Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior deck prep. My removing ink stamps from deck board tips are based on my history as a wood and deck restoration contractor and actual hands-on testing. See here for more info about me.
Remove Ink Stamps from New Deck Boards
Those familiar with the deck staining process know how important it is to properly prep your deck before staining for beautiful results. This article discusses removing pesky ink stamps from new decking before prepping and staining wood surfaces. I always appreciate your input, so feel free to comment below with pictures of your deck stain projects.
Pressure-treated decking, when new, tends to have very annoying ink stamps on the wood when processed at the mill. Lumber is stamped at the mill according to its grade. An American Lumber Standard Committee (ALSC) grade mark and an American Wood-Preservers’ Association (AWPA) tag certify the lumber’s quality. These stamps are very troublesome for owners to remove before applying a decking stain that is either transparent or semi-transparent, as the ink will show through the stain.
Scott’s Pro Tips for Stamp Removal on Deck Boards
Sand First, then let Wood Weather Naturally
Since most decking stain manufacturers want you to let new wood season and weather before staining it is advisable to do these steps:
- Right after installing the new wood, lightly sand all stamps off with 60-80-grit paper and sand with the grain of the wood.
- Let wood weather for 2-4 months, as the stain manufacturer you are using suggests for new wood.
- Clean and Brighten all decking after the weathering for the stain prep and even out the appearance
- Apply stain. Please read this about New Decking stain
The reason for sanding first and then weathering is to make sure the stain will apply evenly. If you were to sand the ink sports right before staining, there would be a solid chance that the stain would take lighter in the sanded areas, resulting in a very uneven appearance of the deck stain.
Staining a New Deck Tips Video
Have Deck Ink Stamp Removal Questions?
Do you still have questions on how to remove those pesky ink stamps? Please ask below. I am glad to assist you. I also suggest reading the comments below, as your question(s) may have already been answered.
Restore-A-Deck Package 300
I spoke with you on Friday I believe, I got your response and thank you. So I started sending the deck it on Saturday with not great results. I am a painter of 55 yrs and this sanding is brutal. I rented a drum floor sander that had a 8 inch drum. Was using 80 grit paper and because of the u shape decking boards it was only sanding the edges. It took me 9 hrs to sand approximately 200sq ft. My question to you is are there chemicals that I can apply, and then power wash it to get the board to match where I sanded the ink stamps off. I rented a hand held belt sander and it getting it done but it’s taking way to long. I still have about 400sqft to go. Any suggestion would be greatly appreciated.
I’m 72 yrs old and sanding is back breaking. Thank you!
No, it is not possible to use chemicals to blend where you spot-sanded and did not spot-sand. Only even sanding for all wood will even that out.
What if we already stained the wood ?
You would have to fully remove your coating and start over.
Hi there, quick question. Would it be alright to use Brillo soap pads and scrub to remove the mill stamps? If that’s a bad idea, should I use an 80 grit and do it by hand or is it okay or better to use an orbital sander or a belt sander (better to sand in same direction as grain)?
Brillo as in metal scrubbies? Don’t do that, it will leave metal in your wood that will turn to rust. Hand sand with 60-80 grit.
Thank you. And only sand the stamps themselves, correct? Not the entire board/deck I assume?
Yes, then weather for awhile before final prep.
Hi. We are located in the Northeast and installed a new deck with pressure-treated pine boards in September of 2023 – 7 months ago. When I do the water test, water still beads on top of the boards for over 10 minutes. Parts of some boards are beginning to gray, but the mill stamps are still very apparent. We are leaning towards a transparent oil-based stain. To remove the mill stamps, should we sand now and wait a few months to stain? How long do you recommend letting pressure-treated pine weather in this part of the country? If we stained without removing the mill stamps, would they naturally fade over time? We just want to be sure that the wood is not getting damaged since it is not protected! Thanks so much for your help. This site is excellent.
Yes, sand them off now and then clean and brighten later in the summer prior to staining. Do nto stain over the stamps. It will be fine to wait until late summer.
Best stain options: https://www.deckstainhelp.com/best-semi-transparent-deck-stain-reviews/
Hi. Great site, tips, and tricks! I have a deck that; I just replaced all the boards with pressure-treated pine. I had to sand a couple of places due to some marks from my pencil and so forth. Now some areas are yellowish, some are lighter (seems to be the second batch of lumber I purchased) and the areas in which I lightly sanded are more white. What should I do? Sand all of it, wait? I have all the rails off now if I need to sand or should I just wait? Thank you for your help!
