the wood with the Thickening Gel Additive. The after picture shows the stripping results.
RAD Stain Stripper with Thickening Gel – Before – During Leaning Against a Wall – After Stripping
How I Rated Restore-A-Deck Stain Stripper w/ Additives
My Restore-A-Deck Stain Stripper with Additives review contains a 5-step process and the final average score. Each step is on a scale of 1-10.
- Removal of Graying and Dirt
- Removal of Old Stain
- Ease of Application
- Restore-A-Deck Stain Stripper Additives Final Score
5-Step Review of Restore-A-Deck Stain with Additives
1. Removal of Graying, Dirt, Grime:Â 10
The RAD stripper will easily remove all oxidized graying, dirt, mildew, mold, and algae.
2. Cost Per Square Foot: 9
-Restore-A-Deck Stain Stripper covers 500- 1000 sq. feet for the 2 pound, $39.99. The RAD Booster and Thickening Gel Additives retail for $29.99 each. All mixed, this will make 5 liquid gallons for a total cost of $90. That equates to $18 per gallon. Excellent price for an extremely effective product.
3. Removal of Old Stain: 10
The Restore-A-Deck Stain Stripper with the Booster Additive was tested on Behr Premium Acrylic Semi-Transparent and a White Solid Stain. The stripper effectively removed over 100% of the Behr on our test boards (see pictures above). With the Solid White Stain, it removed 98% of the stain. Note on Solid Stain removal: while it worked very well for us on these test boards, Restore-A-Deck is not guaranteeing a solid stain removal with the 2 additives in their product description. If removing a solid stain, the RAD Stripper and Additives will help, but you may still need to do some sanding to remove all. The best option to remove a solid stain or deck paint is the RAD PaintStrip Solid Stain Stripping Gel.
Solid Stain Before and After Stripping Booster
4. Ease of Application: 10
The RAD Deck Stain Stripper with the Booster and Thickening Gel Additives is mixed with 5 gallons of water. We tested the stripper by applying it with a pump sprayer.
5. Final Appearance of Stripping: 10
Great at removing both our Behr Acrylic and White Solid Stain. You needed to use a wood brightener to neutralize after use.
Overall Score Restore-A-Deck Deck Stain Stripper with Booster and Gel Additives: 9.8
It removes difficult-to-strip coatings and helps with vertical (railings and siding) stripping. We will be using both of these additives as needed for our deck restoration projects
Manufacturer: Restore-A-Deck
Product Type:Â Deck Stain Stripper Additives to boost overall effectiveness.
Available Sizes: 16oz. Add these into 5 Liquid Gallons of RAD Stain Stripper.
Coverage Per Container: 500-750 sq. ft per 5-Gallons mixed.
Application Tools: Scrub Brush, Pressure Washer, Pump Sprayer.
Deck Wood Type: Cedar
Deck Square Footage:Â Test Boards
The condition of Deck: Behr Semi-Transparent Acrylic was removed. Solid White Stain.
Cost:Â Retails for $29.99 per Additive.
How To Strip With Restore-A-Deck Stripper Additives
Had stained my deck with BEHR Semi Transparent Cedar color on Cedar decking, railings and framing in 2004. Just like your review, it peeled very quickly (7mos) on the decking and other horizontal surfaces and lasted much longer on vertical surfaces. I followed all directions and was so disappointed I just let it gray out. Framing held up well but was now the wrong color as we’re rebuilding so stripping was necessary on any of the existing structure. Used the Stripper, Booster, and Gel Additives and a pressure washer with great success, although I found that even with the Gel, the dwell times were really short in direct sunlight (like 5min) so I had to do small areas at a time and keep it wet. Temps were mid to upper 70’s but results were better once the sun moved and I had more shaded space to work on. Spots where the stain dripped and looked more like paint needed more time, some scrubbing, or a second spot application. I have a 12×24 deck 9ft off the ground and mixed 1 gal at a time using a car wash style brush and a scrub brush and the results are fantastic. 1 package was enough to do all the framing including 4 4x6x9ft posts but barely. Be careful with this stuff if stripping overhead as it is caustic! I wore a Tyvek suit and long cuff chemical gloves and this stuff with the booster will burn your skin quickly. My forearms need a couple of weeks to heal. Pics are just the stripper, no brightener yet as I have to do this in stages but should look even better after that is done.
