Restore-A-Deck Wood Stain Review 4.6/5 (53)
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Restore-A-Deck Wood stain review is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain tips. See here for more info about me.
Restore-A-Deck Semi-Transparent Deck Stain Review
Restore-A-Deck Wood Stain is a water-based penetrating stain designed to provide good color retention while still allowing the wood to breathe. It is a newer generation stain compared to traditional oils and is designed to be more environmentally friendly while still delivering solid performance.
From my experience restoring decks since 1993, Restore-A-Deck performs best for homeowners who want a balance between ease of use, durability, and longer-lasting color. It does not penetrate as deeply as oil-based stains like TWP, but it makes up for that with better UV resistance and more consistent color.
In 2017, our first full year using the Restore A Deck stain, we had no performance issues and saved a tremendous amount of time by prep and stain on the same day. We will continue to offer the Restore A Deck Semi-Transparent Wood Stain as one of our go-to decking stains for the 2026 restoration season.
Overall, Restore-A-Deck is a very good choice for those looking for a low-maintenance, water-based stain that performs well across a variety of wood types.
Note: Restore-A-Deck Semi-Transparent Wood Stain can be applied to dry or damp wood. Applying to damp wood allows you to prep and stain on the same day, saving you a tremendous amount of time.
8.63 Overall Rating Restore-A-Deck Stain
🔹 Quick Verdict
Restore-A-Deck Wood Stain – Quick Review
  • Best For: Homeowners wanting better color retention and easy maintenance
  • Not Ideal For: Those wanting maximum penetration on older wood
  • Type: Water-based penetrating stain
  • My Overall Rating: 8.63/10
Restore-A-Deck is one of the better-performing water-based stains I have used. It offers solid durability and color retention while still being relatively easy to maintain. This is one of the easiest products to apply, and it’s featured in our list of the best deck stains for most decks.
Restore-A-Deck Semi-Transparent Wood Stain is an advanced, water-based, semi-transparent stain formulation designed to penetrate deep into wood pores for maximum protection and longevity. Restore-A-Deck Wood Stain protects the wood from harmful UV rays and damage caused by water penetration. Restore-A-Deck Semi-Transparent Wood Stain is safe to use, has a low odor, and is easy to clean up with soap and water. It is ideal for all wood types including pressure-treated pine, cedar, fir, or redwood.
Recent advancements in water-based wood stain technology have allowed the active ingredients in the Restore-A-Deck Stain to offer better UV protection, excellent penetration into the wood grain, and the ability to apply to damp wood. All this is available in five beautiful semi-transparent colors highlighting the natural wood grain.
RAD Wood and Deck Stain will increase all exterior wood surfaces’ life, appearance, and durability. With the easy-to-apply and maintain Eco-Safe formula, you’ll be able to finish faster and enjoy your exterior wood or deck for years.
Restore-A-Deck Wood Stain Ratings (1-10)
How I Rated Restore-A-Deck Semi-Transparent Wood Stain
My Restore-A-Deck Semi-Transparent Wood Stain review contains an 8-step process and the final average score. Each step is on a scale of 1-10.
  1. The appearance of Restore-A-Deck Semi-Transparent Wood Stain after Application
  2. Preventing UV Graying
  3. Peeling or Wearing
  4. Cost Per Square Foot
  5. Preventing Mold and Mildew
  6. How Easy was the Restore-A-Deck Semi-Transparent Wood Stain Application
  7. Color Shifting
  8. Ease of Reapplication
  9. Restore-A-Deck Semi-Transparent Wood Stain Final Score
8-Step Review of Restore-A-Deck Wood Stain & Sealer
1. Appearance After Initial Stain Application: 8
The Restore-A-Deck wood stain color we used was the Semi-Transparent Light Walnut. The initial appearance was a rich brown with a hint of red (see pictures below) after drying. The Restore-A-Deck Stain penetrated extremely well into the wood grain on our test deck. No surface film on top of the wood.
2. Preventing UV Graying at 2 Year Mark: 9
Restore-A-Deck had little to no fading at the 2-year mark. Excellent color retention should be achieved through years 2-3 as well based on initial pictures and testing. See below for a picture.
Restore A Deck Stain One Year
3. Wear/Tear and Peeling: 9
4. Cost Per Square Foot: 8
We applied two coats to our 150 sq foot deck, including all railings and steps. Less than 1 gallon was used for this at a total cost of $40. This equates to $.30 a square foot. Very reasonable pricing and better than most other top brands.
