Oil Based vs Water Based Deck Stain: Which Is Better? 4.4/5 (98)
Hi, I’m Scott Paul, a licensed exterior restoration contractor with over 30 years of experience and 10,000+ deck restorations. This comparison of oil and water based deck stains is based on my own hands-on field testing, not manufacturer claims. See my full credentials and testing stats here.
My team completes 300 to 400 deck staining projects a year across the US. I have tested both oil and water based stains on pressure treated pine, cedar, redwood, and exotic hardwoods, monitoring results over multiple seasons in climates ranging from the Pacific Northwest to the desert Southwest.
What are Deck Stains, and Why Do They Matter?
Here, I will explore the different options for your deck: oil vs water based stains.
If you are new to the subject, exterior wood stains are sealers or coatings applied to improve the appearance of your deck. More importantly, they help protect it from moisture and ultraviolet (UV) rays, which can cause problems such as peeling, discoloration, mold, or mildew growth. While paints typically form a solid exterior coating on the surface, most deck stains penetrate the fibers to protect the wood while preserving its natural appearance. Exterior deck stains are primarily comprised of either an oil or water base plus dyes, pigments, solvents, and resins.
Quick Answer: Oil vs Water Based Deck Stain
  • deck stain choice depends on wood condition, local climate, and VOC laws; water-based for new/restricted states, oil-based for older weathered wood.
  • deck stain oil-based penetrates deeper and allows easier clean and recoat; water-based dries faster, low odor, but may peel and need stripping.
  • deck stain lifespan is similar: 2 to 3 years horizontal, 4 to 6 years vertical; pigment density and proper prep matter more than base type.
  • deck stain prep is critical: always strip and brighten before switching base types; recommended products: Restore A Deck, Defy Extreme, TWP 1500 Series.
For my full rankings across every wood stain type, oil based and water based, see my top rated deck stain reviews.
Moreover, the main reasons to stain your wood deck are to:
  • Enhance appearance
  • Protect from water damage
  • Prevent UV damage and oxidation
  • Thwart mold and mildew
If left untreated, decks will weaken, fade, and need to be prematurely replaced.
You are probably wondering, is an oil or water based stain a better option for my deck? I always say that the decision depends on your local climate, the age and condition of your deck, and product availability based on VOC laws in your state.
Key Differences Between Water-Based and Oil-Based Stains
Oil vs. Water-Based Deck Stain: Side-by-Side Comparison
Factor Oil Based Water Based
Penetration depth Deep, soaks into wood fibers Moderate. Restore-A-Deck and Defy Extreme are exceptions
Dry time 4 to 12 hours 2 to 4 hours
Cleanup Mineral spirits required Soap and water
VOC level 250 to 450 g/L typical 50 to 250 g/L typical
State availability Can be restricted in 20 states and Canada Available in all 50 states and Canada
Typical longevity on decking 2 to 3 years horizontal, 4 to 6 years vertical 2 to 3 years horizontal, 4 to 6 years vertical
Maintenance recoat Clean, brighten, and recoat Stripping may be needed if worn unevenly
Odor during application Strong, solvent fumes Low odor
Best for new wood Weather smooth or milled wood 3 to 4 months, then oil penetrates well Good option, especially premium brands
Best for older weathered wood Excellent, especially TWP and Armstrong Clark Good if properly prepped
Cost per gallon (pro grade) $65 to $85 $48 to $75
How VOC Laws Changed the Deck Stain Market
For a short history lesson, oil based wood stains used to dominate the market, but that trend changed in the 90s when environmental laws regulated the emission of volatile organic compounds (VOCs). This resulted in a shift to more water based stain options, which varied in quality and ease of use.
Today, most DIYers find oil based products more challenging to use. Still, they can effectively enhance the natural appearance of the wood, protect against moisture, and prevent the growth of mold and mildew. On the other side, water based stains are typically easier for novices to manage, eco friendly, and simple to clean up with only soap and water.