Great job!
Used RAD’s cleaner and brightener on a small, old deck. When it still looked ‘blotchy’ (photo on left), I contacted the company who recommended the stripper and brightener. Turned out very nice and am currently stripping another overly-stained deck.
Looks nice and thanks for your feedback. We have had some good results with the RAD Stain Additives. While they do not create miracles (removing thick solid paints), they definitely help with these hard to remove coatings.
Forgot to mention that I did use the additive during this stripping process and the deck I just finished. Both came out quite well. The deck I just finished was only 1.5 years old; however, it almost looked burned from being over-saturated with another brand of semi-transparent stain. You can see what RAD did for it. I am also working on a gate and have ordered the thickening gel. Will post results.
That looks like Restore A Deck in Semi-transparent Cedar.
Actually, it the clear semi-transparent stain over redwood boards.
Do you mean Natural? It does not come in a clear.
Ooops, yes. I used the Natural on everything except the Cedar gate … that’s the Cedar semi-transparent.
What brand and color/type stain did you use? Love the color.
Video of Stripping Behr Premium Solid Acrylic Stain with Restore-A-Deck Stain Stripper with Booster And Thickening Gel Additives.
I recently bought a 5 gallon pail to hopefully strip the paint i spilled all over my garage floor. This mess included sheet rock ground in and plaster from the people that did the walls. I had already painted the interior so i taped plastic 4 ft up the walls. Put product on with the roller they included.left on thick over night. Used my pressure washer and to my disbelief it loosened all the mess and I was able to get down to bare concert. very satisfied.
Thanks for the review!
I asked this question yesterday and could not find your response. One year ago, a contractor spray painted one coat of Flood semi transparent stain and did not back brush. I did not allow him to apply a second coat since it was well past the 24 hour timeframe to apply a second coat. First coat is very uneven. See attached picture. I plan on applying the exact same stain. How do I prep? If sanding is required do I use 80 grit and when will I know I sanded enough.
Don,
We responded to you yesterday: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/comment-page-260/#comment-108651
Hi. We have a cedar/redwood deck that’s about three years old. From what we’ve been told it was initially sealed with Cabot Clear Wood Protector and then soon after that a coat of some sort of water-based stain was used. That stain has mostly flaked off by now, but the Cabot sealer still seems to be present because water beads up. Now I’m looking to refinish it with something that actually lasts and has quality. Have decided to go with an Armstrong Clark semi transparent. I’ve been researching your site extensively and very much appreciate everything you have on here. My question is, to remove the remnants of the old stain and also the Cabot Clear Wood Protector will the Restore-A-Deck Stain Stripper with the Booster and Thickening Gel additives work, or am I better off just go straight to the RAD PaintStrip? I’d rather do the prep just once, but also don’t want to spend money that doesn’t need to be spent. That said, I don’t mind spending the extra money if it’s going to get the job done. Any advice would be helpful. Thanks.
Please add some pics of the deck in the comments.
Sure!
Here are a few pictures of different areas of the deck. About a third of the deck is covered, a third gets full sun, and a third is uncovered but gets only partial sun. We are in Boise Idaho, so we get cold snowy/icy winters, and hot dry summers.
Also, now I am considering using the restore-a-deck penetrating water-based stain instead of the Armstrong Clark. So if you have any advice on either of those for our climate that would be helpful as well.
Thanks again.
Another picture, this one showing some of the sun versus shade areas.
The Restore-A-Deck Stain Stripper with the Booster and Thickening Gel additives should work for this. You could try that, and if needed, spot apply with the RAD PaintStrip for any stubborn areas. Brightener would be last.
