Defy Extreme Stain Review for 2026 4.1/5 (57)
Defy Extreme Wood and Deck Stain Review
✅ Defy Extreme Stain Review (Quick Verdict)
Defy Extreme is a high-quality water-based deck stain that offers excellent UV resistance and color retention. While it requires proper prep and careful application, it performs well for those wanting a durable, eco-friendly alternative to oil-based stains.
✅ Defy Extreme Stain – Key Takeaways
  • Type: Water-based / acrylic penetrating stain
  • Durability: Above average with proper prep
  • UV Protection: Excellent (zinc nano technology)
  • Ease of Application: Moderate (less forgiving than oil)
  • Maintenance: Moderate—requires proper prep for recoats
7.5 Rating Defy Extreme Wood Stain
Defy Extreme Stain was introduced in 2008 as the newest member of the Defy Stain family. Defy Extreme Deck Stain is a penetrating water-based stain that does not film on the wood. Defy Extreme contains synthetic epoxy resins that “harden” the wood pores below the surface.
Utilizing nano-technology, Defy Extreme is one of the best stains on the market when it comes to preventing UV graying.
✅ What Type of Stain Is Defy Extreme?
Defy Extreme is a water-based semi-transparent wood stain that uses synthetic resins combined with zinc nano-particles for enhanced UV protection. Unlike traditional oil-based stains, it relies more on surface bonding while still offering some penetration into the wood.
Defy Extreme Deck Stain Ratings (1-10)
– Defy Extreme Stain had a rich look to the wood. Natural grain was highlighted evenly throughout. The Defy Extreme did not mask the grain like other water-based wood stains. The penetration of the stain into the wood was excellent. The Cedartone color was slightly on the “orange” side but acceptable for a cedar deck stain color.
– One of the best in the industry. Testing over a 2 year period showed little to no color fade. The zinc oxide nanoparticles seemed to help drastically with the UltraViolet radiation that turns the wood gray.
Wear/Tear and Peeling: 8
– Better than average wear and tear. High traffic areas show some wearing but overall tested
extremely well. No noticeable peeling.
Cost Per Square Foot: 7
– Defy Extreme costs about $55 per gallon. For two coats we got about 100 square feet per gallon. We used 8 gallons for the 750 square foot deck translating to a per square foot price of $.55 a foot.
– Defy Extreme Stain is a water-based stain that does not promote mold growth in the stain. A very small amount of algae was noticeable but was only in a shaded area and was on top of the stain. More of an issue with the decks’ location, not the stain itself.
Ease of Application: 7.5
– Fairly easy to apply. One issue we noticed was that it can dry very fast when in direct sunlight and on a hot day. Easy cleanup with water.
Color Shifting (darkening) after 2 Years: 9
– Stain changed very little in color after the 2 year period. No noticeable darkening.
– No noticeable darkening, deep penetration, and little wearing make the Defy Extreme Stain an easy product to reapply when needed. Mild wood cleaning with the Defy Wood Cleaner and Defy Wood Brightener is what you would need to use to prep.
– Defy Extreme is an excellent product and easily outperforms the majority of stains on the market. When it comes to water-based “Eco-Friendly” stains, Defy Extreme is our top choice. Defy Extreme performed in the top three of all stains tested when it comes to preventing UV graying on a horizontal surface. On vertical surfaces such as railings, the Extreme had no color change.
✅ Real-World Performance
In real-world use, Defy Extreme performs well in terms of color retention and UV resistance. However, like most water-based stains, it can be less forgiving during application and may require more thorough prep to ensure even absorption and long-term performance.
$59.99
$269.99
Help or Questions? Defy Extreme Stain
Cost: $55 per Gallon, $269 per 5 Gallon Pail
Available Colors: Cedartone, Natural Pine, Light Walnut, Clear, Redwood, Butternut, Driftwood Gray
Coats  Required: 2 Coats. “Wet on Wet”
Dry Time: 2-4 Hours
Cleanup: Water
Manufacturer: Saver Systems
Cedartone
Defy Wood Stain Photos
✅ Defy Extreme vs Oil-Based Deck Stains
  • Defy Extreme (Water-Based):
    • Better UV color retention
    • Faster drying
    • Lower VOC
  • Oil-Based Stains:
    • Deeper penetration
    • More forgiving application
✅ When Defy Extreme Works Best
  • Decks in full sun exposure
  • Users wanting long-lasting color retention
  • Environmentally conscious homeowners
❌ When to Avoid Defy Extreme
  • Poorly prepped wood surfaces
  • Users wanting the easiest maintenance option
  • Older decks with heavy wear
FAQs – Defy Extreme Wood Stain
How long does Defy Extreme last?