Fortunately, in recent years, water based stains have improved dramatically. For example, water based stains resist water and harmful UV rays, and additives like zinc prevent fungal growth. Unlike oil based stains that often take 4 to 12 hours to dry, many water based options dry in only 2 hours.
Neither oil nor water based deck stain lasts forever, and on a horizontal deck surface both types perform similarly in terms of lifespan. From my testing, expect 2 to 3 years on horizontal decking and 4 to 6 years on vertical surfaces like railings and trim from a quality penetrating stain of either type. The more important distinction is what happens when the stain begins to wear. Quality oil based stains wear gradually and can usually be recoated with a simple clean and brighten, no stripping needed. Water based stains, when they fail, tend to do so unevenly and often require stripping back to bare wood before a new coat will look consistent. Choosing a penetrating stain over a film forming one, regardless of base type, is the single most important factor in making future maintenance manageable.
Next, I will explore some of the advantages and disadvantages of both oil and water based deck stains.
Advantages of Water-Based Deck Stains
  • Fast drying: Because water evaporates quickly, water based deck stains dry faster than oil based stains.
  • Less odor: Water based stains are more eco friendly and generate less odor.
  • Quick cleanup: Easily cleaned with soap and water.
Water-Based Stain Disadvantages
Less penetrating on dense or weathered wood: Most water based stains bond more to the wood’s surface than inside it, which means they are more vulnerable to peeling in freeze thaw cycles or under heavy foot traffic. The exceptions I have tested are Restore-A-Deck and Defy Extreme, which penetrate close to the level of a quality oil based stain when the wood is properly prepped.
Prone to peeling when over applied: Water based formulas dry quickly, which tempts applicators to add a second coat before the first has fully absorbed. Excess product sitting on the surface rather than inside the wood is the primary reason water based stains fail early. Apply thin, even coats and let the wood absorb what it can before evaluating whether a second coat is needed.
Harder to recoat after uneven wear: When a water based stain wears inconsistently, patches of bare wood sit next to patches of remaining stain. A new coat applied over that pattern will look uneven. In most cases, stripping back to bare wood is required before recoating, which adds time and cost compared to the recoat process for a quality oil based stain.
Benefits of Oil-Based Deck Stains
  • Penetrate deeply: Oil based stains will deeply penetrate the wood and create a durable layer of protection.
  • Enhances the appearance of wood: Most oil based stains provide a rich color and highlight the natural wood grain.
  • Easy to maintain: After several years, oil based stains will begin to wane, allowing you to efficiently clean, brighten, and recoat the surface.
Oil Based Stain Disadvantages
Longer dry time creates application challenges: Oil based stains typically require 4 to 12 hours of dry time and are sensitive to temperature and humidity during that window. Applying in direct sun above 90 degrees or in high humidity can cause the stain to become tacky, trap brush marks, or dry unevenly. Plan application for morning hours when temperatures are stable.
Stronger fumes require ventilation: The solvent content in oil based stains releases VOCs during and after application. Work with adequate ventilation, keep people and pets off the deck until fully cured, and check the product’s safety data sheet for recommended exposure limits. Many newer low VOC oil based formulas from Armstrong Clark and TWP have significantly reduced this issue while maintaining performance. Oily rags can also spontaneously combust, so lay them flat outdoors to dry or store them in a sealed metal container filled with water.
Restricted in about 20 states: VOC regulations in California, Colorado, Connecticut, Rhode Island, Maine, Massachusetts, Michigan, New Hampshire, Vermont, Delaware, Maryland, New Jersey, New York, Northern Virginia, Pennsylvania, parts of Arizona, Ohio, Illinois, Indiana, and Washington DC limit which oil based stains you can legally purchase. TWP 1500 Series and Armstrong Clark Wood Stain remain compliant in all 50 states and are the two oil based products I still recommend for buyers in restricted states, though you may need to order them online.
Oil Based vs Water Based Deck Stain: Which Should You Choose?
The right choice between oil based and water based deck stain comes down to your wood’s age and condition, your local climate, and which products your state’s VOC laws allow. Here is how each factor breaks down.
