Best Deck Stains for 2026: Tested on Real Decks (No Peeling or Fading) 4.8/5 (390)
Hi, I’m Scott Paul, a licensed exterior restoration contractor with over 30 years of experience and 10,000+ deck restorations. These deck stain reviews and ratings are based on my own hands-on field testing, not manufacturer claims. See my full credentials and testing stats here.
What Is the Best Deck Stain 2026?
Quick Answer: What Is the Best Deck Stain?
  • Penetrating semi-transparent stains like TWP 100 Series and Restore-A-Deck are the best overall picks for durability and easy maintenance.
  • Oil-based stains penetrate deeper for easier recoating, while water-based stains offer better UV color retention and faster drying.
  • Avoid film-forming stains on older or weathered decks, as they sit on top of wood and are prone to peeling and premature failure.
  • Proper deck prep, including cleaning and brightening, is the number one factor in preventing stain failure and ensuring long-term performance.
  • VOC regulations vary by state, so confirm your stain is compliant before buying.
Top Deck Stain Picks Summary
Expert Tip: The best deck stain is not just about durability. It is about how easy it is to maintain over time.
Best Deck Stain Comparison Table
TWP 100 Semi-Transparent (Oil) 2 to 3 Years Easy Proven performance, deep penetration Most decks
TWP 1500 Semi-Transparent (Oil, Low VOC) 2 to 3 Years Easy Better VOC compliance, similar performance to TWP 100 VOC-restricted states
Armstrong Clark Wood Stain Semi-Transparent (Oil) 2 to 3 Years Easy Excellent oil penetration plus conditioning oils Dry, aging wood
Restore-A-Deck Wood Stain Semi-Transparent (Water-Based) 2 to 3 Years Very Easy Simple prep system plus easy recoat DIY homeowners
CUTEK Extreme Penetrating Oil 2 Years Very Easy Deepest penetration, no film buildup All wood types
Defy Extreme Semi-Transparent (Water-Based) 1 to 3 Years Moderate Strong UV resistance with zinc nano-particles Sunny or high UV areas
Wood Stain Versus Deck Stain: What Is the Difference?
Wood stain is the broad category, and deck stain is the version of it built for the hardest job in that category. Both add pigment and protection to bare wood, but they are formulated for very different surfaces and very different kinds of wear.
Interior wood stain is made for furniture, floors, trim, and cabinets. It colors the wood, then gets sealed with a topcoat such as polyurethane, varnish, or lacquer. That film works indoors because the wood never gets soaked, never freezes, and never sits in direct sun. Outdoors, the same film cracks and peels as the boards expand and contract through the seasons.
Deck stain has to handle standing water, UV, freeze and thaw cycles, and foot traffic all at once. Every product I recommend on this page is a penetrating exterior wood stain, meaning it soaks into the wood grain instead of forming a film on top. That is why it wears away evenly and can be cleaned and recoated rather than stripped or sanded.
Exterior wood stain also covers fences, siding, log homes, cedar shakes, pergolas, and outdoor furniture. Most of the stains reviewed below work on all of those, and they last noticeably longer on vertical surfaces than on deck flooring, because a fence or a railing sheds water and takes less overhead sun. If you are staining a fence rather than a deck, see my guide on the best fence stain.
The rule I follow is simple. Anything that lives indoors gets an interior wood stain plus a topcoat. Anything exposed to weather gets a penetrating exterior deck stain. Using an interior product outdoors is one of the fastest ways to end up with a peeling deck within a season.
I have over 30 years of hands-on experience restoring and staining wood decks since 1993. I have tested hundreds of deck stains on real-world projects, evaluating durability, UV resistance, ease of application, and long-term maintenance. See here for more info about me.
However, in the last 5 to 10 years, I have noticed a shift in the industry. Not all semi-transparent stains are as penetrating as they used to be. Many manufacturers have moved away from creating truly penetrating stains due to changes in VOC laws and a focus on profitability. The result? Some stains sit on top of the wood and dry, rather than soaking in, which can cause peeling and premature failure. They end up looking more like paint than a stain, which, in my experience, does not hold up as well.
Believe it or not, deck stains actually performed better 10 to 20 years ago when it came to wear and peeling. But here is the silver lining: in the past 5 to 10 years, I have seen major advancements in UV protection. Nanoparticles of zinc oxide and improved trans-oxides have taken UV resistance to a whole new level, keeping your deck looking better for longer.
  • Best for UV and Mildew Resistance: Defy Extreme Wood Stain — A water-based formula enhanced with zinc nano-particles for superior UV protection and mildew resistance.
Top Oil-
Based Stain
Top Water-Based Stain
Top Solid Color Stain
Easiest to Apply Stain
*Free Shipping Included
How I Rate Deck Stains
  • Ease of application
  • Wear and tear after 2 years
  • Color shifting or darkening in color (5 Star = No Darkening)
  • Preventing mold, mildew, and algae at 2-year mark
Oil-Based vs Water-Based Deck Stains
  • Oil-Based:
    • Deep penetration
    • Easier maintenance
  • Water-Based:
    • Better UV color retention
    • Faster drying
  1. TWP 100 Series
  2. Armstrong Clark Wood Stain
  3. TWP 1500 Series
  4. TWP Pro-Series Semi-Solid
  5. CUTEK Extreme Penetrating Wood Oil — New product alert, honorable mention, deep penetrating oil finish
  3. Defy Extreme Stain
  • Durability: 2 to 3 Years
Scott’s Pro Tip: My most used deck stain in the past 30 years! I have used the TWP 100 Series on many 1000s of decks.
TWP 100 Series penetrates well into the wood, fades lightly in color, and holds up to wear and tear. I like that when it is time to redo the wood in 2 to 3 years, the TWP can be cleaned and re-coated or easily removed. This makes the reapplication process much easier. TWP 100 Series is only allowed in 35 States and cannot be used in Canada.
My Test Deck Stats
Deck Square Footage: 2100
[woo_product_slider id=”30708″]
Scott’s Pro Tip: My favorite deck stain to save time and money. I prep and stain on the same day.
I like that Restore-A-Deck Wood Stain can be applied to dry or damp wood. Applying it to damp wood allows me to prep and stain on the same day, saving a tremendous amount of time. Restore-A-Deck Wood Stain is an advanced, water-based, semi-transparent stain formulation designed to penetrate deep into wood pores for maximum protection and longevity. It protects the wood from harmful UV rays and damage caused by water penetration.
My Test Deck Stats
UV Exposure: 50% Full Sun
[woo_product_slider id=”30709″]
Scott’s Pro Tip: Regarding ease of application and performance, the Armstrong Clark stain is one of my top stains. I love their semi-solid colors and performance.
The Armstrong Clark Wood stain has been a solid performer for my team since I started reviewing and using it about 10 years ago. I really like how it penetrates deep into the wood grain and applies easily. Reapplication is simple after prepping with a good deck cleaner. One callout is to make sure you do not overapply. You want the stain to soak thoroughly into the wood. Compliant for all US states and Canada.
My Test Deck Stats
Deck Square Footage: 600
[woo_product_slider id=”30704″]
TWP Semi-Solid Stain
  • Durability: 3 Years
  • Maintenance: Moderate
What I like best about the TWP Semi-Solid Stain is that it is simple to apply, prep, and reapply when the time comes, and it holds color very well despite UV exposure. I have been using the TWP Semi-Solid colors for the last 4 years and have had nothing but positive results. Maximum UV protection and a much larger color palette are the top reasons I will offer the TWP Semi-Solid to all of my customers. The Low-VOC version is allowed in all US States and Canada.
My Test Deck Stats
When Tested: August 2023
Deck Square Footage: 800
UV Exposure: Deck in full sun
How Many Years Tested: Initial test, brand new product
[woo_product_slider id=”30706″]
TWP 1500 Series Rating
  • Maintenance: Easy
The TWP 1500 Series is one of the best wood and decking stains and is one of my top choices. As a contractor, I really like stains that penetrate deep into the wood and can be reapplied without sanding. TWP 1500 fits this and more by adding excellent UV and mold protection. Maintaining TWP every 2 to 3 years is easy. TWP 1500 is compliant for all US states but not Canada.
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
[woo_product_slider id=”30703″]
TWP Natural Effect hardwood stain review
  • Durability: 1.5 to 2.5 Years
  • Maintenance: Easy
  • Best For: Maintaining a natural, bare wood appearance
Scott’s Pro Tip: My new favorite IPE and hardwood deck stain is the first stain I have ever seen last more than one year on exotic hardwoods.
TWP Natural Effect Impregnators are tinted with iron oxide pigments, contain UV absorbers, and are extremely resistant to solar radiation. Their function is to preserve the wood from degradation due to UV light, microorganisms, and more. They prevent changes in wood color and promote adhesion of the Natural Effect Finish. TWP Natural Effect is compliant for all US states and Canada. This is a new product for my team, but I have tested it since 2021. So far, so good with my test deck. Note that TWP Natural Effect is a two-step system and requires a separate top coat, so visit its dedicated page before ordering.
My Test Deck Stats
Stain Color Used: Chestnut
[woo_product_slider id=”30705″]
Defy Extreme Stain Review
  • Durability: 2 Years
Scott’s Pro Tip: The Defy Extreme is one of my top choices when using a water-based semi-transparent wood stain.
I have found the Defy Extreme Wood Stain to be one of the best-performing water-based deck stains on the market. The zinc oxide nano-particles do double duty in preventing UV fading and preventing mold or mildew growth. Defy Extreme penetrates into the wood grain extremely well for a water-based stain, resulting in a non-filming coating that is not prone to peeling or wear from traffic. I use the Defy Extreme on about 30 to 50 deck restorations every year in the Midwest, and it is one of my go-to brands. It is compliant for all US states and Canada.
My Test Deck Stats
Stain Color Used: Cedartone
[woo_product_slider id=”30712″]
Ready Seal Wood Stain Review
  • Durability: 1 to 2 Years
Ready Seal Wood Stain contains the non-drying oil paraffin, which dives into the wood fibers and does not cure on the surface. There are many positives to paraffin stains, such as a user-friendly application and an even finish. The negatives can be poorer UV resistance and coverage rates with an oily finish that can stay on top of the surface. Ready Seal Wood and Deck Stain is a great choice for an easy-to-apply, even finish. However, I have found it necessary to reapply every 12 to 18 months due to color loss.