As for the AC or RAD stain, both are excellent. Do you prefer oil or water-based?
Honestly, my go to has always been oil since I have it in my head that water-based doesn’t penetrate and doesn’t last. But your reviews and videos have convinced me that I am wrong on that and that water-based, at least the restore a deck, can work just as well and will probably be a lot easier to apply and reapply in the future. My only concern was if our weather was too harsh for it to last and protect the deck. It sounds like they both will work well for us here though, so that’s good. Another thought… since the natural oils of the wood dry out, maybe oil-based stains will add oils back, whereas water-based stains do not, so the oil based stains make it last longer? Is any of that real, and if so does it matter?
Thanks again for all the information, advice, and help you give and offer. That’s a really nice thing to do.
The RAD stain penetrates just as well as an oil-based stain, but the application for both would be the same. The RAD would not be any easier.
The oils in the AC would help replenish internally. It does not mean the stain or the wood itself would last longer.
Hello again,
The deck restoration project continues… So I used the restore-a-deck stripper on the deck and it got 95+ percent of the old stain off. But I had used all the stripper to do that and trying to save the delay of having another bag shipped I ran up to the local Home Depot and got a gallon of the Behr deck stripper. While that did work to get the rest of the old stain off, now that it’s all dried there is a large color difference between all of the spots that I used the Behr on and the rest of the deck. Will that go away with brightening? Do I need to get another bag of restore a deck and strip or clean the entire deck again to make it consistent? Should I sand those areas instead? When I buff the deck to remove the fuzzies, will that take care of it? When I spray the deck down with water, mimicking what the final stain would look like, there is a definite color difference in those spot areas. What are my best options for getting a final consistent stain coloration?
You cannot spot-fix this by sanding or buffing. Most likely, the difference was caused by a pH difference between the 2 strippers. As long as you brighten everything and bring it all to the same neutral pH, it should even out the color.
I went ahead and used the RAD brightener, and while it made the rest of the deck look great, it unfortunately did not change the areas that I had used the Behr stripper on. they are still much darker than the rest of the deck. I had serious apprehensions of using a Behr product, but never thought it would lead to this. I thought it just might not work to strip the remaining old stain off. so now I’m still looking for a way to fix this issue. It seems like I can either sand the entire deck and then use the RAD cleaner and brightener, I’d rather avoid doing the sanding but will do if that’s the solution that works. Or strip and brighten again, this time using only RAD. Or use the RAD cleaner and brightener. Do you have any suggestions on which one would be effective? Or some other solution that I haven’t thought of?
Here are some pictures of what the areas look like after brightening. The deck is not entirely dry yet, but the dark areas are not water, they are darker from the Behr stripper.
I do not recommend using Behr stripper.
I do not think you can sand it out as it is internal. How long did you leave the RAD Brightener on the wood before rinsing? Do you have any left over where you can spot test? Apply the RAD Brightener to the dark spot in the first picture and do not rinse but let it dry into the wood. Trying to see if a longer dwell time will lower the pH of the wood there.
Hi Thanks for the quick reply. I only left the brightener on about 20 minutes before starting to wash it off. Unfortunately, I do not have any of the brightener left. If I place another order for the RAD brightener, I would just assume order up some of the stripper and/or cleaner at the same time if they would help, in order to not have to wait for shipping again. Do you think either of those would help this situation? Or is more brightener the most likely to succeed?
I thought I replied to this this morning, but maybe I forgot to push send. First, thanks for the quick reply. I left the RAD brightener on for about 20 minutes before starting to wash it off. I don’t have any left so I’ll need to order some more. If I’m going to make that order I’d happily order some more RAD stripper, or cleaner as well if you think either of those would help.
Thanks again for your knowledge and insights. It helps a lot.
I do not think using the stripper or cleaner will do anything. This is internal and results from raising the wood’s pH balance. The Behr raised it much higher for some reason. The goal is to even it out, and the only way this would work is to use a brightener to lower the pH.
The other possible option is to leave it as is over the Winter. Clean and brighten everything then and see if it evens out over time.