Typically 2–3 years depending on exposure and prep.
Is Defy Extreme better than oil-based stains?
It offers better UV resistance but may require more careful application and prep.
Does Defy Extreme peel?
It is less likely to peel than solid stains, but improper prep can lead to adhesion issues.
Is Defy Extreme easy to apply?
Moderate—requires attention to avoid lap marks.
799 Comments
Bill Ellis
Bill Ellis
Texas Gulf Coast Dock Application Review.
I have a 2 1/2 year old pressure treated pine dock on the Texas gulf coast that needed a sealer preservative application. I had applied Thompson’s after initially allowing the wood to dry for a few months, but the sealer had lost its effectiveness after only 9 months or so. I researched diligently and chose Defy.
I followed the instructions strictly, using first their wood cleaner, then Brightener, then a week later applying the stain. (I had already pressure washed the deck boards before beginning.)
I am highly impressed by the products thus far. The cleaner was very effective and easy to use. The Brightener was a really easy step that I was curious about, but I did it and I’m glad I did. The Brightener makes a huge difference in opening up the wood pores to receive the stain/sealer.
I then applied the Extreme stain/sealer in Natural Pine color. I sprayed it on with a deck pressure tank sprayer followed immediately by brushing in with a car wash type brush (Unger) and followed with a second wet on wet coat, same steps, within 15 minutes or so, again following the instructions as strictly as I could. I was careful not to over-apply. (The deck is about 500 square feet, but I only used about 3 1/2 gallons.)
I am super happy with the whole process and appearance on completion. It looks fantastic. Really first rate. Let’s see how the next two years of wear and tear go.
Bill in Rockport.
Tania Stockless
Tania Stockless
Reply to  Bill Ellis
Hey Bill, how did this hold up for you? I’m in Florida and looking to do the same on large deck – blazing sun, humidity and subsequent mildew here is probably similar to Texas conditions. I love the natural pine color but have been wondering if I should consider going darker for the additional UV protection. Thanks! 🙂
william l duckworth
william l duckworth
how well will this deck stain work in south central Illinois
StephanieT
StephanieT
Used Cabot Australian Oil Natural on cedar deck—it’s been on for about 10 months. Pleased at first but now water seems to be penetrating/soaking into wood, not beading. Also, mold is a problem here in Northern Virginia. Plan is to clean and brighten deck and reapply Australian Oil—but I’d have to repeat process yearly.
I love the natural look of the cedar (and natural tone of Australian oil). I don’t want an orange toned cedar deck.
—What type of stain would you recommend that could give me a longer time in between re-finishing?
—What color stain would you recommend to approximate the natural look of cedar (not orange)?
—What about a stain stripper and process for any small areas on the cedar deck that might still have Australian oil?
StephanieT
StephanieT
Russ Werner
Russ Werner
I have a 15 y/o IPE deck. Which has been treated by the same “Professional ” for 15 yrs. He was using Penofin. Last yr, he stripped and I think cleaned the deck, then applied Penofin after. He did it when it was sunny and 92º , the deck was hot… He applied 2 coats and not wiping down after either of the coats. Needless to say we had problems. it was sticky in spots…the deck chairs would show scratching marks, when moved. He “didn’t know why” !!! He reapplied after cleaning deck again about a month or so after. No change.. He said he though problem was the Penofins and he would contact the Co. But alas, we have not heard from him this yr. SO I AM gonna strip and brighten the deck with the RAD products.  Which stain is recommended ? I have seen there have been problems with the Penofin stain with IPE decks, even tho we liked the colors brought out on our deck. Wanting to keep this colors coming thru, which stain, is water based better than oil?? Im thinking Oil based stain. Any help would be so very appreciated… Thanks
Russ Werner
Russ Werner
Thanks for the reply ! ! ! I guess now it’s which color would I use , respectively for each brand? the Penofin he used had some tint to it, but when it was done right and even in the beginning, it had some nice browns and reds to the IPE wood. Thats what we’re hoping for..I am trying to figure which one of these 2 brands should I use. Im thinking oil base but am open to water base… Ugh!!! Decisions, decisions ! ! ! Any more input, especially anyone use these on IPE decks?? thanks for any help
L Conrad
L Conrad
Does this work well on Cedar Play sets?
