Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Restore-A-Deck Wood stain review is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain tips. See here for more info about me.
Restore-A-Deck Semi-Transparent Deck Stain Review
Restore-A-Deck Wood Stain is a water-based penetrating stain designed to provide good color retention while still allowing the wood to breathe. It is a newer generation stain compared to traditional oils and is designed to be more environmentally friendly while still delivering solid performance.
From my experience restoring decks since 1993, Restore-A-Deck performs best for homeowners who want a balance between ease of use, durability, and longer-lasting color. It does not penetrate as deeply as oil-based stains like TWP, but it makes up for that with better UV resistance and more consistent color.
In 2017, our first full year using the Restore A Deck stain, we had no performance issues and saved a tremendous amount of time by prep and stain on the same day. We will continue to offer the Restore A Deck Semi-Transparent Wood Stain as one of our go-to decking stains for the 2026 restoration season.
Overall, Restore-A-Deck is a very good choice for those looking for a low-maintenance, water-based stain that performs well across a variety of wood types.
Note: Restore-A-Deck Semi-Transparent Wood Stain can be applied to dry or damp wood. Applying to damp wood allows you to prep and stain on the same day, saving you a tremendous amount of time.
8.63 Overall Rating Restore-A-Deck Stain
🔹 Quick Verdict
Restore-A-Deck Wood Stain – Quick Review
- Best For: Homeowners wanting better color retention and easy maintenance
- Not Ideal For: Those wanting maximum penetration on older wood
- Type: Water-based penetrating stain
- My Overall Rating: 8.63/10
Restore-A-Deck is one of the better-performing water-based stains I have used. It offers solid durability and color retention while still being relatively easy to maintain. This is one of the easiest products to apply, and it’s featured in our list of the best deck stains for most decks.
Restore-A-Deck Semi-Transparent Wood Stain is an advanced, water-based, semi-transparent stain formulation designed to penetrate deep into wood pores for maximum protection and longevity. Restore-A-Deck Wood Stain protects the wood from harmful UV rays and damage caused by water penetration. Restore-A-Deck Semi-Transparent Wood Stain is safe to use, has a low odor, and is easy to clean up with soap and water. It is ideal for all wood types including pressure-treated pine, cedar, fir, or redwood.
Recent advancements in water-based wood stain technology have allowed the active ingredients in the Restore-A-Deck Stain to offer better UV protection, excellent penetration into the wood grain, and the ability to apply to damp wood. All this is available in five beautiful semi-transparent colors highlighting the natural wood grain.
RAD Wood and Deck Stain will increase all exterior wood surfaces’ life, appearance, and durability. With the easy-to-apply and maintain Eco-Safe formula, you’ll be able to finish faster and enjoy your exterior wood or deck for years.
Restore-A-Deck Wood Stain Ratings (1-10)
How I Rated Restore-A-Deck Semi-Transparent Wood Stain
My Restore-A-Deck Semi-Transparent Wood Stain review contains an 8-step process and the final average score. Each step is on a scale of 1-10.
- The appearance of Restore-A-Deck Semi-Transparent Wood Stain after Application
- Preventing UV Graying
- Peeling or Wearing
- Preventing Mold and Mildew
- How Easy was the Restore-A-Deck Semi-Transparent Wood Stain Application
- Color Shifting
- Ease of Reapplication
- Restore-A-Deck Semi-Transparent Wood Stain Final Score
8-Step Review of Restore-A-Deck Wood Stain & Sealer
The Restore-A-Deck wood stain color we used was the Semi-Transparent Light Walnut. The initial appearance was a rich brown with a hint of red (see pictures below) after drying. The Restore-A-Deck Stain penetrated extremely well into the wood grain on our test deck. No surface film on top of the wood.
Restore-A-Deck had little to no fading at the 2-year mark. Excellent color retention should be achieved through years 2-3 as well based on initial pictures and testing. See below for a picture.