My Test Deck Stats
New Product Alert: Honorable Mention, Deep Penetrating Oil Finish
Cutek Extreme Oil
CUTEK Extreme Penetrating Wood Oil Review
  • Type: Penetrating Oil
  • Best For: Exotic hardwoods (Ipe, teak) and all wood types
Scott’s Pro Tips: Although CUTEK Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
Note on my CUTEK Extreme Review: I have not yet been able to fully evaluate long-term UV resistance over my standard two-year testing period, as this application was completed in 2025. However, based on my experience so far, I have strong confidence in the product. It checks many of the key criteria I look for in a quality deck stain: deep penetration with added UV protection, along with the ability to reapply easily as it weathers.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
See My Review Article Here: CUTEK Extreme Penetrating Wood Oil Review
Purchase Direct: Purchase CUTEK Extreme Here
[woo_product_slider id=”37163″]
Semi-Solid Deck Stain Review
Best New Semi-Solid Stain for 2026: Available in 30 Custom Colors, the TWP® Semi-Solid Pro-Series is my favorite semi-solid stain. It will keep your wood beautiful, fresh, and looking new longer! The ease of application and maintenance will allow you to enjoy your investment for years to come. TWP® Semi-Solid Pro-Series provides a broad spectrum of weather protection, is water repellent, and aids in color retention. TWP® Semi-Solid Pro-Series resists water absorption that causes warping, cracking, and splitting, and prevents freeze damage in colder climates.
TWP 100 Deck Stain Ratings
TWP 100 Pro Series semi-transparent stain penetrates well into the wood, fades lightly in color, and holds up to wear and tear. I like that when it is time to redo the wood in 2 to 3 years, the TWP outdoor stain can be cleaned and re-applied or removed with ease. This makes the reapplication process much easier. TWP 100 Pro Series patio stain is only allowed in 35 states and cannot be used in Canada.
Restore-A-Deck semi-transparent deck stain can be applied to dry or damp wood. Applying this stain to damp wood allows me to prep and stain on the same day, saving you a tremendous amount of time. This Restore-A-Deck wood stain is an advanced, water-based, semi-transparent stain formulation designed to penetrate deep into wood pores for maximum protection and longevity. It is compliant with regulations in all U.S. states and Canada.
Restore-A-Deck solid-color stain is my go-to solid-color or opaque deck stain for 2026 because of its ease of use, five pre-mixed solid colors (the only solid stain on the market that comes pre-mixed), and the ability to prep and stain on the same day, which adds extra convenience. It uses the latest advances in wood stain technology to seal and protect the wood by penetrating deep into the grain, shielding your deck from UV and water damage which is responsible for the growth of mold and mildew. It is also compliant with regulations in all U.S. states and Canada.
Pro Tip: Restore-A-Deck offers eco-friendly deck stain choices for sustainable living.
Armstrong-Clark Wood Stain has consistently been a well-performing deck stain product. I really like how it penetrates deep into the wood grain and applies easily. Reapplication is simple, with a good deck cleaner for the prep. It is compliant with regulations in all U.S. states and Canada.
The TWP brand of stains is one of my most commonly used wood stain brands, as I have applied it to more than 10,000 decks over the past 30+ years as a wood restoration contractor. What I like best about the TWP semi-solid stain is that it is easy to apply, it is easy to prep and reapply when the time comes, and it holds color very well, even under UV light. TWP semi-solid stain is only allowed in 35 states and cannot be used in Canada.
TWP 1500 Series exterior deck stain is one of my top choices for the best outdoor wood stain because it protects the wood from rot and severe weather. TWP 1500 Series stain is the only deck stain on the market that is registered as a wood preservative with the EPA. As a contractor, I really like stains that penetrate deep into the wood and can be reapplied without sanding. TWP 1500 Series patio stain fits this and more by adding excellent UV and mold protection. Maintaining TWP stain every 2 to 3 years is easy. TWP 1500 Series stain is compliant for all U.S. states but not Canada.
Defy Extreme Semi-Transparent Wood Stain penetrates into the wood grain extremely well for a water-based stain, resulting in a non-filming coating that is not prone to peeling or wear from traffic. I use the Defy Extreme on about 30 to 50 deck restorations every year in the Midwest, and it is one of the best outdoor wood stain options on the market for preventing mildew. Compliant for all US states and Canada.
Homeowners are always looking for an alternative to a deck replacement. When wood is neglected, it can be expensive to have it restored or replaced. If you are looking for a deck resurfacing stain, remember that most users have had an unpleasant experience with big box store products. Reviews and user experiences with most of these products have been overwhelmingly negative. However, comments about Gulf Synthetics Deck Revive have been favorable.
Best Deck Stain for Old Wood
How to Choose the Right Deck Stain
  1. Is There a Best Deck Stain?
  2. Understanding Deck Stain Types
  3. Choosing Your Deck Stain Type
  4. Avoiding Common Deck Stain Mistakes
  5. Getting the Most out of Your Deck Stain
  6. Read My Deck Stain Reviews
  7. Deck Stain FAQ
  8. Ask Me for Help!
My top-rated wood and deck stain, TWP 100 Pro Series, cannot be used in some states or in Canada due to its higher VOC content. It is essential to take these factors into account. Additionally, think about the look you want. Do you prefer a stain that enhances the wood grain or one that hides the grain for a more opaque, paint-like finish?
Deck Stain Types Explained
Pro Tip: See my Deck Stain Types guide for more in-depth differences on deck stains.
Transparent Stains
As the name suggests, transparent stains are clear or very lightly tinted stains that help seal and protect wooden decks while still allowing the wood grain to show through. See below for pros and cons of the best transparent deck stain options for stunning results.
Transparent deck stain on a wood deck
Transparent Deck Stain
Semi-Transparent Stains
Like transparent stains, semi-transparent stains seal and protect your wooden deck from damage. However, these stains typically feature slightly richer colors that can provide more coverage than a transparent stain. You will still see the wood grain of your deck boards, but a semi-transparent stain cannot hide some flawed or damaged boards.
  • Cons of semi-transparent deck stains: These stains are typically better suited to well-maintained decks under ten years old. They are also not the best choice for painted surfaces, as they will not cover imperfections.
Semi-Transparent Deck Stain
Solid (opaque) Stains
Solid Color Deck Stains
2. Long-Term Durability
I believe penetrating, semi-transparent stains provide the perfect balance of customizable color, ease of reapplication, and long-term durability. Transparent stains typically require more frequent applications, while solid stains may last up to 2 to 3 years on a deck and 4 to 6 years on vertical wood such as railings with appropriate care.
3. Deck Condition
You can generally use any stain on a newer deck that is still in good condition. However, you may consider a semi-transparent or solid stain for an older, weathered deck.
4. Climate Concerns
What to Avoid When Choosing a Deck Stain
  • Over-applying stain
  • Skipping prep
  • Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly. See my Deck Cleaning Guide for best results.
  • Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that is not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time. See my How to Stain a Deck tips for the best results.
  • Take the time to prep your deck before applying stain to ensure maximum durability. Start by sweeping off dust, dirt, and grime, then use a scrub brush with a hose or a pressure washer on a low setting. Always use the appropriate deck cleaner or stain stripper. Not sure how to prep your deck? See my article on deck prepping and I will gladly help and offer advice: Strip, Clean, or Sand Your Deck?
  • Apply your stain on a dry, partly sunny day with mild weather. Want to stain your deck the same day as prep? If using the Restore-A-Deck stains, you can apply them to damp wood after prepping.
  • Filming deck stains that dry on top of the wood can be harder to remove or reapply, as they are more prone to peeling, wear, and flaking.
  • Clear sealers without any pigment or color will not prevent UV graying. Lighter-pigmented stains that are transparent, semi-transparent, or semi-solid will have less UV protection than darker-pigmented stains in the same transparency. More color or tint means better UV protection.
  • Deck stain types include oil-based or water-based, filming or penetrating, and either transparent, semi-transparent, semi-solid, or solid (opaque). Deck resurfacing products are also an option.
  • When switching brands of deck stain, I have found it is always best to remove the old coating first. Do this by using a deck stain stripper or sanding.
  • Always apply a wood brightener after prepping with a stain stripper or wood deck cleaner to neutralize the pH.
Best Deck Stain FAQs
Quick Tip: If you want the easiest long-term maintenance, stick with penetrating semi-transparent stains. They consistently perform best across most deck types.
Choosing the Right Deck Stain
Semi-transparent penetrating stains offer the best balance for most decks. They carry enough pigment to block UV graying while still showing the wood grain, and because they soak into the wood instead of forming a film, they wear evenly rather than peeling. That matters most at the 2 to 3 year mark, when a penetrating stain can be cleaned and recoated while a film-forming product has to be stripped or sanded first.
Penetrating semi-solid stains such as TWP Semi-Solid and Armstrong Clark Semi-Solid are best for older wood and decks that are dried out. Older boards are porous and absorb more product, and the heavier pigment load in a semi-solid gives better UV protection while hiding some of the color variation that comes with age. Armstrong Clark also contains nondrying conditioning oils that soak into the wood fiber where the natural oils used to be, which helps rejuvenate dried-out decking.
Both can perform well. Oil-based stains penetrate deeper and are easier to maintain, while water-based stains offer better UV color retention and easier cleanup. My highest rated oil-based stain is TWP 100 Series and my highest rated water-based stain is Restore-A-Deck, and the two score within a fraction of a point of each other. The bigger factors are your state’s VOC limits, which restrict some oil-based products, and whether you want to prep and stain the same day, which only a damp wood product like Restore-A-Deck allows.
Higher-quality stains usually last longer and require less maintenance, so the cost per year is often lower even when the cost per gallon is higher. A premium penetrating stain that lasts 3 years and recoats with a simple cleaning beats a cheap film-forming product that peels in 18 months and needs stripping and sanding before the next coat. Labor is the expensive part of a deck project, not the stain, so paying more up front to avoid a full strip later is usually the better value.
TWP, Restore-A-Deck, and Armstrong Clark are top choices for decks in full sun, and darker tints tend to perform better because pigment is what blocks UV rays. A clear or very light natural tone will start graying within months on a south facing deck, while a medium to dark cedar, brown, or chestnut tone holds color far longer. If your deck gets six or more hours of direct sun a day, step up one level in opacity, from transparent to semi-transparent or from semi-transparent to semi-solid.
Deck Stain Types and Performance
What is a deck stain?
