Deck Stain Brand Comparison 2026 4.1/5 (37)
Deck Stain Brands in 2026
We appreciate you visiting Deckstainhelp.com as we continue to be your go-to source for the latest in deck restoration news and trending topics through 2026. Feel free to leave a comment below with any pictures you may have.
Exterior wood and decks stains are all designed to protect and preserve your exterior wood from the elements. Decks stain brands differ though drastically in the ingredients, solids, etc. Deck stains also come in a variety of types: Transparent, Semi-Transparent, and Semi-Solids that will determine the opacity of the stain when applied to the wood
In this article, we will compare the deck stain brands that we have reviewed to give a better understanding of physical properties, application info, and any other useful data that can help you determine which stain to use.
Deck Stain Brands
Armstrong Clark Behr Premium Wood Stain Benjamin Moore Arbor Coat Cabot Australian Timber Oil Defy Extreme
Oil-Based Penetrating Stain Water Based Acrylic Filming Staining Water Based Acrylic Filming Staining Oil Based Penetrating Stain Water Based Penetrating Stain
Transparent, Semi-Transparent, Semi-Solid Semi-Transparent Semi-Solid Semi-Transparent Semi-Transparent
1-2 Coats 2 Coats 1 Coat Base, 1 Top Coat 1 Coat 1-2 Coats wet on wet
200-250 Sq. Feet Per Gallon 150-250 Sq. Feet Per Gallon 150-250 Sq. Feet Per Gallon 150-250 Sq. Feet Per Gallon 100-200 Sq. Feet Per Gallon
Paint Thinner Cleanup Water Cleanup Water Cleanup Paint Thinner Cleanup Water Cleanup
4-12 Hours Drying 4 Hours Drying 4 Hours Drying 4-24 Hours Drying 1-4 Hours Drying
Compliant All States Compliant All States Compliant All States Compliant All States Compliant All States
Defy Ultra  IPE Oil Flood CWF-Oil  Messmers  One Time
Water Based Penetrating Stain Oil-Based Penetrating Stain Oil-Based Penetrating Stain Oil-Based Penetrating Stain Oil-Based Penetrating Stain
Semi-Transparent Semi-Transparent Semi-Transparent Transparent and Semi-Transparent Semi-Transparent (100% Solids)
1-2 Coats wet on wet  1 Coat  2 Coats  1-2 Coats  1-2 Coats
100-200 Sq. Feet Per Gallon  250 Sq. Feet Per Gallon  150-250 Sq. Feet Per Gallon  150-250 Sq. Feet Per Gallon  300 Sq. Feet Per Gallon
Water Cleanup  Paint Thinner Cleanup  Paint Thinner Cleanup  Paint Thinner Cleanup  Paint Thinner Cleanup
1-4 Hours Drying  4-8 Hours Drying  4-24 Hours Drying  4-12 Hours Drying  12-72 Hours Drying
Penofin Ready Seal
SW Deckscapes
Sikkens SRD
SW Super Deck
Oil-Based Penetrating Stain Oil-Based Penetrating Stain Oil-Based Penetrating Stain and Water Based Filming Oil Based Penetrating Stain Oil-Based Penetrating Stain
Transparent and Semi-Transparent Transparent and Semi-Transparent Semi-Transparent Semi-Transparent Transparent and Semi-Transparent
1-2 Coats 2 Coats 1-2 Coats 1-2 Coats 1-2 Coats
200-250 Sq. Feet Per Gallon 75-150 Sq. Feet Per Gallon 150-250 Sq. Feet Per Gallon 150-250 Sq. Feet Per Gallon 150-300 Sq. Feet Per Gallon
Paint Thinner Cleanup Paint Thinner Cleanup Water Cleanup or Paint Thinner Paint Thinner Cleanup Paint Thinner Cleanup
4-24 Hours Drying 4-48 Hours Drying 4-24 Hours Drying 4-24 Hours Drying 4-48 Hours Drying
Rust-Oleum Deck Restore
Thompsons TWP Stains
Wolman Durastain
Water Based Acrylic Filming Staining Oil-Based Penetrating Stain Oil-Based Penetrating Stain Water Based Acrylic Filming Staining
Solid Stain Transparent Semi-Transparent Semi-Solid
2 Coats 1-2 Coats 1-2 Coats wet on wet 1-2 Coats
50-100 Sq. Feet Per Gallon 150-250 Sq. Feet Per Gallon 150-250 Sq. Feet Per Gallon 100-200 Sq. Feet Per Gallon
Water Cleanup Paint Thinner Cleanup Paint Thinner Cleanup Water Cleanup
4-12 Hours Drying 4 Hours Drying 4-24 Hours Drying 2-8 Hours Drying
Compliant All States Compliant All States *1500 Compliant All States –
*100 is compliant in only 33 States
176 Comments
2 months ago
TWP has worked pretty well, but I would consider alternatives that are considered comparable or better.
2 months ago
My Ipe deck was last stained with TWP 100 cedartone approx. 3 years ago. The stain has largely faded off and the wood has mostly silvered. I am interested in restaining to restore a warm color. What are best products for cleaning and re-sealing.
Karen
Karen
6 months ago
Why do you not mention PPG stains?
Peter Montanino
Peter Montanino
11 months ago
I have a 10 year old ipe deck that I generally clean and stain with Cabot Australian Timber Oil. Due to knee replacement surgery 3 years ago, I missed my 2-year cleaning. I used Penofin Cleaner but it looks like I need to do a second application as I can scrape crud off some of the boards with my fingernail. Is it okay to use Cabot wood brightener after the cleaning or should I stick with the Penofin brightener?