5. Preventing Mold/Mildew/Algae: 10
Like other water-based deck stains, the Restore-A-Deck Wood stain will not promote mold or mildew growth. This is one of the primary advantages of using a water-based coating. At the 1-year mark, the deck showed no signs of any mold or mildew.
6. Ease of Application: 9
Our favorite aspect of the Restore-A-Deck Wood stain is the ability to stain and prep on the same day! We tested this by cleaning and brightening the wood with the Step 1 and Step 2 Restore A Deck Cleaner/Brightener Kit and then applying the RAD stain 1 hour after the prep. The wood was visibly wet on a few deck areas and damp to the touch throughout. The Restore-A-Deck actually applied more easily to the damp wood than any other water-based stain that we have used previously. We also found that the coverage was better when applied to damp wood. In theory, the stain will absorb better when applied to damp wood. The water “swells” the wood pores and “pulls” the stain deep into the wood as it dries.  Applying to damp wood will also help avoid potential issues with Applying a Deck Stain in Full Sun.
See before and after pictures below.
7. Color Shifting (darkening) after 2 Years: 8
As expected, the Restore-A-Deck stain darkened very little and did not shift color. See the picture at the 2-year mark above.
8. Difficulty of Reapplication: 8
The Restore-A-Deck will be an easy clean and reapplication as needed.
Overall Score Restore-A-Deck Stain at 1-Year Period: 8.63
– The Restore-A-Deck is an awesome exterior wood stain and has shown the ability to outperform other water-based and oil-based wood stains. Restore-A-Deck’s 3-Step system allows you to save time and money when restoring your exterior wood and decking. No other system that we have used or tested has allowed the ability to Prep and Stain in the Same Day. If you are looking for the future of exterior wood and deck stain, consider the Restore A Deck Wood Stain and their prepping system.
$51.99
More Info: Restore-A-Deck Wood Stain
Cost: $47.99 per Gallon,  $219.99 per 5 Gallon Pail. Products ship free on their website.
Available Colors: Natural, Cedar, Light Walnut, Dark Walnut, Cottage gray
Coats Required: 2 Coats. “Wet on Wet” for older wood. New wood = 1 Coat.
Dry Time: 2-4 Hours
Cleanup: Water
More Info: Product Data
Manufacturer: Restore-A-Deck
UV Exposure: 50% Full Sun
Light Walnut
🔹 Pros and Cons
  • Easy to apply with consistent results
  • Better UV protection compared to most oil-based stains
  • Holds color longer than many penetrating oils
  • Low VOC and environmentally friendly formula
  • Easy to clean and recoat with proper prep
  • Does not penetrate as deeply as oil-based stains
  • Can sit more on the surface if over-applied
  • Requires proper prep to avoid uneven absorption
  • May not perform as well on very old, dry wood compared to oils
🔹 Best Wood Types for Restore-A-Deck
Best Wood Types for Restore-A-Deck Wood Stain
  • Cedar: Very good color uniformity and protection
  • Pressure Treated Pine: Excellent overall performance when prepped correctly
  • Redwood: Good color enhancement and durability
  • Very old, dry wood – penetrates very well
  • Hardwoods (IPE, Cumaru, etc.) – excellent color retention
🔹 Real-World Testing & Photos
Restore-A-Deck Wood Stain – Real World Testing
Below are examples of Restore-A-Deck Wood Stain applied to different wood types and how it performs over time.
  • Always apply to clean, properly prepped wood
  • Do not over-apply, as this can lead to uneven drying
  • Apply thin, even coats for best results
  • Back-brush or pad for uniform coverage
  • Applying to damp wood is easiest
  • Recoat every 24 months depending on exposure
  • Clean and brighten the wood before reapplying
  • Avoid letting the coating fully wear off
  • Light maintenance coats will extend the life of the finish
🔹 Who Should Use Restore-A-Deck?
Who Should Use Restore-A-Deck Wood Stain
  • You want better color retention than traditional oils
  • You prefer a water-based, lower VOC product
  • You want a stain that is relatively easy to apply and maintain
  • Your wood is in good condition and properly prepped
🔹 FAQs
Restore-A-Deck Wood Stain – FAQs
No, when applied correctly, it penetrates and wears naturally without peeling.