Deck stain is a protective finish for wood that enhances appearance and protects against moisture and UV damage. It comes in transparent, semi-transparent, semi-solid, and solid options, with each step up adding more pigment, more UV protection, and less visible wood grain. The other key distinction is penetrating versus film-forming: a penetrating stain soaks into the wood grain and wears away evenly, while a film-forming product sits on the surface and eventually cracks or peels.
Penetrating semi-transparent and semi-solid stains perform best for most decks due to durability and ease of maintenance. In my testing, the top scorers are TWP 100 Series, Restore-A-Deck, Armstrong Clark, TWP Semi-Solid, and TWP 1500 Series, all of which rated 8.5 or higher on my 1 to 10 scale after 2 year field tests. What they share is deep penetration and the ability to be cleaned and recoated without stripping.
Stains must contain pigment to protect against UV, so a true clear sealer will not stop graying no matter what the label claims. Semi-transparent stains provide good protection while still showing wood grain, and semi-solid stains provide more because they carry a heavier pigment load. Within any transparency level, the darker color will hold out against graying longer than the lighter one. Products with zinc oxide nano-particles or improved trans-oxide pigments, such as Defy Extreme, add another layer of UV resistance.
Penetrating stains can be cleaned and recoated without heavy prep, unlike film-forming stains that may peel. With a penetrating product like TWP, Armstrong Clark, or Restore-A-Deck, maintenance at the 2 to 3 year mark means a wood cleaner, a brightener to neutralize it and open the grain, and a fresh coat. With a film-forming stain or paint, you are looking at a stain stripper and often sanding before any new product can go down, which is where most of the labor cost lives.
Durability and Maintenance
Solid stains such as the Restore-A-Deck Solid Stain last longer in terms of color retention, but penetrating stains are easier to maintain over time. No exterior deck stain will last five or more years on deck flooring. A good-quality stain gives you two or maybe three years on the horizontal surfaces and typically twice as long on railings and other vertical wood. I would rather have a stain that fades evenly and recoats with a cleaning than one that holds color a little longer and then has to be stripped.
Penetrating semi-transparent stains are the easiest to maintain since they do not peel. When it is time to recoat, you clean the deck, apply a brightener, and put down a fresh coat, with no stripping or sanding. Restore-A-Deck is the easiest of all in my experience, because it can be applied to damp wood, which means prep and staining can happen the same day instead of waiting 2 to 3 days for the deck to dry.
Typically every 2 to 3 years, depending on exposure and the product used. Vertical surfaces like railings and fence boards hold up about twice as long as the deck floor, so you may recoat the flooring twice for every one time you do the rails. The best approach is to inspect the deck each spring and recoat when the color has faded rather than waiting for the stain to fail completely, because partial wear is far easier to prep than bare, gray wood.
Appearance and Color
Popular colors include cedar, brown, honey, and redwood tones, and cedar has been the top seller for decades because it reads as a warm, traditional wood tone on almost any species. Remember that the same color looks different on pressure treated pine, cedar, and hardwood, and it looks different again depending on how weathered the boards are. Order a sample and test it on a spare board or an out of sight section before committing to gallons. See my guide to the most popular deck stain colors for photos.
Application and Usage
What is the best way to apply a deck stain?
Stain pads and brushes provide the most even application. Sprayers can be used but should always be back-brushed, working right behind the sprayer so the stain is pushed into the grain instead of sitting on the surface. Apply thin coats rather than heavy ones, stain one full board from end to end before moving to the next to avoid lap marks, and wipe off anything that has not absorbed within the window the manufacturer specifies.
Yes. Deck stains work well on siding, fences, and log homes, and they often last longer on vertical surfaces than on deck flooring. A fence or a wall of siding sheds water, takes less direct overhead sun, and never sees foot traffic, so the same product that gives you 2 to 3 years on a deck floor will commonly give 4 to 6 years on vertical wood. Prep is still the deciding factor, so clean and brighten before you stain.
New Deck Questions
How long you wait to stain a new deck depends on how the lumber was milled and dried:
  • Smooth wood: wait about 3 months
  • Rough wood: can be stained once clean and dry
  • Kiln-dried wood: wait 1 to 2 months
The reason is absorption. Milling closes the wood pores and leaves mill glaze behind, so a stain applied too early sits on the surface and dries blotchy. Test the boards by sprinkling water on them, and stain once the water soaks in within a few minutes rather than beading up.
Deck Stain vs Other Products
What is the difference between deck stain and deck paint?
Deck stain penetrates the wood and looks more natural, while deck paint sits on the surface and creates an opaque film. That film is the problem outdoors: as the boards expand and contract through wet and dry cycles, the paint cracks, peels, and traps moisture underneath, which accelerates rot. Paint also hides the grain completely. On bare wood I recommend stain every time, and paint only makes sense on a deck or fence that is already painted and sound.
  4. Mold, mildew, and algae will leave the wood unsightly or dirty and can cause rotting.
  7. The wood may not have been prepped properly prior to application. Bad prep is the number one reason stains prematurely fail.
  2. How much sun or shade does your deck get?
  5. Why or how did the previous stain fail?
  1. Deck Location: Michigan
  3. Wood Type: Cedar
  4. Mold/Mildew? No
Michigan currently has a VOC limit of 250, down from 550 as of 2023, so not all exterior deck stains are available. You may have different options if you live in Canada, on the East Coast, or in California. I would suggest a penetrating semi-transparent or semi-solid stain that does well with UV protection and fades evenly over time, making future reapplication easier. Based on these questions and answers, I would suggest one of these stains:
How do you choose the best deck stain for your home? I am here to help you find the best wood deck stain for your situation. Just post a comment below with answers to these questions.
  • How much sun or shade does your deck get?
  • Why or how did the previous stain fail?
If you can, please add a picture or two of your deck’s current condition. I will do my best to suggest the best wood deck sealer and stain for your needs.
NOTE: Make sure to post comments below for personalized help.
5 349
4 28
3 4
2 2
1 5
0 2
30.9K Comments
Jennifer
Jennifer
8 days ago
For New England weather : What’s the best type of stain to use on mahogany wood for an outdoor porch (handrails, deck floorbaords, stair treads). I’m concerned about durability/longevity, but also ease of ongoing maintenance. I’ve heard 2 lines of thought – (1) transparent oil based stain because mahogany is dense wood & the oil will penetrate better compared to solid stain – but needs near annual re-application, (2) solid stain offers more protection for the wood, however, I was told by one store not to use solid stain on mahogany because it will only peel off due to the denseness of the wood. Also, has anyone used Benjamin Moore outdoor stains before?
Mavis
Mavis
12 days ago
I had a new cedar deck installed last year. I waited a few months for the wood to dry . It is in a sunny area. I live in South Bend, IN. Then I used Australian Quetec Max which is a sealer. With cedar coloration.
It started peeling the 1st summer.
I will strip it, then what is a good stain/ sealer . Don’t want to have to do this every year. We get alot of snow here.
17903552624064098064775461870055
Letty
Letty
15 days ago
Hello, looking at staining our new deck made with pressure treated pine lumber. It was put down in late June. The deck faces the northwest in southern Michigan and is partially covered by a gazebo. I’m not sure what percentage moisture it is at now, though I am worried about getting it stained prior to the weather becoming too cold/ or even snow. Which stain should I use and what are the risks of putting it on prior to being at a low enough moisture? I’m worried a winter without stain would be an even bigger problem. Thanks!
Letty
Letty
14 days ago
Thank you. If I use RAD cleaner and brightener, how long do I have before I have to stain the deck? Can I wait up to 6 or 7 days or do I have to do it within a day or two?
im25624
im25624
29 days ago
Do you know anything about this product and how it might compare to the TWP 100 for a treated pine deck that is about 6 months old and never had anything put on it?
Seal-Once Nano+Poly Wood Sealer and Waterproofer, Clear, 1 GallonWith Polyurethane, Water-based, Low-VOC, Waterproofer & Stain, For Decks, Fences & Log Homes
Nat
Nat
1 month ago
TWP 100 series is it the older type used in the 70-80th where clean up required either varsol or gasoline?
Juanita
Juanita
1 month ago
What type to use in Oklahoma weather
1 month ago
Our deck is located in western Washington state.
It does not get a ton of sunlight: in addition to being in the PNW, it is east-facing and there are some huge trees towards the east that block the early morning sun. In the height of summer it gets sun from maybe 8 am to 1 PM. Less over the winter.
The deck itself is Trex, but the railings and posts are cedar.
The previous Penofin stain we put on turned gray (or let the wood turn grey) in a year or less; and mold, moss, and lichen grew in it over time. That said, the deck is 15 years old and we’ve only re-stained it once, and that was more than 6 years ago at this point.
1 month ago
Thanks so much for your quick response.
Why are you recommending that vs other options such as TWP? It is because the Restore-a-deck has better mold and UV protection?
1 month ago
I’ve already sanded and brightened the cedar and it’s essentially bare. There are only a few inaccessible corners where some old Penofin remains. I’m in western Washington and TWP 100 is available locally, while RAD would take about a week to arrive. Would you still choose RAD over TWP 100 for my situation?
Thanks again
Will
Will
1 month ago
Hi, I have a very weathered 20 year old composite deck, and am looking for the right product to refinish it with, and also wish to change the color, – am going back and forth between stain and commercial floor paint (like Benjamin Moore “Command” or Sherwin Williams “Forte”) – it would be helpful to hear from someone who has experience with this,
Thanks, Will.
Lonnie Davis
Lonnie Davis
2 months ago
We are still having issues with our new cedar deck, from a distance it looks fine but you walk up to it and it is blotchy and looks like an old worn deck as you can see in the photos attached. Here is the process we did to get rid of the white halo spots we discussed earlier before applying the stain:
We sanded the whole deck to get the white spots off with 120 grit orbital sander, then lightly sprayed with water and wiped off to remove the sawdust. Let that dry for a day and a half. Then went back over with 220 grit orbital sander to remove any fuzzies of fibers and used a leaf blower to remove any sawdust residue. Then next day we applied the stain by hand using brushes. It looked nice wet, but once it dried it began to get the blotchy worn look. We stained the deck on Saturday and as of today, Monday it still looks worn and blotchy. When the sun shines on it you can really see the blotchiness even more.
What can we do to correct this? I know we are not suppose to put a second coat on til next year and even not sure if a second coat will help correct this. Do we need to strip this off and start over? Any help would be deeply appreciated.
