HD80 Deck Stripper Review 3.6/5 (10)
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood cleaning. My HD80 review is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
HD80 Deck Stripper Ratings (1-10)
HD80 Stripper
HD80 Stripper Review
HD80 Stripper ReviewRemoval of Graying, Dirt, Grime: 9
– HD80 as with most stains stripper scores exceptionally well when it comes to the removal of dirt, grime, and mold.
HD80 Deck Stripper: 4-Step Rating & Final Score
My HD80 review contains a 4-step process and the final average score. Each step is on a scale of 1-10.
  1. Cost Per Square Foot
  2. Removal of Old Stain
  3. Ease of Application
  4. Final Appearance after Cleaning
  5. HD80 Final Score
5-Step Review of HD80 Stripper
1. Cost Per Square Foot: 8
Scores very well when it comes to cost-effectiveness. One container of stripper sells for $39.99 and makes 5 liquid gallons. This translates to about $7 per liquid gallon. Each gallon covers 150 square feet.
2. Removal of Old Stain: 7
HD80 contains a mixture of sodium hydroxide and surfactants. When stripping the Olympic deck stain, the HD80 had little trouble. The coating was softened to the point that light agitation removed the Olympic. A small test on a difficult-to-remove acrylic stain (Behr) showed adequate results. The HD80 darkened the wood considerably, but the use of its sister product (Citralic Wood Brightener) reversed the darkening and significantly lightened the wood.
3. Ease of Application: 7
– HD80 is a very strong formula; special care must be taken when mixing the powder with water. It is important to wear protective gloves and eyewear. If any of the HD80 gets on your skin, rinse immediately. Once the powder had dissolved in the water, the Hd80 was easily applied with a pump sprayer. Coverage was better than average at 150 square feet per gallon.
4. Final Appearance of Stripping: 7.7
The Olympic semi-transparent stain was 70-80% removed when done. A few small areas of unexposed stain did not come off.
Overall Score HD80: 7.75
HD80 gets a better-than-average score for a deck stain stripper. Its low cost allows for repeated applications if necessary for difficult stain removal.
Looking For a Stain Stripper?
Manufacturer: Extreme Solutions
Deck Square Footage: 400
The condition of Deck: Heavily worn Olympic Oil-Based Semi-Transparent Deck Stain
How Much Product Used:
2 Pounds. Retails for $44.99.
Logo of DeckStainHelp.com featuring a graduation cap and wood texture background, emphasizing reviews and advice for deck restoration.
72 Comments
Jeff
Jeff
How long should you let it dwell?
Chris ernst
Chris ernst
It there a MSDS fo HD80 stripper?
Chris ernst
Chris ernst
Do you have a MSDS for HD80 stripper?
VJ Watts
VJ Watts
Unfortunately, this stuff does not work on peeling solid stain. Kept it wet for > 15 min section, scrubbed the boards, and used pressure washer on low power. Even tried double treating several sections, still failed. Only removed about 25% of stain. Big fat waste of time that cost me $50. I need to find a new product to finish cleaning my nasty looking deck. Any suggestions?
Don
Don
Do you think this product would work better than restore a deck stripper to remove sikkens srd?
Mary
Mary
Help! We have a western red cedar home and deck and have 2 coats of Olympic Maximum semi transparent stain on it from 2007. Some of the stain has turned black. We have just attempted to strip a small part of our siding using Restore a Deck stripper and after 2 attempts, it’s just not coming off that easily ..including scrubbing. We are concerned as we have a huge – nearly 3 story high wall to do that has a lot of black on it. (we have an entire house but it’s not blackened by the sun exposure) We just need to know if we should switch strippers? I didn’t buy a different brand? I didn’t buy a lot of Restore a Deck – just a few bags to try. Should we try this one instead? Thanks
Mary
Mary
Tina
Tina
Used BM Arborecoat semi-trans 3 yrs ago – it’s flaking off in full sun areas and stuck on in shady areas. 1150 sf deck so working in sections. I’ve cleaned, power washed and just re-stained a section with original product in different color- It looks like plastic to me. Q1: can I use this product on 20 yo cedar to removed the original stuck on stain? Q2: can I use it to remove newly applied stain I just applied this week so I can re-stain with one of the superior quality products I’ve been reading about on this great forum. Q3: if I get everything free of old stain and then run out of good weather (we know what’s coming) would it hurt the deck to leave it totally untreated until the spring? Thank you for your suggestions.
Tina
dawn26
I used this to strip my massive wrap around deck and it made it so much easier. It works great on semi solid stain. pretty much came off like butter. we applied, kept the product wet with product during the 15 minutes. on some sections i would let it sit longer. Used the pressure washer.
