Behr (Advanced) Deckover Review 2026 2.3/5 (683)
Behr Advanced Deckover Review
  2. Preventing UV Graying
  3. Peeling or Wearing
  4. Cost Per Square Foot
  5. Preventing Mold and Mildew
  7. Color Shifting
  8. Ease of Reapplication
3. Wear/Tear and Peeling: 4
4. Cost Per Square Foot: 1
6. Ease of Application: 2
Where To Buy: Home Depot
Cost: $45 per Gallon
Coats Required: 2 Coats.
Dry Time: 8-24 Hours
Cleanup: Water
Manufacturer: Behr
UV Exposure: Full sun
Behr DeckOver Video Review
5 47
4 60
3 140
2 160
1 276
5 163
4 155
3 131
2 93
1 141
5 85
4 77
3 94
2 122
1 305
5 38
4 14
3 35
2 46
1 550
5 123
4 101
3 109
2 93
1 257
5 111
4 66
3 83
2 89
1 334
822 Comments
Russ
Russ
Cathy
Cathy
Reply to  Cathy
Conestler Green
Conestler Green
Leslie E
Leslie E
Lisa Fryar
Lisa Fryar
Reply to  Leslie E
Mick
Mick
JOHN
JOHN
Reply to  Mick
Alice Jones
Alice Jones
Reply to  JOHN
JOHN
JOHN
Reply to  Alice Jones
Eric
Eric
Alice Jones
Alice Jones
Reply to  Eric
Gloria Ezzell
Gloria Ezzell
Is a sealer available that will prevent the footprints that have to be scrubbed to remove… and often can’t be removed!! It seems like it attracts and permanently keeps footprints…. the very reason I spent all this huge amount of money was to be able to keep all my decks clean! Used it on steps as well😳😳😳
Helen rutherfod
Helen rutherfod
One of the most difficult stains to apply
Jean Jacobs
Jean Jacobs
I highly recommend NOT using this product. It does not adhere to wood. It looked good for a very short time then starts to peel off your deck like banana skins. Sad part is it sticks to some then you have to remove it from those areas, takes hours and hours. We used scrapers, grinders with abrasion wheel….and that was to remove what didn’t come off with a pressure washer.
Davek
Davek
I used deckover extensively, what a mistake. My recommendation don’t do it. Don’t wast your time or hard earned money. It will begin to peel after a year and leave you with a big mess. I can summarize it in 2 word- it sucks.
John Smith
John Smith
It’s aptly named…after two years, you have to do your deck over.
Necypro
Necypro
Reply to  John Smith
You were lucky to get two years. My contractor put it on in late summer and it didn’t even last the Upstate N. Y. winter. I made sure he followed directions but by Spring it was a mess. My deck is very large and it will cost me dearly to fix this eyesore. I am sorry I ever had it done and even sorrier that I didn’t read these reviews first.
Mark Scott
Mark Scott
I have had very good experience on my docks in Florida with Behr Premium Deckover despite being immersed several times. This seems contrary to most of the reviews here and it may be due to a lack of freezing in Florida.
My new project is in NC where there is a winter if somewhat moderate one. My elevated deck over a two car garage has a rubber membrane roof over which the previous owner glued down indoor/outdoor carpet. Mildew is a problem and I have removed the carpet. The carpet glue has hardened and looks ok but I want to paint the deck. If not Deckover, (based on the bad reviews her), what should I use? Is this a project for which Deck Revive would be appropriate?
Mark Scott
Mark Scott
Wonder about its application over a rubber roof membrane (probably EPDM) on which there is a hardened ridged layer of carpet outdoor cement which is probably pretty inert. Deck is around a hot tub and only gets light foot traffic.
Paul
Paul
Bought what Home Depot suggested was the best deck paint last Summer.
Peeled of this Spring, when I reapplied the paint bubbled up, paint pealed when applying touchups this Spring. Worst paint ever. Also it goes on like a mix of molasses and sand!!
I have painted and reapplied paint to many decks – never before have I had this problem!
When I went back to Home Depot, the clerk said they have had lots of complaints, andthat I needed to sand down the deck and redo ( not happening – and i will contact Behr ). This product is crap!!!