3. Wear/Tear and Peeling: 9
4. Cost Per Square Foot: 8
We applied two coats to our 150 sq foot deck, including all railings and steps. Less than 1 gallon was used for this at a total cost of $40. This equates to $.30 a square foot. Very reasonable pricing and better than most other top brands.
Like other water-based deck stains, the Restore-A-Deck Wood stain will not promote mold or mildew growth. This is one of the primary advantages of using a water-based coating. At the 1-year mark, the deck showed no signs of any mold or mildew.
6. Ease of Application: 9
Our favorite aspect of the Restore-A-Deck Wood stain is the ability to stain and prep on the same day! We tested this by cleaning and brightening the wood with the Step 1 and Step 2 Restore A Deck Cleaner/Brightener Kit and then applying the RAD stain 1 hour after the prep. The wood was visibly wet on a few deck areas and damp to the touch throughout. The Restore-A-Deck actually applied more easily to the damp wood than any other water-based stain that we have used previously. We also found that the coverage was better when applied to damp wood. In theory, the stain will absorb better when applied to damp wood. The water “swells” the wood pores and “pulls” the stain deep into the wood as it dries. Applying to damp wood will also help avoid potential issues with Applying a Deck Stain in Full Sun.
See before and after pictures below.
As expected, the Restore-A-Deck stain darkened very little and did not shift color. See the picture at the 2-year mark above.
The Restore-A-Deck will be an easy clean and reapplication as needed.
Overall Score Restore-A-Deck Stain at 1-Year Period: 8.63
– The Restore-A-Deck is an awesome exterior wood stain and has shown the ability to outperform other water-based and oil-based wood stains. Restore-A-Deck’s 3-Step system allows you to save time and money when restoring your exterior wood and decking. No other system that we have used or tested has allowed the ability to Prep and Stain in the Same Day. If you are looking for the future of exterior wood and deck stain, consider the Restore A Deck Wood Stain and their prepping system.
Cost: $47.99 per Gallon, $219.99 per 5 Gallon Pail. Products ship free on their website.
Available Colors: Natural, Cedar, Light Walnut, Dark Walnut, Cottage gray
Dry Time: 2-4 Hours
Cleanup: Water
Manufacturer: Restore-A-Deck
UV Exposure: 50% Full Sun
🔹 Pros and Cons
- Easy to apply with consistent results
- Better UV protection compared to most oil-based stains
- Holds color longer than many penetrating oils
- Low VOC and environmentally friendly formula
- Easy to clean and recoat with proper prep
- Can sit more on the surface if over-applied
- Requires proper prep to avoid uneven absorption
- May not perform as well on very old, dry wood compared to oils
🔹 Best Wood Types for Restore-A-Deck
Best Wood Types for Restore-A-Deck Wood Stain
- Cedar: Very good color uniformity and protection
- Pressure Treated Pine: Excellent overall performance when prepped correctly
- Redwood: Good color enhancement and durability
- Very old, dry wood – penetrates very well
- Hardwoods (IPE, Cumaru, etc.) – excellent color retention
🔹 Real-World Testing & Photos
Restore-A-Deck Wood Stain – Real World Testing
Below are examples of Restore-A-Deck Wood Stain applied to different wood types and how it performs over time.
- Always apply to clean, properly prepped wood
- Do not over-apply, as this can lead to uneven drying
- Apply thin, even coats for best results
- Back-brush or pad for uniform coverage
- Applying to damp wood is easiest
- Recoat every 24 months depending on exposure
- Clean and brighten the wood before reapplying
- Avoid letting the coating fully wear off
- Light maintenance coats will extend the life of the finish
🔹 Who Should Use Restore-A-Deck?
Who Should Use Restore-A-Deck Wood Stain
- You want better color retention than traditional oils
- You prefer a water-based, lower VOC product
- You want a stain that is relatively easy to apply and maintain
- Your wood is in good condition and properly prepped
🔹 FAQs
Restore-A-Deck Wood Stain – FAQs
No, when applied correctly, it penetrates and wears naturally without peeling.