IMG_0794
IMG_0793
Lon Davis
Lon Davis
2 months ago
Hi Scott. Do we have to clean and brighten all over again after stripping it?
Lon
Lon
2 months ago
Thank you Scott,
To clarify – no sanding needed just 1. Strip 2. Brighten 3. Stain
  • if for any reason the stripping doesn’t take all the stain off just reapply the stripper again until all the previous stain is gone. Then brighten and stain
  • if for some reason the white halos around the knots appear again after brightener or some of the previous stain does not all come off, what should we do so that we don’t have same scenario.
we are thinking this time to apply the stain with a pad rather than hand brushed with other person following behind to wipe up any pooling. What are your thoughts on that?
Lon
Lon
2 months ago
Ok, thank you Scott
Terri
Terri
2 months ago
We live in southern Idaho which is dry in the summer but can have snow and rain in the winter. We built our deck out of redwood last year and put linseed oil on it. What oil based semi transparent stain do you recommend and how to clean it? Will putting the linseed oil on it be a problem?
Meredith
Meredith
2 months ago
Hello! We are getting a new porch installed and after it’s had time to dry out (pressure treated pine), I am planning on staining the porch myself. From your recommendation we’re looking at TWP. Thank you! I was curious, based on my NE Ohio location is that our smartest option? Also which type would be our best bet: 100, 1500, or the semi-solid?
The porch will see lots of snow, ice and scorching summers. Thank you for your lists and great videos on YouTube! It’s been so informative.
Meredith
Meredith
2 months ago
Thank you thank you!
Mike Gray
Mike Gray
2 months ago
I am 3/4 the way from finishing my deck with stairs. I had not thought about a stain as I was buying pressure treated pine. That I figured would out last me. I was reading in a wood craft magazine about this Australian Timber oil. My question is Can I add this Timber Oil on top of these boards.I had never heard of this brand and I thought If I could it on with a sprayer That would give a extra layer of protection and be faster to apply.
Les
Les
2 months ago
I have some green high-end Polywood chairs that were gifted to me 20 years ago. They were used so I believe they are approaching 25 years old.
I live at altitude where there is bright sun and fairly dry weather (not dessert).
The furniture is very faded. After a friend stained an older Trex type deck, I am trying to find out if this furniture can be stained without looking worse in a year or two.
Do you have any thoughts or experience?
Margie
Margie
2 months ago
Are your answers going to be sent to our email address?
Theresa
Theresa
3 months ago
Question about Armstrong Clark. I had cedar deck prepped by removing existing stain (water based Benjamin Moore Arbor Coat) that was flaking off everywhere. Method to remove was sanding. When stain applied it looks mottled over most of the deck. The color used was black walnut and it dried really light like a natural cedar. Temp about 75 to 80 degrees in full sun. Can you offer any suggestion as to why this happened and if there’s a fix? Thanks
Theresa
Theresa
3 months ago
this was done by a contractor and not sure of the grit. They didn’t appear to have experience with staining. I’ve done a lot of it but just had knee replacement and not able to do it myself. Thi was done yesterday. Today it’s raining. Can I put second coat on after it dries or should I just wait until spring. I’m really disappointed. I ordered a sample of stain and sanded a small section myself and it worked fine. I used 120 grit I believe for the test spot. I know you shouldn’t use any grit above that. The deck is repelling the rain so that’s a plus. Just doesn’t look as I had hoped
IMG_5685
Theresa
Theresa
3 months ago
Do I have to wait until boards are completely dry ie at least 24 to 48 hours?
thanks!
Theresa
Theresa
3 months ago
Not sure about grit. Here’s a picture
IMG_5685
George
George
3 months ago
Hello Scott I moved into a home w/ 25 yr old deck. I believe it’s Cedar but not 100% sure. It wasn’t well cared for. Not going to replace it yet. I’d like to try to salvaged it for the time being. I live in PA and the deck lots of sun. I’ve read comments that Deck restorer or Deck correct products don’t work well. I don’t care about showing the natural characteristic of the wood so it can be a solid color. I just want it look better than it does. Attached pics of it after it was power washed. Can you recommend the best product/stain to use for weathered deck? Appreciate any help..thanks so much.
IMG_Deck6637
Becky
Becky
4 months ago
I live in Ohio. What would be the best solid stain to redo my two year old deck it doesn’t hold stain well
Paula
Paula
4 months ago
I have a 46 year old deck that I treat with an oil stain each year and it turns black by the next summer. I just cleaned it as best as I could and I want to find a stain that won’t turn black. I think the Armstrong Clark sounds best to try for the age of my deck. Please advise
4 months ago
For a new treated lumber deck what is your opinion of products like TotalBoat Clear Penetrating Epoxy Wood Sealer?
29 days ago
Do you have any experience with this product and if so what is your opinion?
29 days ago
Why can’t I find the information or get logged in with this account? The only way I can get here is to follow this link.
26 days ago
I have a new treated pine deck that is between 5 and 6 months old. I think (based on the water test) it is ready to put something on it for the first time. The deck is in sun most of the day. What is your best recommendation for something that will be low maintenance and that I would not have to reapply very often. I am thinking something really dark but would like some advice.
25 days ago
Do you see much difference in the Restore-A-Deck and the TWP 1500 Series and Armstrong Clark other than the clean up? When I do the maintenance coat in a year or two will I have to clean and brighten the wood again? Can I switch from Restore-A-Deck to the oil based products on the maintenance coat if I am not satisfied with the results with the original coat?
23 days ago
What cleaning kit do I need for TWP 1504 stain? Are they both the same (RAD and Gemini)?
Teresa
Teresa
4 months ago
Most of the products that you recommend are not available for sale in my area (Minneapolis MN). TWP used to be offered at a local high end paint store but they no longer carry it and only the semi transparent version is available at Fleet Farm here. I have ordered samples from TWP for their semi solid version and also some from Armstrong. My deck gets full sun and I was thinking that a semi solid would be the best choice but I am concerned about peeling. Will the stains that have a higher pigmentation ie semi solid be more apt to peel due to full sun for most of the day? Also wondering what your thoughts are about PPG which is available here. BTW my deck us Cedar and has a LOT of knots in it which I was trying to cover with a semi solid stain
Thanks!!!
John Organ
John Organ
5 months ago
I installed some cedar 1×4 trim around my windows and doors on my house a couple of years ago. I did not put any coating of any kind on it so it is just raw. Some of it has lost some of it rich color and is faded or bleached out a little bit by the sun. I want to bring back that consistent natural Warm cedar color to it and then apply a protective clear coating. What products do you recommend?
Sue Scott
Sue Scott
5 months ago
Thank you for all this info… i need help in Buffalo NY area… I have a cedar outdoor shower built on a pressure treated deck this year I would like to stain with a semi transparent stain for the cedar without orange tones and showing the grain. I need a stain and sealer for my shower which is used late April-October on average. What is the best product to use that with last without reapplying every 2 years . I can drive to Pennsylvania to buy product if needed.
Also, when should I ? Stain and sealer the pressure treated wood. The deck and shower were completed September 2025
Thank You
The Bakers
The Bakers
5 months ago
Large 13 year old pressure treated pool deck in southern IL, full sun. We have days of upper 90s as well as snow/ice. Mold/mildew non-issue. We used Restore-A-Deck in 2020 and loved the look/color, but felt longevity wasn’t any better than cheaper stains. I used Ready Seal in ’23, but felt it faded quickly. This particular deck hasn’t had an oil base, and I am thinking this year of using Armstrong Clark semi-transparent with hopes of being able to clean and recoat as needed in a year or two. We’ve always used semi-transparent and have been scared of using a semi-solid for fear it will wear like paint with colored patches mingled with worn-off patches and not sure how to recoat with that issue so have stayed away. Maybe we should re-consider. What, in your opinion, would work best for us? All info greatly appreciated.
Larry
Larry
5 months ago
I have a 12×34 deck of pine I want an oil based stain where I can see the grain. I want a true light brown color. I can’t find it! It’s either too yellow or too orange. Do you have any suggestions
cliff
cliff
6 months ago
Live in SE Florida, putting a 6″x 24′ Cypress tongue and groove ceiling in my pergola. Above the cypress will be fiberglass insulation and a roof. I’m concerned about the humid weather in SE FL. Perhaps TWP 1500 semi-transparent, cedar or red cedar color. Since the cypress will be new…do I still need to brighten the wood after sanding with 80 grit?
Johnny spain
Johnny spain
6 months ago
Freshly sanded deck of old stain . Bare wood now . What’s next step ? Deck wash or stain ?
Johnny spain
Johnny spain
6 months ago
80 grit was last grit used . Have finer if needed
Pat Rogers
Pat Rogers
6 months ago
I have an older painted or solid stained deck that is in the mountains of East Tennessee. It does get all sad in the rain lots of wind, high wind, and I’m looking to change the color of the solid stain. That’s on it and really needs your recommendation. I’m wanting to do dark handrails and a lighter color on the floor Naturally would love to have something that would last longer than two or three years. I’ve already prepped a lot of it, but haven’t decided on the solid stain color or what product to use.
Johnny spain
Johnny spain
6 months ago
Two Y old pressure treated pine deck . Had a semi transparent water based stain sealer on it until got pressure washed yesterday , stain peeled off . I’m going to strip all stain off back to bare wood . I’m considering oil based stain sealer . Any recommendations? I am in Deep South in full sunshine to deck . Need UV and waterproofing as well as wood treatment. Thinking oil based?? TIA JS
Russ
Russ
6 months ago
Ok! New deck yellow pine wood, want sealer and tint combined what’s your recommendation full sun northwest Georgia?
Marty Chase
Marty Chase
7 months ago
Looking for a deck stain for townhouse community in Chevy Chase, MD All deck boards have been replaced and will need to match old deck railings, so the stain can’t be too transparent. The present color is a dark reddish cedar.
Ned Witherspoon
Ned Witherspoon
7 months ago
I have an old deck covered with blue Olympic solid stain in good shape. I want to change color to light walnut. Can I use RAC solid stain over the existing deck or is there a better solid stain to use in this situation?
Vince
Vince
8 months ago
Good morning Scott – looking for some assistance on staining our second story deck for the first time. We purchased a fourplex in Kalama, WA (SW Washington; very rainy and mild temps) which has a 10’x27′ +/- second-story deck. Upstairs tenants raised the concern that deck is very slick and they have slipped several times. I recently cleaned the deck with Olympic cleaner, and now I want to stain and add some kind of an anti-slip surface, initially thinking mixing this product to a stain:
What is your recommendation on stain? Looking at historical satellite imagery, the deck appears to be 10+ years old. I care about what the deck looks like, but more importantly, I care about the safety of the tenants. Want it to be slip-resistant.