Local Weather Conditions
If you live in a region with certain weather extremes, an oil based stain might be a better choice for protecting the wood surface. For example, certain parts of Arizona, California, and Nevada may expose your deck to direct sunlight on more than 80% of days each year. Areas of Western Washington, Western New York, and Northeast Ohio have tremendous amounts of rain and other forms of annual precipitation.
Type of Wood
The most common types of wood used in exterior decks are pressure treated pine, cedar, redwood, and exotic hardwoods like IPE. Pressure treated pine is often vulnerable to mildew and rot, making it most suitable for oil based products. Water based stains continue to improve in many ways, and a few brands will penetrate just as well as oil based stains.
Finish and Color
Consider a water based stain when aiming to achieve a more opaque, solid color appearance, and an oil based product for a natural appearance. Water based stains are more easily mixed when trying to match a custom color.
Environmental Considerations
Water based stains are known as the green choice, with lower levels of volatile organic compounds (VOCs). Many makers of oil based deck stains have also introduced low VOC options.
Switching Between Oil and Water Based Stain
If you are switching stain types on a deck that has already been stained, the prep requirements change significantly depending on which direction you are switching. Applying a water based stain over an existing oil based stain is not recommended without stripping first. Oil based stains leave behind a residue that water based formulas cannot reliably bond to, which leads to adhesion failure, uneven color, or peeling within the first season. You must strip the old oil based coating completely using a deck stain stripper, follow with a wood brightener to restore the surface pH, and allow the wood to dry before applying any water based product. Going the other direction, from water based to oil based, requires the same process: a full strip and brighten before recoating. Skipping this step is the most common reason deck staining projects fail on previously stained surfaces. See my complete guide on how to prep a deck for staining for step by step stripping and brightening instructions.
Does Your State Restrict Oil Based Deck Stains?
VOC laws directly affect the oil vs water based stain decision for millions of homeowners. Currently about 20 states plus Washington DC and Canada restrict the sale of high VOC exterior coatings. Those areas are California, Colorado, Connecticut, Rhode Island, Maine, Massachusetts, Michigan, New Hampshire, Vermont, Delaware, Maryland, New Jersey, New York, Northern Virginia, Pennsylvania, parts of Arizona, Ohio, Illinois, and Indiana. In these areas, most traditional oil based stains cannot be sold at local stores and are difficult to find even online. The lower VOC limits primarily affect oil based products because reducing solvents changes how oil based stains dry and cure. If you live in one of these states and prefer oil based performance, TWP 1500 Series and Armstrong Clark Wood Stain are the two oil based products that meet the 250 g/L standard and remain available for shipment to all 50 states. For most homeowners in restricted states, a premium water based stain like Restore-A-Deck or Defy Extreme is the practical path of least resistance and will perform at the same level when the wood is properly prepped.
Top Water-Based Stain Ratings
Restore-A-Deck Wood Stain
The Restore-A-Deck semi transparent product is applied using a three step process that saves time and money. It is among the few options that allow for prepping and staining your deck on the same day.
$53.99
Defy Extreme Stain
This semi transparent option is extremely eco friendly and effectively prevents graying from exposure to UV rays. The Defy Extreme product is available in colors including Cedar, Natural Pine, and Light Walnut. It works well on cedar, ipe, redwood, teak, and tigerwood.
Note: Both the Restore-A-Deck and the Defy Extreme stains will penetrate just as well as an oil based stain.
Top Oil-Based Stain Ratings
TWP 100 Series
The Total Wood Preservative (TWP) 100 Series is a semi transparent product available in eight colors and VOC compliant in 36 states. Although I do not recommend it for new wood decks, it protects very well against water, rot, mildew, and sunlight on older wood.
5.00out of 5
5.00out of 5
5.00out of 5
Oil based options from Armstrong Clark are offered in transparent, semi transparent, and semi solid, and are VOC compliant in all 50 states. I have found that a single coat provides a professional finish that lasts for at least two years.