Is Restore-A-Deck oil or water-based?
It is a water-based penetrating stain.
Yes, as long as the wood is properly prepped to allow absorption.
It performs better than most oil-based stains in terms of UV protection and color retention.
🔹 Final Thoughts
Restore-A-Deck Wood Stain is a solid choice for homeowners looking for a balance between durability, color retention, and ease of use. While it does not penetrate as deeply as traditional oil-based stains, it offers better UV protection and longer-lasting color.
From my hands-on experience working with deck stains for over 30 years, this is one of the better water-based options available, especially for newer or well-maintained wood.
If you prep the wood correctly and stay on top of maintenance, Restore-A-Deck can provide consistent and reliable results without the issues associated with film-forming coatings.
Hi Linda, can you reply back and post some pics in the comments for prep help?
Goof or similar works best. They have some that are not aerosol.
The deck looks great!
Post a picture or two if you have time.
Will do.
Ken, can you try the pictures again when you have time. The issue with uploading images has been fixed.
Here are some photos.
Looks really good!
What shade color is this
Light Walnut
Light Walnut
Some more photos.
Used a semi transparent restore a deck 2 years ago and it is fading. Would a solid stain hold up longer? Also getting some sap coming up, is there an easy way to treat or prevent? Thank you!!
A solid may give a slightly longer lifespan. Sorry but there is no way to prevent sap from leaching out.
We used the Armstrong Stain a few years ago on front deck steps in the gray. We did the restore a deck cleaner and prep on the new wood that we had let cure. All seemed good except the color was very dark. I ordered a clear to mix with it for additional coats. Initially did 2 coats. Did not have to wipe any off and soaked in. The wood seemed to start crqcking and splitting over a year later. Cleaned again. The stain had gotten somewhat congealed in the 5 gallon container. SOOOO, I ordered another 5 gallon. Applied again. Steps got even darker. Splitting continued. Now beginning to wonder about the wood we were given which I had special curved fronts and ends done.Cleaned one more time a year ago and stained. The stain soaked in some places and others just sat until I wipped down. NOW!!! the steps have split a lot. My Hubby the retrofit Engineer is now flipping ALL 28 steps!!The underside is in much better condition and was never stained with the Armstrong. Now I have to decide How to paint the flipped steps. I am not sure all the drips from the Armstrong Dark Gray can be cleaned for just staining or to use a SOLID stain of some sort. The kicks are stained Armstrong Gray too. HELP!!! We live at the Beach in Alabama but not on the water. After Hubby flipped 28 steps X’s 2, (I wanted brand new) not sure what is best. HE wants the OIL again. My definition of Stupid. What is yours. I did contact Armstrong but they did not reply. I think I ordered products from you?? because it was rated very high awhile back.
Splits in exterior decking are normal, not an issue, and cannot be prevented. No need to worry about it. It is not an interior hardwood floor. Flipping boards is not needed and honestly just a time-consuming project that is not needed.
Armstrong Clark does not come in dark gray. We do not have any orders in your email address form from the past, so not sure where or what was bought prior. As for how to prep, add some pics in the comments for advice.
I am replacing pickets on three gates. The wood is rough cut redwood pickets. The red in the redwood pickets clash with my stucco house walls. I live in Arizona zip code 86326. Do I need to by law only order low VOC stain? What dark brown stain can I use to cover the redwood reddish-pink color? How much to ship a gallon to my zip code? Can I use TWP semi-solid tint base? Is Foghorn the darkest brown? I only want to cover the reddish-pink, and if the result is a brown shade of any kind I will be happy, as long as it covers the underlying pink. Thanks
If in Phoenix, you need a low-voc stain. You could use the TWP semi-solid in the low-voc version. Foghorn is pretty dark.
Hi, I am building a pergola and I live in California. The most easily available wood speciesis Redwood. However, I don’t actually like the red toned wood. Any suggestions on how to knock the red tone down? Or is it just better to use more of a solid?