Great. Thanks. And to be clear, the idea is to put the brightener on the darker areas and leave it on there however long it takes until they lighten and match the surrounding areas and then to wash it off? As in, I’m not leaving the brightener on and never washing it off and then staining over the top of it.
I’ll post an update in case anybody goes through a similar thing in the future.
You can let it dry into the wood without rinsing. Try the dark spot in your first picture as a test.
I posted on another one of your articles. You recommended stripping and covering my Behr semi-transparent with a solid because I don’t want strip to the bare wood. I spoke to the RAD people they recommended 2 packs of the stripper and one each of the additives and to just add 2 cups of the 2nd packet stripper pack, which would be 7 gallons to cover my 955 square feet. What do think about the coverage and strength of the mix?
Are you trying to get down to the bare wood or prepping to cover with a solid stain?
The pictures show a Behr stain–thick, sticky and feeding mildew, which is a constant concern in Western Washington. Can RAD stripper with the additives be an effective AND cost-effective solution? Or is this siding shot?
It looks very thick, almost like a shiny varnish. In the faded areas the RAD Deck Stripper with additives will work well. In the very thick/shiny areas, you would need the RAD PaintStrip to it get it off.
Hi , Which product should I use to remove actual Olympic summit stain and seal. Woodland oil transparent? Do I need to use a sandblasting machine? Or you recommend something else? Thanks
Use the Restore A Deck Stripper with both addtives:
You pressure wash while doing this.
My 20+ year old deck was most recently sealed with Thompson’s water seal all in one transparent stain/sealer in Honey Gold. It was done 2 years ago and looks horrible. I would like to use the RAD products and a semi transparent RAD stain. For step 1 stripper, do I need to add any of the additives or just use stripper and brightener? Thanks.
Best to use both stripper additives here.
Hi Scott, need help. Over three weeks ago, I stained my deck with BEHR a transparent oil based stain (see attached) It has been 2 weeks after it dried (see attached of the partial stain photo) it’s still giving the toxic smell particularly under a hot sunny day. I’m afraid now, the smell will last for months. I want to remove the stain and hopefully the smell completely from the deck.
Can I use one of the Restore-a-deck products to remove the stain and the smell ? If yes, which specific product would you recommend is best to do this job ?
Wow, cannot believe they charge that much for their “poor” stain. The good thing it is easy to strip. Use the Restore A Deck Stripper and Brightener kit. As for a better stain without the smell, use the Restore A Deck Stains as well.
I will be stripping an old deck in which Cabot Semi-solid oil stain was used. Is this the same as semi-transparent? Much of it is worn off, but there are patches of the old stain throughout the deck. I’m planning on using RAD stripper and brightener, but should I include the booster?
Post some pics in the comments so we can help with prep info.
Sorry if this is duplicate.. I’m having trouble uploading photos. Hopefully here are photos of Cabot semi-solid stain. Should I use RAD stripper, add the booster, or do I have to sand. The photos are after a power wash
That looks like a solid stain on your wood so your best option is to power sand or use a paint stripper to get it off. We prefer the later. See for tips:
Thanks. I purchased the RAD paint stripper you referenced. Do I need to be concerned about getting it on the vinyl siding or shrubs when power washing it off?
Cover all areas when stripping and rinse with water when done.
Want to remove Sherwin Williams deck paint/stain to restain or repaint deck again, Please help !.
Post some pics.
Will RAD plus the two additives (booster and gel) work on several coats of Benjamin Moore’s Oxford Brown solid stain?
No. You will have to sand off a solid stain.
I’m restoring a Cedar/Doug Fir deck of unknown age, I do not know what brand of stain was previously applied. Last September I replaced several of the boards, then I used RAD stripper but it did not get all the stain off, especially in low foot traffic areas that are also protected by large eaves (see picture).
2 days after using the stripper massive forest fires burned 10 miles away. The deck got covered in ash and the project got put on hold.
Yesterday, April 24 we started back at it.