TWP 1500 Series
TWP 1500 Stain Review
The Total Wood Preservative (TWP) 1500 is a semi transparent deck stain offered in 10 colors. It also works well on exterior wood, such as fences, wood siding, log cabins, and cedar shakes (shingles). I have found that after application, the TWP 1500 prevents graying for two years or longer.
$69.99
$264.95
$315.00
$329.00
Oil vs Water Based Deck Stain: Frequently Asked Questions
Is oil based or water based deck stain better for pressure treated wood?
Oil based deck stain has traditionally been the stronger choice for older pressure treated pine because it penetrates the dense fibers more effectively and delivers better mold and moisture resistance. However, new pressure treated wood should not be stained with either type until it has weathered properly. Smooth or milled boards need about 3 to 4 months, while rough sawn boards can be stained once they are clean and dry. Use the water bead test either way: sprinkle water on the boards and stain once the droplets absorb into the surface rather than beading up. For pressure treated decks that are properly prepped and weathered, Restore-A-Deck Wood Stain and TWP 1500 Series are my top recommendations regardless of base type, as both penetrate and protect this wood well.
Can I apply water based deck stain over an old oil based stain?
No. Applying water based stain directly over an existing oil based stain will almost always result in adhesion failure, peeling, or uneven color within the first season. Oil residue prevents water based formulas from bonding properly to the wood fibers. Before switching stain types in either direction, the existing coating must be stripped completely using a deck stain stripper, followed by a wood brightener to restore the surface pH. Once the wood is bare, clean, and dry, a quality water based stain will adhere and perform correctly.
How long does oil based deck stain last compared to water based?
On a horizontal deck surface, both oil and water based stains from quality brands typically last 2 to 3 years before a maintenance coat is needed. On vertical surfaces like railings and trim, either type can last 4 to 6 years. The practical difference is not how long each lasts but what happens when it wears. Oil based stains wear gradually and usually allow a clean and brighten before recoating without stripping. Water based stains are more likely to wear unevenly, which may require stripping before recoating looks consistent.
Which states restrict oil based deck stains?
Currently about 20 states plus Washington DC and Canada have adopted VOC regulations that restrict or limit the availability of traditional oil based deck stains. Those areas are California, Colorado, Connecticut, Rhode Island, Maine, Massachusetts, Michigan, New Hampshire, Vermont, Delaware, Maryland, New Jersey, New York, Northern Virginia, Pennsylvania, parts of Arizona, Ohio, Illinois, and Indiana. In these areas, most oil based stains are not sold at local stores and can be difficult to source. TWP 1500 Series and Armstrong Clark Wood Stain are the two oil based products I know of that remain 250 VOC compliant and can be shipped to all 50 states.
What is the easiest deck stain to apply, oil or water based?
Water based stains are easier for most DIYers to apply. They go on thinner, allow more working time before lap marks set in moderate temperatures, and clean up with soap and water rather than mineral spirits. Oil based stains require more careful timing, particularly in heat above 90 degrees or high humidity, where they can become tacky and trap brush marks. Armstrong Clark is the exception among oil based products, since it can be applied in direct sunlight and heat. That said, oil based stains are more forgiving when it comes to recoating, because their gradual wear blends more naturally under a new maintenance coat than the uneven wear pattern common with water based stains.
Is water based deck stain as durable as oil based in a hot, sunny climate?
In high UV climates like Arizona, Nevada, and inland California, pigment density matters more than base type. Darker, more pigmented stains of either type will outlast lighter ones because pigment acts as a sunscreen for the wood. Among water based stains, Defy Extreme uses zinc nano particle technology specifically designed for UV resistance and performs well in full sun exposure. For older wood in high UV regions where you want a natural look, TWP 100 Series remains a strong oil based option. In either case, a semi transparent stain will outperform a clear or toner product significantly in direct sun.
Finding the Right Fit for Your Deck
Oil vs water based deck stain is not a one size fits all decision. Here is how to make the right call based on your specific situation.
