Hi, I’m Scott Paul, a licensed exterior restoration contractor with over 30 years of experience and 10,000+ deck restorations. This guide to the best fence stain is based on my own hands-on field testing, not manufacturer claims. See my full credentials and testing stats here.
Best Fence Stain for 2026
The best fence stain is a penetrating semi transparent stain that soaks into the wood instead of forming a film on the surface. After 30+ years of staining fences and decks, the four brands I recommend are TWP 100 Series, Restore-A-Deck, Armstrong Clark, and TWP 1500 Series.
A fence is an easier surface to protect than a deck. Fence boards are vertical, so they shed water, take less direct overhead sun, and never see foot traffic. That is why a quality fence stain lasts 3 to 5 years, roughly twice as long as the same stain on deck flooring.
Below are my top fence stain picks, how long each one lasts, what they cost, and the prep that determines whether you get 5 years or 18 months.
- The best fence stains are penetrating semi transparent stains like TWP 100 Series, Restore-A-Deck, Armstrong Clark, and TWP 1500 Series.
- Fence stains last 3 to 5 years on vertical boards, roughly twice as long as on deck flooring, due to less abuse.
- Surface preparation, including cleaning with a wood cleaner and brightener, is the biggest factor in how long fence stain lasts.
- New smooth or milled fence wood must weather 3 to 4 months before staining, while rough sawn wood can be stained immediately.
In This Guide
Which fence stain lasts the longest?
The longest lasting fence stain is a penetrating semi transparent stain like TWP, Restore-A-Deck, and Armstrong Clark. Penetrating stains soak into the wood and do not crack and peel over time like paint or solid deck stains. They still protect against moisture, while the pigment in a semi transparent color prevents graying. Penetrating semi transparent stains also wear evenly and are easy to maintain over time. Oil based formulas like TWP 100 and TWP 1500 Series tend to penetrate deeper, but water based options like Restore-A-Deck perform comparably on fences when prep is done correctly.
On a fence, expect 3 to 5 years from any of these stains. That is about twice what the same product gives you on deck flooring, because fence boards are vertical and take far less abuse. The south and west facing sides of a fence fade first, so check those before the shaded sides when deciding whether it is time to recoat.
The biggest factor in how long a fence stain lasts is surface preparation. Cleaning the fence with a deck cleaner and following up with a wood brightener opens the wood grain and allows the stain to penetrate fully. Skipping prep is the most common reason fence stain fails before its expected lifespan.
The wood species matters as well. Cedar and pine fence boards accept penetrating stains readily. New smooth or milled wood needs to weather for 3 to 4 months before staining, while rough sawn wood can be stained right away because its open surface absorbs stain immediately.
My Top 4 Fence Stains
These are the fence stains I use on customer projects, listed with my published ratings from hands on testing. All four are penetrating semi transparent stains that can be cleaned and recoated without stripping or sanding.
1. TWP 100 Series — My Highest Rated Fence Stain
My DeckStainHelp.com Rating: 8.63 out of 10
TWP 100 Series is the highest rated fence stain I have tested, and it is the product I reach for first when the state allows it. It is an oil based semi transparent wood preservative that penetrates deeply, holds color well, and reapplies with nothing more than a cleaning. In my testing the TWP 120 Pecan color retained about 80% of its original color after 2 years of full exposure on deck flooring, which is why I expect the full 5 years out of it on a fence.
Pros: Deepest penetration of the four. Excellent UV and mold protection. Prevents warping, cracking, and splitting. Easy to clean and recoat with no stripping.
Cons: At 550 VOC it is not compliant in roughly 20 states, including Michigan, California, New York, Pennsylvania, and all of Canada. Requires 2 coats applied wet on wet.
Coverage: 150 to 250 sq. ft. per gallon per coat
See my full review: TWP 100 Series Review
2. Restore-A-Deck Wood Stain — Best for New Fence Wood
My DeckStainHelp.com Rating: 8.625 out of 10
Restore-A-Deck Wood Stain is my favorite fence stain when the schedule is tight, because it can be applied to damp wood. That means you can clean, brighten, and stain a fence the same day instead of waiting days for it to dry. It is a water based penetrating semi transparent stain with excellent mildew resistance and water only cleanup, and it is compliant in all 50 states and Canada.
Pros: Damp wood application allows same day prep and staining. Excellent mildew resistance. Water cleanup. Compliant everywhere. One coat on new wood.
Cons: Only 5 colors to choose from.