Cheryl Toomey
Cheryl Toomey
I am replacing the top of my deck and benches with Trex. The supports for the benches need to be wood so I am using my existing pressure treated supports. What grit sandpaper should I use to strip it before applying defy extreme stain. I’ve seen you recommend a courser grit but what exactly do you consider courser. Thanks.
Meredith
Meredith
My deck was made with Goodfellow Terra Wood, and I like the reddish undertones but have been burned before by “Redwood” coloured stains that look very red and very fake. (Olympic brand, specifically. I stopped, stripped and switched to “Brick Red” after a few boards because I knew I would hate it.) I have a second, much larger deck to contend with this year. Does the Defy Extreme redwood colour look natural, or should I stick to a cedar tone? I have to order it sight unseen.
Meredith Hang
Meredith Hang
Unfortunately, I have to sand some parts, so lighter will not work. I wish there were more colour options for your top rated water based stains. Thank you for your help!
Meredith Hang
Meredith Hang
The wood in question is currently unstained. Its colour comes from the treatment process and standard deck cleaner does not remove it. I don’t know if brightner would work? The railing really needs sanding because it is rough. I am not willing to sand the whole thing because it is a tiered deck that is encosed on the sides. But the reddish base colour will show through a light semi-transparent where left. I might give up on the water based because your top oil based have better colour options. I really want ease of maintenance, because I am going to have to strip my front deck due to the stain flaking from subpar water-based stain (and full sun application, which I now know not to do.) Glad I did the smaller front deck first…
Meredith Hang
Meredith Hang
It has faded a bit, but still very red toned.
Bill
Bill
Which color of DEFY Extreme Semi-Transparent stainwould best match brown Sienna MicroPro pressure-treated lumber?
Julie
Julie
Just to be sure, Defy Extreme clear will allow my cedar decking to turn grey, but Defy Extreme semi transparent stain will not? Thanks.
Nancy Bauman
Nancy Bauman
We had new floor and top rails put on our 2 decks. Husband power washed rails. There is a lot of color variation. Thinking of using defy, would like it light colored. What is the best way to make it look more uniform? We are both in our 70s. Appreciate advice on the best and easiest way to do this. Thanks. Don’t know how to add pictures, know how with text.
Nancy Bauman
Nancy Bauman
Do you have any ideas on what to do with this situation?
Valerie Keith
Valerie Keith
We stained our new deck (weathered for about a year) with Defy Extreme back in 2017. It really needed a maintenance coat last year but we didn’t get it done. This is what it looks like now. Can we just wash it and brighten it and do a maintenance coat or do we need to do something different?
Mark Huntley
Mark Huntley
What’s your preference, RAD or Defy Extreme? Had lots of darkening and mold problems with Armstrong, so thinking of trying something else. Pacific northwest so lots of rain and winter shade. Looking for durability, ease of application and ease of re-coating a couple years down the road.
Ben
Ben
Hi, I am about to stain my new cedar fence with defy semi-transparent stain. I called defy customer service and they advised me to do 2 coats – wet on wet. I am confused on what to do as you guys recommend only one coat for new wood. Thanks for your help!
Verne Johnson
Verne Johnson
I used Defy’s natural pine a year ago on my deck railing and side deck wall, using wet on wet application. I did not do the floor boards at that time so I’m cleaning and brightening those boards before staining this spring. If I decided to restrain the railing again too, do I just clean and brighten that again too, before restraining?
thanks, Verne
Robert Harris
Robert Harris
Not sure if my question got posted…….sorry for the repeat if it was.
Just stained deck with Defy Extreme semi-transparent cedar stain. Lower “apron” looked dirty and cleaned with a deck cleaner (not just soap and water). Now the white “foam” won’t go away. What do I do?
R. Harris
R. Harris
Used defy extreme cedar color. Top is fine, but side lower apron looked like it needed cleaning. Used deck cleaner (Valspar) and now white foaming on surface won’t wash away. What do I do?
