Why is my deck stain shiny?
Deck stain turns out shiny when it is not properly applied. Proper application of deck stain to avoid a shiny finish begins with preparation. The deck must be prepared and cleaned before new deck stain can be applied. If the deck was prepped correctly the deck stain is shiny because it was over applied. Even solid deck stains that seal and form a film over the wood should not be shiny when completed.
- A shiny deck stain is almost always caused by improper application, either poor prep or too much stain applied to the wood.
- Before applying any deck stain, the deck must be thoroughly cleaned and prepared to avoid finish problems like shininess.
- Over-applying deck stain is the most common cause of a shiny finish, even with solid deck stains that form a film.
- The only fix for a shiny deck is to fully strip it, power wash, and reapply stain carefully without over-applying.
What do I do about a shiny deck?
The only thing you can do with a shiny deck is to strip it and start over. You will not be able to remove the excess deck stain without damaging the layers beneath. Strip the deck, power wash it, and start over being careful not to aver apply.
More information about shiny deck stains
- Why Deck Stain Cannot be Shiny
- Can You Apply a Clear Sealer or Polyurethane over a Deck Stain?
- Why Is Deck Stain Tacky?
- How to Apply Deck Stain
- Deck Stripping – Removing an Old Deck Stain