Is Restore-A-Deck oil or water-based?
It is a water-based penetrating stain.
Yes, as long as the wood is properly prepped to allow absorption.
It performs better than most oil-based stains in terms of UV protection and color retention.
🔹 Final Thoughts
Restore-A-Deck Wood Stain is a solid choice for homeowners looking for a balance between durability, color retention, and ease of use. While it does not penetrate as deeply as traditional oil-based stains, it offers better UV protection and longer-lasting color.
From my hands-on experience working with deck stains for over 30 years, this is one of the better water-based options available, especially for newer or well-maintained wood.
If you prep the wood correctly and stay on top of maintenance, Restore-A-Deck can provide consistent and reliable results without the issues associated with film-forming coatings.
866 Comments
Brandon
Brandon
Richard & Irene Garipoli
Erin
Erin
Irene Garipoli
Irene Garipoli
Reply to  Erin
Erin
Erin
Reply to  Irene Garipoli
Elaine Booth
Elaine Booth
Steven Murillo
Steven Murillo
Ken Tidwell
Ken Tidwell
Ken Tidwell
Ken Tidwell
Will do.
Ken Tidwell
Ken Tidwell
Here are some photos.
Tina
Tina
What shade color is this
jean eustice
jean eustice
Ken Tidwell
Ken Tidwell
Reply to  Ken Tidwell
Some more photos.
Deck Finishes, Stains, Sealers,
Kathy Yancey
Kathy Yancey
I am looking for a product to seal cracks and splits in my wood deck before staining or painting my 30 yr. Old wood deck. I’m on a fixed income and can’t afford to replace it. Thanks for your help.
Joan
Joan
I am so confused with all the options to prepare and stain my deck. My deck is about 20 years old and hasn’t been stained in about 4 years. Looks like it is pressure treated wood. It has some cracks in boards and some areas are green/blackish and gray. Do I just need a cleaner or also a brightner and stripper. Also, should I use a semi-transparent or semi-solid stain since it is so old and worn. Do you recommend one or the other. I like to see a little wood but since it is so old and has so many cracks, I may need to go with semi-solid. I’m not ready to replace the entire deck and would like to see if I can make it better for a couple of years at least. Thank you for your help and guidance.
Joan
Joan
I used RAD and TWP 1500 in 2014 (new deck) and 2018 and have been pleased with the product. I did not use a maintenance coat each year because of cost (900sf deck=$200+ see attached picture of where a potted plant was located on the deck.#1) I live in Raleigh, NC and I have a few questions before I stain my deck this year.
  1. What is the main difference between TWP 100 and 1500? Pro and Con,
  2. What is the main difference (other than H20 base and able to apply on a damp/wet deck) between TWP and your stain (RAD), Pro and Con
  3. I recently purchased RAD (stripper) but at this point have hesitated on purchasing my stain.
  4. With either must I use a cleaner and maintenance coat each year to preserve “the original look.”
  5. Attached picture from 2018-#2. On further examination I think I should have stripped it rather than cleaned it….?
  6. Interested in your recommendation
Thanks in advance,
Darren Vardy
Darren Vardy
how many square feet does a gallon cover on a pressure treated deck
Tim
Tim
I’ve inherited a wood deck that’s not in horrible shape, but I’d like to get it to the point where it’s as good as it can be. It looks like it’s had multiple layers of paint, not stain. Pictures attached and any suggestions appreciated – great site!
Dianne Woody
Dianne Woody
I am staining a deck that has new and old wood both on it. Do I need a solid stain or will a semi-transparent blend both together to be same color?
Troy M
Troy M
Which RAD color best matches the pre-stained pressure treated cedar tone wood? Also, can this PT cedar tone wood be re-stained after a couple years? Meaning will it hold new stain?
I am staining a redwood fence. Will this last as well as an oil based stain such as TWP? Does re-application require stripping, or only clean, brighten and reapply?
Thanks! I plan to use a pump sprayer and back brush. Would you recommend a pad or your yellow brush for the back brushing?
Trina Scott
Trina Scott
Seriously considering using this. Should I pressure wash with diluted bleach water prior to using the deck wash, in order to remove the dark black and green moldy areas? Or, will the deck wash do the job?
Trina Scott
Trina Scott
Which product goes in the pressure washer and what ratio. Thanks a big bunch for your help and advice. So glad I found you today.