I will be using the Cabot product again for staining.
Peter
Peter Montanino
Peter Montanino
11 months ago
the first 2 pictures are before using Penofin cleaner, second 2 are after using cleaner. you can see the one board still has a lot of crud
before-1
before-2
after-first-cleaning-1
after-first-cleaning-2
Peter Montanino
Peter Montanino
11 months ago
Interesting, Ive never stripped the stain before. If I use the Penofin stripper, will I need to use the cleaner again or go straight to brightener?
Can these be done one after the other or do I need to wait a day?
Peter Montanino
Peter Montanino
11 months ago
Do you recommend applying a second coat of the Penofin Cleaner after using the stripper?
Peter Montanino
Peter Montanino
11 months ago
Follow up question, would you use Cabot Australian Timber Oil or Penofin Oil to finish my deck? Or do you have a better recommendation and if so, why? My deck gets about 3-4 hours of full sun in the afternoon.
Peter Montanino
Peter Montanino
11 months ago
Okay, thanks for the help, I’ll send finished pictures.
Peter Montanino
Peter Montanino
11 months ago
Interesting, in the past I’ve only used the Penofin cleaner and brightener never stripped the finish. Is there a reason I should strip the finish? If I use a stripper do I need to clean again or can I go straight to the brightener?
Recommended sealer/stain for soon to be install new cedar privacy fence w/either postmaster or powder coated steel, post’s in Chicagoland/O’hare area? Thanks.
Jerry
Jerry
I am building a new home that has douglas Fir Posts and Beams exterior. I am trying to determine the best penotrating oil stain to protect from elements of cold winters and hot sunny summers central Wa northwest area.
I’ve looked into
Ready Seal
Cabots Australian oil
Messmers UV plus
Help please 🙏
Thanks Jerry
mark kendrick
mark kendrick
How is arborcoat stain for pressure treated deck
Shelly
Shelly
We have used Rymar Extreme Weather Wood Sealer in past years, but the price is high. Do you know how it would compare to TWP? We’ve seen too many ruined decks when using a bad product that flakes or peels or just doesn’t last.
R in NorCal
R in NorCal
Related question – the redwood bars are installed over newly painted Hardie Board. Will oil or water based products applied to the redwood to protect from UV cause/activate anything to seep out and down discoloring the Hardie below? Thanks again.
R in NorCal
R in NorCal
Thank you Scott!
R in NorCal
R in NorCal
What is the best way to treat maybe 60 sq. feet of 1.5″ redwood kiln dried horizontal bars which are the infill of a rebuilt balcony. The bars are approx 2″ apart. There are four infills total. The redwood is straight from the lumber yard, and a few black tannin(?) lines are visible. Added color not necessary but would like to retain the redwood color and protect against UV but not have to strip anything off to retreat with whatever. Oil or water? Transparent or semi? Want to make the right choice as I understand once you pick a product, that’s what you will retreat with(?) Some rain and but lots of west facing sun. Top two choices, and then how and when would we retreat for protection with what. My head is exploding trying to sort all these options! Thanks. (Suggested to us: Messmer’s UV Plus, Cabot, Cutek, Penofin) Please include the specific Brands and types so I get it right.
R in NorCal
R in NorCal
In those brands you mention, what would be the most neutral/natural-looking for redwood tint I could use, but still get UV protection? And what level of tint do you recommend for these horizontal bars? (semi trans, etc..) Thanks.
Tom Rappette
Tom Rappette
having my cedar sliding painted/stained and one uses arborcoat and the other bid is woodscapes (sherman williams)
its a big job and I dont want to make a bad decision… it seems both products are average at best…. its it costly to move to a better product…
both painter say they will guarantee work for 3 years..
What stain is a best buy stain?
Kat Aponte
Kat Aponte
Reply to  Tom Rappette
Hi. We’re doing the same thing and i’d love to know what you ended up using and how it’s turned out? We’ve always used Sikkens (now PPG PROLUXE™ brand) but that has gotten so expensive (along w/ everything else) that I’m looking for an alternative that is as comparable (as possible) since I’m going to need about 20-25 gallons for the project. I’m scared to pick a product that will end up costing more in the longrun!! Thanks for your comments!
I have a new deck built in May 2022 with pressure treated pine and the boards were sanded and it get’s a lot of sun. Which stains are best suited. TWP Semi Solid, or Armstrong Clark ? Maybe something else ?
Thanks ! Is there a particular brand you would recommend that I use?
Barry Gore
Barry Gore
I’m having an outdoor kitchen built and using ruff cut beams and ruff cut boards to wrap with on interior. It has 4/12 and 10/10 columns. I want to keep the wood finish look and with a stain and poly on it, I feel like the weather and sun will have me redoing the stain and clear yearly. What type stain do you recommend that will last and keep the new look. Tongue and groove ceiling.
Can you add M1 Mildew treatment to TPW semi solid stain?
Moss
Moss
I have a 23 year old cedar home with redwood deck…exclusively Superdeck Valley 1906. What product is close in color…cant use valley anymore
Shauna
Shauna
We have the same issue. We’ve used Superdeck Transparent Valley 1906 for 15 years.
Moss – Did you find a color match?
Michael
Michael
What would you recommend is the best solid stain on the market? I’m looking for the highest quality solid stain, oil is preferred but let me know the best one. Price isn’t an issue
Shelley
Shelley
What is your experience/tested Rymar deck stain.
Karen
Karen
Contractor is recommending a product called SharkSkin for my cedar house siding staining. Never heard of this product? Any feedback on it?
176
