This post was updated on February 17, 2025
Here, I’ve created a hub of featured product information and many of my reviews of deck stains, cleaners, brighteners, and more. I’ve created three categories: Featured products, other deck stain reviews, and specialty products reviews. Be sure to check out my latest recommendations on the best stains.
Featured Products
TWP 100 Pro Series Wood Deck Stain
The stain is available in eight colors and works best on wood that is at least four months old (not new wood). It protects very well for two to three years without much discoloration and effectively prevents mold, mildew, and algae.
Restore-A-Deck Semi-Transparent Stain
Offered in five colors, this water-based stain protects very well against the elements for two years. Because it may be applied to damp wood, it’s a great time saver that allows for completing the prepping and staining process in one day.
Armstrong Clark Wood Deck Stain
A long-standing manufacturer, AC makes oil-based stains that are transparent, semi-transparent, and semi-solid. Its special formula uses non-drying oils to penetrate and renew the wood’s appearance and drying oils to form a protective surface barrier.
TWP Semi-Solid Pro-Series Stain
The stain is available in 30 colors and works best on wood that is a minimum of four months old. It protects very well against UV rays, and DIYers usually find it easy to apply (and reapply).
TWP 1500 Series Wood and Deck Stain
This oil-based, semi-transparent formula is available in 10 shades and contains an EPA-approved wood preservative, making it allowable in all 50 states. It effectively prevents graying, wearing, and peeling for over two years.
TWP Natural Effect Impregnating Stain
This is among the best penetrating water-based stains and delivers multi-year protection. It may be applied when the prepped wood is visibly dry, making it a time saver.
Other Stains We Review
Oil-Based Deck Stain Product Reviews
- TWP 100 Pro Series
- TWP 1500
- TWP Semi-Solid Pro-Series
- Ready Seal
- Cabot Australian Timber Oil
- Sikkens/PPG Pro Luxe
Water-Based Deck Stain Product Reviews
Water-based stains offer benefits such as being fast drying, eco-friendly, and easy to clean with soap and water. The following are my reviews.
- Defy Extreme
- TWP Natural Effect Impregnating Stain
- Restore-A-Deck Wood Stain
- Behr Wood Stains
- Valspar Stains
- Pittsburgh Stains
- PPG Timeless
- Sherwin Williams Deck Stains
- Benjamin Moore
- Thompsons Deck Stains and Sealers
- Olympic Wood Stains
- Flood Wood Stains
- Cabot Stains
Semi-Transparent Deck Stain Product Reviews
Semi-Solid Deck Stain Product Reviews
Semi-solid stains have properties that provide numerous benefits, such as allowing some visibility of the natural wood grain and offering very good UV protection. Oil-based semi-solids usually penetrate better than water-based options. Some recent reviews include:
Solid Color Stain Product Reviews
Solid or opaque deck stains have “paint-like” characteristics, making them perfect for older decks with imperfections to hide, decks exposed to constant sunlight, and for coating railings and vertical surfaces. See the following reviews:
Hardwood Deck Stain Product Reviews
Hardwoods such as teak or oak are very dense, so most stains won’t deeply penetrate them. That’s why I evaluate them after one year rather than two.
- Armstrong Clark Hardwood Stain
- TWP Natural Effect Impregnating Hardwood Stain
IPE and Hardwood Stain Product Reviews
Ipe and other “exotic” hardwoods have premium prices but are extremely durable and eye-catching when regularly stained. I recommend cleaning and recoating every 6-12 months with a specialty stain. Be sure to also read my article on the best stains for IPE hardwood.
- Restore-A-Deck Wood Stain for Exotic Hardwoods
- Messmers UV Plus for Hardwoods Stain
Specialty Product Reviews
Deck Cleaner Product Reviews
- Restore-A-Deck Cleaner and Brightener Kit
- Restore-A-Deck Cleaner System
- RAD Guard Mildew Cleaner & Preventer
- Gemini Restore-A-Deck Kit
- Defy Wood Deck Cleaner
- 30 Seconds Outdoor Deck Cleaner
- BEHR Premium 2-In-1 Deck Cleaner
- Messmers Wood Deck Cleaner
- Wolman™ DeckBrite™ Wood Cleaner
Deck Resurface Stain Product Reviews
Thanks to their “paint-like” consistency, wood resurfacing products help minimize cracks and wear found on older or poorly maintained decks. I find these to be a very short-term fix (one year max) and often encourage replacing damaged boards instead.