Ottawa, Ontario
Peter Bybel
Peter Bybel
Had a very bad time applying this product using 1/2 inch roller and stiff brush (terrible is not the word)
I’m a Home Improvements Contractor and have many job refinishing decks. So sorry that I went with this product – will never use it again and advise others the same
What a total disappointment 😡
I’m looking for a product for my 475 square-foot d
Reply to  Peter Bybel
Thanks for your review of this product. What do you use generally? I’m looking for a product to paint my 475 square-foot deck.
Joeg
Joeg
Deck built in 2010, used DeckOver in 2016, first signs of rotting in 2017. Today in 2019, any board that has DeckOver on it is rotted. Whole deck needs replaced. Support structure underneath is fine ONLY because it doesn’t have Behr DeckOver applied to it. My pregnant wife fell through one of the rotted deck boards causing my son to be born 2 months early!
MaryJo Kuzniewicz
MaryJo Kuzniewicz
The first time we used Deck over, I reached out to BEHR . My deck stared peeling within Iyr . BEHR REACHED OUT they sent me cleaner and 4 gallons of new deck over followed all directions and sorry to say my deck is worst then the first time. A lot of hard work went into this project.
Art
Art
Waste of funds. Peeling sections all over my deck. Law suit should be filed for false advertisement.
Lonnie
Lonnie
I painted my deck at my Cottage and my dock with Behr Paint which was supposed to be great outdoor paint. The doc is only in about four months out of the year the rest of the time it’s stacked outside. In less than a year it is peeling horribly. I’m so disappointed as it was a lot of work to do the manufacturer’s preparation and now it’s peeling off and big pieces.
George Shackelford
George Shackelford
I have had excellent performance out of DeckOver, when I put it down in 2013, on the deck of one of my rentals, and then took my next look at it in 2019, when getting ready to sell that rental. It looked almost as originally found, after cleaning it with soap and water. The deck had looked like it had been aging, in 2013, but instead of replacing the wood, I decide to try DeckOver, because it was a lot less expensive. It was at a time when the weather was very dry (for NE Ohio), and the temperature hit 85 deg. every day. Being the owner of the rental, and hoping to keep the cost down, and hoping that DeckOver would not fail, I followed the instructions exactly as stated, including waiting until the deck was totally dry after cleaning, and using Behr’s instructions for the cleaning and prep. I then put down 2 coats of DeckOver, using a brush (not a roller) cross-ways first, to fill all of the gaps in the splits in the wood, as well as nail holes, and then going length-wise, after letting the splits fill in a little, first. It took a lot more product than I expected, but it was worth it. I didn’t hear anything from the renters about any problems with the deck for 6 years. It was only after I started getting the rental for sale, 6 years later (today) that I was very pleased to see no flaking, and that the soap and water was all I needed to get it looking like it was when I originally bought it. No observable deterioration in the wood deck. I think that using this product when the weather was so dry, and then having the time to wait until the deck was totally dry, as well as following the instructions, was why this was successful. I feel bad for people who have not had good success with this product. I think that only home-owners can take the time to apply this product during hot, dry weather.
George Shackelford
George Shackelford
I wonder if the age of the wood, type of wood, or if it was untreated vs. treated, made any difference in how DeckOver worked? This deck was pretty old. I bought the rental at a auction. But DeckOver sure did the trick for me, even though it was alot of work.
George Shackelford
George Shackelford
I entered my opinion before seeing all of the hate mail about this product. I should point out that I do not work for Behr, or any companies affiliated with Behr, nor does Behr or any affiliate pay me any money. I am just entering my personal experience with this product. I will admit that prep. was strenuous, and then waiting for total drying after prep., was something that was very weather-dependent, and I got lucky with that in NE Ohio.
Bobbie Rodrigues
Bobbie Rodrigues
I am a home owner and was a paint contractor for years. I prepped my deck as instructed, applied as instructed. 2 years later, the paint is peeling and where the paint was cracked the wood has started to rot from holding water between the paint and the wood. 600.00 so far and we aren’t done yet.
Barbara Kelly
Barbara Kelly
I would like a full refund for a large pail of DeckOver that did not last more than 18 months.