See my full review: Restore-A-Deck Wood Stain Review
3. Armstrong Clark — Best for Staining in Full Sun
My DeckStainHelp.com Rating: 8.5 out of 10
Armstrong Clark is the fence stain I choose when I have to work in direct sun and heat. Most oil based stains flash dry and leave lap marks in those conditions, but Armstrong Clark can be applied in direct sunlight at temperatures from 50 to well over 110 degrees F. Its formula splits nondrying conditioning oils, which soak deep into the wood fiber, from drying oils that stay near the surface and lock the conditioning oils in. On a long fence run with no shade, that flexibility matters.
Pros: Applies in direct sun and heat. Deep penetration with no peeling. Strong coverage rate. Wide color range across transparent, semi transparent, and semi solid. Compliant in all 50 states and Canada at only 50 VOC.
Cons: Moderate mildew protection in consistently wet climates. Highest price per gallon of the four.
Coverage: 150 to 250 sq. ft. per gallon, and 300+ on hardwood fencing
See my full review: Armstrong Clark Stain Review
4. TWP 1500 Series — Best Fence Stain Available in All 50 States
TWP 1500 Series is my go to fence stain in Michigan and anywhere else TWP 100 cannot ship. It is the only stain on this list registered with the EPA as a wood preservative, which matters on fence posts and boards that sit near soil and stay damp. It performs very close to TWP 100, with slightly less penetration because of the lower VOC formula, and it maintains easily every few years with a cleaning and a fresh coat.
Pros: Compliant in all 50 states. EPA registered wood preservative. Excellent UV and mold protection. Penetrates well and reapplies without sanding. 10 color choices.
Cons: Takes longer to dry than TWP 100 Series. Not available in Canada.
See my full review: TWP 1500 Series Review
Once you have picked a stain, follow my step by step guide on how to stain a wood fence for prep, application, and avoiding lap marks.
Fence Stain Cost Comparison
Fence stain cost comes down to more than the price per gallon, because coverage rate and the number of coats change what you actually spend. Here is how my four picks compare.
| Fence Stain | My Rating | Base Type | Coverage Per Gallon | Where It Ships |
| TWP 100 Series | 8.63/10 | Oil based | 150 to 250 sq. ft. | About 30 states |
| Restore-A-Deck Wood Stain | 8.625/10 | Water based | 150 to 200 sq. ft. | All 50 states and Canada |
| Armstrong Clark | 8.5/10 | Oil based | 150 to 300 sq. ft. | All 50 states and Canada |
| TWP 1500 Series | 8.5/10 | Oil based | 150 to 250 sq. ft. | All 50 states |
Measure both sides of the fence if you plan to stain both. A 6 foot tall fence running 100 linear feet is 600 square feet per side, so 1,200 square feet total. At an average of 175 square feet per gallon, that is about 7 gallons for a single coat on both sides.
Fence Stain Calculator: How Much Do You Need?
Use the fence stain calculator below to estimate how many gallons you need. Enter your fence length and height, then choose your stain type, wood condition, and number of coats. Click the button to expand the calculator.
Fence square footage formula: length x height, then multiply by 2 if you are staining both sides. For a full deck version with inputs for flooring, railings, and steps, see my deck stain calculator.
Fence Stain vs Paint or Solid Stain
A penetrating fence stain outlasts paint and solid stain on bare wood because it soaks in rather than sitting on top. Here is how the two approaches compare on a wood fence.
| Feature | Penetrating Semi Transparent Stain | Paint or Solid Stain |
| Lifespan on Fence Boards | 3 to 5 years | 3 to 5 years before peeling |
| Peeling Risk | None, it soaks into the wood | High, it sits on the surface |
| Recoat Method | Clean and recoat, no stripping | Strip or sand before recoating |
| UV Protection | Yes, pigment blocks UV rays | Yes, but it traps moisture underneath |
| Shows Wood Grain | Yes | No |
| Best For | All fence wood types | Fences already painted or solid stain |
Staining a New Wood Fence
New fence wood needs different timing depending on how the boards were milled, and getting this wrong is one of the most common reasons a fence stain fails early.
Smooth or milled wood should weather for 3 to 4 months before staining. The milling process closes the wood pores and leaves mill glaze on the surface, so stain applied too soon will sit on top instead of soaking in. Test the boards by sprinkling water on them. If it soaks in within a few minutes, the wood is ready. If it beads up, wait longer.
Rough sawn wood can be stained right away. The open, textured surface absorbs stain immediately, so there is no waiting period. Rough sawn boards also soak up more product than smooth boards, so buy extra stain.
Either way, clean and brighten the wood before you stain. New wood picks up dirt, handling marks, and mildew while it sits, and a brightener opens the grain so the stain penetrates evenly. For more detail, see my guide on the best new wood fence stain.
