Restore-A-Deck Stain and Prep on the Same Day!
Restore-A-Deck Semi-Transparent Wood Stain – Advanced UV & Water Protection
Stain & Protect Your Deck the Same Day as Prep!
Restore-A-Deck Semi-Transparent Wood Stain is a high-performance, water-based stain designed to deeply penetrate wood pores, providing maximum protection against UV rays, moisture damage, and graying. This low-odor, eco-friendly stain is easy to apply, maintain, and clean up with soap and water.
✔ Applies to Damp or Dry Wood – Stain the same day as prep!
✔ Penetrates Deep into Wood Grain – Prevents wear, fading, and peeling
✔ Water-Based Formula – Easy application & cleanup
🏆 #1 Rated Wood Stain for Exterior Decks & Fences
🔹 Why Choose Restore-A-Deck Semi-Transparent Wood Stain?
✅ Apply the Same Day as Cleaning – No need to wait days for wood to dry!
✅ Advanced Water-Based Technology – Superior UV resistance & deep wood penetration.
✅ Eco-Safe & Low VOC – Safe for the environment & easy to maintain.
✅ Great for All Exterior Wood Surfaces – Decks, fences, siding, outdoor furniture, gazebos, & more.
✅ Works on Hardwood & Softwood – Can be used on cedar, fir, redwood, pressure-treated pine, mahogany, ipe, & other exotic hardwoods.
✅ Flat, Natural-Looking Finish – Enhances wood grain while providing durable protection.
📌 New Wood Note: New wood must weather & be prepped before staining for best absorption.
🔹 Where to Use Restore-A-Deck Semi-Transparent Stain?
✔ Decks, Railings & Stairs
✔ Fences & Pergolas
✔ Wood Siding & Log Homes
✔ Gazebos, Outdoor Furniture & Playsets
📌 Not just for decks! Works on all exterior wood surfaces.
🔹 Coverage & Application Instructions
📏 Coverage: 150-250 sq. ft. per gallon, per coat (varies by wood porosity). 2 coats applied wet on wet for wood that is older than 1 year and has no prior coats. One coat if doing a maintenance coat. Note: When applying 2 coats, coverage averages around 100-125 sq feet per gallon for the TWO coats.
🕒 Dry Time: 2-4 hours at 70º F, <50% humidity.
🌞 Can Be Applied in Sun or Shade
How to Apply Restore-A-Deck Semi-Transparent Wood Stain
1️⃣ Prep the Wood: Use Restore-A-Deck Cleaner or Stain Stripper followed by Restore-A-Deck Brightener.
2️⃣ Ensure Surface is Ready: All standing water should be dried off (typically 2-4 hours after prep).
3️⃣ Apply Stain Using Brush, Roller, or Pump Sprayer: When applying 2 coats, use wet-on-wet for even absorption.
4️⃣ Back-Brush or Use a Stain Pad: Ensures even penetration & smooth finish.
5️⃣ Let Dry Completely: Allow 24-48 hours before heavy foot traffic.
📌 For detailed guides:
- Aplying RAD Stain Wet-on-Wet
- How to Apply RAD Stain to Damp Wood
- RAD Stain & New Wood Prep
- Two-Tone Deck Application Tips
🔹 Available Colors
🎨 Choose from 5 Beautiful Semi-Transparent Finishes:
✔ Natural – Lightest tone, enhances wood grain
✔ Cedar – Warm, traditional wood finish
✔ Light Walnut – Rich, medium-tone brown
✔ Dark Walnut – Deep, classic wood stain
✔ Get Professional-Quality Protection with Restore-A-Deck Stain!
✔ Stain the same day as prep for fast & easy application!
✔ Enhances wood grain while preventing UV & moisture damage!
✔ Eco-friendly, water-based stain for long-lasting results!
🔹 Order Restore-A-Deck Semi-Transparent Stain today and protect your wood with the latest in stain technology!
AVAILABLE SEMI-TRANSPARENT COLORS:
NATURAL, CEDAR, LIGHT WALNUT, DARK WALNUT, COTTAGE GRAY
I have 1700 sq feet of year 2 cedar deck to stain. I live in Eastern South Dakota. I have decided to use the Restore a Deck product, semitransparent Cedar color. How much stain, cleaner, and brightener do I need to purchase? I was thinking 6 gals of stain but wasn’t sure on the cleaner and brightener. Thanks for your help! Mary
Closer to 15 gallons for two coats. For the prep, 2 Cleaners and 2 Brighteners
Oh, ok. I didn’t realize it would require 2 coats. I did not read that anywhere in the information presented. Why do you recommend 2 coats and where can I read more about 1 vs 2 coats pros and cons. Thanks, Mary
I have a new pergola made from treated pine and I have let weather year and now I want to use the restore a deck product on it. I live in Michigan as well. Do you suggest putting 2 coats on? What do you suggest I prep the pergola with before using the restore a deck stain?