Marcie Roth
Marcie Roth
How is the color retention on ipe? How long after application is that gorgeous photo of the fence? Would I need to re-apply this every year? (NYC winter). Really hoping to find something that can looks good longer than 1 year!
Troy M
Troy M
I stained my cedar/PT framed deck with RAD light walnut several days ago. The pressure treated joists look lighter colored in some areas where I must have applied it too thin. Can I put another coat on to darken it up or do I have to wait til it weathers some? Directions say recoat within 60 minutes… most of the PT joists have a good color so I know it is applied too thin and not differences in the wood. Great product and great resource, Thanks
Troy M
Troy M
Thank you! Again, fantastic resource!
Janette Elliott
Janette Elliott
I’m wondering if there can be a long period of time between stripping old stain using your stripping product and completing the cleaning, brightening and new staining process. And when I say long period I mean. Can I strip now and leave bare for several months.
(I have new wood that needs to be weathered and old wood needs to be stripped all together in the same project, trying to be efficient)
S white
S white
New pressure treated pine deck last year, cedar posts and black aluminum railing. Deck has cured now for 12 months. I know it needs to be cleaned but does it need to be brightened? Do i use 1 coat of restore a deck for new deck and reevaluate next year? Cedar posts were stained in oil base before install and are rough hewn..will stripping the cedar posts damage the railing? Please advise and thanks for your help.
Janette Elliott
Janette Elliott
Thanks for this very helpful and informative site and feedback. Now. Once I’ve weathered my wood for minimum 3 months. Is there a minimum number of dry days “without rain” that should occur to allow for some “drying out or just as the article says, damp but not wet it pooling? I guess what I’m really asking is can I really stain in the fall with the semi transparent if the temperature are mild enough and the deck has received rain.
Janette Elliott
Janette Elliott
I live on the rainy west coast Vancouver British Columbia. Hot sunny summer. But plenty of rain throughout the year. I have removed all my old cedar deck boards to be planed, trimmed and I have additional new dry cedar that I will be using for an addition. I originally was going to use the oil based stain but after seeing the restore a deck in action I think that I might choose to use it. Given our mild, rainy weather. What would you recommend, and do I have to do anything else to prep the wood after planing.
Janette Elliott
Janette Elliott
So just to clarify, are you saying that once sanding or planing occurs to wood that has already bybeen on the deck (ie weathered). Then weathering must be done again? We are going into wet weather season again. Once these planks are planed, and unprotected they will be potentially exposed to rain and sun in unknown amounts, and will absorb a lot of water.
Craig Sickles
Craig Sickles
i have a new deck around my above ground pool, built in Dec 2020. we live in North Central Ohio, so we get all kinds of weather. it is pressure treated lumber. i think it ready to stain. It is in full sun and we have railings. My wife wants to apply White stain to the Railing, then Gray to the deck floor. Also beneath the deck floor, we have treated lumber to act as skirting for toy storage and etc. Me question is what would you suggest for the spindles, the top railing, and the skirting, and for the deck itself?
Donna
Donna
I have just ordered 5 gallons of RAD solid. 1) Why do I need a brightener if I am using a solid color?. 2) what product can I use as a wood filler to fill in some holes from the knots and screw indentations? ALL your advice is greatly appreciated. THANK YOU.!
Donna
Donna
Would the “wood prep for decks” the same as the “brightener”. Thank you again for all your helpful advice.
Donna
Donna
ok..thank you.
mike
mike
we do not want colour but clear deck stain for Haliburton harsh Canadian winter
what is best?
Keturah Swank
Keturah Swank
Do you happen to have any photos of RAD Dark Walnut? We are looking for a dark brown. The little swatch of color on their website seems as though it’s not all that dark but hard to say. Couldn’t find a “photo album” on their site like other companies. Thanks
Heather Fry
Heather Fry
Hi there,
We have about 500sq ft on our cottage deck. The deck is cedar and over 20 years old. Some boards have been replaced over the years. It has been stained several times. For the last 10 years we have been using Cabots Australian timber oil. It really deserves and needs a refresh. I am not looking for perfection but a little more continuity would be nice.
When I can across your video – it gave me hope. I absolutely love the idea of not having to wait for significant drying time! I don’t know if anything like this sold in Canada.