How to Stain a Fence
Staining a fence correctly comes down to prep and thin, even coats. Here is the process I follow on customer fences.
- Clean the fence — Apply a dedicated wood cleaner to remove dirt, mildew, algae, and gray weathered fibers. A powdered cleaner is more cost effective than a liquid, since liquids are mostly water. Work in sections and keep the wood wet with the cleaner for the full dwell time, then rinse with a garden hose or a pressure washer on a wide fan tip held well back from the boards.
- Brighten the wood — Follow the cleaner with an oxalic acid wood brightener. This neutralizes the alkaline cleaner, restores the wood’s pH, and opens the grain so the stain can penetrate. Skipping the brightener is the single most common prep mistake, and it shortens fence stain life more than any other shortcut.
- Let the fence dry, or choose a damp wood stain — Most stains need 2 to 3 days of dry weather before application. Restore-A-Deck is the exception and can go on damp wood the same day, which is why I use it on tight schedules.
- Check the forecast and temperature — Stain between 45 and 95 degrees F with no rain expected for 24 hours. Avoid staining in direct hot sun with most brands, since the stain dries before it can penetrate. Armstrong Clark is the exception and can be applied in full sun and heat.
- Mask what you do not want stained — Cover siding, brick, concrete, and plantings next to the fence. Oil based stain on a light concrete walkway is difficult to remove, so take the time up front.
- Apply with a sprayer and back brush — An airless or pump sprayer covers a fence far faster than a brush, but always back brush or back roll right behind the sprayer to work the stain into the grain. Stain one full board from top to bottom before moving to the next to avoid lap marks.
- Apply the right number of coats — TWP requires 2 coats applied wet on wet, meaning the second goes on before the first dries. Restore-A-Deck and Armstrong Clark usually need only 1 coat, with a second only if the first absorbs within 30 minutes on dry, porous wood. Wipe off anything that has not absorbed.
- Stain the posts and bottom boards carefully — The bottom few inches of a fence and the base of each post stay damp from soil contact and sprinklers, and that is where rot starts. Give those areas a thorough coat, and pick TWP 1500 Series if rot is a concern on your fence.
For a full walkthrough, see my guide on how to stain a wood fence.
Fence Stain FAQs
What is the best fence stain?
The best fence stain is a penetrating semi transparent stain, and my top rated picks are TWP 100 Series at 8.63 out of 10, Restore-A-Deck at 8.625, and Armstrong Clark and TWP 1500 Series at 8.5. Which one is right for your fence depends on your state and your schedule. TWP 100 penetrates deepest but is not compliant in about 20 states, including Michigan, so TWP 1500 Series is my choice where TWP 100 cannot ship. Restore-A-Deck is the best option if you want to clean and stain the same day, since it can be applied to damp wood. Armstrong Clark is the one I use when I have to stain in direct sun and heat. All four can be cleaned and recoated without stripping or sanding, which is what keeps long term maintenance cheap.
How long does fence stain last?
A penetrating semi transparent fence stain applied to clean, dry wood typically lasts 3 to 5 years on vertical fence boards. That is about twice as long as the same stain on deck flooring, because a fence sheds water, takes less overhead sun, and never gets walked on. Longevity depends on sun exposure, climate, and the quality of prep work before application. Top performing brands like TWP, Armstrong Clark, and Restore-A-Deck consistently reach the upper end of that range. The south and west facing sides will fade before the shaded sides, so inspect those first, and recoat when the color has faded rather than waiting for the stain to fail completely.
What is the longest lasting fence stain for pressure treated wood?
The longest lasting fence stain for pressure treated wood is a penetrating semi transparent stain like TWP 1500 Series or Armstrong Clark. Timing matters more than the brand on new pressure treated fencing. New smooth or milled pressure treated boards need to weather for 3 to 4 months before staining, because the treatment process leaves the wood saturated and the milling closes the pores. Rough sawn pressure treated wood can be stained right away, since the open surface absorbs stain immediately. Test smooth boards by sprinkling water on them, and stain once the water soaks in within a few minutes instead of beading on the surface. Applying stain too early is the most common reason fence stain fails prematurely on pressure treated fences.
Is oil based or water based fence stain more durable?
Oil based fence stains like TWP 100 Series and TWP 1500 Series generally penetrate deeper into the wood grain and last longer between recoats. Water based options like Restore-A-Deck are a strong alternative in low VOC states and perform well on fences when properly applied, and Restore-A-Deck actually rated slightly higher than my oil based picks other than TWP 100. Either base can last 3 to 5 years on a fence, so preparation and application quality matter more than base type. The practical differences are cleanup and timing. Oil based stains need mineral spirits for cleanup and dry wood to soak into, while Restore-A-Deck cleans up with water and can be applied to damp wood, which lets you finish prep and staining in one day.