Choose a premium water based stain if: Your deck is newer or in good condition, you live in one of the restricted VOC states, you want to prep and stain in the same day, you prefer soap and water cleanup, or you want the best UV color retention over time. My top recommendations are Restore-A-Deck Wood Stain and Defy Extreme, both of which penetrate as well as a quality oil based stain when properly applied.
Choose an oil based stain if: Your deck is older and heavily weathered, you are dealing with very dry or porous wood that needs deep conditioning, you are in a high moisture or extreme weather climate and your state permits oil based products, or you want the most forgiving recoat process down the road. My top recommendations are Armstrong Clark Wood Stain, which is compliant in all 50 states, and TWP 100 Series for older weathered wood in the 36 states where it is available.
When the choice does not matter as much as you think: On a properly prepped deck with a high quality product from either category, the performance difference between oil and water based is smaller than most people expect. The prep work, including cleaning, brightening, and full drying, will have more impact on how long your stain lasts than the base type alone.
Ask Me About Oil vs Water Based Deck Stain
Still not sure which type is right for your deck? Post a comment below with your state, your wood type, how much sun the deck gets, and what stain was used last time, and I will tell you which base type I would use and which product I would pick.
101 Comments
James
James
4 months ago
Just stumbled across your site. Great resource! Thank you. I have a new fence, with Douglas Fir stringers and Cedar pickets. I live in a high desert environment: low humidity/precipitation, lots of sun and some temperature swings (although not as extreme as some areas). I’m leaning towards a solid color stain, for UV resistance and longevity (and the extra hiding of the grain isn’t a big concern for me, relative to other factors). Ease of use is appreciated, but I’m not worried about completing this in a single day.
I was honestly a little surprised to see that your top solid color stain were water-based, given your comparison of oil-based and water-based stains. I certainly prefer using water-based stains and paints, but I am worried about the risk of peeling and long term maintenance. I guess you’re saying that this is not a concern with the specific brands you recommend (RAD and Defy)? Do you think this may change further out from the 2 year mark? Have you been using RAD and Defy long enough to need to reapply them? In general, why do you recommend oil-based stains for semi-transparent and semi-solid but water based for solid color? Again, I’d prefer to use a water-based stain, but I don’t want to regret this down the road. Thank you.
Helen Lacy
Helen Lacy
10 months ago
How soon should a new deck be stained??
Stephen G
Stephen G
Hi Scott, just found your website, thanks for all the information!! If a water based penetrating stain has been previously applied, do you need to use water based again? Or can you switch to an oil based stain?
Dee
Dee
If it were you Scott Paul and you had a one year old pressure treated deck which is in the shade all of the time except for the steps and near a lake, would you choose oil or water based stain/sealant and which brand would you choose.
Dee
Dee
Yes there is mold & mildew issues here so which brand would you use.
Hannah
Hannah
Hi again,
I have questions about our balcony and front steps as well!
The balcony I can’t tell if its ever been treated with stain? (Pictures below) It looks like it is just cedar toned wood bought that way. We built our front steps with cedar toned wood which is why I think that. But I wanted to ask the professionals!
Is the balcony in need of a strip or does it look like cedar toned wood and can we go ahead and stain and seal it? Should we clean it first with a cleaner or if it’s never been stained before is power washing good enough?
Thanks again!
Hannah
Hannah
Hi, my husband and I have 3 separate wood outdoor surfaces we need to stain/seal. A large back deck, small balcony, and some front steps.
These pictures are of the back deck.
The deck is old with cracks and weathering but still in good condition. Before pressure washing it didn’t seem to have a stain on 85% on it, just greying all over. So we pressure washed the whole thing and it looks new again. But 15% had what the pictures show below and the pressure washing didn’t get it all off. Is it an old stain that I need to strip? Does it need to come off or can i stain right over it?
What do I use after stripper if I need it? A brightener on the whole deck or just those areas?
And if I do need to strip whatever this is, do I need to do the same to the whole deck?
Hannah
Hannah
Strip and brighten for the front balcony as well? I sent separate pictures above this post, because I think it might just be cedar toned treated pine? Your thoughts?