The natural color of your wood is red, so you cannot reduce the red tone when using a lighter transparent or semi-transparent stain. Maybe a dark brown color like Dark Walnut would work.
I am completing construction of my new house after a year of construction. My deck is pressure treated yellow pine and I have done nothing to it. I have been waiting until all the work on the house was done. I live in the middle Georgia area, my deck is on the East side of my house and fully covered. What stain would you recommend for maximum protection and maximum durability?
The RAD Stain would be an excellent choice. Make sure to clean and brighten the wood for prep to remove any oxidation and mill glaze.
Hi. What’s the maintenance process for Restore-A-Deck Transparent Stain? Do you have to strip it off and reapply in a year or two or can you apply a touch-up coat over existing stain?
Clean and brighten for prep when recoating.
Looking for recommendation for our deck.
Southern MD
7 years old / never been treated
Treated pine
50/50% sun/shade sun in hottest part of day
Have mold/mildew issues
Bought Restore-A-Deck cleaner and brightener 3 yrs ago – life has other plans 😑
Thank you for your willingness to share your expertise!
Use the RAD prep, it should still be good. Stain with the Restore-a-Deck Semi-transparent stain when done.
Hi! We are needing a bit of advice regarding refinishing some large posts, corbels and headers on our southwest facing front porch in eastern Tennessee.
The house is relatively new, finished in 2022. We believe the pine posts were stained with an oil-based Minwax interior stain in Early American and then sealed with Minwax Helmsman Spar Urethane to match the T&G wood porch ceiling. The clear urethane coat and stain on the vertical surfaces is now failing and peeling extensively, especially in areas of highest sun exposure. The ceiling is still intact so we are hoping to avoid refinishing that, however matching stain colors could be challenging.
We would like to remove the current stain and clear coat on all non-ceiling surfaces and refinish the with a stain that does not have a clear coat to simplify future maintenance. We are thinking we may need to remove, strip or sand and stain the large corbels separately so it will be a time intensive project. Since both current products are oil based, it is our assumption that we would need to stay with an oil based stain. We were considering either the TWP 100 in 120 Pecan or possibly the TWP Semi-Solid in something like the color Musket but are open to any recommendation you may have. We’d be happy to order samples based on your suggestion.
With the peeling urethane, is our only option to completely sand to remove all previous product? If so, would prepping with a brightener afterwards be sufficient or would we still need to do the cleaner, as well? Thank you so very much for your informative website and help!
You will need to power sand or use a paint stripper, such as the RAD PaintStrip, to remove the poly. You can test it on this link:
https://www.deckstainhelp.com/product/rad-paint-solid-stain-stripper-sample-size/
If you sand, do not use a finer grit than 60-80 and brighten afterward.
Once removed fully, you can use water or an oil-based product.
If I spray the RAD stain on my privacy fence do I also need to use a sealer?
No, and you cannot apply a sealer over the top of a deck stain. It would peel if you tried this.
Is restore a deck available in Ontario?
Online sales only.
Hello we live in Phila pa and installed a new pressure treated deck in Oct. It gets sun all day long and goes down to a smaller pool deck. I am so confused about what stain to use. Leaning towards either the TWP 1500 oil base or the RAD semi solid stain. In your opinion which would hold up better? I watch the video on the RAD prep and coating, didn’t see one on the oil base.
I have always used oil base in the past but with the newer VOC regulations not sure if it’s worth the extra hassle.
Do you also have the tools list to apply the stains, we used to use paint brushes.
Please help…. Appreciate this website.
Both TWP 1500 and the RAD stains are excellent. One does not last longer than the other. Both can be cleaned and recoated as needed since they are penetrating stains.
For applicators, look at the yellow flooring brush for floors and stain pads for the verticals.
https://www.deckstainhelp.com/product-category/brushes-stain-pads-sprayers-and-tools/
Do you have a video of you guys with oil stain application. Thanks for your help, can’t wait to get it done.
Sorry, but we do not.