Should I paint or stain my fence?
Stain lasts longer than paint on a wood fence. Paint sits on the surface and will eventually crack, peel, and trap moisture inside the wood, which accelerates rot in the boards and posts. Penetrating fence stains soak into the wood, wear evenly, and can be recoated by cleaning and applying a fresh coat with no stripping or scraping required. On a fence that has never been coated, I recommend stain every time. The one situation where paint or a solid stain makes sense is a fence that is already painted, because removing old paint from both sides of a full fence is a large job. If your fence is already painted and the coating is sound, keep repainting it rather than trying to convert it to stain.
What fence stain color lasts the longest?
Darker fence stain colors contain more pigment and provide stronger UV protection, which means they last longer than lighter or near clear tones. Pigment is what blocks the UV rays that turn wood gray, so a clear or natural finish will start graying within months while a medium to dark tone holds color for years. If longevity is your priority, choose a medium to dark cedar, brown, or chestnut tone rather than a natural or transparent finish. Keep in mind that the same color looks different on cedar, pine, and pressure treated wood, so order a sample and test it on a spare board or an out of sight section of the fence before committing to gallons.
How much stain do I need for a fence?
Measure the fence length by the height to get the square footage of one side, then multiply by 2 if you are staining both sides. A 6 foot tall fence running 100 linear feet is 600 square feet per side, or 1,200 square feet total. Most fence stains cover 150 to 250 square feet per gallon on the first coat, so that fence needs roughly 6 to 8 gallons for one coat on both sides. Rough sawn and heavily weathered wood can absorb 20 to 40 percent more than the label rate, while a second coat uses up to 50 percent less than the first because the wood is already partly saturated. Use the fence stain calculator above to run your own numbers, and buy 10 to 15 percent extra so you do not run short mid project.
Do I need to clean my fence before staining?
Yes. Cleaning the fence before staining is the single biggest factor in how long the stain will last. Dirt, mildew, and gray weathered wood fibers block penetration, so the stain sits on the surface and wears off in a year or two instead of lasting 3 to 5. Use a wood cleaner followed by a wood brightener before applying any fence stain, even on wood that looks relatively clean. The brightener neutralizes the cleaner and opens the wood pores so the stain can soak in. Skipping this step is the most common reason fence stain fails early, and it is the mistake I see most often on fences homeowners have stained themselves.
More Fence Staining Guides
- Why Penetrating Deck Stains are Best
- What Deck Stain Lasts the Longest?
- Best New Wood Fence Stain
- Best Semi-Transparent Deck Stain Reviews
- The 8 Best Deck Stain Reviews and Ratings
- Deck Stain Calculator: How Many Gallons Do You Need?
- How to Stain a Wood Fence
- How to Stain a Wood Fence Video
Watch my video on how to stain a wood fence, covering prep, application, and the mistakes that shorten fence stain life.
Ask Me a Fence Stain Question
If you need help choosing the best fence stain for your project, post a comment below. Include your wood type, whether the boards are smooth or rough sawn, how old the fence is, your state, and how much sun the fence gets, and I will tell you which stain I would use and how to prep for it.
Hi, Scott! Thank you for the advice you are giving. Very helpful. I am stuck here 🙁 We have 2 floor house and 2 decks with fence and railings. Both decks are in the great condition, but the balusters on the fence are weathered , pilled badly and covered in black something. I washed part of with soap and water, old coating came off easily with little scrubbing. The old coating seems to be a varnish with sick film (who ever applied it wasn’t smart) some areas had it intact so even orbit sander could not take it off (or it was really intense sanding I would say). I also cleaned it this area with mildew and mold spray to remove some black spot, cleaned it, dried it and applied Behr penetrating oil stain. That was the biggest mistake of all I made :(. It has such a solvent odor – OMG. It has been 2 weeks and it smell like auto shop with car oil. And this is where I spent lot of times with my baby. How to Remove that “fresh” stain? I am afraid I have to cover the whole house downstairs to protect from caustic chemicals. Is there any alternatives to remove that horrible product? I applied it only on horizontal railings/balusters. Also what would be best odor free oil for the fence on the deck?
wood type – Western Red Cedar, Boards are smooth sawn with slight texture, fence is 2.5 years old, used Ready Seal Natural when new, Houston, Texas, fence gets 8 to 10 hours of sun a day
Strip and brighten for prep and then try the TWP 1500 Series.
