Restore A Deck Stain and Prep on the Same Day!
Restore-A-Deck Semi-Transparent Wood Stain – Advanced UV & Water Protection
Stain & Protect Your Deck the Same Day as Prep!
Restore-A-Deck Semi-Transparent Wood Stain is a high-performance, water-based stain designed to deeply penetrate wood pores, providing maximum protection against UV rays, moisture damage, and graying. This low-odor, eco-friendly stain is easy to apply, maintain, and clean up with soap and water.
✔ Applies to Damp or Dry Wood – Stain the same day as prep!
✔ Penetrates Deep into Wood Grain – Prevents wear, fading, and peeling
✔ Water-Based Formula – Easy application & cleanup
🏆 #1 Rated Wood Stain for Exterior Decks & Fences
🔹 Why Choose Restore-A-Deck Semi-Transparent Wood Stain?
✅ Apply the Same Day as Cleaning – No need to wait days for wood to dry!
✅ Advanced Water-Based Technology – Superior UV resistance & deep wood penetration.
✅ Eco-Safe & Low VOC – Safe for the environment & easy to maintain.
✅ Great for All Exterior Wood Surfaces – Decks, fences, siding, outdoor furniture, gazebos, & more.
✅ Works on Hardwood & Softwood – Can be used on cedar, fir, redwood, pressure-treated pine, mahogany, ipe, & other exotic hardwoods.
✅ Flat, Natural-Looking Finish – Enhances wood grain while providing durable protection.
📌 New Wood Note: New wood must weather & be prepped before staining for best absorption.
🔹 Where to Use Restore-A-Deck Semi-Transparent Stain?
✔ Decks, Railings & Stairs
✔ Fences & Pergolas
✔ Wood Siding & Log Homes
✔ Gazebos, Outdoor Furniture & Playsets
📌 Not just for decks! Works on all exterior wood surfaces.
🔹 Coverage & Application Instructions
📏 Coverage: 150-250 sq. ft. per gallon, per coat (varies by wood porosity). 2 coats applied wet on wet for wood that is older than 1 year and has no prior coats. One coat if doing a maintenance coat. Note: When applying 2 coats, coverage averages around 100-125 sq feet per gallon for the TWO coats.
🕒 Dry Time: 2-4 hours at 70º F, <50% humidity.
🌞 Can Be Applied in Sun or Shade
How to Apply Restore-A-Deck Semi-Transparent Wood Stain
1️⃣ Prep the Wood: Use Restore-A-Deck Cleaner or Stain Stripper followed by Restore-A-Deck Brightener.
2️⃣ Ensure Surface is Ready: All standing water should be dried off (typically 2-4 hours after prep).
3️⃣ Apply Stain Using Brush, Roller, or Pump Sprayer: When applying 2 coats, use wet-on-wet for even absorption.
4️⃣ Back-Brush or Use a Stain Pad: Ensures even penetration & smooth finish.
5️⃣ Let Dry Completely: Allow 24-48 hours before heavy foot traffic.
📌 For detailed guides:
- Aplying RAD Stain Wet-on-Wet
- How to Apply RAD Stain to Damp Wood
- RAD Stain & New Wood Prep
- Two-Tone Deck Application Tips
🔹 Available Colors
🎨 Choose from 5 Beautiful Semi-Transparent Finishes:
✔ Natural – Lightest tone, enhances wood grain
✔ Cedar – Warm, traditional wood finish
✔ Light Walnut – Rich, medium-tone brown
✔ Dark Walnut – Deep, classic wood stain
✔ Get Professional-Quality Protection with Restore-A-Deck Stain!
✔ Stain the same day as prep for fast & easy application!
✔ Enhances wood grain while preventing UV & moisture damage!
✔ Eco-friendly, water-based stain for long-lasting results!
🔹 Order Restore-A-Deck Semi-Transparent Stain today and protect your wood with the latest in stain technology!
AVAILABLE SEMI-TRANSPARENT COLORS:
NATURAL, CEDAR, LIGHT WALNUT, DARK WALNUT, COTTAGE GRAY
can I spray this product with back pack sprayer
Yes, it can.
This stain makes deck projects simple and effective. It applies easily, even the same day as prep, and delivers excellent UV and water protection while enhancing the wood’s natural look. Cleanup is a breeze with soap and water. A great eco-friendly option for decks, fences, and more!
The only stain on the market that can be applied the same day as prep! 😍
Restore-A-Deck Photos. 😍