However, in your opinion how would your stripper and brightner and stain refresh our deck considering it’s age? Also , because we are in Canada knowing how much would be needed of each product would help me. For example, would we need double of one of the products to improve it? Or would each step just have to sit longer to get the best results? I have attached a pic of one part of the deck.
Thanks for any advice and for answering all my questions.
Cheers,
Daniel W Bigger
Daniel W Bigger
If the semi transparent stain gets on painted trim, can it just be painted over to cover?
Martin
Martin
Just stained with RAD Semi transparent stain. Do I need to do the whole cleaning next year to recoat or just some mild detergent.
What if I need to sand a little before applying the stain, do I dampen the deck after sanding?
Martin
Martin
Should water bead on RAD semi transparent water based stains afterwards?
Martin
Martin
Thanks for the quick reply
Larry Rudisill
Larry Rudisill
In the video above, was the stain that you stripped an oil-based stain?
STEVEN MISCHKE
STEVEN MISCHKE
I have a deck that is 10′ X 16′ with a set of 4 steps that lead to the ground. There is one handrail on the steps and a handrail with balusters on three sides of the deck.
The balusters are 39″ long and 2″ X 2″ square. The top rail and bottom rail are of a 2″ X 6″ redwood.
The deck, steps, handrail, balusters are all new redwood.
How much of the stain will I need to cover the deck two times?
How long do I need to wait between coats of stain?
Jane S Hatter
Jane S Hatter
I used an oil based stain two years ago. Can I use a Restore A Deck water base semi-transparent stain now and will it penetrate into the wood?
Jane S Hatter
Jane S Hatter
the decks have been pressure washed twice. Is that sufficient? (please say yes, please say yes) 😊
Jerome
Jerome
Can I use the RAD Semi-Transparent stain on a deck that still has some stain color after prepping with a pressure washer or does the deck need to have all stain removed?
William J Moore, Jr
William J Moore, Jr
Great web site. What is the Restore-A-Deck stain color used on the picture of the horizontal fence titled “Stain IPE Fence
Kay Ogborn
Kay Ogborn
Where can you get this stain
Yvonne Holloway
Yvonne Holloway
When you say it can be applied to a wet deck, does that include rain? We’re having trouble finding a dry spell for staining.
Amanda
Amanda
I got a bit ahead of myself today and over-sanded my deck. I power washed it yesterday, then sanded it today. Its about 10 years old and was not maintained by the previous owners. I started with 80 grit then went to 120. I am looking online and many people are saying 120 is too much. Should I do back and sand it again with 80 grit to make it a bit more rough?
thanks
Mary Kay
Mary Kay
I live in Windsor, Ontario, and have a deck that is 1 1/2 years old. It faces southwest, and gets the afternoon sun. It is made of pressure treated wood in the Sienna colour. I plan to stain it for the first time using the Restore-a- Deck semi-transparent stain (after using their cleaner and brightener). I am having a hard time deciding between the cedar and light walnut colours. 1. In your opinion, which might go best with the Sienna colour of wood? 2. Would the cedar look too orange? Please and thank you!
Mary Kay
Mary Kay
Thank you. I am also wondering when it is best to do any spot sanding on rough spots. Should I do it, then wait a couple of weeks to clean, brighten, and stain? Or spot sand between the cleaning and brightening?
Mary Kay
Mary Kay
Thank you….one more question. Re: staining a deck for the first time that is 1 1/2 years old, and gets a lot of sun. Should I do 1 or 2 coats. I appreciate your help!
Mark Huntley
Mark Huntley
What’s your preference, RAD or Defy Extreme? Had lots of darkening and mold problems with Armstrong, so thinking of trying something else. Pacific northwest so lots of rain and winter shade. Looking for durability, ease of application and ease of re-coating a couple years down the road.
Larry
Larry
How is it on the re-application, when it is time to re-apply the stain? Do you just clean and add a new coat? Is one or two coats needed at this time?
Eric
Eric
I have a 5-year old Cedar deck that has just been sanded. I’m finding myself needing to strip/sand every year as the stain I’ve been using just doesn’t last that well through the winter without some graying/silvering showing through. I’m in Ontario Canada. Looking for something that I can get a few years out of between re-applying and I’ve come across the RAD product which seems to be getting good reviews. Given this is a newly sanded deck, should I also be using the cleaner/brightener combo before staining (going for the natural semi-transparent)? Also, how many coats of stain given it’s just been sanded? Thanks!