Wait until Fall and them clean and brighen fo prep. No more sanding:
I replaced my deck with cedar tone boards in summer of 2020 but didn’t sand ink stamps off. I’m planning to stain soon but once I sand wood how long hould I wait to stain?
2-3 months and then clean and brighen for final prep.
How do I get ink stamps off tongue and groove pine that is not going to be exposed to weather as it is used inside a horse barn. The plan is to use semi transparent stain on it. I know this is not a deck question but wonder if you have ever dealt with this issue. There is a lot of tongue and groove and a lot of stamp marks-like several thousand square feet and every board has one to three stamps on it!
You will have to sand the stamps off then let it sit for a few months prior to prep and stain.
Before I sand the rest of the ink, does it look like I’m doing it correctly so far? Light pressure along the length of the board? Thank you.
You should be fine as long as you weather and prep after the winter.
Hi again, I’ve read all the comments but want to be 100% certain I’m doing the right thing so my deck doesn’t stay discolored. Most of the boards have been weathering since June/July and the ink has faded some but not completely. If I sand the ink spots with 80grit Diablo sand paper, using a mouse sander, in the direction of the length of the boards, I should end up with white spots that will disappear once the boards weather over the fall and winter? I can use enough pressure to remove all of the ink? Aiming to stain with TWP 101 Cedar Natural or another semi natural look in early March in Georgia. I get nervous at the thought of having to wait until then to see the white marks disappear, or worse that I’ve done something wrong trying to remove the ink. As always, thank you.
Your sanded spots will even out after weathering and prep in the Spring.
Thanks, is there any truth to the idea of sanding while the wood is damp to remove the ink with less pressure from the electric sander? Or does it matter?
No idea as if that works or not.
How to remove stamp on non-treated wood?
Article above explains this.
I found your site after being in the same situation as a few others on here. We had let our new deck weather over the winter and then realized the wood stamps weren’t going away and sanded them off and now it’s two obviously different colors. Is there a quicker solution than letting it weather for 3 months to even out? I’m just concerned those spots are going to look out of place all summer. If we power washed it all before staining, would that be safe and even it all out to one color and consistency before staining? I’ve included pictures of what it looks like wet and dry. Thanks in advance for any advice you can give!
No way around it. Let it weather for a few months and then prep and stain to even it out.
Stupid question. Is it going to hurt the weathering process at all to have a table and chairs and other deck furniture on top of it this summer since they might not get as much sun? Thanks for the quick reply!
I doubt having the furniture on the deck will make a difference or not.
How did it turn out? I’m in the same situation, and curious as to whether I should let it weather till Spring and hope the stamps are gone by then on their own, or sand the several months old wood now and hope the light spots are gone by time to prep and stain in Spring. They have faded some but are still visible.
We just sanded off the stamps on a pressure treated deck installed 6 wks ago. The sanded spots are quite light in comparison to the rest of the wood. My husband used 80 grit but he had to use an electric hand sander to get them off. I’m just looking for some information as to how this will even out in color with the rest of the deck. Is it going to age quicker in the sanded areas because the wood grain was exposed and then result in an even wood tone overall? Just wondering how these “light spots” will catch up with the rest?
Let the wood age for 3 months or so after sanding and then clean and brighten all wood after.
Part of my deck is under cover and part is open air. It will not be weathering evenly. The covered portion will likely not weather at all. It’s been “weathering” for 4 months with no visible change (though it is drying out) I sanded an ink spot thinking I could stain afterward but it left an obvious mark. Ay suggestions?
Sand the ink spots now and then leave alone for another 3 months. Clean and brighten for final prep and it will be even then.
My husband just installed new deck boards on a pre-existing base. Great job!! However, we are trying to deal with the manufacturer’s markings. My question is, it is now mid-September. Should we wait until after the winter months to stain (going to use semi-transparent stain)? Deck gets a good bit of weather (rain, snow, heat…). Wasn’t certain how long it should sit. Pressure treated – a good bit kiln dried. Thank you very much!!
Sand the marks off now, let weather until Spring, clean and brighten for prep before staining.
Why do deck installers place decking boards with the stamp side up. Why not install board with the non stamped side up? Maybe a logical reason? Thanks.
Typically the put the better side up or the side that has fewer imperfections.
Will any solvents like acetone help. Is sanding the best way to remove? Thanks.
Solvents will not help.
Thanks again.
Bark side out to prevent cupping on deck surface.
We bought green treated lumber to build a deck. Some of the boards have a touquise color to them. How can remove it?
Tha is internal. You cannot remove it.
how to remove bleach from pressure treated wood
We do not understand your question. If you applied bleach then rinse it off when done.