State: Southwest Washington (very wet and mild)
Sun/shade: deck is on west side of house. Sees full sun after noon, see attached image.
Type of wood: Unsure, pressure treated. Grey and weared. Structurally solid.
Mold/mildew: No mold. Possibly mildew makes the surface slick?
Previous stain failure: honestly I don’t know if it was originally stained. If so, its long overdue.
Type of stain: unknown.
Any advice is greatly appreciated, thanks!
Vince
Vince
8 months ago
Thanks Scott. You’re right. My apologies forgot to add pictures. Please see attached pictures for reference.
Good to know that I cannot add the grip additive. Assuming it will not bond appropriately since the stain will penetrate the wood grain and not sit on top of the wood?
Any further recommendations based on the attached pictures? If not, thanks again for the advice on the linked stains.
Have a blessed day,
deck2
deck
Vince
Vince
8 months ago
I will go grab some pictures tonight after work. This picture is before I cleaned with Olympic deck cleaner. I sprayed deck cleaner on in a couple coats, let it sit for 5-10 minutes, then hand scrubbed with a deck brush and warm water for about an hour. Several passes. Then rinsed with a hose. More to follow!
Vince
Vince
8 months ago
Reply to  Vince
Here are some pics of the deck.
20260124_091214
20260124_091251
20260124_091310
Nick
Nick
10 months ago
Hello. I have a brand new deck I’m building and was looking for your recommendation of the best finish. Here are the answers to your questions.
In which state is your deck located? California
How much sun/shade does your deck get? Full sun on most of it. One portion is under a patio cover.
What type of wood is your deck made of? Redwood
Do you have mold or mildew issues? No
Why/how did the previous stain fail? New deck
What type and brand (if known) of stain did you use last time? New deck
Nick
Nick
9 months ago
Michael
Michael
10 months ago
Hi. I have a new construction cabin in North Carolina modern style and the siding just went up in Cypress wood. I prefer the darker colors. I love the black walnut and I’ll include the photo of the deck floor on your site. I’d love to put this on my siding but it’s new Cypress. Any suggestions for an approximation of a rich deep color like this?
Screenshot_20251119_130830_Chrome
Michael
Michael
10 months ago
Thank you so much for the speedy
reply. And if I read correctly I don’t need to do anything with the wood until spring correct? Thanks
Michael
Michael
10 months ago
Feel like I’m a pain in the butt but… The contractor tells me his guy’s already put clear coat on three sides of this. Awaiting the stain and then coating to be put on the visible side. Seeing as though that’s already been done should clear coat go on the final face. The guy is suggesting that we have to put it there now because there will be cupping if we don’t. Geez Louise!
I wish I’d stumbled on your page last week!
Thanks again
Alecia
Alecia
11 months ago
I live in Utah and my wood deck is roughly 6 years old. It was stained when it was first built, but hasn’t been refinished or stained since. I want to refinish it now, but am worried about how cold it is in Utah as it’s November already. Moisture wise we should be ok, but temperature wise, is going to dip below 50 degrees fahrenheit. Is it worth putting the money into it and doing it now or is it a safer bet to wait until Spring? The deck is in pretty good shape now. There is some warping. Utah winters are wet.
Alecia
Alecia
10 months ago
I hope I’m not doubling up my response because the first time I tried to reply, it disappeared.
Thank you for the info about waiting until Spring. I am interested in what you’d recommend for prep and stain. I’d also like to know if there’s anything I can do to protect the deck over the winter? Thank you so much for sharing your knowledge. I’m a newbie and this is so much appreciated!
IMG_20251108_133059767
IMG_20251108_133051913
IMG_20251108_133036842
Nikki
Nikki
11 months ago
Do you know anything about the quality of Cabot wood toned deck stain & sealer? How does it compare to Armstrong & Clark?
11 months ago
What semi-transparent do you recommend that comes in black for use on a PT pine fence? Or at least the darkest colored stain? I’ve added fencing to my yard that’s connected to neighbor’s fences so want to “blend” the fences in terms of color as much as possible. Thanks.
Kathryne
Kathryne
11 months ago
Scott,
Downloaded your app to purchase products but a glitch says no such email. So, Im frozen out, can you fix it in your end?
I never could find a deck (dock) wood stripper that wouldnt harm fish…. but closest thing seems to be Restore a Deck cleaner and brightener kit -? Also, did I see RAD wood stain in 2.5 gal? So 2 would be 5 gal? Is there free shipping and approx how long would it take to arrive in zip code 75410? Weathers perfect here…. thank you for all your help. What would I have done without you?
Simon
Simon
11 months ago
Hi there, I just replace the boards of my deck with fresh pressure treated wood in Ontario. Winter is coming and I’m curious if I can stain right away? I see some advice to wait 3-6 months but I don’t want to leave unprotected over winter with salt being used for snow. Can I use restoradeck? If it’s new can I skip to step 3? Thank you
Simon
Simon
11 months ago
Should I protect it in anyway from snow and salt? Its in the front porch
Tom Henderson
Tom Henderson
11 months ago
I’m in the Atlanta area and building a new deck. Deck boards are Home Depot PT #2 Southern Pine 2×6’s. They have been drying in my garage for several months and moisture content is pretty low. I was planning to stain and seal them before installing so I can get all sides. The grain isn’t really great, some of them are pretty dirty and a lot of them still have a greenish tint. There will be a hot tub covering about 35% of the deck surface.
My questions are:
1) Do you think a solid TWP stain would be best?
2) How much should I clean the boards before staining and with what product?
3) Should I treat the cut ends with copper napthante (which I used on the framing) before staining?
4) Is there any extra protection I can do for the boards under the hot tub?
Christina
Christina
11 months ago
My deck is located in the woods in Missouri and gets lots of direct sunlight every day. It’s 17 years old and all of the rotting boards were replaced a couple of years ago. The last stain was a Thompson’s full coverage (more like paint) and it lasted about 1 year before it started peeling and fading in many areas. I also hated the reddish color. I’ve been sanding and stripping and power washing on 4 separate days trying to get back to the bare wood. Once that is completed (more sanding!) I really would like to see the wood that’s been uncovered (SO MUCH WORK!), but after reading about clear protection, it sounds like it’s not enough for a deck that’s getting so much sun. I am planning on taking off the wood balusters (the old stain is not coming off and the power washing and stripping is trashing them) and replacing them with black aluminum balusters. What would you recommend that I put on the deck’s surface and rails? I plan to use some PC-Petrifier Water-Based Wood Hardener on some holes or areas that seem cracked but not rotted before sealing it. The A-frame next to the deck is Sherwin Williams 7502 Dry Dock (trim) and Sherwin Williams 3065 Fawn (house). Photos show deck before I started sanding and stripping and the other photo shows the colors of the Aframe.Thanks,
Christina
IMG_7520
IMG_7519
Nikkisatokon3@yahoo.com
11 months ago
I have Douglas fir deck that was installed two years ago. The contractor applied penofin stain which has completely deteriorated in two years. Which stain should I use and how to apply it? Should I sand then apply the new stain?
Marvin Orr
Marvin Orr
11 months ago
I noticed you advised Todd not to sand for prep as it reduced stain penetration. Is there a stain remover that would be safe to use considering the tree roots that are present? I had figured on using a 40 grit paper as I thought that would open the grain more. Also, what cleaner and brightener is safe to use with the tree roots?
Thanks again Scott
Marvin Orr
Marvin Orr
11 months ago
Following are pics of my deck.Redwood, five years old. I first stained it with transparent Super Deck by Duckback Products. I put one coat on and then another coat the following spring. After two years the horizontal surfaces needed to be done again. Duckback had gone out of business so I went with semitransparent Olympic Maximum stain and sealant. After one year it looked to be peeling in a few places. I recoated it again, this would be last year, and you can see how it looks. You can also see how the Super Deck looks and it has been three years. I should say that I just used water and a brush to clean the deck as I have a Locust tree right there with roots under the deck and I didn’t see a cleaning product that I felt comfortable with. I’m looking at going with TWP 100 semitransparent. I have two questions,.First does TWP have a redwood stain that is the same or close to the Super Deck in color. You can see that the Olympic isn’t even close, it’s more brown than red. Second, at this point would I be better off to wait till next year and completely sand every thing off ant start over with the TWP? I would appreciate any advise you could give me. I should tell you that I live in Elko, Nv. so the winters are cold, -20. We get snow, sometimes a little some times a lot, but I keep the deck pushed off. Summers are rarely over 100 and my deck is shade most of the day. Very dry humidity.
M. Orr
IMG_0286
IMG_0285
IMG_0287
Ruth
Ruth
11 months ago
Any advice would be appreciated.
I have a Douglas Fir balcony in Corpus Christi, TX. I Used Marine One In February and dirt sticks and causes spots, the finish scuffs and the wood faded. Tried the same product again on one plank on the far right this summer thinking the humidity/application was the cause and got the same result. Starting over now. Can you recommend a product to keep a natural wood color (no gray or white) and dirt from clinging to the surface. Thanks in advance!
IMG_3099
IMG_3029
IMG_2994
Sandra
Sandra
11 months ago
Hi Scott:
I live in Illinois and just had a new deck installed with CedarTone pressure treated lumbar from Menards. Attached to the deck is an already existing gazebo. Due to wood rot, the gazebo got a new untreated cedar wood door and a new roof with untreated Western Red Cedar shingles (also from Menards). I need to stain the door and shingles and want the color to match the color of the CedarTone lumbar. What stain do you recommend? Thanks for your help!
Todd Johnson
Todd Johnson
11 months ago
Hi Scott. Looking for some feedback on how to overcome stain that won’t stay on my cedar deck. I’ll try to provide details, while keeping it as brief as possible.
Installed new cedar on my existing deck in the fall of 2023. The wood sat in the yard over a period of four weeks. The deck is on the East side of the house, and gets morning to afternoon sun. After installing it I hand sanded with an orbital sander using 80 grit. Stained with Cabot Australian Timber Oil (oil based, not low VOC) in their Natural, and it looked great. Held up pretty well until the Spring of this year, and while it did not peel, the finish seemed to just disappear, no more water beading, and graying began. This past March I completely re-sanded again with 80 grit. I did use Cabot Deck Cleaner, and stained once again with ATO/Natural, and now it looks worse than ever after only 6 months. Where we’ve had deck furniture the wood has not discolored and still beads water, but the exposed sections are very bad and very dirty looking. I did wash the deck using SpicNSpan per Cabot’s instruction, and while the surface dirt is removed, most of the wood is discolored as you can see in the pic.