I recommend not using this product as it has peeled and I can pull up on loose strips and
It comes right off, poor product.
Wayne Grimes
Wayne Grimes
Would not ever use this product again!! After 1 year it is peeling in several areas, I followed the prep stages and this product did not even last a season..
Paul
Paul
Reply to  Wayne Grimes
Exactly what happened to my deck. Applied in ideal conditions. Has peeled twice this Spring (2019). I am peeved because we have bought a new house and selling this one. This this deck stain has caused me headaches!
Ottawa, Ontario
Amber
Amber
Thank gawd I found this page. We just replaced the front porch and back deck. I was about to go out and buy this stuff and found your webpage. THANK YOU ALL for the reviews- we won’t be buying this. I’d be pist if this happened to us with the peeling etc. I’d rather just stain every year or two.
George Hite
George Hite
I reviewed this once before and rated as poor after just a few months now it’s two years later and if I can rate it below poor I would. Do not buy this project it is only may be good for brand new decking.
Bobbie Rodrigues
Bobbie Rodrigues
My review is the same as most. With the exception that anywhere it cracked, water was able to penetrate, which caused the wood to rot. I am so dissatisfied with this product.
I have been a paint contractor most of my life. I have bought Behr many times, in fact it’s one of my favorites. But because of this incident, I will never support this brand again.
Janice Palladini
Janice Palladini
We used DeckOver two years ago on wood deck–it’s an awful product (cracking and peeling)
We have contacted Behr regarding this situation (many times in the last two years)
However, they will not honor this product due to a lawsuit on Deckove
We completed all forms required for reimbursement but still have not received any response–probably never will
We have been to Home Depot (place of purchase) requesting a Behr representative call or come look at our deck but…again no reply
We have told many people NEVER to buy this product
One would think Behr would make an attempt to contact dissatisfied customer
Janice Palladini
Peoria Heights IL
Dollu
Dollu
Took us 2 years to get refund. Now 2 years later have the ugliest dock on the block. It’s 20 x 8 and 12 x 12. Too big to sand. Sometimes I just sit out there with my paint scraper and get off the huge globs that will come off. Pain in the ass. Also the rails are painted in that garbage. Huge..huge mess. Called home depot to see if they had something. To take it off with. Said they did but he would not guarantee it. Did not purchase
So like everyone else here, DO NOT PURCHASE THIS PRODUCT. Live in South Dakota so don’t know if it is because we have 4 seasons. If that’s the case stop selling it in this area. My husband and I are retired. He has Parkinson so it took a lot for us to prep and paint. Thinking we would not HAVE to ever do it again.
Keith E. Gleasman
Keith E. Gleasman
I applied this product on my concrete pool deck two years ago . Still looks great!
A low spot on the concrete sets in water longer that the rest of the surface ,still no problem.
I live in Up-State, New York,bad winter weather.I am buying more of this product for my sidewalk.
James Carter
James Carter
Adding our dissatisfaction to everyone elses. Deck looks horrible. It’s peeling all over. Why didn’t Home Depot warn us before we spent all that money for 5 gals of this horrible stuff and all the time we spent doing it? Now what?
matt
matt
Wow, I wish I would have found this about 6 months ago. Same problem as everyone else, stripped, and cleaned deck for prep work, and now it’s coming off in great big strips. We don’t even use the deck! It was covered in snow for 4 of the 6 months. My question is, is there something that can lay over it that works? Or am I doomed to strip the whole darn thing again.
George Hite
George Hite
Reply to  matt
I bought some rubber pavers and covered the whole deck and it was a cheaper solution than replacing the deck or sanding and replacing. When i first reviewed and complained about the Deck Over two years ago someone jokingly said that they named it Deck Over because you have to do your deck over after using it and that was a dead on comment.
Barb Anderson
Barb Anderson
I did everything right. Cleaned the deck let it dry, applied the deck over. Didn’t last a year is peeling off in strips will need to be completely redone at great expense. I would NOT recommend this product.
Gayle
Gayle
Lasted 7 months. Peeled off in large strips. Terrible product. Should be against the law to sell it. Do NOT purchase
Dawn
Dawn
Uggh I wish I saw this a couple days ago!!! We have started painting with the smooth deck over. Has anyone had problems using it on composite decking. Also, why cant we poly over it or something??