Prep with this kit: https://www.deckstainhelp.com/product/restore-a-deck-package-300/
One coat of stain should be enough.
I have an older deck see attached pictures. I have completely bleached, and power washed the deck, however there is still some gray, and some previous stain remaining. During winter, I am not able to get deck completely dry. Am i better to get RAD with a darker brown color? Or should I go with TWP? Application temperatures?
You cannot use the TWP or the RAD semi-transparent stains unless you thoroughly remove the old stain. What you have on the tailings looks like an opaque solid stain. You will have to strip and or sand this all off, or go with another solid color stain.
I used Restore-a-Deck stripper and Brightener twice on my deck. There was a lot of grey remaining, which lightened as it dried. So I applied the RAD semi transparent stain. Then it rained! Two questions. 1. Why so much grey, and 2. How do I repair the damage done from the rain?
The rain harmed the stain before it had a chance to dry, so you would have to remove the stain and start over to fix it. As for the gray, we would need to see pics of the wood before it was stained to see the prep.
The first picture is after staining showing the rain damage. The third and fourth pictures are before staining and after prepping twice (strip & brighten).
You did not pressure wash the property while doing the stripping and brightening steps.
I recently replaced my standard 10×12 deck with pressure treated southern pine. We live about 30 miles west of Atlanta.I wanted to use Restore-A-Deck in the light walnut stain. I was giving it 2 months to weather before starting to process of cleaning and staining. Would 2 gallons of stain be enough to complete my project.
Restore A Deck Stains want 3 or more months and then clean and brighten for prep. Only one coat, so if you have only 120 sq feet, then 1 gallon should work. If you have stairs and railings, then you need to add that into the total square footage.
Thanks I do have spindles and top railings also new support beams
Flooring Length x width =?
Railing Length x height =?
Steps Width x Depth x #of Steps =?
Add up all 3 for the Total Sq. footage.
Thank you for all your quick responses and advice in bringing my mahogany deck back to life. I have followed your 3 step process, deck stripper, deck brightened and then stain. I chose the Armstrong Clark wood stain natural tone. The deck was installed 2 years age, has been sanded twice as previous stain and sealers did not hold up to New England weather. My question is this, do I do a 2nd coat of the Armstrong Clark stain? Please advise
Not for hardwood decking. FYI, you should be using a Armstrong Clark hardwood color for your deck, not the natural color: https://www.deckstainhelp.com/product-category/armstrong-clark-ipe-and-hardwood-stains/
I didn’t find your site til After using the Behr Waterbased Semi-Transparent stain on my 1 yr old brand new wood deck. So far it is even enough. I wish I could see more of the wood grain.
For the future I’d prefer to use a penetrating stain …if I wait for few weeks can I just do a “second coat” of something like the Restore? Or would oil-based penetrating product be best?
Hoping in future to just add coats that penetrate into wood without the need for sanding or stripping.
You cannot apply any coating over the Behr. You will have no choice but to remove it fully when it fails or when you switch.
How long does product take for shipping?
That varies based on where you live. 1-4 business days is the norm.
Does restore a deck stain come in oil based clear?
Restore A Deck stain is water based.
Following your 3 step program, I’d like the deck stain stripper, the deck neutralizer and TWP oil based clear stain for 350 sq ft. Can you tell me the amounts I need?
One stripper and brightener kit:
3-4 gallons of the TWP stain.
Is the TWP product and oil based stain?
Yes, it is.
I can’t order this online.
How do I know if I need to apply 2 coats?
-Not sure what you mean? Please pick a color and then add to cart. Let us know if you have any other issues with ordering.
Now, wood, just one coat. Older wood, is typically two coats.
How often should I have to re-stain flat surfaces like stairs, railings & deck floors? We live in N Michigan & plan to use dark walnut color as that most closely matches current stain?
Every 2-3 years is normal.
On line ordering does,nt seem to work from Canada?
It is working now. Sorry about that.
Yes
Used this stain for my 5 year old deck that was never treated. It turned out AMAZING. Coverage is great and really easy to use since it can be applied to damp wood