Do you think i would have to use both cleaner and brightener?
Yes, you need both.
Sorry Scott final question. With either TWP 1500 or RAD on new deck do i need 2 coats?
One coat for new decks.
not sure how to figure Railing as it is a shadow box of 1 x 6. Has to take more than a regular railing. Any ideas?
Length x width x 2=?
Scott, I’m going to purchase 2 5 gallon pails if I don’t use one of them and don’t open it how long will it last?
If I do open it, how long will it last?
2-3 years unopened, about 1 year if opened.
Scott. I stained stripped and neutralized deck with TWP low VOC semi solid stain. Stain took well and dried fast. Just wondering if adding a sealer would brighten up the flat finish a bit and benefit the weather protection at all without negative consequences for refinishing in the furure
It is not possible to add a sealer over the top of a deck stain. It would peel if you did this.
We followed the prep and application instructions but the Rad semi-transparent stain is taking a while to cure. It’s been almost a week and still a little tacky when in the sun and temps rise but hopefully it will cure soon. We also had rubbery balls form when we were brushing it on so now that’s in the finish. Don’t know why this happened. When we pull the bigger balls off the stain lifts. Feels gritty under foot. Is there anything we can do now? or just wait until it wears and then maybe lightly sand off the balls, clean, and brighten before reapplying another coat? If you think wait, should I go around with an artist brush and apply a little stain to each of the bare and? Thanks for your help.
It looks like you overapplied slightly. The RAD is designed to fully penetrate the wood. In your pictures, it looks like it dried on top. This is the main reason for taking longer to cure. I have never seen the balls before. Maybe something in your brush got in the stain? I would suggest leaving it as is and addressing it as needed when you recoat.
Ok thanks. To address it at recoating time do you think we could use an orbital sander on low to knock off the balls and lightly blend the pock marks with the remaining stain, then clean, brighten and recoat- with no need to strip? And we’ll know it’s time when the stain is wearing off in any places at all or water no longer sheds? Reapply stain 1 or 2 coats? Thank you again.
It is best to wait and see how it weathers due to the overapplication. Address how to prep and coats needed when it is time to reapply.
It will look faded and or worn. The need to bead water is a myth and not an indication of time to reapply.
My redwood deck is 6 months old.Do I need to the cleaner/brightner before staining with the RAD brand?
Yes, you need to prep:
Hello, I ordered the RAD sealer today along with the cleaner and brightener. But due to timing with weather I really need to clean and brighten this week ahead of the delivery. I sourced another brightener locally with oxalic acid which should work? I can’t find a cleaner to buy locally with the same chemicals as RAD cleaner. Can I use Oxiclean powder with the RAD sealer and get a good clean or is there something else better sold in big box stores? Our deck is very gray. Thank you
Regular oxalic acid is not the same as the RAD Wood Brightener. Same with the Cleaner. The RAD Cleaner is much more advanced and has better performance that oxiclean. You may run the risk of something going wrong.
This is what I’d love to see when reading this:
Step-by-step implementation, including links to the tools/products.
This would be a great opportunity for affiliate revenue too!
I have a 22 year old porch swing that hangs from its own trellis/pergola that my husband and I started working on yesterday. It is made of pressure treated wood and had never been stained before this. We cleaned and brightened it in the morning, then started the staining process in the afternoon when the wood seemed the right dampness. We worked on it til bedtime and still didn’t quite finish the first coat. Now of course it’s completely dry. Should I dampen the “raw” areas before I stain them? Can I put a second coat on? I had no idea it was going to take us so long. The lattice panels on each side were very tedious. I am using the RAD semi transparent stain.
-If you apply a second coat, it needs to be applied wet on wet. Basically 20-60 minutes after the first coat.
-You can mist with water before applying the first coat.
-A pump sprayer for applying to lattice works well. Spray on and back wipe drips right away.