We had Arborcoat natural put on our cedar siding in fall 2019 here in mountainous B.C. Canada, which receives full sun and some rain/snow exposure. It started looking poor after the first summer and looks terrible now. Would oil-based be better than water-based for this setup? Do we need to sand off the Arborcoat before putting a new product on? Would you recommend TWP 200 or Armstrong wood stain or something else? We would ideally still get this transparent look to see the beautiful western red cedar but have a product that continues looking good for years to come with least amount of maintenance possible. Thank you for all you do.
Thanks Scott. Looking at TWP stain stripper to get the Arborcoat off. Would you suggest 1 coat or 2 coats of TWP 200? And how many years to re-apply? Any idea on which TWP 200 colour would be the most natural looking for cedar — perhaps TWP201 Cedartone or TWP205 California Cedar?
Tanya
Tanya
I just washed my deck with dawn dish soap with a broom and a bucket of water. rinsed well with the hose. I’ve had a lot of squirrels this winter pooping an peeing on my deck. Half of the deck is covered but the uncovered part is taking a beating for the sun. 2 years ago a company came out and power washed the deck with water only and let it dry for a day the came back a put one coat of Pinafin (spelling?) on it. I hated it. No water beaded up except for the covered part. they said there was no need for 2 coats. My deck looks in terrible shape this year. I live in the Denver metro area and limited guy’s that work on decks. Theses last guys wanted Thousands to sand and restain the deck. I had it sanded a year prior. What can I do now to save my deck? My husbands in his 80’s and I’m not worth much any more….
I am refurbishing a barn like building on my property and have a question about interior stain for re-sawn lumber. I am using the re-sawn lumber to trim out windows, for base board and for shelving. I am ok with a rustic look. Some of the lumber is western cedar re-sawn planks which I already have and some will be simple 1×4 re-sawn furring strips (I assume cedar or pine?) from either a lumber yard or box store. Any stain suggestions would be greatly appreciated. Thanks
Faith Johnson
Faith Johnson
I am looking to stain a new pressure treated pine covered porch in Georgia. I am interested in semi transparent and minimal maintenance. Everyone I talk to recommends oil based but since it is covered, is UV protection still an issue? Also, does staining the underside of the deck offfer greater protection? Finally, what about the outside vertical areas? Should I use a more durable stain for that? Does it make sense to use a water based stain on the floor inside the porch and an oil base for the outside and vertical areas?
Thanks for any advice you can give.
Faith Johnson
Faith Johnson
Reply to  Faith Johnson
Thank you so much for your quick reply. The painter I am thinking of using to stain the new porch said they use TPW 200. Is that recommended for a screened in porch. What is the difference between that and TPW 100 that you recommend? (I don’t see the 200 series mentioned on your website.
Thanks again!!!
Edie Kello
Edie Kello
Scott, I am Edie Kello, director of marketing for Viance, LLC. We make the preservatives that go into pressure treated wood, selling to wood treaterts. Our website is treatedwood.com. We have many downstream customers: lumberyards, contractors, architects, code officials, DIYers, that ask us this question in your article, Water-based vs. oil-based deck stains. I would love to have you as a guest author in our news section on our treatedwood.com website. I would post your article acknowledging you as author with a link to your website for more information. This way we direct customers to the authority on this subject matter. I have read many posts on this subject and believe you have the most thorough and credible information. Please check out our site. We have over 10,000 users on our website each month. This education is important and we want to direct them to your website. Thank you.
Michael
Michael
I have some redwood stairs and railing that I initially treated with Superdeck semitransparent stain. Now I would like to switch to a water-based product. Is there an alternative to sending it down to bare wood first? My apologies, I am sure this question is frequently asked.
Michael
Michael
Here are pics showing post-scrubbing with a wood cleaner product.
Michael
Michael
Chuck C
Chuck C
Hi, I’m in the Chicagoland area. We have a pressure treated pine deck, and then an addition covered in cedar car siding. What would you recommend? Thanks a ton!