Phil
Phil
Five year old pressure treated pine deck, mostly shade, very little traffic, one to six feet off the ground with a moisture barrier……..original, first stain Cabot; it peeled. RAD’d with both stripper and lightener and stained with TWP one coat…….it blotched, streaked black, and just generally didn’t look good. RAD’d with cleaner and brightener and re-stained with TWP two coats, wet-on-wet. Got same results as the first time. I again cleaned/brightened and applied wet-on-wet. Same results with some mildew build up [we’ve had a terribly humid, wet summer]. Applied wet & forget after checking with TWPstain who advised it would not hurt surface. Mildew returned immediately.
I just completed a RAD stripper application this week. It stripped maybe 85% but there is no 100% strip anywhere but on the rails.
Is a second stripper application recommended before brightening? Should it strip the remainder? Must it be stripped 100% if I choose to use a darker color?
Does it make sense to try another stain like Defy which is water based rather than oil based and has a mildew resistance and is tolerant of moist conditions?
Picture prior to my last strip job.
Thanks for your advice……this deck is large 44 X 12 and it’s proving to be a real monster.
Denise
Denise
We have a 45 year old cypress deck that’s still in pretty good shape. We’ve replace a few boards, also with cypress. It was treated yearly with Cuprinol for about 25 years so it was a pretty weathered gray. It was neglected for about 5 years, then it was stained brown. That has finally faded and we’ve begun to clean and brighten it. Some boards have been replaced. My hope would be to get it back to a natural weathered gray appearance, but I realize that a lot of time has passed and the wood has been neglected. Would Defy clear or driftwood gray be a good choice? Another option would be to match the deck to the house (which is cedar siding with Cabot Seacoast Gray solid stain), but that would obscure the wood grain and be too matchy-matchy. I don’t want to go brown again. The wood doesn’t have to look perfect. I’m really stumped. The photo shows old boards next to a couple of the new ones. Thanks for any advice!
Diana
Diana
Are there any real life example photos of the “Butternut” color? Trying to decide between this and Light Walnut. I don’t want any orange/red undertones. Thanks!
Diana
Diana
Thanks so much!
Kay hoskins
Kay hoskins
Can this be used on composite decking. I have old Trex decking.
Terry McClintic
Terry McClintic
My home has rough cedar siding that has previously been stained with Cabot Clear Solution, Cedar tint (water based). Since this product is no longer made, I’m trying to find an alternative. I have cleaned my siding, and most of the old stain is removed (but not all). Would Defy Extreme be a good stain to consider for my siding now?
Larry
Larry
This is a very high quality product. I used the solid color stain on 3 separate 35 year old decks at my home. It is well worth the slightly higher price of some other popular brands. It goes on easy with a brush or roller.
Alan Brown
Alan Brown
Hi I live in Kokomo Indiana. Which is an hour north of Indianapolis. I have cleaned the deck and it is not ready for stain. In the past I have used CWF clear, but I wanted to see if there is a better product out there. I’m ready to stain and need some opinions. Is there any concern of going over the CWF with a new stain if it has been cleaned and power washed?
Could you emphasize what “2 coats, wet on wet” means exactly? Thank you!
Andra Frei
Andra Frei
Where can I buy this stain? I’m in the Athens he area.
Susan Siler
Susan Siler
We have heat treated deck on fishing pier and on front and back decks on house. What product should I use to avoid orange or yellowing. The fishing pier is 2 years old and the house decks 6 months to a year old. What pre-treatment is recommended? Also, does sealant help protect the nailheads?
Susan Siler
Susan Siler
Henrieta Riccobono
Henrieta Riccobono
I have a 6 year old cedar deck that was stopped of previous stain which was peeling away year after year. We finally sanded the deck and it’s now prepped for a new application. I’d like to retain the natural color. My brother in Europe recommends just using a natural oil on the deck and stay away from stains. I’m thinking about using DEFY wood oil for decks. Anyone has any experience with that? Will it blacken over time? Peel away? I’m ok with inconsistency in colors as natural wood is but I don’t want to see it peel away.
Nancy
Nancy
We chose Defy clear on our 1 yr old Cedar deck. Love the ease that it went on but feel I want a little color since it is very clear. Can I put a coat of driftwood over the clear?
Dave Dunn
Dave Dunn
We have 22 year old deck. Wood is in good shape. It has been retained 3 times. Areas of the deck horizontal surface have started to peel. I stripped, sanded and scraped the deck. this resulted in much but not all of the existing stain coming off the deck. I am looking for the best advice short of stripping all of existing stain to re-stain the deck. How or do I need to treat the deck after stripping and power washing with water. Should I simply reapply what is already on the deck or is there another stain that has a better adhesion capability? thx
twbjerstedt
twbjerstedt
Does Defy Extreme Stain work well on a pressure treated Yellawood fence.