Willis Lenzner
Willis Lenzner
will this hurt vinyl siding
Laima
Laima
A berettine oil based wood treatment was applied over some dirty footprints. Will hd80 remove the wood treatment oil? Thanks
I just stained my 5yr old deck with Cabot Gold Fireside Cherry. The color looks terrible next to my house. Will the HD80 remove the new stain?
Mary
Mary
Do you have to use a pressure washer with this product to remove the old stain once it has been applied or can you use a regular water hose?
tom nash
tom nash
I believe the best way to do this is with a nylon brush and actual work. The PW can easily damage cedar, as this product softens the wood as it works. They manufacturer states 1000PSI, but then this depends on what size nozzle. A garden hose is at 50PSI or so.
Just do the work. This stuff works pretty good.
Dorothy
Dorothy
We also have a 20 year old deck with a solid stain on both horizontal and vertical surfaces. I see how to remove the horizontal stain from response to RWS. I already wanted a two toned deck but want the color of the rails to be white; a brick color is on now. Can we just apply the white solid stain over what's left of the brick solid stain?
scott
scott
Any opinion on the newer EFC 38 from Woodrich? I'm guessing it was developed to be a "mild stripper" — one that's more eco friendly than the venerable HD-80. (Unsure though if "milder" means less powerful, or just less harsh….? I'm reading conflicting guidance on whether EFC 38 requires a "brightener" afterwards.) Have need to remove CWF-UV cedar semi-transparent from several years ago — that went on too dark. (thought I was putting on "tinted toner" — but apparently not)
Will most deck cleaners neutralize different types of strippers? Been using a big box store brand stripper which is quite expensive and still have rails and residual deck stain to remove. I would like to use a more efficient and economical stripper like HD 80.
I have a deck in which the previous dunderheads apparently used acrylic latex paint. Very strong NaOH in water pumpsprayer (4 lbs NaOH dissolved in 2 gallons) will not really take it off. What can I use? Thanks.
We always stripped decks with sodium hydroxide, let it do it's work for 30 minutes or so, then pressure wash it off. The pressure washing dilutes it to such an extent it's no longer aproblem
Jen
Jen
Has anyone tried this with Rustoleum Deck Restore latex paint? We this dark brown paint on our deck that is peeling & need something we can use to strip it easily.
RWS
RWS
Also is 2lbs enough for a large 2nd story deck with a staircase to the ground level?
RWS
RWS
I am taking on the project of restoring a 20 year old deck. I believe it is made of pressure treated pine. The current stain is a red/brown solid stain that was applied ~5- 7 years ago. I am a new home owner, and looking to completely remove all of this stain so that I can apply one of the highly recommended stains on this site. Upon looking up HD80, I see that it is contractor grade and it is not recommended for shipment to homeowners. Assuming that I follow instructions, use common sense and safety precautions, is there any reason that I should not purchase this product?
Also, my general plan of attack is:
1. Use a grinder with a wire brush attachment across the whole surface of the deck.
2. Use a stripper, HD80 and power washer to remove.
3. Sand the deck with a belt sander.
4. Apply a new stain.
Any flaws in my plan or other helpful recommendations?
Also, this site is awesome, thank you for the amazing amount of information that has been posted already!
RWS
RWS
Thank you for the insight and guidance! Much appreciated!
Janet Altendorf
Janet Altendorf
Where can we find HD8o stripper in Amarillo, Texas?
Drew
Drew
12 years ago
The HD-80 does a great job stripping old stains including oil-based ones but we have found that it leave the wood surface with a significant amount of 'fuzzies' that need to be sanded. This especially happens on teak furniture. Can this be avoided so not as much sanding is required after stripping?
Fran
Fran
12 years ago
Need your help. It was cobat clear natural stain (oil based) on my deck in 5 years ago. I believed my deck is about 23 years old and good condition. I have been sanding, cleaner and then brightener. So I looked at my deck which I thought it was done. But I noticed when the rain come down and then the water beaded still there. I'm surprise to see the deck is not absorbed the water ( in some area). What should I do?
Fran
Fran
12 years ago
Should I use remover stain( can't see stain)? Or should I show u the images when u able to give me some answers? Where should I upload?
Rj Anderson
Rj Anderson
12 years ago
Update: My contractor just finished stripping and brightening our back deck using the HD-80 & Citalic kit from Woodrich. He never used this product before but I think he will for now on. He said they both worked great! Here is a link to before/after photos. Note the "after" photo is before staining but after using the stripper & brightener/neutralizer. If link below is not "clickable" you'll have to copy & paste into your browser.