Dawn
Dawn
Installed new fence. I’m assuming it’s pressure treated pine. I live on the North Carolina coast, 1/2 mile from the ocean. Which should I use Oil or water based?
jeannie reeves
jeannie reeves
What is the best stain for coastal Mississippi?
Austrial
Austrial
I recently wrapped my front porch posts with KDAT pine wood. I would like to know which type of stain would be best for this project, water base or oil base. I’m looking to stain the posts a dark walnut and I do live in Illinois so we go thru all four seasons.
Brian
Brian
Thoughts on Ready Seal? That is the brand pushed by a company in the area. Looking to do the work myself. Power washed already, mixed reviews out there on stain. Want the best stain to look and last the longest!
Jo Anne Supplee
Jo Anne Supplee
My property has a cedar privacy fence and appears to be stained with a semi-transparent stain. Have no idea how old it is, but the stain is starting to fade. When I had to have some large trees removed, they dropped a large limb that bounced and took out two panels of the fencing. They did replace with two new cedar panels, but now I have to stain it. I most likely will have to stain the entire fence. Problem is, I have no idea what type of stain/sealer was used by previous owner. How can I tell if it was oil or water based stain so I know what to use? Any quick and easy solutions? Thank you.
Wayne
Wayne
i used what I thought was a top rated Behr semi-transparent weather proofing stain on my pine treated deck and it started pealing after a few years. While Behr replaced that product, I had to strip and sand which was a pain. While I’m planning to use Behr premium waterproof stain and sealer to recoat this deck, I’m concerned if this paint is my best choose as it has been sitting in my basement for 2 years. My son is planning to stain his treated pine fence and I question if a water base stain would be his best bet as I would hate to have him have to sand the fence when he needs to restain his the fence 5 to 10 years down the road. Your advise would be appreciated
NY1
NY1
I have a new pressure treated deck that was built 2 years ago, the wood has never been painted or stained. I bought Cabots wood sealer to apply and I was told that I should mix 1 gallon of the cabots with a gallon of paint thinner and apply 2 thincoats 2-4 hors apart and then in 24 hours apply an undiluted coat of the cabots. Does anyone have any experience with mixing these 2 products and does it make the finish last longer?
Tracy
Tracy
What do you consider better? I really only want to protect the wood, it is a pool deck and it is in full sun all day. Thank you for responding!
nance
nance
We have multiple cedar & pine decks. Live in VT. . harsh winter and strong sun. Do not know if wood is pressure treated. Have stained several times but all water based stains peel after 1 year. Never last more than 1 year. What are we doing wrong? Would we get a better result using oil based in this climate. We are at our wits end. Please advise.
Louis North
Louis North
Good info, but what are the disadvantages to each? Just bought a house that has a 1 year old pine deck that has never been stained. North Georgia, so very rainy winters, and surrounded by pine trees. Wondering which type would be best, oil or water based. Looking for a semi-transparent. I’ve had deck stains in the base that peeled one year later and want to avoid that here. Thanks
shnook
shnook
we live on rainy west coast…there is a new product that is oil based , claims organic, (claims to have no V.o.c.’s) but dries fast and cleans up with water, so is water soluble… Contains linseed and Tung oils and beeswax. .. I wonder how it will hold up on a new cedar deck? and if another traditional oil based product could be applied on top of it, once applied.?
Lou Roessler
Lou Roessler
We live in N.California in the SF Bay Area… We just replaced our 32 year old 800 sq foot redwood deck with a new one.
I used Penofin redwood tinted oil deck stain on that original deck and it looked and stayed beautiful for a few years before a recoat…
Our deck faces South and gets fried in the summer sun…We can no longer get the “good” stuff because of EPA regulations in this area…
What would be a good oil based product we could use on our new redwood deck?
Lou R.
Lou Roessler
Lou Roessler
We live in N.California in the SF Bay area…We just replaced our 32 year old 8oo square foot redwood deck with a new one. I used Penofin red tinted oil deck stain on that original deck and it looked and stayed beautiful for a few years before a recoat…
Our deck faces south and gets fried in the summer sun…
What would be a good oil based product we could use on our new deck?