Andre
Andre
Where can we buy this product in Canada
Jon Boright
Jon Boright
I’m have some locally milled Eastern White Cedar 5/4 boards that I’m going to use for decking in a treehouse (about 100 sf). It was milled last November so it’s still relatively green. I purchased it over the winter (January), planed it to consistent thickness, and stacked it in my garage (well stickered). I’ll still need to rip it to a standard width and round the edges (probably with a router?). So my question is should I stain it before installing it? Or is the moisture content probably still too high for that? I’d much rather use a water-based product and RAD looks promising…
Angelina Copen
Angelina Copen
Can you tell me what color stain is the 3rd photo down, with the gray house and brick wall.
Martina Sutton
Martina Sutton
But that photo looks same as Ken Tidwell’s photo and he says he used light walnut color. Which is it really – light walnut or cedar?? I also want to use same color so I want to be sure which one to order.
Felix
Felix
Thank you for all the valuable info that you share on your site! Following your advice, I let my eastern cedar deck age for about one year. Then prepped (cleaner and brightener) and stained using semi transparent natural restore a deck stain.
Should I reapply more stain now that a full year has passed? Some areas look a bit blotchy. I also don’t love the yellow tint and wish I could keep the redish natural color of easter cedar. Can I change the stain and just ad cedar semi transparent from RAD or should I stay with the natural semi transparent I already used?
Thanks again!
Felix
Felix
Thank you! And what do you think would happen if I apply the same brand cedar stain but on top of the natural stain without stripping it?
Hello, can I strip cedar decking that has RAD water based stain to apply RAD oil based stain?
Tony Broach
Tony Broach
Hi, Can I spray the RAD semi-transparent stain on with a pump up sprayer? I am planning to use the cleaner and brightener. I have a 450 sq ft deck only 6 months old with railings, stairs and underpinning, and it would take forever to paint with a brush. I have read most of the reviews and no one is clear about it.
Thank you so much for your time!
M. Charles
M. Charles
Question?: I want to stain my new pressure treated wood steps (installed 9/19/2020) with Restore a Deck. Do I have to clean and brighten first and will rain ruin it if the stain isn’t completely dry?
Charlie
Charlie
I am putting in a new redwood fence and will be applying Flame Stop II.
Any thoughts on how RAD will do in terms of a stain after the Flame Stop has dried?
I would test on a board before doing on the fence, but not much sense buying RAD if it’s just going to fail.
Kal Wun
Kal Wun
Not sure if my question got through. My first question is can I use your product on a side fence rather than a deck. Secondly, my contractor mistakenly stained the pine wood side fence using a very dark shade. Can I use your product to remove the dark stain to restore the natural pine look?
Thanks in advance!!
Kalpana Wunnava
Kalpana Wunnava
Thank you so much for the message. We yard Olympic brand water based stain. Attached are some pictures. One side was stained twice and the other side once.
Appreciate your time on this.
Pat
Pat
We have cedar siding painted with a water based acrylic stain. Would the acrylic stain need to be stripped before applying this? Presumably all the acrylic stain would need to be stripped If I used Armstrong Clark oil based stain
Denise
Denise
We have a 45 year old cypress deck that’s still in pretty good shape. We’ve replace a few boards, also with cypress. It was treated yearly with Cuprinol for about 25 years so it was a pretty weathered gray. It was neglected for about 5 years, then it was stained brown. That has finally faded and we’ve begun to clean and brighten it. Some boards have been replaced. I’ve been testing various stain products on the deck, from clear, to semi-transparent, to semi-solid. My hope would be to get it back to a natural weathered gray appearance, but I realize that a lot of time has passed and the wood has been neglected. Would your cottage gray provide a natural look? Another option would be to match the deck to the house (which is cedar siding with Cabot Seacoast Gray solid stain), but that would obscure the wood grain and be too matchy-matchy. I don’t want to go brown again. The wood doesn’t have to look perfect. I’m really stumped. The photo shows old boards next to a couple of the new ones. Thanks for any advice!
Reply to  Denise
There’s an Eco Wood Treatment in a ‘silvery patina’ color similar to what parks use for the greyed treatment
Brian
Brian
Should I put a poly coat on my deck after I stain with RAD
Will this be compatable with a 14 yr. old deck , good condition that has been done only with Cabot clear oil coat and 1 time with Cabot semi transparent. Planning on prep with the remover from Cabots.
866