Rj Anderson
Rj Anderson
12 years ago
We thought so as well. Oh…I just uploaded a new photo to that link I posted above. The deck is now stained using Armstrong-Clark's Rustic Brown in semi-transparent. Not too shabby I believe.
ashley
ashley
12 years ago
Reply to  Rj Anderson
Thanks so much for the pics! This is exactly what we are going to do with our deck.
Rj Anderson
Rj Anderson
12 years ago
Agree with Sally. Order it from the woodrich-brand site. Good price and free shipping. I got the "Kit #2" which is the HD-80 stripper along with their Citralic Brightener/Neutralizer. Forty nine bucks shipped.
Sally
Sally
12 years ago
I have used HD80 for removal of Sikkens Dek. It works well. Deck and porch have had multiple coats so it does take some time. I order it direct from Woodrich. They have excellent customer service. I have called and gotten very detailed info about the product.
Jessica
Jessica
12 years ago
The only Behr product that is worth anything is the Behr stripper, which was our stripper of choice until we found HD-80. HD-80 removes Sherwin Williams Semi-Trans (which is more like a semi-solid), so I would imagine it would do a pretty decent job removing the Behr acrylic.
jackie
jackie
12 years ago
Ditto for us too. The Behr product is horrible and the stripper doesn't work.
Dan
Dan
13 years ago
Brad, I have the same question. The Behr product is awful and needs to come off. Hope someone can help us both.
Brad P
Brad P
13 years ago
Has anyone tried HD-80 on Behr acrylic stain? We made the mistake of using the acrylic semi transparent last august and this spring a massive amount of the stain on the flat boards had flaked off after the snow melted. I just tried the Behr stripper this weekend and also the Benjamin Moore stripper today and neither of them worked very well at all, even with LOTS of scrubbing. I have a huge deck that I built around my pool that I need to fix, so I need to find a stripping solution that won't take forever, it's about 1000 sq ft.
Bill
Bill
12 years ago
Reply to  Brad P
I also had poor results with Behr (high priced) acrylic deck treatment. I have stripped my 1500 sq ft deck and reapplied One-time Wood preserver. I hope for better results. I used the One-time Wood stripper – it did a credible job of removing the Behr acrylic stain. I had to a minimal amount of sanding to remove the Behr stain in a few areas where it was applied very thick and the areas were not exposed.
DIY_deck_wash
DIY_deck_wash
13 years ago
Is there a local store near DC or Baltimore I can buy HD-80? Please let me know. Thanks.
Ryan
Ryan
13 years ago
Is this hd80 produced by Woodrich Brand? I'm trying to find out the exact brand name and am running into confusion.
Thanks!.
12 years ago
where retail stores carry HD-80?
Ann
Ann
Reply to  Jim
I DECIDED WEEK AGO FROM MY RESEARCH NOT TO USE ANY OF THESE Restore PRODUCTS. My deck was painted dark brown (when purchased home) It is like a paint. Took on big job of flipping all boards. BIG JOB! After washing, bleaching, pressure washing again. Applied TWS with garden sprayer. Unfortunately mixed part of can newer protection with older product. Didn't realize one was water base and older stuff was not smelled differently. Like turpentine. What a mess. Now on search to find best product to remove. Wrote to TWS. They gave me a list of products I could use. Theirs was only one found would take off both water and other based sealer .Could not find at HD or Lowes. Found this site tonight.. Did buy JOMAX by Zinsser (read reviews – mixed) Will try to find or order HD-80. Then must try to find best sealer. After all this wk. want to get what will work. how did this wk for you? what did u use after it. Did u use brightener? 71 yr young female with 1080 sq feet to flip.. Only put my concoction on 400 sq ft I live in Fl. Where did you find HD-80? Thanks Yes this is great site.
Dusty
Dusty
Reply to  Ann
To have gone through flipping the boards & then to discover you'd applied oil/water gunk, must be something else. Good for you for not engaging in paint rage.Nice to keep learning too. How did you solve it?
Don
Don
Reply to  Ann
I wouldn’t recommend flipping the boards. Deck boards aren’t flat because of the way wood grows and boards are cut. If the deck was properly installed, they are convex on the surface and will shed water. Flipping them makes them concave and they will collect water in the center of the board. This will stain them as the collected rain water evaporates, keep them wet and promote rot and insects.
trackback
[…] and stain strippers. Manufactured by Extreme Solutions, Citralic works with EFC-38 Wood Cleaner and HD80 Stain Stripper but can be used to with any wood cleaner or stain stripper. Citralic is a professional grade wood […]
72