Since there has not been peeling, I’m wondering if the cedar has never really absorbed the stain correctly and what is virtually a surface treatment just weathers away. I have not used brightener in the past. I’m not enthused about sanding yet again (takes days on my hands and knees). Do I need to strip? Brighten? Use a different brand of stain? I’d just like to get something down that lasts for a couple of years and stays looking good. Thanks in advance.
Pictures: Deck1=Original Stain in 2023, Deck2=2nd Stain after 2 months (June 2025), Deck3=Stain now (October 7, 2025)
Deck1
Deck2
Deck3
Todd Johnson
Todd Johnson
11 months ago
Thank you! A little concerned about the pressure washing as I don’t want to damage the cedar, but will look into it.
Todd Johnson
Todd Johnson
11 months ago
One follow-up, please. I’m in Illinois and the weather is finally changing. Low 70’s during the day, and high 40’s to low 50’s at night. I’m a bit concerned about putting something down now when the temps at night can be below 50 degrees. Should I just be leaving the deck as-is and start over in the spring?
Joe Orr
Joe Orr
Scott, OMG – this is tremendous! I have never been to such a thorough / detailed / more laid out web site. Feel that I owe you some $$ for the mega-consultation. If you send me a PayPal address, I will send you a tip 🙂 I feel all prepared now that I read your web page and been getting quotes for weeks (hiring an expert to perform the work). Have one final firm arriving this Wednesday (1 October), so want to run an overview by you: Deck is old, last Sept. had it restored with pressure treated wood (except the rails). Now need it cleaned and sealed (a few floor-boards already graying). The rails need to be super-stripped BTW. Live in Central Maryland – its hot and humid summertime / winters vary – so can be extreme or mild. Deck is almost a square (17.5′ x 16′) with a walkway of (19′ x 39′). Sun beats on deck much of the summer daytime until late afternoon / early evening at best. All vendors so far want to use either Ready-Seal or Sherwin-Williams – based on your recommendations and others on-line; no experts rate them high at all, so I am advocating TWP Semi-Transparent 1500. Wife wants clear, but I feel Semi is a good compromise and you rate semi over clear, correct? We cannot use the higher rated TWP 100, etc. – banned in Maryland 🙁 If 1500 is a no-go for whatever reason, please recommend next best choice. Please advise and also – whichever I choose / you recommend, hoping to not seal annually and thus how often should we clean and/or seal? Thanks again!!
neal
neal
Thank you for this helpful guide!
i’m looking to stain the siding (and decks) of a newly constructed home. wood is eastern pine. the wood has been aging outside for at least 6 months (April to October on site, not clear how long it aged with the distributor before we received the shipment). we’re in upstate new york, in the mountains, about 1000 feet elevation: cold, snowy winters and rainy/dewy spring, summer, and fall. the house does get partial sun throughout the day, when it is not raining or snowing. mold and mildew are concerns.
neal
neal
thank you so much!
Andrew
Andrew
We have a newly built pressure treated pine (kiln dried) deck that was built around our salt water pool, here near Charlotte, NC. Price is not important. We are looking to find the best available protection that is easy to apply and will retain its color for as long as possible. Deck is West-facing and has full sun most of the day (aside from smaller area under cover until afternoon). Solid or transparent is not that big of a priority one way or another. We just want something that will make our deck last as long as possible while keeping its good looks. Ease of application is also very important and we want as much time as possible in between applications. What would your top suggestions be (in order) and why?
Jeff Keith
Jeff Keith
I live in East Central Illinois, so our weather can be the extremes. Below zero frequently in the winter, well into the low 100’s with humidity during our summers. I recently replaced all the deck boards. With Pressure treated Wood decking. I’m looking for something that will protect my investment, provide UV, Waterproof, Mold and Mildew resistant. I prefer a clear. Any help would be very much appreciated.
Gary M
Gary M
I recently restored a cedar picket fence and used Defy extreme which I discovered on your website, thank you very much. To complete the project I’ve created a “feature” section using Horizontal CVG Douglas fir1x4and 1×6. boards. Looking for advice on staining these (warm redish tone semi transparent). I have read Fir tends to get blotchy. I image a pre-stain would help. Thanks in advance for your response!
Mary
Mary
  • I have a pine log railing for my deck. It was in bad shape when I bought the house 11 years ago, even tho only 6 to 7 years old. I used caulk to seal cracks in the wood, then used Behr Waterproofing stain and sealer solid color, 2 applications. I recoated the top and bottom horizontal rail logs each year, and the spindle vertical logs as needed very lightly. It has held up nicely for the 11+ yrs in the mountains of Colorado where we do get plenty of snow and rain. I am replacing the railings since they are now 18+ years old and a couple of sections’ top and bottom horizontal rails have started to fall apart due to excessive moisture the past 3 years. Wondering what would be best product, or if Behr is one of the best for the new pine railings?
  • In which state is your railings located? Mountains of Colorado with lots of snow and rain
  • How much sun/shade does your deck get? Some sun in the morning, but mostly shaded throughout the day
  • What type of wood is your railings made of? Wood railings all made of pine (top/bottom horizontal logs with vertical spindle logs)
  • Do you have mold or mildew issues? No
  • Why/how did the previous stain fail? Water got under stain layer? Birds pecked at logs, created holes for moisture and water seemed to get under stain layer
  • What type and brand (if known) of stain did you use last time? Behr Waterproofing stain and sealer solid color 10 year deck/25 year fence
Martin Deadman
Martin Deadman
I live in Albany NY, and the deck gets some shade and some sun, also snow in winter. My deck is older and previously coated with a solid stain which has faded somewhat.. Some boards (less that 1/3 of the surface) had to be replaced with pressure treated lumber. The remaining boards are solid, surface is a little rough but structurally ok. After a rough scrub and clean up, it looks pretty good. I want to use a solid stain to coat the entire deck, and realize I need to wait for the pressure coated to dry for 2-3 months. What brand of solid stain would your recommend?
deck1
Hi – I live in northeast Florida about two miles from the ocean. Lots of sun, heat and humidity. Looking for a semi-transparent stain with high UV and mildew resistance. Need it to be penetrating. Deck was installed (southern yellow pine deck with pressure treated railings) a year and a half ago and has not been stained or painted yet. What would you recommend? I seem to be thinking water based as some reviews say oil based stains will show blotching and I want to avoid this. Thanks John
Thanks. And if I decide to go with oil-based which would you recommend for high heat/humidity?
Jerry Kellis
Jerry Kellis
I have a deck that is about 10 months old. I want to put on a stain to protect the wood. My deck is made of treated yellow pine. I live in Cary NC. I have lots of sun about 2/3 of the day. In the summer we have high humidity and temperatures that can range up to the upper 90’s. I want to put on a stain that brings out the true color of the wood but I don’t want it to be the clear stain. I have been debating which brand to use. Wolman’s F & P, Outlast Q Log Oil or TWP 100. I need your advice on which one will protect best and last longer.
Thank you, Jerry
Courtney
Courtney
Hello, and thank you for your time!
In which state is your deck located? Washington state, 900 feet elevation
How much sun/shade does your deck get? We get about 11 hours of sunlight a day in the summer with high UV. LOTS of rain in the Fall, Winter, and Spring. Some snow.
What type of wood is your deck made of? We have no idea. The previous owners did not know.
Do you have mold or mildew issues? No. From my ignorant gaze the damage is sun damage.
Why/how did the previous stain fail? I think they might have stained at one point because some of the wood looks like a different color (middle picture), however, I don’t have any information. It’s been a minimum 4 years since anything was done.
My main question is can I get away with just a clean, sand, stain or do I need something more for this condition?
Would you recommend a semi-solid or solid?
Thank you in advance for answering questions! 😊
IMG_7984
IMG_7983
IMG_7982
Clay Smith
Clay Smith
I am installing a new douglas fir porch floor and I am considering using 1. Cutek Exterior 450, 2. waterlox original sealer, 3. Watco teak, 4. Natural danish oil, 5. Sikkens, 6. Osmo, 7. Nova exo shield. Do you have opinions on any of these finishes and which one of these may be the best product to use?
Kelsey
Kelsey
I’m attempting to redo my deck after 12 years… lol. There are so many options. I think the original was water based but not 100% sure should I do a stripper? I live in the PNW in Kitsap County WA. I been told to use water based all the way to motor oil lol. Sooo. Its covered porch but we get a lot of rain so its semi protected. I have a pressure washer its a 2300 so was only using the 40 tip on it oh its cedar. Thank you!!!!
20250829_084136
20250829_083445
20250827_193125
Angie
Angie
Have prepped a one year old deck and ready to stain, was going to use Cabot Solid Acrylic Stain & Sealer on advice from someone who used it several years ago. Now I see a ton of negative comments on this item, and when I call local hardware stores for advice they only offer their “name brand” item. Need suggestion for pine deck. Thanks!
Georgina
Georgina
our deck is quite large and we live in Monroe, NC and the summers here are quite brutal with temps regularly in 90-100’s. The deck gets southeast sun and portions of deck are so hot you cannot walk on it without shoes in summer. It is made of pine decking boards (treated lumber)! The deck is 9 years old and since we have built it we have only used a semi deck stain, never a solid. We have had it pressure washed and stained each summer-one summer we actually had to have it sanded after we put Sherwin Williams solid color on it and really did not like it! Would you put water based stain or oil based stain and which stain do you recommend?
Bob H.
Bob H.
I live in Pa. Covered porch that will be screened in. Sun hits deck edge ,about 4′ from11a- 5p.
16x 12 size. 1″ thick Red Oak with tongue and groove. Sanded to 60 grit and used Sansin SDF & DEK STAIN coat. Both took 48 hrs. Plus to dry and surface was still tacky.
After applying SDF , SANSIN suggested sand product off, re- sand to 60 grit and apply Sansin Dek stain. Both were tacky in spots after 2 plus days. Good weather conditions. HELP !!
Bob H.
Bob H.
Unfortunately, I agree with you.
Because it is a Hard wood species I believe the stain is not penetrating. We chose Red Oak #1 grade, to match the interior floors and flow to their outdoor space. We are looking to keep the natural grain appearance in a medium brown tone.