- Gulf Synthetics Deck Revive
- Behr (Advanced) Deckover
- Rust-Oleum Deck Restore (Rock Solid)
- Synta (Rust-Oleum Rock Solid) Deck Restore Stain
Deck Brightener Product Reviews
I recommend applying a deck brightener (neutralizer) after cleaning to expand the wood’s pores and enable better stain penetration.
Deck Stain Stripper Product Reviews
Applying a good-quality stripper is sometimes needed to remove stubborn stains, paint, or other coatings.
- RAD PaintStrip Paint & Solid Stain Stripping Gel
- Restore-A-Deck Deck Stain Stripper
- Restore-A-Deck Stain Stripper Booster & Thickening Gel
- Behr Premium Stain and Finisher Stripper
- HD80 Deck Stripper
I have some gaps between the board ends. My deck is three years old and I will be staining for the first time this year with TWP 1500 series after all of the prep work has been completed. Please help me find the best product to fill the gaps. The largest gap is about 1/4 inch. Thank you!
No filler will work here. It is not a big deal, just leave it as is.
can you use water base over oil base? 1m staining a 140 ft fence in florida, lotsa hot humid weather. I have stained a fence in wisconsin with cabot oil over 2years ago and it still looks like new, all kinds of weather up there, 20 d 80 in summer plus ice, snow, sleet & every thing in between. hope this sheds some light to first time stainers, thanks for your input also. T0mmyboy
No, and no matter what, you need to remove the prior coating fully if switching brands of exterior wood stains, unless it is a solid color stain.
Hello Mr. Paul, I have a couple of questions. I’m not sure if this is where I can ask. I do apologize if I’m in the wrong place to post questions.
This is my first time staining my fence and my first time on your site, which by the way is so informative.
My predicament is the types of staining for my fence. I have non-treated unfinished beaded/smooth brown pine wood boards. I have researched the types of staining and not sure which one to use.
Question #1:
Should I use oil based stain or water based stain for my brown pine wood?
Question #2:
Should I use semi-transparent or semi-solid stain for my brown pine wood?
Thank you for your help!
Monica P.
Use a penetrating semi-transparent stain: https://www.deckstainhelp.com/best-semi-transparent-deck-stain-reviews/
It does not matter the base as long as it fully penetrates the wood. Make sure to prep the wood properly. If the wood is new, it needs to weather for 3-4 months before prep and stain.
Good Afternoon Mr. Paul,
Thank you so much for replying to my post as well as sending me your site information about my topic questions.
I did forget to mention that I live in Southwest Florida. I did a ton of research on staining for my new brown pine wood. I have read a lot on your site as well and it did help a lot with my other questions I did have.
I have read so much about using oil based and water based stains. The different sites are conflicting on using water or oil based stains. One site said oil based stains are much better on pine wood and then another site said that water based stains are better for pine wood. I do know what they both provide to pine wood, but I want an expert to help me decide.
I have had to replace a lot of my pine wood on my fence because many areas were moldy and rotted even with the stain on it. There were areas that my previous fence installers did not stain, which were under my pine wood boards that are vertical that go over where the wood connects to hide the board connections and screws. However, I’m not sure what kind of stain they used (oil or water base).
I want a penetrating stain that is best for mold, rot, moisture, etc. and will last a long time. Even though I do know what the oil and water based stains provide to the fence, I still do not know which one to pick.
Can you please let me know what you would use if it were your fence?
I will definitely use the semi-transparent stain. Thank you for that recommendation.
In addition, on your site I have read all of the different companies that make the stains and I see what the best ones are. However, I will need to buy about 25 five gallon cans of stain so I’m looking for an affordable stain that will do the job well. Do you have any recommendations on what affordable stains that I could use for my brown pine wood?
I do want to say that I love your website. It’s so informative!
Thank you so much for your help!
Monica Piccirillo
Look at Restore-A-Deck semi-transparent stains if you want to go water-based, which has less chance of attracting mold or mildew compared to oil-based stains.