DJ Poland
DJ Poland
WHY IS THIS CRAP BEING SOLD?? this product is a joke. Shame on Home Depot for still selling it.
Bob Baldridge
Bob Baldridge
Absolutely the worst coating product on the market. Home Depot had to know it is not good but recommended it, then sold us inappropriate rollers TWICE! Three coats and still looks worse than the concrete patio that we started with. AVOID this terrible product. We will return to Home Depot and demand our money back. Should sue for what it will cost to remove and replace it.
David Clarke
David Clarke
Behr Deck Over is the worst product ever created. It in no way served its purpose and ruined my deck after 1 winter.
James Fram
James Fram
This product is horrible. I own two construction companies, and have been happy with other Behr products. But the deck over is a one on a scale of one to ten. My 1300 sq’ deck was sanded perfectly. All treatments were applied. The directions from the manufacturer were followed to the letter, and beyond. It was applied in early July last summer. And I saw bubbling all over about four weeks ago. The bubbles are all pealing off now.
We helped two friends across the street do their decks. And both of them are far worse.
I went to Home depot to the customer service counter today to ask what could be done. Two couples behind me said hello and they were there for the same reason. The manager of customer service said all they could do was to try and pull up my receipts for payment on the system. As Behr wants them. He told me that many clients have come in with the same problem. Now even if Behr returns my funds, I have a major project ahead of me to sand the entire deck down again. WHAT EVER YOU FOLKS DO, DON’T MAKE THE MISTAKE OF USING THIS PRODUCT.
Kim
Kim
Absolutely horrible. We power washed and sanded. Application went well but now a few issues already. People flip flops and slides stick in heat, they also cause white foot prints everywhere, already have spots coming off with just heavy rain, just painted two months ago. Hate to know what is to come…… would love to get money back on the five gallons I bought and buy something else. Behr always has great products but this is crap!
Michael Wasileski
Michael Wasileski
I used Deckover on several jobs in the last 3 years and was very disappointed with this product. This product was highly recommended and advertised as a high quality long lasting stain. Two of the the jobs I completed started peeling within 9 months. I’m a professional and followed All the proper prep. The other 2 jobs lasted about a year and a half to 2 years. 4 jobs still ok after 2.5 years. I have stopped using this Deckover product. My reputation is on the line. I did find out about the lawsuits a little too late.😧 No Recall? Tell me Again please! Why is this product still being SOLD!??
Dorota Johnson
Dorota Johnson
What do you recommend instead?
Stephanie Martin
Stephanie Martin
We have two decks that we spent all last summer painting with Behr Deck Over. It is already crumbling like dried out leaves. It peels off in sheets and look awful. This was a highly recommended product by the Home Depot associate. He must have never used it himself because I wouldn’t recommend this to anyone. DO NOT WASTE YOUR TIME and MONEY!! I am furious right now.
Lisa
Lisa
I agree. Same here it is aweful.
Maggie Balacki
Maggie Balacki
Three years ago I used deck over on my deck and was prepared this year to have my painter apply a new coat. While prepping the deck, the paint came off in sheets! I hope to return this item and buy a better product. DO NOT USE DECKOVER!!! If could figure out how to attach a photo, I would but our deck looks like Patty’s
Kathleen Dean
Kathleen Dean
Can i use polyurethane over the deckover paint? My deck atteacks dust and looks bad. I have repainted it, but want to coat it so it remains looking nice.
Carol
Carol
Deckover trapped water on my boards and caused massive rotting. Now its peeling off in sheets. I now have to replace all my boards. DO NOT USE THIS PRODUCT!
Frank
Frank
Horrible stuff. Looked great for about 7 months before it started bubbling and peeling. Spent many hours prepping to achieve a good adhesion, also used recommended prep products plus had the perfect weekend to apply product where deck was nice and dry. Now it’s taking me an awful long time scraping and sanding to get this crap product off my deck. I’m not one for telling folks what to do with their money but my experience with this deck over nonsense just like others have gone through causes me to talk folks out of using it, even when I’m at the Home Depot store and see folks observing/considering it. Most if it rose and scrapped off easy but some areas are very stubborn and require heavy sanding. Whenever it rained it trapped water under coated areas which eventually came loose. Do your research and ask lots of questions if you’re considering applying a coating to your deck or just keep it clean with a once a year wash is my best recommendation.