Im trying to figure out how to remove the remaining stain and address the issue of the color difference between new boards installed last September, new boards installed yesterday and the old original boards that still have stain on them? Any help is greatly appreciate. I will be using RAD woodbrightner and Cabot semitransparent stain.
Thank You
Glen from Eugene Oregon
In the pictures it looks like you stripped all of the old stain off. The discoloration under the eaves is not old stain but darkening of the pH of the wood from the stripper and is why you have to brighten the wood right after stripping. Using the brightener should still even out the color. Might want to consider a better stain option. Cabot changed their formulas, not as good as they used to be:
I have an IPE deck which is around 8 years old. I have been able to treat it every other year due to work travel – but will now have more time. We have full, hot sun so the floor turns grey 10 – 12 months after prep and oil.
I am replacing 8 or so 16 foot boards with new IPE (I have not installed them yet). Should I install them then treat them as the rest of the deck – or keep separate for a different process and what would that be?
Install them and then let them weather over the winter. Prep and stain all the same in the Spring prior to staining.
1) 26 yr old deck
2) Has current coating of solid color stain—several layers
3) Unsure what stain will be. May change to semi transparent vs solid color. Will stay with Sherwin Williams however.
4) Sherwin Williams
5) Water based solid stain
6) Green algae issues (north facing deck)
7) No stain failure. Just many years/layers. Need a fresh start again.
A stripper will not remove a solid stain fully so you will have to use a solid stain again unless you want to sand it all off. The RAD Stripper with additives will help with removing the loose and peeling stain.
If we choose to sand it, should we clean it first (algae) with deck cleaner?
Strip it first as mentioned while pressure washing and then sand it.
what is the best stripper to remove flood pro series 100 acrylic stain solid color. thanks
You cannot strip off solid stain fully. You will have to sand to get it off.
Greetings, we are in the process of restraining our deck. Unfortunately I did not run across your awesome website before we started.
We applied Olympic stain and sealer on a new cedar in deck after the wood weathered about 6-7 years ago.
We power washed deck and got most of the stain off. Then proceeded to try and sand off the rest.
Need advice on how to get this thing properly prepped as I have seen here that sounds like the most important part of the process. Based on what I have read I will want to use cedar tone Twp 100.
We live in western central Missouri.
Thanks in advance for your thoughts.
Use the RAD stripper and additives to remove the rest with pressure washing. Brightener after.
Thanks so much for the quick response.
I have a 16 x 20 ceader deck i have just used a diama brush to to remove solid color
sherman williams super deck and dock. i want to apply Restore a Deck semi trans parent
stain is there a stripper to use between the boards that will work? Any help with this!
thank you vince
diamabrush16x20 cedar deck the deck was covered with sold colored sherman williams super deck. the deck is now down to bare wood.but there is some solid stain between boards.
what stripper will work ? i want to apply resoter a deck semi transparent stain
thank you for your time vince
You can try but use both additives.
Is there a sprayer you recommend for using the gel additive and the strip booster? The Chapin International 25020 gets very mixed reviews and I’m afraid it wouldn’t work with the gel. Ideally we’d be able to use the sprayer we get to spray the stripper and also a new sealant (haven’t picked new sealant yet…just want something basic and not tinted). Thank you.
We have personally used that sprayer with the stripper and the gel in the sprayer using the yellow tip and works.
Here is my deck. Looking for suggestions. Deck was built in 2015. See pics. Last pic is stain I used.
Thanks for your suggestions.
That is an opaque solid stain on the deck. You cannot strip this off fully.
So what should I do to get the best result.
Pressure wash and then apply another solid stain over the top. https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
You would just be able to pressure wash and add another stain (any color solid) over the top? I would have thought he would need to sand/strip to get as much stain off as possible. Can you apply another solid stain on top of a cracked/peeling solid stain as long as the wood is clean?
Yes but you have to make sure th current stain is not peeling and is fully intact to the wood.