Steve B
Steve B
I just picked up valspar one coat exterior stain and sealer Cardova brown. I am repainting a 980sq ft deck in Western North Carolina that was already done in a solid stain. It said a 10 years on decks and 25 years on fences and siding. I Already pressure wash the deck how long can I expect the stain to really last.
Should I also use this stain on the siding lattice and concrete We just purchased this house a few months ago and any help would be greatly appreciated
Rayna G.
Rayna G.
I use oil based stain and have to re apply every 6 months
Emerson Lee Noddin
Emerson Lee Noddin
Read your review of both stain types/ Which one is better or do they perform identically? What do pros recommend in general and what for cold climates like Maine?
S. Carpenter
S. Carpenter
If one power washes the deck, can one use oil stain over an old solid water-based stain?
John Martin
John Martin
can a oil deck stain be considered water clean up and still be an oil product? Specifically PPG Timeless penetrating oil deck stain.
Mar
Mar
What is the VOC level in TWP?
Mar
Mar
what is the VOC level in TWP series 100?
Joey
Joey
What is better ail or water to protect agains winter and snow in Canada
katharina Ochoa
katharina Ochoa
I have a cider deck that is approx 1 year old. Last year we stained it with a Behr oil based product, but it has completely worn off at this point. What would be your recommendation?
Doris
Doris
I have a 17 year old redwood deck. I used Sikkens Cetol SRD previously for four two-year applications. I have not re-stained in 5 years so have sanded to raw wood again. If I use a water-based stain, would clear semi-transparent stain bring out the natural color of the red wood?
I shovel snow off the deck in the winter. Will it scrape off the finish? I thought using a solid stain would not hold up in Wyoming winters?
What is your recommendation for brand of stain to use?
Doris
Doris
If some of the wood looks too dry, then do I need to consider an oil base stain or will water base stain give just as much protection for this older deck?
Dana
Dana
What type of stain would you recommend for a one year old pressure treated green deck? It has faded to a natural looking colour that I really like, So looking to keep the nature wood look… oil or water based?
Dana
Dana
So tint of colour to the stain then? Also would you recommend oil or water based? This is a cottage deck…last time I used water based stain (with colour) on my home deck it started peeling a few months later, first time I’d ever had this problem. So want to avoid any peeling if possible.
Joe Rauer-Reis
Joe Rauer-Reis
Thanks for your help. Informative site.
Joe Rauer-Reis
Joe Rauer-Reis
This is not a deck stain question but a cedar siding question. I have a 25 year old house with what looks like to me a tinted blueish grey semi translucent stain on it. I figure oil based since it could be 25 years old. Wanting to use an oil product that is tintable in a light grey color as I don’t like the chipping effect of paint or water based stains. A semi solid would probably be better as we will be replacing some of the cracked boards and need them to match old boards. We are in Canada. Any suggestions on the best tintable oil products.
Kevin Grenon
Kevin Grenon
Benjamin Moore offers oil based semi solid (Arborcoat).
Bill Renz
Bill Renz
Correction to my previous question :
**Is my deck properly sealed**
Bill Renz
Bill Renz
I used a PPG oil based stain (uv, water and mildew protection) on my Doug fir deck a couple months ago. The wood had at least a month drying before I applied stain. I followed the directions, applying one thin coat. The deck looks nice but water doesn’t bead-up, just forming a sheen on the wood. Is my deck probably sealed?
Cherie
Cherie
There are advantages and disadvantages to both depending on many factors. This article seems to imply they’re both great without indicating circumstances where one is more advantageous over other. Fresh pine deck, oil or water? Why?
Amanda
Amanda
We applied Preserva Wood oil based to an very old untreated deck, and it turned the wood black! Why,and what can I do to fix this?
Karen
Karen
Cedar deck
3 years old
First application : THompsons(?) semi-transparent, water base
Next year application: Olympic Maximum, semi-transparent, oil
? Can I use the Olympic again as maintenance over existing stain, or do I need to strip entire deck.?
101