Beth Britton
Beth Britton
Partial sun AM, Full sun afternoon
Pressure treated wood
No mold or mildew issues
Deck is 4 years old-used Thompson’s water sealer stain year 2-didn’t take, peeled, wore away in high traffic areas. Year 3-current stain is Cabot Gold stain. Same issues-wore away, peeling.
The pictures are after power washing it. We would prefer not to sand it. I’ve read your best of 2020 article and am leaning towards the Defy or restore a deck product lines. If we use the stripper product do we have to use their cleaning product first? The power washer didn’t work to get the stain off of the spindles, what would you recommend? Lastly, what’s the best way to apply? I used a power sprayer and brush last time.
Beth Britton
Beth Britton
I’m having trouble adding pictures, it’s says maximum file size is 4MB
Beth Britton
Beth Britton
Here they are…
Beth Britton
Beth Britton
Thank you. Which product would you recommend for the stain?
Beth Britton
Beth Britton
When you said it’s excessively thick, did you mean on the spindles or the floor boards?
Tim
Tim
HORRIBLE DURABILITY!
I purchased Defy wood stain 4 years ago to stain my new deck. I waited 6 months to let the pressure treated pine dry, then cleaned and brightened with Defy brand cleaner and brightener. ALL of the horizontal surfaces on my deck were fading, and peeling within 3 months. I had to reapply the following spring less than one year from the first staining. The second, which I carefully pressure washed, again using Defy brand cleaner and brightener and stain did not last through the summer before deteriorating. I am now preparing for my 4th application of stain in 4 years. the only reason I am still using Defy is because I originally over bought and restocking and return fees were too high, so I decided to keep it for when it was time to re stain, not expecting at the time the horrible performance i have experienced. Since I am stubborn when it comes to wasting money, I have been using it until it’s depleted. I will not use it again. I will however state that all of the vertical surfaces have held up well, especially those that receive the most amount of shade during the day, but that would be the case with any cheap-o stain. Where I was expecting the longevity, and durability of this stain is where it failed most, on the horizontal surfaces that get the most daylight. I have been grossly, and repeatedly disappointed.
Beth
Beth
We recently stained our deck with Defy Extreme Stain in the natural pine. I realize now that as much as I like the product, I made a mistake with the color. What would I have to do to remove the stain before applying the color I should have used (driftwood gray).
Beth
Beth
What is the best product for stripping and the best product for brightening? Will doing that completely remove the current color?
Beth
Beth
P.S. Our deck was installed last fall so the wood is new wood.
Beth
Beth
Okay, putting both of my questions in one reply. The deck we stained was a new deck with new wood. What is the best productto use to remove the Extreme defy natural pine and the best product to brighten the deck before restaining with driftwood gray?
Beth
Beth
Thank you so much. One final question…When we redo the railing would it be better to use the semi-transparent stain or the solid color stain? We are keeping the flooring the semi-transparent.
Igor
Igor
Installed a large swing set (cedar). Exploring using clear (Defy Extreme Clear) vs semi-transparent.
Clear is preferable as I like current swing set colors. But also would like to minimize how often I need to re-apply.
In real life how dose Extreme Clear compare to the their semi-transparent stains?
Can I get away with re-applying Extreme Clear every 2 or 3 years?
Mary Davis
Mary Davis
Our deck surface was replaced with TREX “Tiki Torch”. Is there a specific color that will be a good match when we stain the posts and rails? Because the deck has old and new wood, we plan to use the solid stain.
James Murphy
James Murphy
We used this on a new doug fir outdoor shower enclosure, fence and pergola late summer 2017. Strictly following the instructions we are very happy. The manufacturer was very responsive to our questions and after 2 1/2 years and 3 New England winters we see no peeling and a little fading. This exceeded our expectation! We used the cleaner and brightener as directed and they were easy to use. We found the stain to be a little difficult to install. You have to work very quickly even in temperatures in the 70s. You also have to make sure that you cover the area you are working on in one session otherwise it leaves hard lines. We went through three different contractors before found someone capable of installing this.