Sunday applied RAD dark walnut semi-transparent water-based stain on prepped wood of western red cedar deck. Only finished 1/3 of 360sf. It was done in the morning while air temperatures and sunshine were lower. Monday, I started early again at about 65 degrees and cloud cover was helpful. As the day waxed on, air temp went to a high of 81 degrees and full sun appeared. Rain expected at 2pm on Tuesday so I kept working to stay within the window. That was a mistake. I was trying to keep color uniform, but it became very dark, more like mahogany. Please see pictures attached.
Can you recommend a way to even out the color by either darkening the light area or (much more preferably) lightening the dark area? The cedar is 11 months old, originally light-sanded to remove mill glaze and stained with Behr Premium Transparent Waterproofing Wood Finish Penetrating Oil. A month ago, I stripped and brightened the wood to change the color since it appeared dirty and orange-ish. Pressure washing did not clean it up and I removed too much of the finish. I wanted transparent to show the beauty of the wood, so you recommended RAD Natural or TWP 1515 Honeytone. A good suggestion, but I changed my mind to go with the RAD dark walnut thinking it would hide the dirt better. Lovely color, but I messed it up. Can you help? See pictures of original unfished and recently stained.
Hi Bob, the only way to fix this is to remove it and start over.
Admin question: Is there an easy way to view the question I posted? And, an easy way to check to see if it has been answered? Please offer instructions. Thank you!
When questions are answered, you will get an email with the link to view.
Hi Scott, how should I wash discoloration off my deck from a floor mat and umbrella base before I begin staining? Already stripped and brightened/neutralized about 5 days ago. Gonna use Restore-A-Deck Semi-Transparent Wood Stain. Been raining a lot, but it hasn’t washed away the dirt from base or fading from floor mat.
Those are deep stains in the wood and will not come out. Not an issue of mat and umbrella go back in the same spots.
We’re ready to begin our deck clean, brighten, stain project using RAD products. Lots of Pine Pollen right now. Should we wait a few weeks?
We would. Pollen if trapped in the stain wile drying can feed mildew.
The stained deck looks great after applying the cleaner, brightener and stain. I followed all the instructions. However, I’ve noticed that if I am wearing just socks on the deck that the stain shows up allot on my socks. It concerns me since I do not want to bring the stain onto the indoor house carpet and floors. Was I suppose to apply a wood sealer after the stain was applied ?? What else could be the problem ?
No, you cannot top coat over a deck stain. The RAD stain is fully curing so it could be that it has not cured yet. How long it takes to fully cure varies based on temps, humidity, and how thick you apply it.
Thank you for your quick response. I’ll give it more time to cure and see if that solves this issue.
HI, What is the difference between Defy essential semi-transparent stain and Restore-a-deck semi transparent stain? Are they equivalent products? Between these two which would you recommend and why? Thanks
We use the RAD Stain all the time and have not had any issues. It can be applied same day as prep and saves us time and money. With the Defy products, we like the Extreme the best and would use that over the Essential.
We would suggest the RAD stain over the Defy Extreme.
It is also still quite sticky after 40 hours
You may have over applied some but it will cure out and fully dry.
Can I do anything with the color? Also there’s drips on the sides of the steps, should I sand and restrain those areas?
No, you cannot do anything about the color. Actually I think it looks great! It will tone down a little as it cures over the next week or two. You can sand and fix the drips.
We put two coats of the natural color stain on the deck, after the cleaner and brightener, and it is way more orange than the sample color I had put down. Is there anything I can do to tone down the orange?
No, it is not possible to tone down a deck stain but it should tone down a little while it fully cures.
If you use an airless sprayer to apply RAD semi-transparent stain to vertical walls should you back brush as you apply or, just spray without back brushing? Is 1 coat usually sufficient on walls or should I plan on 2 coats? Thanks, Mike
Yes on the 2 coats and back brush the second coat. Easy to do.
What about if using RAD semi trans on a deck- just spray first coat and spray and back brush second coat or backbrush both coats?
Either is fine, but decks are easy to apply. Both coats are wet on wet with a floor brush or stain pad.