What product do you recommend for this project?
Deanna
Deanna
Hi Paul!
I live in Western NY and have a craftsman house with a covered porch. Just had a new tongue & groove yellow pine deck installed. Replaced the old wooden t &g deck from 1928 which was painted and starting to sag and rot. The deck is mostly shaded, but alternating halves gets sun each day. 4 seasons here, but in severe weather (which is often in winter/rainy season) the deck gets snow or rain on it.
I can’t handle fumes from oil-based, so looking for the best water based stain. I’m not a fan of solid stains.
Deanna
Deanna
Thank you so much for the links and advice!
I don’t believe the yellow pine is treated with anything, seems pretty smooth and dry. I believe it is kiln dried. I will include pics here in case i’m mistaken. So per the article, looks like waiting 1-2 months before prepping/staining.
IMG_0536
IMG_0532
IMG_0535
IMG_0534
I am so glad to see the ability to ask questions on here! I have several questions:
Two years ago, RAD Semitransparent Stain in Cottage Gray was applied to my deck. It started peeling this year. I use RAD Stain Remover to take it off, and in some places I had do it twice, but all of the stain did not come off. There is a slight gray hue remaining on some of the boards. I do not know how to remove that. Does it need to be removed?.
Also, despite trying hard not to hurt the wood of the deck it looked really ragged when I finished using the remover. So, I have been sanding with 60-80 grit paper (unfortunately, some 100 grit when I ran out). Now I am worried about it not taking the new stain well. Do I need to go over everything again with 80 grit?
Also, under my deck is a very nice built-in storage shed that was built about two years ago but never stained. Some overspray from the RAD Stain Remover is on part of it and has left small white bleached out dots on the wood, even though I did clean it before using the stain remover on the deck above. I have tried test sanding it – not effective, Krud Kutter, and then Valspar All In One Deck Prep. Nothing has taken care of the issue. I plan to use a semi transpiring stain from Armstrong-Clark, and I am worried the dots will shine throng. How do I address this before staining?
BTW, I already used brightener on all of the wood – deck and shed below.
Thank you for your advice.
IMG_9798
IMG_9799
IMG_9800
julia
julia
Hi, I live in the Chicago suburbs, IL where we have below freezing temps and snow in the winter. Summers can get hot, rainy, and very humid. My deck and balcony are in the shade in the morning, but gets full sun all afternoon and into the evening. The deck is cedar wood and the balcony is pressure treated wood. The cedar deck was stained, but the balcony was never stained. There is a mold/mildew problem. I’m looking for either a semi-solid stain or a solid stain. Is one better than the other? My deck and balcony are pretty weathered. I don’t want much maintenance with the deck or balcony. What deck stain and brand do you recommend? Also, do you recommend staining the underside of the deck and balcony? Thanks for your help!
Denise
Denise
Hi there…wondering what the best deck stain would be for my cedar deck. It is an older deck but has been sanded and?restained numerous times. I would like the wood grain to show through as much as possible. Looking at 1100 square feet – some is under cover and some is open to the Alberta weather. The last product I used in it was Olympic Maximum stain and sealant in one. Cedar natural tone…which has probably been the best we’ve tried so far…but if there’s something better, I’d definitely do that. TIA
Holly
Holly
Hi! We have a never treated deck made of pine. We just power washed it. We want a deep penetrating stain. It gets full sun in the morning & shaded by evening. Maybe a light color. The deck is in Mid Michigan area.
We just replaced some old boards.
Holly
Matt Pasteris
Matt Pasteris
I’m looking for recommendations for a eco-friendly low odor semi-transparent stain for bird houses I’m making from raw wood (not treated or painted). I’m using 3/4″ rough cut oak, cedar and pine. Preferably looking for a one stroke application and maintain natural wood colors. Oil base stains are not recommended by the birding experts due to potential fumes that could harm the health of the nesting birds.
I’m all ears…………thank – you, Matt
Craig MacDonald
Craig MacDonald
Hi. I have a 20 year old pressure treated wood deck. I’ve used transparent protection over the years. Last time I tried a stain that peeled and made a mess. I’ve removed most of this with stripper and light pressure water knowing pressure washing and sanding pressure treated wood is not recommended.
With prep done I’d like to know my best option. I’d like a deep penetrating oil with a slight color to make it uniform. Any suggestions. Thanks.
Malcolm
Malcolm
Thank you Scott. Power washing has removed any stain on the surface. Are there concerns about the old stain that has penetrated? Not much can be done with that, correct?
Good surface prep should be good to receive new stain? Is there something better to use for re-staining? Thanks.
Malcolm
Malcolm
will need to get photos tonight and send tomorrow. I’m at work now. thanks.
Malcolm
Malcolm
I have a redwood deck that is 18 years old. We applied OneTime deck stain 2 times, first time and 7 years later. It is a penetrating semi-transparent and semi solid stain. We will be re-staining our deck again after making some wood repairs. Deck has been aggressively power washed and cleaned. Is there any product recommended that can be applied over the OneTime? We’re in California living Central Coast area. Thank you!
Jennifer
Jennifer
We bought this house and do not know age or prior maintenance of the deck. It appears to be pressure-treated pine. We can tell they stained at some point with brown stain, and they did a pretty uneven job. We are dealing with either mold or mildew (black stuff) growing in an area that gets full sun. We live in Birmingham, AL and it is hot and humid all summer, with daily storms for long stretches of summer, with very mild winters. I’ve done the research on your site and think that maybe semi-transparent is what we want. The house is a medium gray. We want to stain either a matching grey or a walnut color (not sure pressure-treated pine will do that). We would like to be able to reapply every other year without stripping. We are open to just a straight up oil that is applied and left on (like tung oil for furniture, if that exists for decks). Would like something with some amount of sheen to it, not entirely matte. I understand that slipperiness is a factor, so I’m not talking about so shiny it’s a hazard. Ideally would love the sheen of a new IPE deck, although I know that may not be possible with our conditions.  Appreciate your input.
Deck-pics
Jennifer
Jennifer
Ok, understood. I believe I’ve seen in your other replies that if I’ve stripped, the cleaning and brightening isn’t necessary (although I may have misunderstood). Question 1-is that correct? Question 2-do you have a recommendation for a stain that fits those parameters? Question 3-is there a way for us to support you other than buying the products through your site?
Ann
Ann
Hi, we are planning to re-stain our screen porch and front steps for fire-resistant treatment in accordance with Fire-Wise guidelines using Dek-Gard as an additive. I understand that we should use an oil-based stain of some kind.
The wood surfaces are pine (#1SYP) and are about 15 years old. The porch floor looks pretty good as it’s covered by a metal roof and doesn’t get exposed as much. The steps were previously painted with a solid stain that started peeling after a few years. We stripped the treads and are ready to move forward. The steps face due south and get blasted by 100-degree sun in the summer (we’re in central Texas).
What would you recommend? Thanks!!
Stephanie
Stephanie
I have a cedar wood deck, and am looking for a good long lasting stain. Prefer something that shows the wood grain. I live in central wa. Lots of sun and snow. I like the natural wood look. The stain i have used in the past doesn’t last but a year. I can’t remember the brand, but I got it from my local Rodda paint store. What would you recommend?
Jamie
Jamie
Hello! I have three redwood deck areas, two are 5 years old and one is 8 months old. My area is very prone to mildew (San Francisco). They have never been stained- what do you recommend for a very natural look with long lasting protection and good mildew resistance?
Nikki
Nikki
Long story short…Our contractor didn’t prepare our deck properly prior to staining (didn’t buff the fur off enough) after we stripped and neutralized.
I ended up calling Armstrong and Clark to collect info. on what would be the best way to fix that, but prior to that, I hand buffed one deck board and re-stained it to see if the wood would take the stain. It did. When I expressed this to Jake Armstrong, WOW 🤩, he said that he recommended stripping it again and properly prepping and re-staining. But he also said that I may have found a work around. With that, I hand buffed the entire deck and re-stained it and it took well and dried. With the first rain, the deck boards showed marks where the water dried. I have attached pictures. There is one pic prior to the rain and one following the rain. Do you have any recommendations or thoughts on why there are watermarks and how to remove them? This deck is starting to feel like the never ending story. I really appreciate your help SO much.
Nikki
IMG_6882
IMG_6883
Nikki
Nikki
Ok. So if that is the case, should I sand the deck with 80 grit to open the wood back up and re-stain?
Nikki
Nikki
Ok. Is a brightener the same as a neutralizer? We just neutralized the wood about 2 months ago when we stripped it. Do you still recommend brightening it?
Don V
Don V
I just ordered 5 gallons of Restore a Deck semi transparent stain, my deck is pine and it’s 3 months old. I sanded off the stamping and will be applying it soon. I live in Indiana.
I was looking at doing a basic wash with a deck cleaner from a box store as the wood is so new and applying the stain.
Please let me know your thoughts as to whether I need to do something else or something more.
Thank You
Don
Fran
Fran
I have 8×8 Cedar post that I want to use a semi transparent stain to see grain. What are your thoughts on Structure Wood Care natural color stains products sold a SWP stores.
George
George
What is your recommendation for new redwood sealer/stain, preferably transparent or semi transparent. We are in Colorado, about 7000 feet and extreme southern exposure.
Have you used Penofin previously?
Many thanks
Hello I used the RAD Stain a few years ago. This time I am thanking about using TWP 100 would I need to strip the deck first or just go on top of the current stain ?
Brian Langman
Brian Langman
Hi. I have a 2 year old deck that I coated with Australian timber oil natural.
Last year the deck was infected with a black fungal growth that overtook the deck in a matter of days.
I power washed , but that didn’t remove it all so I started sanding with a hand sander. I did not yet sand the rails.
Not sure what my options are here. I liked the natural look but it didn’t last
Daniel Klein
Daniel Klein
So Generous to offer help! Thank you! I have a big outdoor covered deck made of reclaimed teak boards I handpicked here in Chiang Mai, Thailand. I initially put 5! coats of Thailand Polyurethane (with sandings between) and after 2 years, the edge sections that get wet and sun are already greying.
I plan to belt sand the whole deck to remove the poly and go with an oil or finishing but it’s very difficult to get quality finishes here.
Any ideas of what finish I can use and get here in Thailand?