Jerry Parker
Jerry Parker
I am a little confused by your rating and comments of this product as compared to the Restore A Deck Wood Stain review. In the comments you state that Defy Extreme Stain is the best water based stain on the market and is your go to brand. However when you rate it is slightly lower than the RAD stain. So how and why is this your favorite, especially since the RAD stain has a lower cost factor than the DES?
Angel
Angel
Can use water based Defy on a lower deck that’s very low , very close to the ground and in shade . It is under the upper deck . Does Defy come in oil based stain ? Would it be better oil one? We live in MA . Cold , many wet days, long winters .
Angel
Angel
Thank you for your answer. Do I need 2 coats on this lower deck if I get Defy ? Probably darker color better. Butternut instead of Redwood that I have on the upper deck ?!?
Angel
Angel
I see people saying that second coat has to be applied wet on wet within 15 min.
1. My deck is large , 27×11 . Should I do it in sections ? How else should I do it without stepping on the area that I just painted ?
2. Do I need to wipe with a rag ? Two years ago I used a roll but the stain didn’t penetrate very deep. I sanded and washed the dust with plain water , no cleaner or brightener.
3. After washing the deck how long to wait until I apply stain ? We have sunny days for next week.
duncan crerar
duncan crerar
I am wrapping 21 porch posts (12 x 12 x 10) with western red cedar. I want to darken the cedar since it is almost the color of pine. What would you recommend?
Mike Fisher
Mike Fisher
Indiana, Fort Wayne – Deck gets 80% full sun, 5yrs old pressure treated pine. I pressure washed the deck and removed current stain. Then applied one coat of the semi transparent light chestnut stain with a brush / roller method. The stain dries up quickly when applying it in full sun conditions. However, the results turned out good. I wanted a stain that was human/pet friendly to use since we have a couple of dogs. This did the trick! I hope it will last us two years before needing to apply the next coat. – Mike
Best Deck Stain for Pressure Treated Lumber
Diana
Diana
Reply to  Mike Fisher
Is this the “light walnut” color?
Reply to  Diana
Yes, this is light walnut. It lasted two years. I recently applied the stain this year. However, instead of using a roller, I used a Woodmates Stain Applicator. Much easier applying the stain and took me about 3 hours to do our 20×20 size deck.
Bruce
Bruce
Has anyone used these products on a black locust deck? Black locust is extremely hard, requiring predrilled holes for deck screws. Which product Defy Extreme vs. Defy Hardwood, would folks recommend? Also, is powerwashing recommended, as well as use of the Defy deck cleaner as prep? My deck is about 10 years old with no surface coatings ever applied. Thanks.
Bruce
Bruce
Reply to  Bruce
Gerry
Gerry
Do you have to put on 2 coats? If so, how long between coats? Thank you!
Gerry
Gerry
This is a new deck that was built in the fall, with nothing done to it yet. Should there still be 2 coats?
Tina Liehmann
Tina Liehmann
I have a year old Eastern cedar deck that I stained with Benjamin Moore Arbourcoat Translucent natural after it had weathered 6 months (the second deck for 1 month only). I realize from my research now that I should not have relied on the advice of the paint store personnel with respect to deck prep (none) and product. Much of the stain has worn off the horizontal surfaces and is peeling in a major way. There are also a lot of greying and black mold spots.
I will be stripping the deck and then cleaning and brightening it before applying any stain.
I live in Northern Ontario on waterfront property so the conditions include high humidity in the summers and a lot of freezing and thawing in the winter months. Most of the deck is in full sun with no shade. I prefer the look of translucent stain or clear stain but realize from reading up on it now that this will wear too quickly, so I am prepared to use a semi-translucent stain.
I am thinking about Restore A Deck, Defy, TWP 200, Armstrong (staining in the sun). I had planned to use an oil based product because I thought it was better, Am I correct in thinking the water based stains are newer formulations – which makes me wonder if there is enough info yet on how they stand up over time?
What would you recommend for this deck and can you please indicate under which conditions to apply (wet, dry etc.)
Thank you for your help.
Tina Liehmann
Tina Liehmann
pete
pete
Defy semi-transparent better than clear for sun protection? Sun protection with clear stain still unattainable?
On a new deck of pressure treated pine (after appropriate weathering period) I applied Defy cleaner, brightener, and clear stain, following the directions closely. One year later there was obvious greying and discoloration from sun. (This deck gets full sun all day.)