Patty
Patty
This is a picture of our big deck , not the pool deck
Patty
Patty
I also used this terrible terrible stuff on our deck and it looks like a ship wreck, we need to replace our deck, I also used it on our pool deck that is not rotting yet, was wondering what kind of sander to use ,we hadtried a orbital sander, a belt sander and a deck sander, with not much luck, we were thinking maybe a drum sander would work? What are your thoughts ?
Bobbie Rodrigues
Bobbie Rodrigues
Reply to  Patty
High pressure washer will be easiest.
Mic
Mic
So disappointed in this product! Bought this to put on new deck. Didn’t even last two years! Just peeled off in sheets! What a mess!! My deck is ruined and I’m in for a ton of work just sanding and painting now! You should be ashamed!!
Dana Davis
Dana Davis
Followed prep, application and post application instructions to a T. Difficult and exhausting to say the least. Deck Over peeling after 1 year and got far worse within a short time. Large, expensive deck now looks like the floorboards from the ship used for Gilligan’s Island. Deck Over and this whole process was exorbitantly expensive and was portrayed by Home Depot as a more than worth it miracle product.
I have lost all faith in Home Depot and will NEVER shop there again. I highly suggest all consumers to do the same.
Dana D.
Kathy
Kathy
Look
Kathy
Kathy
Your product destroyed my deck. Bought 10 gallons, cost a fortune, did not tint to the dark brown I wanted and now my deck is destroyed by peeling deckover. The deck will need sanded down completely and redone. Your product is a joke. Was gritty, and ugly and lasted only a year before it started to peel. Worst product ever.
Cynthia Thornton
Cynthia Thornton
We have had several coats in two different colors on our deck it is so hot you cannot get out of the swim pool without a pair of flip-flops. Wood rotted underneath. To replace the whole deck. It is so hot you cannot walk on it. Wasted a lot of money and a lot of time on this.
Lori
Lori
I bought this product, prepped according to instructions, and it looked great last August, September, and October. 8 months later after our Montana winter, most of the deck stain is bubbled and peeling off. I will need to redo the entire deck again this summer which I understand will not be easy according to other reviews. Terrible product and I will never by Behr again. Does anyone have any suggestions for deck stains in a northern climate?
Boomer
Boomer
Worst product ever. Spent $$$ on 10 gallons, now I will have to spend $$$$$$ on new floor. Started to peel by the foot after less than a year.
Sharon Balje
Sharon Balje
Please advise why small white particles from the deck are carried on foot into the house 0n wood floors causing crackling sound when walking on the inside floor? (There is a portion of the deck which has peeled.)
MToris
MToris
Worst paint product I’ve ever used. It has totally ruined my deck. Caused the wood to rot. Complained at the store and sales clerk said I applied it wrong, which is bullshit because I had a paint business. It has cost me more time and money to try to strip this stuff off and start over. I might be able to get one more year out of my deck which is only 7 years old.
Sue Ott
Sue Ott
I bought the Behr stripper, cleaner, and Deckover stain for my front porch. After carefully following” all” instructions it only lasted one year. Peeling in big pieces. Would not recommend any of these products! Will try a different Brand this summer. Same thing happened to a friend with a huge deck.
Nancy
Nancy
Reply to  Sue Ott
I used Behr cleaner and Deckover this past September and my whole deck is pelling off in big pieces also.This product is nothing but a big waste of time and money. I used 7 gallons, I will never buy Any Behr product again
William Crispin
William Crispin
How do you keep painted surface clean. We have tried using mops, rags to clean but found it left a horrendous trail of lint.
Brian Coble
Brian Coble
I put deckover on a 12ft ramp with 2 coats. Less than 1 yr on it started peeling off everywhere.And the wood started to rot. Ramp looks awful mow.The ramp was only about 2yrs old. We probably spent close to $1000 on ramp.Ramp needs to be replaced but lumber now is a lot higher..
1 5 6 7 8 9 11
822