IMG_0542
IMG_6210
IMG_6206-2
Maria Gordienko
Maria Gordienko
Hi Scott! I love your blog—such helpful info, thank you! We have a 20-year-old deck that’s only been pressure washed in the past 7-8 years. We want to restore it but are unsure where to start. We’ll replace the damaged planks but are uncertain about how to treat the existing paint, especially in low-traffic areas like the sides and rails, where the paint is patchy and varies in wear. I’m considering a semi-solid stain since I prefer not to paint it entirely unless necessary. Could you recommend a good paint remover? Also, would a semi-solid stain be effective, and if so, which brands or types should I consider? Lastly, I want to change the current red color to a natural brown to keep the wood appearance as much as possible.
photo_5188487791590372497_y
photo_5188487791590372498_y
photo_5188487791590372499_y
photo_5188487791590372500_y
Maria Gordienko
Maria Gordienko
Thank you! Will look into these options. Is there any chance the semi-transparent stain will work after thorough stripping, or is the deck too old already, and a semi-solid stain is the way to go?
Ray DAlessandro
Ray DAlessandro
Hey Scott, this is Ray. I had a 12′ x 14′ pavilion made of cedar and poplar wood installed about two years ago. The contractor stained the wood with “Wood Defender”. The stain is showing signs of deterioration/fading. I want to apply a dark brown stain but I am unsure of several things.
#1- there are no grains showing typically so I need to decide between a semi-solid or solid stain.
#2- I would prefer a thicker stain (like paint), but I also want the stain to penetrate into the wood.
#3- Searches for the “best” stain reveal many different stains as the best. Which one do you recommend?
#4- How many gallons do you think will cover the exterior? I don’t plan to stain the inside part of the roof.
I appreciate your help.
1-of-3
2-of-3
3-of-3
marnie
marnie
Hi Scott, I wrote a comment earlier today but it seems to have disappeared so I hope I’m not repeating myself if that comment should re-appear. I had a PT deck built Aug/24, let it weather for about 1 year and now I’m ready to stain. I read the reviews for Defy Extreme Semi-Transparent which has directions that the 2nd coat can go over the 1st coat wet over wet while the 1st coat is still damp. This is contrary to your advice to wait till the following year for the 2nd coat and not to stain when the wood is damp so I am confused. Of course it would be more convenient to do it all at one time rather than have the hassle of applying the 2nd coat next year. I’d like to get the stain soon using your website checkout but I would like to get your views first.
marnie
marnie
I phoned The Sealer Store and was told that applying Defy Extreme Semi-Transparent wet-on-wet means not letting the stain dry and to do the 2nd coat after 15-30 minutes. As a novice I am having a hard time visualizing how to do this as: (1) It sounds like I can only do a few boards at a time for fear of them drying? Boards are placed lengthwise 24 ft.and I’ll be using a stain pad and brush.(2) Won’t I smear the stain as I’d have to step on boards with damp stain to do the 2nd coat? (3) Won’t I get stain smears stepping on the next section of dry boards? I’m concerned all these stain smears will leave an uneven unsightly coating and how about shoe prints? (4) Is it necessary to do 2 coats for a new unstained deck weathered for a year? Can 1 coat last 2-3 years? Thanks for your help.
marnie
marnie
Thanks for your quick response! Yes, I did read the wet-on-wet article but I’m still confused. My deck is 350 sq.ft. There’s no way I can stain the whole deck with the first coat in 20-45 minutes. It’ll likely take a couple of hours or more as I am a novice at this and won’t the stain on the first half of the deck be dried by the time I’m ready to do the 2nd coat?
marnie
marnie
Let’s say at 30 minutes only half of the deck is stained with 1st coat I have no choice but to apply the 2nd coat and then continue the same process with the remaining unstained deck, will this cause the deck’s color to look uneven like a demarcation of 2 halves? I just want to be prepared for the worst case scenario to know what to do.
Carlo
Carlo
How much TWP 1500 will I need for 2 coats on an 800 sq ft deck?
Carlo
Carlo
I have a deck made with pressure treated pine. The deck is about 4 years old. I pressure washed it with Olympic deck cleaner however that did not remove the old sealer so I used a stripper on those areas. After it dryed there were still areas where the sealer remained so sanded the entire deck.
Do I need to use a brightner before I stain or can I stain over the sanded surface?
The deck will be stained with a semitransparent product. I was planning on using TWP 1500 or would Defy extream be a better choice.
marnie
marnie
You recommend Defy Extreme Semi-Transparent wood stain so do you also recommend #1 Deck Stain – Premium Semi-Transparent which is also made by Defy? I would like to know your views about #1
Paul VS
Paul VS
Scott, I am very impressed with your site. I have a question. I have an 8 yr old, pressure-treated, pine deck in the Southeast that is in good shape but we want to apply a semi-transparent, black stain to. I pressure washed it and it looked like new but it is in shady area with trees overhanging (sap) and in a hot humid environment so I will need to clean again before applying a stain. I am finding the desire for black limiting the stain options. I went to two big box home supply stores and their choices were not good. Questions are…..
  1. What is the best stain that is semi-transparent, black – my goal is to have the black color but see the wood grain. If oil-based is the best I am fine with that.
  2. The deck, three weeks after pressure washing, is already showing signs of green mildew so what prep should I pursue?
  3. Do I need to put a separate sealer over the initial stain?
Stephen Martin
Stephen Martin
Hi! My name is Stephen, and I live in Buffalo, Wyoming, 5,000′ in elevation at the base of the Bighorn mountains. We built 2 decks in 2021, and I am having a super hard time protecting them and would love your advice!
  • In which state is your deck located? Wyoming
  • How much sun/shade does your deck get? 10 hours
  • What type of wood is your deck made of? Redwood
  • Do you have mold or mildew issues? No, our climate is very dry, but we do get lots of snow, ice, and freezing temps in the winter months
  • Why/how did the previous stain fail? I would assume, uv rays, cold temps, snow, etc.
  • What type and brand (if known) of stain did you use last time? Messmer’s UV Protection (clear weathering formula), oil based
We applied the Messmer’s when the decks were built. We had to re-sand and reapply the back, larger deck the next year (2022), and the front, smaller deck year after that (2023). Now, both have raised grains, splinters, are gray, and in desperate need of sanding and refinishing. I was not happy with the Messmer’s product and would love your opinion on a durable product for our area. I don’t mind reapplying every other year or longer, but I don’t want to have to do it every year. The back deck is 60′ by 12′. The front deck is 30′ by 10′. Thank you!
IMG_8031
IMG_8032
IMG_8033
IMG_8034
Stephen Martin
Stephen Martin
As for color or opacity, I don’t have a preference. I just don’t want to paint it. So, a semi solid would be great if it will protect at our altitude. Would you recommend a brand/product in the semi-solid?
Stephen Martin
Stephen Martin
Do I sand the deck before applying the stipper-brightener, or after applying it?
Stephen Martin
Stephen Martin
Scott, thanks so much for all your help. If I may ask, because I don’t fully understand, why do I not need to sand before doing the work? The wood grains are raised and the boards are rough to the touch, even capable of giving splinters. Is there are part of the restoration process (i.e. stripper/brightener, power washing?) that gets the wood smooth again? I appreciate all your help!
Jeff
Jeff
Opinion on Cutex Extreme wood oil for a PTP deck with sapele wood/cable railing.
Deck is 8 years old, never been treated.
Rob
Rob
I have a 2-year-old western red cedar deck. It was stained last year with Restore A Deck semi-transparent dark walnut. I stripped it off this year and neutralized/brightened it afterwards. I like how the deck looks when it rains because it shows the grain and natural color. I want a stain that will mimic that look as much as possible. A contractor is going to sand the deck with an orbital sander to remove the feathered, raised fibers and remaining dark stain, and then apply the stain of my choice. What do you recommend for a stain that offers a clear seal that doesn’t go on with an orange hue or turn yellow? It’s ok with me if I have to reapply every Spring.
Stripped-and-brightened-before-sanding
Upload-from-mobile-175153965220250611_122729
Upload-from-mobile-175153983220250611_122422
Have gallon of floodpro Urethane modified A blended paint Called Canyon.do not want to open Would like to know what color it is?
Lucy
Lucy
We moved here in January, and the deck was in bad shape so we sanded it and applied Penofin Transparent/Clear in February. It’s 5 months later, and the deck looks dry and faded again. We are in Southern California and the sun is strong. Rain not so much though we did have rain this year.
If you could please let us know what product to use and whether you think we need to sand it again or if we can simply clean it, dust it, and apply the new product.
Appreciate the help, thank you.
IMG_4640
IMG_4641
IMG_4638
IMG_4639
Michael
Michael
i have an older wood deck that is structuraly sound however, it is aged. I have you Rustolium Deck restore in the past and I have had problems with moisture getting underneath and sometimes lifting the coating. I have the deck pretty well scraped and the product left seams to be solid. What is a good product to use to resurface the deck. Thank you
Donna
Donna
I dont want to strip my deck ,wanting solid stain that resist dirt, fading ,I used deck over last year ,looks dirty all time, faded,etc..what do u suggest
Michael
Michael
I am in Atlantic Canada opposite Msine’s a north east shore
The deck is Eastern cedar.
The deck is exposed all day yo the sun.
The deck is showing wear and cracking .
The previous covering as a Dwfy clear transparent, What should I do now- go for a semi transparent colour?
which would last longest in the pacific northwest, armstrong-clark semi-transparent (which i have been using) or twp 1500? thank you for your help!
Nikki
Nikki
A contractor just buffed and stained a deck that we stripped and neutralized. He did not buff it properly leaving quite a bit of furring and there is inconsistency in the finish because of it. The stain used was Armstrong and Clark Natural Tone. Would it be okay to buff over a 5 day old stain to remove the furring and get a smooth wood surface, followed by re-staining? Thoughts?
Thank you, 🙂
Nikki
Nikki
I reached out to you a while back, took your advice, and now have a beautiful stained upper deck! 🤩
We have a lower deck with the same wood as the upper deck and all of the same stripping and neutralizing was done on both decks. The lower deck is quite large and after stripping and neutralizing it, I hired someone to do the prep work (buffing) and staining. He did not buff the furring as well as I did on the upper deck, and then he followed it with staining. I wish I had been there to inspect before he did the staining. Unfortunately, the finished product is not the same quality as the upper deck. My question to you is if we were to buff the furring on the freshly stained and dry deck, and re-stain it, will that cause a problem or will that work? Thoughts?
Nikki
30.9K