I spilled bleach on my new deck and it stained it white. How can I get it back to the pressure treated colour
You cannot. After a few months, you can use a normal deck cleaner and then wood brightener but at this point, you can not undo.
If stain has already been applied over the ink stamps on a deck, will the ink always be on there or will it eventually come off with weather and wear and tear? How long would that take to wear off?
It will not come off until you redo the deck by stripping off the current stain.
Thank you for all your help.
We acquired a brand new built deck (6 months) with treated pine when we bought our house this spring. We were waiting for the wood to weather before staining it and I just sanded off the ink stamps. Unfortunately, I reviewed your site (which is amazing information) after I sanded the stamps with 150 grit sandpaper. I read we need to wait to stain the deck to let the newly sanded spots to weather so they are more uniform. Two questions, should I go over all the sanded spots with 80 grit and how long should we let the newly spots weather before we stain. We live in NC so we still have a few months (currently august) of nice weather left. We are leaning towards the Armstrong stain after reviewing your site. We were going with Behr before that. Thank goodness I found this site!
You should not have to resand. Let the wood all weather for a few months and then clean and brighten all wood for the prep.
Thanks for the quick response. Will post pics when done. Looking at October time frame now.
What do you use to clean and brighten a new weathered cedar decking
Use the Restore a Deck Cleaner and Brightener Kits.
We installed WeatherSheild wood decking with ceder tone. It has stamped marks on it. How do I remove the stamped marks without removing the cedar tone?
Sorry but that is not possible.
I built a cover deck about 6 weeks ago. Sanded for prep. It’s been 6 weeks now. And I still can not get these stamps off. Any other suggestions. This project was big. But getting it prepped for staining and trying to get these stamps off has been a nightmare.
Spot sand the stamps with 40-60 grit. Once removed, let the wood weather for another 2 months. Clean and brighten all for prep.
I just installed deck boards by EcoLife. The boards are air dried after treatment. Should this type of wood have a weathering period before staining? Also, there are perpendicular marks on the boards from the spacers used during the manufactures drying process. I used a scrap piece and sanded, cleaned and used a brightener. I used a semi solid stain but I could still see the spacer marks. Any advice would be greatly appreciated.
Yes weather a month after the sanding and clean and brighten for the prep. No easy way to fix now outside of removing and starting over.
I installed a new deck last fall and did not remove the stains then. I just sanded them off now and have lighter spots where I sanded Is there anything I can do to make them blend in/
To even the wood grain out you will need to let it sit as is for 2-3 months and then clean and brighten the wood for the final prep.
Some marks from patio chairs (black) have stained a newly built pressure treated wood deck. What is the best way to remove these stains (from chair legs) before sealing deck
That is rust. Clean and brighten the wood for prep. The brightener is what will help to remove the rust.
Not rust…..spray paint (black primer) that was put on patio set
A blue crayon melted on our new pressure treated wood deck. We scraped up the solids, but now need to remove the soaked in color. How can I remove the stain? Thanks!
Sand it out or replace the board. Cleaners will not remove the wax.
Did you try gasoline?
No we did not.
PT wood often has annoying wax pencil 'sorting' marks (as well as the manufacturers ink stamps). Since I've built quite a few decks for some picky customers, including myself, I've experimented with just about every solution out there, with spotty results. For starters, if water can penetrate the wood (i.e. wood not sealed well) leave a wet towel on the wax area 10-15 minutes. If water only beads on wood, skip this step. Heat an iron to medium high heat, cover the wax with the clean cotton towel or old tee shirt and apply the iron for 3 or 4 minutes. Wet or dry, steam or heat will melt the wax and the cloth will absorb it. I repeat the process until no more wax transfers to the cloth. I was hoping that by leaving the iron on the wood for longer periods with higher heat it might replicate the mill coating effect (blade friction/heat cause sap/etc. to rinse to the surface) and remove more wax, but just repeating the process was just as effective. Anyhow, I let the wood cool then sand with a pad sander starting with 80 grit and progress to a 220 grit. Using chemicals to break down wax can cause it to penetrate more deeply into the wood, and result in a worse stain than you started with, often not visible till it dried out. A few failed conclusions were xylol, borax, vinegar, mineral spirits, white gas, and HD degreasers (which do break down wax). Now if you're looking to eliminate those ink stamps, good luck!
Having built my own decks, and also hiring contractors for larger projects, I had not ever run into caring for older decks and pressure-treated pine. This article, as well as others on this site, have been extremely helpful. Preserving and maximizing the appearance of my home is easier than I thought. Thank you.
Sikkens is terrible
No its not. The rubbol solid deck stain which is an alkali/oil hybrid is incredibly durable and looks great on a deck.