Have new garage deck and porch railings which are pine. (Vertical posts pressure treated and some older wood which will be sanded prior). Prior deck had terrible peeling problem due to type of strain and full sun all day. Contractor says can be stained right away because pine and suggested arbor coat. Need a better stain that will be taupe/light brown in color not cedarhoney or red. Other times I have used Rymar brand. You seem to have a few favorites – in high sun setting mostly pine what do you suggest?
Your contractor is incorrect, it cannot be stained right away: https://www.deckstainhelp.com/staining-a-new-deck/
Look at Armstrong Clark or TWP.
I posted a question about a deck still being tacky however I gave you incorrect information. The deck has only 2 coats of stain. The stain was completed in 80+ degree weather 17 hours ago. The deck remains tacky. What can I do to remedy the excess. Please see my first posting for further details. Thank you.
Try wiping the excess stain with mineral spirits and rags. Saturate all oil rags in water and lay flat to dry outside of the house when you are done.
Thank you. Will do. I’m very pleased with the product so far and hope to enjoy the finish for a prolonged time.
I used RAD STRIPPER/BRIGHTENER kit on my 830 sq. ft. deck in NE OHIO. Then followed it by 2 coats of TWP 1500 series Cedartone 1501 stain. The result is beautiful. My concern now is my helper sprayed on a third coat that remains shiny even after wiping with a rag. Now what do I do to remedy the excess stain?
Hi there, I have this deck and I believe the stain on it is the Pittsburgh Ulta advanced stain & sealant in one solid color stain. It was stained when we bought the house and I found a mostly used can of it in the shed. It’s peeling badly now, so I’m looking for advice on how to get it stripped so I can restain. Thank you!
You will need to power sand this to remove it fully.
Last one (I think I may have gotten carried away with using RAD). This is our new-ish garden gate before and after. While the gate was only installed a year ago, I realized when I applied the cleaner that it actually had a stain on it. Thus, I used the stripper and gel additive in order to enhance the staying power of the stripper. As you can see, it turned out pretty nice. I’m so impressed with RAD that I’m going to tackle an old redwood structure that surrounds our spa — now that will be a challenge. BTW, I used semi-transparent cedar on the gate.
Me again. This time, I wanted to show you a ‘redo’ of a very large deck that was installed probably 20 years ago. We just had new railings put on last year so I wanted to clean the rails and strip the deck so that the boards would match (everything is redwood). I used the stripper plus the additive and it certainly made a difference. I was amazed at how well the old deck turned out!! The stain I used was the clear semi-transparent — two coats on the deck and one on the railings.
Looks great!
Jan,
Perhaps you did get carried away but I have really enjoyed seeing all your pics. I am about to apply this formula to remove a stain I hated once applied and your posts give me hope that I my deck will turn out just as beautiful. Thanks!
Thanks Silvia. I did end up redoing our spa enclosure and, while I didn’t have much hope for it, it turned out great. A year later and everything still looks good. I’m planning on cleaning and restaining everything next Spring but it should be much easier this time around. Good luck with your project and be sure to post before and after photos!
I have an old ottoman & the legs are a cherry wood color. Can they be stripped? I’m trying to get a more natural wood color. What do u suggest? Thank you!
Post a picture.
Does power washing alone (well I used a crappy cleaner too) strip old stain?
Sometimes but that depends on the coating.
Our original deck was 7 yrs. old when we bought our house. It had never been stained or painted. After we extended the deck, I stained the entire thing with an Oil based semi translucent stain. The two sections came out different colors. Can I use a solid oil based stain over the translucent stain without stripping the old stain? I live in the piedmont region of NC. Mixed sun and shade on deck and mold and algae are a problem.
Yes, you can do that.
Hello, I have the Behr Deckover coating. It is that really thick paint like coating and it is peeling. Will this remove that? I hope I do not have to sand.
Sorry but no. No stripper will remove the Deck Resurface type coatings like Behr Deckover and Rustoleum Deck Restore. They are too thick for any stripper to be effective. Sanding is your only option. Picture of Behr Deckover attached.