One year later I did it all again, although it was looking like the clear wasn’t protecting from sun. The cleaner and brightener did a decent job; although the deck was still discolored, it was brighter and did look better. I applied the clear stain again. Six months later, the deck looks pretty lousy, grey, discolored, etc.
I called Defy and in a moment of candidness, I think, the very helpful customer service guy seemed to suggest the clear wouldn’t really protect from sun. Ironically his does make me trust Defy a little, although the ads promised great sun protection for a clear stain (nano particles and all). I may call them and ask what stain they suggest for sun protection, see what they say, as due to the good reviews I am willing to try another Defy stain.
1) Does anyone else have observations on the sun performance of clear Defy?
2) Is it foolish to expect sun protection from any clear stain?
3) How about their semi-transparent stains? I am inclined to go as light as possible.
4) Does how light the semi-transparent stain is affect sun protection?
Thanks in advance.
Pete
Pete
Thanks! Called Defy earlier. They are very upfront that pigment lasts longer. Still communicating with them, but let’s just say that so far customer service is phenomenal!
Clueless in PA
Clueless in PA
Question/Review: What should I do now?
Almost two years ago we moved into a house with a deck needing some TLC.
What we did: Scrubbed off lots of mold/mildew/algae, sanded off old stain etc, applied Defy Extreme Semi-Transparent. We were pretty happy with how it turned out.
Now: It’s been a year and a half. Obviously there’s been some wear. There is also some significant mold/mildew/algae growth, but, much less than when we moved in. It is on the shaded parts and we do get a lot of moisture, so anything less than a bleach forcefield wouldn’t keep that green sheen at bay forever.
Also, rain doesn’t bead up anymore. not on any part of the deck any more. So, this means it’s ready to recoat right?
What do I do?
Defy Safe Oxygenated Bleach Wood Cleaner, then rinse, then Defy Wood Brightener (same day), then rinse, then let dry for (some days)? Then apply Defy stain (same stain as before)? Is that right?
How long should the deck dry (after brightening) before applying stain?
If rain happens between brightening and staining, do I have to start over with cleaning/brightening, or can I still just wait and stain when it finally dries out? The pH talk kind of confused me, and my current forecast includes rain for 10 of the next 10 days, so, I’m gonna need to know what to do if it rains. (Yes I am waiting for a better stretch of weather than 10 days of rain before I start this project. But still want to know, because rain happens here).
How long does the stain need to dry after applying, in terms of weather– how soon can it safely rain after applying the stain without it affecting the job?
Norman Douglas
Norman Douglas
I know this is a deck forum but I have a question about solid stain. I built an 800 foot fence, pressure treated pine, and was wondering what you would recommend for a solid stain. From what I’ve read, the Defy product looks pretty promising but would like your advice. Would you have any idea how much stain I would need as well?
Ellen Obermiller
Ellen Obermiller
Definitely appreciate your information but am hesitant to get started on our deck because of a tree incident. We live in the Midwest and our deck is made with treated lumber. It is 2 years old and was initially treated with Thompson water seal a year ago. Useless stuff. This past January a tree fell on our house taking out part of our house and part of our deck. We are finally back in our house and now are ready to work on the deck. One side of our deck was replaced with new lumber—spindles, top rail and two horizontal floor planks. We have a combo of color on the deck. Most of it has worn naturally and has a light grey color. I have cleaned the deck and would like to give a fresh and uniform look while using a semi transparent stain. Would really appreciate any and all advice.
Mike Hahn
Mike Hahn
Can this product be used on a 14 yo TREX deck? Fading and mold/mildew are main problem currently.
Todd West
Todd West
Defy Semi Transparent wood stain should NOT be used on Cedar. It ruined my 10 month old 800sq ft beautiful cedar deck, see attached pictures. I used Defy Wood cleaner, which was quite an effort in itself, then Defy Wood Brightener followed by Defy Semi-transparent stain in Cedar. The stain left darker sports wherever it overlapped. I have never seen such discoloration after a short period of overlap. Once I started and saw the staining I tried to prevent overlap but the watery consistence make it impossible to not have at a minimum drops fall into the area immediately coated alongside the planks I was staining and the overlap grew into a dark hideous color. I bought DEFY after reviews on this site; I’m not sure if all of them can be trusted. It may work on other wood but not on Cedar. I am sick to my stomach, can’t stand to look at my deck and I on;y stained it yesterday!!
799
